Bad unit?
Running on a stock GTX570
This is the first unit failure I am aware of on this card. Temps ~60
[15:04:50] Folding@Home GPU Core
[15:04:50] Version 2.15 (Tue Nov 16 09:05:18 PST 2010)
[15:04:50]
[15:04:50] Build host: SimbiosNvdWin7
[15:04:50] Board Type: NVIDIA/CUDA
[15:04:50] Core : x=15
[15:04:50] Window's signal control handler registered.
[15:04:50] Preparing to commence simulation
[15:04:50] - Looking at optimizations...
[15:04:50] DeleteFrameFiles: successfully deleted file=work/wudata_04.ckp
[15:04:50] - Created dyn
[15:04:50] - Files status OK
[15:04:50] sizeof(CORE_PACKET_HDR) = 512 file=<>
[15:04:50] - Expanded 41530 -> 162639 (decompressed 391.6 percent)
[15:04:50] Called DecompressByteArray: compressed_data_size=41530 data_size=162639, decompressed_data_size=162639 diff=0
[15:04:50] - Digital signature verified
[15:04:50]
[15:04:50] Project: 6805 (Run 954, Clone 2, Gen 27)
[15:04:50]
[15:04:50] Assembly optimizations on if available.
[15:04:50] Entering M.D.
[15:04:52] Tpr hash work/wudata_04.tpr: 233505019 3980853943 2077044648 2533523268 888699523
[15:04:52] Working on ALZHEIMER'S DISEASE AMYLOID
[15:04:52] Run: exception thrown in GuardedRun -- cannot continue further.
[15:04:52] Going to send back what have done -- stepsTotalG=0
[15:04:52] Work fraction=0.0000 steps=0.
[15:04:56] logfile size=0 infoLength=0 edr=0 trr=23
[15:04:56] + Opened results file
[15:04:56] - Writing 635 bytes of core data to disk...
[15:04:56] Done: 123 -> 124 (compressed to 100.8 percent)
[15:04:56] ... Done.
[15:04:56] DeleteFrameFiles: successfully deleted file=work/wudata_04.ckp
[15:04:56]
[15:04:56] Folding@home Core Shutdown: UNSTABLE_MACHINE
[15:05:00] CoreStatus = 7A (122)
[15:05:00] Sending work to server
[15:05:00] Project: 6805 (Run 954, Clone 2, Gen 27)
[15:05:00] - Read packet limit of 540015616... Set to 524286976.
[15:05:00] + Attempting to send results [February 19 15:05:00 UTC]
[15:05:00] Gpu type=3 species=20.
[15:05:00] + Results successfully sent
[15:05:00] Thank you for your contribution to Folding@Home.
RoomateoYo
- Hardware configuration: i7-2600k @ 4.4 GHz
GTX780
i7-2630QM
GT555M - Location: Jackson, MI
Re: Project: 6805 (Run 954, Clone 2, Gen 27)
You're the only one to have returned this WU for the time being ...
The WU has been successfully completed by another Donor so it isn't a bad one.
