129.64.95.82 Haven't been able to upload finished projects
jackamo
129.64.95.82:8080
Post by jackamo »
I am unable to receive any new WU's. A little history: Was running GPU NVIDIA for 9 months with no issues and then one day, no WU's. Installed Classic, same issue. Now running SMP, same issue. This has been going on for about 2 weeks. Here is my log.
Note: Please read the license agreement (FAH6.34-win32-SMP.exe -license). Further
use of this software requires that you have read and accepted this agreement.
6 cores detected
'mpiexec' is not recognized as an internal or external command,
operable program or batch file.
--- Opening Log file [November 3 19:43:42 UTC]
                       Folding@Home Client Version 6.34
                          http://folding.stanford.edu
Launch directory: C:\Users\Neil\FAH
Executable: C:\Users\Neil\FAH\FAH6.34-win32-SMP.exe
Arguments: -verbosity 9 -smp
[19:43:42] - Ask before connecting: No
[19:43:42] - User name: jackamo (Team 4)
[19:43:42] - User ID: 2505692E223B3665
[19:43:42] - Machine ID: 1
[19:43:42]
[19:43:42] Loaded queue successfully.
[19:43:42] - Preparing to get new work unit...
[19:43:42] - Autosending finished units... [November 3 19:43:42 UTC]
[19:43:42] Cleaning up work directory
[19:43:42] Trying to send all finished work units
[19:43:42] + Attempting to get work packet
[19:43:42] + No unsent completed units remaining.
[19:43:42] Passkey found
[19:43:42] - Autosend completed
[19:43:42] - Will indicate memory of 8183 MB
[19:43:42] - Detect CPU. Vendor: AuthenticAMD, Family: 15, Model: 10, Stepping:
0
[19:43:42] - Connecting to assignment server
[19:43:42] Connecting to http://assign.stanford.edu:8080/
[19:43:42] Posted data.
[19:43:42] Initial: 4081; - Successful: assigned to (129.64.95.82).
[19:43:42] + News From Folding@Home: Welcome to Folding@Home
[19:43:43] Loaded queue successfully.
[19:43:43] Sent data
[19:43:43] Connecting to http://129.64.95.82:8080/
[19:43:44] Posted data.
[19:43:44] Initial: 8B1F; - Error: Bad packet type from server, expected work as
signment
[19:43:44] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[19:43:53] + Attempting to get work packet
[19:43:53] Passkey found
[19:43:53] - Will indicate memory of 8183 MB
[19:43:53] - Connecting to assignment server
[19:43:53] Connecting to http://assign.stanford.edu:8080/
[19:43:54] Posted data.
[19:43:54] Initial: 4081; - Successful: assigned to (129.64.95.82).
[19:43:54] + News From Folding@Home: Welcome to Folding@Home
[19:43:54] Loaded queue successfully.
[19:43:54] Sent data
[19:43:54] Connecting to http://129.64.95.82:8080/
[19:43:55] Posted data.
[19:43:55] Initial: 8B1F; - Error: Bad packet type from server, expected work as
signment
[19:43:55] - Attempt #2  to get work failed, and no other work to do.
[19:44:17] + Attempting to get work packet
[19:44:17] Passkey found
[19:44:17] - Will indicate memory of 8183 MB
[19:44:17] - Connecting to assignment server
[19:44:17] Connecting to http://assign.stanford.edu:8080/
[19:44:17] Posted data.
[19:44:17] Initial: 4081; - Successful: assigned to (129.64.95.82).
[19:44:17] + News From Folding@Home: Welcome to Folding@Home
[19:44:18] Loaded queue successfully.
[19:44:18] Sent data
[19:44:18] Connecting to http://129.64.95.82:8080/
[19:44:19] Posted data.
[19:44:19] Initial: 8B1F; - Error: Bad packet type from server, expected work as
signment
Re: 129.64.95.82:8080
129.64.95.82 looks like a classic client server, but client got stuck trying to download from there when you switched to smp.
Stop client. Delete the work folder. Delete the queue.dat file. Start client.
Post if this works or not. May need one additional step.
jackamo
Post by jackamo »
No, this did work.
Stop client. Delete the work folder. Delete the queue.dat file. Delete unitinfo.txt file. Reconfigure client with a different Machine ID #. Start client.
jackamo
Post by jackamo »
I don't have a unitinfo.txt file. I deleted work folder and queue.dat file. Reconfigured for ID #2, restarted and nothing...same issue.
codysluder
Post by codysluder »
jackamo wrote:[19:43:43] Connecting to http://129.64.95.82:8080/
[19:43:44] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
Since you have tried different types of clients, you must have seen errors for more than one server. According to this log, you receive a "bad packet type" from server 129.64.95.82. Which other servers report errors somewhere in your logs? Are all of the errors a "bad packet type" or are there different errors reported?
jackamo
Post by jackamo »
No, I only get "bad packet type". Like I originally posted, the problem started while running GPU. I have since uninstalled and updated my Nvidia driver, now I can't run GPU. I had GPU running flawlessly for about 9 months. The error I kept getting was the same. Is there any way to hook to a different server, or is this server just down/bad? I am uncertain which server I was attached to while running GPU and classic, so I am unable to answer that specific question.
codysluder
So are you saying that you DID or DID NOT get a "bad packet type" from both a GPU server and a classic server?
I looked at the server status page and from eveything I see there, 129.64.95.82 seems to be issuing some WUs and receiving some results.
Did you install some proxy software or some new security software or install a new router about the time this started happening? Did you change Internet Service Providers about that time?
jackamo
Post by jackamo »
I only got a bad packet type from the SMP. The GPU and Classic, I got unable to download work unit.
NO to all of your other questions. There was no new software, router, or proxy. Same ISP. This problem just cropped up out of the blue.
I am now trying to access a different server: 171.64.65.55...having the same issues. What gives? About ready to quit and not run FAH.
gwildperson
Post by gwildperson »
When you were unable to download work units, how long did you wait? It sometimes takes 10 minutes for you to be redirected to another server.
To properly diagnose this problem we really need you to post your log showing the addresses of the servers that failed to provide assignments and when that happened and how long the condition persisted. We're trying to help but the question and answer process doesn't seem to be getting us anywhere.
Restart whichever client you really want to run. Leave it trying to get work for 15 or 20 minutes and then post the log. If you want to repeat that process with a different client, do that, too.
jackamo
Post by jackamo »
Well...here are 2 days of log:
Executable: C:\Users\Neil\FAH\fah6.exe
[23:59:38] - Ask before connecting: No
[23:59:38] - User name: jackamo (Team 4)
[23:59:38] - User ID: 2505692E223B3665
[23:59:38] - Machine ID: 1
[23:59:38]
[23:59:38] Loaded queue successfully.
[23:59:38] - Preparing to get new work unit...
[23:59:38] - Autosending finished units... [November 4 23:59:38 UTC]
[23:59:38] Cleaning up work directory
[23:59:38] Trying to send all finished work units
[23:59:38] + Attempting to get work packet
[23:59:38] + No unsent completed units remaining.
[23:59:38] Passkey found
[23:59:38] - Autosend completed
[23:59:38] - Will indicate memory of 8183 MB
[23:59:38] - Detect CPU. Vendor: AuthenticAMD, Family: 15, Model: 10, Stepping: 0
[23:59:38] - Connecting to assignment server
[23:59:38] Connecting to http://assign.stanford.edu:8080/
[23:59:39] Posted data.
[23:59:39] Initial: 4081; - Successful: assigned to (129.64.95.82).
[23:59:39] + News From Folding@Home: Welcome to Folding@Home
[23:59:39] Loaded queue successfully.
[23:59:39] Sent data
[23:59:39] Connecting to http://129.64.95.82:8080/
[23:59:40] Posted data.
[23:59:40] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[23:59:40] - Attempt #1  to get work failed, and no other work to do.
[23:59:50] + Attempting to get work packet
[00:00:27] Passkey found
[00:00:27] - Will indicate memory of 8183 MB
[00:00:27] - Connecting to assignment server
[00:00:27] Connecting to http://assign.stanford.edu:8080/
[00:00:27] Posted data.
[00:00:27] Initial: 4081; - Successful: assigned to (129.64.95.82).
[00:00:27] + News From Folding@Home: Welcome to Folding@Home
[00:00:27] Loaded queue successfully.
[00:00:27] Sent data
[00:00:27] Connecting to http://129.64.95.82:8080/
[00:00:29] Posted data.
[00:00:29] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[00:00:29] - Attempt #2  to get work failed, and no other work to do.
[00:00:44] + Attempting to get work packet
[00:00:44] Passkey found
[00:00:44] - Will indicate memory of 8183 MB
[00:00:44] - Connecting to assignment server
[00:00:44] Connecting to http://assign.stanford.edu:8080/
[00:00:45] Posted data.
[00:00:45] Initial: 4081; - Successful: assigned to (129.64.95.82).
[00:00:45] + News From Folding@Home: Welcome to Folding@Home
[00:00:45] Loaded queue successfully.
[00:00:45] Sent data
[00:00:45] Connecting to http://129.64.95.82:8080/
[00:00:46] Posted data.
[00:00:46] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[00:00:46] - Attempt #3  to get work failed, and no other work to do.
[00:01:08] + Attempting to get work packet
[00:01:08] Passkey found
[00:01:08] - Will indicate memory of 8183 MB
[00:01:08] - Connecting to assignment server
[00:01:08] Connecting to http://assign.stanford.edu:8080/
[00:01:08] Posted data.
[00:01:08] Initial: 4081; - Successful: assigned to (129.64.95.82).
[00:01:08] + News From Folding@Home: Welcome to Folding@Home
[00:01:08] Loaded queue successfully.
[00:01:08] Sent data
[00:01:08] Connecting to http://129.64.95.82:8080/
[00:01:09] Posted data.
[00:01:09] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[00:01:09] - Attempt #4  to get work failed, and no other work to do.
[00:01:51] + Attempting to get work packet
[00:01:51] Passkey found
[00:01:51] - Will indicate memory of 8183 MB
[00:01:51] - Connecting to assignment server
[00:01:51] Connecting to http://assign.stanford.edu:8080/
[00:01:51] Posted data.
[00:01:51] Initial: 4081; - Successful: assigned to (129.64.95.82).
[00:01:51] + News From Folding@Home: Welcome to Folding@Home
[00:01:52] Loaded queue successfully.
[00:01:52] Sent data
[00:01:52] Connecting to http://129.64.95.82:8080/
[00:01:53] Posted data.
[00:01:53] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[00:01:53] - Attempt #5  to get work failed, and no other work to do.
[00:03:25] + Attempting to get work packet
[00:03:25] Passkey found
[00:03:25] - Will indicate memory of 8183 MB
[00:03:25] - Connecting to assignment server
[00:03:25] Connecting to http://assign.stanford.edu:8080/
[00:03:26] Posted data.
[00:03:26] Initial: 40AB; - Successful: assigned to (171.64.65.55).
[00:03:26] + News From Folding@Home: Welcome to Folding@Home
[00:03:26] Loaded queue successfully.
[00:03:26] Sent data
[00:03:26] Connecting to http://171.64.65.55:8080/
[00:03:27] Posted data.
[00:03:27] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[00:03:27] - Attempt #6  to get work failed, and no other work to do.
[00:06:08] + Attempting to get work packet
[00:06:08] Passkey found
[00:06:08] - Will indicate memory of 8183 MB
[00:06:08] - Connecting to assignment server
[00:06:08] Connecting to http://assign.stanford.edu:8080/
[00:06:08] Posted data.
[00:06:08] Initial: 40AB; - Successful: assigned to (171.64.65.55).
[00:06:08] + News From Folding@Home: Welcome to Folding@Home
[00:06:09] Loaded queue successfully.
[00:06:09] Sent data
[00:06:09] Connecting to http://171.64.65.55:8080/
[00:06:10] Posted data.
[00:06:10] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[00:06:10] - Attempt #7  to get work failed, and no other work to do.
[00:11:39] + Attempting to get work packet
[00:11:39] Passkey found
[00:11:39] - Will indicate memory of 8183 MB
[00:11:39] - Connecting to assignment server
[00:11:39] Connecting to http://assign.stanford.edu:8080/
[00:11:39] Posted data.
[00:11:39] Initial: 40AB; - Successful: assigned to (171.64.65.55).
[00:11:39] + News From Folding@Home: Welcome to Folding@Home
[00:11:40] Loaded queue successfully.
[00:11:40] Sent data
[00:11:40] Connecting to http://171.64.65.55:8080/
[00:11:40] Posted data.
[00:11:40] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[00:11:40] - Attempt #8  to get work failed, and no other work to do.
[00:22:23] + Attempting to get work packet
[00:22:23] Passkey found
[00:22:23] - Will indicate memory of 8183 MB
[00:22:23] - Connecting to assignment server
[00:22:23] Connecting to http://assign.stanford.edu:8080/
[00:22:23] Posted data.
[00:22:23] Initial: 40AB; - Successful: assigned to (171.64.65.75).
[00:22:23] + News From Folding@Home: Welcome to Folding@Home
[00:22:24] Loaded queue successfully.
[00:22:24] Sent data
[00:22:24] Connecting to http://171.64.65.75:8080/
[00:22:25] Posted data.
[00:22:25] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[00:22:25] - Attempt #9  to get work failed, and no other work to do.
[00:43:48] + Attempting to get work packet
[00:43:48] Passkey found
[00:43:48] - Will indicate memory of 8183 MB
[00:43:48] - Connecting to assignment server
[00:43:48] Connecting to http://assign.stanford.edu:8080/
[00:43:49] Posted data.
[00:43:49] Initial: 40AB; - Successful: assigned to (171.64.65.55).
[00:43:49] + News From Folding@Home: Welcome to Folding@Home
[00:43:49] Loaded queue successfully.
[00:43:49] Sent data
[00:43:49] Connecting to http://171.64.65.55:8080/
[00:43:50] Posted data.
[00:43:50] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[00:43:50] - Attempt #10  to get work failed, and no other work to do.
[01:26:35] + Attempting to get work packet
[01:26:35] Passkey found
[01:26:35] - Will indicate memory of 8183 MB
[01:26:35] - Connecting to assignment server
[01:26:35] Connecting to http://assign.stanford.edu:8080/
[01:26:35] Posted data.
[01:26:35] Initial: 4081; - Successful: assigned to (129.64.95.82).
[01:26:35] + News From Folding@Home: Welcome to Folding@Home
[01:26:35] Loaded queue successfully.
[01:26:35] Sent data
[01:26:35] Connecting to http://129.64.95.82:8080/
[01:26:36] Posted data.
[01:26:36] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[01:26:36] - Attempt #11  to get work failed, and no other work to do.
