I think my folding is broke :(
e911
Post by e911 »
So, everything was going awesome with my feeble attempt at folding with my new GTX570 video card, but for the last 3-4 days, I have not gotten any big work units for my video card. My video card used to max itself out, and now, i keep getting the folding protein in water WU and i get next to no points for it.
Did something happen? I run folding on two different machines.. One on my desktop which has the core-i5 chip with the gtx570 in which i run both the cpu and gpu folding, and on my old spare laptop, which runs just the basic folding thing.
thank you for the help!
Zagen30
Re: I think my folding is broke :(
Post by Zagen30 »
Welcome to the forum, e911.
Please post the full contents of the log file in Code tags, which can be found in the Full Editor, as that will help a immensely in determining what's going on.
e911
Post by e911 »
Thanks Zagen30. It appears I may have broke it further :( In FAHControl, I removed the GPU thing, and now I can't find it's log. :(
bollix47
Post by bollix47 »
Location of log(s):
Start>All Programs>FAHClient>Data Directory
You will see a file called log.txt which is your current log.
Also, you will see a sub-directory called logs where all previous logs should be stored.
If not in log.txt perhaps you'll find what you're looking for in one of the previous logs.
patonb
Post by patonb »
For the record, the units don't all use 100% gpu.
There are now units that only use 65%ish gpu.
You have no control over what you get, some days yyou get choice units, and other days you get crap units.
65%? Try 85%... :roll:
e911
Post by e911 »
Sorry I havent been able to post my logs, I've been at work since 8am. I wont be home until after 11pm tonight. Once I return home, I will get those logs uploaded. Before, all of the work units I got maxed out my video card to 100% and it ran that way for several weeks in a row until recently then it just went to garbage :(
Thank you for the help!
patonb
Post by patonb »
7im wrote:65%? Try 85%... :roll:
My 560ti was doing a 7034 at 65%.
Should be doing better? Sharing with SMP? v6 or V7?
e911
Post by e911 »
This is the log file located in the main folder of the client:
*********************** Log Started 2012-04-14T12:22:17Z ***********************
12:22:17:************************* Folding@home Client *************************
12:22:17:      Website: http://folding.stanford.edu/
12:22:17:    Copyright: (c) 2009-2012 Stanford University
12:22:17:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
12:22:17:         Args: --lifeline 1152 --command-port=36330
12:22:17:       Config: C:/Users/*edited*
12:22:17:               *edited*/AppData/Roaming/FAHClient/CPU/Data/config.xml
12:22:17:******************************** Build ********************************
12:22:17:      Version: 7.1.52
12:22:17:         Date: Mar 20 2012
12:22:17:         Time: 19:37:42
12:22:17:      SVN Rev: 3515
12:22:17:       Branch: fah/trunk/client
12:22:17:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
12:22:17:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
12:22:17:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
12:22:17:     Platform: win32 XP
12:22:17:         Bits: 32
12:22:17:         Mode: Release
12:22:17:******************************* System ********************************
12:22:17:          CPU: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
12:22:17:       CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
12:22:17:         CPUs: 4
12:22:17:       Memory: 15.98GiB
12:22:17:  Free Memory: 13.22GiB
12:22:17:      Threads: WINDOWS_THREADS
12:22:17:   On Battery: false
12:22:17:   UTC offset: -4
12:22:17:          PID: 4544
12:22:17:          CWD: C:/Users/*EDITED*/AppData/Roaming/FAHClient/CPU/Data
12:22:17:           OS: Windows 7 Professional
12:22:17:      OS Arch: AMD64
12:22:17:         GPUs: 1
12:22:17:        GPU 0: FERMI:1 GF110 [Geforce GTX 570 HD]
12:22:17:         CUDA: 2.0
12:22:17:  CUDA Driver: 4020
12:22:17:Win32 Service: false
12:22:17:***********************************************************************
12:22:17:<config>
12:22:17:  <!-- FahCore Control -->
12:22:17:  <checkpoint v='5'/>
12:22:17:  <core-priority v='low'/>
12:22:17:
12:22:17:  <!-- Folding Slot Configuration -->
12:22:17:  <gpu v='true'/>
12:22:17:
12:22:17:  <!-- Network -->
12:22:17:  <proxy v=':8080'/>
12:22:17:
12:22:17:  <!-- User Information -->
12:22:17:  <passkey v='********************************'/>
12:22:17:  <team v='111065'/>
12:22:17:  <user v='e911'/>
12:22:17:
12:22:17:  <!-- Folding Slots -->
12:22:17:  <slot id='1' type='SMP'/>
12:22:17:</config>
12:22:17:Trying to access database...
12:22:17:Successfully acquired database lock
12:22:17:Enabled folding slot 01: READY smp:4
12:22:17:WU00:FS01:Starting
12:22:17:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe" -dir 00 -suffix 01 -version 701 -lifeline 4544 -checkpoint 5 -np 4
12:22:17:WU00:FS01:Started FahCore on PID 4996
12:22:17:WU00:FS01:Core PID:4936
12:22:17:WU00:FS01:FahCore 0xa4 started
12:22:18:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
12:22:18:WU00:FS01:0xa4:
12:22:18:WU00:FS01:0xa4:*------------------------------*
12:22:18:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
12:22:18:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
12:22:18:WU00:FS01:0xa4:Preparing to commence simulation
12:22:18:WU00:FS01:0xa4:- Looking at optimizations...
12:22:18:WU00:FS01:0xa4:- Files status OK
12:22:18:WU00:FS01:0xa4:- Expanded 2079014 -> 5386224 (decompressed 259.0 percent)
12:22:18:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=2079014 data_size=5386224, decompressed_data_size=5386224 diff=0
12:22:18:WU00:FS01:0xa4:- Digital signature verified
12:22:18:WU00:FS01:0xa4:Project: 7809 (Run 6, Clone 77, Gen 60)
12:22:18:WU00:FS01:0xa4:Assembly optimizations on if available.
12:22:18:WU00:FS01:0xa4:Entering M.D.
12:22:24:WU00:FS01:0xa4:Using Gromacs checkpoints
12:22:24:WU00:FS01:0xa4:Mapping NT from 4 to 4
12:22:24:WU00:FS01:0xa4:Resuming from checkpoint
12:22:24:WU00:FS01:0xa4:Verified 00/wudata_01.log
12:22:24:WU00:FS01:0xa4:Verified 00/wudata_01.trr
12:22:24:WU00:FS01:0xa4:Verified 00/wudata_01.xtc
12:22:24:WU00:FS01:0xa4:Verified 00/wudata_01.edr
12:22:24:WU00:FS01:0xa4:Completed 641020 out of 1500000 steps  (42%)
12:25:48:WU00:FS01:0xa4:Completed 645000 out of 1500000 steps  (43%)
12:38:34:WU00:FS01:0xa4:Completed 660000 out of 1500000 steps  (44%)
12:51:18:WU00:FS01:0xa4:Completed 675000 out of 1500000 steps  (45%)
13:04:02:WU00:FS01:0xa4:Completed 690000 out of 1500000 steps  (46%)
13:16:48:WU00:FS01:0xa4:Completed 705000 out of 1500000 steps  (47%)
13:29:32:WU00:FS01:0xa4:Completed 720000 out of 1500000 steps  (48%)
13:42:15:WU00:FS01:0xa4:Completed 735000 out of 1500000 steps  (49%)
13:54:57:WU00:FS01:0xa4:Completed 750000 out of 1500000 steps  (50%)
14:07:40:WU00:FS01:0xa4:Completed 765000 out of 1500000 steps  (51%)
14:20:25:WU00:FS01:0xa4:Completed 780000 out of 1500000 steps  (52%)
14:33:10:WU00:FS01:0xa4:Completed 795000 out of 1500000 steps  (53%)
14:45:55:WU00:FS01:0xa4:Completed 810000 out of 1500000 steps  (54%)
14:58:42:WU00:FS01:0xa4:Completed 825000 out of 1500000 steps  (55%)
15:11:29:WU00:FS01:0xa4:Completed 840000 out of 1500000 steps  (56%)
15:24:37:WU00:FS01:0xa4:Completed 855000 out of 1500000 steps  (57%)
15:36:47:WU00:FS01:0xa4:Completed 870000 out of 1500000 steps  (58%)
15:48:54:WU00:FS01:0xa4:Completed 885000 out of 1500000 steps  (59%)
16:01:00:WU00:FS01:0xa4:Completed 900000 out of 1500000 steps  (60%)
16:13:05:WU00:FS01:0xa4:Completed 915000 out of 1500000 steps  (61%)
16:25:11:WU00:FS01:0xa4:Completed 930000 out of 1500000 steps  (62%)
16:37:18:WU00:FS01:0xa4:Completed 945000 out of 1500000 steps  (63%)
16:49:23:WU00:FS01:0xa4:Completed 960000 out of 1500000 steps  (64%)
17:01:30:WU00:FS01:0xa4:Completed 975000 out of 1500000 steps  (65%)
17:13:36:WU00:FS01:0xa4:Completed 990000 out of 1500000 steps  (66%)
17:25:44:WU00:FS01:0xa4:Completed 1005000 out of 1500000 steps  (67%)
17:37:49:WU00:FS01:0xa4:Completed 1020000 out of 1500000 steps  (68%)
17:49:54:WU00:FS01:0xa4:Completed 1035000 out of 1500000 steps  (69%)
18:02:05:WU00:FS01:0xa4:Completed 1050000 out of 1500000 steps  (70%)
18:14:12:WU00:FS01:0xa4:Completed 1065000 out of 1500000 steps  (71%)
******************************** Date: 14/04/12 ********************************
18:26:20:WU00:FS01:0xa4:Completed 1080000 out of 1500000 steps  (72%)
18:38:35:WU00:FS01:0xa4:Completed 1095000 out of 1500000 steps  (73%)
18:50:45:WU00:FS01:0xa4:Completed 1110000 out of 1500000 steps  (74%)
19:02:54:WU00:FS01:0xa4:Completed 1125000 out of 1500000 steps  (75%)
19:15:05:WU00:FS01:0xa4:Completed 1140000 out of 1500000 steps  (76%)
19:27:16:WU00:FS01:0xa4:Completed 1155000 out of 1500000 steps  (77%)
19:39:25:WU00:FS01:0xa4:Completed 1170000 out of 1500000 steps  (78%)
19:51:31:WU00:FS01:0xa4:Completed 1185000 out of 1500000 steps  (79%)
20:03:37:WU00:FS01:0xa4:Completed 1200000 out of 1500000 steps  (80%)
20:15:48:WU00:FS01:0xa4:Completed 1215000 out of 1500000 steps  (81%)
20:28:05:WU00:FS01:0xa4:Completed 1230000 out of 1500000 steps  (82%)
20:40:11:WU00:FS01:0xa4:Completed 1245000 out of 1500000 steps  (83%)
20:52:17:WU00:FS01:0xa4:Completed 1260000 out of 1500000 steps  (84%)
21:04:27:WU00:FS01:0xa4:Completed 1275000 out of 1500000 steps  (85%)
21:16:35:WU00:FS01:0xa4:Completed 1290000 out of 1500000 steps  (86%)
21:28:44:WU00:FS01:0xa4:Completed 1305000 out of 1500000 steps  (87%)
21:40:53:WU00:FS01:0xa4:Completed 1320000 out of 1500000 steps  (88%)
21:53:01:WU00:FS01:0xa4:Completed 1335000 out of 1500000 steps  (89%)
22:05:12:WU00:FS01:0xa4:Completed 1350000 out of 1500000 steps  (90%)
22:17:22:WU00:FS01:0xa4:Completed 1365000 out of 1500000 steps  (91%)
22:29:28:WU00:FS01:0xa4:Completed 1380000 out of 1500000 steps  (92%)
22:41:38:WU00:FS01:0xa4:Completed 1395000 out of 1500000 steps  (93%)
22:53:44:WU00:FS01:0xa4:Completed 1410000 out of 1500000 steps  (94%)
23:05:51:WU00:FS01:0xa4:Completed 1425000 out of 1500000 steps  (95%)
23:17:59:WU00:FS01:0xa4:Completed 1440000 out of 1500000 steps  (96%)
23:30:05:WU00:FS01:0xa4:Completed 1455000 out of 1500000 steps  (97%)
23:42:11:WU00:FS01:0xa4:Completed 1470000 out of 1500000 steps  (98%)
23:54:17:WU00:FS01:0xa4:Completed 1485000 out of 1500000 steps  (99%)
23:54:17:WU01:FS01:Connecting to assign3.stanford.edu:8080
23:54:17:WU01:FS01:News: Welcome to Folding@Home
23:54:17:WU01:FS01:Assigned to work server 171.67.108.60
23:54:17:WU01:FS01:Requesting new work unit for slot 01: RUNNING smp:4 from 171.67.108.60
23:54:17:WU01:FS01:Connecting to 171.67.108.60:8080
23:54:18:WU01:FS01:Downloading 863.73KiB
23:54:20:WU01:FS01:Download complete
23:54:20:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:OK project:8013 run:49 clone:26 gen:9 core:0xa4 unit:0x0000000b6652edcc4f782d6c6f395a14
00:06:37:WU00:FS01:0xa4:Completed 1500000 out of 1500000 steps  (100%)
00:06:37:WU00:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
00:06:47:WU00:FS01:0xa4:
00:06:47:WU00:FS01:0xa4:Finished Work Unit:
00:06:47:WU00:FS01:0xa4:- Reading up to 2908800 from "00/wudata_01.trr": Read 2908800
00:06:47:WU00:FS01:0xa4:trr file hash check passed.
00:06:47:WU00:FS01:0xa4:- Reading up to 1554428 from "00/wudata_01.xtc": Read 1554428
00:06:47:WU00:FS01:0xa4:xtc file hash check passed.
00:06:47:WU00:FS01:0xa4:edr file hash check passed.
00:06:47:WU00:FS01:0xa4:logfile size: 39425
00:06:47:WU00:FS01:0xa4:Leaving Run
00:06:50:WU00:FS01:0xa4:- Writing 4507665 bytes of core data to disk...
00:06:51:WU00:FS01:0xa4:Done: 4507153 -> 4326542 (compressed to 95.9 percent)
00:06:51:WU00:FS01:0xa4:  ... Done.
00:06:51:WU00:FS01:0xa4:- Shutting down core
00:06:51:WU00:FS01:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
00:06:52:WU00:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
00:06:52:WU00:FS01:Sending unit results: id:00 state:SEND error:OK project:7809 run:6 clone:77 gen:60 core:0xa4 unit:0x000000530a3b1e874e3111de366e160f
00:06:52:WU00:FS01:Uploading 4.13MiB to 171.64.65.99
00:06:52:WU00:FS01:Connecting to 171.64.65.99:8080
00:06:52:WU01:FS01:Starting
00:06:52:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe" -dir 01 -suffix 01 -version 701 -lifeline 4544 -checkpoint 5 -np 4
00:06:52:WU01:FS01:Started FahCore on PID 4960
00:06:52:WU01:FS01:Core PID:3500
00:06:52:WU01:FS01:FahCore 0xa4 started
00:06:52:WU01:FS01:0xa4:
00:06:52:WU01:FS01:0xa4:*------------------------------*
00:06:52:WU01:FS01:0xa4:Folding@Home Gromacs GB Core
00:06:52:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
00:06:52:WU01:FS01:0xa4:Preparing to commence simulation
00:06:52:WU01:FS01:0xa4:- Looking at optimizations...
00:06:52:WU01:FS01:0xa4:- Created dyn
00:06:52:WU01:FS01:0xa4:- Files status OK
00:06:52:WU01:FS01:0xa4:- Expanded 883946 -> 2028492 (decompressed 229.4 percent)
00:06:52:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=883946 data_size=2028492, decompressed_data_size=2028492 diff=0
00:06:52:WU01:FS01:0xa4:- Digital signature verified
00:06:52:WU01:FS01:0xa4:Project: 8013 (Run 49, Clone 26, Gen 9)
00:06:52:WU01:FS01:0xa4:Assembly optimizations on if available.
00:06:52:WU01:FS01:0xa4:Entering M.D.
00:06:58:WU00:FS01:Upload 15.15%
00:06:58:WU01:FS01:0xa4:Mapping NT from 4 to 4
00:06:59:WU01:FS01:0xa4:Completed 0 out of 250000 steps  (0%)
00:07:04:WU00:FS01:Upload 30.29%
00:07:10:WU00:FS01:Upload 45.44%
00:07:16:WU00:FS01:Upload 60.58%
00:07:22:WU00:FS01:Upload 75.73%
00:07:28:WU00:FS01:Upload 90.87%
00:07:32:WU00:FS01:Upload complete
00:07:32:WU00:FS01:Server responded WORK_ACK (400)
00:07:32:WU00:FS01:Final credit estimate, 10447.00 points
00:07:32:WU00:FS01:Cleaning up
00:08:34:WU01:FS01:0xa4:Completed 2500 out of 250000 steps  (1%)
00:10:10:WU01:FS01:0xa4:Completed 5000 out of 250000 steps  (2%)
00:11:46:WU01:FS01:0xa4:Completed 7500 out of 250000 steps  (3%)
00:13:22:WU01:FS01:0xa4:Completed 10000 out of 250000 steps  (4%)
00:14:57:WU01:FS01:0xa4:Completed 12500 out of 250000 steps  (5%)
00:16:33:WU01:FS01:0xa4:Completed 15000 out of 250000 steps  (6%)
00:18:09:WU01:FS01:0xa4:Completed 17500 out of 250000 steps  (7%)
00:19:45:WU01:FS01:0xa4:Completed 20000 out of 250000 steps  (8%)
00:21:20:WU01:FS01:0xa4:Completed 22500 out of 250000 steps  (9%)
00:22:56:WU01:FS01:0xa4:Completed 25000 out of 250000 steps  (10%)
00:24:32:WU01:FS01:0xa4:Completed 27500 out of 250000 steps  (11%)
00:26:08:WU01:FS01:0xa4:Completed 30000 out of 250000 steps  (12%)
******************************** Date: 15/04/12 ********************************
00:27:44:WU01:FS01:0xa4:Completed 32500 out of 250000 steps  (13%)
00:29:19:WU01:FS01:0xa4:Completed 35000 out of 250000 steps  (14%)
00:30:55:WU01:FS01:0xa4:Completed 37500 out of 250000 steps  (15%)
00:32:31:WU01:FS01:0xa4:Completed 40000 out of 250000 steps  (16%)
00:34:07:WU01:FS01:0xa4:Completed 42500 out of 250000 steps  (17%)
00:35:43:WU01:FS01:0xa4:Completed 45000 out of 250000 steps  (18%)
00:37:19:WU01:FS01:0xa4:Completed 47500 out of 250000 steps  (19%)
00:38:54:WU01:FS01:0xa4:Completed 50000 out of 250000 steps  (20%)
00:40:30:WU01:FS01:0xa4:Completed 52500 out of 250000 steps  (21%)
00:42:06:WU01:FS01:0xa4:Completed 55000 out of 250000 steps  (22%)
00:43:42:WU01:FS01:0xa4:Completed 57500 out of 250000 steps  (23%)
00:45:18:WU01:FS01:0xa4:Completed 60000 out of 250000 steps  (24%)
00:46:54:WU01:FS01:0xa4:Completed 62500 out of 250000 steps  (25%)
00:48:29:WU01:FS01:0xa4:Completed 65000 out of 250000 steps  (26%)
00:50:07:WU01:FS01:0xa4:Completed 67500 out of 250000 steps  (27%)
00:51:43:WU01:FS01:0xa4:Completed 70000 out of 250000 steps  (28%)
00:53:19:WU01:FS01:0xa4:Completed 72500 out of 250000 steps  (29%)
00:54:54:WU01:FS01:0xa4:Completed 75000 out of 250000 steps  (30%)
00:56:32:WU01:FS01:0xa4:Completed 77500 out of 250000 steps  (31%)
00:58:07:WU01:FS01:0xa4:Completed 80000 out of 250000 steps  (32%)
00:59:43:WU01:FS01:0xa4:Completed 82500 out of 250000 steps  (33%)
01:01:19:WU01:FS01:0xa4:Completed 85000 out of 250000 steps  (34%)
01:02:54:WU01:FS01:0xa4:Completed 87500 out of 250000 steps  (35%)
01:04:30:WU01:FS01:0xa4:Completed 90000 out of 250000 steps  (36%)
01:06:05:WU01:FS01:0xa4:Completed 92500 out of 250000 steps  (37%)
01:07:41:WU01:FS01:0xa4:Completed 95000 out of 250000 steps  (38%)
01:09:17:WU01:FS01:0xa4:Completed 97500 out of 250000 steps  (39%)
01:10:52:WU01:FS01:0xa4:Completed 100000 out of 250000 steps  (40%)
01:12:28:WU01:FS01:0xa4:Completed 102500 out of 250000 steps  (41%)
01:14:04:WU01:FS01:0xa4:Completed 105000 out of 250000 steps  (42%)
01:15:39:WU01:FS01:0xa4:Completed 107500 out of 250000 steps  (43%)
01:17:15:WU01:FS01:0xa4:Completed 110000 out of 250000 steps  (44%)
01:18:50:WU01:FS01:0xa4:Completed 112500 out of 250000 steps  (45%)
01:20:26:WU01:FS01:0xa4:Completed 115000 out of 250000 steps  (46%)
01:22:01:WU01:FS01:0xa4:Completed 117500 out of 250000 steps  (47%)
01:23:37:WU01:FS01:0xa4:Completed 120000 out of 250000 steps  (48%)
01:25:13:WU01:FS01:0xa4:Completed 122500 out of 250000 steps  (49%)
01:26:48:WU01:FS01:0xa4:Completed 125000 out of 250000 steps  (50%)
01:28:24:WU01:FS01:0xa4:Completed 127500 out of 250000 steps  (51%)
01:29:59:WU01:FS01:0xa4:Completed 130000 out of 250000 steps  (52%)
01:31:35:WU01:FS01:0xa4:Completed 132500 out of 250000 steps  (53%)
01:33:11:WU01:FS01:0xa4:Completed 135000 out of 250000 steps  (54%)
01:34:49:WU01:FS01:0xa4:Completed 137500 out of 250000 steps  (55%)
01:36:25:WU01:FS01:0xa4:Completed 140000 out of 250000 steps  (56%)
01:38:00:WU01:FS01:0xa4:Completed 142500 out of 250000 steps  (57%)
01:39:36:WU01:FS01:0xa4:Completed 145000 out of 250000 steps  (58%)
01:41:12:WU01:FS01:0xa4:Completed 147500 out of 250000 steps  (59%)
01:42:47:WU01:FS01:0xa4:Completed 150000 out of 250000 steps  (60%)
01:44:23:WU01:FS01:0xa4:Completed 152500 out of 250000 steps  (61%)
01:45:59:WU01:FS01:0xa4:Completed 155000 out of 250000 steps  (62%)
01:47:34:WU01:FS01:0xa4:Completed 157500 out of 250000 steps  (63%)
01:49:10:WU01:FS01:0xa4:Completed 160000 out of 250000 steps  (64%)
01:50:46:WU01:FS01:0xa4:Completed 162500 out of 250000 steps  (65%)
01:52:22:WU01:FS01:0xa4:Completed 165000 out of 250000 steps  (66%)
01:53:57:WU01:FS01:0xa4:Completed 167500 out of 250000 steps  (67%)
01:55:33:WU01:FS01:0xa4:Completed 170000 out of 250000 steps  (68%)
01:57:08:WU01:FS01:0xa4:Completed 172500 out of 250000 steps  (69%)
01:58:47:WU01:FS01:0xa4:Completed 175000 out of 250000 steps  (70%)
02:00:22:WU01:FS01:0xa4:Completed 177500 out of 250000 steps  (71%)
02:01:58:WU01:FS01:0xa4:Completed 180000 out of 250000 steps  (72%)
02:03:34:WU01:FS01:0xa4:Completed 182500 out of 250000 steps  (73%)
02:05:09:WU01:FS01:0xa4:Completed 185000 out of 250000 steps  (74%)
02:06:45:WU01:FS01:0xa4:Completed 187500 out of 250000 steps  (75%)
02:08:20:WU01:FS01:0xa4:Completed 190000 out of 250000 steps  (76%)
02:09:56:WU01:FS01:0xa4:Completed 192500 out of 250000 steps  (77%)
02:11:31:WU01:FS01:0xa4:Completed 195000 out of 250000 steps  (78%)
02:13:07:WU01:FS01:0xa4:Completed 197500 out of 250000 steps  (79%)
02:14:43:WU01:FS01:0xa4:Completed 200000 out of 250000 steps  (80%)
02:16:19:WU01:FS01:0xa4:Completed 202500 out of 250000 steps  (81%)
02:17:55:WU01:FS01:0xa4:Completed 205000 out of 250000 steps  (82%)
02:19:32:WU01:FS01:0xa4:Completed 207500 out of 250000 steps  (83%)
02:21:08:WU01:FS01:0xa4:Completed 210000 out of 250000 steps  (84%)
02:22:44:WU01:FS01:0xa4:Completed 212500 out of 250000 steps  (85%)
02:24:20:WU01:FS01:0xa4:Completed 215000 out of 250000 steps  (86%)
02:25:55:WU01:FS01:0xa4:Completed 217500 out of 250000 steps  (87%)
02:27:31:WU01:FS01:0xa4:Completed 220000 out of 250000 steps  (88%)
02:29:07:WU01:FS01:0xa4:Completed 222500 out of 250000 steps  (89%)
02:30:43:WU01:FS01:0xa4:Completed 225000 out of 250000 steps  (90%)
02:32:18:WU01:FS01:0xa4:Completed 227500 out of 250000 steps  (91%)
02:33:54:WU01:FS01:0xa4:Completed 230000 out of 250000 steps  (92%)
02:35:30:WU01:FS01:0xa4:Completed 232500 out of 250000 steps  (93%)
02:37:05:WU01:FS01:0xa4:Completed 235000 out of 250000 steps  (94%)
02:38:41:WU01:FS01:0xa4:Completed 237500 out of 250000 steps  (95%)
02:40:17:WU01:FS01:0xa4:Completed 240000 out of 250000 steps  (96%)
02:41:52:WU01:FS01:0xa4:Completed 242500 out of 250000 steps  (97%)
02:43:28:WU01:FS01:0xa4:Completed 245000 out of 250000 steps  (98%)
02:45:04:WU01:FS01:0xa4:Completed 247500 out of 250000 steps  (99%)
02:46:39:WU01:FS01:0xa4:Completed 250000 out of 250000 steps  (100%)
02:46:40:WU01:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
02:46:40:WU00:FS01:Connecting to assign3.stanford.edu:8080
02:46:40:WU00:FS01:News: Welcome to Folding@Home
02:46:40:WU00:FS01:Assigned to work server 171.67.108.60
02:46:40:WU00:FS01:Requesting new work unit for slot 01: RUNNING smp:4 from 171.67.108.60
02:46:40:WU00:FS01:Connecting to 171.67.108.60:8080
02:46:41:WU00:FS01:Downloading 865.13KiB
02:46:43:WU00:FS01:Download complete
02:46:43:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:OK project:8013 run:71 clone:23 gen:13 core:0xa4 unit:0x000000136652edcc4f782ddd13951aff
02:46:50:WU01:FS01:0xa4:
02:46:50:WU01:FS01:0xa4:Finished Work Unit:
02:46:50:WU01:FS01:0xa4:- Reading up to 1297176 from "01/wudata_01.trr": Read 1297176
02:46:50:WU01:FS01:0xa4:trr file hash check passed.
02:46:50:WU01:FS01:0xa4:- Reading up to 785492 from "01/wudata_01.xtc": Read 785492
02:46:50:WU01:FS01:0xa4:xtc file hash check passed.
02:46:50:WU01:FS01:0xa4:edr file hash check passed.
02:46:50:WU01:FS01:0xa4:logfile size: 24349
02:46:50:WU01:FS01:0xa4:Leaving Run
02:46:51:WU01:FS01:0xa4:- Writing 2112421 bytes of core data to disk...
