Large drop in PPD
Large drop in PPD
Hello. Normally with my Dell Lattitude E6400 laptop I fold and get 400-500 PPD. Now I look at my machine and it reports my PPD at 65. What could possibly explain such a huge drop in PPD? It seems to be folding right now just fine. One WU was completed and a new one started right away. It takes 1-2 days for me to finish a typical WU but lately I have been getting some that take 4-5 days.
What could be going on? Or is the PPD number reported to me not accurate?
I fold under the name RattyM, not the name used in this forum.
Thanks.
Thanks.
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
Re: Large drop in PPD
Maybe you've missed enough deadlines to fall below an 80% successful return. If that's the case, you'd no longer get bonus points, just base points. That's my first though. I understand the mods/admins are capable of looking up your passkey and checking your completion rate.
I dont keep a serious track of this, but I am reasonably sure that I hit my target times. I could be wrong though. I am not in this for the points. I just want to make sure that I am pounding out WU's at the maximum rate.
Your percentage of completion rate looks fine and AFAIK the PPD calculated by the client or a 3rd party program such as HFM does not take your failure rate into consideration when doing the PPD calculation.
What client version are you using?
There can be a number of reasons for a drop in PPD. From your stats history at kakao it appears you were running two clients/slots but your official stats show only one in the past seven days. You need to look thru your recent logs to see if there are any errors. You can post logs here using the code tags available in Full Editor if you'd like us to take a look.
Your last CPU/SMP WU was returned on November the 15th:
Hi RattyM (team 0),
Your WU (P8056 R34 C28 G49) was added to the stats database on 2012-11-15 21:08:35 for 435.35 points of credit.
Your last GPU WU was returned today:
Hi RattyM (team 0),
Your WU (P10504 R103 C1 G1034) was added to the stats database on 2012-11-26 00:02:07 for 587 points of credit.
In the past 10 or 11 days it appears only your GPU has been contributing.
Hi RattyM (team 0),
Hi RattyM (team 0),
To summarize,
Either the production rate has actually dropped or there has been a disconnect between the PPD being reported and the production rate. Without more information, we can't tell which.
One (fairly common) possible cause for a PPD disconnect is the rate that WUs have missed the deadline but bollix47 has checked that. The next logical step would be to look at the two sources of information and recheck all the steps relating the two. As I said, we don't have enough information to answer the question.
Have you calculated your PPD manually (directly from the log)? Is there something new running in your computer that might have actually reduced your production rate? Is your production rate correct but the points going somewhere other than your personal account (Recheck your UserName and TeamNumber)?
- You're interested in "pounding out WU's at the maximum rate" and
- you've noted a radical change in the PPD number reported to you and
- you've asked if the PPD reports are not accurate.
My PPD are all over the place so I guess the client isnt too accurate. I was up to 700 but am now languishing in the 200's. i am using client 7.1.52.
I fold virtually 24 x 7 on this machine so I dont think I can possibly go any faster.
I dont understand this :Your WU (P8056 R34 C28 G49) was added to the stats database on 2012-11-15 21:08:35 for 435.35 points of credit
As I said, I fold constantly. how can my last WU be listed as finished all the way back on 11/15??
Here is a bunch of code if anyone wants to look at it.
10:37:53:WU00:FS01:Starting
10:37:53:WU00:FS01:Running FahCore: E:\FAHClient/FAHCoreWrapper.exe "C:/Documents and Settings/name/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 00 -suffix 01 -version 701 -lifeline 1104 -checkpoint 15 -np 2
10:37:53:WU00:FS01:Started FahCore on PID 9352
10:37:54:WU00:FS01:Core PID:9420
10:37:54:WU00:FS01:FahCore 0xa4 started
10:37:54:WU02:FS00:Starting
10:37:54:WU02:FS00:Running FahCore: E:\FAHClient/FAHCoreWrapper.exe "C:/Documents and Settings/name/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/NVIDIA/G80/Core_11.fah/FahCore_11.exe" -dir 02 -suffix 01 -version 701 -lifeline 1104 -checkpoint 15 -gpu 0
10:37:54:WU02:FS00:Started FahCore on PID 8936
10:37:54:WU02:FS00:Core PID:7312
10:37:54:WU02:FS00:FahCore 0x11 started
10:37:54:WU00:FS01:0xa4:
10:37:54:WU00:FS01:0xa4:*------------------------------*
10:37:54:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
10:37:54:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
10:37:54:WU00:FS01:0xa4:Preparing to commence simulation
10:37:54:WU00:FS01:0xa4:- Looking at optimizations...
10:37:54:WU00:FS01:0xa4:- Files status OK
10:37:54:WU00:FS01:0xa4:- Expanded 686282 -> 1528544 (decompressed 222.7 percent)
10:37:54:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=686282 data_size=1528544, decompressed_data_size=1528544 diff=0
10:37:54:WU00:FS01:0xa4:- Digital signature verified
10:37:54:WU00:FS01:0xa4:Project: 8056 (Run 19, Clone 7, Gen 37)
10:37:54:WU00:FS01:0xa4:Assembly optimizations on if available.
10:37:54:WU00:FS01:0xa4:Entering M.D.
10:37:55:WU02:FS00:0x11:
10:37:55:WU02:FS00:0x11:*------------------------------*
10:37:55:WU02:FS00:0x11:Folding@Home GPU Core
10:37:55:WU02:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
10:37:55:WU02:FS00:0x11:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
10:37:55:WU02:FS00:0x11:Build host: amoeba
10:37:55:WU02:FS00:0x11:Board Type: Nvidia
10:37:55:WU02:FS00:0x11:Core :
10:37:55:WU02:FS00:0x11:Preparing to commence simulation
10:37:55:WU02:FS00:0x11:- Looking at optimizations...
10:37:55:WU02:FS00:0x11:- Files status OK
10:37:55:WU02:FS00:0x11:- Expanded 45391 -> 251112 (decompressed 553.2 percent)
10:37:55:WU02:FS00:0x11:Called DecompressByteArray: compressed_data_size=45391 data_size=251112, decompressed_data_size=251112 diff=0
10:37:55:WU02:FS00:0x11:- Digital signature verified
10:37:55:WU02:FS00:0x11:Project: 5772 (Run 10, Clone 158, Gen 4891)
10:37:55:WU02:FS00:0x11:Assembly optimizations on if available.
10:37:55:WU02:FS00:0x11:Entering M.D.
10:38:00:WU00:FS01:0xa4:Using Gromacs checkpoints
10:38:00:WU00:FS01:0xa4:Mapping NT from 2 to 2
10:38:01:WU00:FS01:0xa4:Resuming from checkpoint
10:38:01:WU00:FS01:0xa4:Verified 00/wudata_01.log
10:38:01:WU00:FS01:0xa4:Verified 00/wudata_01.trr
10:38:01:WU00:FS01:0xa4:Verified 00/wudata_01.xtc
10:38:01:WU02:FS00:0x11:Will resume from checkpoint file
10:38:01:WU02:FS00:0x11:Tpr hash 02/wudata_01.tpr: 3788852863 3934688430 4045870483 2408932843 2843962430
10:38:01:WU02:FS00:0x11:Calling fah_main args: 14 usage=100
10:38:01:WU00:FS01:0xa4:Verified 00/wudata_01.edr
10:38:01:WU00:FS01:0xa4:Completed 313190 out of 500000 steps (62%)
10:38:01:WU02:FS00:0x11:Working on Protein
10:38:03:WU02:FS00:0x11:Client config unavailable.