[02:14:48] + Attempting to get work packet
[02:14:48] Passkey found
[02:14:48] - Will indicate memory of 8183 MB
[02:14:48] - Connecting to assignment server
[02:14:48] Connecting to http://assign.stanford.edu:8080/
[02:14:49] Posted data.
[02:14:49] Initial: 4081; - Successful: assigned to (129.64.95.82).
[02:14:49] + News From Folding@Home: Welcome to Folding@Home
[02:14:49] Loaded queue successfully.
[02:14:49] Sent data
[02:14:49] Connecting to http://129.64.95.82:8080/
[02:14:50] Posted data.
[02:14:50] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[02:14:50] - Attempt #12  to get work failed, and no other work to do.
[03:02:53] + Attempting to get work packet
[03:02:53] Passkey found
[03:02:53] - Will indicate memory of 8183 MB
[03:02:53] - Connecting to assignment server
[03:02:53] Connecting to http://assign.stanford.edu:8080/
[03:02:54] Posted data.
[03:02:54] Initial: 40AB; - Successful: assigned to (171.64.65.55).
[03:02:54] + News From Folding@Home: Welcome to Folding@Home
[03:02:54] Loaded queue successfully.
[03:02:54] Sent data
[03:02:54] Connecting to http://171.64.65.55:8080/
[03:02:55] Posted data.
[03:02:55] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[03:02:55] - Attempt #13  to get work failed, and no other work to do.
[03:51:04] + Attempting to get work packet
[03:51:04] Passkey found
[03:51:04] - Will indicate memory of 8183 MB
[03:51:04] - Connecting to assignment server
[03:51:04] Connecting to http://assign.stanford.edu:8080/
[03:51:04] Posted data.
[03:51:04] Initial: 4081; - Successful: assigned to (129.64.95.82).
[03:51:04] + News From Folding@Home: Welcome to Folding@Home
[03:51:05] Loaded queue successfully.
[03:51:05] Sent data
[03:51:05] Connecting to http://129.64.95.82:8080/
[03:51:06] Posted data.
[03:51:06] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[03:51:06] - Attempt #14  to get work failed, and no other work to do.
[04:39:18] + Attempting to get work packet
[04:39:18] Passkey found
[04:39:18] - Will indicate memory of 8183 MB
[04:39:18] - Connecting to assignment server
[04:39:18] Connecting to http://assign.stanford.edu:8080/
[04:39:18] Posted data.
[04:39:18] Initial: 4081; - Successful: assigned to (129.64.95.82).
[04:39:18] + News From Folding@Home: Welcome to Folding@Home
[04:39:19] Loaded queue successfully.
[04:39:19] Sent data
[04:39:19] Connecting to http://129.64.95.82:8080/
[04:39:20] Posted data.
[04:39:20] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[04:39:20] - Attempt #15  to get work failed, and no other work to do.
[05:27:21] + Attempting to get work packet
[05:27:21] Passkey found
[05:27:21] - Will indicate memory of 8183 MB
[05:27:21] - Connecting to assignment server
[05:27:21] Connecting to http://assign.stanford.edu:8080/
[05:27:21] Posted data.
[05:27:21] Initial: 4081; - Successful: assigned to (129.64.95.82).
[05:27:21] + News From Folding@Home: Welcome to Folding@Home
[05:27:22] Loaded queue successfully.
[05:27:22] Sent data
[05:27:22] Connecting to http://129.64.95.82:8080/
[05:27:23] Posted data.
[05:27:23] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[05:27:23] - Attempt #16  to get work failed, and no other work to do.
[05:59:38] - Autosending finished units... [November 5 05:59:38 UTC]
[05:59:38] Trying to send all finished work units
[05:59:38] + No unsent completed units remaining.
[05:59:38] - Autosend completed
[06:15:26] + Attempting to get work packet
[06:15:26] Passkey found
[06:15:26] - Will indicate memory of 8183 MB
[06:15:26] - Connecting to assignment server
[06:15:26] Connecting to http://assign.stanford.edu:8080/
[06:15:26] Posted data.
[06:15:26] Initial: 40AB; - Successful: assigned to (171.64.65.55).
[06:15:26] + News From Folding@Home: Welcome to Folding@Home
[06:15:27] Loaded queue successfully.
[06:15:27] Sent data
[06:15:27] Connecting to http://171.64.65.55:8080/
[06:15:27] Posted data.
[06:15:27] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[06:15:27] - Attempt #17  to get work failed, and no other work to do.
[07:03:32] + Attempting to get work packet
[07:03:32] Passkey found
[07:03:32] - Will indicate memory of 8183 MB
[07:03:32] - Connecting to assignment server
[07:03:32] Connecting to http://assign.stanford.edu:8080/
[07:03:33] Posted data.
[07:03:33] Initial: 4081; - Successful: assigned to (129.64.95.82).
[07:03:33] + News From Folding@Home: Welcome to Folding@Home
[07:03:33] Loaded queue successfully.
[07:03:33] Sent data
[07:03:33] Connecting to http://129.64.95.82:8080/
[07:03:34] Posted data.
[07:03:34] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[07:03:34] - Attempt #18  to get work failed, and no other work to do.
[07:51:48] + Attempting to get work packet
[07:51:48] Passkey found
[07:51:48] - Will indicate memory of 8183 MB
[07:51:48] - Connecting to assignment server
[07:51:48] Connecting to http://assign.stanford.edu:8080/
[07:51:49] Posted data.
[07:51:49] Initial: 40AB; - Successful: assigned to (171.64.65.55).
[07:51:49] + News From Folding@Home: Welcome to Folding@Home
[07:51:49] Loaded queue successfully.
[07:51:49] Sent data
[07:51:49] Connecting to http://171.64.65.55:8080/
[07:51:50] Posted data.
[07:51:50] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[07:51:50] - Attempt #19  to get work failed, and no other work to do.
[08:40:04] + Attempting to get work packet
[08:40:04] Passkey found
[08:40:04] - Will indicate memory of 8183 MB
[08:40:04] - Connecting to assignment server
[08:40:04] Connecting to http://assign.stanford.edu:8080/
[08:40:04] Posted data.
[08:40:04] Initial: 40AB; - Successful: assigned to (171.64.65.55).
[08:40:04] + News From Folding@Home: Welcome to Folding@Home
[08:40:05] Loaded queue successfully.
[08:40:05] Sent data
[08:40:05] Connecting to http://171.64.65.55:8080/
[08:40:06] Posted data.
[08:40:06] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[08:40:06] - Attempt #20  to get work failed, and no other work to do.
[09:28:07] + Attempting to get work packet
[09:28:07] Passkey found
[09:28:07] - Will indicate memory of 8183 MB
[09:28:07] - Connecting to assignment server
[09:28:07] Connecting to http://assign.stanford.edu:8080/
[09:28:07] Posted data.
[09:28:07] Initial: 40AB; - Successful: assigned to (171.64.65.55).
[09:28:07] + News From Folding@Home: Welcome to Folding@Home
[09:28:08] Loaded queue successfully.
[09:28:08] Sent data
[09:28:08] Connecting to http://171.64.65.55:8080/
[09:28:08] Posted data.
[09:28:08] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[09:28:08] - Attempt #21  to get work failed, and no other work to do.
[10:16:15] + Attempting to get work packet
[10:16:15] Passkey found
[10:16:15] - Will indicate memory of 8183 MB
[10:16:15] - Connecting to assignment server
[10:16:15] Connecting to http://assign.stanford.edu:8080/
[10:16:16] Posted data.
[10:16:16] Initial: 4081; - Successful: assigned to (129.64.95.82).
[10:16:16] + News From Folding@Home: Welcome to Folding@Home
[10:16:16] Loaded queue successfully.
[10:16:16] Sent data
[10:16:16] Connecting to http://129.64.95.82:8080/
[10:16:17] Posted data.
[10:16:17] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[10:16:17] - Attempt #22  to get work failed, and no other work to do.
[11:04:25] + Attempting to get work packet
[11:04:25] Passkey found
[11:04:25] - Will indicate memory of 8183 MB
[11:04:25] - Connecting to assignment server
[11:04:25] Connecting to http://assign.stanford.edu:8080/
[11:04:25] Posted data.
[11:04:25] Initial: 4081; - Successful: assigned to (129.64.95.82).
[11:04:25] + News From Folding@Home: Welcome to Folding@Home
[11:04:26] Loaded queue successfully.
[11:04:26] Sent data
[11:04:26] Connecting to http://129.64.95.82:8080/
[11:04:27] Posted data.
[11:04:27] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[11:04:27] - Attempt #23  to get work failed, and no other work to do.
[11:52:34] + Attempting to get work packet
[11:52:34] Passkey found
[11:52:34] - Will indicate memory of 8183 MB
[11:52:34] - Connecting to assignment server
[11:52:34] Connecting to http://assign.stanford.edu:8080/
[11:52:34] Posted data.
[11:52:34] Initial: 4081; - Successful: assigned to (129.64.95.82).
[11:52:34] + News From Folding@Home: Welcome to Folding@Home
[11:52:35] Loaded queue successfully.
[11:52:35] Sent data
[11:52:35] Connecting to http://129.64.95.82:8080/
[11:52:36] Posted data.
[11:52:36] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[11:52:36] - Attempt #24  to get work failed, and no other work to do.
[11:59:38] - Autosending finished units... [November 5 11:59:38 UTC]
[11:59:38] Trying to send all finished work units
[11:59:38] + No unsent completed units remaining.
[11:59:38] - Autosend completed
[12:40:50] + Attempting to get work packet
[12:40:50] Passkey found
[12:40:50] - Will indicate memory of 8183 MB
[12:40:50] - Connecting to assignment server
[12:40:50] Connecting to http://assign.stanford.edu:8080/
[12:40:50] Posted data.
[12:40:50] Initial: 4081; - Successful: assigned to (129.64.95.82).
[12:40:50] + News From Folding@Home: Welcome to Folding@Home
[12:40:50] Loaded queue successfully.
[12:40:50] Sent data
[12:40:50] Connecting to http://129.64.95.82:8080/
[12:40:51] Posted data.
[12:40:51] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[12:40:51] - Attempt #25  to get work failed, and no other work to do.
[13:29:04] + Attempting to get work packet
[13:29:04] Passkey found
[13:29:04] - Will indicate memory of 8183 MB
[13:29:04] - Connecting to assignment server
[13:29:04] Connecting to http://assign.stanford.edu:8080/
[13:29:04] Posted data.
[13:29:04] Initial: 4081; - Successful: assigned to (129.64.95.82).
[13:29:04] + News From Folding@Home: Welcome to Folding@Home
[13:29:04] Loaded queue successfully.
[13:29:04] Sent data
[13:29:04] Connecting to http://129.64.95.82:8080/
[13:29:05] Posted data.
[13:29:05] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[13:29:05] - Attempt #26  to get work failed, and no other work to do.
[14:17:18] + Attempting to get work packet
[14:17:18] Passkey found
[14:17:18] - Will indicate memory of 8183 MB
[14:17:18] - Connecting to assignment server
[14:17:18] Connecting to http://assign.stanford.edu:8080/
[14:17:19] Posted data.
[14:17:19] Initial: 4081; - Successful: assigned to (129.64.95.82).
[14:17:19] + News From Folding@Home: Welcome to Folding@Home
[14:17:19] Loaded queue successfully.
[14:17:19] Sent data
[14:17:19] Connecting to http://129.64.95.82:8080/
[14:17:20] Posted data.
[14:17:20] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[14:17:20] - Attempt #27  to get work failed, and no other work to do.
[15:05:25] + Attempting to get work packet
[15:05:25] Passkey found
[15:05:25] - Will indicate memory of 8183 MB
[15:05:25] - Connecting to assignment server
[15:05:25] Connecting to http://assign.stanford.edu:8080/
[15:05:26] Posted data.
[15:05:26] Initial: 4081; - Successful: assigned to (129.64.95.82).
[15:05:26] + News From Folding@Home: Welcome to Folding@Home
[15:05:26] Loaded queue successfully.
[15:05:26] Sent data
[15:05:26] Connecting to http://129.64.95.82:8080/
[15:05:27] Posted data.
[15:05:27] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[15:05:27] - Attempt #28  to get work failed, and no other work to do.
[15:53:27] + Attempting to get work packet
[15:53:27] Passkey found
[15:53:27] - Will indicate memory of 8183 MB
[15:53:27] - Connecting to assignment server
[15:53:27] Connecting to http://assign.stanford.edu:8080/
[15:53:28] Posted data.
[15:53:28] Initial: 4081; - Successful: assigned to (129.64.95.82).
[15:53:28] + News From Folding@Home: Welcome to Folding@Home
[15:53:28] Loaded queue successfully.
[15:53:28] Sent data
[15:53:28] Connecting to http://129.64.95.82:8080/
[15:53:29] Posted data.
[15:53:29] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[15:53:29] - Attempt #29  to get work failed, and no other work to do.
[16:41:40] + Attempting to get work packet
[16:41:40] Passkey found
[16:41:40] - Will indicate memory of 8183 MB
[16:41:40] - Connecting to assignment server
[16:41:40] Connecting to http://assign.stanford.edu:8080/
[16:41:40] Posted data.
[16:41:40] Initial: 40AB; - Successful: assigned to (171.64.65.55).
[16:41:40] + News From Folding@Home: Welcome to Folding@Home
[16:41:40] Loaded queue successfully.
[16:41:40] Sent data
[16:41:40] Connecting to http://171.64.65.55:8080/
[16:41:41] Posted data.
[16:41:41] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[16:41:41] - Attempt #30  to get work failed, and no other work to do.
[17:29:56] + Attempting to get work packet
[17:29:56] Passkey found
[17:29:56] - Will indicate memory of 8183 MB
[17:29:56] - Connecting to assignment server
[17:29:56] Connecting to http://assign.stanford.edu:8080/
[17:29:56] Posted data.
[17:29:56] Initial: 4081; - Successful: assigned to (129.64.95.82).
[17:29:56] + News From Folding@Home: Welcome to Folding@Home
[17:29:56] Loaded queue successfully.
[17:29:56] Sent data
[17:29:56] Connecting to http://129.64.95.82:8080/
[17:29:57] Posted data.
[17:29:57] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[17:29:57] - Attempt #31  to get work failed, and no other work to do.
[17:59:38] - Autosending finished units... [November 5 17:59:38 UTC]
[17:59:38] Trying to send all finished work units
[17:59:38] + No unsent completed units remaining.
[17:59:38] - Autosend completed
[18:17:58] + Attempting to get work packet
[18:17:58] Passkey found
[18:17:58] - Will indicate memory of 8183 MB
[18:17:58] - Connecting to assignment server
[18:17:58] Connecting to http://assign.stanford.edu:8080/
[18:17:59] Posted data.
