Project: 10024 (Run 432, Clone 0, Gen 82)
Tobit
Post by Tobit »
Posting on behalf of a teammate... sounds like it might be a bad WU to me.
Pentium 4 w/HT 3.4ghz
2gigs of Corsair ddr3200 ram - stock timings
Windows Server 2003 Standard - all patches are applied
F@H Client: 6.30
Username: dmolter
[13:55:33] + Processing work unit
[13:55:33] Core required: FahCore_b4.exe
[13:55:33] Core found.
[13:55:33] Working on queue slot 06 [December 22 13:55:33 UTC]
[13:55:33] + Working ...
[13:55:37] *********************** Log Started 22/Dec/2010 13:55:37 ***********************
[13:55:37] ************************** ProtoMol Folding@Home Core **************************
[13:55:37]   Version: 25
[13:55:37]      Type: 180
[13:55:37]      Core: ProtoMol
[13:55:37]   Website: http://folding.stanford.edu/
[13:55:37] Copyright: (c) 2009 Stanford University
[13:55:37]    Author: Joseph Coffland <joseph@cauldrondevelopment.com>
[13:55:37]      Args: -dir work/ -suffix 06 -nice 19 -checkpoint 15 -lifeline 3708 -version
[13:55:37]            630
[13:55:37] ************************************ Build *************************************
[13:55:37]      Date: May 18 2010
[13:55:37]      Time: 23:43:52
[13:55:37]  Revision: 1819
[13:55:37]  Compiler: Intel(R) C++ MSVC 1500 mode 1110
[13:55:37]   Options: /TP /nologo /EHsc /wd4297 /wd4103 /wd1786 /arch:IA32 /Ox
[13:55:37]            /QaxSSE2,SSE3,SSSE3,SSE4.1,SSE4.2 /Qrestrict /MT
[13:55:37]   Defines: _CRT_SECURE_NO_WARNINGS NDEBUG HAVE_GEEKINFO BOOST_ALL_NO_LIB
[13:55:37]            XML_STATIC HAVE_EXPAT HAVE_OPENSSL HAVE_LIBFAH HAVE_SIMTK_LAPACK
[13:55:37]  Platform: Windows XP
[13:55:37]      Bits: 32
[13:55:37]      Mode: Release
[13:55:37] ************************************ System ************************************
[13:55:37]        OS: Microsoft(R) Windows(R) Server 2003, Standard Edition
[13:55:37]       CPU: Intel(R) Pentium(R) 4 CPU 3.40GHz
[13:55:37]    CPU ID: GenuineIntel Family 15 Model 2 Stepping 9
[13:55:37]      CPUs: 2 Logical, 1 Physical
[13:55:37]    Memory: 1.98 GB
[13:55:37]   Threads: Windows
[13:55:37] ********************************************************************************
[13:55:37] Project: 10024 (Run 432, Clone 0, Gen 82)
[13:55:37] Unit: 0x000000750001329c4bd49b6f00007887
[13:55:37] User: 0x00000000000000000000000000000000
[13:55:37] Machine: 1
[13:55:37] Reading tar file par_all27_prot_lipid.inp
[13:55:37] Reading tar file scpismQuartic.inp
[13:55:37] Reading tar file ww.pdb
[13:55:37] Reading tar file ww.psf
[13:55:37] Reading tar file checkpt
[13:55:37] Reading tar file ww.8479.pos
[13:55:37] Reading tar file ww.8479.vel
[13:55:37] Reading tar file protomol.conf
[13:55:37] Reading tar file core.xml
[13:55:37] Digital signatures verified
[13:55:38] Completed 0 out of 499375 steps (0%)
[14:18:46] Completed 5000 out of 499375 steps (1%)
--- snip ---
[23:05:15] Completed 434400 out of 499375 steps (86%)
[23:20:59] ERROR: ProtoMol ERROR: ABORT
[23:20:59] Saving result file logfile_06.txt
[23:20:59] Saving result file checkpt
[23:20:59] Saving result file checkpt.crc
[23:20:59] Saving result file log.txt
[23:21:13] Saving result file protomol.conf
[23:21:13] Saving result file ww.8610.pos
[23:21:13] Saving result file ww.8610.vel
[23:21:13] Saving result file ww.dcd
[23:21:17] Folding@home Core Shutdown: BAD_WORK_UNIT
[23:21:21] CoreStatus = 72 (114)
[23:21:21] Sending work to server
Re: Project: 10024 (Run 432, Clone 0, Gen 82)
I have no sign of this result in the DB :(