10:38:04:WU02:FS00:0x11:Starting GUI Server
10:38:04:WU02:FS00:0x11:Resuming from checkpoint
10:38:04:WU02:FS00:0x11:fcCheckPointResume: retreived and current tpr file hash:
10:38:04:WU02:FS00:0x11: 0 3788852863 3788852863
10:38:04:WU02:FS00:0x11: 1 3934688430 3934688430
10:38:04:WU02:FS00:0x11: 2 4045870483 4045870483
10:38:04:WU02:FS00:0x11: 3 2408932843 2408932843
10:38:04:WU02:FS00:0x11: 4 2843962430 2843962430
10:38:04:WU02:FS00:0x11:fcCheckPointResume: file hashes same.
10:38:04:WU02:FS00:0x11:fcCheckPointResume: state restored.
10:38:04:WU02:FS00:0x11:Verified 02/wudata_01.log
10:38:04:WU02:FS00:0x11:Verified 02/wudata_01.edr
10:38:04:WU02:FS00:0x11:Verified 02/wudata_01.xtc
10:38:04:WU02:FS00:0x11:Completed 5%
10:42:30:WU00:FS01:0xa4:Completed 315000 out of 500000 steps (63%)
10:54:13:WU02:FS00:0x11:Completed 6%
10:54:59:WU00:FS01:0xa4:Completed 320000 out of 500000 steps (64%)
11:08:07:WU00:FS01:0xa4:Completed 325000 out of 500000 steps (65%)
11:17:46:WU02:FS00:0x11:Completed 7%
11:31:56:WU02:FS00:0x11:Completed 8%
******************************** Date: 26/11/12 ********************************
11:44:52:WU02:FS00:0x11:Completed 9%
11:50:31:WU00:FS01:0xa4:Completed 330000 out of 500000 steps (66%)
11:57:16:WU02:FS00:0x11:Completed 10%
12:04:37:WU00:FS01:0xa4:Completed 335000 out of 500000 steps (67%)
12:16:54:WU00:FS01:0xa4:Completed 340000 out of 500000 steps (68%)
12:24:33:WU02:FS00:0x11:Completed 11%
12:29:17:WU00:FS01:0xa4:Completed 345000 out of 500000 steps (69%)
12:39:37:WU02:FS00:0x11:Completed 12%
12:46:11:WU00:FS01:0xa4:Completed 350000 out of 500000 steps (70%)
13:03:25:WU00:FS01:0xa4:Completed 355000 out of 500000 steps (71%)
13:15:47:WU00:FS01:0xa4:Completed 360000 out of 500000 steps (72%)
13:17:53:WU02:FS00:0x11:Completed 13%
13:28:05:WU00:FS01:0xa4:Completed 365000 out of 500000 steps (73%)
13:40:16:WU00:FS01:0xa4:Completed 370000 out of 500000 steps (74%)
13:52:29:WU00:FS01:0xa4:Completed 375000 out of 500000 steps (75%)
14:04:45:WU00:FS01:0xa4:Completed 380000 out of 500000 steps (76%)
14:08:25:WU02:FS00:0x11:Completed 14%
14:17:01:WU00:FS01:0xa4:Completed 385000 out of 500000 steps (77%)
14:29:17:WU00:FS01:0xa4:Completed 390000 out of 500000 steps (78%)
14:41:27:WU00:FS01:0xa4:Completed 395000 out of 500000 steps (79%)
14:53:41:WU00:FS01:0xa4:Completed 400000 out of 500000 steps (80%)
14:58:58:WU02:FS00:0x11:Completed 15%
15:05:54:WU00:FS01:0xa4:Completed 405000 out of 500000 steps (81%)
15:18:10:WU00:FS01:0xa4:Completed 410000 out of 500000 steps (82%)
15:30:22:WU00:FS01:0xa4:Completed 415000 out of 500000 steps (83%)
15:42:31:WU00:FS01:0xa4:Completed 420000 out of 500000 steps (84%)
15:48:25:WU02:FS00:0x11:Completed 16%
15:53:38:WU00:FS01:0xa4:Completed 425000 out of 500000 steps (85%)
16:05:56:WU00:FS01:0xa4:Completed 430000 out of 500000 steps (86%)
16:18:14:WU00:FS01:0xa4:Completed 435000 out of 500000 steps (87%)
16:30:37:WU00:FS01:0xa4:Completed 440000 out of 500000 steps (88%)
16:38:58:WU02:FS00:0x11:Completed 17%
16:43:00:WU00:FS01:0xa4:Completed 445000 out of 500000 steps (89%)
16:55:22:WU00:FS01:0xa4:Completed 450000 out of 500000 steps (90%)
17:07:42:WU00:FS01:0xa4:Completed 455000 out of 500000 steps (91%)
17:20:02:WU00:FS01:0xa4:Completed 460000 out of 500000 steps (92%)
17:29:31:WU02:FS00:0x11:Completed 18%
17:32:23:WU00:FS01:0xa4:Completed 465000 out of 500000 steps (93%)
17:44:45:WU00:FS01:0xa4:Completed 470000 out of 500000 steps (94%)
17:57:08:WU00:FS01:0xa4:Completed 475000 out of 500000 steps (95%)
18:09:33:WU00:FS01:0xa4:Completed 480000 out of 500000 steps (96%)
18:20:04:WU02:FS00:0x11:Completed 19%
18:22:00:WU00:FS01:0xa4:Completed 485000 out of 500000 steps (97%)
18:34:21:WU00:FS01:0xa4:Completed 490000 out of 500000 steps (98%)
18:46:45:WU00:FS01:0xa4:Completed 495000 out of 500000 steps (99%)
18:46:46:WU01:FS01:Connecting to assign3.stanford.edu:8080
18:46:47:WU01:FS01:News: Welcome to Folding@Home
18:46:47:WU01:FS01:Assigned to work server 171.64.65.99
18:46:47:WU01:FS01:Requesting new work unit for slot 01: RUNNING smp:2 from 171.64.65.99
18:46:47:WU01:FS01:Connecting to 171.64.65.99:8080
18:46:49:WU01:FS01:Downloading 1.96MiB
18:46:55:WU01:FS01:Download 82.94%
18:46:56:WU01:FS01:Download complete
18:46:56:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:OK project:7808 run:5 clone:309 gen:98 core:0xa4 unit:0x000000960a3b1e874e30fb13c5f58fe8
18:46:56:WU01:FS01:Downloading project 7808 description
18:46:56:WU01:FS01:Connecting to fah-web.stanford.edu:80
18:46:57:WU01:FS01:Project 7808 description downloaded successfully
18:59:07:WU00:FS01:0xa4:Completed 500000 out of 500000 steps (100%)
18:59:07:WU00:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
18:59:17:WU00:FS01:0xa4:
18:59:17:WU00:FS01:0xa4:Finished Work Unit:
18:59:18:WU00:FS01:0xa4:- Reading up to 876948 from "00/wudata_01.trr": Read 876948
18:59:18:WU00:FS01:0xa4:trr file hash check passed.
