Project: 6511 (Run 0, Clone 312, Gen 20) EUE at 2%.
GreyWhiskers
--i7 2600K@4.2 GHz
--ASUS P8P67 DeluxeB3
--4GB ADATA 1600 RAM
--750W Corsair PS
--MSI GTX560Ti @900MHz
Post by GreyWhiskers »
This is my first EUE report on v7. I've pruned the log file (and thanks to the designers ... It's easy to right click to "select all" and then "Copy" in the log file viewer in the console). I hope I've not pruned too much.
This is on an old Pentium M laptop Uniprocessor. See system description in beginning of log at 16:53:44
To moderators. I am sending this as two reports, but with exactly the same content. I did check the forum on both WUs, and neither seem to have been reported before.
Project: 6502 (Run 0, Clone 589, Gen 41) at 44% followed by
Project: 6511 (Run 0, Clone 312, Gen 20) at 2%.
The substance is for two back-to-back EUEs on Proj 6502 and 6511 - both with the same indication. AND Results from both of these are hung up. The console work queue shows both Unit 0 and 1 in a long-term "SEND" state. The big log below shows many, many attempts to upload these two project results.
- Gromacs cannot continue further;
- Core Shutdown: EARLY_UNIT_END
- BAD_WORK_UNIT (114)
- ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
- WARNING: Exception: Failed to send results to work server: Failed to read response packet
NOTE on current status: the client picked up a third WU, and is folding away on 6502 (0, 589, 41) at 26%
Observation: in the v6 log file, I was always able to find the date close by the unit download or upload sections. It isn't obvious here - I hope PG or the moderators can find the right events from what's in the log.
Anyway, I've included a long log file extract for the EUE on Project: 6502 (Run 0, Clone 589, Gen 41), plus kept the end of the log to see what happened after the EUE. The little snippet below shows where the "cannot continue further" message is in the log. I don't remember seeing in the log before the message, "BAD_WORK_UNIT (114)". Maybe that's new to v7.
I just got an OK from the Work Server at: http://171.64.65.62:8080, so it seems alive. The server log doesn't hint at anything I can see.
Log file extract of EUE for Project: 6502 (Run 0, Clone 589, Gen 41)
11:28:08:Unit 01:Gromacs cannot continue further.
11:28:08:Unit 01:Going to send back what have done.
11:28:08:Unit 01:logfile size: 47171
11:28:08:Unit 01:- Writing 47707 bytes of core data to disk...
11:28:08:Unit 01:Done: 47195 -> 5543 (compressed to 11.7 percent)
11:28:08:Unit 01: ... Done.
11:28:08:Unit 01:
11:28:08:Unit 01:Folding@home Core Shutdown: EARLY_UNIT_END
11:28:09:FahCore running Unit 01 returned: BAD_WORK_UNIT (114)
11:28:09:Sending unit results: id:01 state:SEND project:6502 run:0 clone:589 gen:41 core:0x78 unit:0x16f7dec64d9938390029024d00001966
11:28:09:Unit 01: Uploading 5.91KiB
11:28:09:Connecting to 171.64.65.62:8080
11:28:09:WARNING: Exception: Failed to send results to work server: Failed to read response packet
11:28:09:Trying to send results to collection server
11:28:09:Connecting to assign3.stanford.edu:8080
11:28:09:Connecting to 171.67.108.25:8080
*********************** Log Started 31/Mar/2011-16:53:44 ***********************
16:53:44:************************* Folding@home Client *************************
16:53:44:      Website: http://folding.stanford.edu/
16:53:44:    Copyright: (c) 2009,2010 Stanford University
16:53:44:       Author: Joseph Coffland <joseph@cauldrondevelopment.com>
16:53:44:         Args: --lifeline 4092
16:53:44:       Config: C:/Documents and Settings/Admin/Application
16:53:44:               Data/FAHClient/config.xml
16:53:44:******************************** Build ********************************
16:53:44:      Version: 7.1.21
16:53:44:         Date: Mar 23 2011
16:53:44:         Time: 15:13:48
16:53:44:      SVN Rev: 2883
16:53:44:       Branch: fah/trunk/client
16:53:44:     Compiler: Intel(R) C++ MSVC 1500 mode 1110
16:53:44:      Options: /TP /nologo /EHa /wd4297 /wd4103 /wd1786 /Ox -arch:SSE
16:53:44:               /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
16:53:44:     Platform: win32 XP
16:53:44:         Bits: 32
16:53:44:         Mode: Release
16:53:44:******************************* System ********************************
16:53:44:           OS: Microsoft Windows XP Home Edition
16:53:44:          CPU: Intel(R) Pentium(R) M processor 1.73GHz
16:53:44:       CPU ID: GenuineIntel Family 6 Model 13 Stepping 8
16:53:44:         CPUs: 1
16:53:44:       Memory: 1.99GiB
16:53:44:  Free Memory: 1.19GiB
16:53:44:      Threads: WINDOWS_THREADS
16:53:44:         GPUs: 0
16:53:44:         CUDA: Not detected
