171.67.108.22
k1wi
171.67.108.22
Post by k1wi »
Hi,
I have a 2685 bigadv work unit attempting to upload unsuccessfully to 171.67.108.22, which is listed as a classic client server, while all the CS's seem to be down?
[05:55:25] Trying to send all finished work units
[05:55:25] Project: 2685 (Run 7, Clone 22, Gen 52)
[05:55:25] + Attempting to send results [May 1 05:55:25 UTC]
[05:55:25] - Reading file work/wuresults_08.dat from core
[05:55:25]   (Read 102875118 bytes from disk)
[05:55:25] Connecting to http://171.67.108.22:8080/
[05:55:25] - Couldn't send HTTP request to server
[05:55:25]   (Got status 503)
[05:55:25] + Could not connect to Work Server (results)
[05:55:25]     (171.67.108.22:8080)
[05:55:25] + Retrying using alternative port
[05:55:25] Connecting to http://171.67.108.22:80/
[05:55:26] - Couldn't send HTTP request to server
[05:55:26]   (Got status 503)
[05:55:26] + Could not connect to Work Server (results)
[05:55:26]     (171.67.108.22:80)
[05:55:26] - Error: Could not transmit unit 08 (completed May 1) to work server.
[05:55:26] - 3 failed uploads of this unit.
k1wi
k1wi
Re: 171.67.108.22
Post by k1wi »
Restarted the client about 2 hours later because it hadn't attempted to reconnect again and it has started returning the work unit.
bollix47
Re: 171.67.108.22
Post by bollix47 »
Having the same problem here ... current net load @ 100 :e?:
[10:09:59] Sending work to server
[10:09:59] Project: 2684 (Run 8, Clone 3, Gen 74)
[10:09:59] + Attempting to send results [May 1 10:09:59 UTC]
[10:09:59] - Reading file work/wuresults_00.dat from core
[10:09:59]   (Read 95708588 bytes from disk)
[10:09:59] Connecting to http://171.67.108.22:8080/
[10:10:00] - Couldn't send HTTP request to server
[10:10:00]   (Got status 503)
[10:10:00] + Could not connect to Work Server (results)
[10:10:00]     (171.67.108.22:8080)
[10:10:00] + Retrying using alternative port
[10:10:00] Connecting to http://171.67.108.22:80/
[10:10:00]     (171.67.108.22:80)
[10:10:00] - Error: Could not transmit unit 00 (completed May 1) to work server.
[10:10:00] - 1 failed uploads of this unit.
[10:10:00]   Keeping unit 00 in queue.
[10:10:00] Trying to send all finished work units
[10:10:00] Project: 2684 (Run 8, Clone 3, Gen 74)
[10:10:00] + Attempting to send results [May 1 10:10:00 UTC]
[10:10:00] - Reading file work/wuresults_00.dat from core
[10:10:00]   (Read 95708588 bytes from disk)
[10:10:00] Connecting to http://171.67.108.22:8080/
[10:10:00] - 2 failed uploads of this unit.
[10:10:00] Connecting to http://171.67.108.25:8080/
Trotador
Re: 171.67.108.22
Post by Trotador »
Yeah, one hour and a half to return a 2684 unit!!
It being that way during at least one week for non 69xx units in may case.
regards
kasson
Pande Group Member
Re: 171.67.108.22
Post by kasson »
The 690x big work units have a higher-capacity server. Unfortunately, the server for the 268x work units can't handle too many transactions at a time. So when a lot of people are trying to upload or download the process can slow down. Thanks for your patience!
sco01
Hardware configuration: Core i7 3930K(C2)@4,2 (1.30v)
Swiftech Apogee Drive II + MCR-H220 Radiator
Asus P9X79
4*4Gb SEC 1600@1866 1.5v
GeForce GTX780ti ref (nztx G10+zalman lq315)
Creative X-Fi Titanium Fatal1ty
Lite-On iHAS124-34
HDD- WD3000GLFS + 2*Hitaсhi HDS723030BLE640 + 2*HDT721010SLA360
case-Corsair Obsidian 700D
PSU - Seasonic Platinum 860W (SS-860XP2)
2) Xeon E5645@4Ghz (1,34v)
ASUS P6T
Thermalright Silver Arrow
Corsair TR3X6G1600C7 (3x2048Mb, 7-7-7-20 1,62v)
GeForce GTX780 ref (nztx G10+corsair H75)
Zotac GTX980 AMP! Edition (ZT-90204-10P)
Hitachi 320Gb HTS543232A7A384
case - Chieftec LBX-03B Dremel edition :-)
PSU - Zalman ZM-850HP+ (Enhance silver)
APC SUA1500RMI2U
APC SUA1500RMI2U
Re: 171.67.108.22
Post by sco01 »
Launch directory: C:\smp
Executable: C:\smp\FAH6.34-win32-SMP.exe
Arguments: -send all -forceasm -smp 8 -bigadv -local -verbosity 9
[15:58:08] - Ask before connecting: No
[15:58:08] - User name: sco01 (Team 47191)
[15:58:08] - User ID: 2FC6D63F58654C3A
[15:58:08] - Machine ID: 7
[15:58:08]
[15:58:09] Loaded queue successfully.
