P6801 (Run 4394, Clone 1, Gen 2)
werty316
Post by werty316 »
This WU with a particular Run/Clone/Gen fails to run on two of my video cards.
The two video cards in question are factory overclocked(715/1430/1800) GTX 460 video cards.
Running both video cards at their stock clocks(675/1350/1800) didn't help.
When folding the GPU temperature on both cards never goes over 60°C.
Deleting the Work folder and queue.dat file didn't help.
Has any other donor successfully completed and sent this WU back?
[00:19:09] Folding@Home GPU Core
[00:19:09] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[00:19:09]
[00:19:09] Build host: SimbiosNvdWin7
[00:19:09] Board Type: NVIDIA/CUDA
[00:19:09] Core      : x=15
[00:19:09]  Window's signal control handler registered.
[00:19:09] Preparing to commence simulation
[00:19:09] - Looking at optimizations...
[00:19:09] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[00:19:09] - Created dyn
[00:19:09] - Files status OK
[00:19:09] sizeof(CORE_PACKET_HDR) = 512 file=<>
[00:19:09] - Expanded 39122 -> 171827 (decompressed 439.2 percent)
[00:19:09] Called DecompressByteArray: compressed_data_size=39122 data_size=171827, decompressed_data_size=171827 diff=0
[00:19:09] - Digital signature verified
[00:19:09]
[00:19:09] Project: 6801 (Run 4394, Clone 1, Gen 2)
[00:19:09]
[00:19:09] Assembly optimizations on if available.
[00:19:09] Entering M.D.
[00:19:11] Tpr hash work/wudata_01.tpr:  3072867433 4181462573 2689415243 1031181546 1959007100
[00:19:12] Working on ALZHEIMER'S DISEASE AMYLOID
[00:19:12] Client config found, loading data.
[00:19:12] Starting GUI Server
[00:19:13] Setting checkpoint frequency: 500000
[00:21:04] Completed    500000 out of 50000000 steps (1%).
[00:21:04] mdrun_gpu returned 52
[00:21:04] NANs detected on GPU
[00:21:04]
[00:21:04] Folding@home Core Shutdown: UNSTABLE_MACHINE
[00:21:07] CoreStatus = 7A (122)
[00:21:07] Sending work to server
[00:21:07] Project: 6801 (Run 4394, Clone 1, Gen 2)
[00:21:07] - Error: Could not get length of results file work/wuresults_01.dat
[00:21:07] - Error: Could not read unit 01 file. Removing from queue.
[00:21:07] - Preparing to get new work unit...
[00:21:07] Cleaning up work directory
[00:21:07] + Attempting to get work packet
[00:21:07] Passkey found
[00:21:07] Gpu type=3 species=30.
[00:21:07] - Connecting to assignment server
[00:21:08] - Successful: assigned to (171.64.65.64).
[00:21:08] + News From Folding@Home: Welcome to Folding@Home
[00:21:08] Loaded queue successfully.
[00:21:08] Gpu type=3 species=30.
[00:21:09] + Closed connections
[00:21:14]
[00:21:14] + Processing work unit
[00:21:14] Core required: FahCore_15.exe
[00:21:14] Core found.
[00:21:14] Working on queue slot 02 [March 4 00:21:14 UTC]
[00:21:14] + Working ...
[00:21:14]
[00:21:14] *------------------------------*
[00:21:14] Folding@Home GPU Core
[00:21:14] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[00:21:14]
[00:21:14] Build host: SimbiosNvdWin7
[00:21:14] Board Type: NVIDIA/CUDA
[00:21:14] Core      : x=15
[00:21:14]  Window's signal control handler registered.
[00:21:14] Preparing to commence simulation
[00:21:14] - Looking at optimizations...
[00:21:14] DeleteFrameFiles: successfully deleted file=work/wudata_02.ckp
[00:21:14] - Created dyn
[00:21:14] - Files status OK
[00:21:14] sizeof(CORE_PACKET_HDR) = 512 file=<>
[00:21:14] - Expanded 39122 -> 171827 (decompressed 439.2 percent)
[00:21:14] Called DecompressByteArray: compressed_data_size=39122 data_size=171827, decompressed_data_size=171827 diff=0
[00:21:14] - Digital signature verified
[00:21:14]
[00:21:14] Project: 6801 (Run 4394, Clone 1, Gen 2)
[00:21:14]
[00:21:14] Assembly optimizations on if available.
[00:21:14] Entering M.D.
[00:21:16] Tpr hash work/wudata_02.tpr:  3072867433 4181462573 2689415243 1031181546 1959007100
[00:21:16] Working on ALZHEIMER'S DISEASE AMYLOID
[00:21:16] Client config found, loading data.
[00:21:16] Starting GUI Server
[00:21:17] Setting checkpoint frequency: 500000
The same WU from a different Run/Clone/Gen runs just fine though:
[03:35:09] Folding@Home GPU Core
[03:35:09] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[03:35:09]
[03:35:09] Build host: SimbiosNvdWin7
[03:35:09] Board Type: NVIDIA/CUDA
[03:35:09] Core      : x=15
[03:35:09]  Window's signal control handler registered.
[03:35:09] Preparing to commence simulation
[03:35:09] - Looking at optimizations...
[03:35:10] - Files status OK
[03:35:10] sizeof(CORE_PACKET_HDR) = 512 file=<>
[03:35:10] - Expanded 43575 -> 171827 (decompressed 394.3 percent)
[03:35:10] Called DecompressByteArray: compressed_data_size=43575 data_size=171827, decompressed_data_size=171827 diff=0
[03:35:10] - Digital signature verified
[03:35:10]
[03:35:10] Project: 6801 (Run 4973, Clone 2, Gen 32)
[03:35:10]
[03:35:10] Assembly optimizations on if available.
[03:35:10] Entering M.D.
[03:35:13] Will resume from checkpoint file work/wudata_05.ckp
[03:35:13] Tpr hash work/wudata_05.tpr:  1514002132 4237460176 2088203303 1177227995 2996086443
[03:35:15] Working on ALZHEIMER'S DISEASE AMYLOID
[03:35:15] Client config found, loading data.
[03:35:16] Starting GUI Server
[03:35:27] Resuming from checkpoint
[03:35:27] fcCheckPointResume: retreived and current tpr file hash:
[03:35:27]    0   1514002132   1514002132
[03:35:27]    1   4237460176   4237460176
[03:35:27]    2   2088203303   2088203303
[03:35:27]    3   1177227995   1177227995
[03:35:27]    4   2996086443   2996086443
[03:35:27] fcCheckPointResume: file hashes same.
[03:35:27] fcCheckPointResume: state restored.
[03:35:27] fcCheckPointResume: name work/wudata_05.log Verified work/wudata_05.log
[03:35:27] fcCheckPointResume: name work/wudata_05.trr Verified work/wudata_05.trr
[03:35:27] fcCheckPointResume: name work/wudata_05.xtc Verified work/wudata_05.xtc
[03:35:28] fcCheckPointResume: name work/wudata_05.edr Verified work/wudata_05.edr
[03:35:28] fcCheckPointResume: state restored 2
[03:35:28] Resumed from checkpoint
[03:35:28] Setting checkpoint frequency: 500000
[03:35:28] Completed  40500001 out of 50000000 steps (81%).
[03:37:30] Completed  40999999 out of 50000000 steps (82%).
[03:39:27] Completed  41499999 out of 50000000 steps (83%).
[03:41:24] Completed  41999999 out of 50000000 steps (84%).
[03:43:20] Completed  42499999 out of 50000000 steps (85%).
[03:45:17] Completed  42999999 out of 50000000 steps (86%).
[03:47:14] Completed  43499999 out of 50000000 steps (87%).
[03:49:11] Completed  43999999 out of 50000000 steps (88%).
[03:51:08] Completed  44499999 out of 50000000 steps (89%).
[03:53:04] Completed  44999999 out of 50000000 steps (90%).
[03:55:01] Completed  45499999 out of 50000000 steps (91%).
[03:56:58] Completed  45999999 out of 50000000 steps (92%).
[03:58:55] Completed  46499999 out of 50000000 steps (93%).
[04:00:52] Completed  46999999 out of 50000000 steps (94%).
[04:02:48] Completed  47499999 out of 50000000 steps (95%).
[04:04:45] Completed  47999999 out of 50000000 steps (96%).
[04:06:42] Completed  48499999 out of 50000000 steps (97%).
[04:08:39] Completed  48999999 out of 50000000 steps (98%).
[04:10:36] Completed  49499999 out of 50000000 steps (99%).
[04:12:33] Completed  49999999 out of 50000000 steps (100%).
[04:12:33] Finished fah_main
[04:12:33]
[04:12:33] Successful run
[04:12:33] DynamicWrapper: Finished Work Unit: sleep=10000
[04:12:43] Reserved 2469276 bytes for xtc file; Cosm status=0
[04:12:43] Allocated 2469276 bytes for xtc file
[04:12:43] - Reading up to 2469276 from "work/wudata_05.xtc": Read 2469276
[04:12:43] Read 2469276 bytes from xtc file; available packet space=783961188
[04:12:43] xtc file hash check passed.