16:53:44:   On Battery: false
16:53:44:   UTC offset: -7
16:53:44:          PID: 192
16:53:44:          CWD: C:/Documents and Settings/Admin/Application Data/FAHClient
16:53:44:Win32 Service: false
16:53:44:***********************************************************************
16:53:44:<config>
16:53:44:  <service-description v='Folding@home Client'/>
16:53:44:  <service-restart v='true'/>
16:53:44:  <service-restart-delay v='5000'/>
16:53:44:
16:53:44:  <!-- Client Control -->
16:53:44:  <cycle-rate v='4'/>
16:53:44:  <cycles v='-1'/>
16:53:44:  <data-directory v='.'/>
16:53:44:  <exec-directory v='C:\Program Files\FAHClient'/>
16:53:44:  <exit-when-done v='false'/>
16:53:44:  <max-delay v='21600'/>
16:53:44:  <min-delay v='60'/>
16:53:44:  <threads v='4'/>
16:53:44:
16:53:44:  <!-- Configuration -->
16:53:44:  <config-rotate v='true'/>
16:53:44:  <config-rotate-dir v='configs'/>
16:53:44:  <config-rotate-max v='16'/>
16:53:44:
16:53:44:  <!-- Debugging -->
16:53:44:  <assignment-servers>
16:53:44:    assign3.stanford.edu:8080 assign4.stanford.edu:80
16:53:44:  </assignment-servers>
16:53:44:  <capture-directory v='capture'/>
16:53:44:  <capture-sockets v='false'/>
16:53:44:  <debug-sockets v='false'/>
16:53:44:  <exception-locations v='true'/>
16:53:44:  <gpu-assignment-servers>
16:53:44:    assign-GPU.stanford.edu:80 assign-GPU.stanford.edu:8080
16:53:44:  </gpu-assignment-servers>
16:53:44:  <stack-traces v='false'/>
16:53:44:
16:53:44:  <!-- Error Handling -->
16:53:44:  <max-slot-errors v='5'/>
16:53:44:  <max-unit-errors v='5'/>
16:53:44:
16:53:44:  <!-- FahCore Control -->
16:53:44:  <checkpoint v='15'/>
16:53:44:  <core-dir v='cores'/>
16:53:44:  <core-priority v='idle'/>
16:53:44:  <cpu-affinity v='false'/>
16:53:44:  <cpu-usage v='100'/>
16:53:44:  <no-assembly v='false'/>
16:53:44:
16:53:44:  <!-- Folding Slot Configuration -->
16:53:44:  <client-subtype v='STDCLI'/>
16:53:44:  <client-type v='normal'/>
16:53:44:  <cpu-species v='X86_PENTIUM_II'/>
16:53:44:  <cpu-type v='X86'/>
16:53:44:  <cpus v='1'/>
16:53:44:  <extra-core-args v='-forceasm'/>
16:53:44:  <gpu v='false'/>
16:53:44:  <gpu-id v='0'/>
16:53:44:  <max-packet-size v='normal'/>
16:53:44:  <os-species v='WIN_XP'/>
16:53:44:  <os-type v='WIN32'/>
16:53:44:  <project-key v='0'/>
16:53:44:  <smp v='false'/>
16:53:44:
16:53:44:  <!-- Logging -->
16:53:44:  <log v='log.txt'/>
16:53:44:  <log-color v='false'/>
16:53:44:  <log-crlf v='true'/>
16:53:44:  <log-date v='false'/>
16:53:44:  <log-debug v='true'/>
16:53:44:  <log-domain v='false'/>
16:53:44:  <log-header v='true'/>
16:53:44:  <log-level v='true'/>
16:53:44:  <log-no-info-header v='true'/>
16:53:44:  <log-redirect v='false'/>
16:53:44:  <log-rotate v='true'/>
16:53:44:  <log-rotate-dir v='logs'/>
16:53:44:  <log-rotate-max v='16'/>
16:53:44:  <log-short-level v='false'/>
16:53:44:  <log-simple-domains v='true'/>
16:53:44:  <log-thread-id v='false'/>
16:53:44:  <log-time v='true'/>
16:53:44:  <log-to-screen v='true'/>
16:53:44:  <log-truncate v='false'/>
16:53:44:  <verbosity v='5'/>
16:53:44:
16:53:44:  <!-- Process Control -->
16:53:44:  <child v='false'/>
16:53:44:  <daemon v='false'/>
16:53:44:  <pid v='false'/>
16:53:44:  <pid-file v='Folding@home Client.pid'/>
16:53:44:  <respawn v='false'/>
16:53:44:  <service v='false'/>
16:53:44:
16:53:44:  <!-- Remote Command Server -->
16:53:44:  <command-address v='0.0.0.0'/>
16:53:44:  <command-allow v='127.0.0.1'/>
16:53:44:  <command-allow-no-pass v='127.0.0.1'/>
16:53:44:  <command-deny v='0.0.0.0/0'/>
16:53:44:  <command-deny-no-pass v='0.0.0.0/0'/>
16:53:44:  <command-port v='36330'/>
16:53:44:  <password v=''/>
16:53:44:
16:53:44:  <!-- Slot Control -->
16:53:44:  <max-shutdown-wait v='60'/>
16:53:44:  <pause-on-battery v='false'/>
16:53:44:  <pause-on-start v='false'/>
16:53:44:
16:53:44:  <!-- User Information -->
16:53:44:  <machine-id v='0'/>
16:53:44:  <passkey v='********************************'/>
16:53:44:  <team v='0'/>
16:53:44:  <user v='GreyWhiskers'/>
16:53:44:
16:53:44:  <!-- Work Unit Control -->
16:53:44:  <dump-after-deadline v='true'/>
16:53:44:  <max-queue v='16'/>
16:53:44:  <max-units v='0'/>
16:53:44:  <next-unit-percentage v='99'/>
16:53:44:
16:53:44:  <!-- Folding Slots -->
16:53:44:  <slot id='0' type='UNIPROCESSOR'/>
16:53:44:</config>
16:53:45:Enabled folding slot 00: READY uniprocessor
16:53:45:Started thread 1 on PID 192
16:53:45:Started thread 3 on PID 192
16:53:45:Started thread 4 on PID 192
16:53:45:Started thread 5 on PID 192
16:53:45:Started thread 6 on PID 192
several days of normal activity deleted.
