--- Opening Log file [March 3 18:36:28 UTC]
# Windows GPU Systray Edition #################################################
Folding@Home Client Version 6.41r2
http://folding.stanford.edu
Launch directory: C:\Users\Justin\AppData\Roaming\Folding@home-gpu
[18:36:28] Gpu type=2 species=35.
[18:37:14] - Ask before connecting: No
[18:37:14] - Machine ID: 2
[18:37:14]
[18:37:14] Work directory not found. Creating...
[18:37:14] Could not open work queue, generating new queue...
[18:37:14] Initialization complete
[18:37:14] - Preparing to get new work unit...
[18:37:14] Cleaning up work directory
[18:37:14] + Attempting to get work packet
[18:37:14] Passkey found
[18:37:14] Gpu type=2 species=35.
[18:37:14] - Connecting to assignment server
[18:37:15] - Successful: assigned to (171.67.108.11).
[18:37:15] + News From Folding@Home: Welcome to Folding@Home
[18:37:15] Loaded queue successfully.
[18:37:15] Gpu type=2 species=35.
[18:37:15] + Closed connections
[18:37:15]
[18:37:15] + Processing work unit
[18:37:15] Core required: FahCore_11.exe
[18:37:15] Core not found.
[18:37:15] - Core is not present or corrupted.
[18:37:15] - Attempting to download new core...
[18:37:15] + Downloading new core: FahCore_11.exe
[18:37:15] + 10240 bytes downloaded
[18:37:15] + 20480 bytes downloaded
[18:37:15] + 30720 bytes downloaded
[18:37:15] + 40960 bytes downloaded
[18:37:15] + 51200 bytes downloaded
[18:37:15] + 61440 bytes downloaded
[18:37:15] + 71680 bytes downloaded
[18:37:15] + 81920 bytes downloaded
[18:37:15] + 92160 bytes downloaded
[18:37:15] + 102400 bytes downloaded
[18:37:15] + 112640 bytes downloaded
[18:37:15] + 122880 bytes downloaded
[18:37:15] + 133120 bytes downloaded
[18:37:15] + 143360 bytes downloaded
[18:37:15] + 153600 bytes downloaded
[18:37:15] + 163840 bytes downloaded
[18:37:15] + 174080 bytes downloaded
[18:37:15] + 184320 bytes downloaded
[18:37:15] + 194560 bytes downloaded
[18:37:15] + 204800 bytes downloaded
[18:37:15] + 215040 bytes downloaded
[18:37:15] + 225280 bytes downloaded
[18:37:15] + 235520 bytes downloaded
[18:37:15] + 245760 bytes downloaded
[18:37:15] + 256000 bytes downloaded
[18:37:15] + 266240 bytes downloaded
[18:37:15] + 276480 bytes downloaded
[18:37:15] + 286720 bytes downloaded
[18:37:15] + 296960 bytes downloaded
[18:37:15] + 307200 bytes downloaded
[18:37:15] + 317440 bytes downloaded
[18:37:15] + 327680 bytes downloaded
[18:37:15] + 337920 bytes downloaded
[18:37:15] + 348160 bytes downloaded
[18:37:15] + 358400 bytes downloaded
[18:37:16] + 368640 bytes downloaded
[18:37:16] + 378880 bytes downloaded
[18:37:16] + 389120 bytes downloaded
[18:37:16] + 399360 bytes downloaded
[18:37:16] + 409600 bytes downloaded
[18:37:16] + 419840 bytes downloaded
[18:37:16] + 430080 bytes downloaded
[18:37:16] + 440320 bytes downloaded
[18:37:16] + 450560 bytes downloaded
[18:37:16] + 460800 bytes downloaded
[18:37:16] + 471040 bytes downloaded
[18:37:16] + 481280 bytes downloaded
[18:37:16] + 491520 bytes downloaded
[18:37:16] + 501760 bytes downloaded
[18:37:16] + 512000 bytes downloaded
[18:37:16] + 522240 bytes downloaded
[18:37:16] + 532480 bytes downloaded
[18:37:16] + 542720 bytes downloaded
[18:37:16] + 552960 bytes downloaded
[18:37:16] + 563200 bytes downloaded
[18:37:16] + 573440 bytes downloaded
[18:37:16] + 583680 bytes downloaded
[18:37:16] + 593920 bytes downloaded
[18:37:16] + 604160 bytes downloaded
[18:37:16] + 614400 bytes downloaded
[18:37:16] + 624640 bytes downloaded
[18:37:16] + 634880 bytes downloaded
[18:37:16] + 645120 bytes downloaded
[18:37:16] + 655360 bytes downloaded
[18:37:16] + 665067 bytes downloaded
[18:37:16] Verifying core Core_11.fah...
[18:37:16] Signature is VALID
[18:37:16]
[18:37:16] Trying to unzip core FahCore_11.exe
[18:37:16] Decompressed FahCore_11.exe (1908736 bytes) successfully
[18:37:21] + Core successfully engaged
[18:37:26]
[18:37:26] + Processing work unit
[18:37:26] Core required: FahCore_11.exe
[18:37:26] Core found.
[18:37:26] Working on queue slot 01 [March 3 18:37:26 UTC]
[18:37:26] + Working ...
[18:37:26]
[18:37:26] *------------------------------*
[18:37:26] Folding@Home GPU Core
[18:37:26] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[18:37:26]
[18:37:26] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[18:37:26] Build host: amoeba
[18:37:26] Board Type: Nvidia
[18:37:26] Core :
[18:37:26] Preparing to commence simulation
[18:37:26] - Looking at optimizations...
[18:37:26] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[18:37:26] - Created dyn
[18:37:26] - Files status OK
[18:37:26] - Expanded 46706 -> 252912 (decompressed 541.4 percent)
[18:37:26] Called DecompressByteArray: compressed_data_size=46706 data_size=252912, decompressed_data_size=252912 diff=0
[18:37:26] - Digital signature verified
[18:37:26]
[18:37:26] Project: 5768 (Run 10, Clone 199, Gen 2551)
[18:37:26]
[18:37:26] Assembly optimizations on if available.
[18:37:26] Entering M.D.
[18:37:32] Tpr hash work/wudata_01.tpr: 1472155793 669786492 998905776 3298855814 1239492709
[18:37:32]
[18:37:32] Calling fah_main args: 14 usage=100