18:59:18:WU00:FS01:0xa4:- Reading up to 955320 from "00/wudata_01.xtc": Read 955320
18:59:18:WU00:FS01:0xa4:xtc file hash check passed.
18:59:18:WU00:FS01:0xa4:edr file hash check passed.
18:59:18:WU00:FS01:0xa4:logfile size: 35515
18:59:18:WU00:FS01:0xa4:Leaving Run
18:59:21:WU00:FS01:0xa4:- Writing 1876755 bytes of core data to disk...
18:59:22:WU00:FS01:0xa4:Done: 1876243 -> 1800139 (compressed to 95.9 percent)
18:59:22:WU00:FS01:0xa4: ... Done.
18:59:22:WU00:FS01:0xa4:- Shutting down core
18:59:22:WU00:FS01:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
18:59:23:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
18:59:23:WU00:FS01:Sending unit results: id:00 state:SEND error:OK project:8056 run:19 clone:7 gen:37 core:0xa4 unit:0x000000356652edcb506cee227427167a
18:59:23:WU00:FS01:Uploading 1.72MiB to 171.67.108.59
18:59:23:WU01:FS01:Starting
18:59:23:WU00:FS01:Connecting to 171.67.108.59:8080
18:59:23:WU01:FS01:Running FahCore: E:\FAHClient/FAHCoreWrapper.exe "C:/Documents and Settings/name/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 01 -suffix 01 -version 701 -lifeline 1104 -checkpoint 15 -np 2
18:59:23:WU01:FS01:Started FahCore on PID 9224
18:59:27:WU01:FS01:Core PID:10012
18:59:27:WU01:FS01:FahCore 0xa4 started
18:59:28:WU01:FS01:0xa4:
18:59:28:WU01:FS01:0xa4:*------------------------------*
18:59:28:WU01:FS01:0xa4:Folding@Home Gromacs GB Core
18:59:28:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
18:59:28:WU01:FS01:0xa4:Preparing to commence simulation
18:59:28:WU01:FS01:0xa4:- Looking at optimizations...
18:59:28:WU01:FS01:0xa4:- Created dyn
18:59:28:WU01:FS01:0xa4:- Files status OK
18:59:28:WU01:FS01:0xa4:- Expanded 2054021 -> 5365960 (decompressed 261.2 percent)
18:59:28:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=2054021 data_size=5365960, decompressed_data_size=5365960 diff=0
18:59:28:WU01:FS01:0xa4:- Digital signature verified
18:59:28:WU01:FS01:0xa4:Project: 7808 (Run 5, Clone 309, Gen 98)
18:59:28:WU01:FS01:0xa4:Assembly optimizations on if available.
18:59:28:WU01:FS01:0xa4:Entering M.D.
18:59:29:WU00:FS01:Upload 10.92%
18:59:34:WU01:FS01:0xa4:Mapping NT from 2 to 2
18:59:35:WU00:FS01:Upload 29.12%
18:59:35:WU01:FS01:0xa4:Completed 0 out of 1500000 steps (0%)
18:59:41:WU00:FS01:Upload 47.31%
18:59:47:WU00:FS01:Upload 69.15%
18:59:53:WU00:FS01:Upload 87.35%
18:59:58:WU00:FS01:Upload complete
18:59:58:WU00:FS01:Server responded WORK_ACK (400)
18:59:58:WU00:FS01:Final credit estimate, 422.00 points
18:59:58:WU00:FS01:Cleaning up
19:10:36:WU02:FS00:0x11:Completed 20%
20:01:07:WU02:FS00:0x11:Completed 21%
20:17:15:WU01:FS01:0xa4:Completed 15000 out of 1500000 steps (1%)
20:51:39:WU02:FS00:0x11:Completed 22%
21:35:09:WU01:FS01:0xa4:Completed 30000 out of 1500000 steps (2%)
21:42:14:WU02:FS00:0x11:Completed 23%
22:14:44:WU02:FS00:0x11:Completed 24%
22:51:17:WU02:FS00:0x11:Completed 25%
22:52:03:WU01:FS01:0xa4:Completed 45000 out of 1500000 steps (3%)
23:05:45:FS00:Paused
23:05:45:FS01:Paused
23:05:45:FS00:Shutting core down
23:05:45:FS01:Shutting core down
23:05:47:WU02:FS00:0x11:Client no longer detected. Shutting down core
23:05:47:WU02:FS00:0x11:Folding@home Core Shutdown: CLIENT_DIED
23:05:48:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
23:05:55:WU01:FS01:0xa4:Client no longer detected. Shutting down core
23:05:55:WU01:FS01:0xa4:Folding@home Core Shutdown: CLIENT_DIED
23:05:56:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
******************************** Date: 27/11/12 ********************************
00:23:54:FS00:Unpaused
00:23:54:FS01:Unpaused
00:23:54:WU02:FS00:Starting
00:23:54:WU02:FS00:Running FahCore: E:\FAHClient/FAHCoreWrapper.exe "C:/Documents and Settings/name/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/NVIDIA/G80/Core_11.fah/FahCore_11.exe" -dir 02 -suffix 01 -version 701 -lifeline 1104 -checkpoint 15 -gpu 0
00:23:54:WU02:FS00:Started FahCore on PID 7416
00:23:54:WU02:FS00:Core PID:8888
00:23:54:WU02:FS00:FahCore 0x11 started
00:23:54:WU01:FS01:Starting
00:23:54:WU01:FS01:Running FahCore: E:\FAHClient/FAHCoreWrapper.exe "C:/Documents and Settings/name/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 01 -suffix 01 -version 701 -lifeline 1104 -checkpoint 15 -np 2
00:23:55:WU01:FS01:Started FahCore on PID 10104
00:23:55:WU02:FS00:0x11:
00:23:55:WU02:FS00:0x11:*------------------------------*
00:23:55:WU02:FS00:0x11:Folding@Home GPU Core
00:23:55:WU02:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
00:23:55:WU02:FS00:0x11:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
00:23:55:WU02:FS00:0x11:Build host: amoeba
00:23:55:WU02:FS00:0x11:Board Type: Nvidia
00:23:55:WU02:FS00:0x11:Core :
00:23:55:WU02:FS00:0x11:Preparing to commence simulation
00:23:55:WU02:FS00:0x11:- Looking at optimizations...
00:23:55:WU02:FS00:0x11:- Files status OK
00:23:55:WU02:FS00:0x11:- Expanded 45391 -> 251112 (decompressed 553.2 percent)
00:23:55:WU02:FS00:0x11:Called DecompressByteArray: compressed_data_size=45391 data_size=251112, decompressed_data_size=251112 diff=0
00:23:55:WU02:FS00:0x11:- Digital signature verified
00:23:55:WU02:FS00:0x11:Project: 5772 (Run 10, Clone 158, Gen 4891)
00:23:55:WU02:FS00:0x11:Assembly optimizations on if available.