02:52:58:Unit 00:Writing local files
02:52:58:Unit 00:Completed 240000 out of 250000 steps  (96%)
03:00:53:Unit 00:Writing local files
03:00:53:Unit 00:Completed 242500 out of 250000 steps  (97%)
03:08:49:Unit 00:Writing local files
03:08:49:Unit 00:Completed 245000 out of 250000 steps  (98%)
03:15:53:Saving configuration to config.xml
03:15:53:<config>
03:15:53:  <!-- Folding Slot Configuration -->
03:15:53:  <extra-core-args v='-forceasm'/>
03:15:53:  <smp v='false'/>
03:15:53:
03:15:53:  <!-- Logging -->
03:15:53:  <verbosity v='5'/>
03:15:53:
03:15:53:  <!-- Remote Command Server -->
03:15:53:  <password v=''/>
03:15:53:
03:15:53:  <!-- User Information -->
03:15:53:  <passkey v='********************************'/>
03:15:53:  <user v='GreyWhiskers'/>
03:15:53:
03:15:53:  <!-- Folding Slots -->
03:15:53:  <slot id='0' type='UNIPROCESSOR'>
03:15:53:    <client-type v='advanced'/>
03:15:53:  </slot>
03:15:53:</config>
03:17:11:Unit 00:Writing local files
03:17:11:Unit 00:Completed 247500 out of 250000 steps  (99%)
03:17:11:Connecting to assign3.stanford.edu:8080
03:17:11:News: Welcome to Folding@Home
03:17:11:Assigned to work server 171.64.65.62
03:17:11:Requesting new work unit for slot 00: RUNNING uniprocessor from 171.64.65.62
03:17:11:Connecting to 171.64.65.62:8080
03:17:11:Slot 00: Downloading 410.70KiB
03:17:12:Slot 00: Download complete
03:17:12:Received Unit: id:01 state:DOWNLOAD project:6502 run:0 clone:589 gen:41 core:0x78 unit:0x16f7dec64d9938390029024d00001966
03:27:46:Unit 00:Writing local files
03:27:46:Unit 00:Completed 250000 out of 250000 steps  (100%)
03:27:46:Unit 00:Writing final coordinates.
03:27:47:Unit 00:Past main M.D. loop
03:28:46:Unit 00:
03:28:46:Unit 00:Finished Work Unit:
03:28:47:Unit 00:- Reading up to 293544 from "00/wudata_01.arc": Read 293544
03:28:47:Unit 00:- Reading up to 261168 from "00/wudata_01.xtc": Read 261168
03:28:47:Unit 00:goefile size: 0
03:28:47:Unit 00:logfile size: 22141
03:28:47:Unit 00:Leaving Run
03:28:48:Unit 00:- Writing 582761 bytes of core data to disk...
03:28:48:Unit 00:Done: 582249 -> 560903 (compressed to 96.3 percent)
03:28:48:Unit 00:  ... Done.
03:28:48:FahCore running Unit 00 returned: FINISHED_UNIT (100)
03:28:49:Sending unit results: id:00 state:SEND project:6883 run:515 clone:7 gen:54 core:0x78 unit:0x000000396652edb14d13d7835c37f5dc
03:28:49:Starting Unit 01
03:28:49:Unit 00: Uploading 548.26KiB
03:28:49:Running core: "C:/Documents and Settings/Admin/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_78.fah/FahCore_78.exe" -dir 01 -suffix 01 -lifeline 192 -version 701 -checkpoint 15 -forceasm
03:28:49:Connecting to 171.67.108.33:8080
03:28:49:Started core on PID 832
03:28:49:FahCore 0x78 started
03:28:49:Started thread 31 on PID 192
03:28:50:Unit 01:
03:28:50:Unit 01:*------------------------------*
03:28:50:Unit 01:Folding@Home Gromacs Core
03:28:50:Unit 01:Version 1.90 (March 8, 2006)
03:28:50:Unit 01:
03:28:50:Unit 01:Preparing to commence simulation
03:28:50:Unit 01:- Assembly optimizations manually forced on.
03:28:50:Unit 01:- Not checking prior termination.
03:28:50:Unit 01:- Expanded 420043 -> 2026461 (decompressed 482.4 percent)
03:28:50:Unit 01:- Starting from initial work packet
03:28:50:Unit 01:
03:28:50:Unit 01:Project: 6502 (Run 0, Clone 589, Gen 41)
03:28:50:Unit 01:
03:28:50:Unit 01:Assembly optimizations on if available.
03:28:50:Unit 01:Entering M.D.
03:28:53:Unit 00: Upload complete
03:28:53:Server responded WORK_ACK (400)
03:28:53:Final credit estimate, 69.00 points
03:28:53:Cleaning up Unit 00
03:28:56:Unit 01:Protein: TR462_A_1 in water
03:28:56:Unit 01:
03:28:57:Unit 01:Writing local files
03:28:57:Unit 01:Extra SSE boost OK.
03:28:58:Unit 01:Completed 0 out of 250000 steps  (0%)
03:39:45:Unit 01:Writing local files
03:39:45:Unit 01:Completed 2500 out of 250000 steps  (1%)
03:49:26:Unit 01:Writing local files
03:49:26:Unit 01:Completed 5000 out of 250000 steps  (2%)
03:57:37:Unit 01:Writing local files
03:57:37:Unit 01:Completed 7500 out of 250000 steps  (3%)
04:05:36:Unit 01:Writing local files
04:05:36:Unit 01:Completed 10000 out of 250000 steps  (4%)
04:13:40:Unit 01:Writing local files
04:13:40:Unit 01:Completed 12500 out of 250000 steps  (5%)
04:21:41:Unit 01:Writing local files
04:21:41:Unit 01:Completed 15000 out of 250000 steps  (6%)
04:29:44:Unit 01:Writing local files
04:29:44:Unit 01:Completed 17500 out of 250000 steps  (7%)
04:37:51:Unit 01:Writing local files
04:37:51:Unit 01:Completed 20000 out of 250000 steps  (8%)
04:45:56:Unit 01:Writing local files
04:45:56:Unit 01:Completed 22500 out of 250000 steps  (9%)
04:54:01:Unit 01:Writing local files
04:54:01:Unit 01:Completed 25000 out of 250000 steps  (10%)
05:02:04:Unit 01:Writing local files
05:02:04:Unit 01:Completed 27500 out of 250000 steps  (11%)
05:10:12:Unit 01:Writing local files
05:10:12:Unit 01:Completed 30000 out of 250000 steps  (12%)
05:19:05:Unit 01:Writing local files
05:19:05:Unit 01:Completed 32500 out of 250000 steps  (13%)
05:27:58:Unit 01:Writing local files
