Project: 6501 (Run 8, Clone 7, Gen 62) Bad WU?
daveb
Post by daveb »
This unit immediately EUE'd with a Gromacs error (Client-core communications error: ERROR 0x79). The unit was not deleted. I also noted that the download was unusually small for a 6501 (~146k vs the normal ~750k).
[04:13:40] + Attempting to get work packet
[04:13:40] - Will indicate memory of 1015 MB
[04:13:40] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 13, Stepping: 8
[04:13:40] - Connecting to assignment server
[04:13:40] Connecting to http://assign.stanford.edu:8080/
[04:13:40] Posted data.
[04:13:40] Initial: 40AB; - Successful: assigned to (171.64.65.62).
[04:13:40] + News From Folding@Home: Welcome to Folding@Home
[04:13:40] Loaded queue successfully.
[04:13:40] Connecting to http://171.64.65.62:8080/
[04:13:41] Posted data.
[04:13:41] Initial: 0000; - Receiving payload (expected size: 146035)
[04:13:41] Conversation time very short, giving reduced weight in bandwidth avg
[04:13:41] - Downloaded at ~285 kB/s
[04:13:41] - Averaged speed for that direction ~249 kB/s
[04:13:41] + Received work.
[04:13:43] + Connections closed: You may now disconnect
[04:13:43]
[04:13:43] + Processing work unit
[04:13:43] Core required: FahCore_78.exe
[04:13:43] Core found.
[04:13:44] Working on queue slot 02 [May 27 04:13:44 UTC]
[04:13:44] + Working ...
[04:13:44] - Calling '.\FahCore_78.exe -dir work/ -suffix 02 -checkpoint 15 -verbose -lifeline 4072 -version 620'
[04:13:44]
[04:13:44] *------------------------------*
[04:13:44] Folding@Home Gromacs Core
[04:13:44] Version 1.90 (March 8, 2006)
[04:13:44]
[04:13:44] Preparing to commence simulation
[04:13:44] - Looking at optimizations...
[04:13:44] - Created dyn
[04:13:44] - Files status OK
[04:13:45] - Expanded 145523 -> 3010561 (decompressed 2068.7 percent)
[04:13:45] - Starting from initial work packet
[04:13:45]
[04:13:45] Project: 6501 (Run 8, Clone 7, Gen 62)
[04:13:45]
[04:13:50] Assembly optimizations on if available.
[04:13:50] Entering M.D.
[04:13:59] Gromacs error.
[04:13:59]
[04:13:59] Folding@home Core Shutdown: UNKNOWN_ERROR
[04:14:56] CoreStatus = 79 (121)
[04:14:56] Client-core communications error: ERROR 0x79
[04:14:56] This is a sign of more serious problems, shutting down.
Dave
Re: Project: 6501 (Run 8, Clone 7, Gen 62) Bad WU?
The unit was not deleted in the portion of the log that you posted, but neither was it uploaded. If you look at the next portion of the log, I'm sure you'll see that it WAS deleted (if I'm wrong, please show the time-stamp showing the "Thank you..." message which would have happened when you restarted after [04:14:56].)
There's no record of anybody uploading that WU yet, either as an error or for full credit.
daveb
Post by daveb »
Bruce,
That is all there is to the log. After the message appeared, I got a dialog box informing me that the client was quitting. When I clicked ok, the the client exited back to the command line prompt. When I re-started the unit, it tried to run the same WU again (no download), and EUE'd the same way. The only way I was able to get a new unit was to delete the queue. This is similar to the behavior that I reported in viewtopic.php?f=19&t=18704.
Dave
This is one of the issues with the V6 client which is supposed to be fixed in V7 sooner or later. What I'd like to see happen is for somebody to report that they got the same WU in V7 and post their log, but that's not likely to happen. Until something like that happens, we won't know if V7 fixed the problem.
In the meantime, nothing has changed in V6. Some WUs are bad. Some computers are unstable. We try to sort them out, but we don't have enough information to be able to do that as well as we'd like to.
saintdev
Post by saintdev »
I just got assigned this WU, and have the same issue as the OP. Looks like a bad WU.
Note: Please read the license agreement (fah6 -license). Further
use of this software requires that you have read and accepted this agreement.