[04:12:43] Reserved 76680 76680 783961188 bytes for arc file=<work/wudata_05.trr> Cosm status=0
[04:12:43] Allocated 76680 bytes for arc file
[04:12:43] - Reading up to 76680 from "work/wudata_05.trr": Read 76680
[04:12:43] Read 76680 bytes from arc file; available packet space=783884508
[04:12:43] trr file hash check passed.
[04:12:43] Allocated 544 bytes for edr file
[04:12:43] Read bedfile
[04:12:43] edr file hash check passed.
[04:12:43] Allocated 121268 bytes for logfile
[04:12:43] Read logfile
[04:12:43] GuardedRun: success in DynamicWrapper
[04:12:43] GuardedRun: done
[04:12:43] Run: GuardedRun completed.
[04:12:45] + Opened results file
[04:12:45] - Writing 2668280 bytes of core data to disk...
[04:12:46] Done: 2667768 -> 2508094 (compressed to 94.0 percent)
[04:12:46]   ... Done.
[04:12:46] DeleteFrameFiles: successfully deleted file=work/wudata_05.ckp
[04:12:47] Shutting down core
[04:12:47]
[04:12:47] Folding@home Core Shutdown: FINISHED_UNIT
[04:12:50] CoreStatus = 64 (100)
[04:12:50] Sending work to server
[04:12:50] Project: 6801 (Run 4973, Clone 2, Gen 32)
[04:12:50] + Attempting to send results [March 2 04:12:50 UTC]
[04:12:50] Gpu type=3 species=30.
[04:13:33] + Results successfully sent
[04:13:33] Thank you for your contribution to Folding@Home.
Re: P6801 (Run 4394, Clone 1, Gen 2)
werty316 wrote:Has any other donor successfully completed and sent this WU back?
There's no result in the DB yet for this WU :(
Can you make a backup copy of the WORK directory after the download completes and before it gets the error? If so send it to me.
The only way I know to get rid of the WU is to change your MachineID (but after you capture that backup for me).
werty316
Post by werty316 »
After the files have been downloaded I will backup the WORK folder as a self extracting executable. How do I send you the file?
EDIT: The file has been sent.
rwh202
3x GTX 1080 Ti
3x GTX 1060
Various other bits and pieces
Post by rwh202 »
Hi,
I had this WU fail repeatedly about 10 days ago. I didn't report it because I assumed it was just my hardware issue - but apparently not!
It was on a stock GTX 460 with a broken fan that was running at 90+ C. (I've since cleaned out the dust and fitted some new fans)
Rob
No data in the WU database yet.
SupplyChain
Post by SupplyChain »
I'm now getting this same project, P6801 (Run 4394, Clone 1, Gen 2). I have 3 GTX470's in one of my folding rigs. On one card, I keep getting NANs detected on GPU for this project. I've tried to lower the shader clock, increasing voltage to the card, all on a card that hasn't had any issues in the past. I still can not get this wu to 1% completion. I've noticed others have posted on this wu as well. Is there anything I can provide regarding this wu? Thanks.
Welcome to the F@H Forum SupplyChain,
We would need to see your FAHlog (viewtopic.php?p=160884#p160884). If I were to count both reports, it is 2 and we need a minimum of 3 to mark it as a bad WU (viewtopic.php?f=19&t=16526#p164322). There is still no data in the WU Database
SupplyChain
This is my first try at this, so hopefully I get this right:
--- Opening Log file [March 19 00:19:38 UTC]
                       Folding@Home Client Version 6.30r1
                          http://folding.stanford.edu
Launch directory: C:\FAH\GTX470-1
Executable: C:\FAH\GTX470-1\Folding@home-Win32-gpu.exe
Arguments: -gpu 0 -verbosity 9
[00:19:38] - Ask before connecting: No
[00:19:38] - User name:
[00:19:38] - User ID:
[00:19:38] - Machine ID: 2
[00:19:38]
[00:19:38] Gpu type=3 species=30.
[00:19:38] Work directory not found. Creating...
[00:19:38] Could not open work queue, generating new queue...
[00:19:38] - Preparing to get new work unit...
[00:19:38] Cleaning up work directory
[00:19:38] + Attempting to get work packet
[00:19:38] Passkey found
[00:19:38] - Autosending finished units... [March 19 00:19:38 UTC]
[00:19:38] - Will indicate memory of 4093 MB
[00:19:38] Trying to send all finished work units
[00:19:38] + No unsent completed units remaining.
[00:19:38] - Detect CPU.[00:19:38] - Autosend completed
 Vendor: GenuineIntel, Family: 6, Model: 7, Stepping: 7
[00:19:38] - Connecting to assignment server
[00:19:38] Connecting to http://assign-GPU.stanford.edu:8080/
[00:19:39] Posted data.
[00:19:39] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[00:19:39] + News From Folding@Home: Welcome to Folding@Home
[00:19:39] Loaded queue successfully.
[00:19:39] Gpu type=3 species=30.
[00:19:39] Sent data
[00:19:39] Connecting to http://171.64.65.64:8080/
[00:19:39] Initial: 0000; - Receiving payload (expected size: 39634)
[00:19:40] - Downloaded at ~38 kB/s
[00:19:40] - Averaged speed for that direction ~38 kB/s
[00:19:40] + Received work.
[00:19:40] + Closed connections
[00:19:40]
[00:19:40] + Processing work unit
[00:19:40] Core required: FahCore_15.exe
[00:19:40] Core found.
[00:19:40] Working on queue slot 01 [March 19 00:19:40 UTC]
[00:19:40] + Working ...
[00:19:40] - Calling '.\FahCore_15.exe -dir work/ -suffix 01 -nice 19 -priority 96 -nocpulock -checkpoint 3 -verbose -lifeline 4444 -version 630'
[00:19:40]
[00:19:40] *------------------------------*
[00:19:40] Folding@Home GPU Core
[00:19:40] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[00:19:40]
[00:19:40] Build host: SimbiosNvdWin7
[00:19:40] Board Type: NVIDIA/CUDA
[00:19:40] Core      : x=15
[00:19:40]  Window's signal control handler registered.
[00:19:40] Preparing to commence simulation
[00:19:40] - Looking at optimizations...
[00:19:40] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[00:19:40] - Created dyn
[00:19:40] - Files status OK
[00:19:40] sizeof(CORE_PACKET_HDR) = 512 file=<>
[00:19:40] - Expanded 39122 -> 171827 (decompressed 439.2 percent)
[00:19:40] Called DecompressByteArray: compressed_data_size=39122 data_size=171827, decompressed_data_size=171827 diff=0
[00:19:40] - Digital signature verified
[00:19:40]
[00:19:40] Project: 6801 (Run 4394, Clone 1, Gen 2)
[00:19:40]
[00:19:40] Assembly optimizations on if available.
[00:19:40] Entering M.D.
[00:19:42] Tpr hash work/wudata_01.tpr:  3072867433 4181462573 2689415243 1031181546 1959007100
[00:19:42] Working on ALZHEIMER'S DISEASE AMYLOID
[00:19:42] Client config found, loading data.
[00:19:42] Starting GUI Server
[00:19:42] Setting checkpoint frequency: 500000
[00:21:00] Completed    500000 out of 50000000 steps (1%).
[00:21:00] mdrun_gpu returned 52
[00:21:00] NANs detected on GPU
[00:21:00]
[00:21:00] Folding@home Core Shutdown: UNSTABLE_MACHINE
[00:21:04] CoreStatus = 7A (122)
[00:21:04] Sending work to server
[00:21:04] Project: 6801 (Run 4394, Clone 1, Gen 2)
[00:21:04] - Read packet limit of 540015616... Set to 524286976.
[00:21:04] - Error: Could not get length of results file work/wuresults_01.dat
[00:21:04] - Error: Could not read unit 01 file. Removing from queue.
[00:21:04] Trying to send all finished work units
[00:21:04] + No unsent completed units remaining.
[00:21:04] - Preparing to get new work unit...
[00:21:04] Cleaning up work directory
[00:21:04] + Attempting to get work packet
[00:21:04] Passkey found
[00:21:04] - Will indicate memory of 4093 MB
[00:21:04] Gpu type=3 species=30.
[00:21:04] - Connecting to assignment server
[00:21:04] Connecting to http://assign-GPU.stanford.edu:8080/
[00:21:05] Posted data.
[00:21:05] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[00:21:05] + News From Folding@Home: Welcome to Folding@Home
[00:21:05] Loaded queue successfully.
[00:21:05] Gpu type=3 species=30.
[00:21:05] Sent data
[00:21:05] Connecting to http://171.64.65.64:8080/
[00:21:05] Initial: 0000; - Receiving payload (expected size: 39634)
[00:21:06] - Downloaded at ~38 kB/s
[00:21:06] - Averaged speed for that direction ~38 kB/s
[00:21:06] + Received work.
