i need program to gtx560 for folding
where can i download it ?
Re: i need program to gtx560 for folding
GPU clients are on the High Speed clients page : http://folding.stanford.edu/English/DownloadWinOther
You can also try the v7 unified client if you like : viewtopic.php?f=67&t=20978
Fahrenheit451
- Hardware configuration: System 1:
CPU: Intel Core 2 Duo E6850, 3000 MHz (9 x 333)
Mainboard: Gigabyte P35-DS3P v1.1
RAM: 2 GB (2x1024 MB DDR2 Dual-Channel, DRAM frequency 400 MHz)
OS: Windows Vista Ultimate, 32 bit, Service Pack 2
HD: Samsung HD501LJ (500 GB)
PSU: BeQuiet Straight Power E8 CM 580W
Case: CoolerMaster Cosmos 1000
GPU: NVIDIA GeForce 8800 GTS 512, XFX Pine Group
GFX driver version: 285.62
The card runs at stock speed: GPU 648 MHz, Memory 972 Mhz, Shader 1620 MHz
System 2:
CPU: Intel i7 2600 (Sandy Bridge) @ 3400 MHz (4C/8T)
Mainboard: Asus P8H67-M-Pro
RAM: 8GB (2x4 GB DDR3, 1333 MHz, Kingston)
OS: Windows 7 Ultimate, 64bit
HD: Samsung HD103SJ (1TB)
PSU: BeQuiet Straight Power E8 CM 580 W
Case: Corsair Obsidian 800D with H100 water cooling
GPU: i7 2600 IGP (not for folding) / Gigabyte GTX 560 Ti OC 1GB - Location: Bonn, Germany
If you want to fold with a gtx 560 and FAH client V7 (I didn't tested it with v6) you will need probably the old 285.62 WHQL driver from nvidia. Current drivers like it to crash
Current drivers have a problem with the power saving mode if it turns off the monitor. It crashes if used. Don't use it.
MtM
I saw this yesterday but didn't reply since I was really tired and afraid to make a stupid comment, but are you sure the problem with power saving is tied to V7 alone and not to V6? I am not sure either way but it's not logical to assume the fahcore's behave differently between the two clients so I'm leaning towards saying V6 has the same issues.Fahrenheit451 wrote:If you want to fold with a gtx 560 and FAH client V7 (I didn't tested it with v6) you will need probably the old 285.62 WHQL driver from nvidia. Current drivers like it to crash
I do agree that in lots of cases older driver are better then newer one's
It's a driver issue ... so you'll see similar behavior with v7, v6 or even BOINC clients.
