BA server problem? I'm getting SMP WU on my 4P
rhavern
Post by rhavern »
Note that in this beta posting viewtopic.php?f=66&t=22884&start=15#unread BA folders are getting standard SMP WU. It appears that the WS is up and has WU, but they don't appear to be getting out.
Thanks for investigating.
EDIT: 130.237.232.141 appears to no longer have any client assignment criteria affiliated with it, 128.143.231.201 looks okay from the servstat page. Is this by intent?
Folding since 1 WU=1 point
kasson
Pande Group Member
Re: BA server problem? I'm getting SMP WU on my 4P
Post by kasson »
We're working on it (both availability of current project WU's on 128.143.231.201 and hopefully new projects coming online).
130.237.232.141 has reached end of support by the supercomputing center staff in Stockholm. Our collaborators have asked us to take it offline.
rhavern
Post by rhavern »
Thanks for the update. Will these be completely new projects, clones of existing or a bit of both? Exciting times ;-)
kasson
Pande Group Member
Post by kasson »
Kind of in between--the projects should look very much 8103, but there are some subtle (and scientifically important) differences. There may be some performance differences as well--we're just starting to benchmark. We're planning some additional project that will be a bit more different, but those also take more time to bring up and will be a bit farther out in the future.
PinHead
Hardware configuration: Quad Q9550 2.83 contains the GPU 57xx - running SMP and GPU
Post by PinHead »
So is this an "availability" problem? Or an assignment server problem?
The assignment server seems to send me to 128.143.199.96 after about 2 BA WU. Then it gives me 2-3 SMP WU when BA WU ( 128.143.231.201 ) shows availability.
PinHead wrote:So is this an "availability" problem? Or an assignment server problem?
What do you consider "availability"? Each server has a minimum number of WU's that it needs to reach before it will be available to the assignment server. I don't know the threshold value for this particular server, but using a server in the past that had few WU's available, the threshold on that one was at around 100. 128.143.231.201 shows just 93 as of the last refresh I did of the server stats. As WU's are turned in the number should rise and eventually they will be assigned.
At this moment, 128.143.231.201 shows 99 WUs Avail. and the 99 is in bold. It has never been documented but I'm pretty sure that means that 99 is less than the threshold so it's effectively out of WUs, confirming Joe_H's suggestion that the threshold is probably 100. The % Ass 80 is white, not green, which also indicates that the server is not assigning anything. When that server has no WUs that can be given out, you will be assigned to another server that has WUs that can be processed on your hardware.
From your report, the number of WUs dips below the threshold for about 25-35% of the time while the number of WUs builds up and stays above the threshold for 65-75% of the time.
Leonardo
Hardware configuration: GPU slots on home-built, purpose-built PCs.
Post by Leonardo »
Thanks for the information.
Thomas R
Post by Thomas R »
What the hell.....??
Is the problem in work or what happens?
Can you tell us if the problem is fixed?
I wan´t spend my money for energy if the result is 0
Thomas
Quisarious
Post by Quisarious »
There are currently not enough bigadv WUs to meet the demand of bigadv capable machines. I suspect this will be addressed at some point, but not all the possible fixes involve releasing more units, so careful what you wish for =).
Thomas R wrote:What the hell.....??
Thomas
Please read Dr. Kasson's posts earlier in this topic. They are working on getting new projects ready, but that takes time. Until these projects are tested and ready to send out, the remaining projects are running low on work. That means sometimes a machine set for bigadv will get that, the rest of the time SMP WU's will be assigned. One poster's estimate is he gets SMP about a third of the time his sytems request new work.
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
RAM: 24 GB DDR4
Post by Jesse_V »
Bigadv work has always been both cutting edge and fairly experimental.
I'm sure they'll get new WUs up soon.
Nathan_P
Not currently folding
Post by Nathan_P »
kasson wrote:Kind of in between--the projects should look very much 8103, but there are some subtle (and scientifically important) differences. There may be some performance differences as well--we're just starting to benchmark. We're planning some additional project that will be a bit more different, but those also take more time to bring up and will be a bit farther out in the future.