02:46:51:WU01:FS01:0xa4:Done: 2111909 -> 2024372 (compressed to 95.8 percent)
02:46:51:WU01:FS01:0xa4:  ... Done.
02:46:51:WU01:FS01:0xa4:- Shutting down core
02:46:51:WU01:FS01:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
02:46:52:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
02:46:52:WU01:FS01:Sending unit results: id:01 state:SEND error:OK project:8013 run:49 clone:26 gen:9 core:0xa4 unit:0x0000000b6652edcc4f782d6c6f395a14
02:46:52:WU01:FS01:Uploading 1.93MiB to 171.67.108.60
02:46:52:WU01:FS01:Connecting to 171.67.108.60:8080
02:46:52:WU00:FS01:Starting
02:46:52:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe" -dir 00 -suffix 01 -version 701 -lifeline 4544 -checkpoint 5 -np 4
02:46:52:WU00:FS01:Started FahCore on PID 4356
02:46:52:WU00:FS01:Core PID:2524
02:46:52:WU00:FS01:FahCore 0xa4 started
02:46:52:WU00:FS01:0xa4:
02:46:52:WU00:FS01:0xa4:*------------------------------*
02:46:52:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
02:46:52:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
02:46:52:WU00:FS01:0xa4:Preparing to commence simulation
02:46:52:WU00:FS01:0xa4:- Looking at optimizations...
02:46:52:WU00:FS01:0xa4:- Created dyn
02:46:52:WU00:FS01:0xa4:- Files status OK
02:46:52:WU00:FS01:0xa4:- Expanded 885382 -> 2026332 (decompressed 228.8 percent)
02:46:52:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=885382 data_size=2026332, decompressed_data_size=2026332 diff=0
02:46:52:WU00:FS01:0xa4:- Digital signature verified
02:46:52:WU00:FS01:0xa4:Project: 8013 (Run 71, Clone 23, Gen 13)
02:46:52:WU00:FS01:0xa4:Assembly optimizations on if available.
02:46:52:WU00:FS01:0xa4:Entering M.D.
02:46:58:WU01:FS01:Upload 32.37%
02:46:58:WU00:FS01:0xa4:Mapping NT from 4 to 4
02:46:58:WU00:FS01:0xa4:Completed 0 out of 250000 steps  (0%)
02:47:04:WU01:FS01:Upload 64.73%
02:47:10:WU01:FS01:Upload 97.10%
02:47:11:WU01:FS01:Upload complete
02:47:11:WU01:FS01:Server responded WORK_ACK (400)
02:47:11:WU01:FS01:Final credit estimate, 1211.00 points
02:47:11:WU01:FS01:Cleaning up
02:48:34:WU00:FS01:0xa4:Completed 2500 out of 250000 steps  (1%)
02:50:10:WU00:FS01:0xa4:Completed 5000 out of 250000 steps  (2%)
02:51:45:WU00:FS01:0xa4:Completed 7500 out of 250000 steps  (3%)
02:53:21:WU00:FS01:0xa4:Completed 10000 out of 250000 steps  (4%)
02:54:57:WU00:FS01:0xa4:Completed 12500 out of 250000 steps  (5%)
02:56:34:WU00:FS01:0xa4:Completed 15000 out of 250000 steps  (6%)
02:58:10:WU00:FS01:0xa4:Completed 17500 out of 250000 steps  (7%)
02:59:46:WU00:FS01:0xa4:Completed 20000 out of 250000 steps  (8%)
03:01:22:WU00:FS01:0xa4:Completed 22500 out of 250000 steps  (9%)
03:02:58:WU00:FS01:0xa4:Completed 25000 out of 250000 steps  (10%)
03:04:36:WU00:FS01:0xa4:Completed 27500 out of 250000 steps  (11%)
03:06:12:WU00:FS01:0xa4:Completed 30000 out of 250000 steps  (12%)
03:07:47:WU00:FS01:0xa4:Completed 32500 out of 250000 steps  (13%)
03:09:23:WU00:FS01:0xa4:Completed 35000 out of 250000 steps  (14%)
03:10:59:WU00:FS01:0xa4:Completed 37500 out of 250000 steps  (15%)
03:12:35:WU00:FS01:0xa4:Completed 40000 out of 250000 steps  (16%)
03:14:11:WU00:FS01:0xa4:Completed 42500 out of 250000 steps  (17%)
03:15:46:WU00:FS01:0xa4:Completed 45000 out of 250000 steps  (18%)
03:17:22:WU00:FS01:0xa4:Completed 47500 out of 250000 steps  (19%)
03:18:58:WU00:FS01:0xa4:Completed 50000 out of 250000 steps  (20%)
03:20:34:WU00:FS01:0xa4:Completed 52500 out of 250000 steps  (21%)
03:22:10:WU00:FS01:0xa4:Completed 55000 out of 250000 steps  (22%)
03:23:45:WU00:FS01:0xa4:Completed 57500 out of 250000 steps  (23%)
03:25:21:WU00:FS01:0xa4:Completed 60000 out of 250000 steps  (24%)
03:26:57:WU00:FS01:0xa4:Completed 62500 out of 250000 steps  (25%)
03:28:33:WU00:FS01:0xa4:Completed 65000 out of 250000 steps  (26%)
03:30:08:WU00:FS01:0xa4:Completed 67500 out of 250000 steps  (27%)
03:31:44:WU00:FS01:0xa4:Completed 70000 out of 250000 steps  (28%)
03:33:20:WU00:FS01:0xa4:Completed 72500 out of 250000 steps  (29%)
03:34:56:WU00:FS01:0xa4:Completed 75000 out of 250000 steps  (30%)
03:36:31:WU00:FS01:0xa4:Completed 77500 out of 250000 steps  (31%)
03:38:07:WU00:FS01:0xa4:Completed 80000 out of 250000 steps  (32%)
03:39:43:WU00:FS01:0xa4:Completed 82500 out of 250000 steps  (33%)
03:41:19:WU00:FS01:0xa4:Completed 85000 out of 250000 steps  (34%)
03:42:55:WU00:FS01:0xa4:Completed 87500 out of 250000 steps  (35%)
03:44:30:WU00:FS01:0xa4:Completed 90000 out of 250000 steps  (36%)
03:46:06:WU00:FS01:0xa4:Completed 92500 out of 250000 steps  (37%)
03:47:42:WU00:FS01:0xa4:Completed 95000 out of 250000 steps  (38%)
03:49:17:WU00:FS01:0xa4:Completed 97500 out of 250000 steps  (39%)
03:50:55:WU00:FS01:0xa4:Completed 100000 out of 250000 steps  (40%)
03:52:31:WU00:FS01:0xa4:Completed 102500 out of 250000 steps  (41%)
03:54:07:WU00:FS01:0xa4:Completed 105000 out of 250000 steps  (42%)
03:55:43:WU00:FS01:0xa4:Completed 107500 out of 250000 steps  (43%)
03:57:20:WU00:FS01:0xa4:Completed 110000 out of 250000 steps  (44%)
03:58:55:WU00:FS01:0xa4:Completed 112500 out of 250000 steps  (45%)
04:00:37:WU00:FS01:0xa4:Completed 115000 out of 250000 steps  (46%)
04:04:14:WU00:FS01:0xa4:Completed 117500 out of 250000 steps  (47%)
04:08:06:WU00:FS01:0xa4:Completed 120000 out of 250000 steps  (48%)
04:11:31:WU00:FS01:0xa4:Completed 122500 out of 250000 steps  (49%)
04:13:57:WU00:FS01:0xa4:Completed 125000 out of 250000 steps  (50%)
04:15:38:WU00:FS01:0xa4:Completed 127500 out of 250000 steps  (51%)
04:18:05:WU00:FS01:0xa4:Completed 130000 out of 250000 steps  (52%)
04:20:13:WU00:FS01:0xa4:Completed 132500 out of 250000 steps  (53%)
e911
Post by e911 »
These are the logs from the other logs file:
*********************** Log Started 2012-04-11T14:02:44Z ***********************
14:02:44:************************* Folding@home Client *************************
14:02:44:      Website: http://folding.stanford.edu/
14:02:44:    Copyright: (c) 2009-2012 Stanford University
14:02:44:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
14:02:44:         Args: --lifeline 3804 --command-port=36330
14:02:44:       Config: C:/Users/*EDITED*
14:02:44:              *EDITED*/AppData/Roaming/FAHClient/CPU/Data/config.xml
14:02:44:******************************** Build ********************************
14:02:44:      Version: 7.1.52
14:02:44:         Date: Mar 20 2012
14:02:44:         Time: 19:37:42
14:02:44:      SVN Rev: 3515
14:02:44:       Branch: fah/trunk/client
14:02:44:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
14:02:44:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
14:02:44:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
14:02:44:     Platform: win32 XP
14:02:44:         Bits: 32
14:02:44:         Mode: Release
14:02:44:******************************* System ********************************
14:02:44:          CPU: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
14:02:44:       CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
14:02:44:         CPUs: 4
14:02:44:       Memory: 15.98GiB
14:02:44:  Free Memory: 10.77GiB
14:02:44:      Threads: WINDOWS_THREADS
14:02:44:   On Battery: false
14:02:44:   UTC offset: -4
14:02:44:          PID: 2488
14:02:44:          CWD: C:/Users/*EDITED*/AppData/Roaming/FAHClient/CPU/Data
14:02:44:           OS: Windows 7 Professional
14:02:44:      OS Arch: AMD64
14:02:44:         GPUs: 1
14:02:44:        GPU 0: FERMI:1 GF110 [Geforce GTX 570 HD]
14:02:44:         CUDA: 2.0
14:02:44:  CUDA Driver: 4010
14:02:44:Win32 Service: false
14:02:44:***********************************************************************
14:02:44:<config>
14:02:44:  <!-- Folding Slot Configuration -->
14:02:44:  <gpu v='true'/>
14:02:44:
14:02:44:  <!-- User Information -->
14:02:44:  <passkey v='********************************'/>
14:02:44:  <team v='111065'/>
14:02:44:  <user v='e911'/>
14:02:44:
14:02:44:  <!-- Folding Slots -->
14:02:44:</config>
14:02:44:Trying to access database...
14:02:44:Successfully acquired database lock
14:02:44:Enabled folding slot 00: READY gpu:0:"GF110 [Geforce GTX 570 HD]"
14:02:44:Enabled folding slot 01: READY smp:4
14:02:44:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
14:02:44:WU01:FS01:Connecting to assign-GPU.stanford.edu:80
14:02:45:WU00:FS00:Connecting to assign-GPU.stanford.edu:80
14:02:45:WU01:FS01:Connecting to assign3.stanford.edu:8080
14:02:45:WU00:FS00:News: Welcome to Folding@Home
14:02:45:WU00:FS00:Assigned to work server 171.67.108.142
14:02:45:WU00:FS00:Requesting new work unit for slot 00: READY gpu:0:"GF110 [Geforce GTX 570 HD]" from 171.67.108.142
14:02:45:WU00:FS00:Connecting to 171.67.108.142:8080
14:02:45:WU01:FS01:News: Welcome to Folding@Home
14:02:45:WU01:FS01:Assigned to work server 171.64.65.99
14:02:45:WU01:FS01:Requesting new work unit for slot 01: READY smp:4 from 171.64.65.99
14:02:45:WU01:FS01:Connecting to 171.64.65.99:8080
14:02:46:WU00:FS00:Downloading 117.50KiB
14:02:46:WU00:FS00:Download complete
14:02:46:WU00:FS00:Received Unit: id:00 state:DOWNLOAD error:OK project:8034 run:13 clone:135 gen:34 core:0x15 unit:0x000000256953ee2e4f72df89e2661e4a
14:02:46:WU00:FS00:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah
14:02:46:WU00:FS00:Connecting to www.stanford.edu:80
14:02:46:WU01:FS01:Downloading 1.98MiB
14:02:46:WU00:FS00:FahCore 15: Downloading 1.49MiB
14:02:47:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
14:02:48:WU01:FS01:Download complete
14:02:48:WU01:FS01:Received Unit: id:01 state:DOWNLOAD error:OK project:7809 run:3 clone:443 gen:58 core:0xa4 unit:0x000000590a3b1e874e310cee23b476a2
14:02:48:WU01:FS01:Downloading core from http://www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah
14:02:48:WU01:FS01:Connecting to www.stanford.edu:80
14:02:49:WU01:FS01:FahCore a4: Downloading 2.89MiB
14:02:52:WU00:FS00:FahCore 15: 96.72%
14:02:52:WU00:FS00:FahCore 15: Download complete
14:02:52:WU00:FS00:Valid core signature
14:02:52:WU00:FS00:Unpacked 4.47MiB to cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe
14:02:52:WU00:FS00:Starting
14:02:52:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED**EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 00 -suffix 01 -version 701 -lifeline 2488 -checkpoint 15 -gpu 0
14:02:52:WU00:FS00:Started FahCore on PID 6352
14:02:52:WU00:FS00:Core PID:3792
14:02:52:WU00:FS00:FahCore 0x15 started
14:02:52:WU00:FS00:Downloading project 8034 description
14:02:52:WU00:FS00:Connecting to fah-web.stanford.edu:80
14:02:52:WU00:FS00:0x15:
14:02:52:WU00:FS00:0x15:*------------------------------*
14:02:52:WU00:FS00:0x15:Folding@Home GPU Core
14:02:52:WU00:FS00:0x15:Version                2.22 (Thu Dec 8 17:08:05 PST 2011)
14:02:52:WU00:FS00:0x15:Build host             SimbiosNvdWin7
14:02:52:WU00:FS00:0x15:Board Type             NVIDIA/CUDA
14:02:52:WU00:FS00:0x15:Core                   15
14:02:52:WU00:FS00:0x15:Window's signal control handler registered.
14:02:52:WU00:FS00:0x15:Preparing to commence simulation
14:02:52:WU00:FS00:0x15:- Looking at optimizations...
14:02:52:WU00:FS00:0x15:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
14:02:52:WU00:FS00:0x15:- Created dyn
14:02:52:WU00:FS00:0x15:- Files status OK
14:02:52:WU00:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
14:02:52:WU00:FS00:0x15:- Expanded 119812 -> 542246 (decompressed 452.5 percent)
14:02:52:WU00:FS00:0x15:Called DecompressByteArray: compressed_data_size=119812 data_size=542246, decompressed_data_size=542246 diff=0
14:02:52:WU00:FS00:0x15:- Digital signature verified
14:02:52:WU00:FS00:0x15:Project: 8034 (Run 13, Clone 135, Gen 34)
14:02:52:WU00:FS00:Project 8034 description downloaded successfully
14:02:52:WU00:FS00:0x15:Assembly optimizations on if available.
14:02:52:WU00:FS00:0x15:Entering M.D.
14:02:54:WU00:FS00:0x15:Tpr hash 00/wudata_01.tpr:  2236105115 3505970481 4172047456 2787604446 3396369791
14:02:54:WU00:FS00:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
14:02:54:WU00:FS00:0x15:Working on Protein
14:02:54:WU00:FS00:0x15:Client config unavailable.
14:02:54:WU00:FS00:0x15:Starting GUI Server
14:02:55:WU01:FS01:FahCore a4: 60.60%
14:02:58:WU01:FS01:FahCore a4: Download complete
14:02:58:WU01:FS01:Valid core signature
14:02:58:WU01:FS01:Unpacked 9.59MiB to cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe
14:02:58:WU01:FS01:Starting
14:02:58:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe" -dir 01 -suffix 01 -version 701 -lifeline 2488 -checkpoint 15 -np 4
14:02:58:WU01:FS01:Started FahCore on PID 6216
14:02:58:WU01:FS01:Core PID:6396
14:02:58:WU01:FS01:FahCore 0xa4 started
14:02:58:WU01:FS01:Downloading project 7809 description
14:02:58:WU01:FS01:Connecting to fah-web.stanford.edu:80
14:02:59:WU01:FS01:0xa4:
14:02:59:WU01:FS01:0xa4:*------------------------------*
14:02:59:WU01:FS01:0xa4:Folding@Home Gromacs GB Core
14:02:59:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
14:02:59:WU01:FS01:0xa4:Preparing to commence simulation
14:02:59:WU01:FS01:0xa4:- Looking at optimizations...
14:02:59:WU01:FS01:0xa4:- Created dyn
14:02:59:WU01:FS01:0xa4:- Files status OK
14:02:59:WU01:FS01:0xa4:- Expanded 2079454 -> 5386224 (decompressed 259.0 percent)
14:02:59:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=2079454 data_size=5386224, decompressed_data_size=5386224 diff=0
14:02:59:WU01:FS01:0xa4:- Digital signature verified
14:02:59:WU01:FS01:0xa4:Project: 7809 (Run 3, Clone 443, Gen 58)
14:02:59:WU01:FS01:0xa4:Assembly optimizations on if available.
14:02:59:WU01:FS01:0xa4:Entering M.D.
14:02:59:WU01:FS01:Project 7809 description downloaded successfully
14:03:05:WU01:FS01:0xa4:Mapping NT from 4 to 4
14:03:05:WU01:FS01:0xa4:Completed 0 out of 1500000 steps  (0%)
14:04:08:WU00:FS00:0x15:Setting checkpoint frequency: 250000
14:04:08:WU00:FS00:0x15:Completed         3 out of 25000000 steps (0%).
14:04:17:Saving configuration to config.xml
14:04:17:<config>
14:04:17:  <!-- Folding Slot Configuration -->
14:04:17:  <gpu v='true'/>
14:04:17:
14:04:17:  <!-- Network -->
14:04:17:  <proxy v=':8080'/>
14:04:17:
14:04:17:  <!-- User Information -->
14:04:17:  <passkey v='********************************'/>
14:04:17:  <team v='111065'/>
14:04:17:  <user v='e911'/>
14:04:17:
14:04:17:  <!-- Folding Slots -->
14:04:17:  <slot id='0' type='GPU'/>
14:04:17:  <slot id='1' type='SMP'/>
14:04:17:</config>
14:06:07:WU01:FS01:FahCore returned: UNKNOWN_ENUM (1073807364 = 0x40010004)
14:06:07:WARNING:WU01:FS01:FahCore crashed with Windows unhandled exception code 0x40010004, searching for this code online may provide more information
14:06:07:WU00:FS00:FahCore returned: UNKNOWN_ENUM (1073807364 = 0x40010004)
14:06:07:WARNING:WU00:FS00:FahCore crashed with Windows unhandled exception code 0x40010004, searching for this code online may provide more information
14:06:07:WU01:FS01:Starting
14:06:07:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe" -dir 01 -suffix 01 -version 701 -lifeline 2488 -checkpoint 15 -np 4
14:06:07:WU01:FS01:Started FahCore on PID 1220
e911
Post by e911 »
*********************** Log Started 2012-04-11T15:37:06Z ***********************
15:37:06:************************* Folding@home Client *************************
15:37:06:      Website: http://folding.stanford.edu/
15:37:06:    Copyright: (c) 2009-2012 Stanford University
15:37:06:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
15:37:06:         Args: --lifeline 3312 --command-port=36330
15:37:06:       Config: C:/Users/*EDITED*
15:37:06:               *EDITED*/AppData/Roaming/FAHClient/CPU/Data/config.xml
15:37:06:******************************** Build ********************************
15:37:06:      Version: 7.1.52
15:37:06:         Date: Mar 20 2012
15:37:06:         Time: 19:37:42
15:37:06:      SVN Rev: 3515
15:37:06:       Branch: fah/trunk/client
15:37:06:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
15:37:06:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
15:37:06:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
15:37:06:     Platform: win32 XP
15:37:06:         Bits: 32
15:37:06:         Mode: Release
15:37:06:******************************* System ********************************
15:37:06:          CPU: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
15:37:06:       CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
15:37:06:         CPUs: 4
15:37:06:       Memory: 15.98GiB
15:37:06:  Free Memory: 14.08GiB
15:37:06:      Threads: WINDOWS_THREADS
15:37:06:   On Battery: false
15:37:06:   UTC offset: -4
15:37:06:          PID: 1180
15:37:06:          CWD: C:/Users/*EDITED*/AppData/Roaming/FAHClient/CPU/Data
15:37:06:           OS: Windows 7 Professional
15:37:06:      OS Arch: AMD64
15:37:06:         GPUs: 1
15:37:06:        GPU 0: FERMI:1 GF110 [Geforce GTX 570 HD]
15:37:06:         CUDA: 2.0
15:37:06:  CUDA Driver: 4010
15:37:06:Win32 Service: false
15:37:06:***********************************************************************
15:37:06:<config>
15:37:06:  <!-- Folding Slot Configuration -->
15:37:06:  <gpu v='true'/>
15:37:06:
15:37:06:  <!-- Network -->
15:37:06:  <proxy v=':8080'/>
15:37:06:
15:37:06:  <!-- User Information -->
15:37:06:  <passkey v='********************************'/>
15:37:06:  <team v='111065'/>
15:37:06:  <user v='e911'/>
15:37:06:
15:37:06:  <!-- Folding Slots -->
15:37:06:  <slot id='0' type='GPU'/>
15:37:06:  <slot id='1' type='SMP'/>
15:37:06:</config>
15:37:06:Trying to access database...
15:37:06:Successfully acquired database lock
15:37:06:Enabled folding slot 00: READY gpu:0:"GF110 [Geforce GTX 570 HD]"
15:37:06:Enabled folding slot 01: READY smp:4
15:37:06:WU01:FS01:Starting
15:37:06:WU01:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe" -dir 01 -suffix 01 -version 701 -lifeline 1180 -checkpoint 15 -np 4
15:37:06:WU01:FS01:Started FahCore on PID 3416
15:37:07:WU01:FS01:Core PID:3356
15:37:07:WU01:FS01:FahCore 0xa4 started
15:37:07:WU00:FS00:Starting
15:37:07:WU00:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED* *EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 00 -suffix 01 -version 701 -lifeline 1180 -checkpoint 15 -gpu 0
15:37:07:WU00:FS00:Started FahCore on PID 3600
15:37:07:WU01:FS01:0xa4:
15:37:07:WU01:FS01:0xa4:*------------------------------*
15:37:07:WU01:FS01:0xa4:Folding@Home Gromacs GB Core
15:37:07:WU00:FS00:Core PID:4192
15:37:07:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
15:37:07:WU01:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
15:37:07:WU00:FS00:FahCore 0x15 started
15:37:08:WU01:FS01:0xa4:
15:37:08:WU01:FS01:0xa4:Preparing to commence simulation
15:37:08:WU01:FS01:0xa4:- Ensuring status. Please wait.
15:37:09:WU00:FS00:0x15:
15:37:09:WU00:FS00:0x15:*------------------------------*
15:37:09:WU00:FS00:0x15:Folding@Home GPU Core
15:37:09:WU00:FS00:0x15:Version                2.22 (Thu Dec 8 17:08:05 PST 2011)
15:37:09:WU00:FS00:0x15:Build host             SimbiosNvdWin7
15:37:09:WU00:FS00:0x15:Board Type             NVIDIA/CUDA
15:37:09:WU00:FS00:0x15:Core                   15
15:37:09:WU00:FS00:0x15:Window's signal control handler registered.
15:37:09:WU00:FS00:0x15:Preparing to commence simulation
15:37:09:WU00:FS00:0x15:- Ensuring status. Please wait.
15:37:17:WU01:FS01:0xa4:- Looking at optimizations...
15:37:17:WU01:FS01:0xa4:- Working with standard loops on this execution.
15:37:17:WU01:FS01:0xa4:- Previous termination of core was improper.
15:37:17:WU01:FS01:0xa4:- Files status OK
15:37:17:WU01:FS01:0xa4:- Expanded 2079454 -> 5386224 (decompressed 259.0 percent)
15:37:17:WU01:FS01:0xa4:Called DecompressByteArray: compressed_data_size=2079454 data_size=5386224, decompressed_data_size=5386224 diff=0
15:37:17:WU01:FS01:0xa4:- Digital signature verified
15:37:17:WU01:FS01:0xa4:Project: 7809 (Run 3, Clone 443, Gen 58)
15:37:17:WU01:FS01:0xa4:Entering M.D.
15:37:18:WU00:FS00:0x15:- Looking at optimizations...
15:37:18:WU00:FS00:0x15:- Working with standard loops on this execution.
15:37:18:WU00:FS00:0x15:- Previous termination of core was improper.
15:37:18:WU00:FS00:0x15:- Files status OK
15:37:18:WU00:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
15:37:18:WU00:FS00:0x15:- Expanded 119812 -> 542246 (decompressed 452.5 percent)
15:37:18:WU00:FS00:0x15:Called DecompressByteArray: compressed_data_size=119812 data_size=542246, decompressed_data_size=542246 diff=0
15:37:18:WU00:FS00:0x15:- Digital signature verified
15:37:18:WU00:FS00:0x15:Project: 8034 (Run 13, Clone 135, Gen 34)
15:37:18:WU00:FS00:0x15:Entering M.D.
15:37:20:WU00:FS00:0x15:Tpr hash 00/wudata_01.tpr:  2236105115 3505970481 4172047456 2787604446 3396369791
15:37:20:WU00:FS00:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
15:37:20:WU00:FS00:0x15:Working on Protein
15:37:20:WU00:FS00:0x15:Client config unavailable.
15:37:20:WU00:FS00:0x15:Starting GUI Server
15:37:23:WU01:FS01:0xa4:Mapping NT from 4 to 4
15:37:42:WU01:FS01:0xa4:Completed 0 out of 1500000 steps  (0%)
15:38:25:WU00:FS00:0x15:Setting checkpoint frequency: 250000
15:38:25:WU00:FS00:0x15:Completed         3 out of 25000000 steps (0%).
15:38:26:WARNING:WU00:FS00:Detected clock skew, adjusting time estimates
15:40:36:Server connection id=2 on 0.0.0.0:36330 from 127.0.0.1
15:40:54:Server connection id=2 ended
15:40:58:Server connection id=3 on 0.0.0.0:36330 from 127.0.0.1
15:41:06:Server connection id=3 ended
15:41:30:WU00:FS00:0x15:Completed    250000 out of 25000000 steps (1%).
15:42:21:Saving configuration to config.xml
15:42:21:<config>
15:42:21:  <!-- FahCore Control -->
15:42:21:  <checkpoint v='5'/>
15:42:21:  <core-priority v='low'/>
15:42:21:
15:42:21:  <!-- Folding Slot Configuration -->
15:42:21:  <gpu v='true'/>
15:42:21:
15:42:21:  <!-- Network -->
15:42:21:  <proxy v=':8080'/>
15:42:21:
15:42:21:  <!-- User Information -->
15:42:21:  <passkey v='********************************'/>
15:42:21:  <team v='111065'/>
15:42:21:  <user v='e911'/>
15:42:21:
15:42:21:  <!-- Folding Slots -->
15:42:21:  <slot id='0' type='GPU'/>
15:42:21:  <slot id='1' type='SMP'/>
15:42:21:</config>
15:45:50:WU00:FS00:0x15:Completed    500000 out of 25000000 steps (2%).
15:48:58:WU00:FS00:0x15:Completed    750000 out of 25000000 steps (3%).
15:52:05:WU00:FS00:0x15:Completed   1000000 out of 25000000 steps (4%).
15:55:13:WU00:FS00:0x15:Completed   1250000 out of 25000000 steps (5%).
15:56:19:WU01:FS01:0xa4:Completed 15000 out of 1500000 steps  (1%)
15:58:20:WU00:FS00:0x15:Completed   1500000 out of 25000000 steps (6%).
16:01:27:WU00:FS00:0x15:Completed   1750000 out of 25000000 steps (7%).
16:04:33:WU00:FS00:0x15:Completed   2000000 out of 25000000 steps (8%).
16:07:40:WU00:FS00:0x15:Completed   2250000 out of 25000000 steps (9%).
