Question..
Hadez
Question..
Post by Hadez »
Is it possible to make the CPU on Light and GPU on High?
Re: Question..
Post by calxalot »
Set power to full and manually set desired cpu count for CPU slot using FAHControl > Configure > Slots > select CPU slot and Edit.
Hadez
Re: Question..
Post by Hadez »
calxalot wrote:Set power to full and manually set desired cpu count for CPU slot using FAHControl > Configure > Slots > select CPU slot and Edit.
I couldn't understand this. after that what do I do?
Zagen30
Re: Question..
Post by Zagen30 »
The CPU slot's behavior on light is to use half of your total threads, so once you're editing the CPU slot change the thread count from -1 to the desired number. Also don't forget to add the slot option pause-on-battery set to true if you want that.
P5-133XL
Machine #2:
Machine 3:
Re: Question..
Post by P5-133XL »
Use the advanced-control option from the folding systray icon. Click on configure and go to the slots tab. Double-click on the CPU slot and adjust the number of cores wanted from there. Save
Re: Question..
Post by calxalot »
Pause on battery defaults to true, so no need to add that.