[18:17:59] Initial: 4081; - Successful: assigned to (129.64.95.82).
[18:17:59] + News From Folding@Home: Welcome to Folding@Home
[18:17:59] Loaded queue successfully.
[18:17:59] Sent data
[18:17:59] Connecting to http://129.64.95.82:8080/
[18:18:00] Posted data.
[18:18:00] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[18:18:00] - Attempt #32  to get work failed, and no other work to do.
[19:06:03] + Attempting to get work packet
[19:06:03] Passkey found
[19:06:03] - Will indicate memory of 8183 MB
[19:06:03] - Connecting to assignment server
[19:06:03] Connecting to http://assign.stanford.edu:8080/
[19:06:04] Posted data.
[19:06:04] Initial: 4081; - Successful: assigned to (129.64.95.82).
[19:06:04] + News From Folding@Home: Welcome to Folding@Home
[19:06:04] Loaded queue successfully.
[19:06:04] Sent data
[19:06:04] Connecting to http://129.64.95.82:8080/
[19:06:05] Posted data.
[19:06:05] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[19:06:05] - Attempt #33  to get work failed, and no other work to do.
[19:54:14] + Attempting to get work packet
[19:54:14] Passkey found
[19:54:14] - Will indicate memory of 8183 MB
[19:54:14] - Connecting to assignment server
[19:54:14] Connecting to http://assign.stanford.edu:8080/
[19:54:14] Posted data.
[19:54:14] Initial: 4081; - Successful: assigned to (129.64.95.82).
[19:54:14] + News From Folding@Home: Welcome to Folding@Home
[19:54:14] Loaded queue successfully.
[19:54:14] Sent data
[19:54:14] Connecting to http://129.64.95.82:8080/
[19:54:15] Posted data.
[19:54:15] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[19:54:15] - Attempt #34  to get work failed, and no other work to do.
[20:42:17] + Attempting to get work packet
[20:42:17] Passkey found
[20:42:17] - Will indicate memory of 8183 MB
[20:42:17] - Connecting to assignment server
[20:42:17] Connecting to http://assign.stanford.edu:8080/
[20:42:18] Posted data.
[20:42:18] Initial: 4081; - Successful: assigned to (129.64.95.82).
[20:42:18] + News From Folding@Home: Welcome to Folding@Home
[20:42:18] Loaded queue successfully.
[20:42:18] Sent data
[20:42:18] Connecting to http://129.64.95.82:8080/
[20:42:19] Posted data.
[20:42:19] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[20:42:19] - Attempt #35  to get work failed, and no other work to do.
[21:30:23] + Attempting to get work packet
[21:30:23] Passkey found
[21:30:23] - Will indicate memory of 8183 MB
[21:30:23] - Connecting to assignment server
[21:30:23] Connecting to http://assign.stanford.edu:8080/
[21:30:24] Posted data.
[21:30:24] Initial: 40AB; - Successful: assigned to (171.64.65.55).
[21:30:24] + News From Folding@Home: Welcome to Folding@Home
[21:30:24] Loaded queue successfully.
[21:30:24] Sent data
[21:30:24] Connecting to http://171.64.65.55:8080/
[21:30:25] Posted data.
[21:30:25] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[21:30:25] - Attempt #36  to get work failed, and no other work to do.
[22:18:34] + Attempting to get work packet
[22:18:34] Passkey found
[22:18:34] - Will indicate memory of 8183 MB
[22:18:34] - Connecting to assignment server
[22:18:34] Connecting to http://assign.stanford.edu:8080/
[22:18:34] Posted data.
[22:18:34] Initial: 40AB; - Successful: assigned to (171.64.65.55).
[22:18:34] + News From Folding@Home: Welcome to Folding@Home
[22:18:34] Loaded queue successfully.
[22:18:34] Sent data
[22:18:34] Connecting to http://171.64.65.55:8080/
[22:18:35] Posted data.
[22:18:35] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[22:18:35] - Attempt #37  to get work failed, and no other work to do.
[23:06:41] + Attempting to get work packet
[23:06:41] Passkey found
[23:06:41] - Will indicate memory of 8183 MB
[23:06:41] - Connecting to assignment server
[23:06:41] Connecting to http://assign.stanford.edu:8080/
[23:06:41] Posted data.
[23:06:41] Initial: 40AB; - Successful: assigned to (171.64.65.55).
[23:06:41] + News From Folding@Home: Welcome to Folding@Home
[23:06:41] Loaded queue successfully.
[23:06:41] Sent data
[23:06:41] Connecting to http://171.64.65.55:8080/
[23:06:42] Posted data.
[23:06:42] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[23:06:42] - Attempt #38  to get work failed, and no other work to do.
[23:54:51] + Attempting to get work packet
[23:54:51] Passkey found
[23:54:51] - Will indicate memory of 8183 MB
[23:54:51] - Connecting to assignment server
[23:54:51] Connecting to http://assign.stanford.edu:8080/
[23:54:52] Posted data.
[23:54:52] Initial: 40AB; - Successful: assigned to (171.64.65.55).
[23:54:52] + News From Folding@Home: Welcome to Folding@Home
[23:54:52] Loaded queue successfully.
[23:54:52] Sent data
[23:54:52] Connecting to http://171.64.65.55:8080/
[23:54:53] Posted data.
[23:54:53] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[23:54:53] - Attempt #39  to get work failed, and no other work to do.
[23:59:38] - Autosending finished units... [November 5 23:59:38 UTC]
[00:43:05] + Attempting to get work packet
[00:43:05] Passkey found
[00:43:05] - Will indicate memory of 8183 MB
[00:43:05] - Connecting to assignment server
[00:43:05] Connecting to http://assign.stanford.edu:8080/
[00:43:06] Posted data.
[00:43:06] Initial: 4081; - Successful: assigned to (129.64.95.82).
[00:43:06] + News From Folding@Home: Welcome to Folding@Home
[00:43:06] Loaded queue successfully.
[00:43:06] Sent data
[00:43:06] Connecting to http://129.64.95.82:8080/
[00:43:07] Posted data.
[00:43:07] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[00:43:07] - Attempt #40  to get work failed, and no other work to do.
[01:31:11] + Attempting to get work packet
[01:31:11] Passkey found
[01:31:11] - Will indicate memory of 8183 MB
[01:31:11] - Connecting to assignment server
[01:31:11] Connecting to http://assign.stanford.edu:8080/
[01:31:12] Posted data.
[01:31:12] Initial: 4081; - Successful: assigned to (129.64.95.82).
[01:31:12] + News From Folding@Home: Welcome to Folding@Home
[01:31:12] Loaded queue successfully.
[01:31:12] Sent data
[01:31:12] Connecting to http://129.64.95.82:8080/
[01:31:13] Posted data.
[01:31:13] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[01:31:13] - Attempt #41  to get work failed, and no other work to do.
[02:19:20] + Attempting to get work packet
[02:19:20] Passkey found
[02:19:20] - Will indicate memory of 8183 MB
[02:19:20] - Connecting to assignment server
[02:19:20] Connecting to http://assign.stanford.edu:8080/
[02:19:21] Posted data.
[02:19:21] Initial: 4081; - Successful: assigned to (129.64.95.82).
[02:19:21] + News From Folding@Home: Welcome to Folding@Home
[02:19:21] Loaded queue successfully.
[02:19:21] Sent data
[02:19:21] Connecting to http://129.64.95.82:8080/
[02:19:22] Posted data.
[02:19:22] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[02:19:22] - Attempt #42  to get work failed, and no other work to do.
[03:07:33] + Attempting to get work packet
[03:07:33] Passkey found
[03:07:33] - Will indicate memory of 8183 MB
[03:07:33] - Connecting to assignment server
[03:07:33] Connecting to http://assign.stanford.edu:8080/
[03:07:33] Posted data.
[03:07:33] Initial: 40AB; - Successful: assigned to (171.64.65.55).
[03:07:33] + News From Folding@Home: Welcome to Folding@Home
[03:07:33] Loaded queue successfully.
[03:07:33] Sent data
[03:07:33] Connecting to http://171.64.65.55:8080/
[03:07:34] Posted data.
[03:07:34] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[03:07:34] - Attempt #43  to get work failed, and no other work to do.
[03:55:38] + Attempting to get work packet
[03:55:38] Passkey found
[03:55:38] - Will indicate memory of 8183 MB
[03:55:38] - Connecting to assignment server
[03:55:38] Connecting to http://assign.stanford.edu:8080/
[03:55:39] Posted data.
[03:55:39] Initial: 4081; - Successful: assigned to (129.64.95.82).
[03:55:39] + News From Folding@Home: Welcome to Folding@Home
[03:55:39] Loaded queue successfully.
[03:55:39] Sent data
[03:55:39] Connecting to http://129.64.95.82:8080/
[03:55:40] Posted data.
[03:55:40] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[03:55:40] - Attempt #44  to get work failed, and no other work to do.
[04:43:52] + Attempting to get work packet
[04:43:52] Passkey found
[04:43:52] - Will indicate memory of 8183 MB
[04:43:52] - Connecting to assignment server
[04:43:52] Connecting to http://assign.stanford.edu:8080/
[04:43:53] Posted data.
[04:43:53] Initial: 40AB; - Successful: assigned to (171.64.65.75).
[04:43:53] + News From Folding@Home: Welcome to Folding@Home
[04:43:53] Loaded queue successfully.
[04:43:53] Sent data
[04:43:53] Connecting to http://171.64.65.75:8080/
[04:43:54] Posted data.
[04:43:54] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[04:43:54] - Attempt #45  to get work failed, and no other work to do.
[05:32:04] + Attempting to get work packet
[05:32:04] Passkey found
[05:32:04] - Will indicate memory of 8183 MB
[05:32:04] - Connecting to assignment server
[05:32:04] Connecting to http://assign.stanford.edu:8080/
[05:32:05] Posted data.
[05:32:05] Initial: 4081; - Successful: assigned to (129.64.95.82).
[05:32:05] + News From Folding@Home: Welcome to Folding@Home
[05:32:05] Loaded queue successfully.
[05:32:05] Sent data
[05:32:05] Connecting to http://129.64.95.82:8080/
[05:32:06] Posted data.
[05:32:06] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[05:32:06] - Attempt #46  to get work failed, and no other work to do.
[05:59:38] - Autosending finished units... [November 6 05:59:38 UTC]
[06:20:03] + Attempting to get work packet
[06:20:03] Passkey found
[06:20:03] - Will indicate memory of 8183 MB
[06:20:03] - Connecting to assignment server
[06:20:03] Connecting to http://assign.stanford.edu:8080/
[06:20:03] Posted data.
[06:20:03] Initial: 40AB; - Successful: assigned to (171.64.65.55).
[06:20:03] + News From Folding@Home: Welcome to Folding@Home
[06:20:04] Loaded queue successfully.
[06:20:04] Sent data
[06:20:04] Connecting to http://171.64.65.55:8080/
[06:20:04] Posted data.
[06:20:04] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[06:20:04] - Attempt #47  to get work failed, and no other work to do.
[07:08:10] + Attempting to get work packet
[07:08:10] Passkey found
[07:08:10] - Will indicate memory of 8183 MB
[07:08:10] - Connecting to assignment server
[07:08:10] Connecting to http://assign.stanford.edu:8080/
[07:08:10] Posted data.
[07:08:10] Initial: 40AB; - Successful: assigned to (171.64.65.75).
[07:08:10] + News From Folding@Home: Welcome to Folding@Home
[07:08:11] Loaded queue successfully.
[07:08:11] Sent data
[07:08:11] Connecting to http://171.64.65.75:8080/
[07:08:12] Posted data.
[07:08:12] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[07:08:12] - Attempt #48  to get work failed, and no other work to do.
[07:56:14] + Attempting to get work packet
[07:56:14] Passkey found
[07:56:14] - Will indicate memory of 8183 MB
[07:56:14] - Connecting to assignment server
[07:56:14] Connecting to http://assign.stanford.edu:8080/
[07:56:15] Posted data.
[07:56:15] Initial: 40AB; - Successful: assigned to (171.64.65.55).
[07:56:15] + News From Folding@Home: Welcome to Folding@Home
[07:56:15] Loaded queue successfully.
[07:56:15] Sent data
[07:56:15] Connecting to http://171.64.65.55:8080/
[07:56:16] Posted data.
[07:56:16] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[07:56:16] - Attempt #49  to get work failed, and no other work to do.
[08:44:28] + Attempting to get work packet
[08:44:28] Passkey found
[08:44:28] - Will indicate memory of 8183 MB
[08:44:28] - Connecting to assignment server
[08:44:28] Connecting to http://assign.stanford.edu:8080/
[08:44:29] Posted data.
[08:44:29] Initial: 4081; - Successful: assigned to (129.64.95.82).
[08:44:29] + News From Folding@Home: Welcome to Folding@Home
[08:44:29] Loaded queue successfully.
[08:44:29] Sent data
[08:44:29] Connecting to http://129.64.95.82:8080/
[08:44:30] Posted data.
[08:44:30] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[08:44:30] - Attempt #50  to get work failed, and no other work to do.
[09:32:32] + Attempting to get work packet
[09:32:32] Passkey found
[09:32:32] - Will indicate memory of 8183 MB
[09:32:32] - Connecting to assignment server
[09:32:32] Connecting to http://assign.stanford.edu:8080/
[09:32:32] Posted data.
[09:32:32] Initial: 4081; - Successful: assigned to (129.64.95.82).
[09:32:32] + News From Folding@Home: Welcome to Folding@Home
[09:32:32] Loaded queue successfully.
[09:32:32] Sent data
[09:32:32] Connecting to http://129.64.95.82:8080/
[09:32:34] Posted data.
[09:32:34] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[09:32:34] - Attempt #51  to get work failed, and no other work to do.
[10:20:40] + Attempting to get work packet
[10:20:40] Passkey found
[10:20:40] - Will indicate memory of 8183 MB
[10:20:40] - Connecting to assignment server
[10:20:40] Connecting to http://assign.stanford.edu:8080/
[10:20:40] Posted data.
[10:20:40] Initial: 4081; - Successful: assigned to (129.64.95.82).
[10:20:40] + News From Folding@Home: Welcome to Folding@Home
[10:20:40] Loaded queue successfully.
[10:20:40] Sent data
[10:20:40] Connecting to http://129.64.95.82:8080/
[10:20:41] Posted data.
[10:20:41] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[10:20:41] - Attempt #52  to get work failed, and no other work to do.
