Project: 6885 (Run 94, Clone 4, Gen 72)
John_Weatherman
Post by John_Weatherman »
This might be my old P4 machine going senile or just a bad WU -
Project: 6885 (Run 94, Clone 4, Gen 72)- Quit 101 - Fatal error: Determinant = 1.#QNAN0
--- Opening Log file [February 10 10:35:40 UTC]
                          http://folding.stanford.edu
Launch directory: C:\FAH6
Service: C:\FAH6\Folding@home-Win32-x86.exe
Arguments: -svcstart -d C:\FAH6 -forceasm -verbosity 9
Launched as a service.
Entered C:\FAH6 to do work.
Warning:
 By using the -forceasm flag, you are overriding
 safeguards in the program. If you did not intend to
 do this, please restart the program without -forceasm.
 If work units are not completing fully (and particularly
 if your machine is overclocked), then please discontinue
 use of the flag.
[10:35:40] - Ask before connecting: No
[10:35:40] - User name: John_Weatherman (Team 48913)
[10:35:40] - User ID: BC627F80FF0BC0A
[10:35:40] - Machine ID: 1
[10:35:40]
[10:35:40] Loaded queue successfully.
[10:35:40]
[10:35:40] + Processing work unit
[10:35:40] Core required: FahCore_78.exe
[10:35:40] Core found.
[10:35:40] - Autosending finished units... [February 10 10:35:40 UTC]
[10:35:40] Trying to send all finished work units
[10:35:40] + No unsent completed units remaining.
[10:35:40] - Autosend completed
[10:35:40] Working on queue slot 03 [February 10 10:35:40 UTC]
[10:35:40] + Working ...
[10:35:40] - Calling '.\FahCore_78.exe -dir work/ -suffix 03 -cpu 98 -checkpoint 10 -service -forceasm -verbose -lifeline 1736 -version 623'
[10:35:41]
[10:35:41] *------------------------------*
[10:35:41] Folding@Home Gromacs Core
[10:35:41] Version 1.90 (March 8, 2006)
[10:35:41]
[10:35:41] Preparing to commence simulation
[10:35:41] - Assembly optimizations manually forced on.
[10:35:41] - Not checking prior termination.
[10:35:42] - Expanded 372449 -> 1798060 (decompressed 482.7 percent)
[10:35:45]
[10:35:45] Project: 6885 (Run 94, Clone 4, Gen 72)
[10:35:45]
[10:35:46] Assembly optimizations on if available.
[10:35:46] Entering M.D.
[10:36:07] (Starting from checkpoint)
[10:36:08] Protein: ALZHEIMERS DISEASE AMYLOID
[10:36:08]
[10:36:08] Writing local files
[10:37:27] Completed 10000 out of 250000 steps  (4%)
[10:37:27] Extra SSE boost OK.
[10:44:38] Writing local files
[10:44:38] Completed 12500 out of 250000 steps  (5%)
[10:45:29] Quit 101 - Fatal error: Determinant = 1.#QNAN0
[10:45:29] Simulation instability has been encountered. The run has entered a
[10:45:29]   state from which no further progress can be made.
[10:45:29] This may be the correct result of the simulation, however if you
[10:45:29]   often see other project units terminating early like this
[10:45:29]   too, you may wish to check the stability of your computer (issues
[10:45:29]   such as high temperature, overclocking, etc.).
[10:45:29] Going to send back what have done.
[10:45:29] logfile size: 32759
[10:45:29] - Writing 33319 bytes of core data to disk...
[10:45:29] Done: 32807 -> 4595 (compressed to 14.0 percent)
[10:45:29]   ... Done.
[10:45:29]
[10:45:29] Folding@home Core Shutdown: EARLY_UNIT_END
[10:45:32] CoreStatus = 72 (114)
[10:45:32] Sending work to server
[10:45:32] Project: 6885 (Run 94, Clone 4, Gen 72)
[10:45:32] - Read packet limit of 540015616... Set to 524286976.
[10:45:32] + Attempting to send results [February 10 10:45:32 UTC]
[10:45:32] - Reading file work/wuresults_03.dat from core
[10:45:32]   (Read 5107 bytes from disk)
Re: Project: 6885 (Run 94, Clone 4, Gen 72)
So far, you're the only one:
Hi John_Weatherman (team 48913),
Your WU (P6885 R94 C4 G72) was added to the stats database on 2011-02-10 03:08:01 for 0 points of credit.
I have marked it for a follow up.
In the meantime, someone else completed it for full credit, so that's definitely not a bad WU.
John_Weatherman
Thanks for the update. I'll keep an eye on the poor ol' thing.