05:27:58:Unit 01:Completed 35000 out of 250000 steps  (14%)
05:37:43:Unit 01:Writing local files
05:37:43:Unit 01:Completed 37500 out of 250000 steps  (15%)
05:45:50:Unit 01:Writing local files
05:45:50:Unit 01:Completed 40000 out of 250000 steps  (16%)
05:53:44:Unit 01:Writing local files
05:53:44:Unit 01:Completed 42500 out of 250000 steps  (17%)
06:01:26:Unit 01:Writing local files
06:01:26:Unit 01:Completed 45000 out of 250000 steps  (18%)
06:09:10:Unit 01:Writing local files
06:09:10:Unit 01:Completed 47500 out of 250000 steps  (19%)
06:16:52:Unit 01:Writing local files
06:16:52:Unit 01:Completed 50000 out of 250000 steps  (20%)
08:08:07:Unit 01:Writing local files
08:08:07:Unit 01:Completed 52500 out of 250000 steps  (21%)
08:38:58:Unit 01:Writing local files
08:38:58:Unit 01:Completed 55000 out of 250000 steps  (22%)
08:46:36:Unit 01:Writing local files
08:46:36:Unit 01:Completed 57500 out of 250000 steps  (23%)
08:48:41:Server connection id=18 on 0.0.0.0:36330 from 192.168.10.200:3335
08:48:41:Started thread 32 on PID 192
08:54:08:Unit 01:Writing local files
08:54:08:Unit 01:Completed 60000 out of 250000 steps  (24%)
09:01:39:Unit 01:Writing local files
09:01:39:Unit 01:Completed 62500 out of 250000 steps  (25%)
09:09:17:Unit 01:Writing local files
09:09:17:Unit 01:Completed 65000 out of 250000 steps  (26%)
09:16:47:Unit 01:Writing local files
09:16:47:Unit 01:Completed 67500 out of 250000 steps  (27%)
09:24:19:Unit 01:Writing local files
09:24:19:Unit 01:Completed 70000 out of 250000 steps  (28%)
09:31:49:Unit 01:Writing local files
09:31:49:Unit 01:Completed 72500 out of 250000 steps  (29%)
09:39:21:Unit 01:Writing local files
09:39:21:Unit 01:Completed 75000 out of 250000 steps  (30%)
09:46:51:Unit 01:Writing local files
09:46:51:Unit 01:Completed 77500 out of 250000 steps  (31%)
09:54:23:Unit 01:Writing local files
09:54:23:Unit 01:Completed 80000 out of 250000 steps  (32%)
10:01:53:Unit 01:Writing local files
10:01:53:Unit 01:Completed 82500 out of 250000 steps  (33%)
10:09:24:Unit 01:Writing local files
10:09:25:Unit 01:Completed 85000 out of 250000 steps  (34%)
10:16:55:Unit 01:Writing local files
10:16:55:Unit 01:Completed 87500 out of 250000 steps  (35%)
10:24:27:Unit 01:Writing local files
10:24:27:Unit 01:Completed 90000 out of 250000 steps  (36%)
10:31:57:Unit 01:Writing local files
10:31:57:Unit 01:Completed 92500 out of 250000 steps  (37%)
10:39:29:Unit 01:Writing local files
10:39:29:Unit 01:Completed 95000 out of 250000 steps  (38%)
10:46:59:Unit 01:Writing local files
10:46:59:Unit 01:Completed 97500 out of 250000 steps  (39%)
10:54:30:Unit 01:Writing local files
10:54:30:Unit 01:Completed 100000 out of 250000 steps  (40%)
11:02:06:Unit 01:Writing local files
11:02:06:Unit 01:Completed 102500 out of 250000 steps  (41%)
11:09:38:Unit 01:Writing local files
11:09:38:Unit 01:Completed 105000 out of 250000 steps  (42%)
11:17:09:Unit 01:Writing local files
11:17:09:Unit 01:Completed 107500 out of 250000 steps  (43%)
11:24:41:Unit 01:Writing local files
11:24:41:Unit 01:Completed 110000 out of 250000 steps  (44%)
11:28:08:Unit 01:
11:28:09:News: Welcome to Folding@Home
11:28:09:Assigned to work server 171.64.65.62
11:28:09:Requesting new work unit for slot 00: READY uniprocessor from 171.64.65.62
11:28:10:WARNING: WorkServer connection failed on port 8080 trying 80
11:28:10:Connecting to 171.67.108.25:80
11:28:10:Slot 00: Downloading 730.48KiB
11:28:11:Slot 00: Download complete
11:28:11:Received Unit: id:00 state:DOWNLOAD project:6511 run:0 clone:312 gen:20 core:0x78 unit:0x136027624d99ab4c001401380000196f
11:28:11:Starting Unit 00
11:28:11:Running core: "C:/Documents and Settings/Admin/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_78.fah/FahCore_78.exe" -dir 00 -suffix 01 -lifeline 192 -version 701 -checkpoint 15 -forceasm
11:28:11:Started core on PID 4592
11:28:11:Started thread 33 on PID 192
11:28:11:FahCore 0x78 started
11:28:11:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
11:28:11:Sending unit results: id:01 state:SEND project:6502 run:0 clone:589 gen:41 core:0x78 unit:0x16f7dec64d9938390029024d00001966
11:28:11:Unit 01: Uploading 5.91KiB
11:28:11:Connecting to 171.64.65.62:8080
11:28:11:WARNING: Exception: Failed to send results to work server: Failed to read response packet
11:28:11:Trying to send results to collection server
11:28:12:Unit 01: Uploading 5.91KiB
11:28:12:Connecting to 171.67.108.25:8080
11:28:12:Unit 00:
11:28:12:Unit 00:*------------------------------*
11:28:12:Unit 00:Folding@Home Gromacs Core
11:28:12:Unit 00:Version 1.90 (March 8, 2006)
11:28:12:Unit 00:
11:28:12:Unit 00:Preparing to commence simulation
11:28:12:Unit 00:- Assembly optimizations manually forced on.
11:28:12:Unit 00:- Not checking prior termination.
11:28:12:Unit 00:- Expanded 747502 -> 3750157 (decompressed 501.6 percent)
11:28:12:Unit 00:- Starting from initial work packet
11:28:12:Unit 00:
11:28:12:Unit 00:Project: 6511 (Run 0, Clone 312, Gen 20)
11:28:12:Unit 00:
11:28:12:Unit 00:Assembly optimizations on if available.
