[02:36:04] Completed 250000 out of 250000 steps (100%)
[02:36:16] DynamicWrapper: Finished Work Unit: sleep=10000
[02:36:26]
[02:36:26] Finished Work Unit:
[02:36:26] - Reading up to 64340496 from "work/wudata_03.trr": Read 64340496
[02:36:26] trr file hash check passed.
[02:36:26] - Reading up to 31737400 from "work/wudata_03.xtc": Read 31737400
[02:36:27] xtc file hash check passed.
[02:36:27] edr file hash check passed.
[02:36:27] logfile size: 193726
[02:36:27] Leaving Run
[02:36:29] - Writing 96432498 bytes of core data to disk...
[02:36:52] Done: 96431986 -> 91299420 (compressed to 5.5 percent)
[02:36:52] ... Done.
[02:36:52] - Shutting down core
[02:36:52]
[02:36:52] Folding@home Core Shutdown: FINISHED_UNIT
[02:36:52] CoreStatus = 64 (100)
[02:36:52] Sending work to server
[02:36:52] Project: 8105 (Run 0, Clone 42, Gen 0)
[02:36:52] + Attempting to send results [April 19 02:36:52 UTC]
[02:39:48] + Results successfully sent
[02:39:48] Thank you for your contribution to Folding@Home.
[02:39:48] + Number of Units Completed: 13
[02:39:49] - Preparing to get new work unit...
[02:39:49] Cleaning up work directory
[02:39:49] + Attempting to get work packet
[02:39:49] Passkey found
[02:39:49] - Connecting to assignment server
[02:39:49] + No appropriate work server was available; will try again in a bit.
[02:39:49] + Couldn't get work instructions.
[02:39:49] - Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
[02:39:58] + Attempting to get work packet
[02:39:58] Passkey found
[02:39:58] - Connecting to assignment server
[02:39:58] + No appropriate work server was available; will try again in a bit.
[02:39:58] + Couldn't get work instructions.
[02:39:58] - Attempt #2 to get work failed, and no other work to do.
[02:40:14] + Attempting to get work packet
[02:40:14] Passkey found
[02:40:14] - Connecting to assignment server
[02:40:14] + No appropriate work server was available; will try again in a bit.
[02:40:14] + Couldn't get work instructions.
[02:40:14] - Attempt #3 to get work failed, and no other work to do.
[02:40:39] + Attempting to get work packet
[02:40:39] Passkey found
[02:40:39] - Connecting to assignment server
[02:40:40] + No appropriate work server was available; will try again in a bit.
[02:40:40] + Couldn't get work instructions.
[02:40:40] - Attempt #4 to get work failed, and no other work to do.
[02:41:33] + Attempting to get work packet
[02:41:33] Passkey found
[02:41:33] - Connecting to assignment server
[02:41:33] + No appropriate work server was available; will try again in a bit.
[02:41:33] + Couldn't get work instructions.
[02:41:33] - Attempt #5 to get work failed, and no other work to do.
[02:42:55] + Attempting to get work packet
[02:42:55] Passkey found
[02:42:55] - Connecting to assignment server
[02:42:55] + No appropriate work server was available; will try again in a bit.
[02:42:55] + Couldn't get work instructions.
[02:42:55] - Attempt #6 to get work failed, and no other work to do.
[02:45:36] + Attempting to get work packet
[02:45:36] Passkey found
[02:45:36] - Connecting to assignment server
[02:45:37] + No appropriate work server was available; will try again in a bit.
[02:45:37] + Couldn't get work instructions.
[02:45:37] - Attempt #7 to get work failed, and no other work to do.
[02:51:01] + Attempting to get work packet
[02:51:01] Passkey found
[02:51:01] - Connecting to assignment server
[02:51:01] + No appropriate work server was available; will try again in a bit.
[02:51:01] + Couldn't get work instructions.
[02:51:01] - Attempt #8 to get work failed, and no other work to do.
[03:01:42] + Attempting to get work packet
[03:01:42] Passkey found
[03:01:42] - Connecting to assignment server
[03:01:42] + No appropriate work server was available; will try again in a bit.
[03:01:42] + Couldn't get work instructions.
[03:01:42] - Attempt #9 to get work failed, and no other work to do.
[03:23:03] + Attempting to get work packet
[03:23:03] Passkey found
[03:23:03] - Connecting to assignment server
[03:23:03] + No appropriate work server was available; will try again in a bit.
[03:23:03] + Couldn't get work instructions.
[03:23:03] - Attempt #10 to get work failed, and no other work to do.
[04:05:43] + Attempting to get work packet
[04:05:43] Passkey found
[04:05:43] - Connecting to assignment server
[04:05:43] + No appropriate work server was available; will try again in a bit.