00:23:55:WU02:FS00:0x11:Entering M.D.
00:23:56:WU01:FS01:Core PID:7704
00:23:56:WU01:FS01:FahCore 0xa4 started
00:23:57:WU01:FS01:0xa4:
00:23:57:WU01:FS01:0xa4:*------------------------------*
00:23:57:WU01:FS01:0xa4:Folding@Home Gromacs GB Core
00:23:57:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
00:23:57:WU01:FS01:0xa4:Preparing to commence simulation
00:23:57:WU01:FS01:0xa4:- Looking at optimizations...
00:23:57:WU01:FS01:0xa4:- Files status OK
00:23:57:WU01:FS01:0xa4:- Expanded 2054021 -> 5365960 (decompressed 261.2 percent)
00:23:57:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=2054021 data_size=5365960, decompressed_data_size=5365960 diff=0
00:23:57:WU01:FS01:0xa4:- Digital signature verified
00:23:57:WU01:FS01:0xa4:Project: 7808 (Run 5, Clone 309, Gen 98)
00:23:58:WU01:FS01:0xa4:Assembly optimizations on if available.
00:23:58:WU01:FS01:0xa4:Entering M.D.
00:24:01:WU02:FS00:0x11:Will resume from checkpoint file
00:24:01:WU02:FS00:0x11:Tpr hash 02/wudata_01.tpr: 3788852863 3934688430 4045870483 2408932843 2843962430
00:24:01:WU02:FS00:0x11:Calling fah_main args: 14 usage=100
00:24:02:WU02:FS00:0x11:Working on Protein
00:24:03:WU02:FS00:0x11:Client config unavailable.
00:24:03:WU02:FS00:0x11:Starting GUI Server
00:24:03:WU02:FS00:0x11:Resuming from checkpoint
00:24:03:WU02:FS00:0x11:fcCheckPointResume: retreived and current tpr file hash:
00:24:03:WU02:FS00:0x11: 0 3788852863 3788852863
00:24:03:WU02:FS00:0x11: 1 3934688430 3934688430
00:24:03:WU02:FS00:0x11: 2 4045870483 4045870483
00:24:03:WU02:FS00:0x11: 3 2408932843 2408932843
00:24:03:WU02:FS00:0x11: 4 2843962430 2843962430
00:24:03:WU02:FS00:0x11:fcCheckPointResume: file hashes same.
00:24:03:WU02:FS00:0x11:fcCheckPointResume: state restored.
00:24:03:WU02:FS00:0x11:Verified 02/wudata_01.log
00:24:03:WU02:FS00:0x11:Verified 02/wudata_01.edr
00:24:03:WU02:FS00:0x11:Verified 02/wudata_01.xtc
00:24:03:WU02:FS00:0x11:Completed 25%
00:24:04:WU01:FS01:0xa4:Using Gromacs checkpoints
00:24:05:WU01:FS01:0xa4:Mapping NT from 2 to 2
00:24:08:WU01:FS01:0xa4:Resuming from checkpoint
00:24:08:WU01:FS01:0xa4:Verified 01/wudata_01.log
00:24:09:WU01:FS01:0xa4:Verified 01/wudata_01.trr
00:24:09:WU01:FS01:0xa4:Verified 01/wudata_01.xtc
00:24:09:WU01:FS01:0xa4:Verified 01/wudata_01.edr
00:24:10:WU01:FS01:0xa4:Completed 46450 out of 1500000 steps (3%)
00:36:28:WU02:FS00:0x11:Completed 26%
00:54:59:WU02:FS00:0x11:Completed 27%
01:26:23:WU02:FS00:0x11:Completed 28%
01:39:10:WU02:FS00:0x11:Completed 29%
01:53:59:WU02:FS00:0x11:Completed 30%
02:09:11:WU02:FS00:0x11:Completed 31%
02:21:54:WU02:FS00:0x11:Completed 32%
02:33:54:WU02:FS00:0x11:Completed 33%
02:47:47:WU01:FS01:0xa4:Completed 60000 out of 1500000 steps (4%)
03:12:51:WU02:FS00:0x11:Completed 34%
03:27:04:WU02:FS00:0x11:Completed 35%
03:40:54:WU02:FS00:0x11:Completed 36%
03:41:56:FS00:Paused
03:41:56:FS01:Paused
03:41:56:FS00:Shutting core down
03:41:56:FS01:Shutting core down
03:41:58:WU01:FS01:0xa4:Client no longer detected. Shutting down core
03:41:58:WU01:FS01:0xa4:Folding@home Core Shutdown: CLIENT_DIED
03:41:58:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
03:42:01:WU02:FS00:0x11:Client no longer detected. Shutting down core
03:42:01:WU02:FS00:0x11:Folding@home Core Shutdown: CLIENT_DIED
03:42:04:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:08:37:FS00:Unpaused
04:08:37:FS01:Unpaused
04:08:37:WU02:FS00:Starting
04:08:37:WU02:FS00:Running FahCore: E:\FAHClient/FAHCoreWrapper.exe "C:/Documents and Settings/name/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/NVIDIA/G80/Core_11.fah/FahCore_11.exe" -dir 02 -suffix 01 -version 701 -lifeline 1104 -checkpoint 15 -gpu 0
04:08:37:WU02:FS00:Started FahCore on PID 9792
04:08:38:WU02:FS00:Core PID:10024
04:08:38:WU02:FS00:FahCore 0x11 started
04:08:38:WU01:FS01:Starting
04:08:38:WU01:FS01:Running FahCore: E:\FAHClient/FAHCoreWrapper.exe "C:/Documents and Settings/name/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 01 -suffix 01 -version 701 -lifeline 1104 -checkpoint 15 -np 2
04:08:38:WU01:FS01:Started FahCore on PID 8548
04:08:39:WU02:FS00:0x11:
04:08:39:WU02:FS00:0x11:*------------------------------*
04:08:39:WU02:FS00:0x11:Folding@Home GPU Core
04:08:39:WU02:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
04:08:39:WU02:FS00:0x11:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
04:08:39:WU02:FS00:0x11:Build host: amoeba
04:08:39:WU02:FS00:0x11:Board Type: Nvidia
04:08:39:WU02:FS00:0x11:Core :
04:08:39:WU02:FS00:0x11:Preparing to commence simulation
04:08:39:WU02:FS00:0x11:- Looking at optimizations...
04:08:39:WU02:FS00:0x11:- Files status OK
04:08:39:WU02:FS00:0x11:- Expanded 45391 -> 251112 (decompressed 553.2 percent)
04:08:39:WU02:FS00:0x11:Called DecompressByteArray: compressed_data_size=45391 data_size=251112, decompressed_data_size=251112 diff=0
04:08:39:WU02:FS00:0x11:- Digital signature verified
04:08:39:WU02:FS00:0x11:Project: 5772 (Run 10, Clone 158, Gen 4891)
04:08:39:WU02:FS00:0x11:Assembly optimizations on if available.
04:08:39:WU02:FS00:0x11:Entering M.D.