[11:08:54] + Attempting to get work packet
[11:08:54] Passkey found
[11:08:54] - Will indicate memory of 8183 MB
[11:08:54] - Connecting to assignment server
[11:08:54] Connecting to http://assign.stanford.edu:8080/
[11:08:55] Posted data.
[11:08:55] Initial: 40AB; - Successful: assigned to (171.64.65.55).
[11:08:55] + News From Folding@Home: Welcome to Folding@Home
[11:08:55] Loaded queue successfully.
[11:08:55] Sent data
[11:08:55] Connecting to http://171.64.65.55:8080/
[11:08:56] Posted data.
[11:08:56] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[11:08:56] - Attempt #53  to get work failed, and no other work to do.
[11:57:07] + Attempting to get work packet
[11:57:07] Passkey found
[11:57:07] - Will indicate memory of 8183 MB
[11:57:07] - Connecting to assignment server
[11:57:07] Connecting to http://assign.stanford.edu:8080/
[11:57:08] Posted data.
[11:57:08] Initial: 4081; - Successful: assigned to (129.64.95.82).
[11:57:08] + News From Folding@Home: Welcome to Folding@Home
[11:57:08] Loaded queue successfully.
[11:57:08] Sent data
[11:57:08] Connecting to http://129.64.95.82:8080/
[11:57:09] Posted data.
[11:57:09] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[11:57:09] - Attempt #54  to get work failed, and no other work to do.
[11:59:33] - Autosending finished units... [November 6 11:59:33 UTC]
[11:59:33] Trying to send all finished work units
[11:59:33] + No unsent completed units remaining.
[11:59:33] - Autosend completed
[12:45:21] + Attempting to get work packet
[12:45:21] Passkey found
[12:45:21] - Will indicate memory of 8183 MB
[12:45:21] - Connecting to assignment server
[12:45:21] Connecting to http://assign.stanford.edu:8080/
[12:45:22] Posted data.
[12:45:22] Initial: 4081; - Successful: assigned to (129.64.95.82).
[12:45:22] + News From Folding@Home: Welcome to Folding@Home
[12:45:22] Loaded queue successfully.
[12:45:22] Sent data
[12:45:22] Connecting to http://129.64.95.82:8080/
[12:45:23] Posted data.
[12:45:23] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[12:45:23] - Attempt #55  to get work failed, and no other work to do.
[13:33:38] + Attempting to get work packet
[13:33:38] Passkey found
[13:33:38] - Will indicate memory of 8183 MB
[13:33:38] - Connecting to assignment server
[13:33:38] Connecting to http://assign.stanford.edu:8080/
[13:33:38] Posted data.
[13:33:38] Initial: 40AB; - Successful: assigned to (171.64.65.55).
[13:33:38] + News From Folding@Home: Welcome to Folding@Home
[13:33:38] Loaded queue successfully.
[13:33:38] Sent data
[13:33:38] Connecting to http://171.64.65.55:8080/
[13:33:39] Posted data.
[13:33:39] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[13:33:39] - Attempt #56  to get work failed, and no other work to do.
[14:21:44] + Attempting to get work packet
[14:21:44] Passkey found
[14:21:44] - Will indicate memory of 8183 MB
[14:21:44] - Connecting to assignment server
[14:21:44] Connecting to http://assign.stanford.edu:8080/
[14:21:45] Posted data.
[14:21:45] Initial: 4081; - Successful: assigned to (129.64.95.82).
[14:21:45] + News From Folding@Home: Welcome to Folding@Home
[14:21:45] Loaded queue successfully.
[14:21:45] Sent data
[14:21:45] Connecting to http://129.64.95.82:8080/
[14:21:46] Posted data.
[14:21:46] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[14:21:46] - Attempt #57  to get work failed, and no other work to do.
[15:10:00] + Attempting to get work packet
[15:10:00] Passkey found
[15:10:00] - Will indicate memory of 8183 MB
[15:10:00] - Connecting to assignment server
[15:10:00] Connecting to http://assign.stanford.edu:8080/
[15:10:01] Posted data.
[15:10:01] Initial: 4081; - Successful: assigned to (129.64.95.82).
[15:10:01] + News From Folding@Home: Welcome to Folding@Home
[15:10:01] Loaded queue successfully.
[15:10:01] Sent data
[15:10:01] Connecting to http://129.64.95.82:8080/
[15:10:02] Posted data.
[15:10:02] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[15:10:02] - Attempt #58  to get work failed, and no other work to do.
[15:58:13] + Attempting to get work packet
[15:58:13] Passkey found
[15:58:13] - Will indicate memory of 8183 MB
[15:58:13] - Connecting to assignment server
[15:58:13] Connecting to http://assign.stanford.edu:8080/
[15:58:14] Posted data.
[15:58:14] Initial: 4081; - Successful: assigned to (129.64.95.82).
[15:58:14] + News From Folding@Home: Welcome to Folding@Home
[15:58:14] Loaded queue successfully.
[15:58:14] Sent data
[15:58:14] Connecting to http://129.64.95.82:8080/
[15:58:15] Posted data.
[15:58:15] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[15:58:15] - Attempt #59  to get work failed, and no other work to do.
[16:46:29] + Attempting to get work packet
[16:46:29] Passkey found
[16:46:29] - Will indicate memory of 8183 MB
[16:46:29] - Connecting to assignment server
[16:46:29] Connecting to http://assign.stanford.edu:8080/
[16:46:29] Posted data.
[16:46:29] Initial: 40AB; - Successful: assigned to (171.64.65.55).
[16:46:29] + News From Folding@Home: Welcome to Folding@Home
[16:46:29] Loaded queue successfully.
[16:46:29] Sent data
[16:46:29] Connecting to http://171.64.65.55:8080/
[16:46:30] Posted data.
[16:46:30] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[16:46:30] - Attempt #60  to get work failed, and no other work to do.
[17:34:37] + Attempting to get work packet
[17:34:37] Passkey found
[17:34:37] - Will indicate memory of 8183 MB
[17:34:37] - Connecting to assignment server
[17:34:37] Connecting to http://assign.stanford.edu:8080/
[17:34:38] Posted data.
[17:34:38] Initial: 4081; - Successful: assigned to (129.64.95.82).
[17:34:38] + News From Folding@Home: Welcome to Folding@Home
[17:34:38] Loaded queue successfully.
[17:34:38] Sent data
[17:34:38] Connecting to http://129.64.95.82:8080/
[17:34:39] Posted data.
[17:34:39] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[17:34:39] - Attempt #61  to get work failed, and no other work to do.
[17:59:33] - Autosending finished units... [November 6 17:59:33 UTC]
[17:59:33] Trying to send all finished work units
[17:59:33] + No unsent completed units remaining.
[17:59:33] - Autosend completed
[18:22:51] + Attempting to get work packet
[18:22:51] Passkey found
[18:22:51] - Will indicate memory of 8183 MB
[18:22:51] - Connecting to assignment server
[18:22:51] Connecting to http://assign.stanford.edu:8080/
[18:22:52] Posted data.
[18:22:52] Initial: 4081; - Successful: assigned to (129.64.95.82).
[18:22:52] + News From Folding@Home: Welcome to Folding@Home
[18:22:52] Loaded queue successfully.
[18:22:52] Sent data
[18:22:52] Connecting to http://129.64.95.82:8080/
[18:22:53] Posted data.
[18:22:53] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[18:22:53] - Attempt #62  to get work failed, and no other work to do.
[19:10:59] + Attempting to get work packet
[19:10:59] Passkey found
[19:10:59] - Will indicate memory of 8183 MB
[19:10:59] - Connecting to assignment server
[19:10:59] Connecting to http://assign.stanford.edu:8080/
[19:10:59] Posted data.
[19:10:59] Initial: 4081; - Successful: assigned to (129.64.95.82).
[19:10:59] + News From Folding@Home: Welcome to Folding@Home
[19:10:59] Loaded queue successfully.
[19:10:59] Sent data
[19:10:59] Connecting to http://129.64.95.82:8080/
[19:11:00] Posted data.
[19:11:00] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[19:11:00] - Attempt #63  to get work failed, and no other work to do.
[19:59:08] + Attempting to get work packet
[19:59:08] Passkey found
[19:59:08] - Will indicate memory of 8183 MB
[19:59:08] - Connecting to assignment server
[19:59:08] Connecting to http://assign.stanford.edu:8080/
[19:59:08] Posted data.
[19:59:08] Initial: 40AB; - Successful: assigned to (171.64.65.55).
[19:59:08] + News From Folding@Home: Welcome to Folding@Home
[19:59:08] Loaded queue successfully.
[19:59:08] Sent data
[19:59:08] Connecting to http://171.64.65.55:8080/
[19:59:09] Posted data.
[19:59:09] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[19:59:09] - Attempt #64  to get work failed, and no other work to do.
[20:47:22] + Attempting to get work packet
[20:47:22] Passkey found
[20:47:22] - Will indicate memory of 8183 MB
[20:47:22] - Connecting to assignment server
[20:47:22] Connecting to http://assign.stanford.edu:8080/
[20:47:23] Posted data.
[20:47:23] Initial: 4081; - Successful: assigned to (129.64.95.82).
[20:47:23] + News From Folding@Home: Welcome to Folding@Home
[20:47:23] Loaded queue successfully.
[20:47:23] Sent data
[20:47:23] Connecting to http://129.64.95.82:8080/
[20:47:24] Posted data.
[20:47:24] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[20:47:24] - Attempt #65  to get work failed, and no other work to do.
[21:35:35] + Attempting to get work packet
[21:35:35] Passkey found
[21:35:35] - Will indicate memory of 8183 MB
[21:35:35] - Connecting to assignment server
[21:35:35] Connecting to http://assign.stanford.edu:8080/
[21:35:36] Posted data.
[21:35:36] Initial: 40AB; - Successful: assigned to (171.64.65.55).
[21:35:36] + News From Folding@Home: Welcome to Folding@Home
[21:35:36] Loaded queue successfully.
[21:35:36] Sent data
[21:35:36] Connecting to http://171.64.65.55:8080/
[21:35:37] Posted data.
[21:35:37] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[21:35:37] - Attempt #66  to get work failed, and no other work to do.
[22:23:44] + Attempting to get work packet
[22:23:44] Passkey found
[22:23:44] - Will indicate memory of 8183 MB
[22:23:44] - Connecting to assignment server
[22:23:44] Connecting to http://assign.stanford.edu:8080/
[22:23:44] Posted data.
[22:23:44] Initial: 40AB; - Successful: assigned to (171.64.65.55).
[22:23:44] + News From Folding@Home: Welcome to Folding@Home
[22:23:45] Loaded queue successfully.
[22:23:45] Sent data
[22:23:45] Connecting to http://171.64.65.55:8080/
[22:23:46] Posted data.
[22:23:46] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[22:23:46] - Attempt #67  to get work failed, and no other work to do.
[23:11:57] + Attempting to get work packet
[23:11:57] Passkey found
[23:11:57] - Will indicate memory of 8183 MB
[23:11:57] - Connecting to assignment server
[23:11:57] Connecting to http://assign.stanford.edu:8080/
[23:11:58] Posted data.
[23:11:58] Initial: 4081; - Successful: assigned to (129.64.95.82).
[23:11:58] + News From Folding@Home: Welcome to Folding@Home
[23:11:58] Loaded queue successfully.
[23:11:58] Sent data
[23:11:58] Connecting to http://129.64.95.82:8080/
[23:11:59] Posted data.
[23:11:59] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[23:11:59] - Attempt #68  to get work failed, and no other work to do.
[23:59:33] - Autosending finished units... [November 6 23:59:33 UTC]
[23:59:33] Trying to send all finished work units
[23:59:33] + No unsent completed units remaining.
[23:59:33] - Autosend completed
[00:00:05] + Attempting to get work packet
[00:00:05] Passkey found
[00:00:05] - Will indicate memory of 8183 MB
[00:00:05] - Connecting to assignment server
[00:00:05] Connecting to http://assign.stanford.edu:8080/
[00:00:06] Posted data.
[00:00:06] Initial: 4081; - Successful: assigned to (129.64.95.82).
[00:00:06] + News From Folding@Home: Welcome to Folding@Home
[00:00:06] Loaded queue successfully.
[00:00:06] Sent data
[00:00:06] Connecting to http://129.64.95.82:8080/
[00:00:07] Posted data.
[00:00:07] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[00:00:07] - Attempt #69  to get work failed, and no other work to do.
[00:48:22] + Attempting to get work packet
[00:48:22] Passkey found
[00:48:22] - Will indicate memory of 8183 MB
[00:48:22] - Connecting to assignment server
[00:48:22] Connecting to http://assign.stanford.edu:8080/
[00:48:23] Posted data.
[00:48:23] Initial: 4081; - Successful: assigned to (129.64.95.82).
[00:48:23] + News From Folding@Home: Welcome to Folding@Home
[00:48:23] Loaded queue successfully.
[00:48:23] Sent data
[00:48:23] Connecting to http://129.64.95.82:8080/
[00:48:24] Posted data.
[00:48:24] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[00:48:24] - Attempt #70  to get work failed, and no other work to do.
[01:36:24] + Attempting to get work packet
[01:36:24] Passkey found
[01:36:24] - Will indicate memory of 8183 MB
[01:36:24] - Connecting to assignment server
[01:36:24] Connecting to http://assign.stanford.edu:8080/
[01:36:25] Posted data.
[01:36:25] Initial: 40AB; - Successful: assigned to (171.64.65.55).
[01:36:25] + News From Folding@Home: Welcome to Folding@Home
[01:36:25] Loaded queue successfully.
[01:36:25] Sent data
[01:36:25] Connecting to http://171.64.65.55:8080/
[01:36:26] Posted data.
[01:36:26] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[01:36:26] - Attempt #71  to get work failed, and no other work to do.
[02:24:33] + Attempting to get work packet
[02:24:33] Passkey found
[02:24:33] - Will indicate memory of 8183 MB
[02:24:33] - Connecting to assignment server
[02:24:33] Connecting to http://assign.stanford.edu:8080/
[02:24:34] Posted data.
[02:24:34] Initial: 4081; - Successful: assigned to (129.64.95.82).
[02:24:34] + News From Folding@Home: Welcome to Folding@Home
[02:24:34] Loaded queue successfully.
[02:24:34] Sent data
[02:24:34] Connecting to http://129.64.95.82:8080/
[02:24:35] Posted data.
[02:24:35] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[02:24:35] - Attempt #72  to get work failed, and no other work to do.
[03:12:40] + Attempting to get work packet
[03:12:40] Passkey found
[03:12:40] - Will indicate memory of 8183 MB
[03:12:40] - Connecting to assignment server
[03:12:40] Connecting to http://assign.stanford.edu:8080/
[03:12:41] Posted data.