--- Opening Log file [June 5 01:02:20 UTC]
# Linux Console Edition #######################################################
                       Folding@Home Client Version 6.34
                          http://folding.stanford.edu
Launch directory: /opt/foldingathome
Executable: ./fah6
[01:02:20] - Ask before connecting: No
[01:02:20] - User name: saintdev (Team 33)
[01:02:20] - User ID: 31C7B4BB10079B12
[01:02:20] - Machine ID: 1
[01:02:20]
[01:02:20] Loaded queue successfully.
[01:02:20]
[01:02:20] + Processing work unit
[01:02:20] Core required: FahCore_78.exe
[01:02:20] Core found.
[01:02:20] Working on queue slot 01 [June 5 01:02:20 UTC]
[01:02:20] + Working ...
[01:02:20]
[01:02:20] *------------------------------*
[01:02:20] Folding@Home Gromacs Core
[01:02:20] Version 1.90 (March 8, 2006)
[01:02:20]
[01:02:20] Preparing to commence simulation
[01:02:20] - Ensuring status. Please wait.
[01:02:37] - Looking at optimizations...
[01:02:37] - Working with standard loops on this execution.
[01:02:37] - Created dyn
[01:02:37] - Files status OK
[01:02:38] - Expanded 145523 -> 3010561 (decompressed 2068.7 percent)
[01:02:38] - Starting from initial work packet
[01:02:38]
[01:02:38] Project: 6501 (Run 8, Clone 7, Gen 62)
[01:02:38]
[01:02:38] Entering M.D.
  Gromacs is Copyright (c) 1991-2003, University of Groningen, The Netherlands
        This inclusion of Gromacs code in the Folding@Home Core is under
        a special license (see http://folding.stanford.edu/gromacs.html)
         specially granted to Stanford by the copyright holders. If you
          are interested in using Gromacs, visit www.gromacs.org where
                you can download a free version of Gromacs under
         the terms of the GNU General Public License (GPL) as published
       by the Free Software Foundation; either version 2 of the License,
                     or (at your option) any later version.
[01:02:44] Gromacs error.
[01:02:44]
[01:02:44] Folding@home Core Shutdown: UNKNOWN_ERROR
[01:03:39] CoreStatus = 79 (121)
[01:03:39] Client-core communications error: ERROR 0x79
[01:03:39] This is a sign of more serious problems, shutting down.
karlinhigh
Post by karlinhigh »
Apparently I have the same work unit and same problems as daveb and saintdev reported. Here's my version, I tried to restart it several times:
[09:03:08] Unit 0 finished with 94 percent of time to deadline remaining.
[09:03:08] Updated performance fraction: 0.953396
[09:03:08] Sending work to server
[09:03:08] Project: 6510 (Run 18, Clone 22, Gen 98)
[09:03:08] - Read packet limit of 540015616... Set to 524286976.
[09:03:08] + Attempting to send results [June 5 09:03:08 UTC]
[09:03:08] - Reading file work/wuresults_00.dat from core
[09:03:08]   (Read 727706 bytes from disk)
[09:03:08] Connecting to http://171.64.65.62:8080/
[09:03:10] Posted data.
[09:03:10] Initial: 0000; - Uploaded at ~237 kB/s
[09:03:11] - Averaged speed for that direction ~253 kB/s
[09:03:11] + Results successfully sent
[09:03:11] Thank you for your contribution to Folding@Home.
[09:03:11] + Number of Units Completed: 97
[09:03:15] Trying to send all finished work units
[09:03:15] + No unsent completed units remaining.
[09:03:15] - Preparing to get new work unit...
[09:03:15] + Attempting to get work packet
[09:03:15] - Will indicate memory of 1022 MB
[09:03:15] - Detect CPU. Vendor: GenuineIntel, Family: 15, Model: 2, Stepping: 9
[09:03:15] - Connecting to assignment server
[09:03:15] Connecting to http://assign.stanford.edu:8080/
[09:03:15] Posted data.
[09:03:15] Initial: 40AB; - Successful: assigned to (171.64.65.62).
[09:03:15] + News From Folding@Home: Welcome to Folding@Home
[09:03:15] Loaded queue successfully.
[09:03:15] Connecting to http://171.64.65.62:8080/
[09:03:16] Posted data.
[09:03:16] Initial: 0000; - Receiving payload (expected size: 146035)
[09:03:16] Conversation time very short, giving reduced weight in bandwidth avg
[09:03:16] - Downloaded at ~285 kB/s
[09:03:16] - Averaged speed for that direction ~603 kB/s
[09:03:16] + Received work.