Saw the thread on 8104, 1.8 days is a bit short isn't it? That just ruled out everything running intel below a x5670 2p set up - including 2p e5 24 thread xeon rigs, low end 32 thread machines and most AMD 2p machines. Guess that BA folding is now solely a 4p affair :e(
Please note that discussion of Beta Projects should happen in Beta Forum only.
Thomas R
Post by Thomas R »
Now I have seven WU´s in my work-folder. All done, but can´t be send.
What can I do with it?
I dont want to loose them!
Last big-WU log looks like:
15:20:51] Completed 242500 out of 250000 steps  (97%)
[15:33:15] Completed 245000 out of 250000 steps  (98%)
[15:45:41] Completed 247500 out of 250000 steps  (99%)
[15:58:06] Completed 250000 out of 250000 steps  (100%)
[15:58:21] DynamicWrapper: Finished Work Unit: sleep=10000
[15:58:31]
[15:58:31] Finished Work Unit:
[15:58:31] - Reading up to 64340496 from "work/wudata_06.trr": Read 64340496
[15:58:31] trr file hash check passed.
[15:58:31] - Reading up to 31679028 from "work/wudata_06.xtc": Read 31679028
[15:58:32] xtc file hash check passed.
[15:58:32] edr file hash check passed.
[15:58:32] logfile size: 192418
[15:58:32] Leaving Run
[15:58:33] - Writing 96372818 bytes of core data to disk...
[15:59:01] Done: 96372306 -> 91632767 (compressed to 5.9 percent)
[15:59:01]   ... Done.
[16:00:02] - Shutting down core
[16:00:02]
[16:00:02] Folding@home Core Shutdown: FINISHED_UNIT
[16:00:10] CoreStatus = 64 (100)
[16:00:10] Unit 6 finished with 78 percent of time to deadline remaining.
[16:00:10] Updated performance fraction: 0.911384
[16:00:10] Sending work to server
[16:00:10] Project: 8101 (Run 15, Clone 3, Gen 149)
[16:00:10] + Attempting to send results [April 4 16:00:10 UTC]
[16:00:10] - Reading file work/wuresults_06.dat from core
[16:00:10]   (Read 91633279 bytes from disk)
[16:00:10] Connecting to http://128.143.231.201:8080/
[16:00:10] - Couldn't send HTTP request to server
[16:00:10] + Could not connect to Work Server (results)
[16:00:10]     (128.143.231.201:8080)
[16:00:10] + Retrying using alternative port
[16:00:10] Connecting to http://128.143.231.201:80/
[16:00:10]     (128.143.231.201:80)
[16:00:10] - Error: Could not transmit unit 06 (completed April 4) to work server.
[16:00:10] - 1 failed uploads of this unit.
[16:00:10]   Keeping unit 06 in queue.
[16:00:10] Trying to send all finished work units
[16:00:10] Project: 8101 (Run 6, Clone 5, Gen 225)
[16:00:10] - Reading file work/wuresults_01.dat from core
[16:00:10]   (Read 91576788 bytes from disk)
[16:00:10] - Error: Could not transmit unit 01 (completed April 3) to work server.
[16:00:10] - 18 failed uploads of this unit.
[16:00:10] Connecting to http://128.143.199.97:8080/
[16:00:10]     (128.143.199.97:8080)
[16:00:10] Connecting to http://128.143.199.97:80/
[16:00:10]     (128.143.199.97:80)
[16:00:11]   Could not transmit unit 01 to Collection server; keeping in queue.
[16:00:11] Project: 8554 (Run 0, Clone 8, Gen 87)
[16:00:11] + Attempting to send results [April 4 16:00:11 UTC]
[16:00:11] - Reading file work/wuresults_02.dat from core
[16:00:11]   (Read 7477367 bytes from disk)
[16:00:11] Connecting to http://128.143.199.96:8080/
[16:00:11] - Couldn't send HTTP request to server
[16:00:11] + Could not connect to Work Server (results)
[16:00:11]     (128.143.199.96:8080)
[16:00:11] + Retrying using alternative port
[16:00:11] Connecting to http://128.143.199.96:80/
[16:00:11]     (128.143.199.96:80)
[16:00:11] - Error: Could not transmit unit 02 (completed April 3) to work server.
