More Folding Lost
More Folding Lost
Not sure what happened here. I was in the upper 90's%, nearly finished with a WU when I had to pause it for a second. When I restarted a few minutes later, I no longer saw it being worked on. It says I was past the final deadline, which is very confusing. I have had this computer folding 23 hours a day, every day. Why would I be given a WU that I could not complete with virtually 100% uptime? And why would my computer work all the way up to 92% or so and then dump it? Seems like an awfully wasteful way to work. Can someone help me understand this? Thanks.
20:57:49:WU01:FS01:0xa4:Preparing to commence simulation
20:57:49:WU01:FS01:0xa4:- Looking at optimizations...
20:57:49:WU01:FS01:0xa4:- Created dyn
20:57:49:WU01:FS01:0xa4:- Files status OK
20:57:49:WU01:FS01:0xa4:- Expanded 2079913 -> 5386224 (decompressed 258.9 percent)
20:57:49:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=2079913 data_size=5386224, decompressed_data_size=5386224 diff=0
20:57:49:WU01:FS01:0xa4:- Digital signature verified
20:57:49:WU01:FS01:0xa4:Project: 7809 (Run 10, Clone 266, Gen 67)
20:57:49:WU01:FS01:0xa4:Assembly optimizations on if available.
20:57:49:WU01:FS01:0xa4:Entering M.D.
20:57:54:WU00:FS01:Upload 4.54%
20:57:55:WU01:FS01:0xa4:Mapping NT from 2 to 2
20:57:57:WU01:FS01:0xa4:Completed 0 out of 1500000 steps (0%)
20:58:00:WU00:FS01:Upload 13.63%
20:58:06:WU00:FS01:Upload 19.69%
20:58:12:WU00:FS01:Upload 27.26%
20:58:18:WU00:FS01:Upload 36.35%
20:58:24:WU00:FS01:Upload 43.92%
20:58:30:WU00:FS01:Upload 53.01%
20:58:36:WU00:FS01:Upload 59.07%
20:58:42:WU00:FS01:Upload 68.16%
20:58:48:WU00:FS01:Upload 74.21%
20:58:54:WU00:FS01:Upload 81.79%
20:59:00:WU00:FS01:Upload 89.36%
20:59:07:WU00:FS01:Upload 96.93%
20:59:11:WU00:FS01:Upload complete
20:59:11:WU00:FS01:Server responded WORK_ACK (400)
20:59:11:WU00:FS01:Final credit estimate, 3585.00 points
20:59:11:WU00:FS01:Cleaning up
21:18:29:WU02:FS00:0x11:Completed 88%
22:21:14:WU01:FS01:0xa4:Completed 15000 out of 1500000 steps (1%)
******************************** Date: 12/07/12 ********************************
22:33:49:WU02:FS00:0x11:Completed 89%
23:32:17:FS00:Paused
23:32:17:FS01:Paused
23:32:17:FS00:Shutting core down
23:32:17:FS01:Shutting core down
23:32:22:WU02:FS00:0x11:Client no longer detected. Shutting down core
23:32:22:WU02:FS00:0x11:Folding@home Core Shutdown: CLIENT_DIED
23:32:23:WU01:FS01:0xa4:Client no longer detected. Shutting down core
23:32:23:WU01:FS01:0xa4:Folding@home Core Shutdown: CLIENT_DIED
23:32:23:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
23:32:23:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
00:24:07:FS00:Unpaused
00:24:07:FS01:Unpaused
00:24:07:WU02:FS00:Starting
00:24:08:WU02:FS00:Running FahCore: E:\FAHClient/FAHCoreWrapper.exe "C:/Documents and Settings/name/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/NVIDI ... ore_11.exe" -dir 02 -suffix 01 -version 701 -lifeline 5132 -checkpoint 15 -gpu 0
00:24:08:WU02:FS00:Started FahCore on PID 1128
00:24:08:WU02:FS00:Core PID:4456
00:24:08:WU02:FS00:FahCore 0x11 started
00:24:08:WU01:FS01:Starting
00:24:08:WU01:FS01:Running FahCore: E:\FAHClient/FAHCoreWrapper.exe "C:/Documents and Settings/name/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_ ... ore_a4.exe" -dir 01 -suffix 01 -version 701 -lifeline 5132 -checkpoint 15 -np 2
00:24:08:WU01:FS01:Started FahCore on PID 4152
00:24:09:WU02:FS00:0x11:
00:24:09:WU02:FS00:0x11:*------------------------------*
00:24:09:WU02:FS00:0x11:Folding@Home GPU Core
00:24:09:WU02:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
00:24:09:WU02:FS00:0x11:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
00:24:09:WU02:FS00:0x11:Build host: amoeba
00:24:09:WU02:FS00:0x11:Board Type: Nvidia
00:24:09:WU02:FS00:0x11:Core :
00:24:09:WU02:FS00:0x11:Preparing to commence simulation
00:24:09:WU02:FS00:0x11:- Looking at optimizations...