[04:05:43] + Couldn't get work instructions.
[04:05:43] - Attempt #11 to get work failed, and no other work to do.
[04:53:45] + Attempting to get work packet
[04:53:45] Passkey found
[04:53:45] - Connecting to assignment server
[04:53:45] + No appropriate work server was available; will try again in a bit.
[04:53:45] + Couldn't get work instructions.
[04:53:45] - Attempt #12 to get work failed, and no other work to do.
[05:41:58] + Attempting to get work packet
[05:41:58] Passkey found
[05:41:58] - Connecting to assignment server
[05:42:03] + No appropriate work server was available; will try again in a bit.
[05:42:03] + Couldn't get work instructions.
[05:42:03] - Attempt #13 to get work failed, and no other work to do.
[06:30:04] + Attempting to get work packet
[06:30:04] Passkey found
[06:30:04] - Connecting to assignment server
[06:30:04] + No appropriate work server was available; will try again in a bit.
[06:30:04] + Couldn't get work instructions.
[06:30:04] - Attempt #14 to get work failed, and no other work to do.
[07:18:08] + Attempting to get work packet
[07:18:08] Passkey found
[07:18:08] - Connecting to assignment server
[07:18:08] + No appropriate work server was available; will try again in a bit.
[07:18:08] + Couldn't get work instructions.
[07:18:08] - Attempt #15 to get work failed, and no other work to do.
[08:06:21] + Attempting to get work packet
[08:06:21] Passkey found
[08:06:21] - Connecting to assignment server
[08:06:21] + No appropriate work server was available; will try again in a bit.
[08:06:21] + Couldn't get work instructions.
[08:06:21] - Attempt #16 to get work failed, and no other work to do.
[08:54:26] + Attempting to get work packet
[08:54:26] Passkey found
[08:54:26] - Connecting to assignment server
[08:54:26] + No appropriate work server was available; will try again in a bit.
[08:54:26] + Couldn't get work instructions.
[08:54:26] - Attempt #17 to get work failed, and no other work to do.
[09:42:39] + Attempting to get work packet
[09:42:39] Passkey found
[09:42:39] - Connecting to assignment server
[09:42:39] + No appropriate work server was available; will try again in a bit.
[09:42:39] + Couldn't get work instructions.
[09:42:39] - Attempt #18 to get work failed, and no other work to do.
[10:30:46] + Attempting to get work packet
[10:30:46] Passkey found
[10:30:46] - Connecting to assignment server
[10:30:46] + No appropriate work server was available; will try again in a bit.
[10:30:46] + Couldn't get work instructions.
[10:30:46] - Attempt #19 to get work failed, and no other work to do.
[11:18:50] + Attempting to get work packet
[11:18:50] Passkey found
[11:18:50] - Connecting to assignment server
[11:18:50] + No appropriate work server was available; will try again in a bit.
[11:18:50] + Couldn't get work instructions.
[11:18:50] - Attempt #20 to get work failed, and no other work to do.
[12:06:52] + Attempting to get work packet
[12:06:52] Passkey found
[12:06:52] - Connecting to assignment server
[12:06:52] + No appropriate work server was available; will try again in a bit.
[12:06:52] + Couldn't get work instructions.
[12:06:52] - Attempt #21 to get work failed, and no other work to do.
[12:54:57] + Attempting to get work packet
[12:54:57] Passkey found
[12:54:57] - Connecting to assignment server
[12:54:57] + No appropriate work server was available; will try again in a bit.
[12:54:57] + Couldn't get work instructions.
[12:54:57] - Attempt #22 to get work failed, and no other work to do.
[13:43:04] + Attempting to get work packet
[13:43:04] Passkey found
[13:43:04] - Connecting to assignment server
[13:43:04] + No appropriate work server was available; will try again in a bit.
[13:43:04] + Couldn't get work instructions.
[13:43:04] - Attempt #23 to get work failed, and no other work to do.
[14:31:08] + Attempting to get work packet
[14:31:08] Passkey found
[14:31:08] - Connecting to assignment server
[14:31:08] + No appropriate work server was available; will try again in a bit.
[14:31:08] + Couldn't get work instructions.
[14:31:08] - Attempt #24 to get work failed, and no other work to do.
--- Opening Log file [April 19 14:44:20 UTC]
# Linux SMP Console Edition ###################################################
Folding@Home Client Version 6.34
http://folding.stanford.edu
Launch directory: /home/dual6200/fah
Executable: ./fah6
Arguments: -smp -bigbeta
[14:44:20] - Ask before connecting: No
[14:44:20] - User name: CrayZ4 (Team 33)
[14:44:20] - User ID: 159AB71516E19AD
[14:44:20] - Machine ID: 1
[14:44:20]
[14:44:21] Loaded queue successfully.
