Projekt:5768(13,130,213)
Bobby-Uschi
Hardware configuration: PC1//C2Q-Q9450,GA-X48-DS5-NinjaMini,GTX285,2x160GB Western Sata2,2x1GB Geil800,Tagan 800W;XP Pro SP3-32Bit;
PC2//C2Q-Q2600k.GB-P67UD4-Freezer 7Pro,GTX285Leadtek,260 GB Western Sata2,4x2GB GeilPC3,OCZ600W;Win7-64Bit;Siemens 22"
Post by Bobby-Uschi »
Bad WU?
04:49:28] Thank you for your contribution to Folding@Home.
[04:49:28] + Number of Units Completed: 6625
[04:49:32] Trying to send all finished work units
[04:49:32] + No unsent completed units remaining.
[04:49:32] - Preparing to get new work unit...
[04:49:32] + Attempting to get work packet
[04:49:32] - Will indicate memory of 2046 MB
[04:49:32] - Connecting to assignment server
[04:49:32] Connecting to http://assign-GPU.stanford.edu:8080/
[04:49:33] Posted data.
[04:49:33] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[04:49:33] + News From Folding@Home: Welcome to Folding@Home
[04:49:33] Loaded queue successfully.
[04:49:33] Connecting to http://171.67.108.11:8080/
[04:49:34] Posted data.
[04:49:34] Initial: 0000; - Receiving payload (expected size: 47277)
[04:49:35] - Downloaded at ~46 kB/s
[04:49:35] - Averaged speed for that direction ~40 kB/s
[04:49:35] + Received work.
[04:49:35] Trying to send all finished work units
[04:49:35] + No unsent completed units remaining.
[04:49:35] + Closed connections
[04:49:35]
[04:49:35] + Processing work unit
[04:49:35] Core required: FahCore_11.exe
[04:49:35] Core found.
[04:49:35] Working on queue slot 07 [December 23 04:49:35 UTC]
[04:49:35] + Working ...
[04:49:35] - Calling '.\FahCore_11.exe -dir work/ -suffix 07 -priority 96 -checkpoint 15 -verbose -lifeline 3576 -version 623'
[04:49:35]
[04:49:35] *------------------------------*
[04:49:35] Folding@Home GPU Core
[04:49:35] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[04:49:35]
[04:49:35] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[04:49:35] Build host: amoeba
[04:49:35] Board Type: Nvidia
[04:49:35] Core      :
[04:49:35] Preparing to commence simulation
[04:49:35] - Looking at optimizations...
[04:49:35] DeleteFrameFiles: successfully deleted file=work/wudata_07.ckp
[04:49:35] - Created dyn
[04:49:35] - Files status OK
[04:49:35] - Expanded 46765 -> 252912 (decompressed 540.8 percent)
[04:49:35] Called DecompressByteArray: compressed_data_size=46765 data_size=252912, decompressed_data_size=252912 diff=0
[04:49:35] - Digital signature verified
[04:49:35]
[04:49:35] Project: 5768 (Run 13, Clone 130, Gen 213)
[04:49:35]
[04:49:35] Assembly optimizations on if available.
[04:49:35] Entering M.D.
[04:49:41] Tpr hash work/wudata_07.tpr:  1264142866 3381986924 2430460001 1890696594 841210888
[04:49:41]
[04:49:41] Calling fah_main args: 14 usage=100
[04:49:41]
[04:49:42] Working on Protein
[04:49:42] Client config found, loading data.
[04:49:42] mdrun_gpu returned
[04:49:42] NANs detected on GPU
[04:49:42]
[04:49:42] Folding@home Core Shutdown: UNSTABLE_MACHINE
[04:49:46] CoreStatus = 7A (122)
[04:49:46] Sending work to server
[04:49:46] Project: 5768 (Run 13, Clone 130, Gen 213)
[04:49:46] - Read packet limit of 540015616... Set to 524286976.
[04:49:46] - Error: Could not get length of results file work/wuresults_07.dat
[04:49:46] - Error: Could not read unit 07 file. Removing from queue.
[04:49:46] Trying to send all finished work units
[04:49:46] + No unsent completed units remaining.
