Project: 6512 (Run 6, Clone 260, Gen 55)
OEOTS
Hardware configuration: Main PC: Intel E6400 @ 3.0 Ghz, 4GB RAM, EN7900GS, Win XP SP3
Post by OEOTS »
Another EUE on this machine, the last one was a bad WU I hope this one is as well ;)
As it would be the last day of stability testing this machine.
EDIT: just to be clear, it's not an overclocked machine.
# Windows CPU Systray Edition #################################################
                          http://folding.stanford.edu
Launch directory: C:\Program Files\Folding@home 2\Folding@home-x86
Arguments: -verbosity 9 -advmethods
[08:39:26] - Ask before connecting: No
[08:39:26] - User name: OEOTS (Team 195604)
[08:39:26] - User ID: *****************
[08:39:26] - Machine ID: 2
[08:39:26]
[08:39:27] Loaded queue successfully.
[08:39:27] Deleting incompletely fetched item (4) from queue position #9
[08:39:27] - Warning: Could not delete all work unit files (9): Core file absent
[08:39:27] Initialization complete
[08:39:27] - Preparing to get new work unit...
[08:39:27] - Autosending finished units... [March 29 08:39:27 UTC]
[08:39:27] + Attempting to get work packet
[08:39:27] Trying to send all finished work units
[08:39:27] Project: 6516 (Run 1, Clone 212, Gen 23)
[08:39:27] - Read packet limit of 540015616... Set to 524286976.
[08:39:27] + Attempting to send results [March 29 08:39:27 UTC]
[08:39:27] - Will indicate memory of 1023 MB
[08:39:27] - Detect CPU. Vendor: GenuineIntel, Family: 15, Model: 4, Stepping: 3
[08:39:27] - Connecting to assignment server
[08:39:27] Connecting to http://assign.stanford.edu:8080/
[08:39:27] - Reading file work/wuresults_08.dat from core
[08:39:27]   (Read 736748 bytes from disk)
[08:39:27] Connecting to http://171.64.65.62:8080/
[08:39:28] Posted data.
[08:39:28] Initial: 40AB; - Successful: assigned to (171.64.65.62).
[08:39:28] + News From Folding@Home: Welcome to Folding@Home
[08:39:28] Loaded queue successfully.
[08:39:28] Connecting to http://171.64.65.62:8080/
[08:39:30] Posted data.
[08:39:30] Initial: 0000; - Receiving payload (expected size: 422277)
[08:39:35] Posted data.
[08:39:36] Initial: 0000; - Downloaded at ~68 kB/s
[08:39:36] - Averaged speed for that direction ~141 kB/s
[08:39:36] + Received work.
[08:39:36] - Uploaded at ~80 kB/s
[08:39:36] - Averaged speed for that direction ~66 kB/s
[08:39:36] + Results successfully sent
[08:39:36] Thank you for your contribution to Folding@Home.
[08:39:36] + Number of Units Completed: 27
[08:39:36] + Closed connections
[08:39:36]
[08:39:36] + Processing work unit
[08:39:36] Core required: FahCore_78.exe
[08:39:36] Core found.
[08:39:36] Working on queue slot 09 [March 29 08:39:36 UTC]
[08:39:36] + Working ...
[08:39:36] - Calling '.\FahCore_78.exe -dir work/ -suffix 09 -priority 96 -checkpoint 15 -verbose -lifeline 2396 -version 623'
[08:39:36] + Sent 1 of 1 completed units to the server
[08:39:36] - Autosend completed
[08:39:36]
[08:39:36] *------------------------------*
[08:39:36] Folding@Home Gromacs Core
[08:39:36] Version 1.90 (March 8, 2006)
[08:39:36]
[08:39:36] Preparing to commence simulation
[08:39:36] - Looking at optimizations...
[08:39:36] - Created dyn
[08:39:36] - Files status OK
[08:39:37] - Expanded 421765 -> 2026461 (decompressed 480.4 percent)
[08:39:37] - Starting from initial work packet
[08:39:37]
[08:39:37] Project: 6512 (Run 6, Clone 260, Gen 55)
[08:39:37]
[08:39:37] Assembly optimizations on if available.
[08:39:37] Entering M.D.
[08:39:43] Protein: TR462_A_7 in water
[08:39:43]
[08:39:43] Writing local files
[08:39:43] Extra SSE boost OK.
[08:39:43] Completed 0 out of 250000 steps  (0%)
[08:46:15] Writing local files
[08:46:15] Completed 2500 out of 250000 steps  (1%)
[08:52:46] Writing local files
[12:02:09] Writing local files
[12:02:09] Completed 77500 out of 250000 steps  (31%)
[12:07:30] Gromacs cannot continue further.
[12:07:30] Going to send back what have done.
[12:07:30] logfile size: 32278
[12:07:30] - Writing 32814 bytes of core data to disk...
[12:07:30] Done: 32302 -> 5020 (compressed to 15.5 percent)
[12:07:30]   ... Done.
[12:07:30]
[12:07:30] Folding@home Core Shutdown: EARLY_UNIT_END
[12:07:33] CoreStatus = 72 (114)
[12:07:33] Sending work to server
[12:07:33] Project: 6512 (Run 6, Clone 260, Gen 55)
[12:07:33] - Read packet limit of 540015616... Set to 524286976.
Re: Project: 6512 (Run 6, Clone 260, Gen 55)
Someone else had troubles at the exact same progress as you ... we'll wait for an additional report, but it looks like a bad WU ...
OEOTS
Post by OEOTS »
Great, thanks for the fast response :)
6 Donors failed to fold this WU so it has been marked as a bad one.
