Project: 6806 (Run 3987, Clone 2, Gen 10)
Rich_D
Post by Rich_D »
As brought up in another thread.
[03:35:43] + Processing work unit
[03:35:43] Core required: FahCore_15.exe
[03:35:43] Core found.
[03:35:43] Working on queue slot 03 [February 26 03:35:43 UTC]
[03:35:43] + Working ...
[03:35:43]
[03:35:43] *------------------------------*
[03:35:43] Folding@Home GPU Core
[03:35:43] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[03:35:43]
[03:35:43] Build host: SimbiosNvdWin7
[03:35:43] Board Type: NVIDIA/CUDA
[03:35:43] Core      : x=15
[03:35:43]  Window's signal control handler registered.
[03:35:43] Preparing to commence simulation
[03:35:43] - Looking at optimizations...
[03:35:43] DeleteFrameFiles: successfully deleted file=work/wudata_03.ckp
[03:35:43] - Created dyn
[03:35:43] - Files status OK
[03:35:43] sizeof(CORE_PACKET_HDR) = 512 file=<>
[03:35:43] - Expanded 43699 -> 172159 (decompressed 393.9 percent)
[03:35:43] Called DecompressByteArray: compressed_data_size=43699 data_size=172159, decompressed_data_size=172159 diff=0
[03:35:43] - Digital signature verified
[03:35:43]
[03:35:43] Project: 6806 (Run 3987, Clone 2, Gen 10)
[03:35:43]
[03:35:43] Assembly optimizations on if available.
[03:35:43] Entering M.D.
[03:35:45] Tpr hash work/wudata_03.tpr:  1399213409 2679800626 620498429 1228651168 3715002604
[03:35:45] Working on 2 PEPTIDE (1-42)
[03:35:45] Client config found, loading data.
[03:35:45] Starting GUI Server
[03:35:47] Setting checkpoint frequency: 500000
[03:37:17] Completed    500000 out of 50000000 steps (1%).
[03:37:18] mdrun_gpu returned 52
[03:37:18] NANs detected on GPU
[03:37:18]
[03:37:18] Folding@home Core Shutdown: UNSTABLE_MACHINE
[03:37:21] CoreStatus = 7A (122)
[03:37:21] Sending work to server
[03:37:21] Project: 6806 (Run 3987, Clone 2, Gen 10)
[03:37:21] - Read packet limit of 540015616... Set to 524286976.
[03:37:21] - Error: Could not get length of results file work/wuresults_03.dat
[03:37:21] - Error: Could not read unit 03 file. Removing from queue.
[03:37:21] EUE limit exceeded. Pausing 24 hours.
Re: Project: 6806 (Run 3987, Clone 2, Gen 10)
Unfortunately, no one has been able to return results for this WU yet ...
Still no data in the WU Database :(
We have some data:
Your WU (P6806 R3987 C2 G10) was added to the stats database on 2011-03-08 17:08:14 for 0 points of credit.
Looks like a bad WU but we have to wait.
sortofageek
Post by sortofageek »
The WU (P6806,R3987,C2,G10) has been reported as a bad WU. Note that the list of reported WUs are stoped daily at 8am pacific time.