[04:49:46] - Preparing to get new work unit...
[04:49:46] + Attempting to get work packet
[04:49:46] - Will indicate memory of 2046 MB
[04:49:46] - Connecting to assignment server
[04:49:46] Connecting to http://assign-GPU.stanford.edu:8080/
[04:49:47] Posted data.
[04:49:47] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[04:49:47] + News From Folding@Home: Welcome to Folding@Home
[04:49:47] Loaded queue successfully.
[04:49:47] Connecting to http://171.67.108.11:8080/
[04:49:48] Posted data.
[04:49:48] Initial: 0000; - Receiving payload (expected size: 47277)
[04:49:49] - Downloaded at ~46 kB/s
[04:49:49] - Averaged speed for that direction ~41 kB/s
[04:49:49] + Received work.
[04:49:49] Trying to send all finished work units
[04:49:49] + No unsent completed units remaining.
[04:49:49] + Closed connections
[04:49:54]
[04:49:54] + Processing work unit
[04:49:54] Core required: FahCore_11.exe
[04:49:54] Core found.
[04:49:54] Working on queue slot 08 [December 23 04:49:54 UTC]
[04:49:54] + Working ...
[04:49:54] - Calling '.\FahCore_11.exe -dir work/ -suffix 08 -priority 96 -checkpoint 15 -verbose -lifeline 3576 -version 623'
[04:49:54]
[04:49:54] *------------------------------*
[04:49:54] Folding@Home GPU Core
[04:49:54] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[04:49:54]
[04:49:54] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[04:49:54] Build host: amoeba
[04:49:54] Board Type: Nvidia
[04:49:54] Core      :
[04:49:54] Preparing to commence simulation
[04:49:54] - Looking at optimizations...
[04:49:54] DeleteFrameFiles: successfully deleted file=work/wudata_08.ckp
[04:49:54] - Created dyn
[04:49:54] - Files status OK
[04:49:54] - Expanded 46765 -> 252912 (decompressed 540.8 percent)
[04:49:54] Called DecompressByteArray: compressed_data_size=46765 data_size=252912, decompressed_data_size=252912 diff=0
[04:49:54] - Digital signature verified
[04:49:54]
[04:49:54] Project: 5768 (Run 13, Clone 130, Gen 213)
[04:49:54]
[04:49:54] Assembly optimizations on if available.
[04:49:54] Entering M.D.
[04:50:00] Tpr hash work/wudata_08.tpr:  1264142866 3381986924 2430460001 1890696594 841210888
[04:50:00]
[04:50:00] Calling fah_main args: 14 usage=100
[04:50:00]
[04:50:00] Working on Protein
[04:50:01] Client config found, loading data.
[04:50:01] mdrun_gpu returned
[04:50:01] NANs detected on GPU
[04:50:01]
[04:50:01] Folding@home Core Shutdown: UNSTABLE_MACHINE
[04:50:04] CoreStatus = 7A (122)
[04:50:04] Sending work to server
[04:50:04] Project: 5768 (Run 13, Clone 130, Gen 213)
[04:50:04] - Read packet limit of 540015616... Set to 524286976.
[04:50:04] - Error: Could not get length of results file work/wuresults_08.dat
[04:50:04] - Error: Could not read unit 08 file. Removing from queue.
[04:50:04] Trying to send all finished work units
[04:50:04] + No unsent completed units remaining.
[04:50:04] - Preparing to get new work unit...
[04:50:04] + Attempting to get work packet
[04:50:04] - Will indicate memory of 2046 MB
[04:50:04] - Connecting to assignment server
[04:50:04] Connecting to http://assign-GPU.stanford.edu:8080/
[04:50:05] Posted data.
[04:50:05] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[04:50:05] + News From Folding@Home: Welcome to Folding@Home
[04:50:05] Loaded queue successfully.
[04:50:05] Connecting to http://171.67.108.11:8080/
[04:50:06] Posted data.
[04:50:06] Initial: 0000; - Receiving payload (expected size: 47277)
[04:50:07] - Downloaded at ~46 kB/s
[04:50:07] - Averaged speed for that direction ~42 kB/s
[04:50:07] + Received work.
