8800GTX showing ppd unknown
stevv
Post by stevv »
Hi, I was wondering if there's any special settings for 8800GTX as I'm not showing any PPD / Credit on my client.
I tried both 7.1 and 7.2 running on win 7 x64.
The CPU (Q6600) is working fine on both clients version (~4-5K ppd)
The GPU is a 8800GTX stock and latest drivers and been running for a few days and have completed a few work units.
Here are the work unit stats.
PRCG: 5770 (6, 390, 2965)
Status: Running
Progress: 66.31%
ETA: 32 mins 59 secs
Base Credit: unknown
Estimated Credit: unknown
Estimated PPD: unknown
Estimated TPF: 58.00 secs
Project: 5770
FahCore: 0.11
Work Server: 171.67.108.11
Collection Server: 171.67.108.25
here's a log clip for the gpu: So far no "warnings and errors" when using log filter.
15:40:27:WU01:FS00:0x11:Completed 99%
15:40:27:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
15:40:27:WU00:FS00:News: Welcome to Folding@Home
15:40:27:WU00:FS00:Assigned to work server 171.67.108.11
15:40:27:WU00:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:"G80 [GeForce 8800 GTX]" from 171.67.108.11
15:40:27:WU00:FS00:Connecting to 171.67.108.11:8080
15:40:28:WU00:FS00:Downloading 44.90KiB
15:40:28:WU00:FS00:Download complete
15:40:28:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:NO_ERROR project:5770 run:6 clone:390 gen:2965 core:0x11 unit:0x1643f2ca51151c7f0b9501860006168a
15:41:25:WU01:FS00:0x11:Completed 100%
15:41:26:WU01:FS00:0x11:Successful run
15:41:26:WU01:FS00:0x11:DynamicWrapper: Finished Work Unit: sleep=10000
15:41:36:WU01:FS00:0x11:Reserved 76252 bytes for xtc file; Cosm status=0
15:41:36:WU01:FS00:0x11:Allocated 76252 bytes for xtc file
15:41:36:WU01:FS00:0x11:- Reading up to 76252 from "01/wudata_01.xtc": Read 76252
15:41:36:WU01:FS00:0x11:Read 76252 bytes from xtc file; available packet space=786354212
15:41:36:WU01:FS00:0x11:xtc file hash check passed.
15:41:36:WU01:FS00:0x11:Reserved 15168 15168 786354212 bytes for arc file=<01/wudata_01.trr> Cosm status=0
15:41:36:WU01:FS00:0x11:Allocated 15168 bytes for arc file
15:41:36:WU01:FS00:0x11:- Reading up to 15168 from "01/wudata_01.trr": Read 15168
15:41:36:WU01:FS00:0x11:Read 15168 bytes from arc file; available packet space=786339044
15:41:36:WU01:FS00:0x11:trr file hash check passed.
15:41:36:WU01:FS00:0x11:Allocated 560 bytes for edr file
15:41:36:WU01:FS00:0x11:Read bedfile
15:41:36:WU01:FS00:0x11:edr file hash check passed.
15:41:36:WU01:FS00:0x11:Allocated 0 bytes for logfile
15:41:36:WU01:FS00:0x11:Could not open/read logfile=<01/wudata_01.log>; Cosm status=-1
15:41:36:WU01:FS00:0x11:GuardedRun: success in DynamicWrapper
15:41:36:WU01:FS00:0x11:GuardedRun: done
15:41:36:WU01:FS00:0x11:Run: GuardedRun completed.
15:41:36:WU01:FS00:0x11:+ Opened results file
15:41:36:WU01:FS00:0x11:- Writing 92492 bytes of core data to disk...
15:41:36:WU01:FS00:0x11:Done: 91980 -> 90748 (compressed to 98.6 percent)
15:41:36:WU01:FS00:0x11:  ... Done.