[15:58:09] Attempting to return result(s) to server...
[15:58:09] Trying to send all finished work units
[15:58:09] Project: 2684 (Run 13, Clone 10, Gen 64)
[15:58:09] + Attempting to send results [June 24 15:58:09 UTC]
[15:58:09] - Reading file work/wuresults_08.dat from core
[15:58:09] (Read 95751919 bytes from disk)
[15:58:09] Connecting to http://171.67.108.22:8080/
[15:58:09] - Couldn't send HTTP request to server
[15:58:09] (Got status 503)
[15:58:09] + Could not connect to Work Server (results)
[15:58:09] (171.67.108.22:8080)
[15:58:09] + Retrying using alternative port
[15:58:09] Connecting to http://171.67.108.22:80/
[15:58:10] - Couldn't send HTTP request to server
[15:58:10] (Got status 503)
[15:58:10] + Could not connect to Work Server (results)
[15:58:10] (171.67.108.22:80)
[15:58:10] - Error: Could not transmit unit 08 (completed June 24) to work server.
[15:58:10] - 6 failed uploads of this unit.
DrSpalding
Hardware configuration: Dell Studio 425 MTS-Core i7-920 c0 stock
evga SLI 3x o/c Core i7-920 d0 @ 3.9GHz + nVidia GTX275
Dell 5150 + nVidia 9800GT
Re: 171.67.108.22 & 171.67.108.25
Post by DrSpalding »
These servers are not accessible for uploading a completed WU. I am running v6.34 -bigadv:
[15:39:09] Folding@home Core Shutdown: FINISHED_UNIT
[15:39:20] CoreStatus = 64 (100)
[15:39:20] Sending work to server
[15:39:20] Project: 2684 (Run 2, Clone 12, Gen 87)
[15:39:20] + Attempting to send results [July 17 15:39:20 UTC]
[15:39:20] - Couldn't send HTTP request to server
[15:39:20]   (Got status 503)
[15:39:20] + Could not connect to Work Server (results)
[15:39:20]     (171.67.108.22:8080)
[15:39:20] + Retrying using alternative port
[15:39:20]     (171.67.108.22:80)
[15:39:20] - Error: Could not transmit unit 06 (completed July 17) to work server.
[15:39:20]   Keeping unit 06 in queue.
[15:39:21] - Couldn't send HTTP request to server
[15:39:21] + Could not connect to Work Server (results)
[15:39:21]     (171.67.108.25:8080)
[15:39:21] + Retrying using alternative port
[15:39:23] - Couldn't send HTTP request to server
[15:39:23] + Could not connect to Work Server (results)
[15:39:23]     (171.67.108.25:80)
[15:39:23]   Could not transmit unit 06 to Collection server; keeping in queue.
[15:39:23] - Preparing to get new work unit...
[15:39:23] Cleaning up work directory
[15:39:43] + Attempting to get work packet
[15:39:43] Passkey found
[15:39:43] - Connecting to assignment server
[15:39:43] - Successful: assigned to (130.237.232.141).
[15:39:43] + News From Folding@Home: Welcome to Folding@Home
[15:39:43] Loaded queue successfully.
[15:40:17] Project: 2684 (Run 2, Clone 12, Gen 87)
[15:40:17] + Attempting to send results [July 17 15:40:17 UTC]
[15:40:17] - Couldn't send HTTP request to server
[15:40:17]   (Got status 503)
[15:40:17] + Could not connect to Work Server (results)
[15:40:17]     (171.67.108.22:8080)
[15:40:17] + Retrying using alternative port
[15:40:17]     (171.67.108.22:80)
[15:40:17] - Error: Could not transmit unit 06 (completed July 17) to work server.
[15:40:19] - Couldn't send HTTP request to server
[15:40:19] + Could not connect to Work Server (results)
[15:40:19]     (171.67.108.25:8080)
[15:40:19] + Retrying using alternative port
[15:40:20] - Couldn't send HTTP request to server
[15:40:20] + Could not connect to Work Server (results)
[15:40:20]     (171.67.108.25:80)
[15:40:20]   Could not transmit unit 06 to Collection server; keeping in queue.
[15:40:20] + Closed connections
[15:40:20]
Not a real doctor, I just play one on the 'net!
kasson
Pande Group Member
Re: 171.67.108.22
Post by kasson »
Thanks--we'll take a look.