[16:00:11] - 15 failed uploads of this unit.
[16:00:11] Connecting to http://128.143.231.201:8080/
[16:00:11]     (128.143.231.201:8080)
[16:00:11] Connecting to http://128.143.231.201:80/
[16:00:11]     (128.143.231.201:80)
[16:00:11]   Could not transmit unit 02 to Collection server; keeping in queue.
[16:00:11] Project: 8563 (Run 0, Clone 4, Gen 83)
[16:00:11] - Reading file work/wuresults_03.dat from core
[16:00:11]   (Read 7477191 bytes from disk)
[16:00:11] - Error: Could not transmit unit 03 (completed April 3) to work server.
[16:00:11] - 12 failed uploads of this unit.
[16:00:11]   Could not transmit unit 03 to Collection server; keeping in queue.
[16:00:11] Project: 6944 (Run 0, Clone 224, Gen 196)
[16:00:11] - Reading file work/wuresults_04.dat from core
[16:00:11]   (Read 3521316 bytes from disk)
[16:00:11] - Error: Could not transmit unit 04 (completed April 3) to work server.
[16:00:11] - 10 failed uploads of this unit.
[16:00:11]   Could not transmit unit 04 to Collection server; keeping in queue.
[16:00:11] Project: 8560 (Run 0, Clone 4, Gen 97)
[16:00:11] - Reading file work/wuresults_05.dat from core
[16:00:11]   (Read 7477172 bytes from disk)
[16:00:11] - Error: Could not transmit unit 05 (completed April 3) to work server.
[16:00:11] - 7 failed uploads of this unit.
[16:00:11]   Could not transmit unit 05 to Collection server; keeping in queue.
[16:00:11] Project: 8101 (Run 15, Clone 3, Gen 149)
[16:00:11] - Reading file work/wuresults_06.dat from core
[16:00:11]   (Read 91633279 bytes from disk)
[16:00:11] - Error: Could not transmit unit 06 (completed April 4) to work server.
[16:00:11] - 2 failed uploads of this unit.
[16:00:11] Connecting to http://128.143.199.97:8080/
[16:00:11]     (128.143.199.97:8080)
[16:00:11] Connecting to http://128.143.199.97:80/
[16:00:11]     (128.143.199.97:80)
[16:00:11]   Could not transmit unit 06 to Collection server; keeping in queue.
[16:00:11] + Sent 0 of 6 completed units to the server
[16:00:11] - Preparing to get new work unit...
[16:00:11] Cleaning up work directory
[16:00:11] + Attempting to get work packet
[16:00:11] Passkey found
[16:00:11] - Will indicate memory of 64426 MB
[16:00:11] - Connecting to assignment server
[16:00:11] Connecting to http://assign.stanford.edu:8080/
[16:00:12] Posted data.
[16:00:12] Initial: 8F80; - Successful: assigned to (128.143.199.96).
[16:00:12] + News From Folding@Home: Welcome to Folding@Home
[16:00:12] Loaded queue successfully.
[16:00:12] Sent data
[16:00:12] Connecting to http://128.143.199.96:8080/
[16:00:14] Posted data.
[16:00:14] Initial: 0000; - Receiving payload (expected size: 3792148)
[16:00:30] - Downloaded at ~231 kB/s
[16:00:30] - Averaged speed for that direction ~231 kB/s
[16:00:30] + Received work.
[16:00:30] Trying to send all finished work units
[16:00:30] Project: 8101 (Run 6, Clone 5, Gen 225)
[16:00:30] + Attempting to send results [April 4 16:00:30 UTC]
[16:00:30] - Reading file work/wuresults_01.dat from core
[16:00:30]   (Read 91576788 bytes from disk)
[16:00:30] Connecting to http://128.143.231.201:8080/
[16:00:30] - Couldn't send HTTP request to server
[16:00:30] + Could not connect to Work Server (results)
[16:00:30]     (128.143.231.201:8080)
[16:00:30] + Retrying using alternative port
[16:00:30] Connecting to http://128.143.231.201:80/
[16:00:30]     (128.143.231.201:80)
[16:00:30] - Error: Could not transmit unit 01 (completed April 3) to work server.