[03:12:41] Initial: 40AB; - Successful: assigned to (171.64.65.55).
[03:12:41] + News From Folding@Home: Welcome to Folding@Home
[03:12:41] Loaded queue successfully.
[03:12:41] Sent data
[03:12:41] Connecting to http://171.64.65.55:8080/
[03:12:42] Posted data.
[03:12:42] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[03:12:42] - Attempt #73  to get work failed, and no other work to do.
[04:00:44] + Attempting to get work packet
[04:00:44] Passkey found
[04:00:44] - Will indicate memory of 8183 MB
[04:00:44] - Connecting to assignment server
[04:00:44] Connecting to http://assign.stanford.edu:8080/
[04:00:45] Posted data.
[04:00:45] Initial: 40AB; - Successful: assigned to (171.64.65.55).
[04:00:45] + News From Folding@Home: Welcome to Folding@Home
[04:00:45] Loaded queue successfully.
[04:00:45] Sent data
[04:00:45] Connecting to http://171.64.65.55:8080/
[04:00:46] Posted data.
[04:00:46] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[04:00:46] - Attempt #74  to get work failed, and no other work to do.
[04:48:47] + Attempting to get work packet
[04:48:47] Passkey found
[04:48:47] - Will indicate memory of 8183 MB
[04:48:47] - Connecting to assignment server
[04:48:47] Connecting to http://assign.stanford.edu:8080/
[04:48:48] Posted data.
[04:48:48] Initial: 40AB; - Successful: assigned to (171.64.65.55).
[04:48:48] + News From Folding@Home: Welcome to Folding@Home
[04:48:48] Loaded queue successfully.
[04:48:48] Sent data
[04:48:48] Connecting to http://171.64.65.55:8080/
[04:48:49] Posted data.
[04:48:49] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[04:48:49] - Attempt #75  to get work failed, and no other work to do.
[05:37:03] + Attempting to get work packet
[05:37:03] Passkey found
[05:37:03] - Will indicate memory of 8183 MB
[05:37:03] - Connecting to assignment server
[05:37:03] Connecting to http://assign.stanford.edu:8080/
[05:37:04] Posted data.
[05:37:04] Initial: 40AB; - Successful: assigned to (171.64.65.55).
[05:37:04] + News From Folding@Home: Welcome to Folding@Home
[05:37:04] Loaded queue successfully.
[05:37:04] Sent data
[05:37:04] Connecting to http://171.64.65.55:8080/
[05:37:04] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[05:37:04] - Attempt #76  to get work failed, and no other work to do.
[05:59:33] - Autosending finished units... [November 7 05:59:33 UTC]
[05:59:33] Trying to send all finished work units
[05:59:33] + No unsent completed units remaining.
[05:59:33] - Autosend completed
[06:25:07] + Attempting to get work packet
[06:25:07] Passkey found
[06:25:07] - Will indicate memory of 8183 MB
[06:25:07] - Connecting to assignment server
[06:25:07] Connecting to http://assign.stanford.edu:8080/
[06:25:08] Posted data.
[06:25:08] Initial: 40AB; - Successful: assigned to (171.64.65.55).
[06:25:08] + News From Folding@Home: Welcome to Folding@Home
[06:25:08] Loaded queue successfully.
[06:25:08] Sent data
[06:25:08] Connecting to http://171.64.65.55:8080/
[06:25:09] Posted data.
[06:25:09] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[06:25:09] - Attempt #77  to get work failed, and no other work to do.
[07:13:18] + Attempting to get work packet
[07:13:18] Passkey found
[07:13:18] - Will indicate memory of 8183 MB
[07:13:18] - Connecting to assignment server
[07:13:18] Connecting to http://assign.stanford.edu:8080/
[07:13:18] Posted data.
[07:13:18] Initial: 40AB; - Successful: assigned to (171.64.65.55).
[07:13:18] + News From Folding@Home: Welcome to Folding@Home
[07:13:18] Loaded queue successfully.
[07:13:18] Sent data
[07:13:18] Connecting to http://171.64.65.55:8080/
[07:13:19] Posted data.
[07:13:19] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[07:13:19] - Attempt #78  to get work failed, and no other work to do.
[08:01:23] + Attempting to get work packet
[08:01:23] Passkey found
[08:01:23] - Will indicate memory of 8183 MB
[08:01:23] - Connecting to assignment server
[08:01:23] Connecting to http://assign.stanford.edu:8080/
[08:01:24] Posted data.
[08:01:24] Initial: 4081; - Successful: assigned to (129.64.95.82).
[08:01:24] + News From Folding@Home: Welcome to Folding@Home
[08:01:24] Loaded queue successfully.
[08:01:24] Sent data
[08:01:24] Connecting to http://129.64.95.82:8080/
[08:01:25] Posted data.
[08:01:25] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[08:01:25] - Attempt #79  to get work failed, and no other work to do.
[08:49:26] + Attempting to get work packet
[08:49:26] Passkey found
[08:49:26] - Will indicate memory of 8183 MB
[08:49:26] - Connecting to assignment server
[08:49:26] Connecting to http://assign.stanford.edu:8080/
[08:49:27] Posted data.
[08:49:27] Initial: 40AB; - Successful: assigned to (171.64.65.55).
[08:49:27] + News From Folding@Home: Welcome to Folding@Home
[08:49:27] Loaded queue successfully.
[08:49:27] Sent data
[08:49:27] Connecting to http://171.64.65.55:8080/
[08:49:28] Posted data.
[08:49:28] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[08:49:28] - Attempt #80  to get work failed, and no other work to do.
Waiting before retry.
[09:37:30] + Attempting to get work packet
[09:37:30] Passkey found
[09:37:30] - Will indicate memory of 8183 MB
[09:37:30] - Connecting to assignment server
[09:37:30] Connecting to http://assign.stanford.edu:8080/
[09:37:31] Posted data.
[09:37:31] Initial: 40AB; - Successful: assigned to (171.64.65.55).
[09:37:31] + News From Folding@Home: Welcome to Folding@Home
[09:37:31] Loaded queue successfully.
[09:37:31] Sent data
[09:37:31] Connecting to http://171.64.65.55:8080/
[09:37:32] Posted data.
[09:37:32] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[09:37:32] - Attempt #81  to get work failed, and no other work to do.
[10:25:40] + Attempting to get work packet
[10:25:40] Passkey found
[10:25:40] - Will indicate memory of 8183 MB
[10:25:40] - Connecting to assignment server
[10:25:40] Connecting to http://assign.stanford.edu:8080/
[10:25:40] Posted data.
[10:25:40] Initial: 40AB; - Successful: assigned to (171.64.65.55).
[10:25:40] + News From Folding@Home: Welcome to Folding@Home
[10:25:40] Loaded queue successfully.
[10:25:40] Sent data
[10:25:40] Connecting to http://171.64.65.55:8080/
[10:25:41] Posted data.
[10:25:41] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[10:25:41] - Attempt #82  to get work failed, and no other work to do.
[11:13:55] + Attempting to get work packet
[11:13:55] Passkey found
[11:13:55] - Will indicate memory of 8183 MB
[11:13:55] - Connecting to assignment server
[11:13:55] Connecting to http://assign.stanford.edu:8080/
[11:13:56] Posted data.
[11:13:56] Initial: 4081; - Successful: assigned to (129.64.95.82).
[11:13:56] + News From Folding@Home: Welcome to Folding@Home
[11:13:56] Loaded queue successfully.
[11:13:56] Sent data
[11:13:56] Connecting to http://129.64.95.82:8080/
[11:13:57] Posted data.
[11:13:57] Initial: 8B1F; - Error: Bad packet type from server, expected work assignment
[11:13:57] - Attempt #83  to get work failed, and no other work to do.
dvanatta
Pande Group Member
Re: 129.64.95.82:8080
Post by dvanatta »
Hi,
I looked into this and these servers are assigning and accepting jobs, have any other users seen this error?
-Dan
Meh_Lay_Lay
129.64.95.82 Haven't been able to upload finished projects
Post by Meh_Lay_Lay »
I couldn't upload any of my finished projects the past 2 days, and now have 5 projects that can't send and 1 that's folding. Is there something wrong with the servers? In that case, should I stop folding for now so that I don't download and expire/waste the projects? Basically, it just keeps saying the connection was actively refused. It does happen to me once in a while but usually a few hours later it would be uploaded. Not this time... and for all my projects too :(
17:07:22:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
17:07:22:SocketDevice::write(): Socket not open
17:07:22:WARNING: Exception: Failed to send results to work server: Upload failed
17:07:22:Trying to send results to collection server
17:07:22:Unit 01: Uploading 2.19MiB to 171.67.108.26
17:07:22:Connecting to 171.67.108.26:8080
17:07:23:WARNING: WorkServer connection failed on port 8080 trying 80
17:07:23:Connecting to 171.67.108.26:80
17:07:25:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
17:07:25:Sending unit results: id:01 state:SEND error:OK project:7200 run:65 clone:37 gen:27 core:0xa4 unit:0x0000001c07ba4bae4da725b53aceab17
17:07:25:Unit 01: Uploading 2.19MiB to 129.64.95.82
17:07:25:Connecting to 129.64.95.82:8080
17:08:12:Slot 01 paused
17:08:12:Slot 01: shutting core down
17:08:12:WARNING: FahCore is known to not shutdown cleanly, killing
17:08:12:WARNING: Killing Unit 02
17:08:12:FahCore, running Unit 02, terminated.
17:08:18:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
17:08:18:SocketDevice::write(): Socket not open
17:08:18:WARNING: Exception: Failed to send results to work server: Upload failed
17:08:18:Trying to send results to collection server
17:08:18:Unit 01: Uploading 2.19MiB to 171.67.108.26
17:08:18:Connecting to 171.67.108.26:8080
17:08:19:WARNING: WorkServer connection failed on port 8080 trying 80
17:08:19:Connecting to 171.67.108.26:80
17:08:21:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
17:09:02:Sending unit results: id:01 state:SEND error:OK project:7200 run:65 clone:37 gen:27 core:0xa4 unit:0x0000001c07ba4bae4da725b53aceab17
17:09:02:Unit 01: Uploading 2.19MiB to 129.64.95.82
17:09:02:Connecting to 129.64.95.82:8080
17:09:08:Unit 01: 1.96%
17:10:13:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
17:10:13:SocketDevice::write(): Socket not open
17:10:13:WARNING: Exception: Failed to send results to work server: Upload failed
17:10:13:Trying to send results to collection server
17:10:14:Unit 01: Uploading 2.19MiB to 171.67.108.26
17:10:14:Connecting to 171.67.108.26:8080
17:10:15:WARNING: WorkServer connection failed on port 8080 trying 80
17:10:15:Connecting to 171.67.108.26:80
17:10:17:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
17:10:33:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
17:10:33:SocketDevice::write(): Socket not open
17:10:33:WARNING: Exception: Failed to send results to work server: Upload failed
17:10:33:Trying to send results to collection server
17:10:33:Unit 00: Uploading 2.22MiB to 171.67.108.26
17:10:33:Connecting to 171.67.108.26:8080
17:10:46:WARNING: WorkServer connection failed on port 8080 trying 80
17:10:46:Connecting to 171.67.108.26:80
17:10:59:ERROR: Exception: Failed to connect to 171.67.108.26:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
17:11:00:Sending unit results: id:00 state:SEND error:OK project:7200 run:15 clone:31 gen:23 core:0xa4 unit:0x0000001d07ba4bae4da71fc1f19b3814
17:11:00:Unit 00: Uploading 2.22MiB to 129.64.95.82
17:11:00:Connecting to 129.64.95.82:8080
17:11:39:Sending unit results: id:01 state:SEND error:OK project:7200 run:65 clone:37 gen:27 core:0xa4 unit:0x0000001c07ba4bae4da725b53aceab17
17:11:40:Unit 01: Uploading 2.19MiB to 129.64.95.82
17:11:40:Connecting to 129.64.95.82:8080
17:11:40:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
17:11:40:SocketDevice::write(): Socket not open
17:11:40:WARNING: Exception: Failed to send results to work server: Upload failed
17:11:40:Trying to send results to collection server
17:11:40:Unit 00: Uploading 2.22MiB to 171.67.108.26
17:11:40:Connecting to 171.67.108.26:8080
17:11:42:WARNING: WorkServer connection failed on port 8080 trying 80
17:11:42:Connecting to 171.67.108.26:80
17:11:43:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
17:13:06:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
17:13:06:SocketDevice::write(): Socket not open
17:13:06:WARNING: Exception: Failed to send results to work server: Upload failed
17:13:06:Trying to send results to collection server
17:13:06:Unit 01: Uploading 2.19MiB to 171.67.108.26
17:13:06:Connecting to 171.67.108.26:8080
17:13:07:WARNING: WorkServer connection failed on port 8080 trying 80
17:13:07:Connecting to 171.67.108.26:80
17:13:09:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
17:13:37:Sending unit results: id:00 state:SEND error:OK project:7200 run:15 clone:31 gen:23 core:0xa4 unit:0x0000001d07ba4bae4da71fc1f19b3814
17:13:37:Unit 00: Uploading 2.22MiB to 129.64.95.82
17:13:37:Connecting to 129.64.95.82:8080
17:13:44:Unit 00: 1.23%
17:15:54:Sending unit results: id:01 state:SEND error:OK project:7200 run:65 clone:37 gen:27 core:0xa4 unit:0x0000001c07ba4bae4da725b53aceab17
17:15:54:Unit 01: Uploading 2.19MiB to 129.64.95.82
17:15:54:Connecting to 129.64.95.82:8080
17:16:01:Unit 01: 1.43%
17:16:09:Unit 01: 1.96%
17:18:53:SocketDevice::write(): Send error: 10053: An established connection was aborted by the software in your host machine.