04:08:41:WU01:FS01:Core PID:9416
04:08:41:WU01:FS01:FahCore 0xa4 started
04:08:41:WU01:FS01:0xa4:
04:08:41:WU01:FS01:0xa4:*------------------------------*
04:08:41:WU01:FS01:0xa4:Folding@Home Gromacs GB Core
04:08:41:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
04:08:41:WU01:FS01:0xa4:Preparing to commence simulation
04:08:41:WU01:FS01:0xa4:- Looking at optimizations...
04:08:41:WU01:FS01:0xa4:- Files status OK
04:08:42:WU01:FS01:0xa4:- Expanded 2054021 -> 5365960 (decompressed 261.2 percent)
04:08:42:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=2054021 data_size=5365960, decompressed_data_size=5365960 diff=0
04:08:42:WU01:FS01:0xa4:- Digital signature verified
04:08:42:WU01:FS01:0xa4:Project: 7808 (Run 5, Clone 309, Gen 98)
04:08:42:WU01:FS01:0xa4:Assembly optimizations on if available.
04:08:42:WU01:FS01:0xa4:Entering M.D.
04:08:45:WU02:FS00:0x11:Will resume from checkpoint file
04:08:45:WU02:FS00:0x11:Tpr hash 02/wudata_01.tpr: 3788852863 3934688430 4045870483 2408932843 2843962430
04:08:45:WU02:FS00:0x11:Calling fah_main args: 14 usage=100
04:08:45:WU02:FS00:0x11:Working on Protein
04:08:47:WU02:FS00:0x11:Client config unavailable.
04:08:47:WU02:FS00:0x11:Starting GUI Server
04:08:47:WU02:FS00:0x11:Resuming from checkpoint
04:08:47:WU02:FS00:0x11:fcCheckPointResume: retreived and current tpr file hash:
04:08:47:WU02:FS00:0x11: 0 3788852863 3788852863
04:08:47:WU02:FS00:0x11: 1 3934688430 3934688430
04:08:47:WU02:FS00:0x11: 2 4045870483 4045870483
04:08:47:WU02:FS00:0x11: 3 2408932843 2408932843
04:08:47:WU02:FS00:0x11: 4 2843962430 2843962430
04:08:47:WU02:FS00:0x11:fcCheckPointResume: file hashes same.
04:08:47:WU02:FS00:0x11:fcCheckPointResume: state restored.
04:08:47:WU02:FS00:0x11:Verified 02/wudata_01.log
04:08:47:WU02:FS00:0x11:Verified 02/wudata_01.edr
04:08:47:WU02:FS00:0x11:Verified 02/wudata_01.xtc
04:08:47:WU02:FS00:0x11:Completed 36%
04:08:48:WU01:FS01:0xa4:Using Gromacs checkpoints
04:08:48:WU01:FS01:0xa4:Mapping NT from 2 to 2
04:08:49:WU01:FS01:0xa4:Resuming from checkpoint
04:08:49:WU01:FS01:0xa4:Verified 01/wudata_01.log
04:08:49:WU01:FS01:0xa4:Verified 01/wudata_01.trr
04:08:49:WU01:FS01:0xa4:Verified 01/wudata_01.xtc
04:08:49:WU01:FS01:0xa4:Verified 01/wudata_01.edr
04:08:50:WU01:FS01:0xa4:Completed 61940 out of 1500000 steps (4%)
04:14:07:FS00:Paused
04:14:07:FS01:Paused
04:14:07:FS00:Shutting core down
04:14:07:FS01:Shutting core down
04:14:08:WU02:FS00:0x11:Client no longer detected. Shutting down core
04:14:08:WU02:FS00:0x11:Folding@home Core Shutdown: CLIENT_DIED
04:14:09:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:14:11:WU01:FS01:0xa4:Client no longer detected. Shutting down core
04:14:11:WU01:FS01:0xa4:Folding@home Core Shutdown: CLIENT_DIED
04:14:11:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
04:52:05:FS00:Unpaused
04:52:05:FS01:Unpaused
04:52:05:WU02:FS00:Starting
04:52:05:WU02:FS00:Running FahCore: E:\FAHClient/FAHCoreWrapper.exe "C:/Documents and Settings/name/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/NVIDIA/G80/Core_11.fah/FahCore_11.exe" -dir 02 -suffix 01 -version 701 -lifeline 1104 -checkpoint 15 -gpu 0
04:52:06:WU02:FS00:Started FahCore on PID 8104
04:52:06:WU02:FS00:Core PID:7428
04:52:06:WU02:FS00:FahCore 0x11 started
04:52:07:WU01:FS01:Starting
04:52:07:WU01:FS01:Running FahCore: E:\FAHClient/FAHCoreWrapper.exe "C:/Documents and Settings/name/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 01 -suffix 01 -version 701 -lifeline 1104 -checkpoint 15 -np 2
04:52:07:WU01:FS01:Started FahCore on PID 8308
04:52:07:WU02:FS00:0x11:
04:52:07:WU02:FS00:0x11:*------------------------------*
04:52:07:WU02:FS00:0x11:Folding@Home GPU Core
04:52:07:WU02:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
04:52:07:WU02:FS00:0x11:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
04:52:07:WU02:FS00:0x11:Build host: amoeba
04:52:07:WU02:FS00:0x11:Board Type: Nvidia
04:52:07:WU02:FS00:0x11:Core :
04:52:07:WU02:FS00:0x11:Preparing to commence simulation
04:52:07:WU02:FS00:0x11:- Looking at optimizations...
04:52:07:WU02:FS00:0x11:- Files status OK
04:52:07:WU02:FS00:0x11:- Expanded 45391 -> 251112 (decompressed 553.2 percent)
04:52:07:WU02:FS00:0x11:Called DecompressByteArray: compressed_data_size=45391 data_size=251112, decompressed_data_size=251112 diff=0
04:52:07:WU02:FS00:0x11:- Digital signature verified
04:52:07:WU02:FS00:0x11:Project: 5772 (Run 10, Clone 158, Gen 4891)
04:52:07:WU02:FS00:0x11:Assembly optimizations on if available.
04:52:07:WU02:FS00:0x11:Entering M.D.
04:52:09:WU01:FS01:Core PID:1616
04:52:09:WU01:FS01:FahCore 0xa4 started
04:52:10:WU01:FS01:0xa4:
04:52:10:WU01:FS01:0xa4:*------------------------------*
04:52:10:WU01:FS01:0xa4:Folding@Home Gromacs GB Core
04:52:10:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
04:52:10:WU01:FS01:0xa4:Preparing to commence simulation
04:52:10:WU01:FS01:0xa4:- Looking at optimizations...
04:52:10:WU01:FS01:0xa4:- Files status OK
04:52:10:WU01:FS01:0xa4:- Expanded 2054021 -> 5365960 (decompressed 261.2 percent)
04:52:10:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=2054021 data_size=5365960, decompressed_data_size=5365960 diff=0
04:52:10:WU01:FS01:0xa4:- Digital signature verified
04:52:10:WU01:FS01:0xa4:Project: 7808 (Run 5, Clone 309, Gen 98)
04:52:10:WU01:FS01:0xa4:Assembly optimizations on if available.