11:28:12:Unit 00:Entering M.D.
11:28:12:WARNING: WorkServer connection failed on port 8080 trying 80
11:28:13:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
11:28:19:Unit 00:Protein: UBIQUITIN MODEL250 in water
11:28:19:Unit 00:
11:28:19:Unit 00:Writing local files
11:28:19:Unit 00:Extra SSE boost OK.
11:28:20:Unit 00:Writing local files
11:28:20:Unit 00:Completed 0 out of 250000 steps  (0%)
11:29:11:Sending unit results: id:01 state:SEND project:6502 run:0 clone:589 gen:41 core:0x78 unit:0x16f7dec64d9938390029024d00001966
11:29:12:Unit 01: Uploading 5.91KiB
11:29:12:Connecting to 171.64.65.62:8080
11:29:12:WARNING: Exception: Failed to send results to work server: Failed to read response packet
11:29:12:Trying to send results to collection server
11:29:12:Connecting to 171.67.108.25:8080
11:29:13:WARNING: WorkServer connection failed on port 8080 trying 80
11:29:13:Connecting to 171.67.108.25:80
11:29:14:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
11:30:49:Sending unit results: id:01 state:SEND project:6502 run:0 clone:589 gen:41 core:0x78 unit:0x16f7dec64d9938390029024d00001966
11:30:49:Unit 01: Uploading 5.91KiB
11:30:49:Connecting to 171.64.65.62:8080
11:30:49:WARNING: Exception: Failed to send results to work server: Failed to read response packet
11:30:49:Trying to send results to collection server
11:30:49:Connecting to 171.67.108.25:8080
11:30:50:WARNING: WorkServer connection failed on port 8080 trying 80
11:30:50:Connecting to 171.67.108.25:80
11:30:51:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
11:33:26:Sending unit results: id:01 state:SEND project:6502 run:0 clone:589 gen:41 core:0x78 unit:0x16f7dec64d9938390029024d00001966
11:33:26:Unit 01: Uploading 5.91KiB
11:33:26:Connecting to 171.64.65.62:8080
11:33:26:WARNING: Exception: Failed to send results to work server: Failed to read response packet
11:33:26:Trying to send results to collection server
11:33:27:Unit 01: Uploading 5.91KiB
11:33:27:Connecting to 171.67.108.25:8080
11:33:28:WARNING: WorkServer connection failed on port 8080 trying 80
11:33:28:Connecting to 171.67.108.25:80
11:33:29:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
11:37:40:Sending unit results: id:01 state:SEND project:6502 run:0 clone:589 gen:41 core:0x78 unit:0x16f7dec64d9938390029024d00001966
11:37:41:Unit 01: Uploading 5.91KiB
11:37:41:Connecting to 171.64.65.62:8080
11:37:41:WARNING: Exception: Failed to send results to work server: Failed to read response packet
11:37:41:Trying to send results to collection server
11:37:41:Connecting to 171.67.108.25:8080
11:37:42:WARNING: WorkServer connection failed on port 8080 trying 80
11:37:42:Connecting to 171.67.108.25:80
11:37:43:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
11:42:38:Unit 00:Writing local files
11:42:38:Unit 00:Completed 2500 out of 250000 steps  (1%)
11:44:31:Sending unit results: id:01 state:SEND project:6502 run:0 clone:589 gen:41 core:0x78 unit:0x16f7dec64d9938390029024d00001966
11:44:32:Unit 01: Uploading 5.91KiB
11:44:32:Connecting to 171.64.65.62:8080
11:44:32:WARNING: Exception: Failed to send results to work server: Failed to read response packet
11:44:32:Trying to send results to collection server
11:44:32:Connecting to 171.67.108.25:8080
11:44:33:WARNING: WorkServer connection failed on port 8080 trying 80
11:44:33:Connecting to 171.67.108.25:80
11:44:34:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
11:55:37:Sending unit results: id:01 state:SEND project:6502 run:0 clone:589 gen:41 core:0x78 unit:0x16f7dec64d9938390029024d00001966
11:55:37:Unit 01: Uploading 5.91KiB
11:55:37:Connecting to 171.64.65.62:8080
11:55:37:WARNING: Exception: Failed to send results to work server: Failed to read response packet
11:55:37:Trying to send results to collection server
11:55:37:Connecting to 171.67.108.25:8080
11:55:38:WARNING: WorkServer connection failed on port 8080 trying 80
11:55:38:Connecting to 171.67.108.25:80
11:55:39:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
11:56:55:Unit 00:Writing local files
11:56:56:Unit 00:Completed 5000 out of 250000 steps  (2%)
12:10:55:Unit 00:Gromacs cannot continue further.
12:10:55:Unit 00:Going to send back what have done.
12:10:55:Unit 00:logfile size: 9301
12:10:55:Unit 00:- Writing 9837 bytes of core data to disk...
12:10:55:Unit 00:Done: 9325 -> 3502 (compressed to 37.5 percent)
12:10:55:Unit 00:  ... Done.
