Project: 7647 (Run 100, Clone 0, Gen 11)
CommuPony
Post by CommuPony »
The project was doing fine, but at same point, after half an hour of gaming, I stumbled upon a glitched out TPF (1 minute, was 1 hour or so) and Estimated Points (37k, was 7-8k) with progress jumping to 99,99%. This glitch didn't happen to me for the first time, so I tried rebooting, On both tries the client returned to the same state, just stuck there. The log says it is loaded from a proper point, but if I pause the project, it says this (from log):
23:39:12:FS00:Paused
23:39:12:FS00:Shutting core down
23:39:14:WU00:FS00:0xa4:Client no longer detected. Shutting down core
23:39:14:WU00:FS00:0xa4:Folding@home Core Shutdown: CLIENT_DIED
23:39:14:WU00:FS00:FahCore returned: INTERRUPTED (102 = 0x66)
Is there any way to at least get the points, since the project took around 5 days and just sending it to waste is kinda sad.
Screenshots of client paused and unpaused.
sortofageek
Re: Project: 7647 (Run 100, Clone 0, Gen 11)
Post by sortofageek »
Thanks for the report. This has been marked for follow-up. Nothing has shown up in the database for this WU yet.
Were you able to continue? What happened next?
10-14-2012 database check: Nothing returned so far.
codysluder
Post by codysluder »
I suggest you post your log. I'd be interested in what the text in the log says when the progress bar suddenly jumps. With three or four similar reports from different people and all p764x, there might be something that somebody missed during early testing of the project.
sortofageek
The problem is apparently not the work unit. Result from the database for a different folder:
The WU (P7647 R100 C0 G11) was added to the stats database on 2012-07-19 04:07:53 for 2250 points of credit.