[00:21:06] Trying to send all finished work units
[00:21:06] + No unsent completed units remaining.
[00:21:06] + Closed connections
[00:21:11]
[00:21:11] + Processing work unit
[00:21:11] Core required: FahCore_15.exe
[00:21:11] Core found.
[00:21:11] Working on queue slot 02 [March 19 00:21:11 UTC]
[00:21:11] + Working ...
[00:21:11] - Calling '.\FahCore_15.exe -dir work/ -suffix 02 -nice 19 -priority 96 -nocpulock -checkpoint 3 -verbose -lifeline 4444 -version 630'
[00:21:11]
[00:21:11] *------------------------------*
[00:21:11] Folding@Home GPU Core
[00:21:11] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[00:21:11]
[00:21:11] Build host: SimbiosNvdWin7
[00:21:11] Board Type: NVIDIA/CUDA
[00:21:11] Core      : x=15
[00:21:11]  Window's signal control handler registered.
[00:21:11] Preparing to commence simulation
[00:21:11] - Looking at optimizations...
[00:21:11] DeleteFrameFiles: successfully deleted file=work/wudata_02.ckp
[00:21:11] - Created dyn
[00:21:11] - Files status OK
[00:21:11] sizeof(CORE_PACKET_HDR) = 512 file=<>
[00:21:11] - Expanded 39122 -> 171827 (decompressed 439.2 percent)
[00:21:11] Called DecompressByteArray: compressed_data_size=39122 data_size=171827, decompressed_data_size=171827 diff=0
[00:21:11] - Digital signature verified
[00:21:11]
[00:21:11] Project: 6801 (Run 4394, Clone 1, Gen 2)
[00:21:11]
[00:21:11] Assembly optimizations on if available.
[00:21:11] Entering M.D.
[00:21:13] Tpr hash work/wudata_02.tpr:  3072867433 4181462573 2689415243 1031181546 1959007100
[00:21:13] Working on ALZHEIMER'S DISEASE AMYLOID
[00:21:13] Client config found, loading data.
[00:21:13] Starting GUI Server
[00:21:13] Setting checkpoint frequency: 500000
[00:22:31] Completed    500000 out of 50000000 steps (1%).
[00:22:31] mdrun_gpu returned 52
[00:22:31] NANs detected on GPU
[00:22:31]
[00:22:31] Folding@home Core Shutdown: UNSTABLE_MACHINE
[00:22:35] CoreStatus = 7A (122)
[00:22:35] Sending work to server
[00:22:35] Project: 6801 (Run 4394, Clone 1, Gen 2)
[00:22:35] - Read packet limit of 540015616... Set to 524286976.
[00:22:35] - Error: Could not get length of results file work/wuresults_02.dat
[00:22:35] - Error: Could not read unit 02 file. Removing from queue.
[00:22:35] Trying to send all finished work units
[00:22:35] + No unsent completed units remaining.
[00:22:35] - Preparing to get new work unit...
[00:22:35] Cleaning up work directory
[00:22:35] + Attempting to get work packet
[00:22:35] Passkey found
[00:22:35] - Will indicate memory of 4093 MB
[00:22:35] Gpu type=3 species=30.
[00:22:35] - Connecting to assignment server
[00:22:35] Connecting to http://assign-GPU.stanford.edu:8080/
[00:22:36] Posted data.
[00:22:36] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[00:22:36] + News From Folding@Home: Welcome to Folding@Home
[00:22:36] Loaded queue successfully.
[00:22:36] Gpu type=3 species=30.
[00:22:36] Sent data
[00:22:36] Connecting to http://171.64.65.64:8080/
[00:22:36] Initial: 0000; - Receiving payload (expected size: 39634)
[00:22:37] - Downloaded at ~38 kB/s
[00:22:37] - Averaged speed for that direction ~38 kB/s
[00:22:37] + Received work.
[00:22:37] Trying to send all finished work units
[00:22:37] + No unsent completed units remaining.
[00:22:37] + Closed connections
[00:22:42]
[00:22:42] + Processing work unit
[00:22:42] Core required: FahCore_15.exe
[00:22:42] Core found.
[00:22:42] Working on queue slot 03 [March 19 00:22:42 UTC]
[00:22:42] + Working ...
[00:22:42] - Calling '.\FahCore_15.exe -dir work/ -suffix 03 -nice 19 -priority 96 -nocpulock -checkpoint 3 -verbose -lifeline 4444 -version 630'
[00:22:42]
[00:22:42] *------------------------------*
[00:22:42] Folding@Home GPU Core
[00:22:42] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[00:22:42]
[00:22:42] Build host: SimbiosNvdWin7
[00:22:42] Board Type: NVIDIA/CUDA
[00:22:42] Core      : x=15
[00:22:42]  Window's signal control handler registered.
[00:22:42] Preparing to commence simulation
[00:22:42] - Looking at optimizations...
[00:22:42] DeleteFrameFiles: successfully deleted file=work/wudata_03.ckp
[00:22:42] - Created dyn
[00:22:42] - Files status OK
[00:22:42] sizeof(CORE_PACKET_HDR) = 512 file=<>
[00:22:42] - Expanded 39122 -> 171827 (decompressed 439.2 percent)
[00:22:42] Called DecompressByteArray: compressed_data_size=39122 data_size=171827, decompressed_data_size=171827 diff=0
[00:22:42] - Digital signature verified
[00:22:42]
[00:22:42] Project: 6801 (Run 4394, Clone 1, Gen 2)
[00:22:42]
[00:22:42] Assembly optimizations on if available.
[00:22:42] Entering M.D.
[00:22:44] Tpr hash work/wudata_03.tpr:  3072867433 4181462573 2689415243 1031181546 1959007100
[00:22:44] Working on ALZHEIMER'S DISEASE AMYLOID
[00:22:44] Client config found, loading data.
[00:22:44] Starting GUI Server
[00:22:44] Setting checkpoint frequency: 500000
[00:24:02] Completed    500000 out of 50000000 steps (1%).
[00:24:02] mdrun_gpu returned 52
[00:24:02] NANs detected on GPU
[00:24:02]
[00:24:02] Folding@home Core Shutdown: UNSTABLE_MACHINE
[00:24:06] CoreStatus = 7A (122)
[00:24:06] Sending work to server
[00:24:06] Project: 6801 (Run 4394, Clone 1, Gen 2)
[00:24:06] - Read packet limit of 540015616... Set to 524286976.
[00:24:06] - Error: Could not get length of results file work/wuresults_03.dat
[00:24:06] - Error: Could not read unit 03 file. Removing from queue.
[00:24:06] Trying to send all finished work units
[00:24:06] + No unsent completed units remaining.
[00:24:06] - Preparing to get new work unit...
[00:24:06] Cleaning up work directory
[00:24:06] + Attempting to get work packet
[00:24:06] Passkey found
[00:24:06] - Will indicate memory of 4093 MB
[00:24:06] Gpu type=3 species=30.
[00:24:06] - Connecting to assignment server
[00:24:06] Connecting to http://assign-GPU.stanford.edu:8080/
[00:24:07] Posted data.
[00:24:07] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[00:24:07] + News From Folding@Home: Welcome to Folding@Home
[00:24:07] Loaded queue successfully.
[00:24:07] Gpu type=3 species=30.
[00:24:07] Sent data
[00:24:07] Connecting to http://171.64.65.64:8080/
[00:24:07] Initial: 0000; - Receiving payload (expected size: 39634)
[00:24:08] - Downloaded at ~38 kB/s
[00:24:08] - Averaged speed for that direction ~38 kB/s
[00:24:08] + Received work.
[00:24:08] Trying to send all finished work units
[00:24:08] + No unsent completed units remaining.
[00:24:08] + Closed connections
[00:24:13]
[00:24:13] + Processing work unit
[00:24:13] Core required: FahCore_15.exe
[00:24:13] Core found.
[00:24:13] Working on queue slot 04 [March 19 00:24:13 UTC]
[00:24:13] + Working ...
[00:24:13] - Calling '.\FahCore_15.exe -dir work/ -suffix 04 -nice 19 -priority 96 -nocpulock -checkpoint 3 -verbose -lifeline 4444 -version 630'
[00:24:13]
[00:24:13] *------------------------------*
[00:24:13] Folding@Home GPU Core
[00:24:13] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[00:24:13]
[00:24:13] Build host: SimbiosNvdWin7
[00:24:13] Board Type: NVIDIA/CUDA
[00:24:13] Core      : x=15
[00:24:13]  Window's signal control handler registered.
[00:24:13] Preparing to commence simulation
[00:24:13] - Looking at optimizations...