04:52:10:WU01:FS01:0xa4:Entering M.D.
04:52:13:WU02:FS00:0x11:Will resume from checkpoint file
04:52:13:WU02:FS00:0x11:Tpr hash 02/wudata_01.tpr: 3788852863 3934688430 4045870483 2408932843 2843962430
04:52:13:WU02:FS00:0x11:Calling fah_main args: 14 usage=100
04:52:13:WU02:FS00:0x11:Working on Protein
04:52:15:WU02:FS00:0x11:Client config unavailable.
04:52:15:WU02:FS00:0x11:Starting GUI Server
04:52:15:WU02:FS00:0x11:Resuming from checkpoint
04:52:15:WU02:FS00:0x11:fcCheckPointResume: retreived and current tpr file hash:
04:52:15:WU02:FS00:0x11: 0 3788852863 3788852863
04:52:15:WU02:FS00:0x11: 1 3934688430 3934688430
04:52:15:WU02:FS00:0x11: 2 4045870483 4045870483
04:52:15:WU02:FS00:0x11: 3 2408932843 2408932843
04:52:15:WU02:FS00:0x11: 4 2843962430 2843962430
04:52:15:WU02:FS00:0x11:fcCheckPointResume: file hashes same.
04:52:15:WU02:FS00:0x11:fcCheckPointResume: state restored.
04:52:15:WU02:FS00:0x11:Verified 02/wudata_01.log
04:52:15:WU02:FS00:0x11:Verified 02/wudata_01.edr
04:52:15:WU02:FS00:0x11:Verified 02/wudata_01.xtc
04:52:15:WU02:FS00:0x11:Completed 36%
04:52:16:WU01:FS01:0xa4:Using Gromacs checkpoints
04:52:16:WU01:FS01:0xa4:Mapping NT from 2 to 2
04:52:17:WU01:FS01:0xa4:Resuming from checkpoint
04:52:17:WU01:FS01:0xa4:Verified 01/wudata_01.log
04:52:17:WU01:FS01:0xa4:Verified 01/wudata_01.trr
04:52:18:WU01:FS01:0xa4:Verified 01/wudata_01.xtc
04:52:18:WU01:FS01:0xa4:Verified 01/wudata_01.edr
04:52:18:WU01:FS01:0xa4:Completed 61940 out of 1500000 steps (4%)
05:07:43:WU02:FS00:0x11:Completed 37%
05:21:01:WU02:FS00:0x11:Completed 38%
05:51:36:WU02:FS00:0x11:Completed 39%
06:04:52:WU02:FS00:0x11:Completed 40%
06:28:16:WU02:FS00:0x11:Completed 41%
06:42:54:WU02:FS00:0x11:Completed 42%
06:55:16:WU02:FS00:0x11:Completed 43%
07:08:12:WU02:FS00:0x11:Completed 44%
07:22:54:WU02:FS00:0x11:Completed 45%
07:38:05:WU02:FS00:0x11:Completed 46%
07:52:08:WU02:FS00:0x11:Completed 47%
08:05:23:WU02:FS00:0x11:Completed 48%
08:25:32:WU02:FS00:0x11:Completed 49%
08:37:28:WU02:FS00:0x11:Completed 50%
08:47:01:FS00:Paused
08:47:01:FS01:Paused
08:47:02:FS00:Shutting core down
08:47:02:FS01:Shutting core down
08:47:10:WU02:FS00:0x11:Client no longer detected. Shutting down core
08:47:10:WU02:FS00:0x11:Folding@home Core Shutdown: CLIENT_DIED
08:47:11:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
08:47:12:WU01:FS01:0xa4:Client no longer detected. Shutting down core
08:47:12:WU01:FS01:0xa4:Folding@home Core Shutdown: CLIENT_DIED
08:47:12:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
09:43:19:FS00:Unpaused
09:43:19:FS01:Unpaused
09:43:19:WU02:FS00:Starting
09:43:19:WU02:FS00:Running FahCore: E:\FAHClient/FAHCoreWrapper.exe "C:/Documents and Settings/name/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/NVIDIA/G80/Core_11.fah/FahCore_11.exe" -dir 02 -suffix 01 -version 701 -lifeline 1104 -checkpoint 15 -gpu 0
09:43:20:WU02:FS00:Started FahCore on PID 8604
09:43:21:WU02:FS00:Core PID:9088
09:43:21:WU02:FS00:FahCore 0x11 started
09:43:21:WU01:FS01:Starting
09:43:21:WU01:FS01:Running FahCore: E:\FAHClient/FAHCoreWrapper.exe "C:/Documents and Settings/name/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 01 -suffix 01 -version 701 -lifeline 1104 -checkpoint 15 -np 2
09:43:21:WU01:FS01:Started FahCore on PID 9372
09:43:23:WU02:FS00:0x11:
09:43:23:WU02:FS00:0x11:*------------------------------*
09:43:23:WU02:FS00:0x11:Folding@Home GPU Core
09:43:23:WU02:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
09:43:23:WU02:FS00:0x11:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
09:43:23:WU02:FS00:0x11:Build host: amoeba
09:43:23:WU02:FS00:0x11:Board Type: Nvidia
09:43:23:WU02:FS00:0x11:Core :
09:43:23:WU02:FS00:0x11:Preparing to commence simulation
09:43:23:WU02:FS00:0x11:- Looking at optimizations...
09:43:23:WU02:FS00:0x11:- Files status OK
09:43:23:WU02:FS00:0x11:- Expanded 45391 -> 251112 (decompressed 553.2 percent)
09:43:23:WU02:FS00:0x11:Called DecompressByteArray: compressed_data_size=45391 data_size=251112, decompressed_data_size=251112 diff=0
09:43:23:WU02:FS00:0x11:- Digital signature verified
09:43:23:WU02:FS00:0x11:Project: 5772 (Run 10, Clone 158, Gen 4891)
09:43:23:WU02:FS00:0x11:Assembly optimizations on if available.
09:43:23:WU02:FS00:0x11:Entering M.D.
09:43:26:WU01:FS01:Core PID:5648
09:43:26:WU01:FS01:FahCore 0xa4 started
09:43:27:WU01:FS01:0xa4:
09:43:27:WU01:FS01:0xa4:*------------------------------*
09:43:27:WU01:FS01:0xa4:Folding@Home Gromacs GB Core
09:43:27:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
09:43:27:WU01:FS01:0xa4:Preparing to commence simulation
09:43:27:WU01:FS01:0xa4:- Looking at optimizations...
09:43:27:WU01:FS01:0xa4:- Files status OK
09:43:29:WU02:FS00:0x11:Will resume from checkpoint file
09:43:29:WU02:FS00:0x11:Tpr hash 02/wudata_01.tpr: 3788852863 3934688430 4045870483 2408932843 2843962430
09:43:29:WU02:FS00:0x11:Calling fah_main args: 14 usage=100
09:43:29:WU01:FS01:0xa4:- Expanded 2054021 -> 5365960 (decompressed 261.2 percent)
09:43:29:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=2054021 data_size=5365960, decompressed_data_size=5365960 diff=0
09:43:29:WU01:FS01:0xa4:- Digital signature verified
09:43:29:WU01:FS01:0xa4:Project: 7808 (Run 5, Clone 309, Gen 98)
09:43:29:WU02:FS00:0x11:Working on Protein
09:43:30:WU01:FS01:0xa4:Assembly optimizations on if available.
