Unkown WU being uploaded as me
User: Rob_J
Team: 173855
Over the last few days i have been getting additional WU uploaded, most noticeably last night 3 WU of about 1,200 have been added which are not me.
I only fold smp which gets about 4000points a WU and bigadv stuff.
Whats going on?
Team: 173855
Whats going on?
John_Weatherman
Re: Unkown WU being uploaded as me
Looks like you've returned some standard SMPs - can you post a log so we can see what the details are?
Napoleon
Windows 7 Ultimate 64bit
NVidia GT430, core_15 work
Do those phantom WUs also appear if you search the stats using your passkey? Someone may have (mis)configured a client with your user/team name.
Win7 64bit, FAH v7, OC'd
NaCl - Core_15 - display
I'd quickly double check your logs to see whether your bigadv machine hasn't been folding some regular SMP work units (either because it's incorrectly configured, or due to a lack of Bigadv it's fallen back to regular SMP work units)...
Scratch that - from the point values I'd say that those extra work units are OPENMMPGU work units (that is, GPU folding work units) projects 6801, 6805, 6806.
You haven't got a GPU folding too do you?
No gpu folding, just a 2600k, so even if my bigadv picks up smp wu it puts out at least 4000points.
Tried a search using the passkey but it just shows the same information.
I have checked on here as its easier to see each workunit.
http://folding.extremeoverclocking.com/ ... =&u=501723
As you can see the last 3 WU arent mine.
I'm pretty certain that there is a gpu folding for your user/team name. In the vicinity of 5,000 ppd too.
If searching by passkey then someone is using your username, team name and passkey.
Using kakaostats, those 'extra' workunits are GPU work units (projects as listed prior).
Have to double check my pc for gpu, wouldnt it impact my cpu folding though which has never changed from about 80k per unit.
ChelseaOilman
Your definately folding GPU WUs.
These are the last 2 WUs submitted from 2 different clients on your machine.
Hi Rob_J (team 173855),
Your WU (P7146 R0 C34 G106) was added to the stats database on 2011-05-19 03:07:12 for 4797.58 points of credit.
Your WU (P10944 R2 C69 G23) was added to the stats database on 2011-05-20 06:05:47 for 925 points of credit.
Thanks, some how the gpu client was running even though it wasnt in the systray.
