Is finstall still being maintained?
P5-133XL
Machine #2:
Machine 3:
I just tried installing with finstall and noticed that it didn't work. Specificly, the (SMP) url's and file names are no longer valid. I edited them to point to the correct location and it then worked just fine.
Re: Is finstall still being maintained?
I still update the finstall script and I haven't noticed anything wrong.
Just report what is wrong and I will fix it.
P5-133XL
Machine #2:
Machine 3:
Old version:
Fclient_linuxA_SMP_Fdwnl=http://folding.stanford.edu/release/
Fclient_linuxA_SMP=FAH_SMP_Linux.tgz
Fclient_linuxA_SMP_name=fah5
new version:
Fclient_linuxA_SMP_Fdwnl=http://www.stanford.edu/group/pandegrou ... g/release/
Fclient_linuxA_SMP=FAH6.02beta1-Linux.tgz
Fclient_linuxA_SMP_name=fah6
With those small changes, it seems to work correctly to install the Linux SMP client
new version:
Thanks, it is fixed.P5-133XL wrote:Old version:
new version:
smoking2000
I've got fix for you too, on OpenBSD 4.3 (which was recently released, and for which I wrote a F@H related HOWTO) the code added to /etc/rc.{local,shutdown} by the installService script throws an error:Ivoshiee wrote:Thanks, it is fixed.
root@vmware-openbsd:~# tail -3 /etc/rc.local /etc/rc.shutdown
==> /etc/rc.local <==
#Start up Folding@Home Service
echo "Starting Folding@Home Service..."
su folding -c "/home/folding/foldingathome/folding start"
==> /etc/rc.shutdown <==
su folding -c "/home/folding/foldingathome/folding stop"
echo "Sleeping 20 seconds to allow Folding@Home service time to shut down properly..."
sleep 20
root@vmware-openbsd:~# su folding -c "/home/folding/foldingathome/folding start"
shell-init: error retrieving current directory: getcwd: cannot access parent directories: Permission denied
['folding' ver. 5.9]
Starting up FAH client(s) on 1 processor(s):
Starting FAH client at CPU1...
FAH client #1 startup: OK
^C
root@vmware-openbsd:~# su - folding -c "/home/folding/foldingathome/folding start"
^CCode: Select all
- Same as the -l option (deprecated).
-l Simulate a full login. The environment is discarded except for
HOME, SHELL, PATH, TERM, LOGNAME, and USER. HOME and SHELL are
modified as above. LOGNAME and USER are set to the target login.
PATH is set to the value specified by the ``path'' entry in
login.conf(5). TERM is imported from your current environment.
The invoked shell is the target login's, and su will change di-
rectory to the target login's home directory.
--- finstall-orig 2008-05-04 00:24:47.000000000 +0200
+++ finstall 2008-05-04 00:25:48.000000000 +0200
@@ -2551,12 +2551,12 @@
cat >> /etc/rc.local << $terminator
-su \$USERNAME -c "\$Fpath/folding start"
+su - \$USERNAME -c "\$Fpath/folding start"
$terminator
cat >> /etc/rc.shutdown << $terminator
#Shut down Folding@Home Service
-su \$USERNAME -c "\$Fpath/folding stop"
+su - \$USERNAME -c "\$Fpath/folding stop"
sleep 20
$terminator
Another excellent contribution!
Finstall is fixed and released as 6.0.
smoking2000
I've got another patch for you, it adds support for Arch Linux which uses BSD style init:
archlinux.patch | finstall
--- finstall-orig 2009-01-21 00:54:57.000000000 +0100
+++ finstall 2009-01-21 01:42:56.000000000 +0100
@@ -2314,6 +2314,12 @@
# To get to know more about FAH go to http://folding.stanford.edu.
StartDir="/etc/init.d"
+# Arch Linux uses /etc/rc.d/ for init scripts, and DAEMONS
+# in /etc/rc.conf specifies which services to start at boot
+if [ -r /etc/arch-release ]
+ then
+ StartDir="/etc/rc.d"
+fi
Fpath="$Fdir"
#tr utility will be used if it is available:
tr_OK=$tr_OK
@@ -2412,6 +2418,16 @@
then
#Debian specific:
update-rc.d folding defaults
+elif [ -e /etc/arch-release ];
+ then
+#Arch specific:
+ if [ \$(egrep "^DAEMONS=(.*?\s*[!|@]?folding\s*.*?)" /etc/rc.conf | wc -l) == 0 ]
+ then
+# folding is not yet added to DAEMONS in /etc/rc.conf
+ cp /etc/rc.conf /etc/rc.conf.folding-bak
+ sed -r 's/^\s*DAEMONS=\((.*?)\)/DAEMONS=\(\1 folding\)/' /etc/rc.conf > /etc/rc.conf.new
+ mv /etc/rc.conf.new /etc/rc.conf
+ fi
else
#All other Linux distros:
chkconfig --add folding
@@ -2457,6 +2473,11 @@
+ then
+fi
UseSudo=false
# Several Linux distros these days use sudo instead of a separate root account,
@@ -2512,6 +2533,16 @@
then
#Debian specific:
update-rc.d -f folding remove
+ then
+#Arch specific:
+ if [ \$(egrep "^DAEMONS=(.*?\s*[\!|@]?folding\s*.*?)" /etc/rc.conf | wc -l) == 1 ]
+ then
+# folding is added to DAEMONS in /etc/rc.conf
+ cp /etc/rc.conf /etc/rc.conf.folding-bak2
+ sed -r 's/^DAEMONS=\((.*?)\s*[!|@]?folding\s*(.*?)\)/DAEMONS=\(\1\2\)/' /etc/rc.conf > /etc/rc.conf.new
+ fi
else
chkconfig --del foldingRe: Is finstall still being maintained?
Thanks, I'll implement it and some other changes as well.smoking2000 wrote:I've got another patch for you, it adds support for Arch Linux which uses BSD style init:
archlinux.patch | finstallCode: Select all
--- finstall-orig 2009-01-21 00:54:57.000000000 +0100 +++ finstall 2009-01-21 01:42:56.000000000 +0100 @@ -2314,6 +2314,12 @@ # To get to know more about FAH go to http://folding.stanford.edu. StartDir="/etc/init.d" +# Arch Linux uses /etc/rc.d/ for init scripts, and DAEMONS +# in /etc/rc.conf specifies which services to start at boot +if [ -r /etc/arch-release ] + then + StartDir="/etc/rc.d" +fi Fpath="$Fdir" #tr utility will be used if it is available: tr_OK=$tr_OK @@ -2412,6 +2418,16 @@ then #Debian specific: update-rc.d folding defaults +elif [ -e /etc/arch-release ]; + then +#Arch specific: + if [ \$(egrep "^DAEMONS=(.*?\s*[!|@]?folding\s*.*?)" /etc/rc.conf | wc -l) == 0 ] + then +# folding is not yet added to DAEMONS in /etc/rc.conf + cp /etc/rc.conf /etc/rc.conf.folding-bak + sed -r 's/^\s*DAEMONS=\((.*?)\)/DAEMONS=\(\1 folding\)/' /etc/rc.conf > /etc/rc.conf.new + mv /etc/rc.conf.new /etc/rc.conf + fi else #All other Linux distros: chkconfig --add folding @@ -2457,6 +2473,11 @@ # To get to know more about FAH go to http://folding.stanford.edu. StartDir="/etc/init.d" +# Arch Linux uses /etc/rc.d/ for init scripts +if [ -r /etc/arch-release ] + then + StartDir="/etc/rc.d" +fi UseSudo=false # Several Linux distros these days use sudo instead of a separate root account, @@ -2512,6 +2533,16 @@ then #Debian specific: update-rc.d -f folding remove +elif [ -e /etc/arch-release ]; + then +#Arch specific: + if [ \$(egrep "^DAEMONS=(.*?\s*[\!|@]?folding\s*.*?)" /etc/rc.conf | wc -l) == 1 ] + then +# folding is added to DAEMONS in /etc/rc.conf + cp /etc/rc.conf /etc/rc.conf.folding-bak2 + sed -r 's/^DAEMONS=\((.*?)\s*[!|@]?folding\s*(.*?)\)/DAEMONS=\(\1\2\)/' /etc/rc.conf > /etc/rc.conf.new + mv /etc/rc.conf.new /etc/rc.conf + fi else #All other Linux distros: chkconfig --del folding
It took some time (and failed long wait for a new FAH client), but I've updated the finstall script.
I wonder why egrep does trigger an error when to run installService. It should not get run at the first place.
[ivo@haskaa foldingathome]$ ./installService
Installing FAH as a service...
'/etc/init.d/folding' is present.