00:24:09:WU02:FS00:0x11:- Files status OK
00:24:09:WU02:FS00:0x11:- Expanded 62974 -> 336763 (decompressed 534.7 percent)
00:24:09:WU02:FS00:0x11:Called DecompressByteArray: compressed_data_size=62974 data_size=336763, decompressed_data_size=336763 diff=0
00:24:09:WU02:FS00:0x11:- Digital signature verified
00:24:09:WU02:FS00:0x11:Project: 10502 (Run 489, Clone 0, Gen 427)
00:24:09:WU02:FS00:0x11:Assembly optimizations on if available.
00:24:09:WU02:FS00:0x11:Entering M.D.
00:24:09:WU01:FS01:Core PID:5408
00:24:09:WU01:FS01:FahCore 0xa4 started
00:24:09:WU01:FS01:0xa4:
00:24:09:WU01:FS01:0xa4:*------------------------------*
00:24:09:WU01:FS01:0xa4:Folding@Home Gromacs GB Core
00:24:09:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
00:24:09:WU01:FS01:0xa4:Preparing to commence simulation
00:24:09:WU01:FS01:0xa4:- Looking at optimizations...
00:24:09:WU01:FS01:0xa4:- Files status OK
00:24:09:WU01:FS01:0xa4:- Expanded 2079913 -> 5386224 (decompressed 258.9 percent)
00:24:09:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=2079913 data_size=5386224, decompressed_data_size=5386224 diff=0
00:24:10:WU01:FS01:0xa4:- Digital signature verified
00:24:10:WU01:FS01:0xa4:Project: 7809 (Run 10, Clone 266, Gen 67)
00:24:10:WU01:FS01:0xa4:Assembly optimizations on if available.
00:24:10:WU01:FS01:0xa4:Entering M.D.
00:24:15:WU02:FS00:0x11:Will resume from checkpoint file
00:24:15:WU02:FS00:0x11:Tpr hash 02/wudata_01.tpr: 2124241214 1914994775 1056910139 1102866594 2690281205
00:24:15:WU02:FS00:0x11:Calling fah_main args: 14 usage=100
00:24:15:WU02:FS00:0x11:Working on Protein
00:24:16:WU01:FS01:0xa4:Using Gromacs checkpoints
00:24:16:WU01:FS01:0xa4:Mapping NT from 2 to 2
00:24:16:WU01:FS01:0xa4:Resuming from checkpoint
00:24:16:WU01:FS01:0xa4:Verified 01/wudata_01.log
00:24:17:WU01:FS01:0xa4:Verified 01/wudata_01.trr
00:24:17:WU01:FS01:0xa4:Verified 01/wudata_01.xtc
00:24:17:WU01:FS01:0xa4:Verified 01/wudata_01.edr
00:24:17:WU01:FS01:0xa4:Completed 26990 out of 1500000 steps (1%)
00:24:18:WU02:FS00:0x11:Client config unavailable.