17:18:53:SocketDevice::write(): Socket not open
17:18:53:WARNING: Exception: Failed to send results to work server: Upload failed
17:18:53:Trying to send results to collection server
17:18:53:Unit 00: Uploading 2.22MiB to 171.67.108.26
17:18:53:Connecting to 171.67.108.26:8080
17:18:54:WARNING: WorkServer connection failed on port 8080 trying 80
17:18:54:Connecting to 171.67.108.26:80
17:18:56:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
17:18:56:Sending unit results: id:00 state:SEND error:OK project:7200 run:15 clone:31 gen:23 core:0xa4 unit:0x0000001d07ba4bae4da71fc1f19b3814
17:18:56:Unit 00: Uploading 2.22MiB to 129.64.95.82
17:18:56:Connecting to 129.64.95.82:8080
17:19:03:Unit 00: 1.23%
17:19:46:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
17:19:46:SocketDevice::write(): Socket not open
17:19:46:WARNING: Exception: Failed to send results to work server: Upload failed
17:19:46:Trying to send results to collection server
17:19:46:Unit 01: Uploading 2.19MiB to 171.67.108.26
17:19:46:Connecting to 171.67.108.26:8080
17:19:47:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
17:19:47:SocketDevice::write(): Socket not open
17:19:47:WARNING: Exception: Failed to send results to work server: Upload failed
17:19:47:Trying to send results to collection server
17:19:47:Unit 00: Uploading 2.22MiB to 171.67.108.26
17:19:47:Connecting to 171.67.108.26:8080
17:19:47:WARNING: WorkServer connection failed on port 8080 trying 80
17:19:48:WARNING: WorkServer connection failed on port 8080 trying 80
17:19:48:Connecting to 171.67.108.26:80
17:19:49:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
17:19:50:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
17:22:45:Sending unit results: id:01 state:SEND error:OK project:7200 run:65 clone:37 gen:27 core:0xa4 unit:0x0000001c07ba4bae4da725b53aceab17
17:22:45:Unit 01: Uploading 2.19MiB to 129.64.95.82
17:22:45:Connecting to 129.64.95.82:8080
17:25:47:Sending unit results: id:00 state:SEND error:OK project:7200 run:15 clone:31 gen:23 core:0xa4 unit:0x0000001d07ba4bae4da71fc1f19b3814
17:25:48:Unit 00: Uploading 2.22MiB to 129.64.95.82
17:25:48:Connecting to 129.64.95.82:8080
17:26:34:SocketDevice::write(): Send error: 10053: An established connection was aborted by the software in your host machine.
17:26:34:SocketDevice::write(): Socket not open
17:26:34:WARNING: Exception: Failed to send results to work server: Upload failed
17:26:34:Trying to send results to collection server
17:26:35:Unit 01: Uploading 2.19MiB to 171.67.108.26
17:26:35:Connecting to 171.67.108.26:8080
17:26:36:WARNING: WorkServer connection failed on port 8080 trying 80
17:26:36:Connecting to 171.67.108.26:80
17:26:38:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
17:26:51:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
17:26:51:SocketDevice::write(): Socket not open
17:26:51:WARNING: Exception: Failed to send results to work server: Upload failed
17:26:51:Trying to send results to collection server
17:26:51:Unit 00: Uploading 2.22MiB to 171.67.108.26
17:26:51:Connecting to 171.67.108.26:8080
17:26:52:WARNING: WorkServer connection failed on port 8080 trying 80
17:26:52:Connecting to 171.67.108.26:80
17:26:54:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
17:33:51:Sending unit results: id:01 state:SEND error:OK project:7200 run:65 clone:37 gen:27 core:0xa4 unit:0x0000001c07ba4bae4da725b53aceab17
17:33:51:Unit 01: Uploading 2.19MiB to 129.64.95.82
17:33:51:Connecting to 129.64.95.82:8080
17:34:19:Unit 01: 0.71%
17:36:53:Sending unit results: id:00 state:SEND error:OK project:7200 run:15 clone:31 gen:23 core:0xa4 unit:0x0000001d07ba4bae4da71fc1f19b3814
17:36:53:Unit 00: Uploading 2.22MiB to 129.64.95.82
17:36:53:Connecting to 129.64.95.82:8080
17:40:15:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
17:40:15:SocketDevice::write(): Socket not open
17:40:15:WARNING: Exception: Failed to send results to work server: Upload failed
17:40:15:Trying to send results to collection server
17:40:16:Unit 00: Uploading 2.22MiB to 171.67.108.26
17:40:16:Connecting to 171.67.108.26:8080
17:40:17:WARNING: WorkServer connection failed on port 8080 trying 80
17:40:17:Connecting to 171.67.108.26:80
17:40:24:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
17:41:24:SocketDevice::write(): Send error: 10053: An established connection was aborted by the software in your host machine.
17:41:24:SocketDevice::write(): Socket not open
17:41:24:WARNING: Exception: Failed to send results to work server: Upload failed
17:41:24:Trying to send results to collection server
17:41:24:Unit 01: Uploading 2.19MiB to 171.67.108.26
17:41:24:Connecting to 171.67.108.26:8080
17:41:26:WARNING: WorkServer connection failed on port 8080 trying 80
17:41:26:Connecting to 171.67.108.26:80
17:41:33:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
17:51:48:Sending unit results: id:01 state:SEND error:OK project:7200 run:65 clone:37 gen:27 core:0xa4 unit:0x0000001c07ba4bae4da725b53aceab17
17:51:48:Unit 01: Uploading 2.19MiB to 129.64.95.82
17:51:48:Connecting to 129.64.95.82:8080
17:51:57:Unit 01: 0.54%
17:54:49:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
17:54:49:SocketDevice::write(): Socket not open
17:54:49:WARNING: Exception: Failed to send results to work server: Upload failed
17:54:49:Trying to send results to collection server
17:54:49:Unit 01: Uploading 2.19MiB to 171.67.108.26
17:54:49:Connecting to 171.67.108.26:8080
17:54:50:Sending unit results: id:00 state:SEND error:OK project:7200 run:15 clone:31 gen:23 core:0xa4 unit:0x0000001d07ba4bae4da71fc1f19b3814
17:54:50:Unit 00: Uploading 2.22MiB to 129.64.95.82
17:54:50:Connecting to 129.64.95.82:8080
17:54:50:WARNING: WorkServer connection failed on port 8080 trying 80
17:54:50:Connecting to 171.67.108.26:80
17:54:52:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
17:56:45:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
17:56:45:SocketDevice::write(): Socket not open
17:56:45:WARNING: Exception: Failed to send results to work server: Upload failed
17:56:45:Trying to send results to collection server
17:56:45:Unit 00: Uploading 2.22MiB to 171.67.108.26
17:56:45:Connecting to 171.67.108.26:8080
17:56:46:WARNING: WorkServer connection failed on port 8080 trying 80
17:56:46:Connecting to 171.67.108.26:80
17:56:48:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
18:20:50:Sending unit results: id:01 state:SEND error:OK project:7200 run:65 clone:37 gen:27 core:0xa4 unit:0x0000001c07ba4bae4da725b53aceab17
18:20:50:Unit 01: Uploading 2.19MiB to 129.64.95.82
18:20:50:Connecting to 129.64.95.82:8080
18:21:50:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
18:21:50:SocketDevice::write(): Socket not open
18:21:50:WARNING: Exception: Failed to send results to work server: Upload failed
18:21:50:Trying to send results to collection server
18:21:50:Unit 01: Uploading 2.19MiB to 171.67.108.26
18:21:50:Connecting to 171.67.108.26:8080
18:21:52:WARNING: WorkServer connection failed on port 8080 trying 80
18:21:52:Connecting to 171.67.108.26:80
18:21:53:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
18:23:52:Sending unit results: id:00 state:SEND error:OK project:7200 run:15 clone:31 gen:23 core:0xa4 unit:0x0000001d07ba4bae4da71fc1f19b3814
18:23:52:Unit 00: Uploading 2.22MiB to 129.64.95.82
18:23:52:Connecting to 129.64.95.82:8080
18:25:41:Unit 00: 0.88%
18:28:41:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
18:28:41:SocketDevice::write(): Socket not open
18:28:41:WARNING: Exception: Failed to send results to work server: Upload failed
18:28:41:Trying to send results to collection server
18:28:41:Unit 00: Uploading 2.22MiB to 171.67.108.26
18:28:41:Connecting to 171.67.108.26:8080
18:28:43:WARNING: WorkServer connection failed on port 8080 trying 80
18:28:43:Connecting to 171.67.108.26:80
18:28:56:ERROR: Exception: Failed to connect to 171.67.108.26:80: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
18:30:58:Slot 01 unpaused
18:30:58:Sending unit results: id:01 state:SEND error:OK project:7200 run:65 clone:37 gen:27 core:0xa4 unit:0x0000001c07ba4bae4da725b53aceab17
18:30:58:Unit 01: Uploading 2.19MiB to 129.64.95.82
18:30:58:Connecting to 129.64.95.82:8080
18:30:58:Sending unit results: id:00 state:SEND error:OK project:7200 run:15 clone:31 gen:23 core:0xa4 unit:0x0000001d07ba4bae4da71fc1f19b3814
18:30:58:Unit 00: Uploading 2.22MiB to 129.64.95.82
18:30:58:Starting Unit 02
18:30:58:Running core: C:/Users/Gary/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 02 -suffix 01 -lifeline 7984 -version 701 -checkpoint 3 -np 4
18:30:59:Started core on PID 8112
18:30:59:FahCore 0xa4 started
18:30:59:Started thread 11 on PID 7984
18:30:59:Unit 02:
18:30:59:Unit 02:*------------------------------*
18:30:59:Unit 02:Folding@Home Gromacs GB Core
18:30:59:Unit 02:Version 2.27 (Dec. 15, 2010)
18:30:59:Unit 02:
18:30:59:Unit 02:Preparing to commence simulation
18:30:59:Unit 02:- Ensuring status. Please wait.
18:31:04:Unit 00: 1.06%
18:31:05:Unit 01: 0.71%
18:31:08:Unit 02:- Looking at optimizations...
18:31:08:Unit 02:- Working with standard loops on this execution.
18:31:08:Unit 02:- Previous termination of core was improper.
18:31:08:Unit 02:- Going to use standard loops.
18:31:08:Unit 02:- Files status OK
18:31:09:Unit 02:- Expanded 663947 -> 1297016 (decompressed 195.3 percent)
18:31:09:Unit 02:Called DecompressByteArray: compressed_data_size=663947 data_size=1297016, decompressed_data_size=1297016 diff=0
18:31:09:Unit 02:- Digital signature verified
18:31:09:Unit 02:
18:31:09:Unit 02:Project: 7200 (Run 72, Clone 25, Gen 52)
18:31:09:Unit 02:
18:31:09:Unit 02:Entering M.D.
18:31:15:Unit 02:Using Gromacs checkpoints
18:31:15:Unit 02:Mapping NT from 4 to 4
18:31:15:Unit 02:Resuming from checkpoint
18:31:15:Unit 02:Verified 02/wudata_01.log
18:31:15:Unit 02:Verified 02/wudata_01.trr
18:31:16:Unit 02:Verified 02/wudata_01.xtc
18:31:16:Unit 02:Verified 02/wudata_01.edr
18:31:16:Unit 02:Completed 428676 out of 750000 steps  (57%)
18:31:19:Unit 01: 1.07%
18:31:45:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
18:31:45:SocketDevice::write(): Socket not open
18:31:45:WARNING: Exception: Failed to send results to work server: Upload failed
18:31:45:Trying to send results to collection server
18:31:45:Unit 00: Uploading 2.22MiB to 171.67.108.26
18:31:45:Connecting to 171.67.108.26:8080
18:31:58:WARNING: WorkServer connection failed on port 8080 trying 80
18:31:58:Connecting to 171.67.108.26:80
18:32:00:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
18:32:09:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
18:32:09:SocketDevice::write(): Socket not open
18:32:09:WARNING: Exception: Failed to send results to work server: Upload failed
18:32:09:Trying to send results to collection server
18:32:09:Unit 01: Uploading 2.19MiB to 171.67.108.26
18:32:09:Connecting to 171.67.108.26:8080
18:32:11:WARNING: WorkServer connection failed on port 8080 trying 80
18:32:11:Connecting to 171.67.108.26:80
18:32:13:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
18:32:35:Sending unit results: id:01 state:SEND error:OK project:7200 run:65 clone:37 gen:27 core:0xa4 unit:0x0000001c07ba4bae4da725b53aceab17
18:32:35:Unit 01: Uploading 2.19MiB to 129.64.95.82
18:32:35:Connecting to 129.64.95.82:8080
18:32:35:Sending unit results: id:00 state:SEND error:OK project:7200 run:15 clone:31 gen:23 core:0xa4 unit:0x0000001d07ba4bae4da71fc1f19b3814
18:32:35:Unit 00: Uploading 2.22MiB to 129.64.95.82
18:33:25:Unit 01: 0.89%
18:33:29:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
18:33:29:SocketDevice::write(): Socket not open
18:33:29:WARNING: Exception: Failed to send results to work server: Upload failed
18:33:29:Trying to send results to collection server
18:33:29:Unit 00: Uploading 2.22MiB to 171.67.108.26
18:33:29:Connecting to 171.67.108.26:8080
18:33:31:Unit 01: 1.61%
18:33:31:WARNING: WorkServer connection failed on port 8080 trying 80
18:33:31:Connecting to 171.67.108.26:80
18:33:33:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
18:34:04:Unit 02:Completed 435000 out of 750000 steps  (58%)
18:35:13:Sending unit results: id:00 state:SEND error:OK project:7200 run:15 clone:31 gen:23 core:0xa4 unit:0x0000001d07ba4bae4da71fc1f19b3814
18:35:13:Unit 00: Uploading 2.22MiB to 129.64.95.82
18:35:13:Connecting to 129.64.95.82:8080
18:36:54:SocketDevice::write(): Send error: 10053: An established connection was aborted by the software in your host machine.
18:36:54:SocketDevice::write(): Socket not open
18:36:54:WARNING: Exception: Failed to send results to work server: Upload failed
18:36:54:Trying to send results to collection server
18:36:54:Unit 00: Uploading 2.22MiB to 171.67.108.26
18:36:54:Connecting to 171.67.108.26:8080
18:36:55:WARNING: WorkServer connection failed on port 8080 trying 80
18:36:55:Connecting to 171.67.108.26:80
18:36:57:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
18:37:23:Unit 02:Completed 442500 out of 750000 steps  (59%)
18:39:27:Sending unit results: id:00 state:SEND error:OK project:7200 run:15 clone:31 gen:23 core:0xa4 unit:0x0000001d07ba4bae4da71fc1f19b3814
18:39:27:Unit 00: Uploading 2.22MiB to 129.64.95.82
18:39:27:Connecting to 129.64.95.82:8080
18:39:34:Unit 00: 0.88%
18:39:40:Unit 00: 1.41%
18:40:41:Unit 02:Completed 450000 out of 750000 steps  (60%)
18:40:50:SocketDevice::write(): Send error: 10053: An established connection was aborted by the software in your host machine.