[16:00:30] - 19 failed uploads of this unit.
[16:00:30] Connecting to http://128.143.199.97:8080/
[16:00:30]     (128.143.199.97:8080)
[16:00:30] Connecting to http://128.143.199.97:80/
[16:00:30]     (128.143.199.97:80)
[16:00:30]   Could not transmit unit 01 to Collection server; keeping in queue.
[16:00:30] Project: 8554 (Run 0, Clone 8, Gen 87)
[16:00:30] - Reading file work/wuresults_02.dat from core
[16:00:30]   (Read 7477367 bytes from disk)
[16:00:30] Connecting to http://128.143.199.96:8080/
[16:00:30]     (128.143.199.96:8080)
[16:00:30] Connecting to http://128.143.199.96:80/
[16:00:30]     (128.143.199.96:80)
[16:00:30] - Error: Could not transmit unit 02 (completed April 3) to work server.
[16:00:30] - 16 failed uploads of this unit.
[16:00:31] - Couldn't send HTTP request to server
[16:00:31] + Could not connect to Work Server (results)
[16:00:31]     (128.143.231.201:80)
[16:00:31]   Could not transmit unit 02 to Collection server; keeping in queue.
[16:00:31] Project: 8563 (Run 0, Clone 4, Gen 83)
[16:00:31] + Attempting to send results [April 4 16:00:31 UTC]
[16:00:31] - Reading file work/wuresults_03.dat from core
[16:00:31]   (Read 7477191 bytes from disk)
[16:00:31] Connecting to http://128.143.199.96:8080/
[16:00:31]     (128.143.199.96:8080)
[16:00:31] + Retrying using alternative port
[16:00:31] Connecting to http://128.143.199.96:80/
[16:00:31]     (128.143.199.96:80)
[16:00:31] - Error: Could not transmit unit 03 (completed April 3) to work server.
[16:00:31] - 13 failed uploads of this unit.
[16:00:31] Connecting to http://128.143.231.201:8080/
[16:00:31]     (128.143.231.201:8080)
[16:00:31] Connecting to http://128.143.231.201:80/
[16:00:31]   Could not transmit unit 03 to Collection server; keeping in queue.
[16:00:31] Project: 6944 (Run 0, Clone 224, Gen 196)
[16:00:31] - Reading file work/wuresults_04.dat from core
[16:00:31]   (Read 3521316 bytes from disk)
[16:00:31] - Error: Could not transmit unit 04 (completed April 3) to work server.
[16:00:31] - 11 failed uploads of this unit.
[16:00:31]   Could not transmit unit 04 to Collection server; keeping in queue.
[16:00:31] Project: 8560 (Run 0, Clone 4, Gen 97)
[16:00:31] - Reading file work/wuresults_05.dat from core
[16:00:31]   (Read 7477172 bytes from disk)
[16:00:31] - Error: Could not transmit unit 05 (completed April 3) to work server.
[16:00:31] - 8 failed uploads of this unit.
[16:00:31]   Could not transmit unit 05 to Collection server; keeping in queue.
[16:00:31] Project: 8101 (Run 15, Clone 3, Gen 149)
[16:00:31] - Reading file work/wuresults_06.dat from core
[16:00:31]   (Read 91633279 bytes from disk)
[16:00:31] - Error: Could not transmit unit 06 (completed April 4) to work server.
[16:00:31] - 3 failed uploads of this unit.
[16:00:31] Connecting to http://128.143.199.97:8080/
[16:00:31]     (128.143.199.97:8080)
[16:00:31] Connecting to http://128.143.199.97:80/
[16:00:31]     (128.143.199.97:80)
[16:00:31]   Could not transmit unit 06 to Collection server; keeping in queue.
[16:00:31] + Sent 0 of 6 completed units to the server