[00:24:13] DeleteFrameFiles: successfully deleted file=work/wudata_04.ckp
[00:24:13] - Created dyn
[00:24:13] - Files status OK
[00:24:13] sizeof(CORE_PACKET_HDR) = 512 file=<>
[00:24:13] - Expanded 39122 -> 171827 (decompressed 439.2 percent)
[00:24:13] Called DecompressByteArray: compressed_data_size=39122 data_size=171827, decompressed_data_size=171827 diff=0
[00:24:13] - Digital signature verified
[00:24:13]
[00:24:13] Project: 6801 (Run 4394, Clone 1, Gen 2)
[00:24:13]
[00:24:13] Assembly optimizations on if available.
[00:24:13] Entering M.D.
[00:24:15] Tpr hash work/wudata_04.tpr:  3072867433 4181462573 2689415243 1031181546 1959007100
[00:24:15] Working on ALZHEIMER'S DISEASE AMYLOID
[00:24:15] Client config found, loading data.
[00:24:15] Starting GUI Server
[00:24:15] Setting checkpoint frequency: 500000
[00:25:33] Completed    500000 out of 50000000 steps (1%).
[00:25:33] mdrun_gpu returned 52
[00:25:33] NANs detected on GPU
[00:25:33]
[00:25:33] Folding@home Core Shutdown: UNSTABLE_MACHINE
[00:25:37] CoreStatus = 7A (122)
[00:25:37] Sending work to server
[00:25:37] Project: 6801 (Run 4394, Clone 1, Gen 2)
[00:25:37] - Read packet limit of 540015616... Set to 524286976.
[00:25:37] - Error: Could not get length of results file work/wuresults_04.dat
[00:25:37] - Error: Could not read unit 04 file. Removing from queue.
[00:25:37] Trying to send all finished work units
[00:25:37] + No unsent completed units remaining.
[00:25:37] - Preparing to get new work unit...
[00:25:37] Cleaning up work directory
[00:25:37] + Attempting to get work packet
[00:25:37] Passkey found
[00:25:37] - Will indicate memory of 4093 MB
[00:25:37] Gpu type=3 species=30.
[00:25:37] - Connecting to assignment server
[00:25:37] Connecting to http://assign-GPU.stanford.edu:8080/
[00:25:37] Posted data.
[00:25:37] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[00:25:37] + News From Folding@Home: Welcome to Folding@Home
[00:25:38] Loaded queue successfully.
[00:25:38] Gpu type=3 species=30.
[00:25:38] Sent data
[00:25:38] Connecting to http://171.64.65.64:8080/
[00:25:38] Posted data.
[00:25:38] Initial: 0000; - Receiving payload (expected size: 39634)
[00:25:38] Conversation time very short, giving reduced weight in bandwidth avg
[00:25:38] - Downloaded at ~77 kB/s
[00:25:38] - Averaged speed for that direction ~43 kB/s
[00:25:38] + Received work.
[00:25:38] Trying to send all finished work units
[00:25:38] + No unsent completed units remaining.
[00:25:38] + Closed connections
[00:25:43]
[00:25:43] + Processing work unit
[00:25:43] Core required: FahCore_15.exe
[00:25:43] Core found.
[00:25:43] Working on queue slot 05 [March 19 00:25:43 UTC]
[00:25:43] + Working ...
[00:25:43] - Calling '.\FahCore_15.exe -dir work/ -suffix 05 -nice 19 -priority 96 -nocpulock -checkpoint 3 -verbose -lifeline 4444 -version 630'
[00:25:44]
[00:25:44] *------------------------------*
[00:25:44] Folding@Home GPU Core
[00:25:44] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[00:25:44]
[00:25:44] Build host: SimbiosNvdWin7
[00:25:44] Board Type: NVIDIA/CUDA
[00:25:44] Core      : x=15
[00:25:44]  Window's signal control handler registered.
[00:25:44] Preparing to commence simulation
[00:25:44] - Looking at optimizations...
[00:25:44] DeleteFrameFiles: successfully deleted file=work/wudata_05.ckp
[00:25:44] - Created dyn
[00:25:44] - Files status OK
[00:25:44] sizeof(CORE_PACKET_HDR) = 512 file=<>
[00:25:44] - Expanded 39122 -> 171827 (decompressed 439.2 percent)
[00:25:44] Called DecompressByteArray: compressed_data_size=39122 data_size=171827, decompressed_data_size=171827 diff=0
[00:25:44] - Digital signature verified
[00:25:44]
[00:25:44] Project: 6801 (Run 4394, Clone 1, Gen 2)
[00:25:44]
[00:25:44] Assembly optimizations on if available.
[00:25:44] Entering M.D.
[00:25:46] Tpr hash work/wudata_05.tpr:  3072867433 4181462573 2689415243 1031181546 1959007100
[00:25:46] Working on ALZHEIMER'S DISEASE AMYLOID
[00:25:46] Client config found, loading data.
[00:25:46] Starting GUI Server
[00:25:46] Setting checkpoint frequency: 500000
[00:27:04] Completed    500000 out of 50000000 steps (1%).
[00:27:04] mdrun_gpu returned 52
[00:27:04] NANs detected on GPU
[00:27:04]
[00:27:04] Folding@home Core Shutdown: UNSTABLE_MACHINE
[00:27:08] CoreStatus = 7A (122)
[00:27:08] Sending work to server
[00:27:08] Project: 6801 (Run 4394, Clone 1, Gen 2)
[00:27:08] - Read packet limit of 540015616... Set to 524286976.
[00:27:08] - Error: Could not get length of results file work/wuresults_05.dat
[00:27:08] - Error: Could not read unit 05 file. Removing from queue.
[00:27:08] EUE limit exceeded. Pausing 24 hours.
--- Opening Log file [March 19 00:54:23 UTC]
[00:54:23] - Ask before connecting: No
[00:54:23] - User name:
[00:54:23] - User ID:
[00:54:23] - Machine ID: 2
[00:54:23]
[00:54:23] Gpu type=3 species=30.
[00:54:24] Loaded queue successfully.
[00:54:24] - Preparing to get new work unit...
[00:54:24] Cleaning up work directory
[00:54:24] - Autosending finished units... [March 19 00:54:24 UTC]
[00:54:24] Trying to send all finished work units
[00:54:24] + No unsent completed units remaining.
[00:54:24] - Autosend completed
[00:54:24] + Attempting to get work packet
[00:54:24] Passkey found
[00:54:24] - Will indicate memory of 4093 MB
[00:54:24] Gpu type=3 species=30.
[00:54:24] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 7, Stepping: 7
[00:54:24] - Connecting to assignment server
[00:54:24] Connecting to http://assign-GPU.stanford.edu:8080/
[00:54:25] Posted data.
[00:54:25] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[00:54:25] + News From Folding@Home: Welcome to Folding@Home
[00:54:25] Loaded queue successfully.
[00:54:25] Gpu type=3 species=30.
[00:54:25] Sent data
[00:54:25] Connecting to http://171.64.65.64:8080/
[00:54:25] Initial: 0000; - Receiving payload (expected size: 39634)
[00:54:26] - Downloaded at ~38 kB/s
[00:54:26] - Averaged speed for that direction ~42 kB/s
[00:54:26] + Received work.
[00:54:26] + Closed connections
[00:54:26]
[00:54:26] + Processing work unit
[00:54:26] Core required: FahCore_15.exe
[00:54:26] Core found.
[00:54:26] Working on queue slot 06 [March 19 00:54:26 UTC]
[00:54:26] + Working ...
[00:54:26] - Calling '.\FahCore_15.exe -dir work/ -suffix 06 -nice 19 -priority 96 -nocpulock -checkpoint 3 -verbose -lifeline 5692 -version 630'
[00:54:26]
[00:54:26] *------------------------------*
[00:54:26] Folding@Home GPU Core
[00:54:26] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[00:54:26]
[00:54:26] Build host: SimbiosNvdWin7
[00:54:26] Board Type: NVIDIA/CUDA
[00:54:26] Core      : x=15
[00:54:26]  Window's signal control handler registered.
[00:54:26] Preparing to commence simulation
[00:54:26] - Looking at optimizations...
[00:54:26] DeleteFrameFiles: successfully deleted file=work/wudata_06.ckp
[00:54:26] - Created dyn
[00:54:26] - Files status OK
[00:54:26] sizeof(CORE_PACKET_HDR) = 512 file=<>
[00:54:26] - Expanded 39122 -> 171827 (decompressed 439.2 percent)
[00:54:26] Called DecompressByteArray: compressed_data_size=39122 data_size=171827, decompressed_data_size=171827 diff=0
[00:54:26] - Digital signature verified
[00:54:27]
[00:54:27] Project: 6801 (Run 4394, Clone 1, Gen 2)
[00:54:27]
[00:54:27] Assembly optimizations on if available.
[00:54:27] Entering M.D.
[00:54:29] Tpr hash work/wudata_06.tpr:  3072867433 4181462573 2689415243 1031181546 1959007100
[00:54:29] Working on ALZHEIMER'S DISEASE AMYLOID
[00:54:29] Client config found, loading data.
