10090 WUs low points?
Damn I just got one of these on my i7 2600, all 8 cores dedicated to it and its saying 23 hours, reduced my predicted PPD from 34k to 1.8k LOL
- Hardware configuration: i7-3930K@4.1GHz
GTX680@1.275GHz
Q9300@2.4GHz
GTX460@800MHz - Location: Essen, Germany
Re: 10090 WUs low points?
I had the same problem today. Quit and restart F@H and everything will be fine again.
I don´t understand what happend but CPU (12 cores) was under 100% load but the CPU didn´t produce much heat.
After 20 hours only 29% finished and now after thge restart it seems that the WU will be finished in less than 2 hours.
So something must have happend after the start.
Heiko
Folding@Home Gromacs GB Core
Version 2.27 (Dec. 15, 2010)
Preparing to commence simulation
- Looking at optimizations...
- Created dyn
- Files status OK
- Expanded 51609 -> 199068 (decompressed 385.7 percent)
Called DecompressByteArray: compressed_data_size=51609 data_size=199068, decompressed_data_size=199068 diff=0
- Digital signature verified
Project: 10090 (Run 69, Clone 3, Gen 21)
Assembly optimizations on if available.
Entering M.D.
Mapping NT from 12 to 12
Completed 0 out of 10000000 steps (0%)
Completed 100000 out of 10000000 steps (1%)
Completed 200000 out of 10000000 steps (2%)
Completed 300000 out of 10000000 steps (3%)
Completed 400000 out of 10000000 steps (4%)
Completed 500000 out of 10000000 steps (5%)
Completed 600000 out of 10000000 steps (6%)
Completed 700000 out of 10000000 steps (7%)
Completed 800000 out of 10000000 steps (8%)
Completed 900000 out of 10000000 steps (9%)
Completed 1000000 out of 10000000 steps (10%)
Completed 1100000 out of 10000000 steps (11%)
Completed 1200000 out of 10000000 steps (12%)
Completed 1300000 out of 10000000 steps (13%)
Completed 1400000 out of 10000000 steps (14%)
Completed 1500000 out of 10000000 steps (15%)
Completed 1600000 out of 10000000 steps (16%)
Completed 1700000 out of 10000000 steps (17%)
Completed 1800000 out of 10000000 steps (18%)
Completed 1900000 out of 10000000 steps (19%)
Completed 2000000 out of 10000000 steps (20%)
Completed 2100000 out of 10000000 steps (21%)
Completed 2200000 out of 10000000 steps (22%)
Completed 2300000 out of 10000000 steps (23%)
Completed 2400000 out of 10000000 steps (24%)
Completed 2500000 out of 10000000 steps (25%)
Completed 2600000 out of 10000000 steps (26%)
Completed 2700000 out of 10000000 steps (27%)
Completed 2800000 out of 10000000 steps (28%)
Completed 2900000 out of 10000000 steps (29%)
Client no longer detected. Shutting down core
Folding@home Core Shutdown: CLIENT_DIED
GTX680@1.275GHz
Q9300@2.4GHz
Same problem again today but at a different computer with project 8042.
Quitting the FahControl didn´t stop the fah core pürocess (with 25% CPU on a Q9300), I had to kill the process manually.
Log with the odd behaviour before and correct behaviour after a restart:
Heiko
02:26:16:WU00:FS01:Starting
02:26:16:WU02:FS01:Connecting to 171.67.108.59:8080
02:26:16:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 701 -lifeline 3924 -checkpoint 15 -np 4
02:26:16:WU00:FS01:Started FahCore on PID 48
02:26:16:WU00:FS01:Core PID:1964
02:26:16:WU00:FS01:FahCore 0xa4 started
02:26:16:WU00:FS01:0xa4:
02:26:16:WU00:FS01:0xa4:*------------------------------*
02:26:16:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
02:26:16:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
02:26:16:WU00:FS01:0xa4:Preparing to commence simulation
02:26:16:WU00:FS01:0xa4:- Looking at optimizations...
02:26:16:WU00:FS01:0xa4:- Created dyn
02:26:16:WU00:FS01:0xa4:- Files status OK
02:26:16:WU00:FS01:0xa4:- Expanded 1130442 -> 3056400 (decompressed 270.3 percent)
02:26:16:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=1130442 data_size=3056400, decompressed_data_size=3056400 diff=0
02:26:16:WU00:FS01:0xa4:- Digital signature verified
02:26:16:WU00:FS01:0xa4:Project: 8042 (Run 1, Clone 1630, Gen 18)
02:26:16:WU00:FS01:0xa4:Assembly optimizations on if available.
02:26:16:WU00:FS01:0xa4:Entering M.D.