00:24:18:WU02:FS00:0x11:Starting GUI Server
00:24:18:WU02:FS00:0x11:Resuming from checkpoint
00:24:18:WU02:FS00:0x11:fcCheckPointResume: retreived and current tpr file hash:
00:24:18:WU02:FS00:0x11: 0 2124241214 2124241214
00:24:18:WU02:FS00:0x11: 1 1914994775 1914994775
00:24:18:WU02:FS00:0x11: 2 1056910139 1056910139
00:24:18:WU02:FS00:0x11: 3 1102866594 1102866594
00:24:18:WU02:FS00:0x11: 4 2690281205 2690281205
00:24:18:WU02:FS00:0x11:fcCheckPointResume: file hashes same.
00:24:18:WU02:FS00:0x11:fcCheckPointResume: state restored.
00:24:18:WU02:FS00:0x11:Verified 02/wudata_01.log
00:24:18:WU02:FS00:0x11:Verified 02/wudata_01.edr
00:24:18:WU02:FS00:0x11:Verified 02/wudata_01.xtc
00:24:18:WU02:FS00:0x11:Completed 89%
00:44:16:WU01:FS01:0xa4:Completed 30000 out of 1500000 steps (2%)
00:47:13:WU02:FS00:0x11:Completed 90%
01:10:18:WU02:FS00:0x11:Completed 91%
01:32:55:WU02:FS00:0x11:Completed 92%
01:55:39:WU02:FS00:0x11:Completed 93%
02:18:25:WU02:FS00:0x11:Completed 94%
02:25:59:WU01:FS01:0xa4:Completed 45000 out of 1500000 steps (3%)
02:41:31:WU02:FS00:0x11:Completed 95%
03:04:30:WU02:FS00:0x11:Completed 96%
03:27:57:WU02:FS00:0x11:Completed 97%
03:56:17:WU02:FS00:0x11:Completed 98%
04:15:00:WU01:FS01:0xa4:Completed 60000 out of 1500000 steps (4%)
04:18:46:WU02:FS00:0x11:Completed 99%
04:18:47:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
04:18:54:WU00:FS00:News: Welcome to Folding@Home
04:18:54:WU00:FS00:Assigned to work server 171.67.108.11
04:18:54:WU00:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:"G98M [Quadro NVS 160M]" from 171.67.108.11
04:18:54:WU00:FS00:Connecting to 171.67.108.11:8080
04:18:55:WU00:FS00:Downloading 44.87KiB
04:18:56:WU00:FS00:Download complete
04:18:56:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:OK project:5771 run:2 clone:179 gen:1477 core:0x11 unit:0x1a3ba4524fffa19805c500b30002168b
04:18:56:WU00:FS00:Downloading project 5771 description
04:18:56:WU00:FS00:Connecting to fah-web.stanford.edu:80
04:18:58:WU00:FS00:Project 5771 description downloaded successfully
04:21:30:FS00:Paused
04:21:30:FS01:Paused
04:21:30:FS00:Shutting core down
04:21:30:FS01:Shutting core down
04:21:32:WU01:FS01:0xa4:Client no longer detected. Shutting down core
04:21:32:WU01:FS01:0xa4:Folding@home Core Shutdown: CLIENT_DIED
04:21:32:WU02:FS00:0x11:Client no longer detected. Shutting down core
04:21:32:WU02:FS00:0x11:Folding@home Core Shutdown: CLIENT_DIED
04:21:32:WU01:FS01:FahCore returned: INTERRUPTED (102 = 0x66)
04:21:33:WU02:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
04:28:52:WARNING:WU02:FS00:Past final deadline 2012-07-13T04:28:51Z, dumping
04:28:52:WU02:FS00:Cleaning up
iceman1992
Re: More Folding Lost
When was it downloaded?
From the log I see that the WU in question was Project 10502 (Run 489, Clone 0, Gen 427), am I right?
It has a deadline of 12 days http://fah-web.stanford.edu/cgi-bin/fah ... ed?p=10502
The assignment server doesn't know how fast your machine is. Most of the time it is up to the user to decide if the machine can complete a WU or not.RMouse wrote:Why would I be given a WU that I could not complete with virtually 100% uptime?
I am not sure when it started. I didnt notice my computer working on the same WU for 12 days. I'll have to pay more close attention. Since it finished the last 20% or so today, I doubt it was working on this WU for 12 days. I have no idea what is going on.iceman1992 wrote:When was it downloaded?
