help with pc optimizing
astar
- Hardware configuration: OS Name Microsoft Windows 7 Home Premium 64
Version 6.1.7601 Service Pack 1 Build 7601
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name XXXXX
System Manufacturer eMachines
System Model ET1331G
System Type x64-based PC
Processor AMD Athlon(tm) II X2 250u Processor, 1600 Mhz, 2 Core(s), 2 Logical Processor(s)
BIOS Version/Date AMI P01-A2, 12/10/2009
SMBIOS Version 2.6
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume2
Locale United States
Hardware Abstraction Layer Version = "6.1.7601.17514"
User Name XXXXXXXXX
Time Zone Pacific Daylight Time
Installed Physical Memory (RAM) 4.00 GB
Total Physical Memory 4.00 GB
Available Physical Memory 2.36 GB
Total Virtual Memory 8.00 GB
Available Virtual Memory 5.65 GB
Page File Space 4.00 GB
Page File C:\pagefile.sys - Contact:
I wounder if anybody is even interested in helping
astar
System Name XXXXX
SMBIOS Version 2.6
User Name XXXXXXXXX
how can i find out if my pc is fully optimized for your use . i am running a amd 2x2 windows7 pc and dont know if its running at it full potential how can i check thank you
Re: help with pc optimizing
Welcome to foldingforum.org, astar.
Please don't get discouraged before we have a chance to read your comments. The forum has anti-spam procedures which make getting started take longer than it should, particularly when your first post says nothing about FAH. Add to that the fact that there's are very few people on the forum during much of the night (We're all volunteers here), and it can take some time to get a response.
I'm not sure what an amd 22 pc is so I'll need more information to help you. Please provide us with a more detailed hardware description. Also tell us which client you have installed and post the log that will tell us how the client is configured.
astar
System Name XXXXX
SMBIOS Version 2.6
User Name XXXXXXXXX
System Name ASTAR-PC
SMBIOS Version 2.6
User Name astar-PC\astar
Available Physical Memory 2.37 GB
Available Virtual Memory 5.67 GB
[23:47:56] Completed 100%
[23:47:57] Successful run
[23:47:57] DynamicWrapper: Finished Work Unit: sleep=10000
[23:48:07] Reserved 108960 bytes for xtc file; Cosm status=0
[23:48:07] Allocated 108960 bytes for xtc file
[23:48:07] - Reading up to 108960 from "work/wudata_05.xtc": Read 108960
[23:48:07] Read 108960 bytes from xtc file; available packet space=786321504
[23:48:07] xtc file hash check passed.
[23:48:07] Reserved 21912 21912 786321504 bytes for arc file=<work/wudata_05.trr> Cosm status=0
[23:48:07] Allocated 21912 bytes for arc file
[23:48:07] - Reading up to 21912 from "work/wudata_05.trr": Read 21912
[23:48:07] Read 21912 bytes from arc file; available packet space=786299592
[23:48:07] trr file hash check passed.
[23:48:07] Allocated 560 bytes for edr file
[23:48:07] Read bedfile
[23:48:07] edr file hash check passed.
[23:48:07] Allocated 37084 bytes for logfile
[23:48:07] Read logfile
[23:48:07] GuardedRun: success in DynamicWrapper
[23:48:07] GuardedRun: done
[23:48:07] Run: GuardedRun completed.
[23:48:10] + Opened results file
[23:48:10] - Writing 169028 bytes of core data to disk...
[23:48:10] Done: 168516 -> 139810 (compressed to 82.9 percent)
[23:48:10] ... Done.
[23:48:10] DeleteFrameFiles: successfully deleted file=work/wudata_05.ckp
[23:48:10] Shutting down core
[23:48:10]
[23:48:10] Folding@home Core Shutdown: FINISHED_UNIT
[23:48:14] CoreStatus = 64 (100)
[23:48:14] Sending work to server
[23:48:14] Project: 10506 (Run 0, Clone 295, Gen 34)
[23:48:14] + Attempting to send results [October 29 23:48:14 UTC]
[23:48:14] Gpu type=2 species=12.
[23:48:16] + Results successfully sent
[23:48:16] Thank you for your contribution to Folding@Home.
[23:48:16] + Starting local stats count at 1
[23:48:20] - Preparing to get new work unit...
[23:48:20] Cleaning up work directory
[23:48:20] + Attempting to get work packet
[23:48:20] Gpu type=2 species=12.
[23:48:20] - Connecting to assignment server
[23:48:21] - Successful: assigned to (171.64.65.61).
[23:48:21] + News From Folding@Home: Welcome to Folding@Home
[23:48:21] Loaded queue successfully.
[23:48:21] Gpu type=2 species=12.
[23:48:22] + Closed connections
[23:48:22]
[23:48:22] + Processing work unit
[23:48:22] Core required: FahCore_11.exe
[23:48:22] Core found.
[23:48:22] Working on queue slot 06 [October 29 23:48:22 UTC]
[23:48:22] + Working ...
[23:48:22]
[23:48:22] *------------------------------*
[23:48:22] Folding@Home GPU Core
[23:48:22] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[23:48:22]
[23:48:22] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[23:48:22] Build host: amoeba
[23:48:22] Board Type: Nvidia
[23:48:22] Core :
[23:48:22] Preparing to commence simulation
[23:48:22] - Looking at optimizations...
[23:48:22] DeleteFrameFiles: successfully deleted file=work/wudata_06.ckp
[23:48:22] - Created dyn
[23:48:22] - Files status OK
[23:48:22] - Expanded 73888 -> 383588 (decompressed 519.1 percent)
[23:48:22] Called DecompressByteArray: compressed_data_size=73888 data_size=383588, decompressed_data_size=383588 diff=0
[23:48:22] - Digital signature verified
[23:48:22]
[23:48:22] Project: 6600 (Run 0, Clone 388, Gen 542)
[23:48:22]
[23:48:22] Assembly optimizations on if available.
[23:48:22] Entering M.D.
[23:48:28] Tpr hash work/wudata_06.tpr: 2862868679 3031524270 1911028513 252802710 3929897744
[23:48:28]
[23:48:28] Calling fah_main args: 14 usage=100
[23:48:28]
SMBIOS Version 2.6
[23:48:10]
[23:48:22]
[23:48:22]
[23:48:22]
[23:48:22] Core :
[23:48:22]
[23:48:22]
[23:48:28]
[23:48:28]
astar
System Name XXXXX
SMBIOS Version 2.6
User Name XXXXXXXXX
WOW didnt mean to put all that in there but hope its what someone needs to help with all my lag problems.
Zagen30
You didn't mention any lag problems in your previous posts. What's going on?
Regarding your original question of what's the best setup for your machine, I'd recommend 2 uniprocessor clients and 1 GPU client (assuming you don't have more than 1 GPU). It looks like the GPU client is already taken care of. Your Athlon II X2 is somewhat marginal for SMP units if you don't fold 24/7, but it should be able to handle a uniprocessor unit on each core.
If you're pasting a lot of text you should put it inside Code tags, which will condense everything into a scrollable window and keep the physical size of your post small.