16:10:19:WU01:FS01:0xa4:Completed 30000 out of 1500000 steps  (2%)
16:10:46:WU00:FS00:0x15:Completed   2500000 out of 25000000 steps (10%).
16:13:54:WU00:FS00:0x15:Completed   2750000 out of 25000000 steps (11%).
16:17:02:WU00:FS00:0x15:Completed   3000000 out of 25000000 steps (12%).
16:20:09:WU00:FS00:0x15:Completed   3250000 out of 25000000 steps (13%).
16:23:18:WU00:FS00:0x15:Completed   3500000 out of 25000000 steps (14%).
16:23:33:WU01:FS01:0xa4:Completed 45000 out of 1500000 steps  (3%)
16:26:25:WU00:FS00:0x15:Completed   3750000 out of 25000000 steps (15%).
16:29:32:WU00:FS00:0x15:Completed   4000000 out of 25000000 steps (16%).
16:32:40:WU00:FS00:0x15:Completed   4250000 out of 25000000 steps (17%).
16:35:47:WU00:FS00:0x15:Completed   4500000 out of 25000000 steps (18%).
16:37:38:WU01:FS01:0xa4:Completed 60000 out of 1500000 steps  (4%)
16:38:54:WU00:FS00:0x15:Completed   4750000 out of 25000000 steps (19%).
16:42:00:WU00:FS00:0x15:Completed   5000000 out of 25000000 steps (20%).
16:45:07:WU00:FS00:0x15:Completed   5250000 out of 25000000 steps (21%).
16:48:12:WU00:FS00:0x15:Completed   5500000 out of 25000000 steps (22%).
16:51:19:WU00:FS00:0x15:Completed   5750000 out of 25000000 steps (23%).
16:51:49:WU01:FS01:0xa4:Completed 75000 out of 1500000 steps  (5%)
16:54:26:WU00:FS00:0x15:Completed   6000000 out of 25000000 steps (24%).
16:57:32:WU00:FS00:0x15:Completed   6250000 out of 25000000 steps (25%).
17:00:38:WU00:FS00:0x15:Completed   6500000 out of 25000000 steps (26%).
17:03:45:WU00:FS00:0x15:Completed   6750000 out of 25000000 steps (27%).
17:05:58:WU01:FS01:0xa4:Completed 90000 out of 1500000 steps  (6%)
17:06:52:WU00:FS00:0x15:Completed   7000000 out of 25000000 steps (28%).
17:09:58:WU00:FS00:0x15:Completed   7250000 out of 25000000 steps (29%).
17:13:06:WU00:FS00:0x15:Completed   7500000 out of 25000000 steps (30%).
17:16:13:WU00:FS00:0x15:Completed   7750000 out of 25000000 steps (31%).
17:19:20:WU00:FS00:0x15:Completed   8000000 out of 25000000 steps (32%).
17:19:53:WU01:FS01:0xa4:Completed 105000 out of 1500000 steps  (7%)
17:22:26:WU00:FS00:0x15:Completed   8250000 out of 25000000 steps (33%).
17:25:33:WU00:FS00:0x15:Completed   8500000 out of 25000000 steps (34%).
17:28:41:WU00:FS00:0x15:Completed   8750000 out of 25000000 steps (35%).
17:31:47:WU00:FS00:0x15:Completed   9000000 out of 25000000 steps (36%).
17:34:20:WU01:FS01:0xa4:Completed 120000 out of 1500000 steps  (8%)
17:34:56:WU00:FS00:0x15:Completed   9250000 out of 25000000 steps (37%).
17:38:04:WU00:FS00:0x15:Completed   9500000 out of 25000000 steps (38%).
17:41:11:WU00:FS00:0x15:Completed   9750000 out of 25000000 steps (39%).
17:44:18:WU00:FS00:0x15:Completed  10000000 out of 25000000 steps (40%).
17:48:46:WU01:FS01:0xa4:Completed 135000 out of 1500000 steps  (9%)
17:49:29:WU00:FS00:0x15:Completed  10250000 out of 25000000 steps (41%).
17:57:43:WU00:FS00:0x15:Completed  10500000 out of 25000000 steps (42%).
18:03:13:WU01:FS01:0xa4:Completed 150000 out of 1500000 steps  (10%)
18:05:53:WU00:FS00:0x15:Completed  10750000 out of 25000000 steps (43%).
18:14:00:WU00:FS00:0x15:Completed  11000000 out of 25000000 steps (44%).
18:18:27:WU01:FS01:0xa4:Completed 165000 out of 1500000 steps  (11%)
18:21:44:WU00:FS00:0x15:Completed  11250000 out of 25000000 steps (45%).
18:29:40:WU00:FS00:0x15:Completed  11500000 out of 25000000 steps (46%).
18:33:31:WU01:FS01:0xa4:Completed 180000 out of 1500000 steps  (12%)
18:37:33:WU00:FS00:0x15:Completed  11750000 out of 25000000 steps (47%).
18:45:36:WU00:FS00:0x15:Completed  12000000 out of 25000000 steps (48%).
18:48:40:WU01:FS01:0xa4:Completed 195000 out of 1500000 steps  (13%)
18:53:46:WU00:FS00:0x15:Completed  12250000 out of 25000000 steps (49%).
19:01:58:WU00:FS00:0x15:Completed  12500000 out of 25000000 steps (50%).
19:02:37:WU01:FS01:0xa4:Completed 210000 out of 1500000 steps  (14%)
19:10:03:WU00:FS00:0x15:Completed  12750000 out of 25000000 steps (51%).
19:16:08:WU01:FS01:0xa4:Completed 225000 out of 1500000 steps  (15%)
19:18:00:WU00:FS00:0x15:Completed  13000000 out of 25000000 steps (52%).
19:25:58:WU00:FS00:0x15:Completed  13250000 out of 25000000 steps (53%).
19:28:56:WU01:FS01:0xa4:Completed 240000 out of 1500000 steps  (16%)
19:33:55:WU00:FS00:0x15:Completed  13500000 out of 25000000 steps (54%).
19:42:01:WU00:FS00:0x15:Completed  13750000 out of 25000000 steps (55%).
19:42:35:WU01:FS01:0xa4:Completed 255000 out of 1500000 steps  (17%)
19:50:18:WU00:FS00:0x15:Completed  14000000 out of 25000000 steps (56%).
19:57:31:WU01:FS01:0xa4:Completed 270000 out of 1500000 steps  (18%)
19:58:30:WU00:FS00:0x15:Completed  14250000 out of 25000000 steps (57%).
20:06:46:WU00:FS00:0x15:Completed  14500000 out of 25000000 steps (58%).
20:12:06:WU01:FS01:0xa4:Completed 285000 out of 1500000 steps  (19%)
20:15:07:WU00:FS00:0x15:Completed  14750000 out of 25000000 steps (59%).
20:23:12:WU00:FS00:0x15:Completed  15000000 out of 25000000 steps (60%).
20:27:11:WU01:FS01:0xa4:Completed 300000 out of 1500000 steps  (20%)
20:31:23:WU00:FS00:0x15:Completed  15250000 out of 25000000 steps (61%).
20:35:16:Saving configuration to config.xml
20:35:16:<config>
20:35:16:  <!-- FahCore Control -->
20:35:16:  <checkpoint v='5'/>
20:35:16:  <core-priority v='low'/>
20:35:16:
20:35:16:  <!-- Folding Slot Configuration -->
20:35:16:  <gpu v='true'/>
20:35:16:
20:35:16:  <!-- Network -->
20:35:16:  <proxy v=':8080'/>
20:35:16:
20:35:16:  <!-- User Information -->
20:35:16:  <passkey v='********************************'/>
20:35:16:  <team v='111065'/>
20:35:16:  <user v='e911'/>
20:35:16:
20:35:16:  <!-- Folding Slots -->
20:35:16:  <slot id='0' type='GPU'/>
20:35:16:  <slot id='1' type='SMP'/>
20:35:16:</config>
20:38:33:WU00:FS00:0x15:Completed  15500000 out of 25000000 steps (62%).
20:39:35:Server connection id=4 on 0.0.0.0:36330 from 127.0.0.1
20:40:24:Server connection id=4 ended
20:41:45:WU01:FS01:0xa4:Completed 315000 out of 1500000 steps  (21%)
20:46:48:WU00:FS00:0x15:Completed  15750000 out of 25000000 steps (63%).
20:55:03:WU00:FS00:0x15:Completed  16000000 out of 25000000 steps (64%).
20:55:33:WU01:FS01:0xa4:Completed 330000 out of 1500000 steps  (22%)
21:03:20:WU00:FS00:0x15:Completed  16250000 out of 25000000 steps (65%).
21:10:25:WU01:FS01:0xa4:Completed 345000 out of 1500000 steps  (23%)
21:11:32:WU00:FS00:0x15:Completed  16500000 out of 25000000 steps (66%).
21:19:42:WU00:FS00:0x15:Completed  16750000 out of 25000000 steps (67%).
21:25:25:WU01:FS01:0xa4:Completed 360000 out of 1500000 steps  (24%)
21:27:50:WU00:FS00:0x15:Completed  17000000 out of 25000000 steps (68%).
21:36:04:WU00:FS00:0x15:Completed  17250000 out of 25000000 steps (69%).
******************************** Date: 11/04/12 ********************************
21:39:20:WU01:FS01:0xa4:Completed 375000 out of 1500000 steps  (25%)
21:44:12:WU00:FS00:0x15:Completed  17500000 out of 25000000 steps (70%).
21:52:08:WU01:FS01:0xa4:Completed 390000 out of 1500000 steps  (26%)
21:52:14:WU00:FS00:0x15:Completed  17750000 out of 25000000 steps (71%).
22:00:11:WU00:FS00:0x15:Completed  18000000 out of 25000000 steps (72%).
22:04:54:WU01:FS01:0xa4:Completed 405000 out of 1500000 steps  (27%)
22:08:08:WU00:FS00:0x15:Completed  18250000 out of 25000000 steps (73%).
22:16:12:WU00:FS00:0x15:Completed  18500000 out of 25000000 steps (74%).
22:17:45:WU01:FS01:0xa4:Completed 420000 out of 1500000 steps  (28%)
22:24:19:WU00:FS00:0x15:Completed  18750000 out of 25000000 steps (75%).
22:31:59:WU01:FS01:0xa4:Completed 435000 out of 1500000 steps  (29%)
22:32:29:WU00:FS00:0x15:Completed  19000000 out of 25000000 steps (76%).
22:40:38:WU00:FS00:0x15:Completed  19250000 out of 25000000 steps (77%).
22:46:09:WU01:FS01:0xa4:Completed 450000 out of 1500000 steps  (30%)
22:48:46:WU00:FS00:0x15:Completed  19500000 out of 25000000 steps (78%).
22:56:55:WU00:FS00:0x15:Completed  19750000 out of 25000000 steps (79%).
23:00:07:WU01:FS01:0xa4:Completed 465000 out of 1500000 steps  (31%)
23:05:07:WU00:FS00:0x15:Completed  20000000 out of 25000000 steps (80%).
23:13:15:WU00:FS00:0x15:Completed  20250000 out of 25000000 steps (81%).
23:14:19:WU01:FS01:0xa4:Completed 480000 out of 1500000 steps  (32%)
23:21:24:WU00:FS00:0x15:Completed  20500000 out of 25000000 steps (82%).
23:28:27:WU01:FS01:0xa4:Completed 495000 out of 1500000 steps  (33%)
23:29:35:WU00:FS00:0x15:Completed  20750000 out of 25000000 steps (83%).
23:37:45:WU00:FS00:0x15:Completed  21000000 out of 25000000 steps (84%).
23:42:51:WU01:FS01:0xa4:Completed 510000 out of 1500000 steps  (34%)
23:45:53:WU00:FS00:0x15:Completed  21250000 out of 25000000 steps (85%).
23:54:00:WU00:FS00:0x15:Completed  21500000 out of 25000000 steps (86%).
23:57:01:WU01:FS01:0xa4:Completed 525000 out of 1500000 steps  (35%)
00:02:12:WU00:FS00:0x15:Completed  21750000 out of 25000000 steps (87%).
00:10:19:WU00:FS00:0x15:Completed  22000000 out of 25000000 steps (88%).
00:11:26:WU01:FS01:0xa4:Completed 540000 out of 1500000 steps  (36%)
00:18:26:WU00:FS00:0x15:Completed  22250000 out of 25000000 steps (89%).
00:25:37:WU01:FS01:0xa4:Completed 555000 out of 1500000 steps  (37%)
00:26:33:WU00:FS00:0x15:Completed  22500000 out of 25000000 steps (90%).
00:34:42:WU00:FS00:0x15:Completed  22750000 out of 25000000 steps (91%).
00:39:49:WU01:FS01:0xa4:Completed 570000 out of 1500000 steps  (38%)
00:42:47:WU00:FS00:0x15:Completed  23000000 out of 25000000 steps (92%).
00:50:56:WU00:FS00:0x15:Completed  23250000 out of 25000000 steps (93%).
00:53:41:WU01:FS01:0xa4:Completed 585000 out of 1500000 steps  (39%)
00:59:05:WU00:FS00:0x15:Completed  23500000 out of 25000000 steps (94%).
01:07:12:WU00:FS00:0x15:Completed  23750000 out of 25000000 steps (95%).
01:07:28:WU01:FS01:0xa4:Completed 600000 out of 1500000 steps  (40%)
01:15:20:WU00:FS00:0x15:Completed  24000000 out of 25000000 steps (96%).
01:21:48:WU01:FS01:0xa4:Completed 615000 out of 1500000 steps  (41%)
01:23:29:WU00:FS00:0x15:Completed  24250000 out of 25000000 steps (97%).
01:31:40:WU00:FS00:0x15:Completed  24500000 out of 25000000 steps (98%).
01:35:44:WU01:FS01:0xa4:Completed 630000 out of 1500000 steps  (42%)
01:39:48:WU00:FS00:0x15:Completed  24750000 out of 25000000 steps (99%).
01:39:49:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
01:39:50:WU02:FS00:News: Welcome to Folding@Home
01:39:50:WU02:FS00:Assigned to work server 171.67.108.142
01:39:50:WU02:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:"GF110 [Geforce GTX 570 HD]" from 171.67.108.142
01:39:50:WU02:FS00:Connecting to 171.67.108.142:8080
01:39:50:WU02:FS00:Downloading 117.44KiB
01:39:51:WU02:FS00:Download complete
01:39:51:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:OK project:8034 run:17 clone:108 gen:46 core:0x15 unit:0x0000002f6953ee2e4f72e0985eac0d0c
01:48:02:WU00:FS00:0x15:Completed  25000000 out of 25000000 steps (100%).
01:48:04:WU00:FS00:0x15:Finished fah_main status=0
01:48:04:WU00:FS00:0x15:Successful run
01:48:04:WU00:FS00:0x15:DynamicWrapper: Finished Work Unit: sleep=10000
01:48:14:WU00:FS00:0x15:Reserved 351144 bytes for xtc file; Cosm status=0
01:48:14:WU00:FS00:0x15:Allocated 351144 bytes for xtc file
01:48:14:WU00:FS00:0x15:- Reading up to 351144 from "00/wudata_01.xtc": Read 351144
01:48:14:WU00:FS00:0x15:Read 351144 bytes from xtc file; available packet space=786079320
01:48:14:WU00:FS00:0x15:xtc file hash check passed.
01:48:14:WU00:FS00:0x15:Reserved 43968 43968 786079320 bytes for arc file=<00/wudata_01.trr> Cosm status=0
01:48:14:WU00:FS00:0x15:Allocated 43968 bytes for arc file
01:48:14:WU00:FS00:0x15:- Reading up to 43968 from "00/wudata_01.trr": Read 43968
01:48:14:WU00:FS00:0x15:Read 43968 bytes from arc file; available packet space=786035352
01:48:14:WU00:FS00:0x15:trr file hash check passed.
01:48:14:WU00:FS00:0x15:Allocated 544 bytes for edr file
01:48:14:WU00:FS00:0x15:Read bedfile
01:48:14:WU00:FS00:0x15:edr file hash check passed.
01:48:14:WU00:FS00:0x15:Allocated 32180 bytes for logfile
01:48:14:WU00:FS00:0x15:Read logfile
01:48:14:WU00:FS00:0x15:GuardedRun: success in DynamicWrapper
01:48:14:WU00:FS00:0x15:GuardedRun: done
01:48:14:WU00:FS00:0x15:Run: GuardedRun completed.
01:48:19:WU00:FS00:0x15:+ Opened results file
01:48:19:WU00:FS00:0x15:- Writing 428348 bytes of core data to disk...
01:48:19:WU00:FS00:0x15:Done: 427836 -> 404579 (compressed to 94.5 percent)
01:48:19:WU00:FS00:0x15:  ... Done.
01:48:19:WU00:FS00:0x15:DeleteFrameFiles: successfully deleted file=00/wudata_01.ckp
01:48:19:WU00:FS00:0x15:Shutting down core
01:48:19:WU00:FS00:0x15:Folding@home Core Shutdown: FINISHED_UNIT
01:48:19:WU00:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
01:48:19:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:8034 run:13 clone:135 gen:34 core:0x15 unit:0x000000256953ee2e4f72df89e2661e4a
01:48:19:WU00:FS00:Uploading 395.60KiB to 171.67.108.142
01:48:19:WU00:FS00:Connecting to 171.67.108.142:8080
01:48:19:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
01:48:19:WARNING:WU00:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.142:80: A socket operation was attempted to an unreachable host.
01:48:19:WU00:FS00:Trying to send results to collection server
01:48:19:WU00:FS00:Uploading 395.60KiB to 171.65.103.160
01:48:19:WU00:FS00:Connecting to 171.65.103.160:8080
01:48:19:ERROR:WU00:FS00:Exception: Failed to connect to 171.65.103.160:80: A socket operation was attempted to an unreachable host.
01:48:19:WU02:FS00:Starting
01:48:19:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED* *EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 02 -suffix 01 -version 701 -lifeline 1180 -checkpoint 5 -gpu 0
01:48:19:WU02:FS00:Started FahCore on PID 1664
01:48:19:WU02:FS00:Core PID:4288
01:48:19:WU02:FS00:FahCore 0x15 started
01:48:20:WU02:FS00:0x15:
01:48:20:WU02:FS00:0x15:*------------------------------*
01:48:20:WU02:FS00:0x15:Folding@Home GPU Core
01:48:20:WU02:FS00:0x15:Version                2.22 (Thu Dec 8 17:08:05 PST 2011)
01:48:20:WU02:FS00:0x15:Build host             SimbiosNvdWin7
01:48:20:WU02:FS00:0x15:Board Type             NVIDIA/CUDA
01:48:20:WU02:FS00:0x15:Core                   15
01:48:20:WU02:FS00:0x15:Window's signal control handler registered.
01:48:20:WU02:FS00:0x15:Preparing to commence simulation
01:48:20:WU02:FS00:0x15:- Looking at optimizations...
01:48:20:WU02:FS00:0x15:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
01:48:20:WU02:FS00:0x15:- Created dyn
01:48:20:WU02:FS00:0x15:- Files status OK
01:48:20:WU02:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
01:48:20:WU02:FS00:0x15:- Expanded 119748 -> 542246 (decompressed 452.8 percent)
01:48:20:WU02:FS00:0x15:Called DecompressByteArray: compressed_data_size=119748 data_size=542246, decompressed_data_size=542246 diff=0
01:48:20:WU02:FS00:0x15:- Digital signature verified
01:48:20:WU02:FS00:0x15:Project: 8034 (Run 17, Clone 108, Gen 46)
01:48:20:WU02:FS00:0x15:Assembly optimizations on if available.
01:48:20:WU02:FS00:0x15:Entering M.D.
01:48:21:WU02:FS00:0x15:Tpr hash 02/wudata_01.tpr:  644068730 1825390679 2509337284 304286769 2166930463
01:48:21:WU02:FS00:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
01:48:21:WU02:FS00:0x15:Working on Protein
01:48:21:WU02:FS00:0x15:Client config unavailable.
01:48:22:WU02:FS00:0x15:Starting GUI Server
01:49:19:WU00:FS00:Sending unit results: id:00 state:SEND error:OK project:8034 run:13 clone:135 gen:34 core:0x15 unit:0x000000256953ee2e4f72df89e2661e4a
01:49:19:WU00:FS00:Uploading 395.60KiB to 171.67.108.142
01:49:19:WU00:FS00:Connecting to 171.67.108.142:8080
01:49:33:WU02:FS00:0x15:Setting checkpoint frequency: 250000
01:49:33:WU02:FS00:0x15:Completed         3 out of 25000000 steps (0%).
01:49:40:WARNING:WU00:FS00:WorkServer connection failed on port 8080 trying 80
01:49:40:WU00:FS00:Connecting to 171.67.108.142:80
01:49:41:WU00:FS00:Upload 16.18%
01:49:45:WU00:FS00:Upload complete
01:49:45:WU00:FS00:Server responded WORK_ACK (400)
01:49:45:WU00:FS00:Final credit estimate, 3843.00 points
01:49:45:WU00:FS00:Cleaning up
01:50:21:WU01:FS01:0xa4:Completed 645000 out of 1500000 steps  (43%)
01:57:39:WU02:FS00:0x15:Completed    250000 out of 25000000 steps (1%).
02:04:49:WU01:FS01:0xa4:Completed 660000 out of 1500000 steps  (44%)
02:05:48:WU02:FS00:0x15:Completed    500000 out of 25000000 steps (2%).
02:13:57:WU02:FS00:0x15:Completed    750000 out of 25000000 steps (3%).
02:19:13:WU01:FS01:0xa4:Completed 675000 out of 1500000 steps  (45%)
02:22:10:WU02:FS00:0x15:Completed   1000000 out of 25000000 steps (4%).
02:30:20:WU02:FS00:0x15:Completed   1250000 out of 25000000 steps (5%).
02:33:28:WU01:FS01:0xa4:Completed 690000 out of 1500000 steps  (46%)
02:38:30:WU02:FS00:0x15:Completed   1500000 out of 25000000 steps (6%).
02:46:41:WU02:FS00:0x15:Completed   1750000 out of 25000000 steps (7%).
02:47:58:WU01:FS01:0xa4:Completed 705000 out of 1500000 steps  (47%)
02:54:48:WU02:FS00:0x15:Completed   2000000 out of 25000000 steps (8%).
03:02:08:WU01:FS01:0xa4:Completed 720000 out of 1500000 steps  (48%)
03:02:58:WU02:FS00:0x15:Completed   2250000 out of 25000000 steps (9%).
03:11:09:WU02:FS00:0x15:Completed   2500000 out of 25000000 steps (10%).
03:16:10:WU01:FS01:0xa4:Completed 735000 out of 1500000 steps  (49%)
03:19:19:WU02:FS00:0x15:Completed   2750000 out of 25000000 steps (11%).
03:27:31:WU02:FS00:0x15:Completed   3000000 out of 25000000 steps (12%).
03:29:43:WU01:FS01:0xa4:Completed 750000 out of 1500000 steps  (50%)
03:35:38:WU02:FS00:0x15:Completed   3250000 out of 25000000 steps (13%).
******************************** Date: 12/04/12 ********************************
03:42:25:WU01:FS01:0xa4:Completed 765000 out of 1500000 steps  (51%)
03:43:36:WU02:FS00:0x15:Completed   3500000 out of 25000000 steps (14%).
03:51:33:WU02:FS00:0x15:Completed   3750000 out of 25000000 steps (15%).
03:55:11:WU01:FS01:0xa4:Completed 780000 out of 1500000 steps  (52%)
03:59:31:WU02:FS00:0x15:Completed   4000000 out of 25000000 steps (16%).
04:07:29:WU02:FS00:0x15:Completed   4250000 out of 25000000 steps (17%).
04:08:03:WU01:FS01:0xa4:Completed 795000 out of 1500000 steps  (53%)
04:15:27:WU02:FS00:0x15:Completed   4500000 out of 25000000 steps (18%).
04:21:06:WU01:FS01:0xa4:Completed 810000 out of 1500000 steps  (54%)
04:23:26:WU02:FS00:0x15:Completed   4750000 out of 25000000 steps (19%).
04:31:23:WU02:FS00:0x15:Completed   5000000 out of 25000000 steps (20%).
04:34:54:WU01:FS01:0xa4:Completed 825000 out of 1500000 steps  (55%)
04:39:21:WU02:FS00:0x15:Completed   5250000 out of 25000000 steps (21%).
04:47:19:WU02:FS00:0x15:Completed   5500000 out of 25000000 steps (22%).
04:47:36:WU01:FS01:0xa4:Completed 840000 out of 1500000 steps  (56%)
04:55:17:WU02:FS00:0x15:Completed   5750000 out of 25000000 steps (23%).
05:00:19:WU01:FS01:0xa4:Completed 855000 out of 1500000 steps  (57%)
05:03:15:WU02:FS00:0x15:Completed   6000000 out of 25000000 steps (24%).
05:11:13:WU02:FS00:0x15:Completed   6250000 out of 25000000 steps (25%).
05:13:02:WU01:FS01:0xa4:Completed 870000 out of 1500000 steps  (58%)
05:19:10:WU02:FS00:0x15:Completed   6500000 out of 25000000 steps (26%).
05:25:44:WU01:FS01:0xa4:Completed 885000 out of 1500000 steps  (59%)
05:27:08:WU02:FS00:0x15:Completed   6750000 out of 25000000 steps (27%).
05:35:06:WU02:FS00:0x15:Completed   7000000 out of 25000000 steps (28%).
05:38:31:WU01:FS01:0xa4:Completed 900000 out of 1500000 steps  (60%)
05:43:05:WU02:FS00:0x15:Completed   7250000 out of 25000000 steps (29%).
05:51:03:WU02:FS00:0x15:Completed   7500000 out of 25000000 steps (30%).
05:51:23:WU01:FS01:0xa4:Completed 915000 out of 1500000 steps  (61%)
05:59:00:WU02:FS00:0x15:Completed   7750000 out of 25000000 steps (31%).
06:04:18:WU01:FS01:0xa4:Completed 930000 out of 1500000 steps  (62%)
06:06:58:WU02:FS00:0x15:Completed   8000000 out of 25000000 steps (32%).
06:14:55:WU02:FS00:0x15:Completed   8250000 out of 25000000 steps (33%).
06:16:54:WU01:FS01:0xa4:Completed 945000 out of 1500000 steps  (63%)
06:22:52:WU02:FS00:0x15:Completed   8500000 out of 25000000 steps (34%).
06:29:37:WU01:FS01:0xa4:Completed 960000 out of 1500000 steps  (64%)
06:30:50:WU02:FS00:0x15:Completed   8750000 out of 25000000 steps (35%).
06:38:49:WU02:FS00:0x15:Completed   9000000 out of 25000000 steps (36%).
06:42:34:WU01:FS01:0xa4:Completed 975000 out of 1500000 steps  (65%)
06:46:47:WU02:FS00:0x15:Completed   9250000 out of 25000000 steps (37%).
06:54:45:WU02:FS00:0x15:Completed   9500000 out of 25000000 steps (38%).
06:55:22:WU01:FS01:0xa4:Completed 990000 out of 1500000 steps  (66%)
07:02:43:WU02:FS00:0x15:Completed   9750000 out of 25000000 steps (39%).
07:08:10:WU01:FS01:0xa4:Completed 1005000 out of 1500000 steps  (67%)
07:10:41:WU02:FS00:0x15:Completed  10000000 out of 25000000 steps (40%).
07:18:38:WU02:FS00:0x15:Completed  10250000 out of 25000000 steps (41%).
07:20:51:WU01:FS01:0xa4:Completed 1020000 out of 1500000 steps  (68%)
07:26:36:WU02:FS00:0x15:Completed  10500000 out of 25000000 steps (42%).
07:33:41:WU01:FS01:0xa4:Completed 1035000 out of 1500000 steps  (69%)
07:34:34:WU02:FS00:0x15:Completed  10750000 out of 25000000 steps (43%).
