CPU Type Intel Pentium 4 530J, 3000 MHz (15 x 200) (so no overclocking on this one)
Prescott E0 stepping
With Hyperthreading enabled, running one Systray client.
OS: Windows XP Home SP3
if you need any more information just ask
[19:16:33] + Attempting to get work packet
[19:16:33] - Will indicate memory of 511 MB
[19:16:33] - Detect CPU. Vendor: GenuineIntel, Family: 15, Model: 4, Stepping: 1
[19:16:33] - Connecting to assignment server
[19:16:33] Connecting to http://assign.stanford.edu:8080/
[19:16:34] Posted data.
[19:16:34] Initial: 40AB; - Successful: assigned to (171.64.65.62).
[19:16:34] + News From Folding@Home: Welcome to Folding@Home
[19:16:35] Loaded queue successfully.
[19:16:35] Connecting to http://171.64.65.62:8080/
[19:16:36] Posted data.
[19:16:36] Initial: 0000; - Receiving payload (expected size: 504116)
[19:16:44] - Downloaded at ~61 kB/s
[19:16:44] - Averaged speed for that direction ~107 kB/s
[19:16:44] + Received work.
[19:16:44] Trying to send all finished work units
[19:16:44] + No unsent completed units remaining.
[19:16:44] + Closed connections
[19:16:44]
[19:16:44] + Processing work unit
[19:16:44] Core required: FahCore_78.exe
[19:16:44] Core found.
[19:16:44] Working on queue slot 08 [January 2 19:16:44 UTC]
[19:16:44] + Working ...
[19:16:44] - Calling '.\FahCore_78.exe -dir work/ -suffix 08 -priority 96 -checkpoint 15 -verbose -lifeline 2480 -version 623'
[19:16:44]
[19:16:44] *------------------------------*
[19:16:44] Folding@Home Gromacs Core
[19:16:44] Version 1.90 (March 8, 2006)
[19:16:44]
[19:16:44] Preparing to commence simulation
[19:16:44] - Looking at optimizations...
[19:16:44] - Created dyn
[19:16:44] - Files status OK
[19:16:45] - Expanded 503604 -> 2511117 (decompressed 498.6 percent)
[19:16:45] - Starting from initial work packet
[19:16:45]
[19:16:45] Project: 6515 (Run 7, Clone 158, Gen 54)
[19:16:45]
[19:16:45] Assembly optimizations on if available.
[19:16:45] Entering M.D.
[19:16:51] Protein: 1CFC_A_8 in water
[19:16:51]
[19:16:51] Writing local files
[19:16:51] Extra SSE boost OK.
[19:16:52] Writing local files
[19:16:52] Completed 0 out of 250000 steps (0%)
[19:26:09] Writing local files
[19:26:09] Completed 2500 out of 250000 steps (1%)
[19:35:25] Writing local files
*SNIP*
[01:00:19] Completed 92500 out of 250000 steps (37%)
[01:09:40] Writing local files
[01:09:40] Completed 95000 out of 250000 steps (38%)
[01:16:27] Gromacs cannot continue further.
[01:16:27] Going to send back what have done.
[01:16:27] logfile size: 13404
[01:16:27] - Writing 13940 bytes of core data to disk...
[01:16:27] Done: 13428 -> 3904 (compressed to 29.0 percent)
[01:16:27] ... Done.
[01:16:27]
[01:16:27] Folding@home Core Shutdown: EARLY_UNIT_END
[01:16:31] CoreStatus = 72 (114)
[01:16:31] Sending work to server
[01:16:31] Project: 6515 (Run 7, Clone 158, Gen 54)
[01:16:31] - Read packet limit of 540015616... Set to 524286976.
[01:16:31] + Attempting to send results [January 3 01:16:31 UTC]
[01:16:31] - Reading file work/wuresults_08.dat from core
[01:16:31] (Read 4416 bytes from disk)
[01:16:31] Connecting to http://171.64.65.62:8080/
[01:16:33] Posted data.
[01:16:33] Initial: 0000; - Uploaded at ~2 kB/s
[01:16:33] - Averaged speed for that direction ~54 kB/s
[01:16:33] + Results successfully sent
[01:16:33] Thank you for your contribution to Folding@Home.
