Project: 2494 (Run 174, Clone 27, Gen 6) Missing Points
martiou
Post by martiou »
This WU finished on 31/01/2011 08:06:33 and I don't see the 905 points for it.
[23:21:03] Connecting to http://assign2.stanford.edu:80/
[23:21:04] Posted data.
[23:21:04] Initial: 41AB; - Successful: assigned to (171.65.103.160).
[23:21:04] + News From Folding@Home: Welcome to Folding@Home
[23:21:04] Loaded queue successfully.
[23:21:04] Connecting to http://171.65.103.160:80/
[23:21:10] Posted data.
[23:21:10] Initial: 0000; - Receiving payload (expected size: 2949083)
[23:21:18] - Downloaded at ~359 kB/s
[23:21:18] - Averaged speed for that direction ~238 kB/s
[23:21:18] + Received work.
[23:21:18] Trying to send all finished work units
[23:21:18] + No unsent completed units remaining.
[23:21:18] + Closed connections
[23:21:18]
[23:21:18] + Processing work unit
[23:21:18] Core required: FahCore_78.exe
[23:21:18] Core found.
[23:21:18] Working on Unit 09 [January 26 23:21:18]
[23:21:18] + Working ...
[23:21:18] - Calling './FahCore_78.exe -dir work/ -suffix 09 -checkpoint 3 -verbose -lifeline 2478 -version 602'
[23:21:18]
[23:21:18] *------------------------------*
[23:21:18] Folding@Home Gromacs Core
[23:21:18] Version 1.90 (March 8, 2006)
[23:21:18]
[23:21:18] Preparing to commence simulation
[23:21:18] - Looking at optimizations...
[23:21:18] - Created dyn
[23:21:18] - Files status OK
[23:21:19] - Expanded 2948571 -> 15080525 (decompressed 511.4 percent)
[23:21:20] - Starting from initial work packet
[23:21:20]
[23:21:20] Project: 2494 (Run 174, Clone 27, Gen 6)
[23:21:20]
[23:21:20] Assembly optimizations on if available.
[23:21:20] Entering M.D.
[23:21:28] Protein: system
[23:21:28]
[23:21:28] Writing local files
[23:21:29] Extra SSE boost OK.
[23:21:30] Writing local files
[23:21:31] Completed 0 out of 250000 steps  (0%)
[23:24:32] Timered checkpoint triggered.
[23:27:34] Timered checkpoint triggered.
[23:30:35] Timered checkpoint triggered.
[08:01:53] Timered checkpoint triggered.
[08:04:54] Timered checkpoint triggered.
[08:05:27] Writing local files
[08:05:27] Completed 250000 out of 250000 steps  (100%)
[08:05:27] Writing final coordinates.
[08:05:28] Past main M.D. loop
[08:06:27]
[08:06:27] Finished Work Unit:
[08:06:27] - Reading up to 2296584 from "work/wudata_09.arc": Read 2296584
[08:06:27] - Reading up to 143296 from "work/wudata_09.xtc": Read 143296
[08:06:27] goefile size: 0
[08:06:27] logfile size: 38344
[08:06:27] Leaving Run
[08:06:31] - Writing 2496400 bytes of core data to disk...
[08:06:31]   ... Done.
[08:06:31] - Shutting down core
[08:06:31]
[08:06:31] Folding@home Core Shutdown: FINISHED_UNIT
[08:06:33] CoreStatus = 64 (100)
[08:06:33] Unit 9 finished with 95 percent of time to deadline remaining.
[08:06:33] Updated performance fraction: 0.970258
[08:06:33] Sending work to server
[08:06:33] - Read packet limit of 540015616... Set to 524286976.
[08:06:33] + Attempting to send results
[08:06:33] - Reading file work/wuresults_09.dat from core
[08:06:33]   (Read 2496400 bytes from disk)
[08:06:33] Connecting to http://171.65.103.160:80/
[08:06:41] Posted data.
[08:06:42] Initial: 0000; - Uploaded at ~270 kB/s
[08:06:42] - Averaged speed for that direction ~148 kB/s
[08:06:42] + Results successfully sent
[08:06:42] Thank you for your contribution to Folding@Home.
[08:06:42] + Number of Units Completed: 209
I think there is really an issue with this type of WU or with the server 171.65.103.160.
It's at least the 3rd WU p2494 in 1 month (see this thread and this thread) for 2 clients for which I don't have points.
And I'm not sure that for other clients I always have points for this type of WU.
Re: Project: 2494 (Run 174, Clone 27, Gen 6) Missing Points
There's no sign of this WU in the DB yet :(