How can I properly evaluate a WU so that I only get what my machine is capable of?
EDIT: I looked at my log and see that I started this WU on either 7/9 or 7/10 of this month. So it did not take me 12 days to finish this.
00:39:15:WU02:FS00:Starting
00:39:15:WU02:FS00:Running FahCore: E:\FAHClient/FAHCoreWrapper.exe "C:/Documents and Settings/name/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/NVIDIA/G80/Core_11.fah/FahCore_11.exe" -dir 02 -suffix 01 -version 701 -lifeline 5132 -checkpoint 15 -gpu 0
00:39:15:WU02:FS00:Started FahCore on PID 528
00:39:16:WU02:FS00:Core PID:6020
00:39:16:WU02:FS00:FahCore 0x11 started
00:39:16:WU00:FS01:Starting
00:39:16:WU00:FS01:Running FahCore: E:\FAHClient/FAHCoreWrapper.exe "C:/Documents and Settings/name/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_a4.fah/FahCore_a4.exe" -dir 00 -suffix 01 -version 701 -lifeline 5132 -checkpoint 15 -np 2
00:39:16:WU00:FS01:Started FahCore on PID 5556
00:39:16:WU00:FS01:Core PID:1596
00:39:16:WU00:FS01:FahCore 0xa4 started
00:39:16:WU02:FS00:0x11:
00:39:16:WU02:FS00:0x11:*------------------------------*
00:39:16:WU02:FS00:0x11:Folding@Home GPU Core
00:39:16:WU02:FS00:0x11:Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
00:39:16:WU02:FS00:0x11:Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
00:39:16:WU02:FS00:0x11:Build host: amoeba
00:39:16:WU02:FS00:0x11:Board Type: Nvidia
00:39:16:WU02:FS00:0x11:Core :
00:39:16:WU02:FS00:0x11:Preparing to commence simulation
00:39:16:WU02:FS00:0x11:- Looking at optimizations...
00:39:16:WU02:FS00:0x11:- Files status OK
00:39:16:WU02:FS00:0x11:- Expanded 62974 -> 336763 (decompressed 534.7 percent)
00:39:16:WU02:FS00:0x11:Called DecompressByteArray: compressed_data_size=62974 data_size=336763, decompressed_data_size=336763 diff=0
00:39:16:WU02:FS00:0x11:- Digital signature verified
00:39:16:WU02:FS00:0x11:Project: 10502 (Run 489, Clone 0, Gen 427)
00:39:16:WU02:FS00:0x11:Assembly optimizations on if available.
00:39:16:WU02:FS00:0x11:Entering M.D.
00:39:16:WU00:FS01:0xa4:
00:39:16:WU00:FS01:0xa4:*------------------------------*
00:39:16:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
00:39:16:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
00:39:16:WU00:FS01:0xa4:Preparing to commence simulation
00:39:16:WU00:FS01:0xa4:- Looking at optimizations...
00:39:16:WU00:FS01:0xa4:- Files status OK
00:39:16:WU00:FS01:0xa4:- Expanded 2079246 -> 5386224 (decompressed 259.0 percent)
00:39:16:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=2079246 data_size=5386224, decompressed_data_size=5386224 diff=0
00:39:16:WU00:FS01:0xa4:- Digital signature verified
00:39:16:WU00:FS01:0xa4:Project: 7809 (Run 5, Clone 106, Gen 113)
00:39:17:WU00:FS01:0xa4:Assembly optimizations on if available.
00:39:17:WU00:FS01:0xa4:Entering M.D.