02:26:22:WU02:FS01:Upload 43.44%
02:26:22:WU00:FS01:0xa4:Mapping NT from 4 to 4
02:26:23:WU00:FS01:0xa4:Completed 0 out of 250000 steps (0%)
02:26:28:WU02:FS01:Upload 80.68%
02:26:33:WU02:FS01:Upload complete
02:26:33:WU02:FS01:Server responded WORK_ACK (400)
02:26:33:WU02:FS01:Final credit estimate, 1290.00 points
02:26:33:WU02:FS01:Cleaning up
02:29:50:WU00:FS01:0xa4:Completed 2500 out of 250000 steps (1%)
02:33:16:WU00:FS01:0xa4:Completed 5000 out of 250000 steps (2%)
02:36:43:WU00:FS01:0xa4:Completed 7500 out of 250000 steps (3%)
02:40:09:WU00:FS01:0xa4:Completed 10000 out of 250000 steps (4%)
02:43:35:WU00:FS01:0xa4:Completed 12500 out of 250000 steps (5%)
02:47:00:WU00:FS01:0xa4:Completed 15000 out of 250000 steps (6%)
02:50:26:WU00:FS01:0xa4:Completed 17500 out of 250000 steps (7%)
02:53:52:WU00:FS01:0xa4:Completed 20000 out of 250000 steps (8%)
02:57:17:WU00:FS01:0xa4:Completed 22500 out of 250000 steps (9%)
03:00:43:WU00:FS01:0xa4:Completed 25000 out of 250000 steps (10%)
03:04:09:WU00:FS01:0xa4:Completed 27500 out of 250000 steps (11%)
03:07:34:WU00:FS01:0xa4:Completed 30000 out of 250000 steps (12%)
03:11:00:WU00:FS01:0xa4:Completed 32500 out of 250000 steps (13%)
03:14:27:WU00:FS01:0xa4:Completed 35000 out of 250000 steps (14%)
******************************** Date: 12/05/12 ********************************
03:45:18:WU00:FS01:0xa4:Completed 37500 out of 250000 steps (15%)
05:49:38:WU00:FS01:0xa4:Completed 40000 out of 250000 steps (16%)
07:42:03:WU00:FS01:0xa4:Completed 42500 out of 250000 steps (17%)
09:15:01:FS01:Shutting core down
09:15:05:WU00:FS01:0xa4:Client no longer detected. Shutting down core
09:15:05:WU00:FS01:0xa4:Folding@home Core Shutdown: CLIENT_DIED
*********************** Log Started 2012-05-12T09:15:40Z ***********************
09:15:40:WU00:FS01:Starting
09:15:40:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient/FAHCoreWrapper.exe" C:/ProgramData/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 00 -suffix 01 -version 701 -lifeline 3968 -checkpoint 15 -np 4
09:15:40:WU00:FS01:Started FahCore on PID 2492
09:15:40:WU00:FS01:Core PID:2360
09:15:40:WU00:FS01:FahCore 0xa4 started
09:15:41:WU00:FS01:0xa4:
09:15:41:WU00:FS01:0xa4:*------------------------------*
09:15:41:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
09:15:41:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
09:15:41:WU00:FS01:0xa4:Preparing to commence simulation
09:15:41:WU00:FS01:0xa4:- Looking at optimizations...
09:15:41:WU00:FS01:0xa4:- Files status OK
09:15:41:WU00:FS01:0xa4:- Expanded 1130442 -> 3056400 (decompressed 270.3 percent)
09:15:41:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=1130442 data_size=3056400, decompressed_data_size=3056400 diff=0
09:15:41:WU00:FS01:0xa4:- Digital signature verified
09:15:41:WU00:FS01:0xa4:Project: 8042 (Run 1, Clone 1630, Gen 18)
09:15:41:WU00:FS01:0xa4:Assembly optimizations on if available.
09:15:41:WU00:FS01:0xa4:Entering M.D.
09:15:47:WU00:FS01:0xa4:Using Gromacs checkpoints
09:15:47:WU00:FS01:0xa4:Mapping NT from 4 to 4
09:15:47:WU00:FS01:0xa4:Resuming from checkpoint
09:15:47:WU00:FS01:0xa4:Verified 00/wudata_01.log
09:15:47:WU00:FS01:0xa4:Verified 00/wudata_01.trr
09:15:47:WU00:FS01:0xa4:Verified 00/wudata_01.xtc
09:15:47:WU00:FS01:0xa4:Verified 00/wudata_01.edr
09:15:47:WU00:FS01:0xa4:Completed 44160 out of 250000 steps (17%)
09:16:46:WU00:FS01:0xa4:Completed 45000 out of 250000 steps (18%)
09:20:13:WU00:FS01:0xa4:Completed 47500 out of 250000 steps (19%)
