Proj:6900 Run 7 Clone 0 Gen 10 "Srvr reports prob with unit"
MNParadox
Post by MNParadox »
Username: MNParadox
Team: 111065
I completed "Project: 6900 (Run 7, Clone 0, Gen 10)" and when the client was trying to upload the data, the logfile states "[21:23:47] - Server reports problem with unit."
Here's the end of the logfile:
[20:30:02] Completed 250000 out of 250000 steps  (100%)
[20:30:11] DynamicWrapper: Finished Work Unit: sleep=10000
[20:30:21]
[20:30:21] Finished Work Unit:
[20:30:21] - Reading up to 52713120 from "work/wudata_01.trr": Read 52713120
[20:30:21] trr file hash check passed.
[20:30:21] - Reading up to 46991788 from "work/wudata_01.xtc": Read 46991788
[20:30:21] xtc file hash check passed.
[20:30:21] edr file hash check passed.
[20:30:21] logfile size: 209985
[20:30:21] Leaving Run
[20:30:26] - Writing 100084841 bytes of core data to disk...
[20:30:26]   ... Done.
[20:51:48] - Autosending finished units... [July 10 20:51:48 UTC]
[20:51:48] Trying to send all finished work units
[20:51:48] + No unsent completed units remaining.
[20:51:48] - Autosend completed
[21:13:35] - Shutting down core
[21:13:35]
[21:13:35] Folding@home Core Shutdown: FINISHED_UNIT
[21:17:40] CoreStatus = 64 (100)
[21:17:40] Unit 1 finished with 56 percent of time to deadline remaining.
[21:17:40] Updated performance fraction: 0.556549
[21:17:40] Sending work to server
[21:17:40] Project: 6900 (Run 7, Clone 0, Gen 10)
[21:17:40] + Attempting to send results [July 10 21:17:40 UTC]
[21:17:40] - Reading file work/wuresults_01.dat from core
[21:17:40]   (Read 100084841 bytes from disk)
[21:17:40] Connecting to http://130.237.232.141:8080/
[21:23:47] Posted data.
[21:23:47] Initial: 0000; - Uploaded at ~266 kB/s
[21:23:47] - Averaged speed for that direction ~266 kB/s
[21:23:47] Trying to send all finished work units
[21:23:47] + No unsent completed units remaining.
[21:23:47] + -oneunit flag given and have now finished a unit. Exiting.- Preparing to get new work unit...
[21:23:47] Cleaning up work directory
[21:23:47] ***** Got a SIGTERM signal (15)
[21:23:47] Killing all core threads
Folding@Home Client Shutdown.
I tried running a "-send all" command but nothing happens.
Suggestions on how to proceed since: :Due time: July 14 05:26:15"?
Thanks!
Re: 6900 - Uploading - "Server reports problem with unit"
Something very strange is going on with project 6900. I need to check with the project owner.
MNParadox
Post by MNParadox »
I backed the files up for safe keeping and I started folding another 6900 WU. If there is a way to send in the WU that I processed other than through the client, please let me know and I'll send it along.
The client is the only way to return the WU.
The message "server reports a problem with unit" generally means that the WU is corrupt or has expired and in either case, there's nothing you can do to convince the server to accept it.
The "very strange" comment that I made refers is about the data in the Mod DataBase and there's very little chance that I'm going to be able to tell you anything about the WU. Nevertheless, I'll mark this topic for followup and I'll change the title to conform to the recommended format.
MNParadox
Post by MNParadox »
bruce wrote:The client is the only way to return the WU.
Well, since it won't upload using the client, it looks like I may as well delete the backup files then.
bruce wrote:The "very strange" comment that I made refers is about the data in the Mod DataBase and there's very little chance that I'm going to be able to tell you anything about the WU. Nevertheless, I'll mark this topic for followup and I'll change the title to conform to the recommended format.
Sorry about the format. This thread was my first time posting on this form. I'll follow the format in the future. I assume that the points for that WU are lost as well?
Thanks for your help!
-Greg
Re: Proj:6900 Run 7 Clone 0 Gen 10 "Srvr reports prob with u
No problem about the title ....
Yes, unless the client can upload the results to the server, there will be no credit in the stats.
MNParadox
Post by MNParadox »
bruce wrote:Yes, unless the client can upload the results to the server, there will be no credit in the stats.
Any tips/tricks on how to do this?
I have another PC that hasn't done any folding. The WU completed on a Linux PC (that is currently folding another bigadv WU, it's my dedicated folding system) and my other PC has Windows 7. Can I install the client on the Windows 7 PC, copy the WU information into the folder and try the "-send all" flag again? Or am I going to run into issues because of different OS, clients, etc?
It's hightly unlikely that a Linux > Windows transfer would work. Even if it did, the WU would still be unacceptable to the server for the very same reason.
MNParadox
Post by MNParadox »
OK, thank you for the info. I'll just delete out the files then since I won't be able to try uploading them until after the expiration date. :(
Following the timeout of your assignment, the WU was reassigned and it was completed successfully.
WU (P6900 R7 C0 G10) was added to the stats database on 2011-07-14 18:09:13 for 65908.8 points of credit.
I conclude that the WU was somehow corrupted while running on your system and the server rejected it for cause -- though I have no way of knowing what happened.