07:42:33:WU02:FS00:0x15:Completed  11000000 out of 25000000 steps (44%).
07:46:40:WU01:FS01:0xa4:Completed 1050000 out of 1500000 steps  (70%)
07:50:31:WU02:FS00:0x15:Completed  11250000 out of 25000000 steps (45%).
07:58:30:WU02:FS00:0x15:Completed  11500000 out of 25000000 steps (46%).
07:59:33:WU01:FS01:0xa4:Completed 1065000 out of 1500000 steps  (71%)
08:06:28:WU02:FS00:0x15:Completed  11750000 out of 25000000 steps (47%).
08:12:27:WU01:FS01:0xa4:Completed 1080000 out of 1500000 steps  (72%)
08:14:26:WU02:FS00:0x15:Completed  12000000 out of 25000000 steps (48%).
08:22:24:WU02:FS00:0x15:Completed  12250000 out of 25000000 steps (49%).
08:25:16:WU01:FS01:0xa4:Completed 1095000 out of 1500000 steps  (73%)
08:30:22:WU02:FS00:0x15:Completed  12500000 out of 25000000 steps (50%).
08:38:00:WU01:FS01:0xa4:Completed 1110000 out of 1500000 steps  (74%)
08:38:20:WU02:FS00:0x15:Completed  12750000 out of 25000000 steps (51%).
08:46:18:WU02:FS00:0x15:Completed  13000000 out of 25000000 steps (52%).
08:50:50:WU01:FS01:0xa4:Completed 1125000 out of 1500000 steps  (75%)
08:54:16:WU02:FS00:0x15:Completed  13250000 out of 25000000 steps (53%).
09:02:15:WU02:FS00:0x15:Completed  13500000 out of 25000000 steps (54%).
09:03:51:WU01:FS01:0xa4:Completed 1140000 out of 1500000 steps  (76%)
09:10:13:WU02:FS00:0x15:Completed  13750000 out of 25000000 steps (55%).
09:16:45:WU01:FS01:0xa4:Completed 1155000 out of 1500000 steps  (77%)
09:18:12:WU02:FS00:0x15:Completed  14000000 out of 25000000 steps (56%).
09:26:10:WU02:FS00:0x15:Completed  14250000 out of 25000000 steps (57%).
09:29:34:WU01:FS01:0xa4:Completed 1170000 out of 1500000 steps  (78%)
09:34:08:WU02:FS00:0x15:Completed  14500000 out of 25000000 steps (58%).
09:42:05:WU02:FS00:0x15:Completed  14750000 out of 25000000 steps (59%).
09:42:15:WU01:FS01:0xa4:Completed 1185000 out of 1500000 steps  (79%)
09:50:03:WU02:FS00:0x15:Completed  15000000 out of 25000000 steps (60%).
09:55:14:WU01:FS01:0xa4:Completed 1200000 out of 1500000 steps  (80%)
09:58:02:WU02:FS00:0x15:Completed  15250000 out of 25000000 steps (61%).
10:06:00:WU02:FS00:0x15:Completed  15500000 out of 25000000 steps (62%).
10:08:11:WU01:FS01:0xa4:Completed 1215000 out of 1500000 steps  (81%)
10:13:59:WU02:FS00:0x15:Completed  15750000 out of 25000000 steps (63%).
10:21:04:WU01:FS01:0xa4:Completed 1230000 out of 1500000 steps  (82%)
10:21:57:WU02:FS00:0x15:Completed  16000000 out of 25000000 steps (64%).
10:29:55:WU02:FS00:0x15:Completed  16250000 out of 25000000 steps (65%).
10:33:53:WU01:FS01:0xa4:Completed 1245000 out of 1500000 steps  (83%)
10:37:53:WU02:FS00:0x15:Completed  16500000 out of 25000000 steps (66%).
10:45:52:WU02:FS00:0x15:Completed  16750000 out of 25000000 steps (67%).
10:46:48:WU01:FS01:0xa4:Completed 1260000 out of 1500000 steps  (84%)
10:53:50:WU02:FS00:0x15:Completed  17000000 out of 25000000 steps (68%).
10:59:44:WU01:FS01:0xa4:Completed 1275000 out of 1500000 steps  (85%)
11:01:49:WU02:FS00:0x15:Completed  17250000 out of 25000000 steps (69%).
11:09:47:WU02:FS00:0x15:Completed  17500000 out of 25000000 steps (70%).
11:12:41:WU01:FS01:0xa4:Completed 1290000 out of 1500000 steps  (86%)
11:17:46:WU02:FS00:0x15:Completed  17750000 out of 25000000 steps (71%).
11:25:34:WU01:FS01:0xa4:Completed 1305000 out of 1500000 steps  (87%)
11:25:44:WU02:FS00:0x15:Completed  18000000 out of 25000000 steps (72%).
11:33:42:WU02:FS00:0x15:Completed  18250000 out of 25000000 steps (73%).
11:38:19:WU01:FS01:0xa4:Completed 1320000 out of 1500000 steps  (88%)
11:41:40:WU02:FS00:0x15:Completed  18500000 out of 25000000 steps (74%).
11:49:39:WU02:FS00:0x15:Completed  18750000 out of 25000000 steps (75%).
11:51:18:WU01:FS01:0xa4:Completed 1335000 out of 1500000 steps  (89%)
11:57:37:WU02:FS00:0x15:Completed  19000000 out of 25000000 steps (76%).
12:04:18:WU01:FS01:0xa4:Completed 1350000 out of 1500000 steps  (90%)
12:05:36:WU02:FS00:0x15:Completed  19250000 out of 25000000 steps (77%).
12:13:35:WU02:FS00:0x15:Completed  19500000 out of 25000000 steps (78%).
12:17:15:WU01:FS01:0xa4:Completed 1365000 out of 1500000 steps  (91%)
12:21:33:WU02:FS00:0x15:Completed  19750000 out of 25000000 steps (79%).
12:29:31:WU02:FS00:0x15:Completed  20000000 out of 25000000 steps (80%).
12:30:02:WU01:FS01:0xa4:Completed 1380000 out of 1500000 steps  (92%)
12:37:29:WU02:FS00:0x15:Completed  20250000 out of 25000000 steps (81%).
12:42:53:WU01:FS01:0xa4:Completed 1395000 out of 1500000 steps  (93%)
12:45:27:WU02:FS00:0x15:Completed  20500000 out of 25000000 steps (82%).
12:53:26:WU02:FS00:0x15:Completed  20750000 out of 25000000 steps (83%).
12:55:51:WU01:FS01:0xa4:Completed 1410000 out of 1500000 steps  (94%)
13:01:25:WU02:FS00:0x15:Completed  21000000 out of 25000000 steps (84%).
13:08:41:WU01:FS01:0xa4:Completed 1425000 out of 1500000 steps  (95%)
13:09:23:WU02:FS00:0x15:Completed  21250000 out of 25000000 steps (85%).
13:17:21:WU02:FS00:0x15:Completed  21500000 out of 25000000 steps (86%).
13:21:26:WU01:FS01:0xa4:Completed 1440000 out of 1500000 steps  (96%)
13:25:19:WU02:FS00:0x15:Completed  21750000 out of 25000000 steps (87%).
13:33:16:WU02:FS00:0x15:Completed  22000000 out of 25000000 steps (88%).
13:34:08:WU01:FS01:0xa4:Completed 1455000 out of 1500000 steps  (97%)
13:41:18:WU02:FS00:0x15:Completed  22250000 out of 25000000 steps (89%).
13:48:14:WU01:FS01:0xa4:Completed 1470000 out of 1500000 steps  (98%)
13:49:32:WU02:FS00:0x15:Completed  22500000 out of 25000000 steps (90%).
13:57:46:WU02:FS00:0x15:Completed  22750000 out of 25000000 steps (91%).
14:03:29:WU01:FS01:0xa4:Completed 1485000 out of 1500000 steps  (99%)
14:03:30:WU00:FS01:Connecting to assign3.stanford.edu:8080
14:03:31:WU00:FS01:News: Welcome to Folding@Home
14:03:31:WU00:FS01:Assigned to work server 171.64.65.99
14:03:31:WU00:FS01:Requesting new work unit for slot 01: RUNNING smp:4 from 171.64.65.99
14:03:31:WU00:FS01:Connecting to 171.64.65.99:8080
14:03:32:WU00:FS01:Downloading 1.96MiB
14:03:34:WU00:FS01:Download complete
14:03:34:WU00:FS01:Received Unit: id:00 state:DOWNLOAD error:OK project:7808 run:3 clone:475 gen:70 core:0xa4 unit:0x000000540a3b1e874e30f786976573e7
14:03:34:WU00:FS01:Downloading project 7808 description
14:03:34:WU00:FS01:Connecting to fah-web.stanford.edu:80
14:03:35:WU00:FS01:Project 7808 description downloaded successfully
14:06:06:WU02:FS00:0x15:Completed  23000000 out of 25000000 steps (92%).
14:14:03:WU02:FS00:0x15:Completed  23250000 out of 25000000 steps (93%).
14:17:53:WU01:FS01:0xa4:Completed 1500000 out of 1500000 steps  (100%)
14:17:54:WU01:FS01:0xa4:DynamicWrapper: Finished Work Unit: sleep=10000
14:18:04:WU01:FS01:0xa4:
14:18:04:WU01:FS01:0xa4:Finished Work Unit:
14:18:04:WU01:FS01:0xa4:- Reading up to 2908800 from "01/wudata_01.trr": Read 2908800
14:18:04:WU01:FS01:0xa4:trr file hash check passed.
14:18:04:WU01:FS01:0xa4:- Reading up to 1554476 from "01/wudata_01.xtc": Read 1554476
14:18:04:WU01:FS01:0xa4:xtc file hash check passed.
14:18:04:WU01:FS01:0xa4:edr file hash check passed.
14:18:04:WU01:FS01:0xa4:logfile size: 28416
14:18:04:WU01:FS01:0xa4:Leaving Run
14:18:06:WU01:FS01:0xa4:- Writing 4496704 bytes of core data to disk...
14:18:07:WU01:FS01:0xa4:Done: 4496192 -> 4325488 (compressed to 96.2 percent)
14:18:07:WU01:FS01:0xa4:  ... Done.
14:18:08:WU01:FS01:0xa4:- Shutting down core
14:18:08:WU01:FS01:0xa4:Folding@home Core Shutdown: FINISHED_UNIT
14:18:08:WU01:FS01:FahCore returned: FINISHED_UNIT (100 = 0x64)
14:18:08:WU01:FS01:Sending unit results: id:01 state:SEND error:OK project:7809 run:3 clone:443 gen:58 core:0xa4 unit:0x000000590a3b1e874e310cee23b476a2
14:18:08:WU01:FS01:Uploading 4.13MiB to 171.64.65.99
14:18:08:WU01:FS01:Connecting to 171.64.65.99:8080
14:18:08:WU00:FS01:Starting
14:18:08:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe" -dir 00 -suffix 01 -version 701 -lifeline 1180 -checkpoint 5 -np 4
14:18:08:WU00:FS01:Started FahCore on PID 5920
14:18:08:WU00:FS01:Core PID:5644
14:18:08:WU00:FS01:FahCore 0xa4 started
14:18:09:WU00:FS01:0xa4:
14:18:09:WU00:FS01:0xa4:*------------------------------*
14:18:09:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
14:18:09:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
14:18:09:WU00:FS01:0xa4:Preparing to commence simulation
14:18:09:WU00:FS01:0xa4:- Looking at optimizations...
14:18:09:WU00:FS01:0xa4:- Created dyn
14:18:09:WU00:FS01:0xa4:- Files status OK
14:18:09:WU00:FS01:0xa4:- Expanded 2053702 -> 5365960 (decompressed 261.2 percent)
14:18:09:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=2053702 data_size=5365960, decompressed_data_size=5365960 diff=0
14:18:09:WU00:FS01:0xa4:- Digital signature verified
14:18:09:WU00:FS01:0xa4:Project: 7808 (Run 3, Clone 475, Gen 70)
14:18:09:WU00:FS01:0xa4:Assembly optimizations on if available.
14:18:09:WU00:FS01:0xa4:Entering M.D.
14:18:14:WU01:FS01:Upload 15.15%
14:18:15:WU00:FS01:0xa4:Mapping NT from 4 to 4
14:18:15:WU00:FS01:0xa4:Completed 0 out of 1500000 steps  (0%)
14:18:20:WU01:FS01:Upload 30.30%
14:18:26:WU01:FS01:Upload 46.96%
14:18:32:WU01:FS01:Upload 62.11%
14:18:38:WU01:FS01:Upload 78.78%
14:18:44:WU01:FS01:Upload 93.93%
14:18:47:WU01:FS01:Upload complete
14:18:47:WU01:FS01:Server responded WORK_ACK (400)
14:18:47:WU01:FS01:Final credit estimate, 9715.00 points
14:18:47:WU01:FS01:Cleaning up
14:22:12:WU02:FS00:0x15:Completed  23500000 out of 25000000 steps (94%).
14:30:23:WU02:FS00:0x15:Completed  23750000 out of 25000000 steps (95%).
14:32:01:WU00:FS01:0xa4:Completed 15000 out of 1500000 steps  (1%)
14:38:20:WU02:FS00:0x15:Completed  24000000 out of 25000000 steps (96%).
14:45:59:WU00:FS01:0xa4:Completed 30000 out of 1500000 steps  (2%)
14:46:19:WU02:FS00:0x15:Completed  24250000 out of 25000000 steps (97%).
14:54:30:WU02:FS00:0x15:Completed  24500000 out of 25000000 steps (98%).
15:00:45:WU00:FS01:0xa4:Completed 45000 out of 1500000 steps  (3%)
15:02:43:WU02:FS00:0x15:Completed  24750000 out of 25000000 steps (99%).
15:02:43:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
15:02:43:WU01:FS00:News: Welcome to Folding@Home
15:02:43:WU01:FS00:Assigned to work server 171.67.108.142
15:02:43:WU01:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:"GF110 [Geforce GTX 570 HD]" from 171.67.108.142
15:02:43:WU01:FS00:Connecting to 171.67.108.142:8080
15:02:44:WU01:FS00:Downloading 117.34KiB
15:02:44:WU01:FS00:Download complete
15:02:44:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:OK project:8034 run:16 clone:65 gen:34 core:0x15 unit:0x000000256953ee2e4f72e04cf63bf671
15:10:55:WU02:FS00:0x15:Completed  25000000 out of 25000000 steps (100%).
15:10:56:WU02:FS00:0x15:Finished fah_main status=0
15:10:56:WU02:FS00:0x15:Successful run
15:10:56:WU02:FS00:0x15:DynamicWrapper: Finished Work Unit: sleep=10000
15:11:06:WU02:FS00:0x15:Reserved 350616 bytes for xtc file; Cosm status=0
15:11:06:WU02:FS00:0x15:Allocated 350616 bytes for xtc file
15:11:06:WU02:FS00:0x15:- Reading up to 350616 from "02/wudata_01.xtc": Read 350616
15:11:06:WU02:FS00:0x15:Read 350616 bytes from xtc file; available packet space=786079848
15:11:06:WU02:FS00:0x15:xtc file hash check passed.
15:11:06:WU02:FS00:0x15:Reserved 43968 43968 786079848 bytes for arc file=<02/wudata_01.trr> Cosm status=0
15:11:06:WU02:FS00:0x15:Allocated 43968 bytes for arc file
15:11:06:WU02:FS00:0x15:- Reading up to 43968 from "02/wudata_01.trr": Read 43968
15:11:06:WU02:FS00:0x15:Read 43968 bytes from arc file; available packet space=786035880
15:11:06:WU02:FS00:0x15:trr file hash check passed.
15:11:06:WU02:FS00:0x15:Allocated 544 bytes for edr file
15:11:06:WU02:FS00:0x15:Read bedfile
15:11:06:WU02:FS00:0x15:edr file hash check passed.
15:11:06:WU02:FS00:0x15:Allocated 32180 bytes for logfile
15:11:06:WU02:FS00:0x15:Read logfile
15:11:06:WU02:FS00:0x15:GuardedRun: success in DynamicWrapper
15:11:06:WU02:FS00:0x15:GuardedRun: done
15:11:06:WU02:FS00:0x15:Run: GuardedRun completed.
15:11:08:WU02:FS00:0x15:+ Opened results file
15:11:08:WU02:FS00:0x15:- Writing 427820 bytes of core data to disk...
15:11:09:WU02:FS00:0x15:Done: 427308 -> 404019 (compressed to 94.5 percent)
15:11:09:WU02:FS00:0x15:  ... Done.
15:11:09:WU02:FS00:0x15:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
15:11:09:WU02:FS00:0x15:Shutting down core
15:11:09:WU02:FS00:0x15:Folding@home Core Shutdown: FINISHED_UNIT
15:11:09:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
15:11:09:WU02:FS00:Sending unit results: id:02 state:SEND error:OK project:8034 run:17 clone:108 gen:46 core:0x15 unit:0x0000002f6953ee2e4f72e0985eac0d0c
15:11:09:WU02:FS00:Uploading 395.05KiB to 171.67.108.142
15:11:09:WU02:FS00:Connecting to 171.67.108.142:8080
15:11:09:WU01:FS00:Starting
15:11:09:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED* *EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 01 -suffix 01 -version 701 -lifeline 1180 -checkpoint 5 -gpu 0
15:11:09:WU01:FS00:Started FahCore on PID 5076
15:11:09:WU01:FS00:Core PID:5040
15:11:09:WU01:FS00:FahCore 0x15 started
15:11:10:WU01:FS00:0x15:
15:11:10:WU01:FS00:0x15:*------------------------------*
15:11:10:WU01:FS00:0x15:Folding@Home GPU Core
15:11:10:WU01:FS00:0x15:Version                2.22 (Thu Dec 8 17:08:05 PST 2011)
15:11:10:WU01:FS00:0x15:Build host             SimbiosNvdWin7
15:11:10:WU01:FS00:0x15:Board Type             NVIDIA/CUDA
15:11:10:WU01:FS00:0x15:Core                   15
15:11:10:WU01:FS00:0x15:Window's signal control handler registered.
15:11:10:WU01:FS00:0x15:Preparing to commence simulation
15:11:10:WU01:FS00:0x15:- Looking at optimizations...
15:11:10:WU01:FS00:0x15:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
15:11:10:WU01:FS00:0x15:- Created dyn
15:11:10:WU01:FS00:0x15:- Files status OK
15:11:10:WU01:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
15:11:10:WU01:FS00:0x15:- Expanded 119643 -> 542246 (decompressed 453.2 percent)
15:11:10:WU01:FS00:0x15:Called DecompressByteArray: compressed_data_size=119643 data_size=542246, decompressed_data_size=542246 diff=0
15:11:10:WU01:FS00:0x15:- Digital signature verified
15:11:10:WU01:FS00:0x15:Project: 8034 (Run 16, Clone 65, Gen 34)
15:11:10:WU01:FS00:0x15:Assembly optimizations on if available.
15:11:10:WU01:FS00:0x15:Entering M.D.
15:11:12:WU01:FS00:0x15:Tpr hash 01/wudata_01.tpr:  4030649859 3002864431 557817268 1998267159 3481938135
15:11:12:WU01:FS00:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
15:11:12:WU01:FS00:0x15:Working on Protein
15:11:12:WU01:FS00:0x15:Client config unavailable.
15:11:12:WU01:FS00:0x15:Starting GUI Server
15:11:13:WU02:FS00:Upload complete
15:11:13:WU02:FS00:Server responded WORK_ACK (400)
15:11:13:WU02:FS00:Final credit estimate, 3843.00 points
15:11:13:WU02:FS00:Cleaning up
15:12:18:WU01:FS00:0x15:Setting checkpoint frequency: 250000
15:12:18:WU01:FS00:0x15:Completed         3 out of 25000000 steps (0%).
15:14:40:WU00:FS01:0xa4:Completed 60000 out of 1500000 steps  (4%)
15:20:22:WU01:FS00:0x15:Completed    250000 out of 25000000 steps (1%).
15:27:44:WU00:FS01:0xa4:Completed 75000 out of 1500000 steps  (5%)
15:28:29:WU01:FS00:0x15:Completed    500000 out of 25000000 steps (2%).
15:36:35:WU01:FS00:0x15:Completed    750000 out of 25000000 steps (3%).
15:40:39:WU00:FS01:0xa4:Completed 90000 out of 1500000 steps  (6%)
15:44:33:WU01:FS00:0x15:Completed   1000000 out of 25000000 steps (4%).
15:52:32:WU01:FS00:0x15:Completed   1250000 out of 25000000 steps (5%).
15:53:35:WU00:FS01:0xa4:Completed 105000 out of 1500000 steps  (7%)
16:00:30:WU01:FS00:0x15:Completed   1500000 out of 25000000 steps (6%).
16:06:27:WU00:FS01:0xa4:Completed 120000 out of 1500000 steps  (8%)
16:08:28:WU01:FS00:0x15:Completed   1750000 out of 25000000 steps (7%).
16:16:26:WU01:FS00:0x15:Completed   2000000 out of 25000000 steps (8%).
16:19:18:WU00:FS01:0xa4:Completed 135000 out of 1500000 steps  (9%)
16:24:25:WU01:FS00:0x15:Completed   2250000 out of 25000000 steps (9%).
16:32:09:WU00:FS01:0xa4:Completed 150000 out of 1500000 steps  (10%)
16:32:23:WU01:FS00:0x15:Completed   2500000 out of 25000000 steps (10%).
16:40:21:WU01:FS00:0x15:Completed   2750000 out of 25000000 steps (11%).
16:45:01:WU00:FS01:0xa4:Completed 165000 out of 1500000 steps  (11%)
16:48:19:WU01:FS00:0x15:Completed   3000000 out of 25000000 steps (12%).
16:56:18:WU01:FS00:0x15:Completed   3250000 out of 25000000 steps (13%).
16:57:52:WU00:FS01:0xa4:Completed 180000 out of 1500000 steps  (12%)
17:04:16:WU01:FS00:0x15:Completed   3500000 out of 25000000 steps (14%).
17:10:43:WU00:FS01:0xa4:Completed 195000 out of 1500000 steps  (13%)
17:12:14:WU01:FS00:0x15:Completed   3750000 out of 25000000 steps (15%).
17:20:13:WU01:FS00:0x15:Completed   4000000 out of 25000000 steps (16%).
17:23:37:WU00:FS01:0xa4:Completed 210000 out of 1500000 steps  (14%)
17:28:10:WU01:FS00:0x15:Completed   4250000 out of 25000000 steps (17%).
17:36:08:WU01:FS00:0x15:Completed   4500000 out of 25000000 steps (18%).
17:36:37:WU00:FS01:0xa4:Completed 225000 out of 1500000 steps  (15%)
17:44:06:WU01:FS00:0x15:Completed   4750000 out of 25000000 steps (19%).
17:49:29:WU00:FS01:0xa4:Completed 240000 out of 1500000 steps  (16%)
17:52:04:WU01:FS00:0x15:Completed   5000000 out of 25000000 steps (20%).
18:00:03:WU01:FS00:0x15:Completed   5250000 out of 25000000 steps (21%).
18:02:22:WU00:FS01:0xa4:Completed 255000 out of 1500000 steps  (17%)
18:08:01:WU01:FS00:0x15:Completed   5500000 out of 25000000 steps (22%).
18:15:15:WU00:FS01:0xa4:Completed 270000 out of 1500000 steps  (18%)
18:15:59:WU01:FS00:0x15:Completed   5750000 out of 25000000 steps (23%).
18:23:57:WU01:FS00:0x15:Completed   6000000 out of 25000000 steps (24%).
18:28:04:WU00:FS01:0xa4:Completed 285000 out of 1500000 steps  (19%)
18:31:55:WU01:FS00:0x15:Completed   6250000 out of 25000000 steps (25%).
18:39:53:WU01:FS00:0x15:Completed   6500000 out of 25000000 steps (26%).
18:40:51:WU00:FS01:0xa4:Completed 300000 out of 1500000 steps  (20%)
18:47:52:WU01:FS00:0x15:Completed   6750000 out of 25000000 steps (27%).
18:53:39:WU00:FS01:0xa4:Completed 315000 out of 1500000 steps  (21%)
18:55:50:WU01:FS00:0x15:Completed   7000000 out of 25000000 steps (28%).
19:03:48:WU01:FS00:0x15:Completed   7250000 out of 25000000 steps (29%).
19:06:25:WU00:FS01:0xa4:Completed 330000 out of 1500000 steps  (22%)
19:11:46:WU01:FS00:0x15:Completed   7500000 out of 25000000 steps (30%).
19:19:10:WU00:FS01:0xa4:Completed 345000 out of 1500000 steps  (23%)
19:19:44:WU01:FS00:0x15:Completed   7750000 out of 25000000 steps (31%).
19:27:43:WU01:FS00:0x15:Completed   8000000 out of 25000000 steps (32%).
19:31:47:WU00:FS01:0xa4:Completed 360000 out of 1500000 steps  (24%)
19:35:41:WU01:FS00:0x15:Completed   8250000 out of 25000000 steps (33%).
19:43:39:WU01:FS00:0x15:Completed   8500000 out of 25000000 steps (34%).
19:44:29:WU00:FS01:0xa4:Completed 375000 out of 1500000 steps  (25%)
19:51:36:WU01:FS00:0x15:Completed   8750000 out of 25000000 steps (35%).
19:57:08:WU00:FS01:0xa4:Completed 390000 out of 1500000 steps  (26%)
19:59:34:WU01:FS00:0x15:Completed   9000000 out of 25000000 steps (36%).
20:07:32:WU01:FS00:0x15:Completed   9250000 out of 25000000 steps (37%).
20:09:52:WU00:FS01:0xa4:Completed 405000 out of 1500000 steps  (27%)
20:15:31:WU01:FS00:0x15:Completed   9500000 out of 25000000 steps (38%).
20:22:41:WU00:FS01:0xa4:Completed 420000 out of 1500000 steps  (28%)
20:23:30:WU01:FS00:0x15:Completed   9750000 out of 25000000 steps (39%).
20:31:28:WU01:FS00:0x15:Completed  10000000 out of 25000000 steps (40%).
20:35:31:WU00:FS01:0xa4:Completed 435000 out of 1500000 steps  (29%)
20:39:26:WU01:FS00:0x15:Completed  10250000 out of 25000000 steps (41%).
20:47:24:WU01:FS00:0x15:Completed  10500000 out of 25000000 steps (42%).
20:48:22:WU00:FS01:0xa4:Completed 450000 out of 1500000 steps  (30%)
20:55:23:WU01:FS00:0x15:Completed  10750000 out of 25000000 steps (43%).
21:01:18:WU00:FS01:0xa4:Completed 465000 out of 1500000 steps  (31%)
21:03:22:WU01:FS00:0x15:Completed  11000000 out of 25000000 steps (44%).
21:11:21:WU01:FS00:0x15:Completed  11250000 out of 25000000 steps (45%).
21:14:18:WU00:FS01:0xa4:Completed 480000 out of 1500000 steps  (32%)
21:19:19:WU01:FS00:0x15:Completed  11500000 out of 25000000 steps (46%).
21:27:05:WU00:FS01:0xa4:Completed 495000 out of 1500000 steps  (33%)
21:27:17:WU01:FS00:0x15:Completed  11750000 out of 25000000 steps (47%).
21:35:15:WU01:FS00:0x15:Completed  12000000 out of 25000000 steps (48%).
21:39:52:WU00:FS01:0xa4:Completed 510000 out of 1500000 steps  (34%)
21:43:13:WU01:FS00:0x15:Completed  12250000 out of 25000000 steps (49%).
21:51:11:WU01:FS00:0x15:Completed  12500000 out of 25000000 steps (50%).
21:52:43:WU00:FS01:0xa4:Completed 525000 out of 1500000 steps  (35%)
21:59:10:WU01:FS00:0x15:Completed  12750000 out of 25000000 steps (51%).