DrSpalding
Re: 171.67.108.22
kasson, thanks. I suspect that your response a couple of months ago probably still holds true, but for both of the servers to be in a state where no uploads are happening is a bit more suspicious.
DrSpalding
Re: 171.67.108.22
The WU uploaded at 19:13 UTC (12:13 PDT) today, so I guess the servers are fixed or unclogged.
stevew
Hardware configuration: Mac Pro 8-core 2.26 GHz 2009, 12 GB.
iMac i7 3.4 GHz, 4 GB.
171.67.108.22 - Problem sending WU
Post by stevew »
OS X 10.7 -> Wine -> FAH6-1.34-win32-SMP.exe -> FahCore_a5.exe Averaging one WU every 2 days except for 2684s which take ~3.
Watched as a "Project: 2684 (Run 13, Clone 19, Gen 69)" has failed to send to stanford.edu since 11:00 MST, now 22:42. http://fah-web.stanford.edu/serverstat.html shows that the main target is up. A 2nd server showed REJECT. I've stopped F@h a couple of times and run "-send 03" with no success and then restarted the next WU. Now folding a 6900 run 18, clone 12, generation 15
Excerpts from FAHlog.txt follow.
[17:00:18] + Attempting to send results [July 21 17:00:18 UTC]
[17:00:18] - Reading file work/wuresults_03.dat from core
[17:00:18]   (Read 95812360 bytes from disk)
[17:00:18] Connecting to http://171.67.108.22:8080/
[17:06:55] - Couldn't send HTTP request to server
[17:06:55] + Could not connect to Work Server (results)
[17:06:55]     (171.67.108.22:8080)
[17:06:55] + Retrying using alternative port
[17:06:55] Connecting to http://171.67.108.22:80/
[17:18:41] - Couldn't send HTTP request to server
[17:18:41] + Could not connect to Work Server (results)
[17:18:41]     (171.67.108.22:80)
[17:18:41] - Error: Could not transmit unit 03 (completed July 21) to work server.
[17:18:41] - 1 failed uploads of this unit.
[17:18:41]   Keeping unit 03 in queue.
[17:18:41] Trying to send all finished work units
[17:18:41] Project: 2684 (Run 13, Clone 19, Gen 69)
[17:38:52] - Couldn't send HTTP request to server
[17:38:52] + Could not connect to Work Server (results)
[17:38:52]     (171.67.108.22:8080)
[17:38:52] + Retrying using alternative port
[17:38:52] Connecting to http://171.67.108.22:80/
[17:53:31] - Couldn't send HTTP request to server
[17:53:31] + Could not connect to Work Server (results)
[17:53:31]     (171.67.108.22:80)
[17:53:31] - Error: Could not transmit unit 03 (completed July 21) to work server.
[17:53:31] - 2 failed uploads of this unit
[17:53:31] + Attempting to send results [July 21 17:53:31 UTC]
[17:53:31] - Reading file work/wuresults_03.dat from core
[17:53:31]   (Read 95812360 bytes from disk)
[17:53:31] Connecting to http://171.67.108.25:8080/
[17:53:31]     (171.67.108.25:8080)
[17:53:31] + Retrying using alternative port
[17:53:31] Connecting to http://171.67.108.25:80/
[17:53:31]     (171.67.108.25:80)
[17:53:31]   Could not transmit unit 03 to Collection server; keeping in queue.
[17:53:31] + Sent 0 of 1 completed units to the server
[22:24:37] + Attempting to send results [July 21 22:24:37 UTC]
[22:24:37] - Reading file work/wuresults_03.dat from core
[22:24:37]   (Read 95812360 bytes from disk)
[22:24:37] Connecting to http://171.67.108.22:8080/
[22:28:04] - Couldn't send HTTP request to server
[22:28:04] + Could not connect to Work Server (results)
[22:28:04]     (171.67.108.22:8080)
[22:28:04] + Retrying using alternative port
[22:28:04] Connecting to http://171.67.108.22:80/
[22:43:45] - Couldn't send HTTP request to server
[22:43:45] + Could not connect to Work Server (results)
[22:43:45]     (171.67.108.22:80)
[22:43:45] - Error: Could not transmit unit 03 (completed July 21) to work server.
[22:43:45] - 3 failed uploads of this unit.
[00:15:59] Completed 24015 out of 250000 steps  (9%)
[00:26:33] - Couldn't send HTTP request to server
[00:26:33] + Could not connect to Work Server (results)
[00:26:33]     (171.67.108.22:8080)
[00:26:33] + Retrying using alternative port
[00:26:33] Connecting to http://171.67.108.22:80/
[00:27:05] Completed 25000 out of 250000 steps  (10%)
[00:36:44] - Couldn't send HTTP request to server
[00:36:44] + Could not connect to Work Server (results)
[00:36:44]     (171.67.108.22:80)
[00:36:44] - Error: Could not transmit unit 03 (completed July 21) to work server.