[04:50:07] Trying to send all finished work units
[04:50:07] + No unsent completed units remaining.
[04:50:07] + Closed connections
[04:50:12]
[04:50:12] + Processing work unit
[04:50:12] Core required: FahCore_11.exe
[04:50:12] Core found.
[04:50:12] Working on queue slot 09 [December 23 04:50:12 UTC]
[04:50:12] + Working ...
[04:50:12] - Calling '.\FahCore_11.exe -dir work/ -suffix 09 -priority 96 -checkpoint 15 -verbose -lifeline 3576 -version 623'
[04:50:12]
[04:50:12] *------------------------------*
[04:50:12] Folding@Home GPU Core
[04:50:12] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[04:50:12]
[04:50:12] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[04:50:12] Build host: amoeba
[04:50:12] Board Type: Nvidia
[04:50:12] Core      :
[04:50:12] Preparing to commence simulation
[04:50:12] - Looking at optimizations...
[04:50:12] DeleteFrameFiles: successfully deleted file=work/wudata_09.ckp
[04:50:12] - Created dyn
[04:50:12] - Files status OK
[04:50:12] - Expanded 46765 -> 252912 (decompressed 540.8 percent)
[04:50:12] Called DecompressByteArray: compressed_data_size=46765 data_size=252912, decompressed_data_size=252912 diff=0
[04:50:12] - Digital signature verified
[04:50:12]
[04:50:12] Project: 5768 (Run 13, Clone 130, Gen 213)
[04:50:12]
[04:50:12] Assembly optimizations on if available.
[04:50:12] Entering M.D.
[04:50:18] Tpr hash work/wudata_09.tpr:  1264142866 3381986924 2430460001 1890696594 841210888
[04:50:18]
[04:50:18] Calling fah_main args: 14 usage=100
[04:50:18]
[04:50:19] Working on Protein
[04:50:19] Client config found, loading data.
[04:50:19] mdrun_gpu returned
[04:50:19] NANs detected on GPU
[04:50:19]
[04:50:19] Folding@home Core Shutdown: UNSTABLE_MACHINE
[04:50:22] CoreStatus = 7A (122)
[04:50:22] Sending work to server
[04:50:22] Project: 5768 (Run 13, Clone 130, Gen 213)
[04:50:22] - Read packet limit of 540015616... Set to 524286976.
[04:50:22] - Error: Could not get length of results file work/wuresults_09.dat
[04:50:22] - Error: Could not read unit 09 file. Removing from queue.
[04:50:22] Trying to send all finished work units
[04:50:22] + No unsent completed units remaining.
[04:50:22] - Preparing to get new work unit...
[04:50:22] + Attempting to get work packet
[04:50:22] - Will indicate memory of 2046 MB
[04:50:22] - Connecting to assignment server
[04:50:22] Connecting to http://assign-GPU.stanford.edu:8080/
[04:50:23] Posted data.
[04:50:23] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[04:50:23] + News From Folding@Home: Welcome to Folding@Home
[04:50:24] Loaded queue successfully.
[04:50:24] Connecting to http://171.67.108.11:8080/
[04:50:24] Posted data.
[04:50:24] Initial: 0000; - Receiving payload (expected size: 47277)
[04:50:26] - Downloaded at ~23 kB/s
[04:50:26] - Averaged speed for that direction ~38 kB/s
[04:50:26] + Received work.
[04:50:26] Trying to send all finished work units
[04:50:26] + No unsent completed units remaining.
[04:50:26] + Closed connections
[04:50:31]
[04:50:31] + Processing work unit
[04:50:31] Core required: FahCore_11.exe
[04:50:31] Core found.
[04:50:31] Working on queue slot 00 [December 23 04:50:31 UTC]
[04:50:31] + Working ...