[00:54:29] Starting GUI Server
[00:54:29] Setting checkpoint frequency: 500000
[00:55:49] Completed    500000 out of 50000000 steps (1%).
[00:55:49] mdrun_gpu returned 52
[00:55:49] NANs detected on GPU
[00:55:49]
[00:55:49] Folding@home Core Shutdown: UNSTABLE_MACHINE
[00:55:52] CoreStatus = 7A (122)
[00:55:52] Sending work to server
[00:55:52] Project: 6801 (Run 4394, Clone 1, Gen 2)
[00:55:52] - Read packet limit of 540015616... Set to 524286976.
[00:55:52] - Error: Could not get length of results file work/wuresults_06.dat
[00:55:52] - Error: Could not read unit 06 file. Removing from queue.
[00:55:52] Trying to send all finished work units
[00:55:52] + No unsent completed units remaining.
[00:55:52] - Preparing to get new work unit...
[00:55:52] Cleaning up work directory
[00:55:52] + Attempting to get work packet
[00:55:52] Passkey found
[00:55:52] - Will indicate memory of 4093 MB
[00:55:52] Gpu type=3 species=30.
[00:55:52] - Connecting to assignment server
[00:55:52] Connecting to http://assign-GPU.stanford.edu:8080/
[00:55:53] Posted data.
[00:55:53] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[00:55:53] + News From Folding@Home: Welcome to Folding@Home
[00:55:53] Loaded queue successfully.
[00:55:53] Gpu type=3 species=30.
[00:55:53] Sent data
[00:55:53] Connecting to http://171.64.65.64:8080/
[00:55:53] Initial: 0000; - Receiving payload (expected size: 39634)
[00:55:54] - Downloaded at ~38 kB/s
[00:55:54] - Averaged speed for that direction ~41 kB/s
[00:55:54] + Received work.
[00:55:54] Trying to send all finished work units
[00:55:54] + No unsent completed units remaining.
[00:55:54] + Closed connections
[00:55:59]
[00:55:59] + Processing work unit
[00:55:59] Core required: FahCore_15.exe
[00:55:59] Core found.
[00:55:59] Working on queue slot 07 [March 19 00:55:59 UTC]
[00:55:59] + Working ...
[00:55:59] - Calling '.\FahCore_15.exe -dir work/ -suffix 07 -nice 19 -priority 96 -nocpulock -checkpoint 3 -verbose -lifeline 5692 -version 630'
[00:55:59]
[00:55:59] *------------------------------*
[00:55:59] Folding@Home GPU Core
[00:55:59] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[00:55:59]
[00:55:59] Build host: SimbiosNvdWin7
[00:55:59] Board Type: NVIDIA/CUDA
[00:55:59] Core      : x=15
[00:55:59]  Window's signal control handler registered.
[00:55:59] Preparing to commence simulation
[00:55:59] - Looking at optimizations...
[00:55:59] DeleteFrameFiles: successfully deleted file=work/wudata_07.ckp
[00:55:59] - Created dyn
[00:55:59] - Files status OK
[00:55:59] sizeof(CORE_PACKET_HDR) = 512 file=<>
[00:55:59] - Expanded 39122 -> 171827 (decompressed 439.2 percent)
[00:55:59] Called DecompressByteArray: compressed_data_size=39122 data_size=171827, decompressed_data_size=171827 diff=0
[00:55:59] - Digital signature verified
[00:55:59]
[00:55:59] Project: 6801 (Run 4394, Clone 1, Gen 2)
[00:55:59]
[00:55:59] Assembly optimizations on if available.
[00:55:59] Entering M.D.
[00:56:01] Tpr hash work/wudata_07.tpr:  3072867433 4181462573 2689415243 1031181546 1959007100
[00:56:01] Working on ALZHEIMER'S DISEASE AMYLOID
[00:56:01] Client config found, loading data.
[00:56:01] Starting GUI Server
[00:56:01] Setting checkpoint frequency: 500000
[00:57:19] Completed    500000 out of 50000000 steps (1%).
[00:57:19] mdrun_gpu returned 52
[00:57:19] NANs detected on GPU
[00:57:19]
[00:57:19] Folding@home Core Shutdown: UNSTABLE_MACHINE
[00:57:23] CoreStatus = 7A (122)
[00:57:23] Sending work to server
[00:57:23] Project: 6801 (Run 4394, Clone 1, Gen 2)
[00:57:23] - Read packet limit of 540015616... Set to 524286976.
[00:57:23] - Error: Could not get length of results file work/wuresults_07.dat
[00:57:23] - Error: Could not read unit 07 file. Removing from queue.
[00:57:23] Trying to send all finished work units
[00:57:23] + No unsent completed units remaining.
[00:57:23] - Preparing to get new work unit...
[00:57:23] Cleaning up work directory
[00:57:23] + Attempting to get work packet
[00:57:23] Passkey found
[00:57:23] - Will indicate memory of 4093 MB
[00:57:23] Gpu type=3 species=30.
[00:57:23] - Connecting to assignment server
[00:57:23] Connecting to http://assign-GPU.stanford.edu:8080/
[00:57:24] Posted data.
[00:57:24] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[00:57:24] + News From Folding@Home: Welcome to Folding@Home
[00:57:24] Loaded queue successfully.
[00:57:24] Gpu type=3 species=30.
[00:57:24] Sent data
[00:57:24] Connecting to http://171.64.65.64:8080/
[00:57:24] Initial: 0000; - Receiving payload (expected size: 39634)
[00:57:25] - Downloaded at ~38 kB/s
[00:57:25] - Averaged speed for that direction ~40 kB/s
[00:57:25] + Received work.
[00:57:25] Trying to send all finished work units
[00:57:25] + No unsent completed units remaining.
[00:57:25] + Closed connections
[00:57:30]
[00:57:30] + Processing work unit
[00:57:30] Core required: FahCore_15.exe
[00:57:30] Core found.
[00:57:30] Working on queue slot 08 [March 19 00:57:30 UTC]
[00:57:30] + Working ...
[00:57:30] - Calling '.\FahCore_15.exe -dir work/ -suffix 08 -nice 19 -priority 96 -nocpulock -checkpoint 3 -verbose -lifeline 5692 -version 630'
[00:57:30]
[00:57:30] *------------------------------*
[00:57:30] Folding@Home GPU Core
[00:57:30] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[00:57:30]
[00:57:30] Build host: SimbiosNvdWin7
[00:57:30] Board Type: NVIDIA/CUDA
[00:57:30] Core      : x=15
[00:57:30]  Window's signal control handler registered.
[00:57:30] Preparing to commence simulation
[00:57:30] - Looking at optimizations...
[00:57:30] DeleteFrameFiles: successfully deleted file=work/wudata_08.ckp
[00:57:30] - Created dyn
[00:57:30] - Files status OK
[00:57:30] sizeof(CORE_PACKET_HDR) = 512 file=<>
[00:57:30] - Expanded 39122 -> 171827 (decompressed 439.2 percent)
[00:57:30] Called DecompressByteArray: compressed_data_size=39122 data_size=171827, decompressed_data_size=171827 diff=0
[00:57:30] - Digital signature verified
[00:57:30]
[00:57:30] Project: 6801 (Run 4394, Clone 1, Gen 2)
[00:57:30]
[00:57:30] Assembly optimizations on if available.
[00:57:30] Entering M.D.
[00:57:32] Tpr hash work/wudata_08.tpr:  3072867433 4181462573 2689415243 1031181546 1959007100
[00:57:32] Working on ALZHEIMER'S DISEASE AMYLOID
[00:57:32] Client config found, loading data.
[00:57:32] Starting GUI Server
[00:57:32] Setting checkpoint frequency: 500000
[00:58:51] Completed    500000 out of 50000000 steps (1%).
[00:58:51] mdrun_gpu returned 52
[00:58:51] NANs detected on GPU
[00:58:51]
[00:58:51] Folding@home Core Shutdown: UNSTABLE_MACHINE
[00:58:54] CoreStatus = 7A (122)
[00:58:54] Sending work to server
[00:58:54] Project: 6801 (Run 4394, Clone 1, Gen 2)
[00:58:54] - Read packet limit of 540015616... Set to 524286976.
[00:58:54] - Error: Could not get length of results file work/wuresults_08.dat
[00:58:54] - Error: Could not read unit 08 file. Removing from queue.
[00:58:54] Trying to send all finished work units
[00:58:54] + No unsent completed units remaining.
[00:58:54] - Preparing to get new work unit...
[00:58:54] Cleaning up work directory
[00:58:54] + Attempting to get work packet
[00:58:54] Passkey found
[00:58:54] - Will indicate memory of 4093 MB
[00:58:54] Gpu type=3 species=30.
[00:58:54] - Connecting to assignment server
[00:58:54] Connecting to http://assign-GPU.stanford.edu:8080/
[00:58:54] Posted data.
