Project: 10504 (Run 312, Clone 0, Gen 1131) - EUE
Fahrenheit451
Hardware configuration: System 1:
CPU: Intel Core 2 Duo E6850, 3000 MHz (9 x 333)
Mainboard: Gigabyte P35-DS3P v1.1
RAM: 2 GB (2x1024 MB DDR2 Dual-Channel, DRAM frequency 400 MHz)
OS: Windows Vista Ultimate, 32 bit, Service Pack 2
HD: Samsung HD501LJ (500 GB)
PSU: BeQuiet Straight Power E8 CM 580W
Case: CoolerMaster Cosmos 1000
GPU: NVIDIA GeForce 8800 GTS 512, XFX Pine Group
GFX driver version: 285.62
The card runs at stock speed: GPU 648 MHz, Memory 972 Mhz, Shader 1620 MHz
System 2:
CPU: Intel i7 2600 (Sandy Bridge) @ 3400 MHz (4C/8T)
Mainboard: Asus P8H67-M-Pro
RAM: 8GB (2x4 GB DDR3, 1333 MHz, Kingston)
OS: Windows 7 Ultimate, 64bit
HD: Samsung HD103SJ (1TB)
PSU: BeQuiet Straight Power E8 CM 580 W
Case: Corsair Obsidian 800D with H100 water cooling
GPU: i7 2600 IGP (not for folding) / Gigabyte GTX 560 Ti OC 1GB
Post by Fahrenheit451 »
It seems that my 8800 GTS 512 sometimes doesn't like the 10504:
--- Opening Log file [April 25 05:58:01 UTC]
                          http://folding.stanford.edu
Launch directory: D:\Programme\Folding@home-Win32-GPU_Vista-623_console_client
Executable: D:\Programme\Folding@home-Win32-GPU_Vista-623_console_client\Folding@home-Win32-GPU.exe
Arguments: -advmethods -verbosity 9
[05:58:01] - Ask before connecting: No
[05:58:01] - User name: superduper4711 (Team 0)
[05:58:01] - User ID: ECCE00A5AF7AA44
[05:58:01] - Machine ID: 2
[05:58:01]
<SNIP>
[11:24:37] + Number of Units Completed: 4545
[11:24:41] Trying to send all finished work units
[11:24:41] + No unsent completed units remaining.
[11:24:41] - Preparing to get new work unit...
[11:24:41] + Attempting to get work packet
[11:24:41] - Will indicate memory of 2045 MB
[11:24:41] - Connecting to assignment server
[11:24:41] Connecting to http://assign-GPU.stanford.edu:8080/
[11:24:43] Posted data.
[11:24:43] Initial: 43AB; - Successful: assigned to (171.67.108.21).
[11:24:43] + News From Folding@Home: Welcome to Folding@Home
[11:24:43] Loaded queue successfully.
[11:24:43] Connecting to http://171.67.108.21:8080/
[11:24:44] Posted data.
[11:24:44] Initial: 0000; - Receiving payload (expected size: 63379)
[11:24:45] - Downloaded at ~61 kB/s
[11:24:45] - Averaged speed for that direction ~67 kB/s
[11:24:45] + Received work.
[11:24:45] Trying to send all finished work units
[11:24:45] + No unsent completed units remaining.
[11:24:45] + Closed connections
[11:24:45]
[11:24:45] + Processing work unit
[11:24:45] Core required: FahCore_11.exe
[11:24:45] Core found.
[11:24:45] Working on queue slot 06 [May 1 11:24:45 UTC]
[11:24:45] + Working ...
[11:24:45] - Calling '.\FahCore_11.exe -dir work/ -suffix 06 -priority 96 -checkpoint 15 -verbose -lifeline 5768 -version 623'
[11:24:45]
[11:24:45] *------------------------------*
[11:24:45] Folding@Home GPU Core
[11:24:45] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[11:24:45]
[11:24:45] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[11:24:45] Build host: amoeba
[11:24:45] Board Type: Nvidia
[11:24:45] Core      :
[11:24:45] Preparing to commence simulation
[11:24:45] - Looking at optimizations...
[11:24:45] DeleteFrameFiles: successfully deleted file=work/wudata_06.ckp
[11:24:45] - Created dyn
[11:24:45] - Files status OK
[11:24:45] - Expanded 62867 -> 336799 (decompressed 535.7 percent)
[11:24:45] Called DecompressByteArray: compressed_data_size=62867 data_size=336799, decompressed_data_size=336799 diff=0
[11:24:45] - Digital signature verified
[11:24:45]
[11:24:45] Project: 10504 (Run 312, Clone 0, Gen 1131)
[11:24:45]
[11:24:45] Assembly optimizations on if available.
[11:24:45] Entering M.D.
[11:24:51] Tpr hash work/wudata_06.tpr:  2219368417 3897068104 4063502753 1085652199 3010320312
[11:24:51]
[11:24:51] Calling fah_main args: 14 usage=100
[11:24:51]
[11:24:51] Working on Protein
[11:24:53] Client config found, loading data.