[04:50:31] - Calling '.\FahCore_11.exe -dir work/ -suffix 00 -priority 96 -checkpoint 15 -verbose -lifeline 3576 -version 623'
[04:50:31]
[04:50:31] *------------------------------*
[04:50:31] Folding@Home GPU Core
[04:50:31] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[04:50:31]
[04:50:31] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[04:50:31] Build host: amoeba
[04:50:31] Board Type: Nvidia
[04:50:31] Core      :
[04:50:31] Preparing to commence simulation
[04:50:31] - Looking at optimizations...
[04:50:31] DeleteFrameFiles: successfully deleted file=work/wudata_00.ckp
[04:50:31] - Created dyn
[04:50:31] - Files status OK
[04:50:31] - Expanded 46765 -> 252912 (decompressed 540.8 percent)
[04:50:31] Called DecompressByteArray: compressed_data_size=46765 data_size=252912, decompressed_data_size=252912 diff=0
[04:50:31] - Digital signature verified
[04:50:31]
[04:50:31] Project: 5768 (Run 13, Clone 130, Gen 213)
[04:50:31]
[04:50:31] Assembly optimizations on if available.
[04:50:31] Entering M.D.
[04:50:37] Tpr hash work/wudata_00.tpr:  1264142866 3381986924 2430460001 1890696594 841210888
[04:50:37]
[04:50:37] Calling fah_main args: 14 usage=100
[04:50:37]
[04:50:37] Working on Protein
[04:50:38] Client config found, loading data.
[04:50:38] mdrun_gpu returned
[04:50:38] NANs detected on GPU
[04:50:38]
[04:50:38] Folding@home Core Shutdown: UNSTABLE_MACHINE
[04:50:41] CoreStatus = 7A (122)
[04:50:41] Sending work to server
[04:50:41] Project: 5768 (Run 13, Clone 130, Gen 213)
[04:50:41] - Read packet limit of 540015616... Set to 524286976.
[04:50:41] - Error: Could not get length of results file work/wuresults_00.dat
[04:50:41] - Error: Could not read unit 00 file. Removing from queue.
[04:50:41] Trying to send all finished work units
[04:50:41] + No unsent completed units remaining.
[04:50:41] - Preparing to get new work unit...
[04:50:41] + Attempting to get work packet
[04:50:41] - Will indicate memory of 2046 MB
[04:50:41] - Connecting to assignment server
[04:50:41] Connecting to http://assign-GPU.stanford.edu:8080/
[04:50:42] Posted data.
[04:50:42] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[04:50:42] + News From Folding@Home: Welcome to Folding@Home
[04:50:42] Loaded queue successfully.
[04:50:42] Connecting to http://171.67.108.11:8080/
[04:50:43] Posted data.
[04:50:43] Initial: 0000; - Receiving payload (expected size: 47277)
[04:50:44] - Downloaded at ~46 kB/s
[04:50:44] - Averaged speed for that direction ~40 kB/s
[04:50:44] + Received work.
[04:50:44] Trying to send all finished work units
[04:50:44] + No unsent completed units remaining.
[04:50:44] + Closed connections
[04:50:49]
[04:50:49] + Processing work unit
[04:50:49] Core required: FahCore_11.exe
[04:50:49] Core found.
[04:50:49] Working on queue slot 01 [December 23 04:50:49 UTC]
[04:50:49] + Working ...
[04:50:49] - Calling '.\FahCore_11.exe -dir work/ -suffix 01 -priority 96 -checkpoint 15 -verbose -lifeline 3576 -version 623'
[04:50:49]
[04:50:49] *------------------------------*
[04:50:49] Folding@Home GPU Core
[04:50:49] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[04:50:49]
[04:50:49] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[04:50:49] Build host: amoeba
[04:50:49] Board Type: Nvidia
[04:50:49] Core      :
[04:50:49] Preparing to commence simulation
[04:50:49] - Looking at optimizations...
[04:50:49] DeleteFrameFiles: successfully deleted file=work/wudata_01.ckp
[04:50:49] - Created dyn
[04:50:49] - Files status OK
[04:50:49] - Expanded 46765 -> 252912 (decompressed 540.8 percent)
[04:50:49] Called DecompressByteArray: compressed_data_size=46765 data_size=252912, decompressed_data_size=252912 diff=0
[04:50:49] - Digital signature verified
[04:50:49]
[04:50:49] Project: 5768 (Run 13, Clone 130, Gen 213)
[04:50:49]
[04:50:49] Assembly optimizations on if available.