[00:58:54] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[00:58:54] + News From Folding@Home: Welcome to Folding@Home
[00:58:55] Loaded queue successfully.
[00:58:55] Gpu type=3 species=30.
[00:58:55] Sent data
[00:58:55] Connecting to http://171.64.65.64:8080/
[00:58:55] Posted data.
[00:58:55] Initial: 0000; - Receiving payload (expected size: 39634)
[00:58:56] - Downloaded at ~38 kB/s
[00:58:56] - Averaged speed for that direction ~40 kB/s
[00:58:56] + Received work.
[00:58:56] Trying to send all finished work units
[00:58:56] + No unsent completed units remaining.
[00:58:56] + Closed connections
[00:59:01]
[00:59:01] + Processing work unit
[00:59:01] Core required: FahCore_15.exe
[00:59:01] Core found.
[00:59:01] Working on queue slot 09 [March 19 00:59:01 UTC]
[00:59:01] + Working ...
[00:59:01] - Calling '.\FahCore_15.exe -dir work/ -suffix 09 -nice 19 -priority 96 -nocpulock -checkpoint 3 -verbose -lifeline 5692 -version 630'
[00:59:01]
[00:59:01] *------------------------------*
[00:59:01] Folding@Home GPU Core
[00:59:01] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[00:59:01]
[00:59:01] Build host: SimbiosNvdWin7
[00:59:01] Board Type: NVIDIA/CUDA
[00:59:01] Core      : x=15
[00:59:01]  Window's signal control handler registered.
[00:59:01] Preparing to commence simulation
[00:59:01] - Looking at optimizations...
[00:59:01] DeleteFrameFiles: successfully deleted file=work/wudata_09.ckp
[00:59:01] - Created dyn
[00:59:01] - Files status OK
[00:59:01] sizeof(CORE_PACKET_HDR) = 512 file=<>
[00:59:01] - Expanded 39122 -> 171827 (decompressed 439.2 percent)
[00:59:01] Called DecompressByteArray: compressed_data_size=39122 data_size=171827, decompressed_data_size=171827 diff=0
[00:59:01] - Digital signature verified
[00:59:01]
[00:59:01] Project: 6801 (Run 4394, Clone 1, Gen 2)
[00:59:01]
[00:59:01] Assembly optimizations on if available.
[00:59:01] Entering M.D.
[00:59:03] Tpr hash work/wudata_09.tpr:  3072867433 4181462573 2689415243 1031181546 1959007100
[00:59:03] Working on ALZHEIMER'S DISEASE AMYLOID
[00:59:03] Client config found, loading data.
[00:59:03] Starting GUI Server
[00:59:03] Setting checkpoint frequency: 500000
[01:00:21] Completed    500000 out of 50000000 steps (1%).
[01:00:21] mdrun_gpu returned 52
[01:00:21] NANs detected on GPU
[01:00:21]
[01:00:21] Folding@home Core Shutdown: UNSTABLE_MACHINE
[01:00:25] CoreStatus = 7A (122)
[01:00:25] Sending work to server
[01:00:25] Project: 6801 (Run 4394, Clone 1, Gen 2)
[01:00:25] - Read packet limit of 540015616... Set to 524286976.
[01:00:25] - Error: Could not get length of results file work/wuresults_09.dat
[01:00:25] - Error: Could not read unit 09 file. Removing from queue.
[01:00:25] Trying to send all finished work units
[01:00:25] + No unsent completed units remaining.
[01:00:25] - Preparing to get new work unit...
[01:00:25] Cleaning up work directory
[01:00:25] + Attempting to get work packet
[01:00:25] Passkey found
[01:00:25] - Will indicate memory of 4093 MB
[01:00:25] Gpu type=3 species=30.
[01:00:25] - Connecting to assignment server
[01:00:25] Connecting to http://assign-GPU.stanford.edu:8080/
[01:00:25] Posted data.
[01:00:25] Initial: 40AB; - Successful: assigned to (171.64.65.64).
[01:00:25] + News From Folding@Home: Welcome to Folding@Home
[01:00:26] Loaded queue successfully.
[01:00:26] Gpu type=3 species=30.
[01:00:26] Sent data
[01:00:26] Connecting to http://171.64.65.64:8080/
[01:00:26] Posted data.
[01:00:26] Initial: 0000; - Receiving payload (expected size: 39634)
[01:00:26] Conversation time very short, giving reduced weight in bandwidth avg
[01:00:26] - Downloaded at ~77 kB/s
[01:00:26] - Averaged speed for that direction ~44 kB/s
[01:00:26] + Received work.
[01:00:26] Trying to send all finished work units
[01:00:26] + No unsent completed units remaining.
[01:00:26] + Closed connections
[01:00:31]
[01:00:31] + Processing work unit
[01:00:31] Core required: FahCore_15.exe
[01:00:31] Core found.
[01:00:31] Working on queue slot 00 [March 19 01:00:31 UTC]
[01:00:31] + Working ...
[01:00:31] - Calling '.\FahCore_15.exe -dir work/ -suffix 00 -nice 19 -priority 96 -nocpulock -checkpoint 3 -verbose -lifeline 5692 -version 630'
[01:00:32]
[01:00:32] *------------------------------*
[01:00:32] Folding@Home GPU Core
[01:00:32] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[01:00:32]
[01:00:32] Build host: SimbiosNvdWin7
[01:00:32] Board Type: NVIDIA/CUDA
[01:00:32] Core      : x=15
[01:00:32]  Window's signal control handler registered.
[01:00:32] Preparing to commence simulation
[01:00:32] - Looking at optimizations...
[01:00:32] DeleteFrameFiles: successfully deleted file=work/wudata_00.ckp
[01:00:32] - Created dyn
[01:00:32] - Files status OK
[01:00:32] sizeof(CORE_PACKET_HDR) = 512 file=<>
[01:00:32] - Expanded 39122 -> 171827 (decompressed 439.2 percent)
[01:00:32] Called DecompressByteArray: compressed_data_size=39122 data_size=171827, decompressed_data_size=171827 diff=0
[01:00:32] - Digital signature verified
[01:00:32]
[01:00:32] Project: 6801 (Run 4394, Clone 1, Gen 2)
[01:00:32]
[01:00:32] Assembly optimizations on if available.
[01:00:32] Entering M.D.
[01:00:34] Tpr hash work/wudata_00.tpr:  3072867433 4181462573 2689415243 1031181546 1959007100
[01:00:34] Working on ALZHEIMER'S DISEASE AMYLOID
[01:00:34] Client config found, loading data.
[01:00:34] Starting GUI Server
[01:00:34] Setting checkpoint frequency: 500000
[01:01:53] Completed    500000 out of 50000000 steps (1%).
[01:01:53] mdrun_gpu returned 52
[01:01:53] NANs detected on GPU
[01:01:53]
[01:01:53] Folding@home Core Shutdown: UNSTABLE_MACHINE
[01:01:56] CoreStatus = 7A (122)
[01:01:56] Sending work to server
[01:01:56] Project: 6801 (Run 4394, Clone 1, Gen 2)
[01:01:56] - Read packet limit of 540015616... Set to 524286976.
[01:01:56] - Error: Could not get length of results file work/wuresults_00.dat
[01:01:56] - Error: Could not read unit 00 file. Removing from queue.
[01:01:56] EUE limit exceeded. Pausing 24 hours.
[01:03:10] ***** Got a SIGTERM signal (2)
[01:03:10] Killing all core threads
Folding@Home Client Shutdown.
A report of error is now in the WU Database:
Your WU (P6801 R4394 C1 G2) was added to the stats database on 2011-03-23 13:05:19 for 0 points of credit.
(Not sure who since I can't see the username in the FAHlogs and it doesn't match the Forum Names. You can either post it here or PM me if you want)
BigJohnFAH
Post by BigJohnFAH »
Add one more with the issue.
--- Opening Log file [March 9 15:25:18 UTC]
Launch directory: C:\FAH\gpu0
Executable: C:\FAH\gpu0\gpu0.exe
Arguments: -local -verbosity 7 -gpu 0
[15:25:18] - Ask before connecting: No
[15:25:18] - User name: BigJohnFAH (Team 111065)
[15:25:18] - User ID: -----------
[15:25:18] - Machine ID: 1
. removed
[11:12:32] + Results successfully sent
[11:12:32] Thank you for your contribution to Folding@Home.
[11:12:32] + Number of Units Completed: 1442
[11:12:36] Trying to send all finished work units
[11:12:36] + No unsent completed units remaining.
[11:12:36] - Preparing to get new work unit...
[11:12:36] Cleaning up work directory
[11:12:36] + Attempting to get work packet
[11:12:36] Passkey found
[11:12:36] - Will indicate memory of 2814 MB
[11:12:36] Gpu type=3 species=30.
[11:12:36] - Connecting to assignment server
[11:12:36] Connecting to http://assign-GPU.stanford.edu:8080/
[11:12:37] - Successful: assigned to (171.64.65.64).