18:40:50:SocketDevice::write(): Socket not open
18:40:50:WARNING: Exception: Failed to send results to work server: Upload failed
18:40:50:Trying to send results to collection server
18:40:50:Unit 01: Uploading 2.19MiB to 171.67.108.26
18:40:50:Connecting to 171.67.108.26:8080
18:40:52:WARNING: WorkServer connection failed on port 8080 trying 80
18:40:52:Connecting to 171.67.108.26:80
18:40:53:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
18:40:54:Sending unit results: id:01 state:SEND error:OK project:7200 run:65 clone:37 gen:27 core:0xa4 unit:0x0000001c07ba4bae4da725b53aceab17
18:40:54:Unit 01: Uploading 2.19MiB to 129.64.95.82
18:40:54:Connecting to 129.64.95.82:8080
18:41:01:Unit 01: 0.54%
18:41:03:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
18:41:03:SocketDevice::write(): Socket not open
18:41:03:WARNING: Exception: Failed to send results to work server: Upload failed
18:41:03:Trying to send results to collection server
18:41:03:Unit 00: Uploading 2.22MiB to 171.67.108.26
18:41:03:Connecting to 171.67.108.26:8080
18:41:05:WARNING: WorkServer connection failed on port 8080 trying 80
18:41:05:Connecting to 171.67.108.26:80
18:41:06:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
18:41:08:Unit 01: 2.32%
18:41:14:Unit 01: 3.75%
18:41:21:Unit 01: 5.53%
18:41:27:Unit 01: 6.60%
18:41:33:Unit 01: 7.67%
18:42:39:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
18:42:39:SocketDevice::write(): Socket not open
18:42:39:WARNING: Exception: Failed to send results to work server: Upload failed
18:42:39:Trying to send results to collection server
18:42:39:Unit 01: Uploading 2.19MiB to 171.67.108.26
18:42:39:Connecting to 171.67.108.26:8080
18:42:41:WARNING: WorkServer connection failed on port 8080 trying 80
18:42:41:Connecting to 171.67.108.26:80
18:42:43:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
18:43:58:Unit 02:Completed 457500 out of 750000 steps  (61%)
18:45:08:Sending unit results: id:01 state:SEND error:OK project:7200 run:65 clone:37 gen:27 core:0xa4 unit:0x0000001c07ba4bae4da725b53aceab17
18:45:08:Unit 01: Uploading 2.19MiB to 129.64.95.82
18:45:08:Connecting to 129.64.95.82:8080
18:45:58:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
18:45:58:SocketDevice::write(): Socket not open
18:45:58:WARNING: Exception: Failed to send results to work server: Upload failed
18:45:58:Trying to send results to collection server
18:45:58:Unit 01: Uploading 2.19MiB to 171.67.108.26
18:45:58:Connecting to 171.67.108.26:8080
18:46:00:WARNING: WorkServer connection failed on port 8080 trying 80
18:46:00:Connecting to 171.67.108.26:80
18:46:01:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
18:46:18:Sending unit results: id:00 state:SEND error:OK project:7200 run:15 clone:31 gen:23 core:0xa4 unit:0x0000001d07ba4bae4da71fc1f19b3814
18:46:18:Unit 00: Uploading 2.22MiB to 129.64.95.82
18:46:18:Connecting to 129.64.95.82:8080
18:46:29:Unit 00: 0.70%
18:47:17:Unit 02:Completed 465000 out of 750000 steps  (62%)
18:47:18:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
18:47:18:SocketDevice::write(): Socket not open
18:47:18:WARNING: Exception: Failed to send results to work server: Upload failed
18:47:18:Trying to send results to collection server
18:47:18:Unit 00: Uploading 2.22MiB to 171.67.108.26
18:47:18:Connecting to 171.67.108.26:8080
18:47:20:WARNING: WorkServer connection failed on port 8080 trying 80
18:47:20:Connecting to 171.67.108.26:80
18:47:21:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
18:50:37:Unit 02:Completed 472500 out of 750000 steps  (63%)
18:51:59:Sending unit results: id:01 state:SEND error:OK project:7200 run:65 clone:37 gen:27 core:0xa4 unit:0x0000001c07ba4bae4da725b53aceab17
18:51:59:Unit 01: Uploading 2.19MiB to 129.64.95.82
18:51:59:Connecting to 129.64.95.82:8080
18:53:55:Unit 02:Completed 480000 out of 750000 steps  (64%)
18:55:06:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
18:55:06:SocketDevice::write(): Socket not open
18:55:06:WARNING: Exception: Failed to send results to work server: Upload failed
18:55:06:Trying to send results to collection server
18:55:06:Unit 01: Uploading 2.19MiB to 171.67.108.26
18:55:06:Connecting to 171.67.108.26:8080
18:55:08:WARNING: WorkServer connection failed on port 8080 trying 80
18:55:08:Connecting to 171.67.108.26:80
18:55:09:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
18:57:14:Unit 02:Completed 487500 out of 750000 steps  (65%)
18:57:24:Sending unit results: id:00 state:SEND error:OK project:7200 run:15 clone:31 gen:23 core:0xa4 unit:0x0000001d07ba4bae4da71fc1f19b3814
18:57:24:Unit 00: Uploading 2.22MiB to 129.64.95.82
18:57:24:Connecting to 129.64.95.82:8080
18:59:29:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
18:59:29:SocketDevice::write(): Socket not open
18:59:29:WARNING: Exception: Failed to send results to work server: Upload failed
18:59:29:Trying to send results to collection server
18:59:29:Unit 00: Uploading 2.22MiB to 171.67.108.26
18:59:29:Connecting to 171.67.108.26:8080
18:59:31:WARNING: WorkServer connection failed on port 8080 trying 80
18:59:31:Connecting to 171.67.108.26:80
18:59:32:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
19:00:34:Unit 02:Completed 495000 out of 750000 steps  (66%)
19:03:05:Sending unit results: id:01 state:SEND error:OK project:7200 run:65 clone:37 gen:27 core:0xa4 unit:0x0000001c07ba4bae4da725b53aceab17
19:03:05:Unit 01: Uploading 2.19MiB to 129.64.95.82
19:03:05:Connecting to 129.64.95.82:8080
19:03:11:Unit 01: 1.43%
19:03:58:Unit 02:Completed 502500 out of 750000 steps  (67%)
19:04:14:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
19:04:14:SocketDevice::write(): Socket not open
19:04:14:WARNING: Exception: Failed to send results to work server: Upload failed
19:04:14:Trying to send results to collection server
19:04:14:Unit 01: Uploading 2.19MiB to 171.67.108.26
19:04:14:Connecting to 171.67.108.26:8080
19:04:16:WARNING: WorkServer connection failed on port 8080 trying 80
19:04:16:Connecting to 171.67.108.26:80
19:04:17:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
19:07:34:Unit 02:Completed 510000 out of 750000 steps  (68%)
19:10:55:Unit 02:Completed 517500 out of 750000 steps  (69%)
19:14:14:Unit 02:Completed 525000 out of 750000 steps  (70%)
19:15:21:Sending unit results: id:00 state:SEND error:OK project:7200 run:15 clone:31 gen:23 core:0xa4 unit:0x0000001d07ba4bae4da71fc1f19b3814
19:15:21:Unit 00: Uploading 2.22MiB to 129.64.95.82
19:15:21:Connecting to 129.64.95.82:8080
19:15:28:Unit 00: 0.53%
19:15:34:Unit 00: 1.41%
19:16:18:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
19:16:18:SocketDevice::write(): Socket not open
19:16:18:WARNING: Exception: Failed to send results to work server: Upload failed
19:16:18:Trying to send results to collection server
19:16:18:Unit 00: Uploading 2.22MiB to 171.67.108.26
19:16:18:Connecting to 171.67.108.26:8080
19:16:20:WARNING: WorkServer connection failed on port 8080 trying 80
19:16:20:Connecting to 171.67.108.26:80
19:16:21:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
19:17:34:Unit 02:Completed 532500 out of 750000 steps  (71%)
19:20:54:Unit 02:Completed 540000 out of 750000 steps  (72%)
19:21:01:Sending unit results: id:01 state:SEND error:OK project:7200 run:65 clone:37 gen:27 core:0xa4 unit:0x0000001c07ba4bae4da725b53aceab17
19:21:02:Unit 01: Uploading 2.19MiB to 129.64.95.82
19:21:02:Connecting to 129.64.95.82:8080
19:24:13:Unit 02:Completed 547500 out of 750000 steps  (73%)
19:25:31:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
19:25:31:SocketDevice::write(): Socket not open
19:25:31:WARNING: Exception: Failed to send results to work server: Upload failed
19:25:31:Trying to send results to collection server
19:25:31:Unit 01: Uploading 2.19MiB to 171.67.108.26
19:25:31:Connecting to 171.67.108.26:8080
19:25:33:WARNING: WorkServer connection failed on port 8080 trying 80
19:25:33:Connecting to 171.67.108.26:80
19:25:34:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
19:27:33:Unit 02:Completed 555000 out of 750000 steps  (74%)
19:30:53:Unit 02:Completed 562500 out of 750000 steps  (75%)
19:34:13:Unit 02:Completed 570000 out of 750000 steps  (76%)
19:37:32:Unit 02:Completed 577500 out of 750000 steps  (77%)
19:40:52:Unit 02:Completed 585000 out of 750000 steps  (78%)
19:44:11:Unit 02:Completed 592500 out of 750000 steps  (79%)
19:44:23:Sending unit results: id:00 state:SEND error:OK project:7200 run:15 clone:31 gen:23 core:0xa4 unit:0x0000001d07ba4bae4da71fc1f19b3814
19:44:23:Unit 00: Uploading 2.22MiB to 129.64.95.82
19:44:23:Connecting to 129.64.95.82:8080
19:45:09:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
19:45:09:SocketDevice::write(): Socket not open
19:45:09:WARNING: Exception: Failed to send results to work server: Upload failed
19:45:09:Trying to send results to collection server
19:45:09:Unit 00: Uploading 2.22MiB to 171.67.108.26
19:45:09:Connecting to 171.67.108.26:8080
19:45:11:WARNING: WorkServer connection failed on port 8080 trying 80
19:45:11:Connecting to 171.67.108.26:80
19:45:12:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
19:47:30:Unit 02:Completed 600000 out of 750000 steps  (80%)
19:50:04:Sending unit results: id:01 state:SEND error:OK project:7200 run:65 clone:37 gen:27 core:0xa4 unit:0x0000001c07ba4bae4da725b53aceab17
19:50:04:Unit 01: Uploading 2.19MiB to 129.64.95.82
19:50:04:Connecting to 129.64.95.82:8080
19:50:10:Unit 01: 2.14%
19:50:29:Unit 01: 2.86%
19:50:49:Unit 02:Completed 607500 out of 750000 steps  (81%)
19:54:08:Unit 02:Completed 615000 out of 750000 steps  (82%)
19:55:10:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
19:55:10:SocketDevice::write(): Socket not open
19:55:10:WARNING: Exception: Failed to send results to work server: Upload failed
19:55:10:Trying to send results to collection server
19:55:10:Unit 01: Uploading 2.19MiB to 171.67.108.26
19:55:10:Connecting to 171.67.108.26:8080
19:55:11:WARNING: WorkServer connection failed on port 8080 trying 80
19:55:11:Connecting to 171.67.108.26:80
19:55:13:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
19:57:27:Unit 02:Completed 622500 out of 750000 steps  (83%)
20:00:46:Unit 02:Completed 630000 out of 750000 steps  (84%)
20:04:04:Unit 02:Completed 637500 out of 750000 steps  (85%)
20:07:23:Unit 02:Completed 645000 out of 750000 steps  (86%)
20:10:42:Unit 02:Completed 652500 out of 750000 steps  (87%)
20:14:01:Unit 02:Completed 660000 out of 750000 steps  (88%)
20:17:20:Unit 02:Completed 667500 out of 750000 steps  (89%)
20:20:38:Unit 02:Completed 675000 out of 750000 steps  (90%)
20:23:56:Unit 02:Completed 682500 out of 750000 steps  (91%)
20:27:15:Unit 02:Completed 690000 out of 750000 steps  (92%)
20:30:34:Unit 02:Completed 697500 out of 750000 steps  (93%)
20:31:21:Sending unit results: id:00 state:SEND error:OK project:7200 run:15 clone:31 gen:23 core:0xa4 unit:0x0000001d07ba4bae4da71fc1f19b3814
20:31:22:Unit 00: Uploading 2.22MiB to 129.64.95.82
20:31:22:Connecting to 129.64.95.82:8080
20:31:30:Unit 00: 0.70%
20:33:52:Unit 02:Completed 705000 out of 750000 steps  (94%)
20:35:37:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
20:35:37:SocketDevice::write(): Socket not open
20:35:37:WARNING: Exception: Failed to send results to work server: Upload failed
20:35:37:Trying to send results to collection server
20:35:37:Unit 00: Uploading 2.22MiB to 171.67.108.26
20:35:37:Connecting to 171.67.108.26:8080
20:35:38:WARNING: WorkServer connection failed on port 8080 trying 80
20:35:38:Connecting to 171.67.108.26:80
20:35:40:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
20:37:03:Sending unit results: id:01 state:SEND error:OK project:7200 run:65 clone:37 gen:27 core:0xa4 unit:0x0000001c07ba4bae4da725b53aceab17
20:37:03:Unit 01: Uploading 2.19MiB to 129.64.95.82
20:37:03:Connecting to 129.64.95.82:8080
20:37:11:Unit 02:Completed 712500 out of 750000 steps  (95%)
20:37:31:Unit 01: 0.89%
20:40:16:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
20:40:16:SocketDevice::write(): Socket not open
20:40:16:WARNING: Exception: Failed to send results to work server: Upload failed
20:40:16:Trying to send results to collection server
20:40:16:Unit 01: Uploading 2.19MiB to 171.67.108.26
20:40:16:Connecting to 171.67.108.26:8080
20:40:17:WARNING: WorkServer connection failed on port 8080 trying 80
20:40:17:Connecting to 171.67.108.26:80
20:40:19:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
20:40:30:Unit 02:Completed 720000 out of 750000 steps  (96%)
20:43:48:Unit 02:Completed 727500 out of 750000 steps  (97%)
20:47:06:Unit 02:Completed 735000 out of 750000 steps  (98%)
20:50:25:Unit 02:Completed 742500 out of 750000 steps  (99%)
20:50:25:Connecting to assign3.stanford.edu:8080
20:50:26:News: Welcome to Folding@Home
20:50:26:Assigned to work server 129.64.95.82
20:50:26:Requesting new work unit for slot 01: RUNNING smp:4 from 129.64.95.82
20:50:26:Connecting to 129.64.95.82:8080
20:50:27:Slot 01: Downloading 648.63KiB
20:50:31:Slot 01: Download complete
20:50:31:Received Unit: id:03 state:DOWNLOAD error:OK project:7200 run:37 clone:7 gen:71 core:0xa4 unit:0x0000004c07ba4bae4da7224e826fb391
20:53:44:Unit 02:Completed 750000 out of 750000 steps  (100%)
20:53:44:Unit 02:DynamicWrapper: Finished Work Unit: sleep=10000
20:53:54:Unit 02:
20:53:54:Unit 02:Finished Work Unit:
20:53:54:Unit 02:- Reading up to 1152288 from "02/wudata_01.trr": Read 1152288
20:53:54:Unit 02:trr file hash check passed.
