I've been out of Folding for a little while, but I just came across a pair of new-in-box Xeon E7-2860's. The specs look good but the design is almost a couple of years old. Would it be worth buying a new dual socket system board and other goodies to turn these into a folding machine? They have 10 cores each per processor with hyperthreading, and run at 2.26 GHz with 24 MB of cahce.
If anyone knows anthing about Xeons, can you recommend a reasonable system board for them?
Dual Xeon E7-2860
Re: Dual Xeon E7-2860
P5-133XL, on this topic, provided a link to a good table to look at:
https://docs.google.com/spreadsheet/ccc ... DcHc#gid=0
Last edited by art_l_j_PlanetAMD64 on Mon Jan 28, 2013 1:04 am, edited 1 time in total.
art_l_j_PlanetAMD64
Over 1.04 Billion Total Points
Over 185,000 Work Units
Over 3,800,000 PPD
Overall rank (if points are combined) 20 of 1721690
In memory of my Mother May 12th 1923 - February 10th 2012
Over 3,800,000 PPD
Thanks for the link. I should probably find a way to pass these processors on to somebody who could make good use of them. Motherboard prices for the LGA 1567 are sky high.
Machine #2:
Machine 3:
It is not my list! I just remembered its existence and pulled the list from HardOCP after searching for it in their forums.art_l_j_PlanetAMD64 wrote:P5-133XL, on this topic, had a good table to look at:
Sorry, I was not trying to imply that it was, but my original message was poorly worded. I have amended it to make it clear that all you did was to provide a link to the table. I was just trying to give you credit for finding the table, as I did not want proliance to think that I found it on my own.P5-133XL wrote:It is not my list! I just remembered its existence and pulled the list from HardOCP after searching for it in their forums.
art_l_j_PlanetAMD64
Over 3,800,000 PPD
Over 3,800,000 PPD