Do You want to reinstall it?: y
egrep: /etc/rc.conf: No such file or directory
Password:
#!/bin/bash
# This is FAH ("Folding At Home") service installation script.
then
fi
Fpath="/home/ivo/folding2/foldingathome"
tr_OK=true
UseSudo=false
# use of the su command is only allowed to the root user or users who use sudo.
# So for finstall to work, it has to use sudo to run the su command or the it
# will not be allowed.
# The LSB specifies two ways to find out which distro your program is run on.
# The file /etc/lsb-release, and the program /usr/bin/lsb_release.
# The program is the only thing specified in the standard, so the file may be
# missing even on LSB conforming distros.
# See also:
# http://lists.freestandards.org/pipermail/lsb-discuss/2004-May/002143.html
# http://refspecs.freestandards.org/LSB_3.1.0/LSB-Core-generic/LSB-Core-generic/lsbrelease.html
# Check for /etc/lsb-release and inside it for distribution name
# $ cat /etc/lsb-release
# DISTRIB_ID=Ubuntu
# DISTRIB_RELEASE=6.06
# DISTRIB_CODENAME=dapper
# DISTRIB_DESCRIPTION="Ubuntu 6.06.1 LTS"
if [ -r /etc/lsb-release ]
then
# using Ubuntu?
ret=$(grep DISTRIB_ID /etc/lsb-release | sed 's/^\w*=//')
if [ "X$ret" == "XUbuntu" ]
then
UseSudo=true
fi
elif [ -x /bin/lsb_release ]
then
# using Ubuntu?
ret=$(/bin/lsb_release --id | sed 's/^Distributor ID:\t//')
then
UseSudo=true
fi
elif [ -x /usr/bin/lsb_release ]
then
# using Ubuntu?
ret=$(/usr/bin/lsb_release --id | sed 's/^Distributor ID:\t//')
then
UseSudo=true
fi
fi
AskChoice(){
#Ask for y/n type choice.
#Input: $Message
#Output: $Answer
local answerOK
local input_count
input_count=0
answerOK="false"
while [ "$answerOK" = "false" ]
do
if [ $input_count -gt 9 ];
then
echo
echo CANCELLED!
echo
exit 1
fi
echo -n "$Message"
read Answer
if [ "$tr_OK" = "true" ]
then
Answer=$(echo $(echo "$Answer" | tr A-Z a-z))
fi
if [ "$Answer" = "yes" -o "$Answer" = "y" -o "$Answer" = "no" -o "$Answer" = "n" ]
then
answerOK="true"
fi
let "input_count=input_count+1"
done
ServiceInstall(){
cat << EOF
#!/bin/bash
if [ -w ${StartDir}/folding ];
then
rm -f ${StartDir}/folding
fi
cp ${Fpath}/folding ${StartDir}/
if [ -e /etc/debian_version ];
then
#Debian specific:
then
#Arch Linux specific:
if [ $(egrep "^DAEMONS=(.*?\s*[!|@]?folding\s*.*?)" /etc/rc.conf | wc -l) == 0 ]
then
fi
else
fi
EOF
echo "Installing FAH as a service..."
echo ""
if [ -r ${StartDir}/folding ];
then
echo "'${StartDir}/folding' is present."
Message="Do You want to reinstall it?: "
AskChoice
if [ "$Answer" = "n" -o "$Answer" = "no" ];
then
exit
fi
fi
# When running on Ubuntu use sudo, because su is not available to normal users
if [ $UseSudo == true ]
then
sudo su - -c "$(ServiceInstall)"
else
fi
#END
ikerekes
- Hardware configuration: q6600 @ 3.3Ghz windows xp-sp3 one SMP2 (2.15 core) + 1 9800GT native GPU2
Athlon x2 6000+ @ 3.0Ghz ubuntu 8.04 smp + asus 9600GSO gpu2 in wine wrapper
5600X2 @ 3.19Ghz ubuntu 8.04 smp + asus 9600GSO gpu2 in wine wrapper
E5200 @ 3.7Ghz ubuntu 8.04 smp2 + asus 9600GT silent gpu2 in wine wrapper
E5200 @ 3.65Ghz ubuntu 8.04 smp2 + asus 9600GSO gpu2 in wine wrapper
E6550 vmware ubuntu 8.4.1
q8400 @ 3.3Ghz windows xp-sp3 one SMP2 (2.15 core) + 1 9800GT native GPU2
Athlon II 620 @ 2.6 Ghz windows xp-sp3 one SMP2 (2.15 core) + 1 9800GT native GPU2 - Location: Calgary, Canada
smoking2000
It's probably the use of a sub shell ($()) which might by evaluated always even when it's in a condition which is never triggered, you can try replacing it with backticks.Ivoshiee wrote:It took some time (and failed long wait for a new FAH client), but I've updated the finstall script.