22:05:38:WU00:FS01:0xa4:Completed 540000 out of 1500000 steps  (36%)
22:07:08:WU01:FS00:0x15:Completed  13000000 out of 25000000 steps (52%).
22:15:05:WU01:FS00:0x15:Completed  13250000 out of 25000000 steps (53%).
22:18:33:WU00:FS01:0xa4:Completed 555000 out of 1500000 steps  (37%)
22:23:03:WU01:FS00:0x15:Completed  13500000 out of 25000000 steps (54%).
22:31:01:WU01:FS00:0x15:Completed  13750000 out of 25000000 steps (55%).
22:31:26:WU00:FS01:0xa4:Completed 570000 out of 1500000 steps  (38%)
22:39:00:WU01:FS00:0x15:Completed  14000000 out of 25000000 steps (56%).
22:44:27:WU00:FS01:0xa4:Completed 585000 out of 1500000 steps  (39%)
22:46:58:WU01:FS00:0x15:Completed  14250000 out of 25000000 steps (57%).
22:54:56:WU01:FS00:0x15:Completed  14500000 out of 25000000 steps (58%).
22:57:20:WU00:FS01:0xa4:Completed 600000 out of 1500000 steps  (40%)
23:02:55:WU01:FS00:0x15:Completed  14750000 out of 25000000 steps (59%).
23:10:16:WU00:FS01:0xa4:Completed 615000 out of 1500000 steps  (41%)
23:10:54:WU01:FS00:0x15:Completed  15000000 out of 25000000 steps (60%).
23:18:52:WU01:FS00:0x15:Completed  15250000 out of 25000000 steps (61%).
23:23:10:WU00:FS01:0xa4:Completed 630000 out of 1500000 steps  (42%)
23:26:50:WU01:FS00:0x15:Completed  15500000 out of 25000000 steps (62%).
23:34:48:WU01:FS00:0x15:Completed  15750000 out of 25000000 steps (63%).
23:36:07:WU00:FS01:0xa4:Completed 645000 out of 1500000 steps  (43%)
23:42:46:WU01:FS00:0x15:Completed  16000000 out of 25000000 steps (64%).
23:49:01:WU00:FS01:0xa4:Completed 660000 out of 1500000 steps  (44%)
23:50:44:WU01:FS00:0x15:Completed  16250000 out of 25000000 steps (65%).
23:58:42:WU01:FS00:0x15:Completed  16500000 out of 25000000 steps (66%).
00:01:53:WU00:FS01:0xa4:Completed 675000 out of 1500000 steps  (45%)
00:06:40:WU01:FS00:0x15:Completed  16750000 out of 25000000 steps (67%).
00:14:38:WU01:FS00:0x15:Completed  17000000 out of 25000000 steps (68%).
00:14:49:WU00:FS01:0xa4:Completed 690000 out of 1500000 steps  (46%)
00:22:37:WU01:FS00:0x15:Completed  17250000 out of 25000000 steps (69%).
00:27:43:WU00:FS01:0xa4:Completed 705000 out of 1500000 steps  (47%)
00:30:35:WU01:FS00:0x15:Completed  17500000 out of 25000000 steps (70%).
00:38:33:WU01:FS00:0x15:Completed  17750000 out of 25000000 steps (71%).
00:40:37:WU00:FS01:0xa4:Completed 720000 out of 1500000 steps  (48%)
00:46:32:WU01:FS00:0x15:Completed  18000000 out of 25000000 steps (72%).
00:53:30:WU00:FS01:0xa4:Completed 735000 out of 1500000 steps  (49%)
00:54:29:WU01:FS00:0x15:Completed  18250000 out of 25000000 steps (73%).
01:02:27:WU01:FS00:0x15:Completed  18500000 out of 25000000 steps (74%).
01:06:23:WU00:FS01:0xa4:Completed 750000 out of 1500000 steps  (50%)
01:10:26:WU01:FS00:0x15:Completed  18750000 out of 25000000 steps (75%).
01:18:24:WU01:FS00:0x15:Completed  19000000 out of 25000000 steps (76%).
01:19:15:WU00:FS01:0xa4:Completed 765000 out of 1500000 steps  (51%)
01:26:22:WU01:FS00:0x15:Completed  19250000 out of 25000000 steps (77%).
01:32:06:WU00:FS01:0xa4:Completed 780000 out of 1500000 steps  (52%)
01:34:20:WU01:FS00:0x15:Completed  19500000 out of 25000000 steps (78%).
01:42:18:WU01:FS00:0x15:Completed  19750000 out of 25000000 steps (79%).
01:44:58:WU00:FS01:0xa4:Completed 795000 out of 1500000 steps  (53%)
01:50:15:WU01:FS00:0x15:Completed  20000000 out of 25000000 steps (80%).
01:57:47:WU00:FS01:0xa4:Completed 810000 out of 1500000 steps  (54%)
01:58:13:WU01:FS00:0x15:Completed  20250000 out of 25000000 steps (81%).
*had to snip this one due to its length. sorry*
e911
Re: I think my folding is broke :(
Post by e911 »
part two of previous
02:06:11:WU01:FS00:0x15:Completed  20500000 out of 25000000 steps (82%).
02:10:41:WU00:FS01:0xa4:Completed 825000 out of 1500000 steps  (55%)
02:14:10:WU01:FS00:0x15:Completed  20750000 out of 25000000 steps (83%).
02:22:08:WU01:FS00:0x15:Completed  21000000 out of 25000000 steps (84%).
02:23:49:WU00:FS01:0xa4:Completed 840000 out of 1500000 steps  (56%)
02:30:06:WU01:FS00:0x15:Completed  21250000 out of 25000000 steps (85%).
02:37:21:WU00:FS01:0xa4:Completed 855000 out of 1500000 steps  (57%)
02:38:13:WU01:FS00:0x15:Completed  21500000 out of 25000000 steps (86%).
02:46:27:WU01:FS00:0x15:Completed  21750000 out of 25000000 steps (87%).
02:52:45:WU00:FS01:0xa4:Completed 870000 out of 1500000 steps  (58%)
02:54:42:WU01:FS00:0x15:Completed  22000000 out of 25000000 steps (88%).
03:02:59:WU01:FS00:0x15:Completed  22250000 out of 25000000 steps (89%).
03:07:47:WU00:FS01:0xa4:Completed 885000 out of 1500000 steps  (59%)
03:11:08:WU01:FS00:0x15:Completed  22500000 out of 25000000 steps (90%).
03:19:19:WU01:FS00:0x15:Completed  22750000 out of 25000000 steps (91%).
03:22:17:WU00:FS01:0xa4:Completed 900000 out of 1500000 steps  (60%)
03:27:30:WU01:FS00:0x15:Completed  23000000 out of 25000000 steps (92%).
03:35:42:WU01:FS00:0x15:Completed  23250000 out of 25000000 steps (93%).
03:36:39:WU00:FS01:0xa4:Completed 915000 out of 1500000 steps  (61%)
03:43:53:WU01:FS00:0x15:Completed  23500000 out of 25000000 steps (94%).
03:51:32:WU00:FS01:0xa4:Completed 930000 out of 1500000 steps  (62%)
03:52:04:WU01:FS00:0x15:Completed  23750000 out of 25000000 steps (95%).
******************************** Date: 13/04/12 ********************************
04:00:18:WU01:FS00:0x15:Completed  24000000 out of 25000000 steps (96%).
04:05:36:WU00:FS01:0xa4:Completed 945000 out of 1500000 steps  (63%)
04:08:31:WU01:FS00:0x15:Completed  24250000 out of 25000000 steps (97%).
04:16:42:WU01:FS00:0x15:Completed  24500000 out of 25000000 steps (98%).
04:19:43:WU00:FS01:0xa4:Completed 960000 out of 1500000 steps  (64%)
04:24:58:WU01:FS00:0x15:Completed  24750000 out of 25000000 steps (99%).
04:24:58:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
04:24:58:WU02:FS00:News: Welcome to Folding@Home
04:24:58:WU02:FS00:Assigned to work server 171.67.108.142
04:24:58:WU02:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:"GF110 [Geforce GTX 570 HD]" from 171.67.108.142
04:24:58:WU02:FS00:Connecting to 171.67.108.142:8080
04:24:59:WU02:FS00:Downloading 117.29KiB
04:25:00:WU02:FS00:Download complete
04:25:00:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:OK project:8034 run:8 clone:0 gen:38 core:0x15 unit:0x000000296953ee2e4f72de226aa1212a
04:31:57:Server connection id=1 ended
04:32:54:WU01:FS00:0x15:Completed  25000000 out of 25000000 steps (100%).
04:32:56:WU01:FS00:0x15:Finished fah_main status=0
04:32:56:WU01:FS00:0x15:Successful run
04:32:56:WU01:FS00:0x15:DynamicWrapper: Finished Work Unit: sleep=10000
04:33:06:WU01:FS00:0x15:Reserved 349996 bytes for xtc file; Cosm status=0
04:33:06:WU01:FS00:0x15:Allocated 349996 bytes for xtc file
04:33:06:WU01:FS00:0x15:- Reading up to 349996 from "01/wudata_01.xtc": Read 349996
04:33:06:WU01:FS00:0x15:Read 349996 bytes from xtc file; available packet space=786080468
04:33:06:WU01:FS00:0x15:xtc file hash check passed.
04:33:06:WU01:FS00:0x15:Reserved 43968 43968 786080468 bytes for arc file=<01/wudata_01.trr> Cosm status=0
04:33:06:WU01:FS00:0x15:Allocated 43968 bytes for arc file
04:33:06:WU01:FS00:0x15:- Reading up to 43968 from "01/wudata_01.trr": Read 43968
04:33:06:WU01:FS00:0x15:Read 43968 bytes from arc file; available packet space=786036500
04:33:06:WU01:FS00:0x15:trr file hash check passed.
04:33:06:WU01:FS00:0x15:Allocated 544 bytes for edr file
04:33:06:WU01:FS00:0x15:Read bedfile
04:33:06:WU01:FS00:0x15:edr file hash check passed.
04:33:06:WU01:FS00:0x15:Allocated 32180 bytes for logfile
04:33:06:WU01:FS00:0x15:Read logfile
04:33:06:WU01:FS00:0x15:GuardedRun: success in DynamicWrapper
04:33:06:WU01:FS00:0x15:GuardedRun: done
04:33:06:WU01:FS00:0x15:Run: GuardedRun completed.
04:33:10:WU01:FS00:0x15:+ Opened results file
04:33:10:WU01:FS00:0x15:- Writing 427200 bytes of core data to disk...
04:33:10:WU01:FS00:0x15:Done: 426688 -> 403441 (compressed to 94.5 percent)
04:33:10:WU01:FS00:0x15:  ... Done.
04:33:10:WU01:FS00:0x15:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
04:33:10:WU01:FS00:0x15:Shutting down core
04:33:10:WU01:FS00:0x15:Folding@home Core Shutdown: FINISHED_UNIT
04:33:10:WU01:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
04:33:10:WU01:FS00:Sending unit results: id:01 state:SEND error:OK project:8034 run:16 clone:65 gen:34 core:0x15 unit:0x000000256953ee2e4f72e04cf63bf671
04:33:10:WU01:FS00:Uploading 394.49KiB to 171.67.108.142
04:33:10:WU01:FS00:Connecting to 171.67.108.142:8080
04:33:10:WU02:FS00:Starting
04:33:10:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED* *EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 02 -suffix 01 -version 701 -lifeline 1180 -checkpoint 5 -gpu 0
04:33:10:WU02:FS00:Started FahCore on PID 5772
04:33:10:WU02:FS00:Core PID:4076
04:33:10:WU02:FS00:FahCore 0x15 started
04:33:11:WU02:FS00:0x15:
04:33:11:WU02:FS00:0x15:*------------------------------*
04:33:11:WU02:FS00:0x15:Folding@Home GPU Core
04:33:11:WU02:FS00:0x15:Version                2.22 (Thu Dec 8 17:08:05 PST 2011)
04:33:11:WU02:FS00:0x15:Build host             SimbiosNvdWin7
04:33:11:WU02:FS00:0x15:Board Type             NVIDIA/CUDA
04:33:11:WU02:FS00:0x15:Core                   15
04:33:11:WU02:FS00:0x15:Window's signal control handler registered.
04:33:11:WU02:FS00:0x15:Preparing to commence simulation
04:33:11:WU02:FS00:0x15:- Looking at optimizations...
04:33:11:WU02:FS00:0x15:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
04:33:11:WU02:FS00:0x15:- Created dyn
04:33:11:WU02:FS00:0x15:- Files status OK
04:33:11:WU02:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
04:33:11:WU02:FS00:0x15:- Expanded 119591 -> 542246 (decompressed 453.4 percent)
04:33:11:WU02:FS00:0x15:Called DecompressByteArray: compressed_data_size=119591 data_size=542246, decompressed_data_size=542246 diff=0
04:33:11:WU02:FS00:0x15:- Digital signature verified
04:33:11:WU02:FS00:0x15:Project: 8034 (Run 8, Clone 0, Gen 38)
04:33:11:WU02:FS00:0x15:Assembly optimizations on if available.
04:33:11:WU02:FS00:0x15:Entering M.D.
04:33:13:WU02:FS00:0x15:Tpr hash 02/wudata_01.tpr:  2482075659 2715558207 4113023445 1370293439 1174263184
04:33:13:WU02:FS00:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
04:33:13:WU02:FS00:0x15:Working on Protein
04:33:13:WU02:FS00:0x15:Client config unavailable.
04:33:13:WU02:FS00:0x15:Starting GUI Server
04:33:14:WU01:FS00:Upload complete
04:33:14:WU01:FS00:Server responded WORK_ACK (400)
04:33:14:WU01:FS00:Final credit estimate, 3843.00 points
04:33:14:WU01:FS00:Cleaning up
04:33:54:Lost lifeline PID 3312, exiting
04:33:55:FS00:Shutting core down
04:33:55:FS01:Shutting core down
04:34:00:Server connection id=5 on 0.0.0.0:36330 from 127.0.0.1
04:34:01:WU02:FS00:0x15:Client no longer detected. Shutting down core
04:34:01:WU02:FS00:0x15:Folding@home Core Shutdown: CLIENT_DIED
04:34:03:WU00:FS01:0xa4:Client no longer detected. Shutting down core
04:34:03:WU00:FS01:0xa4:Folding@home Core Shutdown: CLIENT_DIED
04:34:03:Clean exit
*********************** Log Started 2012-04-13T04:34:54Z ***********************
04:34:54:************************* Folding@home Client *************************
04:34:54:      Website: http://folding.stanford.edu/
04:34:54:    Copyright: (c) 2009-2012 Stanford University
04:34:54:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:34:54:         Args: --lifeline 5272 --command-port=36330
04:34:54:       Config: C:/Users/*EDITED*
04:34:54:               *EDITED*/AppData/Roaming/FAHClient/CPU/Data/config.xml
04:34:54:******************************** Build ********************************
04:34:54:      Version: 7.1.52
04:34:54:         Date: Mar 20 2012
04:34:54:         Time: 19:37:42
04:34:54:      SVN Rev: 3515
04:34:54:       Branch: fah/trunk/client
04:34:54:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
04:34:54:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
04:34:54:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
04:34:54:     Platform: win32 XP
04:34:54:         Bits: 32
04:34:54:         Mode: Release
04:34:54:******************************* System ********************************
04:34:54:          CPU: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
04:34:54:       CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
04:34:54:         CPUs: 4
04:34:54:       Memory: 15.98GiB
04:34:54:  Free Memory: 12.44GiB
04:34:54:      Threads: WINDOWS_THREADS
04:34:54:   On Battery: false
04:34:54:   UTC offset: -4
04:34:54:          PID: 5184
04:34:54:          CWD: C:/Users/*EDITED*/AppData/Roaming/FAHClient/CPU/Data
04:34:54:           OS: Windows 7 Professional
04:34:54:      OS Arch: AMD64
04:34:54:         GPUs: 1
04:34:54:        GPU 0: FERMI:1 GF110 [Geforce GTX 570 HD]
04:34:54:         CUDA: 2.0
04:34:54:  CUDA Driver: 4010
04:34:54:Win32 Service: false
04:34:54:***********************************************************************
04:34:54:<config>
04:34:54:  <!-- FahCore Control -->
04:34:54:  <checkpoint v='5'/>
04:34:54:  <core-priority v='low'/>
04:34:54:
04:34:54:  <!-- Folding Slot Configuration -->
04:34:54:  <gpu v='true'/>
04:34:54:
04:34:54:  <!-- Network -->
04:34:54:  <proxy v=':8080'/>
04:34:54:
04:34:54:  <!-- User Information -->
04:34:54:  <passkey v='********************************'/>
04:34:54:  <team v='111065'/>
04:34:54:  <user v='e911'/>
04:34:54:
04:34:54:  <!-- Folding Slots -->
04:34:54:  <slot id='0' type='GPU'/>
04:34:54:  <slot id='1' type='SMP'/>
04:34:54:</config>
04:34:54:Trying to access database...
04:34:54:Successfully acquired database lock
04:34:54:Enabled folding slot 00: READY gpu:0:"GF110 [Geforce GTX 570 HD]"
04:34:54:Enabled folding slot 01: READY smp:4
04:34:54:WU00:FS01:Starting
04:34:54:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe" -dir 00 -suffix 01 -version 701 -lifeline 5184 -checkpoint 5 -np 4
04:34:54:WU00:FS01:Started FahCore on PID 2788
04:34:54:WU00:FS01:Core PID:2556
04:34:54:WU00:FS01:FahCore 0xa4 started
04:34:54:WU02:FS00:Starting
04:34:54:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED* *EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 02 -suffix 01 -version 701 -lifeline 5184 -checkpoint 5 -gpu 0
04:34:54:WU02:FS00:Started FahCore on PID 2168
04:34:54:WU02:FS00:Core PID:6036
04:34:54:WU02:FS00:FahCore 0x15 started
04:34:54:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
04:34:54:WU00:FS01:0xa4:
04:34:54:WU00:FS01:0xa4:*------------------------------*
04:34:54:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
04:34:54:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
04:34:54:WU00:FS01:0xa4:Preparing to commence simulation
04:34:54:WU00:FS01:0xa4:- Looking at optimizations...
04:34:54:WU00:FS01:0xa4:- Files status OK
04:34:54:WU00:FS01:0xa4:- Expanded 2053702 -> 5365960 (decompressed 261.2 percent)
04:34:54:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=2053702 data_size=5365960, decompressed_data_size=5365960 diff=0
04:34:54:WU00:FS01:0xa4:- Digital signature verified
04:34:54:WU00:FS01:0xa4:Project: 7808 (Run 3, Clone 475, Gen 70)
04:34:54:WU00:FS01:0xa4:Assembly optimizations on if available.
04:34:54:WU00:FS01:0xa4:Entering M.D.
04:34:55:WU02:FS00:0x15:
04:34:55:WU02:FS00:0x15:*------------------------------*
04:34:55:WU02:FS00:0x15:Folding@Home GPU Core
04:34:55:WU02:FS00:0x15:Version                2.22 (Thu Dec 8 17:08:05 PST 2011)
04:34:55:WU02:FS00:0x15:Build host             SimbiosNvdWin7
04:34:55:WU02:FS00:0x15:Board Type             NVIDIA/CUDA
04:34:55:WU02:FS00:0x15:Core                   15
04:34:55:WU02:FS00:0x15:Window's signal control handler registered.
04:34:55:WU02:FS00:0x15:Preparing to commence simulation
04:34:55:WU02:FS00:0x15:- Looking at optimizations...
04:34:55:WU02:FS00:0x15:- Files status OK
04:34:55:WU02:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
04:34:55:WU02:FS00:0x15:- Expanded 119591 -> 542246 (decompressed 453.4 percent)
04:34:55:WU02:FS00:0x15:Called DecompressByteArray: compressed_data_size=119591 data_size=542246, decompressed_data_size=542246 diff=0
04:34:55:WU02:FS00:0x15:- Digital signature verified
04:34:55:WU02:FS00:0x15:Project: 8034 (Run 8, Clone 0, Gen 38)
04:34:55:WU02:FS00:0x15:Assembly optimizations on if available.
04:34:55:WU02:FS00:0x15:Entering M.D.
04:34:56:WU02:FS00:0x15:Tpr hash 02/wudata_01.tpr:  2482075659 2715558207 4113023445 1370293439 1174263184
04:34:56:WU02:FS00:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
04:34:56:WU02:FS00:0x15:Working on Protein
04:34:56:WU02:FS00:0x15:Client config unavailable.
04:34:56:WU02:FS00:0x15:Starting GUI Server
04:35:00:FS00:Shutting core down
04:35:00:FS01:Shutting core down
04:35:00:WU00:FS01:0xa4:Using Gromacs checkpoints
04:35:00:WU00:FS01:0xa4:Mapping NT from 4 to 4
04:35:01:WU00:FS01:0xa4:Resuming from checkpoint
04:35:01:WU00:FS01:0xa4:Verified 00/wudata_01.log
04:35:01:WU00:FS01:0xa4:Verified 00/wudata_01.trr
04:35:01:WU00:FS01:0xa4:Verified 00/wudata_01.xtc
04:35:01:WU00:FS01:0xa4:Verified 00/wudata_01.edr
04:35:01:WU00:FS01:0xa4:Completed 972780 out of 1500000 steps  (64%)
04:35:04:WU02:FS00:0x15:Client no longer detected. Shutting down core
04:35:04:WU02:FS00:0x15:Folding@home Core Shutdown: CLIENT_DIED
04:35:04:WU00:FS01:0xa4:Client no longer detected. Shutting down core
04:35:04:WU00:FS01:0xa4:Folding@home Core Shutdown: CLIENT_DIED
04:35:06:Clean exit
*********************** Log Started 2012-04-13T04:41:05Z ***********************
04:41:05:************************* Folding@home Client *************************
04:41:05:      Website: http://folding.stanford.edu/
04:41:05:    Copyright: (c) 2009-2012 Stanford University
04:41:05:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
04:41:05:         Args: --lifeline 5272 --command-port=36330
04:41:05:       Config: C:/Users/*EDITED*
04:41:05:               *EDITED*/AppData/Roaming/FAHClient/CPU/Data/config.xml
04:41:05:******************************** Build ********************************
04:41:05:      Version: 7.1.52
04:41:05:         Date: Mar 20 2012
04:41:05:         Time: 19:37:42
04:41:05:      SVN Rev: 3515
04:41:05:       Branch: fah/trunk/client
04:41:05:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
04:41:05:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
04:41:05:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
04:41:05:     Platform: win32 XP
04:41:05:         Bits: 32
04:41:05:         Mode: Release
04:41:05:******************************* System ********************************
04:41:05:          CPU: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
04:41:05:       CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
04:41:05:         CPUs: 4
04:41:05:       Memory: 15.98GiB
04:41:05:  Free Memory: 11.81GiB
04:41:05:      Threads: WINDOWS_THREADS
04:41:05:   On Battery: false
04:41:05:   UTC offset: -4
04:41:05:          PID: 4392
04:41:05:          CWD: C:/Users/*EDITED*/AppData/Roaming/FAHClient/CPU/Data
04:41:05:           OS: Windows 7 Professional
04:41:05:      OS Arch: AMD64
04:41:05:         GPUs: 1
04:41:05:        GPU 0: FERMI:1 GF110 [Geforce GTX 570 HD]
04:41:05:         CUDA: 2.0
04:41:05:  CUDA Driver: 4010
04:41:05:Win32 Service: false
04:41:05:***********************************************************************
04:41:05:<config>
04:41:05:  <!-- FahCore Control -->
04:41:05:  <checkpoint v='5'/>
04:41:05:  <core-priority v='low'/>
04:41:05:
04:41:05:  <!-- Folding Slot Configuration -->
04:41:05:  <gpu v='true'/>
04:41:05:
04:41:05:  <!-- Network -->
04:41:05:  <proxy v=':8080'/>
04:41:05:
04:41:05:  <!-- User Information -->
04:41:05:  <passkey v='********************************'/>
04:41:05:  <team v='111065'/>
04:41:05:  <user v='e911'/>
04:41:05:
04:41:05:  <!-- Folding Slots -->
04:41:05:  <slot id='0' type='GPU'/>
04:41:05:  <slot id='1' type='SMP'/>
04:41:05:</config>
04:41:05:Trying to access database...
04:41:05:Successfully acquired database lock
04:41:05:Enabled folding slot 00: READY gpu:0:"GF110 [Geforce GTX 570 HD]"
04:41:05:Enabled folding slot 01: READY smp:4
04:41:05:WU00:FS01:Starting
04:41:05:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe" -dir 00 -suffix 01 -version 701 -lifeline 4392 -checkpoint 5 -np 4
04:41:05:WU00:FS01:Started FahCore on PID 1376
04:41:05:WU00:FS01:Core PID:3704
04:41:05:WU00:FS01:FahCore 0xa4 started
04:41:05:WU02:FS00:Starting
04:41:06:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED**EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 02 -suffix 01 -version 701 -lifeline 4392 -checkpoint 5 -gpu 0
04:41:06:WU02:FS00:Started FahCore on PID 4804
04:41:06:WU02:FS00:Core PID:4944
04:41:06:WU02:FS00:FahCore 0x15 started
04:41:06:WU00:FS01:0xa4:
04:41:06:WU00:FS01:0xa4:*------------------------------*
04:41:06:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
04:41:06:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
04:41:06:WU00:FS01:0xa4:Preparing to commence simulation
04:41:06:WU00:FS01:0xa4:- Looking at optimizations...
04:41:06:WU00:FS01:0xa4:- Files status OK
04:41:06:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
04:41:06:WU02:FS00:0x15:
04:41:06:WU02:FS00:0x15:*------------------------------*
04:41:06:WU02:FS00:0x15:Folding@Home GPU Core
04:41:06:WU02:FS00:0x15:Version                2.22 (Thu Dec 8 17:08:05 PST 2011)
04:41:06:WU02:FS00:0x15:Build host             SimbiosNvdWin7
04:41:06:WU02:FS00:0x15:Board Type             NVIDIA/CUDA
04:41:06:WU02:FS00:0x15:Core                   15
04:41:06:WU02:FS00:0x15:Window's signal control handler registered.
04:41:06:WU02:FS00:0x15:Preparing to commence simulation
04:41:06:WU02:FS00:0x15:- Looking at optimizations...
04:41:06:WU02:FS00:0x15:- Files status OK
04:41:06:WU02:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
04:41:06:WU02:FS00:0x15:- Expanded 119591 -> 542246 (decompressed 453.4 percent)
04:41:06:WU02:FS00:0x15:Called DecompressByteArray: compressed_data_size=119591 data_size=542246, decompressed_data_size=542246 diff=0
04:41:06:WU02:FS00:0x15:- Digital signature verified
04:41:06:WU02:FS00:0x15:Project: 8034 (Run 8, Clone 0, Gen 38)
04:41:06:WU02:FS00:0x15:Assembly optimizations on if available.
04:41:06:WU02:FS00:0x15:Entering M.D.
04:41:06:WU00:FS01:0xa4:- Expanded 2053702 -> 5365960 (decompressed 261.2 percent)
04:41:06:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=2053702 data_size=5365960, decompressed_data_size=5365960 diff=0
04:41:06:WU00:FS01:0xa4:- Digital signature verified
04:41:06:WU00:FS01:0xa4:Project: 7808 (Run 3, Clone 475, Gen 70)
04:41:06:WU00:FS01:0xa4:Assembly optimizations on if available.
04:41:06:WU00:FS01:0xa4:Entering M.D.
04:41:08:WU02:FS00:0x15:Tpr hash 02/wudata_01.tpr:  2482075659 2715558207 4113023445 1370293439 1174263184
04:41:08:WU02:FS00:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
04:41:08:WU02:FS00:0x15:Working on Protein
04:41:08:WU02:FS00:0x15:Client config unavailable.