15:41:36:WU01:FS00:0x11:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
15:41:36:WU01:FS00:0x11:Shutting down core
15:41:36:WU01:FS00:0x11:Folding@home Core Shutdown: FINISHED_UNIT
15:41:37:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
15:41:37:WU01:FS00:Sending unit results: id:01 state:SEND error:NO_ERROR project:5772 run:3 clone:158 gen:3798 core:0x11 unit:0x75e40e34511505b00ed6009e0003168c
15:41:37:WU01:FS00:Uploading 89.12KiB to 171.67.108.11
15:41:37:WU01:FS00:Connecting to 171.67.108.11:8080
15:41:37:WU00:FS00:Starting
15:41:37:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/Users/me/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/G80/Core_11.fah/FahCore_11.exe -dir 00 -suffix 01 -version 702 -lifeline 2224 -checkpoint 15 -gpu 0
15:41:37:WU00:FS00:Started FahCore on PID 2444
15:41:37:WU00:FS00:Core PID:560
15:41:37:WU00:FS00:FahCore 0x11 started
15:41:37:WU00:FS00:0x11:
15:41:37:WU00:FS00:0x11:*------------------------------*
15:41:37:WU00:FS00:0x11:Folding@Home GPU Core
15:41:37:WU00:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
15:41:37:WU00:FS00:0x11:Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
15:41:37:WU00:FS00:0x11:Build host: amoeba
15:41:37:WU00:FS00:0x11:Board Type: Nvidia
15:41:37:WU00:FS00:0x11:Core      :
15:41:37:WU00:FS00:0x11:Preparing to commence simulation
15:41:37:WU00:FS00:0x11:- Looking at optimizations...
15:41:37:WU00:FS00:0x11:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
15:41:37:WU00:FS00:0x11:- Created dyn
15:41:37:WU00:FS00:0x11:- Files status OK
15:41:37:WU00:FS00:0x11:- Expanded 45463 -> 251112 (decompressed 552.3 percent)
15:41:37:WU00:FS00:0x11:Called DecompressByteArray: compressed_data_size=45463 data_size=251112, decompressed_data_size=251112 diff=0
15:41:37:WU00:FS00:0x11:- Digital signature verified
15:41:37:WU00:FS00:0x11:Project: 5770 (Run 6, Clone 390, Gen 2965)
15:41:37:WU00:FS00:0x11:Assembly optimizations on if available.
15:41:37:WU00:FS00:0x11:Entering M.D.
15:41:38:WU01:FS00:Upload complete
15:41:38:WU01:FS00:Server responded WORK_ACK (400)
15:41:38:WU01:FS00:Cleaning up
15:41:43:WU00:FS00:0x11:Tpr hash 00/wudata_01.tpr:  2948734565 3430960714 185800344 754333147 551765373
15:41:43:WU00:FS00:0x11:Calling fah_main args: 14 usage=100
15:41:43:WU00:FS00:0x11:Working on Protein
15:41:44:WU00:FS00:0x11:Client config unavailable.
15:41:44:WU00:FS00:0x11:Starting GUI Server
15:42:42:WU00:FS00:0x11:Completed 1%
15:43:40:WU00:FS00:0x11:Completed 2%
Re: 8800GTX showing ppd unknown
No special settings are needed or can be used. Some of the older work servers need to be updated before they will provide the data needed by the client to calculate the credit for the WU. So as long as the WU is processed successfully and turned in, your credit should show up in the stats.
art_l_j_PlanetAMD64
Post by art_l_j_PlanetAMD64 »
stevv wrote:Hi, I was wondering if there's any special settings for 8800GTX as I'm not showing any PPD / Credit on my client.
Status: Running
Progress: 66.31%
Project: 5770
FahCore: 0x11
You can calculate your PPD from your TPF as follows:
  • Find the points for your Project's WU: Project 5770
  • Your TPF means that 1 WU will complete in about 5800 seconds (ignoring the extra overhead at the start and end of a WU)
  • WUs per day = 86400/5800, or about 14.9 WU/day
  • 14.9 WU/day * 353 Points/WU = about 5260 PPD
  • If the loss due to "overhead" is 5%, then 5260 * 0.95 = 4997 PPD
art_l_j_PlanetAMD64
Over 1.04 Billion Total Points
Over 185,000 Work Units
Over 3,800,000 PPD
Overall rank (if points are combined) 20 of 1721690
In memory of my Mother May 12th 1923 - February 10th 2012