00:39:22:WU02:FS00:0x11:Will resume from checkpoint file
00:39:22:WU02:FS00:0x11:Tpr hash 02/wudata_01.tpr: 2124241214 1914994775 1056910139 1102866594 2690281205
00:39:22:WU02:FS00:0x11:Calling fah_main args: 14 usage=100
00:39:22:WU02:FS00:0x11:Working on Protein
00:39:23:WU00:FS01:0xa4:Using Gromacs checkpoints
00:39:23:WU00:FS01:0xa4:Mapping NT from 2 to 2
00:39:23:WU00:FS01:0xa4:Resuming from checkpoint
00:39:23:WU00:FS01:0xa4:Verified 00/wudata_01.log
00:39:23:WU00:FS01:0xa4:Verified 00/wudata_01.trr
00:39:23:WU00:FS01:0xa4:Verified 00/wudata_01.xtc
00:39:23:WU00:FS01:0xa4:Verified 00/wudata_01.edr
00:39:24:WU00:FS01:0xa4:Completed 865860 out of 1500000 steps (57%)
00:39:25:WU02:FS00:0x11:Client config unavailable.
00:39:25:WU02:FS00:0x11:Starting GUI Server
00:39:25:WU02:FS00:0x11:Resuming from checkpoint
00:39:25:WU02:FS00:0x11:fcCheckPointResume: retreived and current tpr file hash:
00:39:25:WU02:FS00:0x11: 0 2124241214 2124241214
00:39:25:WU02:FS00:0x11: 1 1914994775 1914994775
00:39:25:WU02:FS00:0x11: 2 1056910139 1056910139
00:39:25:WU02:FS00:0x11: 3 1102866594 1102866594
00:39:25:WU02:FS00:0x11: 4 2690281205 2690281205
00:39:25:WU02:FS00:0x11:fcCheckPointResume: file hashes same.
00:39:25:WU02:FS00:0x11:fcCheckPointResume: state restored.
00:39:25:WU02:FS00:0x11:Verified 02/wudata_01.log
00:39:25:WU02:FS00:0x11:Verified 02/wudata_01.edr
00:39:25:WU02:FS00:0x11:Verified 02/wudata_01.xtc
00:39:25:WU02:FS00:0x11:Completed 9%
01:02:36:WU02:FS00:0x11:Completed 10%
01:04:18:WU00:FS01:0xa4:Completed 870000 out of 1500000 steps (58%)
01:25:14:WU02:FS00:0x11:Completed 11%
01:47:58:WU02:FS00:0x11:Completed 12%
02:11:14:WU02:FS00:0x11:Completed 13%
02:32:12:WU00:FS01:0xa4:Completed 885000 out of 1500000 steps (59%)
02:40:42:WU02:FS00:0x11:Completed 14%
03:03:48:WU02:FS00:0x11:Completed 15%
03:27:02:WU02:FS00:0x11:Completed 16%
03:49:35:WU02:FS00:0x11:Completed 17%
03:59:51:WU00:FS01:0xa4:Completed 900000 out of 1500000 steps (60%)
04:12:36:WU02:FS00:0x11:Completed 18%
04:36:07:WU02:FS00:0x11:Completed 19%
04:59:13:WU02:FS00:0x11:Completed 20%
05:27:43:WU02:FS00:0x11:Completed 21%
05:28:15:WU00:FS01:0xa4:Completed 915000 out of 1500000 steps (61%)
******************************** Date: 10/07/12 ********************************
05:51:10:WU02:FS00:0x11:Completed 22%
06:14:16:WU02:FS00:0x11:Completed 23%
06:42:22:WU02:FS00:0x11:Completed 24%
iceman1992
Your TPF was around 23 minutes. Which means the WU should be completed in about 40 hours. I'm not sure why yours expired.
Well you can try adding the option "max-packet-size : small". I've never tried that myself, but it might work.
Can you explain this better. What is the theory behind it and how do I make this change? Thanks very much for your help.iceman1992 wrote:Your TPF was around 23 minutes. Which means the WU should be completed in about 40 hours. I'm not sure why yours expired.
iceman1992
"max-packet-size : small" makes your client download small units. It's more about the download size rather than the processing time, but as I said it might work.
Some useful options :
http://www.overclock.net/t/979691/info- ... ed-options
and
https://fah-web.stanford.edu/projects/F ... ncesV6ToV7
And here's how to add these options http://folding.stanford.edu/English/WinGuide#ntoc9
and
compdewd
- Hardware configuration: [1] Debian 8 64-bit: EVGA NVIDIA GTX 650 Ti, MSI NVIDIA GTX 460, AMD FX-8120
[2] Windows 7 64-bit: MSI NVIDIA GTX 460, AMD Phenom II X4 - Location: Cincinnati, Ohio, USA
Limiting the max packet size would be good if the deadlines were close, but apparently that isn't the case. Plus if you are able fold bigger work then you should IMO.