[11:24:53] Starting GUI Server
[11:26:26] Completed 1%
[11:28:01] Completed 2%
[11:29:36] Completed 3%
[11:31:10] Completed 4%
[11:32:45] Completed 5%
[11:34:20] Completed 6%
[11:35:54] Completed 7%
[11:37:29] Completed 8%
[11:39:03] Completed 9%
[11:40:38] Completed 10%
[11:42:12] Completed 11%
[11:43:47] Completed 12%
[11:45:22] Completed 13%
[11:46:56] Completed 14%
[11:48:31] Completed 15%
[11:50:05] Completed 16%
[11:51:40] Completed 17%
[11:53:14] Completed 18%
[11:54:49] Completed 19%
[11:56:24] Completed 20%
[11:57:58] Completed 21%
[11:58:08] - Autosending finished units... [May 1 11:58:08 UTC]
[11:58:08] Trying to send all finished work units
[11:58:08] + No unsent completed units remaining.
[11:58:08] - Autosend completed
[11:59:33] Completed 22%
[12:01:07] Completed 23%
[12:02:42] Completed 24%
[12:04:16] Completed 25%
[12:05:51] Completed 26%
[12:07:25] Completed 27%
[12:09:01] Completed 28%
[12:10:35] Completed 29%
[12:12:11] Completed 30%
[12:13:44] Completed 31%
[12:15:19] Completed 32%
[12:16:53] Completed 33%
[12:18:28] Completed 34%
[12:20:02] Completed 35%
[12:21:37] Completed 36%
[12:23:12] Completed 37%
[12:24:46] Completed 38%
[12:26:21] Completed 39%
[12:27:55] Completed 40%
[12:29:30] Completed 41%
[12:31:05] Completed 42%
[12:32:39] Completed 43%
[12:34:14] Completed 44%
[12:35:48] Completed 45%
[12:37:23] Completed 46%
[12:38:57] Completed 47%
[12:40:32] Completed 48%
[12:42:06] Completed 49%
[12:43:41] Completed 50%
[12:45:15] Completed 51%
[12:46:50] Completed 52%
[12:48:25] Completed 53%
[12:50:00] Completed 54%
[12:51:34] Completed 55%
[12:53:09] Completed 56%
[12:54:43] Completed 57%
[12:56:18] Completed 58%
[12:57:53] Completed 59%
[12:59:28] Completed 60%
[13:01:02] Completed 61%
[13:02:36] Completed 62%
[13:04:11] Completed 63%
[13:05:45] Completed 64%
[13:07:20] Completed 65%
[13:08:55] Completed 66%
[13:10:29] Completed 67%
[13:12:04] Completed 68%
[13:13:38] Completed 69%
[13:15:13] Completed 70%
[13:16:47] Completed 71%
[13:18:22] Completed 72%
[13:19:57] Completed 73%
[13:21:31] Completed 74%
[13:22:44] Run: exception thrown during GuardedRun
[13:22:44] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[13:22:44] Going to send back what have done -- stepsTotalG=15000000
[13:22:44] Work fraction=0.7477 steps=15000000.
[13:22:48] logfile size=10467 infoLength=10467 edr=0 trr=23
[13:22:48] + Opened results file
[13:22:48] - Writing 11003 bytes of core data to disk...
[13:22:48] Done: 10491 -> 3903 (compressed to 37.2 percent)
[13:22:48]   ... Done.
[13:22:48] DeleteFrameFiles: successfully deleted file=work/wudata_06.ckp
[13:22:48]
[13:22:48] Folding@home Core Shutdown: EARLY_UNIT_END
[13:22:51] CoreStatus = 72 (114)
[13:22:51] Sending work to server
[13:22:51] Project: 10504 (Run 312, Clone 0, Gen 1131)
[13:22:51] - Read packet limit of 540015616... Set to 524286976.
[13:22:51] + Attempting to send results [May 1 13:22:51 UTC]
[13:22:51] - Reading file work/wuresults_06.dat from core
[13:22:51]   (Read 4415 bytes from disk)
[13:22:51] Connecting to http://171.67.108.21:8080/
[13:22:52] Posted data.
[13:22:52] Initial: 0000; - Uploaded at ~5 kB/s
[13:22:52] - Averaged speed for that direction ~35 kB/s
[13:22:52] + Results successfully sent
[13:22:52] Thank you for your contribution to Folding@Home.
Re: Project: 10504 (Run 312, Clone 0, Gen 1131) - EUE
I'm not sure what happened. This WU has been returned twice, once with an error report (presumably by you) and once by someone else who completed it successfully.
Fahrenheit451
System 2:
Thank you for your feedback. Does it make sense to report such errors here? Or is Stanford able to find out partially or complete failed WUs automatically, so that they can take really bad WUs out of distribution?
The V7 beta does a better job of reporting errors than earlier clients, but still does not successfully report them all. There are many types of failures that V7 and V6 clients do not turn in to the servers, so reports here are the only way for PG to be informed of them. So, keep reporting is what I would recommend. Do take a look through the postings to see if there is already a report, yours can be added to an existing one.