[11:12:37] + News From Folding@Home: Welcome to Folding@Home
[11:12:37] Loaded queue successfully.
[11:12:37] Gpu type=3 species=30.
[11:12:37] Sent data
[11:12:37] Connecting to http://171.64.65.64:8080/
[11:12:38] - Downloaded at ~38 kB/s
[11:12:38] - Averaged speed for that direction ~54 kB/s
[11:12:38] + Received work.
[11:12:38] Trying to send all finished work units
[11:12:38] + No unsent completed units remaining.
[11:12:38] + Closed connections
[11:12:38]
[11:12:38] + Processing work unit
[11:12:38] Core required: FahCore_15.exe
[11:12:38] Core found.
[11:12:38] Working on queue slot 06 [March 28 11:12:38 UTC]
[11:12:38] + Working ...
[11:12:38]
[11:12:38] *------------------------------*
[11:12:38] Folding@Home GPU Core
[11:12:38] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[11:12:38]
[11:12:38] Build host: SimbiosNvdWin7
[11:12:38] Board Type: NVIDIA/CUDA
[11:12:38] Core      : x=15
[11:12:38]  Window's signal control handler registered.
[11:12:38] Preparing to commence simulation
[11:12:38] - Looking at optimizations...
[11:12:38] DeleteFrameFiles: successfully deleted file=work/wudata_06.ckp
[11:12:38] - Created dyn
[11:12:38] - Files status OK
[11:12:38] sizeof(CORE_PACKET_HDR) = 512 file=<>
[11:12:38] - Expanded 39122 -> 171827 (decompressed 439.2 percent)
[11:12:38] Called DecompressByteArray: compressed_data_size=39122 data_size=171827, decompressed_data_size=171827 diff=0
[11:12:38] - Digital signature verified
[11:12:38]
[11:12:38] Project: 6801 (Run 4394, Clone 1, Gen 2)
[11:12:38]
[11:12:38] Assembly optimizations on if available.
[11:12:38] Entering M.D.
[11:12:40] Tpr hash work/wudata_06.tpr:  3072867433 4181462573 2689415243 1031181546 1959007100
[11:12:40] Working on ALZHEIMER'S DISEASE AMYLOID
[11:12:40] Client config found, loading data.
[11:12:40] Starting GUI Server
[11:12:40] Setting checkpoint frequency: 500000
[11:14:19] Completed    500000 out of 50000000 steps (1%).
[11:14:19] mdrun_gpu returned 52
[11:14:19] NANs detected on GPU
[11:14:19]
[11:14:19] Folding@home Core Shutdown: UNSTABLE_MACHINE
[11:14:22] CoreStatus = 7A (122)
[11:14:22] Sending work to server
[11:14:22] Project: 6801 (Run 4394, Clone 1, Gen 2)
[11:14:22] - Read packet limit of 540015616... Set to 524286976.
[11:14:22] - Error: Could not get length of results file work/wuresults_06.dat
[11:14:22] - Error: Could not read unit 06 file. Removing from queue.
[11:14:22] Trying to send all finished work units
[11:14:22] + No unsent completed units remaining.
[11:14:22] - Preparing to get new work unit...
[11:14:22] Cleaning up work directory
[11:14:22] + Attempting to get work packet
[11:14:22] Passkey found
[11:14:22] - Will indicate memory of 2814 MB
[11:14:22] Gpu type=3 species=30.
[11:14:22] - Connecting to assignment server
[11:14:22] Connecting to http://assign-GPU.stanford.edu:8080/
[11:14:23] - Successful: assigned to (171.64.65.64).
[11:14:23] + News From Folding@Home: Welcome to Folding@Home
[11:14:23] Loaded queue successfully.
[11:14:23] Gpu type=3 species=30.
[11:14:23] Sent data
[11:14:23] Connecting to http://171.64.65.64:8080/
[11:14:24] - Downloaded at ~38 kB/s
[11:14:24] - Averaged speed for that direction ~51 kB/s
[11:14:24] + Received work.
[11:14:24] Trying to send all finished work units
[11:14:24] + No unsent completed units remaining.
[11:14:24] + Closed connections
[11:14:29]
[11:14:29] + Processing work unit
[11:14:29] Core required: FahCore_15.exe
[11:14:29] Core found.
[11:14:29] Working on queue slot 07 [March 28 11:14:29 UTC]
[11:14:29] + Working ...
[11:14:29]
[11:14:29] *------------------------------*
[11:14:29] Folding@Home GPU Core
[11:14:29] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[11:14:29]
[11:14:29] Build host: SimbiosNvdWin7
[11:14:29] Board Type: NVIDIA/CUDA
[11:14:29] Core      : x=15
[11:14:29]  Window's signal control handler registered.
[11:14:29] Preparing to commence simulation
[11:14:29] - Looking at optimizations...
[11:14:29] DeleteFrameFiles: successfully deleted file=work/wudata_07.ckp
[11:14:29] - Created dyn
[11:14:29] - Files status OK
[11:14:29] sizeof(CORE_PACKET_HDR) = 512 file=<>
[11:14:29] - Expanded 39122 -> 171827 (decompressed 439.2 percent)
[11:14:29] Called DecompressByteArray: compressed_data_size=39122 data_size=171827, decompressed_data_size=171827 diff=0
[11:14:29] - Digital signature verified
[11:14:29]
[11:14:29] Project: 6801 (Run 4394, Clone 1, Gen 2)
[11:14:29]
[11:14:29] Assembly optimizations on if available.
[11:14:29] Entering M.D.
[11:14:31] Tpr hash work/wudata_07.tpr:  3072867433 4181462573 2689415243 1031181546 1959007100
[11:14:31] Working on ALZHEIMER'S DISEASE AMYLOID
[11:14:31] Client config found, loading data.
[11:14:31] Starting GUI Server
[11:14:31] Setting checkpoint frequency: 500000
[11:16:10] Completed    500000 out of 50000000 steps (1%).
[11:16:10] mdrun_gpu returned 52
[11:16:10] NANs detected on GPU
[11:16:10]
[11:16:10] Folding@home Core Shutdown: UNSTABLE_MACHINE
[11:16:13] CoreStatus = 7A (122)
[11:16:13] Sending work to server
[11:16:13] Project: 6801 (Run 4394, Clone 1, Gen 2)
[11:16:13] - Read packet limit of 540015616... Set to 524286976.
[11:16:13] - Error: Could not get length of results file work/wuresults_07.dat
[11:16:13] - Error: Could not read unit 07 file. Removing from queue.
[11:16:13] Trying to send all finished work units
[11:16:13] + No unsent completed units remaining.
[11:16:13] - Preparing to get new work unit...
[11:16:13] Cleaning up work directory
[11:16:13] + Attempting to get work packet
[11:16:13] Passkey found
[11:16:13] - Will indicate memory of 2814 MB
[11:16:13] Gpu type=3 species=30.
[11:16:13] - Connecting to assignment server
[11:16:13] Connecting to http://assign-GPU.stanford.edu:8080/
[11:16:13] - Successful: assigned to (171.64.65.64).
[11:16:13] + News From Folding@Home: Welcome to Folding@Home
[11:16:14] Loaded queue successfully.
[11:16:14] Gpu type=3 species=30.
[11:16:14] Sent data
[11:16:14] Connecting to http://171.64.65.64:8080/
[11:16:14] Conversation time very short, giving reduced weight in bandwidth avg
[11:16:14] - Downloaded at ~77 kB/s
[11:16:14] - Averaged speed for that direction ~54 kB/s
[11:16:14] + Received work.
[11:16:14] Trying to send all finished work units
[11:16:14] + No unsent completed units remaining.
[11:16:14] + Closed connections
[11:16:19]
[11:16:19] + Processing work unit
[11:16:19] Core required: FahCore_15.exe
[11:16:19] Core found.
[11:16:19] Working on queue slot 08 [March 28 11:16:19 UTC]
[11:16:19] + Working ...
[11:16:19]
[11:16:19] *------------------------------*
[11:16:19] Folding@Home GPU Core
[11:16:19] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[11:16:19]
[11:16:19] Build host: SimbiosNvdWin7
[11:16:19] Board Type: NVIDIA/CUDA
[11:16:19] Core      : x=15
[11:16:19]  Window's signal control handler registered.
[11:16:19] Preparing to commence simulation
[11:16:19] - Looking at optimizations...
[11:16:19] DeleteFrameFiles: successfully deleted file=work/wudata_08.ckp
[11:16:19] - Created dyn
[11:16:19] - Files status OK
[11:16:19] sizeof(CORE_PACKET_HDR) = 512 file=<>
[11:16:19] - Expanded 39122 -> 171827 (decompressed 439.2 percent)
[11:16:19] Called DecompressByteArray: compressed_data_size=39122 data_size=171827, decompressed_data_size=171827 diff=0
[11:16:19] - Digital signature verified
[11:16:19]
[11:16:19] Project: 6801 (Run 4394, Clone 1, Gen 2)
[11:16:19]
[11:16:19] Assembly optimizations on if available.