04:41:08:WU02:FS00:0x15:Starting GUI Server
04:41:12:WU00:FS01:0xa4:Using Gromacs checkpoints
04:41:12:WU00:FS01:0xa4:Mapping NT from 4 to 4
04:41:13:WU00:FS01:0xa4:Resuming from checkpoint
04:41:13:WU00:FS01:0xa4:Verified 00/wudata_01.log
04:41:13:WU00:FS01:0xa4:Verified 00/wudata_01.trr
04:41:13:WU00:FS01:0xa4:Verified 00/wudata_01.xtc
04:41:13:WU00:FS01:0xa4:Verified 00/wudata_01.edr
04:41:13:WU00:FS01:0xa4:Completed 972780 out of 1500000 steps  (64%)
04:45:42:WU00:FS01:0xa4:Completed 975000 out of 1500000 steps  (65%)
04:48:18:WU02:FS00:0x15:Setting checkpoint frequency: 250000
04:48:18:WU02:FS00:0x15:Completed         3 out of 25000000 steps (0%).
04:55:42:WU02:FS00:0x15:Completed    250000 out of 25000000 steps (1%).
05:00:49:WU00:FS01:0xa4:Completed 990000 out of 1500000 steps  (66%)
05:02:07:WU02:FS00:0x15:Completed    500000 out of 25000000 steps (2%).
05:08:32:WU02:FS00:0x15:Completed    750000 out of 25000000 steps (3%).
05:13:55:WU00:FS01:0xa4:Completed 1005000 out of 1500000 steps  (67%)
05:14:57:WU02:FS00:0x15:Completed   1000000 out of 25000000 steps (4%).
05:17:08:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1 = 0xffffffff)
05:17:09:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
05:17:13:WU02:FS00:Starting
05:17:13:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED* *EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 02 -suffix 01 -version 701 -lifeline 4392 -checkpoint 5 -gpu 0
05:17:16:WU02:FS00:Started FahCore on PID 1248
05:17:18:WU02:FS00:Core PID:3084
05:17:18:WU02:FS00:FahCore 0x15 started
05:17:19:WU02:FS00:0x15:
05:17:19:WU02:FS00:0x15:*------------------------------*
05:17:22:WU02:FS00:0x15:Folding@Home GPU Core
05:17:22:WU02:FS00:0x15:Version                2.22 (Thu Dec 8 17:08:05 PST 2011)
05:17:22:WU02:FS00:0x15:Build host             SimbiosNvdWin7
05:17:23:WU02:FS00:0x15:Board Type             NVIDIA/CUDA
05:17:23:WU02:FS00:0x15:Core                   15
05:17:23:WU02:FS00:0x15:Window's signal control handler registered.
05:17:24:WU02:FS00:0x15:Preparing to commence simulation
05:17:24:WU02:FS00:0x15:- Ensuring status. Please wait.
05:17:28:Server connection id=1 ended
05:17:28:WU02:FS00:0x15:- Looking at optimizations...
05:17:29:WU02:FS00:0x15:- Working with standard loops on this execution.
05:17:29:WU02:FS00:0x15:- Previous termination of core was improper.
05:17:31:WU02:FS00:0x15:- Files status OK
05:17:31:WU02:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
05:17:33:WU02:FS00:0x15:- Expanded 119591 -> 542246 (decompressed 453.4 percent)
05:17:34:WU02:FS00:0x15:Called DecompressByteArray: compressed_data_size=119591 data_size=542246, decompressed_data_size=542246 diff=0
05:17:35:WU02:FS00:0x15:- Digital signature verified
05:17:36:WU02:FS00:0x15:Project: 8034 (Run 8, Clone 0, Gen 38)
05:17:37:WU02:FS00:0x15:Entering M.D.
05:17:38:WU02:FS00:0x15:Will resume from checkpoint file 02/wudata_01.ckp
05:17:38:WU02:FS00:0x15:Tpr hash 02/wudata_01.tpr:  2482075659 2715558207 4113023445 1370293439 1174263184
05:17:40:WU02:FS00:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
05:17:41:WU02:FS00:0x15:Working on Protein
05:17:43:WU02:FS00:0x15:Client config unavailable.
05:17:43:WU02:FS00:0x15:Starting GUI Server
05:17:48:Server connection id=2 on 0.0.0.0:36330 from 127.0.0.1
05:19:12:WU02:FS00:0x15:Resuming from checkpoint
05:19:12:WU02:FS00:0x15:fcCheckPointResume: retreived and current tpr file hash:
05:19:12:WU02:FS00:0x15:   0   2482075659   2482075659
05:19:13:WU02:FS00:0x15:   1   2715558207   2715558207
05:19:13:WARNING:WU02:FS00:Detected clock skew, adjusting time estimates
05:19:13:WU02:FS00:0x15:   2   4113023445   4113023445
05:19:13:WU02:FS00:0x15:   3   1370293439   1370293439
05:19:14:WU02:FS00:0x15:   4   1174263184   1174263184
05:19:14:WU02:FS00:0x15:fcCheckPointResume: file hashes same.
05:19:14:WU02:FS00:0x15:fcCheckPointResume: state restored.
05:19:14:WU02:FS00:0x15:fcCheckPointResume: name 02/wudata_01.log Verified 02/wudata_01.log
05:19:15:WU02:FS00:0x15:fcCheckPointResume: name 02/wudata_01.trr Verified 02/wudata_01.trr
05:19:15:WU02:FS00:0x15:fcCheckPointResume: name 02/wudata_01.xtc Verified 02/wudata_01.xtc
05:19:15:WU02:FS00:0x15:fcCheckPointResume: name 02/wudata_01.edr Verified 02/wudata_01.edr
05:19:16:WU02:FS00:0x15:fcCheckPointResume: state restored 2
05:19:16:WU02:FS00:0x15:Resumed from checkpoint
05:19:16:WU02:FS00:0x15:Setting checkpoint frequency: 250000
05:19:16:WU02:FS00:0x15:Completed   1000001 out of 25000000 steps (4%).
05:25:30:WU02:FS00:0x15:Completed   1250000 out of 25000000 steps (5%).
05:27:10:WU00:FS01:0xa4:Completed 1020000 out of 1500000 steps  (68%)
05:31:40:WU02:FS00:0x15:Completed   1500000 out of 25000000 steps (6%).
05:37:45:WU02:FS00:0x15:Completed   1750000 out of 25000000 steps (7%).
05:41:27:WU00:FS01:0xa4:Completed 1035000 out of 1500000 steps  (69%)
05:43:45:WU02:FS00:0x15:Completed   2000000 out of 25000000 steps (8%).
05:50:16:WU02:FS00:0x15:Completed   2250000 out of 25000000 steps (9%).
05:55:23:WU00:FS01:0xa4:Completed 1050000 out of 1500000 steps  (70%)
05:56:08:WU02:FS00:0x15:Completed   2500000 out of 25000000 steps (10%).
06:02:47:WU02:FS00:0x15:Completed   2750000 out of 25000000 steps (11%).
06:07:43:WU00:FS01:0xa4:Completed 1065000 out of 1500000 steps  (71%)
06:09:25:WU02:FS00:0x15:Completed   3000000 out of 25000000 steps (12%).
06:16:03:WU02:FS00:0x15:Completed   3250000 out of 25000000 steps (13%).
06:20:02:WU00:FS01:0xa4:Completed 1080000 out of 1500000 steps  (72%)
06:22:44:WU02:FS00:0x15:Completed   3500000 out of 25000000 steps (14%).
06:29:25:WU02:FS00:0x15:Completed   3750000 out of 25000000 steps (15%).
06:32:17:WU00:FS01:0xa4:Completed 1095000 out of 1500000 steps  (73%)
06:36:06:WU02:FS00:0x15:Completed   4000000 out of 25000000 steps (16%).
06:42:45:WU02:FS00:0x15:Completed   4250000 out of 25000000 steps (17%).
06:44:33:WU00:FS01:0xa4:Completed 1110000 out of 1500000 steps  (74%)
06:49:23:WU02:FS00:0x15:Completed   4500000 out of 25000000 steps (18%).
06:55:58:WU02:FS00:0x15:Completed   4750000 out of 25000000 steps (19%).
06:56:52:WU00:FS01:0xa4:Completed 1125000 out of 1500000 steps  (75%)
07:02:39:WU02:FS00:0x15:Completed   5000000 out of 25000000 steps (20%).
07:09:07:WU00:FS01:0xa4:Completed 1140000 out of 1500000 steps  (76%)
07:09:22:WU02:FS00:0x15:Completed   5250000 out of 25000000 steps (21%).
07:15:11:WU02:FS00:FahCore returned: UNKNOWN_ENUM (1073807364 = 0x40010004)
e911
Post by e911 »
*********************** Log Started 2012-04-13T13:50:02Z ***********************
13:50:02:************************* Folding@home Client *************************
13:50:02:      Website: http://folding.stanford.edu/
13:50:02:    Copyright: (c) 2009-2012 Stanford University
13:50:02:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
13:50:02:         Args: --lifeline 3208 --command-port=36330
13:50:02:       Config: C:/Users/*EDITED*
13:50:02:               *EDITED*/AppData/Roaming/FAHClient/CPU/Data/config.xml
13:50:02:******************************** Build ********************************
13:50:02:      Version: 7.1.52
13:50:02:         Date: Mar 20 2012
13:50:02:         Time: 19:37:42
13:50:02:      SVN Rev: 3515
13:50:02:       Branch: fah/trunk/client
13:50:02:     Compiler: Intel(R) C++ MSVC 1500 mode 1200
13:50:02:      Options: /TP /nologo /EHa /Qdiag-disable:4297,4103,1786,279 /Ox -arch:SSE
13:50:02:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qopenmp /Qrestrict /MT
13:50:02:     Platform: win32 XP
13:50:02:         Bits: 32
13:50:02:         Mode: Release
13:50:02:******************************* System ********************************
13:50:02:          CPU: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
13:50:02:       CPU ID: GenuineIntel Family 6 Model 42 Stepping 7
13:50:02:         CPUs: 4
13:50:02:       Memory: 15.98GiB
13:50:02:  Free Memory: 13.88GiB
13:50:02:      Threads: WINDOWS_THREADS
13:50:02:   On Battery: false
13:50:02:   UTC offset: -4
13:50:02:          PID: 1932
13:50:02:          CWD: C:/Users/*EDITED*/AppData/Roaming/FAHClient/CPU/Data
13:50:02:           OS: Windows 7 Professional
13:50:02:      OS Arch: AMD64
13:50:02:         GPUs: 1
13:50:02:        GPU 0: FERMI:1 GF110 [Geforce GTX 570 HD]
13:50:02:         CUDA: 2.0
13:50:02:  CUDA Driver: 4020
13:50:02:Win32 Service: false
13:50:02:***********************************************************************
13:50:02:<config>
13:50:02:  <!-- FahCore Control -->
13:50:02:  <checkpoint v='5'/>
13:50:02:  <core-priority v='low'/>
13:50:02:
13:50:02:  <!-- Folding Slot Configuration -->
13:50:02:  <gpu v='true'/>
13:50:02:
13:50:02:  <!-- Network -->
13:50:02:  <proxy v=':8080'/>
13:50:02:
13:50:02:  <!-- User Information -->
13:50:02:  <passkey v='********************************'/>
13:50:02:  <team v='111065'/>
13:50:02:  <user v='e911'/>
13:50:02:
13:50:02:  <!-- Folding Slots -->
13:50:02:  <slot id='0' type='GPU'/>
13:50:02:  <slot id='1' type='SMP'/>
13:50:02:</config>
13:50:02:Trying to access database...
13:50:02:Successfully acquired database lock
13:50:02:Enabled folding slot 00: READY gpu:0:"GF110 [Geforce GTX 570 HD]"
13:50:02:Enabled folding slot 01: READY smp:4
13:50:02:WU00:FS01:Starting
13:50:02:WU00:FS01:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe" -dir 00 -suffix 01 -version 701 -lifeline 1932 -checkpoint 5 -np 4
13:50:03:WU00:FS01:Started FahCore on PID 4140
13:50:03:Server connection id=1 on 0.0.0.0:36330 from 127.0.0.1
13:50:03:WU00:FS01:Core PID:4204
13:50:03:WU00:FS01:FahCore 0xa4 started
13:50:03:WU02:FS00:Starting
13:50:03:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED* *EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 02 -suffix 01 -version 701 -lifeline 1932 -checkpoint 5 -gpu 0
13:50:03:WU02:FS00:Started FahCore on PID 4236
13:50:03:WU02:FS00:Core PID:4268
13:50:03:WU02:FS00:FahCore 0x15 started
13:50:04:WU00:FS01:0xa4:
13:50:04:WU00:FS01:0xa4:*------------------------------*
13:50:04:WU00:FS01:0xa4:Folding@Home Gromacs GB Core
13:50:04:WU00:FS01:0xa4:Version 2.27 (Dec. 15, 2010)
13:50:04:WU00:FS01:0xa4:Preparing to commence simulation
13:50:04:WU00:FS01:0xa4:- Ensuring status. Please wait.
13:50:04:WU02:FS00:0x15:
13:50:04:WU02:FS00:0x15:*------------------------------*
13:50:04:WU02:FS00:0x15:Folding@Home GPU Core
13:50:04:WU02:FS00:0x15:Version                2.22 (Thu Dec 8 17:08:05 PST 2011)
13:50:04:WU02:FS00:0x15:Build host             SimbiosNvdWin7
13:50:04:WU02:FS00:0x15:Board Type             NVIDIA/CUDA
13:50:04:WU02:FS00:0x15:Core                   15
13:50:04:WU02:FS00:0x15:Window's signal control handler registered.
13:50:04:WU02:FS00:0x15:Preparing to commence simulation
13:50:04:WU02:FS00:0x15:- Ensuring status. Please wait.
13:50:13:WU00:FS01:0xa4:- Looking at optimizations...
13:50:13:WU00:FS01:0xa4:- Working with standard loops on this execution.
13:50:13:WU00:FS01:0xa4:- Previous termination of core was improper.
13:50:13:WU00:FS01:0xa4:- Files status OK
13:50:13:WU00:FS01:0xa4:- Expanded 2053702 -> 5365960 (decompressed 261.2 percent)
13:50:13:WU00:FS01:0xa4:Called DecompressByteArray: compressed_data_size=2053702 data_size=5365960, decompressed_data_size=5365960 diff=0
13:50:13:WU00:FS01:0xa4:- Digital signature verified
13:50:13:WU00:FS01:0xa4:Project: 7808 (Run 3, Clone 475, Gen 70)
13:50:13:WU00:FS01:0xa4:Entering M.D.
13:50:13:WU02:FS00:0x15:- Looking at optimizations...
13:50:13:WU02:FS00:0x15:- Working with standard loops on this execution.
13:50:13:WU02:FS00:0x15:- Previous termination of core was improper.
13:50:13:WU02:FS00:0x15:- Going to use standard loops.
13:50:13:WU02:FS00:0x15:- Files status OK
13:50:13:WU02:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
13:50:13:WU02:FS00:0x15:- Expanded 119591 -> 542246 (decompressed 453.4 percent)
13:50:13:WU02:FS00:0x15:Called DecompressByteArray: compressed_data_size=119591 data_size=542246, decompressed_data_size=542246 diff=0
13:50:13:WU02:FS00:0x15:- Digital signature verified
13:50:13:WU02:FS00:0x15:Project: 8034 (Run 8, Clone 0, Gen 38)
13:50:13:WU02:FS00:0x15:Entering M.D.
13:50:15:WU02:FS00:0x15:Will resume from checkpoint file 02/wudata_01.ckp
13:50:15:WU02:FS00:0x15:Tpr hash 02/wudata_01.tpr:  2482075659 2715558207 4113023445 1370293439 1174263184
13:50:15:WU02:FS00:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
13:50:15:WU02:FS00:0x15:Working on Protein
13:50:15:WU02:FS00:0x15:Client config unavailable.
13:50:15:WU02:FS00:0x15:Starting GUI Server
13:50:19:WU00:FS01:0xa4:Using Gromacs checkpoints
13:50:19:WU00:FS01:0xa4:Mapping NT from 4 to 4
13:50:20:WU00:FS01:0xa4:Resuming from checkpoint
13:50:20:WU00:FS01:0xa4:Verified 00/wudata_01.log
13:50:20:WU00:FS01:0xa4:Verified 00/wudata_01.trr
13:50:20:WU00:FS01:0xa4:Verified 00/wudata_01.xtc
13:50:20:WU00:FS01:0xa4:Verified 00/wudata_01.edr
13:50:21:WU00:FS01:0xa4:Completed 1142550 out of 1500000 steps  (76%)
13:51:18:WU02:FS00:0x15:Resuming from checkpoint
13:51:18:WU02:FS00:0x15:fcCheckPointResume: retreived and current tpr file hash:
13:51:18:WU02:FS00:0x15:   0   2482075659   2482075659
13:51:18:WU02:FS00:0x15:   1   2715558207   2715558207
13:51:18:WU02:FS00:0x15:   2   4113023445   4113023445
13:51:18:WU02:FS00:0x15:   3   1370293439   1370293439
13:51:18:WU02:FS00:0x15:   4   1174263184   1174263184
13:51:18:WU02:FS00:0x15:fcCheckPointResume: file hashes same.
13:51:18:WU02:FS00:0x15:fcCheckPointResume: state restored.
13:51:18:WU02:FS00:0x15:fcCheckPointResume: name 02/wudata_01.log Verified 02/wudata_01.log
13:51:18:WU02:FS00:0x15:fcCheckPointResume: name 02/wudata_01.trr Verified 02/wudata_01.trr
13:51:18:WU02:FS00:0x15:fcCheckPointResume: name 02/wudata_01.xtc Verified 02/wudata_01.xtc
13:51:18:WU02:FS00:0x15:fcCheckPointResume: name 02/wudata_01.edr Verified 02/wudata_01.edr
13:51:18:WU02:FS00:0x15:fcCheckPointResume: state restored 2
13:51:18:WU02:FS00:0x15:Resumed from checkpoint
13:51:18:WU02:FS00:0x15:Setting checkpoint frequency: 250000
13:51:18:WU02:FS00:0x15:Completed   5250001 out of 25000000 steps (21%).
13:51:19:WARNING:WU02:FS00:Detected clock skew, adjusting time estimates
13:54:21:WU02:FS00:0x15:Completed   5500000 out of 25000000 steps (22%).
13:57:28:WU02:FS00:0x15:Completed   5750000 out of 25000000 steps (23%).
14:00:36:WU02:FS00:0x15:Completed   6000000 out of 25000000 steps (24%).
14:02:43:WU00:FS01:0xa4:Completed 1155000 out of 1500000 steps  (77%)
14:03:44:WU02:FS00:0x15:Completed   6250000 out of 25000000 steps (25%).
14:06:51:WU02:FS00:0x15:Completed   6500000 out of 25000000 steps (26%).
14:09:55:WU02:FS00:0x15:Completed   6750000 out of 25000000 steps (27%).
14:09:56:Server connection id=2 on 0.0.0.0:36330 from 127.0.0.1
14:10:17:Server connection id=2 ended
14:12:26:WU02:FS00:0x15:Completed   7000000 out of 25000000 steps (28%).
14:14:56:WU02:FS00:0x15:Completed   7250000 out of 25000000 steps (29%).
14:17:14:WU00:FS01:0xa4:Completed 1170000 out of 1500000 steps  (78%)
14:17:27:WU02:FS00:0x15:Completed   7500000 out of 25000000 steps (30%).
14:19:58:WU02:FS00:0x15:Completed   7750000 out of 25000000 steps (31%).
14:22:30:WU02:FS00:0x15:Completed   8000000 out of 25000000 steps (32%).
14:25:00:WU02:FS00:0x15:Completed   8250000 out of 25000000 steps (33%).
14:27:31:WU02:FS00:0x15:Completed   8500000 out of 25000000 steps (34%).
14:30:03:WU02:FS00:0x15:Completed   8750000 out of 25000000 steps (35%).
14:31:50:WU00:FS01:0xa4:Completed 1185000 out of 1500000 steps  (79%)
14:32:35:WU02:FS00:0x15:Completed   9000000 out of 25000000 steps (36%).
14:35:06:WU02:FS00:0x15:Completed   9250000 out of 25000000 steps (37%).
14:37:37:WU02:FS00:0x15:Completed   9500000 out of 25000000 steps (38%).
14:40:08:WU02:FS00:0x15:Completed   9750000 out of 25000000 steps (39%).
14:42:37:WU02:FS00:0x15:Completed  10000000 out of 25000000 steps (40%).
14:45:07:WU02:FS00:0x15:Completed  10250000 out of 25000000 steps (41%).
14:45:40:WU00:FS01:0xa4:Completed 1200000 out of 1500000 steps  (80%)
14:47:37:WU02:FS00:0x15:Completed  10500000 out of 25000000 steps (42%).
14:50:08:WU02:FS00:0x15:Completed  10750000 out of 25000000 steps (43%).
14:52:38:WU02:FS00:0x15:Completed  11000000 out of 25000000 steps (44%).
14:55:08:WU02:FS00:0x15:Completed  11250000 out of 25000000 steps (45%).
14:57:39:WU02:FS00:0x15:Completed  11500000 out of 25000000 steps (46%).
14:59:15:WU00:FS01:0xa4:Completed 1215000 out of 1500000 steps  (81%)
15:00:10:WU02:FS00:0x15:Completed  11750000 out of 25000000 steps (47%).
15:02:40:WU02:FS00:0x15:Completed  12000000 out of 25000000 steps (48%).
15:05:10:WU02:FS00:0x15:Completed  12250000 out of 25000000 steps (49%).
15:07:41:WU02:FS00:0x15:Completed  12500000 out of 25000000 steps (50%).
15:10:11:WU02:FS00:0x15:Completed  12750000 out of 25000000 steps (51%).
15:12:23:WU00:FS01:0xa4:Completed 1230000 out of 1500000 steps  (82%)
15:12:41:WU02:FS00:0x15:Completed  13000000 out of 25000000 steps (52%).
15:15:11:WU02:FS00:0x15:Completed  13250000 out of 25000000 steps (53%).
15:17:42:WU02:FS00:0x15:Completed  13500000 out of 25000000 steps (54%).
15:20:11:WU02:FS00:0x15:Completed  13750000 out of 25000000 steps (55%).
15:22:41:WU02:FS00:0x15:Completed  14000000 out of 25000000 steps (56%).
15:24:50:WU00:FS01:0xa4:Completed 1245000 out of 1500000 steps  (83%)
15:25:11:WU02:FS00:0x15:Completed  14250000 out of 25000000 steps (57%).
15:27:40:WU02:FS00:0x15:Completed  14500000 out of 25000000 steps (58%).
15:30:10:WU02:FS00:0x15:Completed  14750000 out of 25000000 steps (59%).
15:32:39:WU02:FS00:0x15:Completed  15000000 out of 25000000 steps (60%).
15:35:09:WU02:FS00:0x15:Completed  15250000 out of 25000000 steps (61%).
15:37:15:WU00:FS01:0xa4:Completed 1260000 out of 1500000 steps  (84%)
15:37:38:WU02:FS00:0x15:Completed  15500000 out of 25000000 steps (62%).
15:40:08:WU02:FS00:0x15:Completed  15750000 out of 25000000 steps (63%).
15:42:38:WU02:FS00:0x15:Completed  16000000 out of 25000000 steps (64%).
15:45:07:WU02:FS00:0x15:Completed  16250000 out of 25000000 steps (65%).
15:47:37:WU02:FS00:0x15:Completed  16500000 out of 25000000 steps (66%).
15:49:44:WU00:FS01:0xa4:Completed 1275000 out of 1500000 steps  (85%)
15:50:06:WU02:FS00:0x15:Completed  16750000 out of 25000000 steps (67%).
15:52:36:WU02:FS00:0x15:Completed  17000000 out of 25000000 steps (68%).
15:55:05:WU02:FS00:0x15:Completed  17250000 out of 25000000 steps (69%).
15:57:35:WU02:FS00:0x15:Completed  17500000 out of 25000000 steps (70%).
16:00:06:WU02:FS00:0x15:Completed  17750000 out of 25000000 steps (71%).
16:02:12:WU00:FS01:0xa4:Completed 1290000 out of 1500000 steps  (86%)
16:02:35:WU02:FS00:0x15:Completed  18000000 out of 25000000 steps (72%).
16:05:05:WU02:FS00:0x15:Completed  18250000 out of 25000000 steps (73%).
16:07:34:WU02:FS00:0x15:Completed  18500000 out of 25000000 steps (74%).
16:10:04:WU02:FS00:0x15:Completed  18750000 out of 25000000 steps (75%).
16:12:34:WU02:FS00:0x15:Completed  19000000 out of 25000000 steps (76%).
16:14:35:WU00:FS01:0xa4:Completed 1305000 out of 1500000 steps  (87%)
16:15:03:WU02:FS00:0x15:Completed  19250000 out of 25000000 steps (77%).
16:17:33:WU02:FS00:0x15:Completed  19500000 out of 25000000 steps (78%).
16:20:02:WU02:FS00:0x15:Completed  19750000 out of 25000000 steps (79%).
16:22:32:WU02:FS00:0x15:Completed  20000000 out of 25000000 steps (80%).
16:25:02:WU02:FS00:0x15:Completed  20250000 out of 25000000 steps (81%).
16:26:59:WU00:FS01:0xa4:Completed 1320000 out of 1500000 steps  (88%)
16:27:31:WU02:FS00:0x15:Completed  20500000 out of 25000000 steps (82%).
16:30:01:WU02:FS00:0x15:Completed  20750000 out of 25000000 steps (83%).
16:32:30:WU02:FS00:0x15:Completed  21000000 out of 25000000 steps (84%).
16:35:00:WU02:FS00:0x15:Completed  21250000 out of 25000000 steps (85%).
16:37:29:WU02:FS00:0x15:Completed  21500000 out of 25000000 steps (86%).
16:39:24:WU00:FS01:0xa4:Completed 1335000 out of 1500000 steps  (89%)
16:39:59:WU02:FS00:0x15:Completed  21750000 out of 25000000 steps (87%).
16:42:28:WU02:FS00:0x15:Completed  22000000 out of 25000000 steps (88%).
16:44:58:WU02:FS00:0x15:Completed  22250000 out of 25000000 steps (89%).
16:47:27:WU02:FS00:0x15:Completed  22500000 out of 25000000 steps (90%).
16:49:57:WU02:FS00:0x15:Completed  22750000 out of 25000000 steps (91%).
16:51:46:WU00:FS01:0xa4:Completed 1350000 out of 1500000 steps  (90%)
16:52:26:WU02:FS00:0x15:Completed  23000000 out of 25000000 steps (92%).
16:54:56:WU02:FS00:0x15:Completed  23250000 out of 25000000 steps (93%).
16:57:26:WU02:FS00:0x15:Completed  23500000 out of 25000000 steps (94%).
16:59:55:WU02:FS00:0x15:Completed  23750000 out of 25000000 steps (95%).
*snipped*
e911
Post by e911 »
*continued from above*
17:02:25:WU02:FS00:0x15:Completed  24000000 out of 25000000 steps (96%).
17:04:11:WU00:FS01:0xa4:Completed 1365000 out of 1500000 steps  (91%)
17:04:55:WU02:FS00:0x15:Completed  24250000 out of 25000000 steps (97%).
17:07:24:WU02:FS00:0x15:Completed  24500000 out of 25000000 steps (98%).
17:09:54:WU02:FS00:0x15:Completed  24750000 out of 25000000 steps (99%).
17:09:55:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
17:09:55:WU01:FS00:News: Welcome to Folding@Home
17:09:55:WU01:FS00:Assigned to work server 171.67.108.142
17:09:55:WU01:FS00:Requesting new work unit for slot 00: RUNNING gpu:0:"GF110 [Geforce GTX 570 HD]" from 171.67.108.142
17:09:55:WU01:FS00:Connecting to 171.67.108.142:8080
17:09:56:WU01:FS00:Downloading 117.27KiB
17:09:56:WU01:FS00:Download complete
17:09:56:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:OK project:8034 run:1 clone:43 gen:11 core:0x15 unit:0x000000106953ee2e4f72dc498ee49e88
17:12:24:WU02:FS00:0x15:Completed  25000000 out of 25000000 steps (100%).