[04:50:49] Entering M.D.
[04:50:55] Tpr hash work/wudata_01.tpr:  1264142866 3381986924 2430460001 1890696594 841210888
[04:50:55]
[04:50:55] Calling fah_main args: 14 usage=100
[04:50:55]
[04:50:56] Working on Protein
[04:50:56] Client config found, loading data.
[04:50:56] mdrun_gpu returned
[04:50:56] NANs detected on GPU
[04:50:56]
[04:50:56] Folding@home Core Shutdown: UNSTABLE_MACHINE
[04:50:59] CoreStatus = 7A (122)
[04:50:59] Sending work to server
[04:50:59] Project: 5768 (Run 13, Clone 130, Gen 213)
[04:50:59] - Read packet limit of 540015616... Set to 524286976.
[04:50:59] - Error: Could not get length of results file work/wuresults_01.dat
[04:50:59] - Error: Could not read unit 01 file. Removing from queue.
[04:50:59] EUE limit exceeded. Pausing 24 hours.
[10:40:08] - Autosending finished units... [December 23 10:40:08 UTC]
[10:40:08] Trying to send all finished work units
[10:40:08] + No unsent completed units remaining.
[10:40:08] - Autosend completed
[10:40:08] + Working...
[12:45:17] ***** Got a SIGTERM signal (2)
[12:45:17] Killing all core threads
Folding@Home Client Shutdown.
Launch directory: C:\Dokumente und Einstellungen\Bobby2\Anwendungsdaten\Folding@home-gpu1
Arguments: -gpu 1 -forcegpu nvidia_g80 -verbosity 9 -advmethods
[12:45:22] - Ask before connecting: No
[12:45:22] - User name: Bobby-Uschi (Team 34361)
[12:45:22] - User ID: xxxxxxxxxx08F99C2
[12:45:22] - Machine ID: 3
[12:45:22]
[12:45:23] Loaded queue successfully.
[12:45:23] Initialization complete
[12:45:23] - Preparing to get new work unit...
[12:45:23] + Attempting to get work packet
[12:45:23] - Autosending finished units... [December 23 12:45:23 UTC]
[12:45:23] Trying to send all finished work units
[12:45:23] + No unsent completed units remaining.
[12:45:23] - Autosend completed
[12:45:23] - Will indicate memory of 2046 MB
[12:45:23] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 7, Stepping: 7
[12:45:23] - Connecting to assignment server
[12:45:23] Connecting to http://assign-GPU.stanford.edu:8080/
[12:45:24] Posted data.
[12:45:24] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[12:45:24] + News From Folding@Home: Welcome to Folding@Home
[12:45:24] Loaded queue successfully.
[12:45:24] Connecting to http://171.67.108.11:8080/
[12:45:25] Posted data.
[12:45:25] Initial: 0000; - Receiving payload (expected size: 47277)
[12:45:26] - Downloaded at ~46 kB/s
[12:45:26] - Averaged speed for that direction ~41 kB/s
[12:45:26] + Received work.
[12:45:26] + Closed connections
[12:45:26]
[12:45:26] + Processing work unit
[12:45:26] Core required: FahCore_11.exe
[12:45:26] Core found.
[12:45:26] Working on queue slot 02 [December 23 12:45:26 UTC]
[12:45:26] + Working ...
[12:45:26] - Calling '.\FahCore_11.exe -dir work/ -suffix 02 -priority 96 -checkpoint 15 -verbose -lifeline 4232 -version 623'
[12:45:26]
[12:45:26] *------------------------------*
[12:45:26] Folding@Home GPU Core
[12:45:26] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[12:45:26]
[12:45:26] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:45:26] Build host: amoeba
[12:45:26] Board Type: Nvidia
[12:45:26] Core      :
[12:45:26] Preparing to commence simulation
[12:45:26] - Looking at optimizations...