[11:16:19] Entering M.D.
[11:16:21] Tpr hash work/wudata_08.tpr:  3072867433 4181462573 2689415243 1031181546 1959007100
[11:16:21] Working on ALZHEIMER'S DISEASE AMYLOID
[11:16:21] Client config found, loading data.
[11:16:22] Starting GUI Server
[11:16:22] Setting checkpoint frequency: 500000
[11:18:00] Completed    500000 out of 50000000 steps (1%).
[11:18:00] mdrun_gpu returned 52
[11:18:00] NANs detected on GPU
[11:18:00]
[11:18:00] Folding@home Core Shutdown: UNSTABLE_MACHINE
[11:18:04] CoreStatus = 7A (122)
[11:18:04] Sending work to server
[11:18:04] Project: 6801 (Run 4394, Clone 1, Gen 2)
[11:18:04] - Read packet limit of 540015616... Set to 524286976.
[11:18:04] - Error: Could not get length of results file work/wuresults_08.dat
[11:18:04] - Error: Could not read unit 08 file. Removing from queue.
[11:18:04] Trying to send all finished work units
[11:18:04] + No unsent completed units remaining.
[11:18:04] - Preparing to get new work unit...
[11:18:04] Cleaning up work directory
[11:18:04] + Attempting to get work packet
[11:18:04] Passkey found
[11:18:04] - Will indicate memory of 2814 MB
[11:18:04] Gpu type=3 species=30.
[11:18:04] - Connecting to assignment server
[11:18:04] Connecting to http://assign-GPU.stanford.edu:8080/
[11:18:04] - Successful: assigned to (171.64.65.64).
[11:18:04] + News From Folding@Home: Welcome to Folding@Home
[11:18:05] Loaded queue successfully.
[11:18:05] Gpu type=3 species=30.
[11:18:05] Sent data
[11:18:05] Connecting to http://171.64.65.64:8080/
[11:18:05] Conversation time very short, giving reduced weight in bandwidth avg
[11:18:05] - Downloaded at ~77 kB/s
[11:18:05] - Averaged speed for that direction ~56 kB/s
[11:18:05] + Received work.
[11:18:05] Trying to send all finished work units
[11:18:05] + No unsent completed units remaining.
[11:18:05] + Closed connections
[11:18:10]
[11:18:10] + Processing work unit
[11:18:10] Core required: FahCore_15.exe
[11:18:10] Core found.
[11:18:10] Working on queue slot 09 [March 28 11:18:10 UTC]
[11:18:10] + Working ...
[11:18:11]
[11:18:11] *------------------------------*
[11:18:11] Folding@Home GPU Core
[11:18:11] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[11:18:11]
[11:18:11] Build host: SimbiosNvdWin7
[11:18:11] Board Type: NVIDIA/CUDA
[11:18:11] Core      : x=15
[11:18:11]  Window's signal control handler registered.
[11:18:11] Preparing to commence simulation
[11:18:11] - Looking at optimizations...
[11:18:11] DeleteFrameFiles: successfully deleted file=work/wudata_09.ckp
[11:18:11] - Created dyn
[11:18:11] - Files status OK
[11:18:11] sizeof(CORE_PACKET_HDR) = 512 file=<>
[11:18:11] - Expanded 39122 -> 171827 (decompressed 439.2 percent)
[11:18:11] Called DecompressByteArray: compressed_data_size=39122 data_size=171827, decompressed_data_size=171827 diff=0
[11:18:11] - Digital signature verified
[11:18:11]
[11:18:11] Project: 6801 (Run 4394, Clone 1, Gen 2)
[11:18:11]
[11:18:11] Assembly optimizations on if available.
[11:18:11] Entering M.D.
[11:18:13] Tpr hash work/wudata_09.tpr:  3072867433 4181462573 2689415243 1031181546 1959007100
[11:18:13] Working on ALZHEIMER'S DISEASE AMYLOID
[11:18:13] Client config found, loading data.
[11:18:13] Starting GUI Server
[11:18:13] Setting checkpoint frequency: 500000
[11:19:52] Completed    500000 out of 50000000 steps (1%).
[11:19:52] mdrun_gpu returned 52
[11:19:52] NANs detected on GPU
[11:19:52]
[11:19:52] Folding@home Core Shutdown: UNSTABLE_MACHINE
[11:19:55] CoreStatus = 7A (122)
[11:19:55] Sending work to server
[11:19:55] Project: 6801 (Run 4394, Clone 1, Gen 2)
[11:19:55] - Read packet limit of 540015616... Set to 524286976.
[11:19:55] - Error: Could not get length of results file work/wuresults_09.dat
[11:19:55] - Error: Could not read unit 09 file. Removing from queue.
[11:19:55] Trying to send all finished work units
[11:19:55] + No unsent completed units remaining.
[11:19:55] - Preparing to get new work unit...
[11:19:55] Cleaning up work directory
[11:19:55] + Attempting to get work packet
[11:19:55] Passkey found
[11:19:55] - Will indicate memory of 2814 MB
[11:19:55] Gpu type=3 species=30.
[11:19:55] - Connecting to assignment server
[11:19:55] Connecting to http://assign-GPU.stanford.edu:8080/
[11:19:55] - Successful: assigned to (171.64.65.64).
[11:19:55] + News From Folding@Home: Welcome to Folding@Home
[11:19:56] Loaded queue successfully.
[11:19:56] Gpu type=3 species=30.
[11:19:56] Sent data
[11:19:56] Connecting to http://171.64.65.64:8080/
[11:19:56] Conversation time very short, giving reduced weight in bandwidth avg
[11:19:56] - Downloaded at ~77 kB/s
[11:19:56] - Averaged speed for that direction ~59 kB/s
[11:19:56] + Received work.
[11:19:56] Trying to send all finished work units
[11:19:56] + No unsent completed units remaining.
[11:19:56] + Closed connections
[11:20:01]
[11:20:01] + Processing work unit
[11:20:01] Core required: FahCore_15.exe
[11:20:01] Core found.
[11:20:01] Working on queue slot 00 [March 28 11:20:01 UTC]
[11:20:01] + Working ...
[11:20:02]
[11:20:02] *------------------------------*
[11:20:02] Folding@Home GPU Core
[11:20:02] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[11:20:02]
[11:20:02] Build host: SimbiosNvdWin7
[11:20:02] Board Type: NVIDIA/CUDA
[11:20:02] Core      : x=15
[11:20:02]  Window's signal control handler registered.
[11:20:02] Preparing to commence simulation
[11:20:02] - Looking at optimizations...
[11:20:02] DeleteFrameFiles: successfully deleted file=work/wudata_00.ckp
[11:20:02] - Created dyn
[11:20:02] - Files status OK
[11:20:02] sizeof(CORE_PACKET_HDR) = 512 file=<>
[11:20:02] - Expanded 39122 -> 171827 (decompressed 439.2 percent)
[11:20:02] Called DecompressByteArray: compressed_data_size=39122 data_size=171827, decompressed_data_size=171827 diff=0
[11:20:02] - Digital signature verified
[11:20:02]
[11:20:02] Project: 6801 (Run 4394, Clone 1, Gen 2)
[11:20:02]
[11:20:02] Assembly optimizations on if available.
[11:20:02] Entering M.D.
[11:20:04] Tpr hash work/wudata_00.tpr:  3072867433 4181462573 2689415243 1031181546 1959007100
[11:20:04] Working on ALZHEIMER'S DISEASE AMYLOID
[11:20:04] Client config found, loading data.
[11:20:04] Starting GUI Server
[11:20:04] Setting checkpoint frequency: 500000
[11:21:43] Completed    500000 out of 50000000 steps (1%).
[11:21:43] mdrun_gpu returned 52
[11:21:43] NANs detected on GPU
[11:21:43]
[11:21:43] Folding@home Core Shutdown: UNSTABLE_MACHINE
[11:21:46] CoreStatus = 7A (122)
[11:21:46] Sending work to server
[11:21:46] Project: 6801 (Run 4394, Clone 1, Gen 2)
[11:21:46] - Read packet limit of 540015616... Set to 524286976.
[11:21:46] - Error: Could not get length of results file work/wuresults_00.dat
[11:21:46] - Error: Could not read unit 00 file. Removing from queue.
[11:21:46] EUE limit exceeded. Pausing 24 hours.
Thank you for the reports.
The WU (P6801,R4394,C1,G2) has been reported as a bad WU.
tjmagneto
Hardware configuration: used to be: i7-920 @ 3.2 ghz, ASUS P6T dlx mobo, BFG 275 OC (2 of 'em) 6 Gb OCZ 1333, Velociraptor 300 Gb, WD black 1 TB
Post by tjmagneto »
Thanks for reporting that WU as being bad. I've been having similar problems to what has already posted above.
