Project: 6504 (Run 10, Clone 233, Gen 77)
saintdev
Post by saintdev »
[19:16:57] - Preparing to get new work unit...
[19:16:57] Cleaning up work directory
[19:16:57] + Attempting to get work packet
[19:16:57] Passkey found
[19:16:57] - Connecting to assignment server
[19:16:59] - Successful: assigned to (171.64.65.62).
[19:16:59] + News From Folding@Home: Welcome to Folding@Home
[19:16:59] Loaded queue successfully.
[19:17:07] + Closed connections
[19:17:07]
[19:17:07] + Processing work unit
[19:17:07] Core required: FahCore_78.exe
[19:17:07] Core found.
[19:17:07] Working on queue slot 03 [May 7 19:17:07 UTC]
[19:17:07] + Working ...
[19:17:07]
[19:17:07] *------------------------------*
[19:17:07] Folding@Home Gromacs Core
[19:17:07] Version 1.90 (March 8, 2006)
[19:17:07]
[19:17:07] Preparing to commence simulation
[19:17:07] - Looking at optimizations...
[19:17:07] - Created dyn
[19:17:07] - Files status OK
[19:17:08] - Expanded 717518 -> 3536685 (decompressed 492.9 percent)
[19:17:08] - Starting from initial work packet
[19:17:08]
[19:17:08] Project: 6504 (Run 10, Clone 233, Gen 77)
[19:17:08]
[19:17:08] Assembly optimizations on if available.
[19:17:08] Entering M.D.
[19:17:14] Protein: TR568_11 in water
[19:17:14]
[19:17:14] Writing local files
[19:17:14] Extra SSE boost OK.
[19:17:14] Completed 0 out of 250000 steps  (0%)
[19:26:54] Writing local files
[19:26:54] Completed 2500 out of 250000 steps  (1%)
[19:36:32] Writing local files
[19:36:32] Completed 5000 out of 250000 steps  (2%)
[19:46:11] Writing local files
[19:46:11] Completed 7500 out of 250000 steps  (3%)
[19:47:30] CoreStatus = 8B (139)
[19:47:30] Client-core communications error: ERROR 0x8b
[19:47:30] This is a sign of more serious problems, shutting down.
Re: Project: 6504 (Run 10, Clone 233, Gen 77)
There were multiple failures in the WU Database so it has been marked as a bad WU:
The WU (P6504,R10,C233,G77) has been reported as a bad WU.
Thanks for your report.
