Project: 7013 (Run 0, Clone 56, Gen 17)
bollix47
Post by bollix47 »
FYI
This WU is progressing very slowly. On previous P7013 WUs the TPF was less than 7min but for this one the TPF is over 28min. Same Project, same client, same cpu. Other clients currently running on the computer are showing no signs of slowing down and the previous WU ran fine.
I realize that different projects can result in a wide range of TPFs but, on the same project four times the rate seems a bit high.
I'm letting it continue but if someone can please check the DB to see if there are any reports that might suggest the WU is problematic. Thanks.
[12:09:07] + Attempting to get work packet
[12:09:07] Passkey found
[12:09:07] - Will indicate memory of 8168 MB
[12:09:07] - Connecting to assignment server
[12:09:07] Connecting to http://assign.stanford.edu:8080/
[12:09:08] Posted data.
[12:09:08] Initial: 4A81; - Successful: assigned to (129.74.85.15).
[12:09:08] + News From Folding@Home: Welcome to Folding@Home
[12:09:08] Loaded queue successfully.
[12:09:08] Sent data
[12:09:08] Connecting to http://129.74.85.15:8080/
[12:09:09] Posted data.
[12:09:09] Initial: 0000; - Receiving payload (expected size: 39182)
[12:09:09] Conversation time very short, giving reduced weight in bandwidth avg
[12:09:09] - Downloaded at ~76 kB/s
[12:09:09] - Averaged speed for that direction ~166 kB/s
[12:09:09] + Received work.
[12:09:09] Trying to send all finished work units
[12:09:09] + No unsent completed units remaining.
[12:09:09] + Closed connections
[12:09:09]
[12:09:09] + Processing work unit
[12:09:09] Core required: FahCore_a4.exe
[12:09:09] Core found.
[12:09:09] Working on queue slot 05 [August 8 12:09:09 UTC]
[12:09:09] + Working ...
[12:09:09] - Calling '.\FahCore_a4.exe -dir work/ -nice 19 -suffix 05 -np 0 -priority 96 -checkpoint 30 -verbose -lifeline 2436 -version 634'
[12:09:09]
[12:09:09] *------------------------------*
[12:09:09] Folding@Home Gromacs GB Core
[12:09:09] Version 2.27 (Dec. 15, 2010)
[12:09:09]
[12:09:09] Preparing to commence simulation
[12:09:09] - Looking at optimizations...
[12:09:09] - Created dyn
[12:09:09] - Files status OK
[12:09:09] - Expanded 38670 -> 198568 (decompressed 513.4 percent)
[12:09:09] Called DecompressByteArray: compressed_data_size=38670 data_size=198568, decompressed_data_size=198568 diff=0
[12:09:09] - Digital signature verified
[12:09:09]
[12:09:09] Project: 7013 (Run 0, Clone 56, Gen 17)
[12:09:09]
[12:09:09] Assembly optimizations on if available.
[12:09:09] Entering M.D.
[12:09:15] Mapping NT from 1 to 1
[12:09:15] Completed 0 out of 10000000 steps  (0%)
[12:37:41] Completed 100000 out of 10000000 steps  (1%)
[13:06:01] Completed 200000 out of 10000000 steps  (2%)
[13:34:22] Completed 300000 out of 10000000 steps  (3%)
[14:02:43] Completed 400000 out of 10000000 steps  (4%)
Re: Project: 7013 (Run 0, Clone 56, Gen 17)
If a project runs "slow" I wouldn't expect to see any indication of a problem in the Mod DB. We can only see records where WUs were returned by the client.
Gen 16 was added to the stats database on 2011-08-08 02:09:23 PDT which would be 09:09 UTC which is consistent with Gen 17 being assigned to you a few hours later at [August 8 12:09:09 UTC] The FAH server has assigned this WU to only you, and you haven't uploaded any results yet so there's nothing to report.