[14:44:21] - Preparing to get new work unit...
[14:44:21] Cleaning up work directory
[14:44:21] + Attempting to get work packet
[14:44:21] Passkey found
[14:44:21] - Connecting to assignment server
[14:44:21] + No appropriate work server was available; will try again in a bit.
[14:44:21] + Couldn't get work instructions.
[14:44:21] - Attempt #1 to get work failed, and no other work to do.
[14:44:33] + Attempting to get work packet
[14:44:33] Passkey found
[14:44:33] - Connecting to assignment server
[14:44:33] + No appropriate work server was available; will try again in a bit.
[14:44:33] + Couldn't get work instructions.
[14:44:33] - Attempt #2 to get work failed, and no other work to do.
Folding@Home Client Shutdown.
--- Opening Log file [April 19 14:44:54 UTC]
Executable: ./fah6
Arguments: -smp -bigadv
[14:44:54] - Ask before connecting: No
[14:44:54] - User name: CrayZ4 (Team 33)
[14:44:54] - User ID: 159AB71516E19AD
[14:44:54] - Machine ID: 1
[14:44:54]
[14:44:54] Loaded queue successfully.
[14:44:54] - Preparing to get new work unit...
[14:44:54] Cleaning up work directory
[14:44:54] + Attempting to get work packet
[14:44:54] Passkey found
[14:44:54] - Connecting to assignment server
[14:44:54] + No appropriate work server was available; will try again in a bit.
[14:44:54] + Couldn't get work instructions.
[14:44:54] - Attempt #1 to get work failed, and no other work to do.
[14:45:13] + Attempting to get work packet
[14:45:13] Passkey found
[14:45:13] - Connecting to assignment server
[14:45:13] + No appropriate work server was available; will try again in a bit.
[14:45:13] + Couldn't get work instructions.
[14:45:13] - Attempt #2 to get work failed, and no other work to do.
[14:45:25] + Attempting to get work packet
[14:45:25] Passkey found
[14:45:25] - Connecting to assignment server
[14:45:25] + No appropriate work server was available; will try again in a bit.
[14:45:25] + Couldn't get work instructions.
[14:45:25] - Attempt #3 to get work failed, and no other work to do.
--- Opening Log file [April 19 14:45:43 UTC]
Executable: ./fah6
Arguments: -smp -bigadv -verbosity 9
[14:45:43] - Ask before connecting: No
[14:45:43] - User name: CrayZ4 (Team 33)
[14:45:43] - User ID: 159AB71516E19AD
[14:45:43] - Machine ID: 1
[14:45:43]
[14:45:43] Loaded queue successfully.
[14:45:43] - Preparing to get new work unit...
[14:45:43] - Autosending finished units... [April 19 14:45:43 UTC]
[14:45:43] Cleaning up work directory
[14:45:43] Trying to send all finished work units
[14:45:43] + No unsent completed units remaining.
[14:45:43] - Autosend completed
[14:45:43] + Attempting to get work packet
[14:45:43] Passkey found
[14:45:43] - Will indicate memory of 16031 MB
[14:45:43] - Connecting to assignment server
[14:45:43] Connecting to http://assign.stanford.edu:8080/
[14:45:43] Posted data.
[14:45:43] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[14:45:43] + Couldn't get work instructions.
[14:45:43] - Attempt #1 to get work failed, and no other work to do.
[14:45:51] + Attempting to get work packet
[14:45:51] Passkey found
[14:45:51] - Will indicate memory of 16031 MB
[14:45:51] - Connecting to assignment server
[14:45:51] Connecting to http://assign.stanford.edu:8080/
[14:45:51] Posted data.
[14:45:51] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[14:45:51] + Couldn't get work instructions.
[14:45:51] - Attempt #2 to get work failed, and no other work to do.
[14:46:14] + Attempting to get work packet
[14:46:14] Passkey found
[14:46:14] - Will indicate memory of 16031 MB
[14:46:14] - Connecting to assignment server
[14:46:14] Connecting to http://assign.stanford.edu:8080/
[14:46:14] Posted data.
[14:46:14] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[14:46:14] + Couldn't get work instructions.
[14:46:14] - Attempt #3 to get work failed, and no other work to do.
[14:46:43] + Attempting to get work packet
[14:46:43] Passkey found
[14:46:43] - Will indicate memory of 16031 MB
[14:46:43] - Connecting to assignment server
[14:46:43] Connecting to http://assign.stanford.edu:8080/
[14:46:43] Posted data.
[14:46:43] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[14:46:43] + Couldn't get work instructions.
[14:46:43] - Attempt #4 to get work failed, and no other work to do.
[14:46:45] ***** Got an Activate signal (2)
[14:46:45] Killing all core threads