12:10:55:Unit 00:
12:10:55:Unit 00:Folding@home Core Shutdown: EARLY_UNIT_END
12:10:55:FahCore running Unit 00 returned: BAD_WORK_UNIT (114)
12:10:56:Sending unit results: id:00 state:SEND project:6511 run:0 clone:312 gen:20 core:0x78 unit:0x136027624d99ab4c001401380000196f
12:10:56:Unit 00: Uploading 3.92KiB
12:10:56:Connecting to 171.64.65.62:8080
12:10:56:Connecting to assign3.stanford.edu:8080
12:10:56:WARNING: Exception: Failed to send results to work server: Failed to read response packet
12:10:56:Trying to send results to collection server
12:10:56:News: Welcome to Folding@Home
12:10:56:Assigned to work server 171.64.65.62
12:10:56:Connecting to 171.67.108.25:8080
12:10:56:Requesting new work unit for slot 00: READY uniprocessor from 171.64.65.62
12:10:57:Slot 00: Downloading 668.47KiB
12:10:57:WARNING: WorkServer connection failed on port 8080 trying 80
12:10:57:Connecting to 171.67.108.25:80
12:10:58:Slot 00: Download complete
12:10:58:Received Unit: id:02 state:DOWNLOAD project:6526 run:9 clone:111 gen:65 core:0x78 unit:0x267e55e04d99b5530041006f0009197e
12:10:58:Starting Unit 02
12:10:58:Running core: "C:/Documents and Settings/Admin/Application Data/FAHClient/cores/www.stanford.edu/~pande/Win32/x86/Core_78.fah/FahCore_78.exe" -dir 02 -suffix 01 -lifeline 192 -version 701 -checkpoint 15 -forceasm
12:10:58:Started core on PID 3148
12:10:58:FahCore 0x78 started
12:10:58:Started thread 34 on PID 192
12:10:58:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
12:10:58:Sending unit results: id:00 state:SEND project:6511 run:0 clone:312 gen:20 core:0x78 unit:0x136027624d99ab4c001401380000196f
12:10:58:Unit 00: Uploading 3.92KiB
12:10:58:Connecting to 171.64.65.62:8080
12:10:58:Unit 02:
12:10:58:Unit 02:*------------------------------*
12:10:58:Unit 02:Folding@Home Gromacs Core
12:10:58:WARNING: Exception: Failed to send results to work server: Failed to read response packet
12:10:58:Unit 02:Version 1.90 (March 8, 2006)
12:10:58:Trying to send results to collection server
12:10:58:Unit 02:
12:10:58:Unit 02:Preparing to commence simulation
12:10:58:Unit 02:- Assembly optimizations manually forced on.
12:10:58:Unit 02:- Not checking prior termination.
12:10:59:Unit 00: Uploading 3.92KiB
12:10:59:Connecting to 171.67.108.25:8080
12:10:59:Unit 02:- Expanded 684000 -> 3411889 (decompressed 498.8 percent)
12:10:59:Unit 02:- Starting from initial work packet
12:10:59:Unit 02:
12:10:59:Unit 02:Project: 6526 (Run 9, Clone 111, Gen 65)
12:10:59:Unit 02:
12:10:59:Unit 02:Assembly optimizations on if available.
12:10:59:Unit 02:Entering M.D.
12:10:59:WARNING: WorkServer connection failed on port 8080 trying 80
12:11:00:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
12:11:05:Unit 02:Protein: proA_10 in water
12:11:05:Unit 02:
12:11:05:Unit 02:Writing local files
12:11:05:Unit 02:Extra SSE boost OK.
12:11:06:Unit 02:Writing local files
12:11:06:Unit 02:Completed 0 out of 250000 steps  (0%)
12:11:58:Sending unit results: id:00 state:SEND project:6511 run:0 clone:312 gen:20 core:0x78 unit:0x136027624d99ab4c001401380000196f
12:11:59:Unit 00: Uploading 3.92KiB
12:11:59:Connecting to 171.64.65.62:8080
12:11:59:WARNING: Exception: Failed to send results to work server: Failed to read response packet
12:11:59:Trying to send results to collection server
12:11:59:Connecting to 171.67.108.25:8080
12:12:00:WARNING: WorkServer connection failed on port 8080 trying 80
12:12:00:Connecting to 171.67.108.25:80
12:12:01:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
12:13:34:Sending unit results: id:01 state:SEND project:6502 run:0 clone:589 gen:41 core:0x78 unit:0x16f7dec64d9938390029024d00001966
12:13:34:Unit 01: Uploading 5.91KiB
12:13:34:Connecting to 171.64.65.62:8080
12:13:34:WARNING: Exception: Failed to send results to work server: Failed to read response packet
12:13:34:Trying to send results to collection server
12:13:35:Unit 01: Uploading 5.91KiB
12:13:35:Connecting to 171.67.108.25:8080
12:13:36:Sending unit results: id:00 state:SEND project:6511 run:0 clone:312 gen:20 core:0x78 unit:0x136027624d99ab4c001401380000196f
12:13:36:Unit 00: Uploading 3.92KiB
12:13:36:Connecting to 171.64.65.62:8080
12:13:36:WARNING: Exception: Failed to send results to work server: Failed to read response packet
12:13:36:Trying to send results to collection server
12:13:36:WARNING: WorkServer connection failed on port 8080 trying 80
12:13:36:Connecting to 171.67.108.25:80
12:13:36:Connecting to 171.67.108.25:8080
12:13:37:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
12:13:37:WARNING: WorkServer connection failed on port 8080 trying 80
12:13:37:Connecting to 171.67.108.25:80
12:13:38:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
12:16:13:Sending unit results: id:00 state:SEND project:6511 run:0 clone:312 gen:20 core:0x78 unit:0x136027624d99ab4c001401380000196f
12:16:13:Unit 00: Uploading 3.92KiB
12:16:13:Connecting to 171.64.65.62:8080
12:16:13:WARNING: Exception: Failed to send results to work server: Failed to read response packet
12:16:13:Trying to send results to collection server
12:16:13:Connecting to 171.67.108.25:8080
12:16:14:WARNING: WorkServer connection failed on port 8080 trying 80
12:16:14:Connecting to 171.67.108.25:80
12:16:15:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
12:20:27:Sending unit results: id:00 state:SEND project:6511 run:0 clone:312 gen:20 core:0x78 unit:0x136027624d99ab4c001401380000196f
12:20:27:Unit 00: Uploading 3.92KiB
12:20:27:Connecting to 171.64.65.62:8080
12:20:27:WARNING: Exception: Failed to send results to work server: Failed to read response packet
12:20:27:Trying to send results to collection server
12:20:27:Connecting to 171.67.108.25:8080
