A couple things are necessary for this to work:
1) the laptop must have a removable back panel that exposes these cooling components. Fortunately, I have a ASUS N61V model that was well engineered and is capable of these kinds of tricks.
2) The laptop should be stationary most of the time. Obviously removing the back panel is not a good idea if you're going to support it on your knees.
3) There must be a sufficient amount of space under the laptop for air to flow in, as there's likely little to be gained by removing the panel if the top of the desk takes its place. Fancy cooling pads would work, but if you're cheap then I find that three empty rolls of electrical tape are a sufficient alternative. The cardboard tubes are just the right height IMO.
There's a couple of advantages that come out of removing this back panel:
1) Lower temperatures. I attribute this mainly to better airflow, though the warm cooling pipes are also better able to radiate.
2) Less fan noise. Obviously lower temperatures means the fan isn't going to spin as fast, but the air has less turbulence because it no longer has to squeeze through the air intakes and swirl around all the inner components. The fan is able to easily take in air and blow it straight through the radiators.
I removed the panels yesterday, so I have yet to see if more dust is a disadvantage to this, but so far this idea appears to be largely successful. I wish I had thought of this months ago.