[00:36:44] - 4 failed uploads of this unit.
[01:19:19] Loaded queue successfully.
[01:19:19] Attempting to return result(s) to server...
[01:19:19] Project: 2684 (Run 13, Clone 19, Gen 69)
[01:19:19] + Attempting to send results [July 22 01:19:19 UTC]
[01:19:19] - Reading file work/wuresults_03.dat from core
[01:19:19]   (Read 95812360 bytes from disk)
[01:19:19] Connecting to http://171.67.108.22:8080/
[01:28:47] - Couldn't send HTTP request to server
[01:28:47] + Could not connect to Work Server (results)
[01:28:47]     (171.67.108.22:8080)
[01:28:47] + Retrying using alternative port
[01:28:47] Connecting to http://171.67.108.22:80/
[01:37:38] - Couldn't send HTTP request to server
[01:37:38] + Could not connect to Work Server (results)
[01:37:38]     (171.67.108.22:8080)
[01:37:38] + Retrying using alternative port
[01:37:38] Connecting to http://171.67.108.22:80/
[01:56:51] - Couldn't send HTTP request to server
[01:56:51] + Could not connect to Work Server (results)
[01:56:51]     (171.67.108.22:80)
[01:56:51] - Error: Could not transmit unit 03 (completed July 21) to work server.
[01:56:51] - 5 failed uploads of this unit.
[03:33:05] + Attempting to send results [July 22 03:33:05 UTC]
[03:33:05] - Reading file work/wuresults_03.dat from core
[03:33:05]   (Read 95812360 bytes from disk)
[03:33:05] Connecting to http://171.67.108.25:8080/
[03:33:05] - Couldn't send HTTP request to server
[03:33:05] + Could not connect to Work Server (results)
[03:33:05]     (171.67.108.25:8080)
[03:33:05] + Retrying using alternative port
[03:33:05] Connecting to http://171.67.108.25:80/
[03:33:05]     (171.67.108.25:80)
[03:33:05]   Could not transmit unit 03 to Collection server; keeping in queue.
[03:33:05] + Sent 0 of 1 completed units to the serve
kasson
Pande Group Member
Re: 171.67.108.22
Post by kasson »
Server code restarted; it should unclog given a little time.
stevew
Re: 171.67.108.22
Post by stevew »
I'll keep trying by stopping the 6900 currently folding and running F@h with "-send 03". It has been trying for 24+ hours to send to 171.67.108.22 (Accepting) and then falls back on 171.67.108.25 (Not Accept). I'm curious that FAH6-1.34-win32-SMP.exe is not using one of the SMP client servers, guess it is because "-bigadv -smp 16" is beta.
When this 2684 WU's time expires and/or the current 6900 WU is ready for upload, I will restore to before the OS X 10.7 update and check with 10.6.8 to see if it may be OS related. Making a backup now.....
[16:46:29] + Could not connect to Work Server (results)
[16:46:29]     (171.67.108.22:8080)
[16:46:29] + Retrying using alternative port
[16:46:29] Connecting to http://171.67.108.22:80/
[16:57:23] Completed 100000 out of 250000 steps  (40%)
[17:04:23] - Couldn't send HTTP request to server
[17:04:23] + Could not connect to Work Server (results)
[17:04:23]     (171.67.108.22:80)
[17:04:23] - Error: Could not transmit unit 03 (completed July 21) to work server.
[17:04:23] - 12 failed uploads of this unit.
[17:04:23] + Attempting to send results [July 22 17:04:23 UTC]
[17:04:23] - Reading file work/wuresults_03.dat from core
[17:04:23]   (Read 95812360 bytes from disk)
[17:04:23] Connecting to http://171.67.108.25:8080/
[17:04:23]     (171.67.108.25:8080)
[17:04:23] + Retrying using alternative port
[17:04:23] Connecting to http://171.67.108.25:80/
[17:04:23]     (171.67.108.25:80)
[17:04:23]   Could not transmit unit 03 to Collection server; keeping in queue.
[17:04:23] + Sent 0 of 1 completed units to the server
[17:04:23] - Autosend completed
Adam_Johnessee
Re: 171.67.108.22
Post by Adam_Johnessee »
I am having the same problem with a 2684 WU right now. It completed last night and still has not sent as of today. Is the server just that clogged up or is there a greater problem? I will try to post my log tonight if possible so as to make sure it is nothing wrong on my end.
Re: 171.67.108.22
stevew wrote:I'll keep trying by stopping the 6900 currently folding and running F@h with "-send 03".
This is unnecessary. The client retries the upload periodically. It uses exactly the same methodology when you specify "-send N" as when it is the one that decided it was time to try again.