12:20:28:WARNING: WorkServer connection failed on port 8080 trying 80
12:20:28:Connecting to 171.67.108.25:80
12:20:29:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
12:27:18:Sending unit results: id:00 state:SEND project:6511 run:0 clone:312 gen:20 core:0x78 unit:0x136027624d99ab4c001401380000196f
12:27:18:Unit 00: Uploading 3.92KiB
12:27:18:Connecting to 171.64.65.62:8080
12:27:19:WARNING: Exception: Failed to send results to work server: Failed to read response packet
12:27:19:Trying to send results to collection server
12:27:19:Unit 00: Uploading 3.92KiB
12:27:19:Connecting to 171.67.108.25:8080
12:27:20:WARNING: WorkServer connection failed on port 8080 trying 80
12:27:20:Connecting to 171.67.108.25:80
12:27:21:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
12:36:43:Unit 02:Writing local files
12:36:43:Unit 02:Completed 2500 out of 250000 steps  (1%)
12:38:24:Sending unit results: id:00 state:SEND project:6511 run:0 clone:312 gen:20 core:0x78 unit:0x136027624d99ab4c001401380000196f
12:38:24:Unit 00: Uploading 3.92KiB
12:38:24:Connecting to 171.64.65.62:8080
12:38:24:WARNING: Exception: Failed to send results to work server: Failed to read response packet
12:38:24:Trying to send results to collection server
12:38:24:Connecting to 171.67.108.25:8080
12:38:25:WARNING: WorkServer connection failed on port 8080 trying 80
12:38:25:Connecting to 171.67.108.25:80
12:38:26:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
12:42:36:Sending unit results: id:01 state:SEND project:6502 run:0 clone:589 gen:41 core:0x78 unit:0x16f7dec64d9938390029024d00001966
12:42:36:Unit 01: Uploading 5.91KiB
12:42:36:Connecting to 171.64.65.62:8080
12:42:36:WARNING: Exception: Failed to send results to work server: Failed to read response packet
12:42:36:Trying to send results to collection server
12:42:37:Unit 01: Uploading 5.91KiB
12:42:37:Connecting to 171.67.108.25:8080
12:42:38:WARNING: WorkServer connection failed on port 8080 trying 80
12:42:38:Connecting to 171.67.108.25:80
12:42:39:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
12:56:12:Unit 02:Writing local files
12:56:12:Unit 02:Completed 5000 out of 250000 steps  (2%)
12:56:21:Sending unit results: id:00 state:SEND project:6511 run:0 clone:312 gen:20 core:0x78 unit:0x136027624d99ab4c001401380000196f
12:56:21:Unit 00: Uploading 3.92KiB
12:56:21:Connecting to 171.64.65.62:8080
12:56:21:WARNING: Exception: Failed to send results to work server: Failed to read response packet
12:56:21:Trying to send results to collection server
12:56:21:Connecting to 171.67.108.25:8080
12:56:22:WARNING: WorkServer connection failed on port 8080 trying 80
12:56:22:Connecting to 171.67.108.25:80
12:56:23:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
13:09:17:Unit 02:Writing local files
13:09:17:Unit 02:Completed 7500 out of 250000 steps  (3%)
13:22:28:Unit 02:Writing local files
13:22:29:Unit 02:Completed 10000 out of 250000 steps  (4%)
13:25:23:Sending unit results: id:00 state:SEND project:6511 run:0 clone:312 gen:20 core:0x78 unit:0x136027624d99ab4c001401380000196f
13:25:23:Unit 00: Uploading 3.92KiB
13:25:23:Connecting to 171.64.65.62:8080
13:25:23:WARNING: Exception: Failed to send results to work server: Failed to read response packet
13:25:23:Trying to send results to collection server
13:25:23:Connecting to 171.67.108.25:8080
13:25:24:WARNING: WorkServer connection failed on port 8080 trying 80
13:25:24:Connecting to 171.67.108.25:80
13:25:25:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
13:29:35:Sending unit results: id:01 state:SEND project:6502 run:0 clone:589 gen:41 core:0x78 unit:0x16f7dec64d9938390029024d00001966
13:29:35:Unit 01: Uploading 5.91KiB
13:29:35:Connecting to 171.64.65.62:8080
13:29:35:WARNING: Exception: Failed to send results to work server: Failed to read response packet
13:29:35:Trying to send results to collection server
13:29:35:Connecting to 171.67.108.25:8080
13:29:36:WARNING: WorkServer connection failed on port 8080 trying 80
13:29:36:Connecting to 171.67.108.25:80
13:29:37:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
13:35:32:Unit 02:Writing local files
13:35:32:Unit 02:Completed 12500 out of 250000 steps  (5%)
13:48:37:Unit 02:Writing local files
13:48:37:Unit 02:Completed 15000 out of 250000 steps  (6%)
14:01:42:Unit 02:Writing local files
14:01:42:Unit 02:Completed 17500 out of 250000 steps  (7%)
14:12:22:Sending unit results: id:00 state:SEND project:6511 run:0 clone:312 gen:20 core:0x78 unit:0x136027624d99ab4c001401380000196f
14:12:22:Unit 00: Uploading 3.92KiB
14:12:22:Connecting to 171.64.65.62:8080
14:12:22:WARNING: Exception: Failed to send results to work server: Failed to read response packet
14:12:22:Trying to send results to collection server
14:12:22:Connecting to 171.67.108.25:8080
14:12:23:WARNING: WorkServer connection failed on port 8080 trying 80
14:12:23:Connecting to 171.67.108.25:80
14:12:24:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
14:14:46:Unit 02:Writing local files
14:14:46:Unit 02:Completed 20000 out of 250000 steps  (8%)
14:27:50:Unit 02:Writing local files
14:27:50:Unit 02:Completed 22500 out of 250000 steps  (9%)
14:40:54:Unit 02:Writing local files
14:40:55:Unit 02:Completed 25000 out of 250000 steps  (10%)
14:45:36:Sending unit results: id:01 state:SEND project:6502 run:0 clone:589 gen:41 core:0x78 unit:0x16f7dec64d9938390029024d00001966
14:45:36:Unit 01: Uploading 5.91KiB
14:45:36:Connecting to 171.64.65.62:8080
14:45:36:WARNING: Exception: Failed to send results to work server: Failed to read response packet
14:45:36:Trying to send results to collection server
14:45:36:Connecting to 171.67.108.25:8080