RMouse, it might be a good idea to post the section of the log where the WU was actually downloaded so we can make verifications and whatnot. It should be close to where you found the second section of the log you posted since the WU was only at 9% there
I dont see anything earlier than 9%. My log does not go back any further than this.compdewd wrote:Limiting the max packet size would be good if the deadlines were close, but apparently that isn't the case. Plus if you are able fold bigger work then you should IMO.
00:38:47:Saving configuration to config.xml
00:38:47:<config>
00:38:47: <!-- Folding Slot Configuration -->
00:38:47: <gpu v='true'/>
00:38:47:
00:38:47: <!-- Network -->
00:38:47: <proxy v=':8080'/>
00:38:47:
00:38:47: <!-- User Information -->
00:38:47: <passkey v='********************************'/>
00:38:47: <user v='RattyM'/>
00:38:47:
00:38:47: <!-- Folding Slots -->
00:38:47: <slot id='0' type='GPU'/>
00:38:47: <slot id='1' type='SMP'/>
00:38:47:</config>
00:39:15:FS00:Unpaused
00:39:15:FS01:Unpaused
compdewd
Well honestly I would wait until someone more experienced can help you with your problem since I'm pretty stumped on this one and I may be leading you on a wild goose chase here
. But if you want, you can still follow my directions and maybe learn something
If you decide to let me keep trying to help, there should be past logs stored in the FAH directory. You should be able to find them here (you should be able to copy and past this into an explorer address bar since I modified it a little): C:\Documents and Settings\name\Application Data\FAHClient\logs. Or go to "Start Menu", "All Programs", "FAH Client", "Data Directory", then "logs". There will be a lot if you have been folding for a long time. They go in order of dates (log-YYYYMMDD-...), so look for something that would correspond to the most recent, open it up, start from the bottom and look for something close to "Received Unit: id:00 state:DOWNLOAD error:OK project:5771 run:2 clone:179 gen:1477 core:0x11 unit:0x1a3ba4524fffa19805c500b30002168b" (with the proper PRCG and slot id of course)
Note for future log postings, many like to have log postings placed in code tags so the log doesn't make the thread page unnecessarily long
Thanks for all your help! Let's wait and see what others think. The work is lost so there is no urgency here.compdewd wrote:Well honestly I would wait until someone more experienced can help you with your problem since I'm pretty stumped on this one and I may be leading you on a wild goose chase here. But if you want, you can still follow my directions and maybe learn something
iceman1992
Meanwhile, you can edit your posts, and add [code*]-log here-[/code*] (without the *) to improve readability
ChelseaOilman
Hi RattyM (team 0),
Your WU (P7809 R5 C106 G113) was added to the stats database on 2012-07-12 14:08:01 for 1722.5 points of credit.
WU assigned to donor at: 2012-07-05 03:47:07
Days taken to complete WU: 7.43
WU 10502 is the one in question. Is this the one you are talking about here? Was in reality not lost?ChelseaOilman wrote:Hi RattyM (team 0),
Done! Thank you for the tip!iceman1992 wrote:Meanwhile, you can edit your posts, and add [code*]-log here-[/code*] (without the *) to improve readability
The V7 folding client does keep a folder of past logs in the same directory as the current log. The filename gets modified with a timestamp. By default the V7 client keeps the last 16 logs in that folder.
If one is old enough, look to see if the WU downloaded either in part or completely and exited before. The assignment servers do keep track of WU's assigned to a machine and will resend them back to you later. The timeouts do go from initial assignment, so it is possible it was assigned to you first 12 days ago and then given to you again if it was not returned then.
P.S. As I recall, you are folding on a Windows machine. I recall from the time I was doing some folding on my son's Mac Pro booted into Windows 7 that the folder where the logs, etc. are kept is in a "hidden" folder named .FAHClient.