[09:03:16] Trying to send all finished work units
[09:03:16] + No unsent completed units remaining.
[09:03:16] + Closed connections
[09:03:16]
[09:03:16] + Processing work unit
[09:03:16] Core required: FahCore_78.exe
[09:03:16] Core found.
[09:03:16] Working on queue slot 01 [June 5 09:03:16 UTC]
[09:03:16] + Working ...
[09:03:16] - Calling '.\FahCore_78.exe -dir work/ -suffix 01 -checkpoint 15 -verbose -lifeline 2380 -version 623'
[09:03:16]
[09:03:16] *------------------------------*
[09:03:16] Folding@Home Gromacs Core
[09:03:16] Version 1.90 (March 8, 2006)
[09:03:16]
[09:03:16] Preparing to commence simulation
[09:03:16] - Looking at optimizations...
[09:03:16] - Created dyn
[09:03:16] - Files status OK
[09:03:17] - Expanded 145523 -> 3010561 (decompressed 2068.7 percent)
[09:03:17] - Starting from initial work packet
[09:03:17]
[09:03:17] Project: 6501 (Run 8, Clone 7, Gen 62)
[09:03:17]
[09:03:17] Assembly optimizations on if available.
[09:03:17] Entering M.D.
[09:03:23] Gromacs error.
[09:03:23]
[09:03:23] Folding@home Core Shutdown: UNKNOWN_ERROR
[09:03:27] CoreStatus = 79 (121)
[09:03:27] Client-core communications error: ERROR 0x79
[09:03:27] This is a sign of more serious problems, shutting down.
[14:11:55] - Autosending finished units... [June 5 14:11:55 UTC]
[14:11:55] Trying to send all finished work units
[14:11:55] + No unsent completed units remaining.
[14:11:55] - Autosend completed
--- Opening Log file [June 5 17:50:03 UTC]
Launch directory: C:\Documents and Settings\karlin\FAH
Executable: fah6
Arguments: -verbosity 9
[17:50:03] - Ask before connecting: No
[17:50:03] - User name: desktopsvcs.com (Team 35054)
[17:50:03] - User ID: ############
[17:50:03] - Machine ID: 1
[17:50:03]
[17:50:03] Loaded queue successfully.
[17:50:03]
[17:50:03] + Processing work unit
[17:50:03] Core required: FahCore_78.exe
[17:50:03] - Autosending finished units... [June 5 17:50:03 UTC]
[17:50:03] Trying to send all finished work units
[17:50:03] + No unsent completed units remaining.
[17:50:03] - Autosend completed
[17:50:03] Core found.
[17:50:03] Working on queue slot 01 [June 5 17:50:03 UTC]
[17:50:03] + Working ...
[17:50:03] - Calling '.\FahCore_78.exe -dir work/ -suffix 01 -checkpoint 15 -verbose -lifeline 2420 -version 623'
[17:50:04]
[17:50:04] *------------------------------*
[17:50:04] Folding@Home Gromacs Core
[17:50:04] Version 1.90 (March 8, 2006)
[17:50:04]
[17:50:04] Preparing to commence simulation
[17:50:04] - Ensuring status. Please wait.
[17:50:21] - Looking at optimizations...
[17:50:21] - Working with standard loops on this execution.
[17:50:21] - Created dyn
[17:50:21] - Files status OK
[17:50:21] - Expanded 145523 -> 3010561 (decompressed 2068.7 percent)
[17:50:21] - Starting from initial work packet
[17:50:21]
[17:50:21] Project: 6501 (Run 8, Clone 7, Gen 62)
[17:50:21]
[17:50:22] Entering M.D.
[17:50:28] Gromacs error.
[17:50:44]
[17:50:44] Folding@home Core Shutdown: UNKNOWN_ERROR
[17:50:45] CoreStatus = 79 (121)
[17:50:45] Client-core communications error: ERROR 0x79
[17:50:45] This is a sign of more serious problems, shutting down.
--- Opening Log file [June 5 18:04:27 UTC]
Executable: fah6
[18:04:27] - Ask before connecting: No
[18:04:27] - User name: desktopsvcs.com (Team 35054)
[18:04:27] - User ID: #################
[18:04:27] - Machine ID: 1
[18:04:27]
[18:04:28] Loaded queue successfully.