14:45:37:WARNING: WorkServer connection failed on port 8080 trying 80
14:45:37:Connecting to 171.67.108.25:80
14:45:38:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
14:54:00:Unit 02:Writing local files
14:54:00:Unit 02:Completed 27500 out of 250000 steps  (11%)
15:02:49:Server connection id=19 on 0.0.0.0:36330 from 192.168.10.200:3631
15:02:49:Started thread 35 on PID 192
15:07:20:Unit 02:Writing local files
15:07:20:Unit 02:Completed 30000 out of 250000 steps  (12%)
15:20:45:Unit 02:Writing local files
15:20:45:Unit 02:Completed 32500 out of 250000 steps  (13%)
15:28:23:Sending unit results: id:00 state:SEND project:6511 run:0 clone:312 gen:20 core:0x78 unit:0x136027624d99ab4c001401380000196f
15:28:23:Unit 00: Uploading 3.92KiB
15:28:23:Connecting to 171.64.65.62:8080
15:28:23:WARNING: Exception: Failed to send results to work server: Failed to read response packet
15:28:23:Trying to send results to collection server
15:28:23:Connecting to 171.67.108.25:8080
15:28:24:WARNING: WorkServer connection failed on port 8080 trying 80
15:28:24:Connecting to 171.67.108.25:80
15:28:25:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
15:33:56:Unit 02:Writing local files
15:33:56:Unit 02:Completed 35000 out of 250000 steps  (14%)
15:47:03:Unit 02:Writing local files
15:47:03:Unit 02:Completed 37500 out of 250000 steps  (15%)
16:00:11:Unit 02:Writing local files
16:00:11:Unit 02:Completed 40000 out of 250000 steps  (16%)
16:06:04:Server connection id=20 on 0.0.0.0:36330 from 192.168.10.200:3678
16:06:04:Started thread 36 on PID 192
16:13:21:Unit 02:Writing local files
16:13:21:Unit 02:Completed 42500 out of 250000 steps  (17%)
16:19:26:Server connection id=21 on 0.0.0.0:36330 from 192.168.10.200:3685
16:19:26:Started thread 37 on PID 192
16:26:33:Unit 02:Writing local files
16:26:33:Unit 02:Completed 45000 out of 250000 steps  (18%)
16:40:24:Unit 02:Writing local files
16:40:24:Unit 02:Completed 47500 out of 250000 steps  (19%)
16:47:37:Server connection id=22 on 0.0.0.0:36330 from 192.168.10.200:3707
16:47:37:Started thread 38 on PID 192
16:47:38:Server connection id=23 on 0.0.0.0:36330 from 192.168.10.200:3708
16:47:38:Started thread 39 on PID 192
16:48:35:Sending unit results: id:01 state:SEND project:6502 run:0 clone:589 gen:41 core:0x78 unit:0x16f7dec64d9938390029024d00001966
16:48:35:Unit 01: Uploading 5.91KiB
16:48:35:Connecting to 171.64.65.62:8080
16:48:36:WARNING: Exception: Failed to send results to work server: Failed to read response packet
16:48:36:Trying to send results to collection server
16:48:36:Unit 01: Uploading 5.91KiB
16:48:36:Connecting to 171.67.108.25:8080
16:48:37:WARNING: WorkServer connection failed on port 8080 trying 80
16:48:37:Connecting to 171.67.108.25:80
16:48:38:ERROR: Exception: Failed to connect to 171.67.108.25:80: No connection could be made because the target machine actively refused it.
16:53:52:Unit 02:Writing local files
16:53:52:Unit 02:Completed 50000 out of 250000 steps  (20%)
17:09:04:Unit 02:Writing local files
17:09:05:Unit 02:Completed 52500 out of 250000 steps  (21%)
17:23:30:Unit 02:Writing local files
17:23:30:Unit 02:Completed 55000 out of 250000 steps  (22%)
Re: Project: 6511 (Run 0, Clone 312, Gen 20) EUE at 2%.
Ticket #122 and Ticket #615 cover at least some of the issues you've raised.
GreyWhiskers
--i7 2600K@4.2 GHz
--750W Corsair PS
@bruce. Thank you very much for the links. :D
I just looked through the history of Ticket #615, and it describes pretty exactly what I'm still seeing. Two WUs EUEed on 4 April. It's continuing to get new WUs, successfully process them, and upload them. But, my client is, indeed, continuing to hammer the server trying to get rid of the old EUEed WUs. For all I know, it will continue to hammer until the WUs expire on Apr 20/May 8 (each WU has a different expiration date).
Thanks to the existing design, the backoff does work, as observed in the Ticket 615 narrative, but it's still hammering every several hours.
At this point, how do I get rid of the two WUs that the client is repetitively trying to upload?
Can I just get rid of the two folders in the Work section, or is it more complicated so as not to screw up the client?
C:\Documents and Settings\Admin\Application Data\FAHClient\work\00
C:\Documents and Settings\Admin\Application Data\FAHClient\work\01
From WU Status pane:
Work Queue ID 01
Project 6502
FahCore 0x78
Waiting on Send Results
Attempts 28
Next attempt 3 hours 32 minutes
Unit ID: 0x16f7dec64d9938390029024d00001966
Work Queue ID 00
Project 6511
FahCore 0x78
Attempts 28
Next attempt 3 hours 30 minutes
Unit ID: 0x136027624d99ab4c001401380000196f
GreyWhiskers wrote:how do I get rid of the two WUs that the client is repetitively trying to upload?
You have two WUs you need to get rid of: WorkQueue 01 and 00.
Assuming Windows, go to the Start+All_Programs and find the shortcut for FAHClient. Copy it to the desktop. Edit the Target by adding a parameter string to the extreme right end of whatever is already there. ...FAHClient.exe" --dump 1. Stop the production copy of FAHClient and run that shortcut. Replace 1 with 0 and run it again.
GreyWhiskers
--i7 2600K@4.2 GHz
--750W Corsair PS
@Bruce. Perfect. The modified shortcut cleaned up the offending Work Queue items, and when I restarted the FAHControl, it went right back to processing the WU it was working on before. Of course, I had to re'add the connection to the other computers I have running V7, but its all OK now.
FYI, the client user guide documents the dump parameter, but I didn't see anything with the Queue position to dump.
dump
Dump all work units from the queue and start over. Warning you will not get even partial credit for dumped units.
