Getting the Most PPD out of my 40 Cores
stimpy_555
Post by stimpy_555 »
All,
Would like some help with configuration of the V7 Client with my team of servers I would like to put through their paces. They are all running Windows 2008 x64... I know Linux would be better at the task. I seem to have only been able to get an x86 version of the v7 Client to install as it installs to the x86 Program files area. So I have the following at my disposal for a few weeks;
2 of the following servers; (These register as only 20CPU's in the client)
4 x 10 Core Xeon e7-4870 2.4Ghz (40 Physical Cores, 80 Logical HT)
512GB Ram
1 of the following (This Registers as 32CPU's in the client)
2 x 10 Core Xeon e7-4870 2.4Ghz (40 Physical Cores, 80 Logical HT)
256Gb Ram
3 of the following (Registers as 24CPU's in the Client, which is right)
2 x Xeon x5680 3.33Ghz
64Gb Ram
So is anyone out there that can help me configure this to chew through the CPU's to give them a workout?
Thanks
bollix47
Re: Getting the Most PPD out of my 40 Cores
Post by bollix47 »
Personally, I would set all of them up for SMP and bigadv.
Add an SMP client and max out the # of cores/threads (80,40,24). (32 is just the default high but not the max)
For each client add an extra arg:
client-type
bigadv
btw the following line isn't adding up for me:
2 x 10 = 20 cores + HT = 40 threads
orion
Hardware configuration: 4p/4 MC ES @ 3.0GHz/32GB
4p/4x6128 @ 2.47GHz/32GB
2p/2 IL ES @ 2.7GHz/16GB
1p/8150/8GB
1p/1090T/4GB
Post by orion »
bollix47 wrote:btw the following line isn't adding up for me:
Since he is saying he has 2 (systems/servers) he's doubling up on the cores and HT's.
512GB Ram
iustus quia...
bollix47
Post by bollix47 »
I wasn't referring to those systems.
This one:
256Gb Ram
orion
1p/8150/8GB
1p/1090T/4GB
Post by orion »
bollix47 wrote:I wasn't referring to those systems.
This one:
256Gb Ram
My bad :oops:
Maybe a typo on his part.
iustus quia...