09:43:30:WU01:FS01:0xa4:Entering M.D.
09:43:31:WU02:FS00:0x11:Client config unavailable.
09:43:31:WU02:FS00:0x11:Starting GUI Server
09:43:31:WU02:FS00:0x11:Resuming from checkpoint
09:43:31:WU02:FS00:0x11:fcCheckPointResume: retreived and current tpr file hash:
09:43:31:WU02:FS00:0x11: 0 3788852863 3788852863
09:43:31:WU02:FS00:0x11: 1 3934688430 3934688430
09:43:31:WU02:FS00:0x11: 2 4045870483 4045870483
09:43:31:WU02:FS00:0x11: 3 2408932843 2408932843
09:43:31:WU02:FS00:0x11: 4 2843962430 2843962430
09:43:31:WU02:FS00:0x11:fcCheckPointResume: file hashes same.
09:43:31:WU02:FS00:0x11:fcCheckPointResume: state restored.
09:43:31:WU02:FS00:0x11:Verified 02/wudata_01.log
09:43:31:WU02:FS00:0x11:Verified 02/wudata_01.edr
09:43:31:WU02:FS00:0x11:Verified 02/wudata_01.xtc
09:43:31:WU02:FS00:0x11:Completed 50%
09:43:36:WU01:FS01:0xa4:Using Gromacs checkpoints
09:43:37:WU01:FS01:0xa4:Mapping NT from 2 to 2
09:43:40:WU01:FS01:0xa4:Resuming from checkpoint
09:43:40:WU01:FS01:0xa4:Verified 01/wudata_01.log
09:43:41:WU01:FS01:0xa4:Verified 01/wudata_01.trr
09:43:41:WU01:FS01:0xa4:Verified 01/wudata_01.xtc
09:43:41:WU01:FS01:0xa4:Verified 01/wudata_01.edr
09:43:43:WU01:FS01:0xa4:Completed 71050 out of 1500000 steps (4%)
09:56:55:WU02:FS00:0x11:Completed 51%
10:05:44:WU01:FS01:0xa4:Completed 75000 out of 1500000 steps (5%)
10:33:29:WU02:FS00:0x11:Completed 52%
10:51:33:WU02:FS00:0x11:Completed 53%
11:09:06:WU02:FS00:0x11:Completed 54%
11:20:47:WU02:FS00:0x11:Completed 55%
11:35:11:WU02:FS00:0x11:Completed 56%Re: Large drop in PPD
Hi Bruce,bruce wrote:To summarize,To state it another way, does the PPD accurately reflect your WU production rate?
No I have not calculated my points manually. Now that you mention it, I did notice in my logs that sometimes a work unit will be finished, uploaded, and then accepted but Folding @ home will not report back how many points were earned. In other cases, I get back a number that tells me the points, but recently points stopped arriving, at least in the log.
As I said, I dont fold for points so I have not been on top of this too much. But judging from what another responder said, it looks like my CPU work is not being credited. That's a shame as I have had my computer running night and day for months.
I'll try to see if I can find an example in my logs. I have not looked in a long time. I posted some logs in the last reply, but did not look for this particular issue.
I think this is an example of what I was talking about. Look here and see that work was completed, uploaded, and accepted but no points awarded.
05:37:29:WU00:FS01:0xa4:Completed 290000 out of 500000 steps (58%)
05:37:41:WU01:FS00:0x11:Completed 96%
06:14:09:WU01:FS00:0x11:Completed 97%
06:39:42:WU01:FS00:0x11:Completed 98%
06:41:14:WU00:FS01:0xa4:Completed 295000 out of 500000 steps (59%)
07:17:08:WU01:FS00:0x11:Completed 99%
07:17:09:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
07:17:13:WU02:FS00:News: Welcome to Folding@Home
07:17:13:WU02:FS00:Assigned to work server 171.67.108.11
07:17:13:WU02:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:"G98M [Quadro NVS 160M]" from 171.67.108.11
07:17:13:WU02:FS00:Connecting to 171.67.108.11:8080
07:17:14:WU02:FS00:Downloading 44.83KiB
07:17:14:WU02:FS00:Download complete
07:17:14:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:OK project:5772 run:10 clone:158 gen:4891 core:0x11 unit:0x1ba37bb650b31766131b009e000a168c
07:17:14:WU02:FS00:Downloading project 5772 description
07:17:15:WU02:FS00:Connecting to fah-web.stanford.edu:80
07:17:17:WU02:FS00:Project 5772 description downloaded successfully
07:43:38:WU01:FS00:0x11:Completed 100%
07:43:39:WU01:FS00:0x11:Successful run
07:43:39:WU01:FS00:0x11:DynamicWrapper: Finished Work Unit: sleep=10000
07:43:49:WU01:FS00:0x11:Reserved 109056 bytes for xtc file; Cosm status=0
07:43:49:WU01:FS00:0x11:Allocated 109056 bytes for xtc file
07:43:49:WU01:FS00:0x11:- Reading up to 109056 from "01/wudata_01.xtc": Read 109056
07:43:49:WU01:FS00:0x11:Read 109056 bytes from xtc file; available packet space=786321408
07:43:49:WU01:FS00:0x11:xtc file hash check passed.
07:43:49:WU01:FS00:0x11:Reserved 21912 21912 786321408 bytes for arc file=<01/wudata_01.trr> Cosm status=0
07:43:49:WU01:FS00:0x11:Allocated 21912 bytes for arc file
07:43:49:WU01:FS00:0x11:- Reading up to 21912 from "01/wudata_01.trr": Read 21912
07:43:49:WU01:FS00:0x11:Read 21912 bytes from arc file; available packet space=786299496
07:43:49:WU01:FS00:0x11:trr file hash check passed.
07:43:49:WU01:FS00:0x11:Allocated 560 bytes for edr file
07:43:49:WU01:FS00:0x11:Read bedfile
07:43:49:WU01:FS00:0x11:edr file hash check passed.
07:43:49:WU01:FS00:0x11:Logfile not read.
07:43:49:WU01:FS00:0x11:GuardedRun: success in DynamicWrapper
07:43:49:WU01:FS00:0x11:GuardedRun: done
07:43:49:WU01:FS00:0x11:Run: GuardedRun completed.
07:43:52:WU01:FS00:0x11:+ Opened results file
07:43:52:WU01:FS00:0x11:- Writing 132040 bytes of core data to disk...
07:43:53:WU01:FS00:0x11:Done: 131528 -> 130516 (compressed to 99.2 percent)
07:43:53:WU01:FS00:0x11: ... Done.