17:12:24:WU02:FS00:0x15:Finished fah_main status=0
17:12:24:WU02:FS00:0x15:Successful run
17:12:24:WU02:FS00:0x15:DynamicWrapper: Finished Work Unit: sleep=10000
17:12:34:WU02:FS00:0x15:Reserved 350964 bytes for xtc file; Cosm status=0
17:12:34:WU02:FS00:0x15:Allocated 350964 bytes for xtc file
17:12:34:WU02:FS00:0x15:- Reading up to 350964 from "02/wudata_01.xtc": Read 350964
17:12:34:WU02:FS00:0x15:Read 350964 bytes from xtc file; available packet space=786079500
17:12:34:WU02:FS00:0x15:xtc file hash check passed.
17:12:34:WU02:FS00:0x15:Reserved 43968 43968 786079500 bytes for arc file=<02/wudata_01.trr> Cosm status=0
17:12:34:WU02:FS00:0x15:Allocated 43968 bytes for arc file
17:12:34:WU02:FS00:0x15:- Reading up to 43968 from "02/wudata_01.trr": Read 43968
17:12:34:WU02:FS00:0x15:Read 43968 bytes from arc file; available packet space=786035532
17:12:34:WU02:FS00:0x15:trr file hash check passed.
17:12:34:WU02:FS00:0x15:Allocated 544 bytes for edr file
17:12:34:WU02:FS00:0x15:Read bedfile
17:12:34:WU02:FS00:0x15:edr file hash check passed.
17:12:34:WU02:FS00:0x15:Allocated 32583 bytes for logfile
17:12:34:WU02:FS00:0x15:Read logfile
17:12:34:WU02:FS00:0x15:GuardedRun: success in DynamicWrapper
17:12:34:WU02:FS00:0x15:GuardedRun: done
17:12:34:WU02:FS00:0x15:Run: GuardedRun completed.
17:12:35:WU02:FS00:0x15:+ Opened results file
17:12:35:WU02:FS00:0x15:- Writing 428571 bytes of core data to disk...
17:12:35:WU02:FS00:0x15:Done: 428059 -> 404659 (compressed to 94.5 percent)
17:12:35:WU02:FS00:0x15:  ... Done.
17:12:35:WU02:FS00:0x15:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
17:12:35:WU02:FS00:0x15:Shutting down core
17:12:35:WU02:FS00:0x15:Folding@home Core Shutdown: FINISHED_UNIT
17:12:35:WU02:FS00:FahCore returned: FINISHED_UNIT (100 = 0x64)
17:12:35:WU02:FS00:Sending unit results: id:02 state:SEND error:OK project:8034 run:8 clone:0 gen:38 core:0x15 unit:0x000000296953ee2e4f72de226aa1212a
17:12:35:WU02:FS00:Uploading 395.67KiB to 171.67.108.142
17:12:35:WU01:FS00:Starting
17:12:35:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED* *EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 01 -suffix 01 -version 701 -lifeline 1932 -checkpoint 5 -gpu 0
17:12:35:WU02:FS00:Connecting to 171.67.108.142:8080
17:12:35:WU01:FS00:Started FahCore on PID 3972
17:12:35:WU01:FS00:Core PID:4680
17:12:35:WU01:FS00:FahCore 0x15 started
17:12:36:WU01:FS00:0x15:
17:12:36:WU01:FS00:0x15:*------------------------------*
17:12:36:WU01:FS00:0x15:Folding@Home GPU Core
17:12:36:WU01:FS00:0x15:Version                2.22 (Thu Dec 8 17:08:05 PST 2011)
17:12:36:WU01:FS00:0x15:Build host             SimbiosNvdWin7
17:12:36:WU01:FS00:0x15:Board Type             NVIDIA/CUDA
17:12:36:WU01:FS00:0x15:Core                   15
17:12:36:WU01:FS00:0x15:Window's signal control handler registered.
17:12:36:WU01:FS00:0x15:Preparing to commence simulation
17:12:36:WU01:FS00:0x15:- Looking at optimizations...
17:12:36:WU01:FS00:0x15:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
17:12:36:WU01:FS00:0x15:- Created dyn
17:12:36:WU01:FS00:0x15:- Files status OK
17:12:36:WU01:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
17:12:36:WU01:FS00:0x15:- Expanded 119576 -> 542246 (decompressed 453.4 percent)
17:12:36:WU01:FS00:0x15:Called DecompressByteArray: compressed_data_size=119576 data_size=542246, decompressed_data_size=542246 diff=0
17:12:36:WU01:FS00:0x15:- Digital signature verified
17:12:36:WU01:FS00:0x15:Project: 8034 (Run 1, Clone 43, Gen 11)
17:12:36:WU01:FS00:0x15:Assembly optimizations on if available.
17:12:36:WU01:FS00:0x15:Entering M.D.
17:12:37:WU01:FS00:0x15:Tpr hash 01/wudata_01.tpr:  1640838670 3668853026 2337881775 1256426802 3390302441
17:12:37:WU01:FS00:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
17:12:37:WU01:FS00:0x15:Working on Protein
17:12:37:WU01:FS00:0x15:Client config unavailable.
17:12:38:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1 = 0xffffffff)
17:12:38:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
17:12:38:WU01:FS00:Starting
17:12:38:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED* *EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 01 -suffix 01 -version 701 -lifeline 1932 -checkpoint 5 -gpu 0
17:12:38:WU01:FS00:Started FahCore on PID 4168
17:12:38:WU01:FS00:Core PID:2864
17:12:38:WU01:FS00:FahCore 0x15 started
17:12:38:WU01:FS00:0x15:
17:12:38:WU01:FS00:0x15:*------------------------------*
17:12:38:WU01:FS00:0x15:Folding@Home GPU Core
17:12:38:WU01:FS00:0x15:Version                2.22 (Thu Dec 8 17:08:05 PST 2011)
17:12:38:WU01:FS00:0x15:Build host             SimbiosNvdWin7
17:12:38:WU01:FS00:0x15:Board Type             NVIDIA/CUDA
17:12:38:WU01:FS00:0x15:Core                   15
17:12:38:WU01:FS00:0x15:Window's signal control handler registered.
17:12:38:WU01:FS00:0x15:Preparing to commence simulation
17:12:38:WU01:FS00:0x15:- Ensuring status. Please wait.
17:12:39:WU02:FS00:Upload complete
17:12:39:WU02:FS00:Server responded WORK_ACK (400)
17:12:39:WU02:FS00:Final credit estimate, 3843.00 points
17:12:39:WU02:FS00:Cleaning up
17:12:48:WU01:FS00:0x15:- Looking at optimizations...
17:12:48:WU01:FS00:0x15:- Working with standard loops on this execution.
17:12:48:WU01:FS00:0x15:- Previous termination of core was improper.
17:12:48:WU01:FS00:0x15:- Files status OK
17:12:48:WU01:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
17:12:48:WU01:FS00:0x15:- Expanded 119576 -> 542246 (decompressed 453.4 percent)
17:12:48:WU01:FS00:0x15:Called DecompressByteArray: compressed_data_size=119576 data_size=542246, decompressed_data_size=542246 diff=0
17:12:48:WU01:FS00:0x15:- Digital signature verified
17:12:48:WU01:FS00:0x15:Project: 8034 (Run 1, Clone 43, Gen 11)
17:12:48:WU01:FS00:0x15:Entering M.D.
17:12:50:WU01:FS00:0x15:Tpr hash 01/wudata_01.tpr:  1640838670 3668853026 2337881775 1256426802 3390302441
17:12:50:WU01:FS00:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
17:12:50:WU01:FS00:0x15:Working on Protein
17:12:50:WU01:FS00:0x15:Client config unavailable.
17:12:50:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1 = 0xffffffff)
17:12:50:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
17:13:38:WU01:FS00:Starting
17:13:38:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED* *EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 01 -suffix 01 -version 701 -lifeline 1932 -checkpoint 5 -gpu 0
17:13:38:WU01:FS00:Started FahCore on PID 2572
17:13:38:WU01:FS00:Core PID:1964
17:13:38:WU01:FS00:FahCore 0x15 started
17:13:38:WU01:FS00:0x15:
17:13:38:WU01:FS00:0x15:*------------------------------*
17:13:38:WU01:FS00:0x15:Folding@Home GPU Core
17:13:38:WU01:FS00:0x15:Version                2.22 (Thu Dec 8 17:08:05 PST 2011)
17:13:38:WU01:FS00:0x15:Build host             SimbiosNvdWin7
17:13:38:WU01:FS00:0x15:Board Type             NVIDIA/CUDA
17:13:38:WU01:FS00:0x15:Core                   15
17:13:38:WU01:FS00:0x15:Window's signal control handler registered.
17:13:38:WU01:FS00:0x15:Preparing to commence simulation
17:13:38:WU01:FS00:0x15:- Ensuring status. Please wait.
17:13:48:WU01:FS00:0x15:- Looking at optimizations...
17:13:48:WU01:FS00:0x15:- Working with standard loops on this execution.
17:13:48:WU01:FS00:0x15:- Previous termination of core was improper.
17:13:48:WU01:FS00:0x15:- Going to use standard loops.
17:13:48:WU01:FS00:0x15:- Files status OK
17:13:48:WU01:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
17:13:48:WU01:FS00:0x15:- Expanded 119576 -> 542246 (decompressed 453.4 percent)
17:13:48:WU01:FS00:0x15:Called DecompressByteArray: compressed_data_size=119576 data_size=542246, decompressed_data_size=542246 diff=0
17:13:48:WU01:FS00:0x15:- Digital signature verified
17:13:48:WU01:FS00:0x15:Project: 8034 (Run 1, Clone 43, Gen 11)
17:13:48:WU01:FS00:0x15:Entering M.D.
17:13:50:WU01:FS00:0x15:Tpr hash 01/wudata_01.tpr:  1640838670 3668853026 2337881775 1256426802 3390302441
17:13:50:WU01:FS00:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
17:13:50:WU01:FS00:0x15:Working on Protein
17:13:50:WU01:FS00:0x15:Client config unavailable.
17:13:50:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1 = 0xffffffff)
17:13:50:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
17:15:15:WU01:FS00:Starting
17:15:15:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED* *EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 01 -suffix 01 -version 701 -lifeline 1932 -checkpoint 5 -gpu 0
17:15:15:WU01:FS00:Started FahCore on PID 3052
17:15:15:WU01:FS00:Core PID:4404
17:15:15:WU01:FS00:FahCore 0x15 started
17:15:15:WU01:FS00:0x15:
17:15:15:WU01:FS00:0x15:*------------------------------*
17:15:15:WU01:FS00:0x15:Folding@Home GPU Core
17:15:15:WU01:FS00:0x15:Version                2.22 (Thu Dec 8 17:08:05 PST 2011)
17:15:15:WU01:FS00:0x15:Build host             SimbiosNvdWin7
17:15:15:WU01:FS00:0x15:Board Type             NVIDIA/CUDA
17:15:15:WU01:FS00:0x15:Core                   15
17:15:15:WU01:FS00:0x15:Window's signal control handler registered.
17:15:15:WU01:FS00:0x15:Preparing to commence simulation
17:15:15:WU01:FS00:0x15:- Ensuring status. Please wait.
17:15:25:WU01:FS00:0x15:- Looking at optimizations...
17:15:25:WU01:FS00:0x15:- Working with standard loops on this execution.
17:15:25:WU01:FS00:0x15:- Previous termination of core was improper.
17:15:25:WU01:FS00:0x15:- Going to use standard loops.
17:15:25:WU01:FS00:0x15:- Files status OK
17:15:25:WU01:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
17:15:25:WU01:FS00:0x15:- Expanded 119576 -> 542246 (decompressed 453.4 percent)
17:15:25:WU01:FS00:0x15:Called DecompressByteArray: compressed_data_size=119576 data_size=542246, decompressed_data_size=542246 diff=0
17:15:25:WU01:FS00:0x15:- Digital signature verified
17:15:25:WU01:FS00:0x15:Project: 8034 (Run 1, Clone 43, Gen 11)
17:15:25:WU01:FS00:0x15:Entering M.D.
17:15:27:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1 = 0xffffffff)
17:15:27:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
17:16:40:WU00:FS01:0xa4:Completed 1380000 out of 1500000 steps  (92%)
17:17:52:WU01:FS00:Starting
17:17:52:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED* *EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 01 -suffix 01 -version 701 -lifeline 1932 -checkpoint 5 -gpu 0
17:17:52:WU01:FS00:Started FahCore on PID 3752
17:17:52:WU01:FS00:Core PID:3728
17:17:52:WU01:FS00:FahCore 0x15 started
17:17:53:WU01:FS00:0x15:
17:17:53:WU01:FS00:0x15:*------------------------------*
17:17:53:WU01:FS00:0x15:Folding@Home GPU Core
17:17:53:WU01:FS00:0x15:Version                2.22 (Thu Dec 8 17:08:05 PST 2011)
17:17:53:WU01:FS00:0x15:Build host             SimbiosNvdWin7
17:17:53:WU01:FS00:0x15:Board Type             NVIDIA/CUDA
17:17:53:WU01:FS00:0x15:Core                   15
17:17:53:WU01:FS00:0x15:Window's signal control handler registered.
17:17:53:WU01:FS00:0x15:Preparing to commence simulation
17:17:53:WU01:FS00:0x15:- Ensuring status. Please wait.
17:18:02:WU01:FS00:0x15:- Looking at optimizations...
17:18:02:WU01:FS00:0x15:- Working with standard loops on this execution.
17:18:02:WU01:FS00:0x15:- Previous termination of core was improper.
17:18:02:WU01:FS00:0x15:- Going to use standard loops.
17:18:02:WU01:FS00:0x15:- Files status OK
17:18:02:WU01:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
17:18:02:WU01:FS00:0x15:- Expanded 119576 -> 542246 (decompressed 453.4 percent)
17:18:02:WU01:FS00:0x15:Called DecompressByteArray: compressed_data_size=119576 data_size=542246, decompressed_data_size=542246 diff=0
17:18:02:WU01:FS00:0x15:- Digital signature verified
17:18:02:WU01:FS00:0x15:Project: 8034 (Run 1, Clone 43, Gen 11)
17:18:02:WU01:FS00:0x15:Entering M.D.
17:18:04:WU01:FS00:0x15:Tpr hash 01/wudata_01.tpr:  1640838670 3668853026 2337881775 1256426802 3390302441
17:18:04:WU01:FS00:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
17:18:04:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1 = 0xffffffff)
17:18:04:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
17:18:04:WARNING:WU01:FS00:Too many errors, failing
17:18:04:WU01:FS00:Sending unit results: id:01 state:SEND error:FAILED project:8034 run:1 clone:43 gen:11 core:0x15 unit:0x000000106953ee2e4f72dc498ee49e88
17:18:04:WU01:FS00:Connecting to 171.67.108.142:8080
17:18:05:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
17:18:05:WU01:FS00:Server responded WORK_QUIT (404)
17:18:05:WARNING:WU01:FS00:Server did not like results, dumping
17:18:05:WU01:FS00:Cleaning up
17:18:05:WU02:FS00:News: Welcome to Folding@Home
17:18:05:WU02:FS00:Assigned to work server 171.67.108.142
17:18:05:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"GF110 [Geforce GTX 570 HD]" from 171.67.108.142
17:18:05:WU02:FS00:Connecting to 171.67.108.142:8080
17:18:06:WU02:FS00:Downloading 117.58KiB
17:18:06:WU02:FS00:Download complete
17:18:06:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:OK project:8034 run:6 clone:105 gen:5 core:0x15 unit:0x000000096953ee2e4f72dda83b5d2580
17:18:06:WU02:FS00:Starting
17:18:06:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED* *EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 02 -suffix 01 -version 701 -lifeline 1932 -checkpoint 5 -gpu 0
17:18:06:WU02:FS00:Started FahCore on PID 2816
17:18:06:WU02:FS00:Core PID:4800
17:18:06:WU02:FS00:FahCore 0x15 started
17:18:07:WU02:FS00:0x15:
17:18:07:WU02:FS00:0x15:*------------------------------*
17:18:07:WU02:FS00:0x15:Folding@Home GPU Core
17:18:07:WU02:FS00:0x15:Version                2.22 (Thu Dec 8 17:08:05 PST 2011)
17:18:07:WU02:FS00:0x15:Build host             SimbiosNvdWin7
17:18:07:WU02:FS00:0x15:Board Type             NVIDIA/CUDA
17:18:07:WU02:FS00:0x15:Core                   15
17:18:07:WU02:FS00:0x15:Window's signal control handler registered.
17:18:07:WU02:FS00:0x15:Preparing to commence simulation
17:18:07:WU02:FS00:0x15:- Looking at optimizations...
17:18:07:WU02:FS00:0x15:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
17:18:07:WU02:FS00:0x15:- Created dyn
17:18:07:WU02:FS00:0x15:- Files status OK
17:18:07:WU02:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
17:18:07:WU02:FS00:0x15:- Expanded 119894 -> 542246 (decompressed 452.2 percent)
17:18:07:WU02:FS00:0x15:Called DecompressByteArray: compressed_data_size=119894 data_size=542246, decompressed_data_size=542246 diff=0
17:18:07:WU02:FS00:0x15:- Digital signature verified
17:18:07:WU02:FS00:0x15:Project: 8034 (Run 6, Clone 105, Gen 5)
17:18:07:WU02:FS00:0x15:Assembly optimizations on if available.
17:18:07:WU02:FS00:0x15:Entering M.D.
17:18:09:WU02:FS00:0x15:Tpr hash 02/wudata_01.tpr:  1576197434 3832933658 2122727470 89264158 4036828121
17:18:09:WU02:FS00:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
17:18:09:WU02:FS00:0x15:Working on Protein
17:18:09:WU02:FS00:0x15:Client config unavailable.
17:18:09:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1 = 0xffffffff)
17:18:09:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
17:18:09:WU02:FS00:Starting
17:18:09:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED* *EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 02 -suffix 01 -version 701 -lifeline 1932 -checkpoint 5 -gpu 0
17:18:09:WU02:FS00:Started FahCore on PID 4812
17:18:09:WU02:FS00:Core PID:4784
17:18:09:WU02:FS00:FahCore 0x15 started
17:18:10:WU02:FS00:0x15:
17:18:10:WU02:FS00:0x15:*------------------------------*
17:18:10:WU02:FS00:0x15:Folding@Home GPU Core
17:18:10:WU02:FS00:0x15:Version                2.22 (Thu Dec 8 17:08:05 PST 2011)
17:18:10:WU02:FS00:0x15:Build host             SimbiosNvdWin7
17:18:10:WU02:FS00:0x15:Board Type             NVIDIA/CUDA
17:18:10:WU02:FS00:0x15:Core                   15
17:18:10:WU02:FS00:0x15:Window's signal control handler registered.
17:18:10:WU02:FS00:0x15:Preparing to commence simulation
17:18:10:WU02:FS00:0x15:- Ensuring status. Please wait.
17:18:19:WU02:FS00:0x15:- Looking at optimizations...
17:18:19:WU02:FS00:0x15:- Working with standard loops on this execution.
17:18:19:WU02:FS00:0x15:- Previous termination of core was improper.
17:18:19:WU02:FS00:0x15:- Files status OK
17:18:19:WU02:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
17:18:19:WU02:FS00:0x15:- Expanded 119894 -> 542246 (decompressed 452.2 percent)
17:18:19:WU02:FS00:0x15:Called DecompressByteArray: compressed_data_size=119894 data_size=542246, decompressed_data_size=542246 diff=0
17:18:19:WU02:FS00:0x15:- Digital signature verified
17:18:19:WU02:FS00:0x15:Project: 8034 (Run 6, Clone 105, Gen 5)
17:18:19:WU02:FS00:0x15:Entering M.D.
17:18:21:WU02:FS00:0x15:Tpr hash 02/wudata_01.tpr:  1576197434 3832933658 2122727470 89264158 4036828121
17:18:21:WU02:FS00:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
17:18:21:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1 = 0xffffffff)
17:18:21:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
17:19:09:WU02:FS00:Starting
17:19:09:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED* *EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 02 -suffix 01 -version 701 -lifeline 1932 -checkpoint 5 -gpu 0
17:19:09:WU02:FS00:Started FahCore on PID 3316
17:19:09:WU02:FS00:Core PID:3120
17:19:09:WU02:FS00:FahCore 0x15 started
17:19:10:WU02:FS00:0x15:
17:19:10:WU02:FS00:0x15:*------------------------------*
17:19:10:WU02:FS00:0x15:Folding@Home GPU Core
17:19:10:WU02:FS00:0x15:Version                2.22 (Thu Dec 8 17:08:05 PST 2011)
17:19:10:WU02:FS00:0x15:Build host             SimbiosNvdWin7
17:19:10:WU02:FS00:0x15:Board Type             NVIDIA/CUDA
17:19:10:WU02:FS00:0x15:Core                   15
17:19:10:WU02:FS00:0x15:Window's signal control handler registered.
17:19:10:WU02:FS00:0x15:Preparing to commence simulation
17:19:10:WU02:FS00:0x15:- Ensuring status. Please wait.
17:19:19:WU02:FS00:0x15:- Looking at optimizations...
17:19:19:WU02:FS00:0x15:- Working with standard loops on this execution.
17:19:19:WU02:FS00:0x15:- Previous termination of core was improper.
17:19:19:WU02:FS00:0x15:- Going to use standard loops.
17:19:19:WU02:FS00:0x15:- Files status OK
17:19:19:WU02:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
17:19:19:WU02:FS00:0x15:- Expanded 119894 -> 542246 (decompressed 452.2 percent)
17:19:19:WU02:FS00:0x15:Called DecompressByteArray: compressed_data_size=119894 data_size=542246, decompressed_data_size=542246 diff=0
17:19:19:WU02:FS00:0x15:- Digital signature verified
17:19:19:WU02:FS00:0x15:Project: 8034 (Run 6, Clone 105, Gen 5)
17:19:19:WU02:FS00:0x15:Entering M.D.
17:19:21:WU02:FS00:0x15:Tpr hash 02/wudata_01.tpr:  1576197434 3832933658 2122727470 89264158 4036828121
17:19:21:WU02:FS00:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
17:19:21:WU02:FS00:0x15:Working on Protein
17:19:21:WU02:FS00:0x15:Client config unavailable.
17:19:21:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1 = 0xffffffff)
17:19:21:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
17:20:46:WU02:FS00:Starting
17:20:46:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED* *EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 02 -suffix 01 -version 701 -lifeline 1932 -checkpoint 5 -gpu 0
17:20:46:WU02:FS00:Started FahCore on PID 3548
17:20:46:WU02:FS00:Core PID:4516
17:20:46:WU02:FS00:FahCore 0x15 started
17:20:47:WU02:FS00:0x15:
17:20:47:WU02:FS00:0x15:*------------------------------*
17:20:47:WU02:FS00:0x15:Folding@Home GPU Core
17:20:47:WU02:FS00:0x15:Version                2.22 (Thu Dec 8 17:08:05 PST 2011)
17:20:47:WU02:FS00:0x15:Build host             SimbiosNvdWin7
17:20:47:WU02:FS00:0x15:Board Type             NVIDIA/CUDA
17:20:47:WU02:FS00:0x15:Core                   15
17:20:47:WU02:FS00:0x15:Window's signal control handler registered.
17:20:47:WU02:FS00:0x15:Preparing to commence simulation
17:20:47:WU02:FS00:0x15:- Ensuring status. Please wait.
17:20:56:WU02:FS00:0x15:- Looking at optimizations...
17:20:56:WU02:FS00:0x15:- Working with standard loops on this execution.
17:20:56:WU02:FS00:0x15:- Previous termination of core was improper.
17:20:56:WU02:FS00:0x15:- Going to use standard loops.
17:20:56:WU02:FS00:0x15:- Files status OK
17:20:56:WU02:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
17:20:56:WU02:FS00:0x15:- Expanded 119894 -> 542246 (decompressed 452.2 percent)
17:20:56:WU02:FS00:0x15:Called DecompressByteArray: compressed_data_size=119894 data_size=542246, decompressed_data_size=542246 diff=0
17:20:56:WU02:FS00:0x15:- Digital signature verified
17:20:56:WU02:FS00:0x15:Project: 8034 (Run 6, Clone 105, Gen 5)
17:20:56:WU02:FS00:0x15:Entering M.D.
17:20:58:WU02:FS00:0x15:Tpr hash 02/wudata_01.tpr:  1576197434 3832933658 2122727470 89264158 4036828121
17:20:58:WU02:FS00:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
17:20:58:WU02:FS00:0x15:Working on Protein
17:20:58:WU02:FS00:0x15:Client config unavailable.
17:20:58:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1 = 0xffffffff)
17:20:58:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
17:23:24:WU02:FS00:Starting
17:23:24:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED* *EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 02 -suffix 01 -version 701 -lifeline 1932 -checkpoint 5 -gpu 0
17:23:24:WU02:FS00:Started FahCore on PID 4616
17:23:24:WU02:FS00:Core PID:4196
17:23:24:WU02:FS00:FahCore 0x15 started
17:23:24:WU02:FS00:0x15:
17:23:24:WU02:FS00:0x15:*------------------------------*
17:23:24:WU02:FS00:0x15:Folding@Home GPU Core
17:23:24:WU02:FS00:0x15:Version                2.22 (Thu Dec 8 17:08:05 PST 2011)
17:23:24:WU02:FS00:0x15:Build host             SimbiosNvdWin7
17:23:24:WU02:FS00:0x15:Board Type             NVIDIA/CUDA
17:23:24:WU02:FS00:0x15:Core                   15
17:23:24:WU02:FS00:0x15:Window's signal control handler registered.
17:23:24:WU02:FS00:0x15:Preparing to commence simulation
17:23:24:WU02:FS00:0x15:- Ensuring status. Please wait.
17:23:33:WU02:FS00:0x15:- Looking at optimizations...
17:23:33:WU02:FS00:0x15:- Working with standard loops on this execution.
17:23:33:WU02:FS00:0x15:- Previous termination of core was improper.
17:23:33:WU02:FS00:0x15:- Going to use standard loops.
17:23:33:WU02:FS00:0x15:- Files status OK
17:23:33:WU02:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
17:23:33:WU02:FS00:0x15:- Expanded 119894 -> 542246 (decompressed 452.2 percent)
17:23:33:WU02:FS00:0x15:Called DecompressByteArray: compressed_data_size=119894 data_size=542246, decompressed_data_size=542246 diff=0
17:23:33:WU02:FS00:0x15:- Digital signature verified
17:23:33:WU02:FS00:0x15:Project: 8034 (Run 6, Clone 105, Gen 5)
17:23:33:WU02:FS00:0x15:Entering M.D.