20:53:54:Unit 02:- Reading up to 1123616 from "02/wudata_01.xtc": Read 1123616
20:53:54:Unit 02:xtc file hash check passed.
20:53:54:Unit 02:edr file hash check passed.
20:53:54:Unit 02:logfile size: 137935
20:53:54:Unit 02:Leaving Run
20:53:57:Unit 02:- Writing 2522343 bytes of core data to disk...
20:53:58:Unit 02:Done: 2521831 -> 2327104 (compressed to 92.2 percent)
20:53:58:Unit 02:  ... Done.
20:53:58:Unit 02:- Shutting down core
20:53:58:Unit 02:
20:53:58:Unit 02:Folding@home Core Shutdown: FINISHED_UNIT
20:53:59:FahCore, running Unit 02, returned: FINISHED_UNIT (100 = 0x64)
20:53:59:Sending unit results: id:02 state:SEND error:OK project:7200 run:72 clone:25 gen:52 core:0xa4 unit:0x0000003a07ba4bae4da726841b9a5948
20:53:59:Unit 02: Uploading 2.22MiB to 129.64.95.82
20:53:59:Starting Unit 03
20:53:59:Connecting to 129.64.95.82:8080
20:53:59:Running core: C:/Users/Gary/AppData/Roaming/FAHClient/cores/www.stanford.edu/~pande/Win32/AMD64/Core_a4.fah/FahCore_a4.exe -dir 03 -suffix 01 -lifeline 7984 -version 701 -checkpoint 3 -np 4
20:53:59:Started core on PID 9300
20:53:59:FahCore 0xa4 started
20:53:59:Started thread 12 on PID 7984
20:54:00:Unit 03:
20:54:00:Unit 03:*------------------------------*
20:54:00:Unit 03:Folding@Home Gromacs GB Core
20:54:00:Unit 03:Version 2.27 (Dec. 15, 2010)
20:54:00:Unit 03:
20:54:00:Unit 03:Preparing to commence simulation
20:54:00:Unit 03:- Looking at optimizations...
20:54:00:Unit 03:- Created dyn
20:54:00:Unit 03:- Files status OK
20:54:00:Unit 03:- Expanded 663687 -> 1297016 (decompressed 195.4 percent)
20:54:00:Unit 03:Called DecompressByteArray: compressed_data_size=663687 data_size=1297016, decompressed_data_size=1297016 diff=0
20:54:00:Unit 03:- Digital signature verified
20:54:00:Unit 03:
20:54:00:Unit 03:Project: 7200 (Run 37, Clone 7, Gen 71)
20:54:00:Unit 03:
20:54:00:Unit 03:Assembly optimizations on if available.
20:54:00:Unit 03:Entering M.D.
20:54:06:Unit 03:Mapping NT from 4 to 4
20:54:06:Unit 03:Completed 0 out of 750000 steps  (0%)
20:54:35:Unit 02: 0.53%
20:57:23:Unit 03:Completed 7500 out of 750000 steps  (1%)
20:57:35:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
20:57:35:SocketDevice::write(): Socket not open
20:57:35:WARNING: Exception: Failed to send results to work server: Upload failed
20:57:35:Trying to send results to collection server
20:57:35:Unit 02: Uploading 2.22MiB to 171.67.108.26
20:57:35:Connecting to 171.67.108.26:8080
20:57:36:WARNING: WorkServer connection failed on port 8080 trying 80
20:57:36:Connecting to 171.67.108.26:80
20:57:38:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
20:57:38:Sending unit results: id:02 state:SEND error:OK project:7200 run:72 clone:25 gen:52 core:0xa4 unit:0x0000003a07ba4bae4da726841b9a5948
20:57:38:Unit 02: Uploading 2.22MiB to 129.64.95.82
20:57:38:Connecting to 129.64.95.82:8080
20:58:10:Unit 02: 0.53%
21:00:39:Unit 03:Completed 15000 out of 750000 steps  (2%)
21:03:55:Unit 03:Completed 22500 out of 750000 steps  (3%)
21:04:01:SocketDevice::write(): Send error: 10053: An established connection was aborted by the software in your host machine.
21:04:01:SocketDevice::write(): Socket not open
21:04:01:WARNING: Exception: Failed to send results to work server: Upload failed
21:04:01:Trying to send results to collection server
21:04:01:Unit 02: Uploading 2.22MiB to 171.67.108.26
21:04:01:Connecting to 171.67.108.26:8080
21:04:03:WARNING: WorkServer connection failed on port 8080 trying 80
21:04:03:Connecting to 171.67.108.26:80
21:04:04:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
21:04:04:Sending unit results: id:02 state:SEND error:OK project:7200 run:72 clone:25 gen:52 core:0xa4 unit:0x0000003a07ba4bae4da726841b9a5948
21:04:04:Unit 02: Uploading 2.22MiB to 129.64.95.82
21:04:04:Connecting to 129.64.95.82:8080
21:04:14:Unit 02: 0.53%
21:05:17:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
21:05:17:SocketDevice::write(): Socket not open
21:05:17:WARNING: Exception: Failed to send results to work server: Upload failed
21:05:17:Trying to send results to collection server
21:05:17:Unit 02: Uploading 2.22MiB to 171.67.108.26
21:05:17:Connecting to 171.67.108.26:8080
21:05:19:WARNING: WorkServer connection failed on port 8080 trying 80
21:05:19:Connecting to 171.67.108.26:80
21:05:20:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
21:05:41:Sending unit results: id:02 state:SEND error:OK project:7200 run:72 clone:25 gen:52 core:0xa4 unit:0x0000003a07ba4bae4da726841b9a5948
21:05:41:Unit 02: Uploading 2.22MiB to 129.64.95.82
21:05:41:Connecting to 129.64.95.82:8080
21:06:00:Unit 02: 0.53%
21:07:12:Unit 03:Completed 30000 out of 750000 steps  (4%)
21:09:10:SocketDevice::write(): Send error: 10053: An established connection was aborted by the software in your host machine.
21:09:10:SocketDevice::write(): Socket not open
21:09:10:WARNING: Exception: Failed to send results to work server: Upload failed
21:09:10:Trying to send results to collection server
21:09:10:Unit 02: Uploading 2.22MiB to 171.67.108.26
21:09:10:Connecting to 171.67.108.26:8080
21:09:11:WARNING: WorkServer connection failed on port 8080 trying 80
21:09:12:Connecting to 171.67.108.26:80
21:09:13:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
21:09:13:Sending unit results: id:02 state:SEND error:OK project:7200 run:72 clone:25 gen:52 core:0xa4 unit:0x0000003a07ba4bae4da726841b9a5948
21:09:13:Unit 02: Uploading 2.22MiB to 129.64.95.82
21:09:13:Connecting to 129.64.95.82:8080
21:10:08:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
21:10:08:SocketDevice::write(): Socket not open
21:10:08:WARNING: Exception: Failed to send results to work server: Upload failed
21:10:08:Trying to send results to collection server
21:10:08:Unit 02: Uploading 2.22MiB to 171.67.108.26
21:10:08:Connecting to 171.67.108.26:8080
21:10:10:WARNING: WorkServer connection failed on port 8080 trying 80
21:10:10:Connecting to 171.67.108.26:80
21:10:11:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
21:10:29:Unit 03:Completed 37500 out of 750000 steps  (5%)
21:13:27:Sending unit results: id:02 state:SEND error:OK project:7200 run:72 clone:25 gen:52 core:0xa4 unit:0x0000003a07ba4bae4da726841b9a5948
21:13:28:Unit 02: Uploading 2.22MiB to 129.64.95.82
21:13:28:Connecting to 129.64.95.82:8080
21:13:46:Unit 03:Completed 45000 out of 750000 steps  (6%)
21:17:02:Unit 03:Completed 52500 out of 750000 steps  (7%)
21:17:36:SocketDevice::write(): Send error: 10053: An established connection was aborted by the software in your host machine.
21:17:36:SocketDevice::write(): Socket not open
21:17:36:WARNING: Exception: Failed to send results to work server: Upload failed
21:17:36:Trying to send results to collection server
21:17:36:Unit 02: Uploading 2.22MiB to 171.67.108.26
21:17:36:Connecting to 171.67.108.26:8080
21:17:38:WARNING: WorkServer connection failed on port 8080 trying 80
21:17:38:Connecting to 171.67.108.26:80
21:17:40:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
21:20:18:Unit 03:Completed 60000 out of 750000 steps  (8%)
21:20:19:Sending unit results: id:02 state:SEND error:OK project:7200 run:72 clone:25 gen:52 core:0xa4 unit:0x0000003a07ba4bae4da726841b9a5948
21:20:19:Unit 02: Uploading 2.22MiB to 129.64.95.82
21:20:19:Connecting to 129.64.95.82:8080
21:21:18:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
21:21:18:SocketDevice::write(): Socket not open
21:21:18:WARNING: Exception: Failed to send results to work server: Upload failed
21:21:18:Trying to send results to collection server
21:21:18:Unit 02: Uploading 2.22MiB to 171.67.108.26
21:21:18:Connecting to 171.67.108.26:8080
21:21:20:WARNING: WorkServer connection failed on port 8080 trying 80
21:21:20:Connecting to 171.67.108.26:80
21:21:22:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
21:23:34:Unit 03:Completed 67500 out of 750000 steps  (9%)
21:26:51:Unit 03:Completed 75000 out of 750000 steps  (10%)
21:30:07:Unit 03:Completed 82500 out of 750000 steps  (11%)
21:31:24:Sending unit results: id:02 state:SEND error:OK project:7200 run:72 clone:25 gen:52 core:0xa4 unit:0x0000003a07ba4bae4da726841b9a5948
21:31:25:Unit 02: Uploading 2.22MiB to 129.64.95.82
21:31:25:Connecting to 129.64.95.82:8080
21:32:18:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
21:32:18:SocketDevice::write(): Socket not open
21:32:18:WARNING: Exception: Failed to send results to work server: Upload failed
21:32:18:Trying to send results to collection server
21:32:18:Unit 02: Uploading 2.22MiB to 171.67.108.26
21:32:18:Connecting to 171.67.108.26:8080
21:32:19:WARNING: WorkServer connection failed on port 8080 trying 80
21:32:19:Connecting to 171.67.108.26:80
21:32:21:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
21:33:23:Unit 03:Completed 90000 out of 750000 steps  (12%)
21:36:38:Unit 03:Completed 97500 out of 750000 steps  (13%)
21:39:58:Unit 03:Completed 105000 out of 750000 steps  (14%)
21:43:38:Unit 03:Completed 112500 out of 750000 steps  (15%)
21:46:54:Unit 03:Completed 120000 out of 750000 steps  (16%)
21:47:22:Sending unit results: id:00 state:SEND error:OK project:7200 run:15 clone:31 gen:23 core:0xa4 unit:0x0000001d07ba4bae4da71fc1f19b3814
21:47:22:Unit 00: Uploading 2.22MiB to 129.64.95.82
21:47:23:Connecting to 129.64.95.82:8080
21:47:37:Unit 00: 0.53%
21:47:44:Unit 00: 0.70%
21:49:21:Sending unit results: id:02 state:SEND error:OK project:7200 run:72 clone:25 gen:52 core:0xa4 unit:0x0000003a07ba4bae4da726841b9a5948
21:49:21:Unit 02: Uploading 2.22MiB to 129.64.95.82
21:49:21:Connecting to 129.64.95.82:8080
21:50:09:Unit 03:Completed 127500 out of 750000 steps  (17%)
21:51:32:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
21:51:32:SocketDevice::write(): Socket not open
21:51:32:WARNING: Exception: Failed to send results to work server: Upload failed
21:51:32:Trying to send results to collection server
21:51:32:Unit 00: Uploading 2.22MiB to 171.67.108.26
21:51:32:Connecting to 171.67.108.26:8080
21:51:34:WARNING: WorkServer connection failed on port 8080 trying 80
21:51:34:Connecting to 171.67.108.26:80
21:51:35:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
21:52:13:SocketDevice::write(): Send error: 10053: An established connection was aborted by the software in your host machine.
21:52:13:SocketDevice::write(): Socket not open
21:52:13:WARNING: Exception: Failed to send results to work server: Upload failed
21:52:13:Trying to send results to collection server
21:52:13:Unit 02: Uploading 2.22MiB to 171.67.108.26
21:52:13:Connecting to 171.67.108.26:8080
21:52:15:WARNING: WorkServer connection failed on port 8080 trying 80
21:52:15:Connecting to 171.67.108.26:80
21:52:16:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
21:53:03:Sending unit results: id:01 state:SEND error:OK project:7200 run:65 clone:37 gen:27 core:0xa4 unit:0x0000001c07ba4bae4da725b53aceab17
21:53:04:Unit 01: Uploading 2.19MiB to 129.64.95.82
21:53:04:Connecting to 129.64.95.82:8080
21:53:26:Unit 03:Completed 135000 out of 750000 steps  (18%)
21:54:01:SocketDevice::write(): Send error: 10054: An existing connection was forcibly closed by the remote host.
21:54:01:SocketDevice::write(): Socket not open
21:54:01:WARNING: Exception: Failed to send results to work server: Upload failed
21:54:01:Trying to send results to collection server
21:54:02:Unit 01: Uploading 2.19MiB to 171.67.108.26
21:54:02:Connecting to 171.67.108.26:8080
21:54:03:WARNING: WorkServer connection failed on port 8080 trying 80
21:54:03:Connecting to 171.67.108.26:80
21:54:05:ERROR: Exception: Failed to connect to 171.67.108.26:80: No connection could be made because the target machine actively refused it.
Re: 129.64.95.82 Haven't been able to upload finished projec
Welcome to foldingforum.org, Meh_Lay_Lay.
First of all, ignore all messages associated with 171.67.108.26. That's a collection server. See Troubleshooting Server Connectivity Issues (Do This First) at the top of this forum for more information.
The other messages all appear to be associated with 129.64.95.82 I'll add that to the title of this topic and merge your post into the topic that's already discussing the issue. You'll see (above) that Dan has already been working on this issue but apparently the problem still exists.
jackamo
Post by jackamo »
Meh_lay_lay...I've been having issues for over 3 weeks...still can't download anything. I've been in idle. Just patiently waiting for things to be fixed.