07:43:53:WU01:FS00:0x11:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
07:43:53:WU01:FS00:0x11:Shutting down core
07:43:53:WU01:FS00:0x11:Folding@home Core Shutdown: FINISHED_UNIT
07:43:54:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
07:43:54:WU01:FS00:Sending unit results: id:01 state:SEND error:OK project:10504 run:103 clone:1 gen:1033 core:0x11 unit:0x000009556652eda54b75af3400003483
07:43:54:WU01:FS00:Uploading 127.96KiB to 171.67.108.21
07:43:54:WU02:FS00:Starting
07:43:54:WU01:FS00:Connecting to 171.67.108.21:8080
07:43:54:WU02:FS00:Running FahCore: E:\FAHClient/FAHCoreWrapper.exe "C:/Documents and Settings/tomribaudo/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/NVIDIA/G80/Core_11.fah/FahCore_11.exe" -dir 02 -suffix 01 -version 701 -lifeline 1104 -checkpoint 15 -gpu 0
07:43:55:WU02:FS00:Started FahCore on PID 10040
07:43:56:WU02:FS00:Core PID:10008
07:43:56:WU02:FS00:FahCore 0x11 started
07:43:57:WU02:FS00:0x11:
07:43:57:WU02:FS00:0x11:*------------------------------*
07:43:57:WU02:FS00:0x11:Folding@Home GPU Core
07:43:57:WU02:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
07:43:57:WU02:FS00:0x11:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
07:43:57:WU02:FS00:0x11:Build host: amoeba
07:43:57:WU02:FS00:0x11:Board Type: Nvidia
07:43:57:WU02:FS00:0x11:Core :
07:43:57:WU02:FS00:0x11:Preparing to commence simulation
07:43:57:WU02:FS00:0x11:- Looking at optimizations...
07:43:57:WU02:FS00:0x11:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
07:43:57:WU02:FS00:0x11:- Created dyn
07:43:57:WU02:FS00:0x11:- Files status OK
07:43:57:WU02:FS00:0x11:- Expanded 45391 -> 251112 (decompressed 553.2 percent)
07:43:57:WU02:FS00:0x11:Called DecompressByteArray: compressed_data_size=45391 data_size=251112, decompressed_data_size=251112 diff=0
07:43:57:WU02:FS00:0x11:- Digital signature verified
07:43:57:WU02:FS00:0x11:Project: 5772 (Run 10, Clone 158, Gen 4891)
07:43:57:WU02:FS00:0x11:Assembly optimizations on if available.
07:43:57:WU02:FS00:0x11:Entering M.D.
07:44:03:WU02:FS00:0x11:Tpr hash 02/wudata_01.tpr: 3788852863 3934688430 4045870483 2408932843 2843962430
07:44:03:WU02:FS00:0x11:Calling fah_main args: 14 usage=100
07:44:05:WU02:FS00:0x11:Working on Protein
07:44:14:WU02:FS00:0x11:Client config unavailable.
07:44:16:WU02:FS00:0x11:Starting GUI Server
07:44:52:WU01:FS00:Upload 100.00%
07:44:55:WU01:FS00:Upload complete
07:44:55:WU01:FS00:Server responded WORK_ACK (400)
07:44:55:WU01:FS00:Cleaning upRe: Large drop in PPD
*********************** Log Started 2012-11-22T04:41:11Z ***********************
04:41:11:************************* Folding@home Client *************************
04:41:11: Website: http://folding.stanford.edu/
04:41:11: Copyright: (c) 2009-2012 Stanford University
04:41:11: Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:41:11: Args: --lifeline 3528 --command-port=36330
04:41:11: Config: C:/Documents and Settings/name/Application
04:41:11: Data/FAHClient/config.xml
04:41:11:******************************** Build ********************************
04:41:11: Version: 7.1.52
04:41:11: Date: Mar 20 2012
04:41:11: Time: 19:37:42
04:41:11: SVN Rev: 3515
04:41:11: Branch: fah/trunk/client
04:41:11: Compiler: Intel(R) C++ MSVC 1500 mode 1200
04:41:11: Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
04:41:11: /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
04:41:11: Platform: win32 XP
04:41:11: Bits: 32
04:41:11: Mode: Release
04:41:11:******************************* System ********************************
04:41:11: CPU: Intel(R) Core(TM)2 Duo CPU P8600 @ 2.40GHz
04:41:11: CPU ID: GenuineIntel Family 6 Model 23 Stepping 10
04:41:11: CPUs: 2
04:41:11: Memory: 1.99GiB
04:41:11: Free Memory: 812.27MiB
04:41:11: Threads: WINDOWS_THREADS
04:41:11: On Battery: false
04:41:11: UTC offset: 8
04:41:11: PID: 1104
04:41:11: CWD: C:/Documents and Settings/name/Application Data/FAHClient
04:41:11: OS: Microsoft Windows XP Service Pack 3
04:41:11: OS Arch: X86
04:41:11: GPUs: 1
04:41:11: GPU 0: NVIDIA:1 G98M [Quadro NVS 160M]
04:41:11: CUDA: Not detected
04:41:11:Win32 Service: false
04:41:11:***********************************************************************
04:41:11:<config>
04:41:11: <!-- Folding Slot Configuration -->
04:41:11: <gpu v='true'/>
04:41:11:
04:41:11: <!-- Network -->
04:41:11: <proxy v=':8080'/>
04:41:11:
04:41:11: <!-- User Information -->
04:41:11: <passkey v='********************************'/>
04:41:11: <user v='RattyM'/>
04:41:11:
04:41:11: <!-- Folding Slots -->
04:41:11: <slot id='0' type='GPU'/>
04:41:11: <slot id='1' type='SMP'/>
04:41:11:</config>
04:41:11:Trying to access database...
04:41:11:Successfully acquired database lock
04:41:11:Enabled folding slot 00: READY gpu:0:"G98M [Quadro NVS 160M]"
04:41:11:Enabled folding slot 01: READY smp:2
04:41:12:WU02:FS01:StartingRe: Large drop in PPD
You did receive credit for the one in your first log:
Hi RattyM (team 0),
Your WU (P8056 R19 C7 G37) was added to the stats database on 2012-11-26 11:10:34 for 464.92 points of credit.
As far as points not showing in the log there are some servers that need an upgrade to do that so there's nothing unusual there.
It does appear that there's a gap between the 15th and 26th where no SMP WUs were returned. You need to look at the logs during that period to see what was going on.
Other than you're not using the latest version of the client the logs look good.
Hi RattyM (team 0),
Thank you for the help. My logs don't go back that far in time so I cannot post any more information. I cant guess why I have an 11 day gap in my WU's being returned. I recall working on one WU that needed almost a full week of crunching. But I dont recall it taking 11 days.
What doe SMP stand for?
My SMP is currently working on a WU that will take almost 5.5 days to complete. I hope that all that crunching will not be lost. I am getting a lot of WU that take 5-6 days now. Might that be the problem?
If you're referring to the P7808 it has a preferred deadline of 25.23 days so 5-6 days is okay. However, if for some reason those type of WUs are not finishing and uploading properly then that could explain the large gap in returns. Take a look at the previous logs especially around the 20th and look for the upload.
Previous logs can be found in the Data Directory (Start>All Programs>FAHClient>Data Directory) in a sub directory called logs.
SMP stands for Symmetric multiprocessing and is one of your slot types. Basically referring to a CPU that has more than one core.