17:23:35:WU02:FS00:0x15:Tpr hash 02/wudata_01.tpr:  1576197434 3832933658 2122727470 89264158 4036828121
17:23:35:WU02:FS00:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
17:23:36:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1 = 0xffffffff)
17:23:36:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
17:23:36:WARNING:WU02:FS00:Too many errors, failing
17:23:36:WU02:FS00:Sending unit results: id:02 state:SEND error:FAILED project:8034 run:6 clone:105 gen:5 core:0x15 unit:0x000000096953ee2e4f72dda83b5d2580
17:23:36:WU02:FS00:Connecting to 171.67.108.142:8080
17:23:36:WU02:FS00:Server responded WORK_QUIT (404)
17:23:36:WARNING:WU02:FS00:Server did not like results, dumping
17:23:36:WU02:FS00:Cleaning up
17:23:36:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
17:23:36:WU01:FS00:News: Welcome to Folding@Home
17:23:36:WU01:FS00:Assigned to work server 171.67.108.142
17:23:36:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"GF110 [Geforce GTX 570 HD]" from 171.67.108.142
17:23:36:WU01:FS00:Connecting to 171.67.108.142:8080
17:23:37:WU01:FS00:Downloading 117.65KiB
17:23:38:WU01:FS00:Download complete
17:23:38:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:OK project:8034 run:2 clone:9 gen:18 core:0x15 unit:0x000000146953ee2e4f72dc89a0a595ea
17:23:38:WU01:FS00:Starting
17:23:38:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED* *EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 01 -suffix 01 -version 701 -lifeline 1932 -checkpoint 5 -gpu 0
17:23:38:WU01:FS00:Started FahCore on PID 2020
17:23:38:WU01:FS00:Core PID:1132
17:23:38:WU01:FS00:FahCore 0x15 started
17:23:38:WU01:FS00:0x15:
17:23:38:WU01:FS00:0x15:*------------------------------*
17:23:38:WU01:FS00:0x15:Folding@Home GPU Core
17:23:38:WU01:FS00:0x15:Version                2.22 (Thu Dec 8 17:08:05 PST 2011)
17:23:38:WU01:FS00:0x15:Build host             SimbiosNvdWin7
17:23:38:WU01:FS00:0x15:Board Type             NVIDIA/CUDA
17:23:38:WU01:FS00:0x15:Core                   15
17:23:38:WU01:FS00:0x15:Window's signal control handler registered.
17:23:38:WU01:FS00:0x15:Preparing to commence simulation
17:23:38:WU01:FS00:0x15:- Looking at optimizations...
17:23:38:WU01:FS00:0x15:DeleteFrameFiles: successfully deleted file=01/wudata_01.ckp
17:23:38:WU01:FS00:0x15:- Created dyn
17:23:38:WU01:FS00:0x15:- Files status OK
17:23:38:WU01:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
17:23:38:WU01:FS00:0x15:- Expanded 119965 -> 542246 (decompressed 452.0 percent)
17:23:38:WU01:FS00:0x15:Called DecompressByteArray: compressed_data_size=119965 data_size=542246, decompressed_data_size=542246 diff=0
17:23:38:WU01:FS00:0x15:- Digital signature verified
17:23:38:WU01:FS00:0x15:Project: 8034 (Run 2, Clone 9, Gen 18)
17:23:38:WU01:FS00:0x15:Assembly optimizations on if available.
17:23:38:WU01:FS00:0x15:Entering M.D.
17:23:40:WU01:FS00:0x15:Tpr hash 01/wudata_01.tpr:  2051003952 1702952036 1707662212 3532447481 32763849
17:23:40:WU01:FS00:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
17:23:40:WU01:FS00:0x15:Working on Protein
17:23:40:WU01:FS00:0x15:Client config unavailable.
17:23:40:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1 = 0xffffffff)
17:23:40:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
17:23:40:WU01:FS00:Starting
17:23:40:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED* *EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 01 -suffix 01 -version 701 -lifeline 1932 -checkpoint 5 -gpu 0
17:23:40:WU01:FS00:Started FahCore on PID 1488
17:23:40:WU01:FS00:Core PID:3596
17:23:40:WU01:FS00:FahCore 0x15 started
17:23:41:WU01:FS00:0x15:
17:23:41:WU01:FS00:0x15:*------------------------------*
17:23:41:WU01:FS00:0x15:Folding@Home GPU Core
17:23:41:WU01:FS00:0x15:Version                2.22 (Thu Dec 8 17:08:05 PST 2011)
17:23:41:WU01:FS00:0x15:Build host             SimbiosNvdWin7
17:23:41:WU01:FS00:0x15:Board Type             NVIDIA/CUDA
17:23:41:WU01:FS00:0x15:Core                   15
17:23:41:WU01:FS00:0x15:Window's signal control handler registered.
17:23:41:WU01:FS00:0x15:Preparing to commence simulation
17:23:41:WU01:FS00:0x15:- Ensuring status. Please wait.
17:23:50:WU01:FS00:0x15:- Looking at optimizations...
17:23:50:WU01:FS00:0x15:- Working with standard loops on this execution.
17:23:50:WU01:FS00:0x15:- Previous termination of core was improper.
17:23:50:WU01:FS00:0x15:- Files status OK
17:23:50:WU01:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
17:23:50:WU01:FS00:0x15:- Expanded 119965 -> 542246 (decompressed 452.0 percent)
17:23:50:WU01:FS00:0x15:Called DecompressByteArray: compressed_data_size=119965 data_size=542246, decompressed_data_size=542246 diff=0
17:23:50:WU01:FS00:0x15:- Digital signature verified
17:23:50:WU01:FS00:0x15:Project: 8034 (Run 2, Clone 9, Gen 18)
17:23:50:WU01:FS00:0x15:Entering M.D.
17:23:52:WU01:FS00:0x15:Tpr hash 01/wudata_01.tpr:  2051003952 1702952036 1707662212 3532447481 32763849
17:23:52:WU01:FS00:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
17:23:52:WU01:FS00:0x15:Working on Protein
17:23:52:WU01:FS00:0x15:Client config unavailable.
17:23:52:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1 = 0xffffffff)
17:23:52:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
17:24:40:WU01:FS00:Starting
17:24:40:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED**EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 01 -suffix 01 -version 701 -lifeline 1932 -checkpoint 5 -gpu 0
17:24:40:WU01:FS00:Started FahCore on PID 1876
17:24:40:WU01:FS00:Core PID:1476
17:24:40:WU01:FS00:FahCore 0x15 started
17:24:41:WU01:FS00:0x15:
17:24:41:WU01:FS00:0x15:*------------------------------*
17:24:41:WU01:FS00:0x15:Folding@Home GPU Core
17:24:41:WU01:FS00:0x15:Version                2.22 (Thu Dec 8 17:08:05 PST 2011)
17:24:41:WU01:FS00:0x15:Build host             SimbiosNvdWin7
17:24:41:WU01:FS00:0x15:Board Type             NVIDIA/CUDA
17:24:41:WU01:FS00:0x15:Core                   15
17:24:41:WU01:FS00:0x15:Window's signal control handler registered.
17:24:41:WU01:FS00:0x15:Preparing to commence simulation
17:24:41:WU01:FS00:0x15:- Ensuring status. Please wait.
17:24:50:WU01:FS00:0x15:- Looking at optimizations...
17:24:50:WU01:FS00:0x15:- Working with standard loops on this execution.
17:24:50:WU01:FS00:0x15:- Previous termination of core was improper.
17:24:50:WU01:FS00:0x15:- Going to use standard loops.
17:24:50:WU01:FS00:0x15:- Files status OK
17:24:50:WU01:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
17:24:50:WU01:FS00:0x15:- Expanded 119965 -> 542246 (decompressed 452.0 percent)
17:24:50:WU01:FS00:0x15:Called DecompressByteArray: compressed_data_size=119965 data_size=542246, decompressed_data_size=542246 diff=0
17:24:50:WU01:FS00:0x15:- Digital signature verified
17:24:50:WU01:FS00:0x15:Project: 8034 (Run 2, Clone 9, Gen 18)
17:24:50:WU01:FS00:0x15:Entering M.D.
17:24:52:WU01:FS00:0x15:Tpr hash 01/wudata_01.tpr:  2051003952 1702952036 1707662212 3532447481 32763849
17:24:52:WU01:FS00:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
17:24:52:WU01:FS00:0x15:Working on Protein
17:24:52:WU01:FS00:0x15:Client config unavailable.
17:24:52:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1 = 0xffffffff)
17:24:52:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
17:26:18:WU01:FS00:Starting
17:26:18:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 01 -suffix 01 -version 701 -lifeline 1932 -checkpoint 5 -gpu 0
17:26:18:WU01:FS00:Started FahCore on PID 4652
17:26:18:WU01:FS00:Core PID:3696
17:26:18:WU01:FS00:FahCore 0x15 started
17:26:18:WU01:FS00:0x15:
17:26:18:WU01:FS00:0x15:*------------------------------*
17:26:18:WU01:FS00:0x15:Folding@Home GPU Core
17:26:18:WU01:FS00:0x15:Version                2.22 (Thu Dec 8 17:08:05 PST 2011)
17:26:18:WU01:FS00:0x15:Build host             SimbiosNvdWin7
17:26:18:WU01:FS00:0x15:Board Type             NVIDIA/CUDA
17:26:18:WU01:FS00:0x15:Core                   15
17:26:18:WU01:FS00:0x15:Window's signal control handler registered.
17:26:18:WU01:FS00:0x15:Preparing to commence simulation
17:26:18:WU01:FS00:0x15:- Ensuring status. Please wait.
17:26:27:WU01:FS00:0x15:- Looking at optimizations...
17:26:27:WU01:FS00:0x15:- Working with standard loops on this execution.
17:26:27:WU01:FS00:0x15:- Previous termination of core was improper.
17:26:27:WU01:FS00:0x15:- Going to use standard loops.
17:26:27:WU01:FS00:0x15:- Files status OK
17:26:27:WU01:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
17:26:27:WU01:FS00:0x15:- Expanded 119965 -> 542246 (decompressed 452.0 percent)
17:26:27:WU01:FS00:0x15:Called DecompressByteArray: compressed_data_size=119965 data_size=542246, decompressed_data_size=542246 diff=0
17:26:27:WU01:FS00:0x15:- Digital signature verified
17:26:27:WU01:FS00:0x15:Project: 8034 (Run 2, Clone 9, Gen 18)
17:26:27:WU01:FS00:0x15:Entering M.D.
17:26:29:WU01:FS00:0x15:Tpr hash 01/wudata_01.tpr:  2051003952 1702952036 1707662212 3532447481 32763849
17:26:29:WU01:FS00:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
17:26:29:WU01:FS00:0x15:Working on Protein
17:26:29:WU01:FS00:0x15:Client config unavailable.
17:26:30:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1 = 0xffffffff)
17:26:30:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
17:28:55:WU01:FS00:Starting
17:28:55:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 01 -suffix 01 -version 701 -lifeline 1932 -checkpoint 5 -gpu 0
17:28:55:WU01:FS00:Started FahCore on PID 2996
17:28:55:WU01:FS00:Core PID:3300
17:28:55:WU01:FS00:FahCore 0x15 started
17:28:55:WU01:FS00:0x15:
17:28:55:WU01:FS00:0x15:*------------------------------*
17:28:55:WU01:FS00:0x15:Folding@Home GPU Core
17:28:55:WU01:FS00:0x15:Version                2.22 (Thu Dec 8 17:08:05 PST 2011)
17:28:55:WU01:FS00:0x15:Build host             SimbiosNvdWin7
17:28:55:WU01:FS00:0x15:Board Type             NVIDIA/CUDA
17:28:55:WU01:FS00:0x15:Core                   15
17:28:55:WU01:FS00:0x15:Window's signal control handler registered.
17:28:55:WU01:FS00:0x15:Preparing to commence simulation
17:28:55:WU01:FS00:0x15:- Ensuring status. Please wait.
17:29:05:WU01:FS00:0x15:- Looking at optimizations...
17:29:05:WU01:FS00:0x15:- Working with standard loops on this execution.
17:29:05:WU01:FS00:0x15:- Previous termination of core was improper.
17:29:05:WU01:FS00:0x15:- Going to use standard loops.
17:29:05:WU01:FS00:0x15:- Files status OK
17:29:05:WU01:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
17:29:05:WU01:FS00:0x15:- Expanded 119965 -> 542246 (decompressed 452.0 percent)
17:29:05:WU01:FS00:0x15:Called DecompressByteArray: compressed_data_size=119965 data_size=542246, decompressed_data_size=542246 diff=0
17:29:05:WU01:FS00:0x15:- Digital signature verified
17:29:05:WU01:FS00:0x15:Project: 8034 (Run 2, Clone 9, Gen 18)
17:29:05:WU01:FS00:0x15:Entering M.D.
17:29:07:WU01:FS00:0x15:Tpr hash 01/wudata_01.tpr:  2051003952 1702952036 1707662212 3532447481 32763849
17:29:07:WU01:FS00:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
17:29:07:WU01:FS00:0x15:Working on Protein
17:29:07:WU01:FS00:0x15:Client config unavailable.
17:29:07:WU01:FS00:FahCore returned: UNKNOWN_ENUM (-1 = 0xffffffff)
17:29:07:WARNING:WU01:FS00:FahCore returned an unknown error code which probably indicates that it crashed
17:29:07:WARNING:WU01:FS00:Too many errors, failing
17:29:07:WU01:FS00:Sending unit results: id:01 state:SEND error:FAILED project:8034 run:2 clone:9 gen:18 core:0x15 unit:0x000000146953ee2e4f72dc89a0a595ea
17:29:07:WU01:FS00:Connecting to 171.67.108.142:8080
17:29:07:WU02:FS00:Connecting to assign-GPU.stanford.edu:80
17:29:07:WU01:FS00:Server responded WORK_QUIT (404)
17:29:07:WARNING:WU01:FS00:Server did not like results, dumping
17:29:07:WU01:FS00:Cleaning up
17:29:08:WU02:FS00:News: Welcome to Folding@Home
17:29:08:WU02:FS00:Assigned to work server 171.67.108.142
17:29:08:WU02:FS00:Requesting new work unit for slot 00: READY gpu:0:"GF110 [Geforce GTX 570 HD]" from 171.67.108.142
17:29:08:WU02:FS00:Connecting to 171.67.108.142:8080
17:29:08:WU02:FS00:Downloading 117.72KiB
17:29:09:WU02:FS00:Download complete
17:29:09:WU02:FS00:Received Unit: id:02 state:DOWNLOAD error:OK project:8034 run:9 clone:26 gen:20 core:0x15 unit:0x000000176953ee2e4f72de6a3da04834
17:29:09:WU02:FS00:Starting
17:29:09:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 02 -suffix 01 -version 701 -lifeline 1932 -checkpoint 5 -gpu 0
17:29:09:WU02:FS00:Started FahCore on PID 2308
17:29:09:WU02:FS00:Core PID:4104
17:29:09:WU02:FS00:FahCore 0x15 started
17:29:09:WU02:FS00:0x15:
17:29:09:WU02:FS00:0x15:*------------------------------*
17:29:09:WU02:FS00:0x15:Folding@Home GPU Core
17:29:09:WU02:FS00:0x15:Version                2.22 (Thu Dec 8 17:08:05 PST 2011)
17:29:09:WU02:FS00:0x15:Build host             SimbiosNvdWin7
17:29:09:WU02:FS00:0x15:Board Type             NVIDIA/CUDA
17:29:09:WU02:FS00:0x15:Core                   15
17:29:09:WU02:FS00:0x15:Window's signal control handler registered.
17:29:09:WU02:FS00:0x15:Preparing to commence simulation
17:29:09:WU02:FS00:0x15:- Looking at optimizations...
17:29:09:WU02:FS00:0x15:DeleteFrameFiles: successfully deleted file=02/wudata_01.ckp
17:29:09:WU02:FS00:0x15:- Created dyn
17:29:09:WU02:FS00:0x15:- Files status OK
17:29:09:WU02:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
17:29:09:WU02:FS00:0x15:- Expanded 120029 -> 542246 (decompressed 451.7 percent)
17:29:09:WU02:FS00:0x15:Called DecompressByteArray: compressed_data_size=120029 data_size=542246, decompressed_data_size=542246 diff=0
17:29:09:WU02:FS00:0x15:- Digital signature verified
17:29:09:WU02:FS00:0x15:Project: 8034 (Run 9, Clone 26, Gen 20)
17:29:09:WU02:FS00:0x15:Assembly optimizations on if available.
17:29:09:WU02:FS00:0x15:Entering M.D.
17:29:11:WU02:FS00:0x15:Tpr hash 02/wudata_01.tpr:  785461331 2832076605 2557835048 906713514 3048164590
17:29:11:WU02:FS00:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
17:29:11:WU02:FS00:0x15:Working on Protein
17:29:11:WU02:FS00:0x15:Client config unavailable.
17:29:11:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1 = 0xffffffff)
17:29:11:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
17:29:12:WU02:FS00:Starting
17:29:12:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 02 -suffix 01 -version 701 -lifeline 1932 -checkpoint 5 -gpu 0
17:29:12:WU02:FS00:Started FahCore on PID 5044
17:29:12:WU02:FS00:Core PID:2552
17:29:12:WU02:FS00:FahCore 0x15 started
17:29:12:WU02:FS00:0x15:
17:29:12:WU02:FS00:0x15:*------------------------------*
17:29:12:WU02:FS00:0x15:Folding@Home GPU Core
17:29:12:WU02:FS00:0x15:Version                2.22 (Thu Dec 8 17:08:05 PST 2011)
17:29:12:WU02:FS00:0x15:Build host             SimbiosNvdWin7
17:29:12:WU02:FS00:0x15:Board Type             NVIDIA/CUDA
17:29:12:WU02:FS00:0x15:Core                   15
17:29:12:WU02:FS00:0x15:Window's signal control handler registered.
17:29:12:WU02:FS00:0x15:Preparing to commence simulation
17:29:12:WU02:FS00:0x15:- Ensuring status. Please wait.
17:29:13:WU00:FS01:0xa4:Completed 1395000 out of 1500000 steps  (93%)
17:29:21:WU02:FS00:0x15:- Looking at optimizations...
17:29:21:WU02:FS00:0x15:- Working with standard loops on this execution.
17:29:21:WU02:FS00:0x15:- Previous termination of core was improper.
17:29:21:WU02:FS00:0x15:- Files status OK
17:29:21:WU02:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
17:29:21:WU02:FS00:0x15:- Expanded 120029 -> 542246 (decompressed 451.7 percent)
17:29:21:WU02:FS00:0x15:Called DecompressByteArray: compressed_data_size=120029 data_size=542246, decompressed_data_size=542246 diff=0
17:29:21:WU02:FS00:0x15:- Digital signature verified
17:29:21:WU02:FS00:0x15:Project: 8034 (Run 9, Clone 26, Gen 20)
17:29:21:WU02:FS00:0x15:Entering M.D.
17:29:23:WU02:FS00:0x15:Tpr hash 02/wudata_01.tpr:  785461331 2832076605 2557835048 906713514 3048164590
17:29:23:WU02:FS00:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
17:29:23:WU02:FS00:0x15:Working on Protein
17:29:23:WU02:FS00:0x15:Client config unavailable.
17:29:24:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1 = 0xffffffff)
17:29:24:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
17:30:12:WU02:FS00:Starting
17:30:12:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 02 -suffix 01 -version 701 -lifeline 1932 -checkpoint 5 -gpu 0
17:30:12:WU02:FS00:Started FahCore on PID 3668
17:30:12:WU02:FS00:Core PID:3932
17:30:12:WU02:FS00:FahCore 0x15 started
17:30:12:WU02:FS00:0x15:
17:30:12:WU02:FS00:0x15:*------------------------------*
17:30:12:WU02:FS00:0x15:Folding@Home GPU Core
17:30:12:WU02:FS00:0x15:Version                2.22 (Thu Dec 8 17:08:05 PST 2011)
17:30:12:WU02:FS00:0x15:Build host             SimbiosNvdWin7
17:30:12:WU02:FS00:0x15:Board Type             NVIDIA/CUDA
17:30:12:WU02:FS00:0x15:Core                   15
17:30:12:WU02:FS00:0x15:Window's signal control handler registered.
17:30:12:WU02:FS00:0x15:Preparing to commence simulation
17:30:12:WU02:FS00:0x15:- Ensuring status. Please wait.
17:30:21:WU02:FS00:0x15:- Looking at optimizations...
17:30:21:WU02:FS00:0x15:- Working with standard loops on this execution.
17:30:21:WU02:FS00:0x15:- Previous termination of core was improper.
17:30:21:WU02:FS00:0x15:- Going to use standard loops.
17:30:21:WU02:FS00:0x15:- Files status OK
17:30:21:WU02:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
17:30:21:WU02:FS00:0x15:- Expanded 120029 -> 542246 (decompressed 451.7 percent)
17:30:21:WU02:FS00:0x15:Called DecompressByteArray: compressed_data_size=120029 data_size=542246, decompressed_data_size=542246 diff=0
17:30:21:WU02:FS00:0x15:- Digital signature verified
17:30:21:WU02:FS00:0x15:Project: 8034 (Run 9, Clone 26, Gen 20)
17:30:21:WU02:FS00:0x15:Entering M.D.
17:30:23:WU02:FS00:0x15:Tpr hash 02/wudata_01.tpr:  785461331 2832076605 2557835048 906713514 3048164590
17:30:23:WU02:FS00:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
17:30:23:WU02:FS00:0x15:Working on Protein
17:30:23:WU02:FS00:0x15:Client config unavailable.
17:30:24:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1 = 0xffffffff)
17:30:24:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
17:31:49:WU02:FS00:Starting
17:31:49:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 02 -suffix 01 -version 701 -lifeline 1932 -checkpoint 5 -gpu 0
17:31:49:WU02:FS00:Started FahCore on PID 3960
17:31:49:WU02:FS00:Core PID:2000
17:31:49:WU02:FS00:FahCore 0x15 started
17:31:49:WU02:FS00:0x15:
17:31:49:WU02:FS00:0x15:*------------------------------*
17:31:49:WU02:FS00:0x15:Folding@Home GPU Core
17:31:49:WU02:FS00:0x15:Version                2.22 (Thu Dec 8 17:08:05 PST 2011)
17:31:49:WU02:FS00:0x15:Build host             SimbiosNvdWin7
17:31:49:WU02:FS00:0x15:Board Type             NVIDIA/CUDA
17:31:49:WU02:FS00:0x15:Core                   15
17:31:49:WU02:FS00:0x15:Window's signal control handler registered.
17:31:49:WU02:FS00:0x15:Preparing to commence simulation
17:31:49:WU02:FS00:0x15:- Ensuring status. Please wait.
17:31:59:WU02:FS00:0x15:- Looking at optimizations...
17:31:59:WU02:FS00:0x15:- Working with standard loops on this execution.
17:31:59:WU02:FS00:0x15:- Previous termination of core was improper.
17:31:59:WU02:FS00:0x15:- Going to use standard loops.
17:31:59:WU02:FS00:0x15:- Files status OK
17:31:59:WU02:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
17:31:59:WU02:FS00:0x15:- Expanded 120029 -> 542246 (decompressed 451.7 percent)
17:31:59:WU02:FS00:0x15:Called DecompressByteArray: compressed_data_size=120029 data_size=542246, decompressed_data_size=542246 diff=0
17:31:59:WU02:FS00:0x15:- Digital signature verified
17:31:59:WU02:FS00:0x15:Project: 8034 (Run 9, Clone 26, Gen 20)
17:31:59:WU02:FS00:0x15:Entering M.D.
17:32:01:WU02:FS00:0x15:Tpr hash 02/wudata_01.tpr:  785461331 2832076605 2557835048 906713514 3048164590
17:32:01:WU02:FS00:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
17:32:01:WU02:FS00:0x15:Working on Protein
17:32:01:WU02:FS00:0x15:Client config unavailable.
17:32:01:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1 = 0xffffffff)
17:32:01:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
17:34:26:WU02:FS00:Starting
17:34:26:WU02:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 02 -suffix 01 -version 701 -lifeline 1932 -checkpoint 5 -gpu 0
17:34:26:WU02:FS00:Started FahCore on PID 2516
17:34:26:WU02:FS00:Core PID:2864
17:34:26:WU02:FS00:FahCore 0x15 started
17:34:26:WU02:FS00:0x15:
17:34:26:WU02:FS00:0x15:*------------------------------*
17:34:26:WU02:FS00:0x15:Folding@Home GPU Core
17:34:26:WU02:FS00:0x15:Version                2.22 (Thu Dec 8 17:08:05 PST 2011)
17:34:26:WU02:FS00:0x15:Build host             SimbiosNvdWin7
17:34:26:WU02:FS00:0x15:Board Type             NVIDIA/CUDA
17:34:26:WU02:FS00:0x15:Core                   15
17:34:26:WU02:FS00:0x15:Window's signal control handler registered.
17:34:26:WU02:FS00:0x15:Preparing to commence simulation
17:34:26:WU02:FS00:0x15:- Ensuring status. Please wait.
17:34:36:WU02:FS00:0x15:- Looking at optimizations...
17:34:36:WU02:FS00:0x15:- Working with standard loops on this execution.
17:34:36:WU02:FS00:0x15:- Previous termination of core was improper.
17:34:36:WU02:FS00:0x15:- Going to use standard loops.
17:34:36:WU02:FS00:0x15:- Files status OK
17:34:36:WU02:FS00:0x15:sizeof(CORE_PACKET_HDR) = 512 file=<>
17:34:36:WU02:FS00:0x15:- Expanded 120029 -> 542246 (decompressed 451.7 percent)
17:34:36:WU02:FS00:0x15:Called DecompressByteArray: compressed_data_size=120029 data_size=542246, decompressed_data_size=542246 diff=0
17:34:36:WU02:FS00:0x15:- Digital signature verified
17:34:36:WU02:FS00:0x15:Project: 8034 (Run 9, Clone 26, Gen 20)
17:34:36:WU02:FS00:0x15:Entering M.D.
17:34:38:WU02:FS00:0x15:Tpr hash 02/wudata_01.tpr:  785461331 2832076605 2557835048 906713514 3048164590
17:34:38:WU02:FS00:0x15:GPU device info: vendor=0 device=0 name=<NA> match=0
17:34:38:WU02:FS00:0x15:Working on Protein
17:34:38:WU02:FS00:0x15:Client config unavailable.
17:34:38:WU02:FS00:FahCore returned: UNKNOWN_ENUM (-1 = 0xffffffff)
17:34:38:WARNING:WU02:FS00:FahCore returned an unknown error code which probably indicates that it crashed
17:34:38:WARNING:WU02:FS00:Too many errors, failing
17:34:38:WU02:FS00:Sending unit results: id:02 state:SEND error:FAILED project:8034 run:9 clone:26 gen:20 core:0x15 unit:0x000000176953ee2e4f72de6a3da04834
17:34:38:WU02:FS00:Connecting to 171.67.108.142:8080
17:34:38:WU01:FS00:Connecting to assign-GPU.stanford.edu:80
17:34:38:WU02:FS00:Server responded WORK_QUIT (404)
17:34:38:WARNING:WU02:FS00:Server did not like results, dumping
17:34:38:WU02:FS00:Cleaning up
17:34:38:WU01:FS00:News: Welcome to Folding@Home
17:34:38:WU01:FS00:Assigned to work server 171.67.108.142
17:34:38:WU01:FS00:Requesting new work unit for slot 00: READY gpu:0:"GF110 [Geforce GTX 570 HD]" from 171.67.108.142
17:34:38:WU01:FS00:Connecting to 171.67.108.142:8080
17:34:39:WU01:FS00:Downloading 117.64KiB
17:34:40:WU01:FS00:Download complete
17:34:40:WU01:FS00:Received Unit: id:01 state:DOWNLOAD error:OK project:8034 run:4 clone:121 gen:44 core:0x15 unit:0x0000002e6953ee2e4f72dd217aaceae6
17:34:40:WU01:FS00:Starting
17:34:40:WU01:FS00:Running FahCore: "C:\Program Files (x86)\FAHClient\CPU/FAHCoreWrapper.exe" "C:/Users/*EDITED*/AppData/Roaming/FAHClient/CPU/Data/cores/www.stanford.edu/~pande/Win32/AMD64/NVIDIA/Fermi/Core_15.fah/FahCore_15.exe" -dir 01 -suffix 01 -version 701 -lifeline 1932 -checkpoint 5 -gpu 0
17:34:40:WU01:FS00:Started FahCore on PID 4448
17:34:40:WU01:FS00:Core PID:4688
17:34:40:WU01:FS00:FahCore 0x15 started
17:34:40:WU01:FS00:0x15:
17:34:40:WU01:FS00:0x15:*------------------------------*
*snipped*
