Project: 6518 (Run 16, Clone 184, Gen 65)
OEOTS
Hardware configuration: Main PC: Intel E6400 @ 3.0 Ghz, 4GB RAM, EN7900GS, Win XP SP3
Post by OEOTS »
Got an EUE on this WU, system is a stock 3.0 Ghz P4 LGA775 with windows XP SP3
[01:03:08] + Processing work unit
[01:03:08] Core required: FahCore_78.exe
[01:03:08] Core found.
[01:03:08] Working on queue slot 00 [April 17 01:03:08 UTC]
[01:03:08] + Working ...
[01:03:08] - Calling '.\FahCore_78.exe -dir work/ -suffix 00 -priority 96 -checkpoint 15 -verbose -lifeline 1432 -version 623'
[01:03:08]
[01:03:08] *------------------------------*
[01:03:08] Folding@Home Gromacs Core
[01:03:08] Version 1.90 (March 8, 2006)
[01:03:08]
[01:03:08] Preparing to commence simulation
[01:03:08] - Looking at optimizations...
[01:03:08] - Created dyn
[01:03:08] - Files status OK
[01:03:09] - Expanded 471409 -> 2359121 (decompressed 500.4 percent)
[01:03:09] - Starting from initial work packet
[01:03:09]
[01:03:09] Project: 6518 (Run 16, Clone 184, Gen 65)
[01:03:09]
[01:03:09] Assembly optimizations on if available.
[01:03:09] Entering M.D.
[01:03:15] Protein: proG_17 in water
[01:03:15]
[01:03:15] Writing local files
[01:03:15] Extra SSE boost OK.
[01:03:15] Completed 0 out of 250000 steps  (0%)
[01:12:00] Writing local files
[01:12:00] Completed 2500 out of 250000 steps  (1%)
[01:20:48] Writing local files
[01:20:48] Completed 5000 out of 250000 steps  (2%)
[01:29:33] Writing local files
[01:29:33] Completed 7500 out of 250000 steps  (3%)
[01:38:17] Writing local files
[01:38:17] Completed 10000 out of 250000 steps  (4%)
[01:39:34] - Autosending finished units... [April 17 01:39:34 UTC]
[01:39:34] Trying to send all finished work units
[01:39:34] + No unsent completed units remaining.
[01:39:34] - Autosend completed
[01:39:34] + Working...
[01:47:03] Writing local files
[01:47:03] Completed 12500 out of 250000 steps  (5%)
[01:47:47] Gromacs cannot continue further.
[01:47:47] Going to send back what have done.
[01:47:47] logfile size: 9045
[01:47:47] - Writing 9581 bytes of core data to disk...
[01:47:47] Done: 9069 -> 3418 (compressed to 37.6 percent)
[01:47:47]   ... Done.
[01:47:47]
[01:47:47] Folding@home Core Shutdown: EARLY_UNIT_END
[01:47:50] CoreStatus = 72 (114)
[01:47:50] Sending work to server
[01:47:50] Project: 6518 (Run 16, Clone 184, Gen 65)
[01:47:50] - Read packet limit of 540015616... Set to 524286976.
Re: Project: 6518 (Run 16, Clone 184, Gen 65)
There were multiple failures in the WU Database so it is now banished:
The WU (P6518,R16,C184,G65) has been reported as a bad WU.
Thanks for your report.
