171.67.108.11 not accepting work units
HendricksSA
171.67.108.11 shows rejecting in the server stats page. I've not been able to send back completed work units for about an hour. Might need to check it out. Thanks.
Re: 171.67.108.11 not accepting work units
I don't doubt that you're having trouble uploading to it -- it does show a 14.57 CPU load -- but it's not showing REJECT at the moment.
Jesse_V
CPU: i7-6700k
GPU: GTX 970, GTX 1080 TI
It's having issues again.
19:44:27:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
19:44:28:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.11:80: No connection could be made because the target machine actively refused it.
19:44:30:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
19:44:31:ERROR:WU02:FS00:Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
Jesse_V
CPU: i7-6700k
The issue has been resolved I guess:
20:24:34:WU02:FS00:Sending unit results: id:02 state:SEND error:OK project:5771 run:6 clone:213 gen:1217 core:0x11 unit:0x786e071e4ff30cfa04c100d50006168b
20:24:34:WU02:FS00:Uploading 96.02KiB to 171.67.108.11
20:24:34:WU02:FS00:Connecting to 171.67.108.11:8080
20:24:35:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
20:24:35:WU02:FS00:Connecting to 171.67.108.11:80
20:24:36:WARNING:WU02:FS00:Exception: Failed to send results to work server: Failed to connect to 171.67.108.11:80: No connection could be made because the target machine actively refused it.
20:24:36:WU02:FS00:Trying to send results to collection server
20:24:36:WU02:FS00:Uploading 96.02KiB to 171.67.108.25
20:24:36:WU02:FS00:Connecting to 171.67.108.25:8080
20:24:38:WARNING:WU02:FS00:WorkServer connection failed on port 8080 trying 80
20:24:38:WU02:FS00:Connecting to 171.67.108.25:80
20:24:39:ERROR:WU02:FS00:Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
20:53:36:WU02:FS00:Sending unit results: id:02 state:SEND error:OK project:5771 run:6 clone:213 gen:1217 core:0x11 unit:0x786e071e4ff30cfa04c100d50006168b
20:53:36:WU02:FS00:Uploading 96.02KiB to 171.67.108.11
20:53:36:WU02:FS00:Connecting to 171.67.108.11:8080
20:53:37:WU02:FS00:Upload complete
20:53:37:WU02:FS00:Server responded WORK_ACK (400)
20:53:37:WU02:FS00:Cleaning up