[18:04:28]
[18:04:28] + Processing work unit
[18:04:28] Core required: FahCore_78.exe
[18:04:28] - Autosending finished units... [June 5 18:04:28 UTC]
[18:04:28] Trying to send all finished work units
[18:04:28] + No unsent completed units remaining.
[18:04:28] - Autosend completed
[18:04:28] Core found.
[18:04:28] Working on queue slot 01 [June 5 18:04:28 UTC]
[18:04:28] + Working ...
[18:04:28] - Calling '.\FahCore_78.exe -dir work/ -suffix 01 -checkpoint 15 -verbose -lifeline 2548 -version 623'
[18:04:28]
[18:04:28] *------------------------------*
[18:04:28] Folding@Home Gromacs Core
[18:04:28] Version 1.90 (March 8, 2006)
[18:04:28]
[18:04:28] Preparing to commence simulation
[18:04:28] - Ensuring status. Please wait.
[18:04:45] - Looking at optimizations...
[18:04:45] - Working with standard loops on this execution.
[18:04:45] - Created dyn
[18:04:45] - Files status OK
[18:04:45] - Expanded 145523 -> 3010561 (decompressed 2068.7 percent)
[18:04:46] - Starting from initial work packet
[18:04:46]
[18:04:46] Project: 6501 (Run 8, Clone 7, Gen 62)
[18:04:46]
[18:04:46] Entering M.D.
[18:04:52] Gromacs error.
[18:04:52]
[18:04:52] Folding@home Core Shutdown: UNKNOWN_ERROR
[18:04:56] CoreStatus = 79 (121)
[18:04:56] Client-core communications error: ERROR 0x79
[18:04:56] This is a sign of more serious problems, shutting down.
--- Opening Log file [June 5 21:19:17 UTC]
Executable: fah6
Arguments: -forceasm -verbosity 9
Warning:
 By using the -forceasm flag, you are overriding
 safeguards in the program. If you did not intend to
 do this, please restart the program without -forceasm.
 If work units are not completing fully (and particularly
 if your machine is overclocked), then please discontinue
 use of the flag.
[21:19:17] - Ask before connecting: No
[21:19:17] - User name: desktopsvcs.com (Team 35054)
[21:19:17] - User ID: ################
[21:19:17] - Machine ID: 1
[21:19:17]
[21:19:17] Loaded queue successfully.
[21:19:17]
[21:19:17] + Processing work unit
[21:19:17] Core required: FahCore_78.exe
[21:19:17] Core found.
[21:19:17] - Autosending finished units... [June 5 21:19:17 UTC]
[21:19:17] Trying to send all finished work units
[21:19:17] + No unsent completed units remaining.
[21:19:17] - Autosend completed
[21:19:17] Working on queue slot 01 [June 5 21:19:17 UTC]
[21:19:17] + Working ...
[21:19:17] - Calling '.\FahCore_78.exe -dir work/ -suffix 01 -checkpoint 15 -forceasm -verbose -lifeline 3760 -version 623'
[21:19:17]
[21:19:17] *------------------------------*
[21:19:17] Folding@Home Gromacs Core
[21:19:17] Version 1.90 (March 8, 2006)
[21:19:17]
[21:19:17] Preparing to commence simulation
[21:19:17] - Ensuring status. Please wait.
[21:19:34] - Assembly optimizations manually forced on.
[21:19:34] - Not checking prior termination.
[21:19:35] - Expanded 145523 -> 3010561 (decompressed 2068.7 percent)
[21:19:35] - Starting from initial work packet
[21:19:35]
[21:19:35] Project: 6501 (Run 8, Clone 7, Gen 62)
[21:19:35]
[21:19:35] Assembly optimizations on if available.
[21:19:35] Entering M.D.
[21:19:41] Gromacs error.
[21:19:41]
[21:19:41] Folding@home Core Shutdown: UNKNOWN_ERROR
[21:19:44] CoreStatus = 79 (121)
[21:19:44] Client-core communications error: ERROR 0x79
[21:19:44] This is a sign of more serious problems, shutting down.
I guess I'll have to delete the work folder and queue.dat file and go on.
PS - This machine is a Dell Inspiron 1150 laptop, with an Intel Mobile Pentium 4 2.8 GHz CPU.
k1wi
Post by k1wi »
I had to change my machine id and 'fool' the server to get a different work unit when I had one.
k1wi
The WU (P6501,R8,C7,G62) has been reported as a bad WU. Note that the list of reported WUs are stopped daily at 8am pacific time.