[12:45:26] DeleteFrameFiles: successfully deleted file=work/wudata_02.ckp
[12:45:26] - Created dyn
[12:45:26] - Files status OK
[12:45:26] - Expanded 46765 -> 252912 (decompressed 540.8 percent)
[12:45:26] Called DecompressByteArray: compressed_data_size=46765 data_size=252912, decompressed_data_size=252912 diff=0
[12:45:26] - Digital signature verified
[12:45:26]
[12:45:26] Project: 5768 (Run 13, Clone 130, Gen 213)
[12:45:26]
[12:45:26] Assembly optimizations on if available.
[12:45:26] Entering M.D.
[12:45:32] Tpr hash work/wudata_02.tpr:  1264142866 3381986924 2430460001 1890696594 841210888
[12:45:32]
[12:45:32] Calling fah_main args: 14 usage=100
[12:45:32]
[12:45:32] Working on Protein
[12:45:33] Client config found, loading data.
[12:45:33] mdrun_gpu returned
[12:45:33] NANs detected on GPU
[12:45:33]
[12:45:33] Folding@home Core Shutdown: UNSTABLE_MACHINE
[12:45:36] CoreStatus = 7A (122)
[12:45:36] Sending work to server
[12:45:36] Project: 5768 (Run 13, Clone 130, Gen 213)
[12:45:36] - Read packet limit of 540015616... Set to 524286976.
[12:45:36] - Error: Could not get length of results file work/wuresults_02.dat
[12:45:36] - Error: Could not read unit 02 file. Removing from queue.
[12:45:36] Trying to send all finished work units
[12:45:36] + No unsent completed units remaining.
[12:45:36] - Preparing to get new work unit...
[12:45:36] + Attempting to get work packet
[12:45:36] - Will indicate memory of 2046 MB
[12:45:36] - Connecting to assignment server
[12:45:36] Connecting to http://assign-GPU.stanford.edu:8080/
[12:45:37] Posted data.
[12:45:37] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[12:45:37] + News From Folding@Home: Welcome to Folding@Home
[12:45:37] Loaded queue successfully.
[12:45:37] Connecting to http://171.67.108.11:8080/
[12:45:38] Posted data.
[12:45:38] Initial: 0000; - Error: Bad packet type from server, expected work assignment
[12:45:38] - Attempt #1  to get work failed, and no other work to do.
Waiting before retry.
[12:45:49] + Attempting to get work packet
[12:45:49] - Will indicate memory of 2046 MB
[12:45:49] - Connecting to assignment server
[12:45:49] Connecting to http://assign-GPU.stanford.edu:8080/
[12:45:50] Posted data.
[12:45:50] Initial: 43AB; - Successful: assigned to (171.67.108.11).
[12:45:50] + News From Folding@Home: Welcome to Folding@Home
[12:45:51] Loaded queue successfully.
[12:45:51] Connecting to http://171.67.108.11:8080/
[12:45:51] Posted data.
[12:45:51] Initial: 0000; - Receiving payload (expected size: 47064)
[12:45:53] - Downloaded at ~22 kB/s
[12:45:53] - Averaged speed for that direction ~37 kB/s
[12:45:53] + Received work.
[12:45:53] Trying to send all finished work units
[12:45:53] + No unsent completed units remaining.
[12:45:53] + Closed connections
[12:45:58]
[12:45:58] + Processing work unit
[12:45:58] Core required: FahCore_11.exe
[12:45:58] Core found.
[12:45:58] Working on queue slot 03 [December 23 12:45:58 UTC]
[12:45:58] + Working ...
[12:45:58] - Calling '.\FahCore_11.exe -dir work/ -suffix 03 -priority 96 -checkpoint 15 -verbose -lifeline 4232 -version 623'
[12:45:58]
[12:45:58] *------------------------------*
[12:45:58] Folding@Home GPU Core
[12:45:58] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[12:45:58]
[12:45:58] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[12:45:58] Build host: amoeba
[12:45:58] Board Type: Nvidia
[12:45:58] Core      :
[12:45:58] Preparing to commence simulation
[12:45:58] - Looking at optimizations...
[12:45:58] DeleteFrameFiles: successfully deleted file=work/wudata_03.ckp
[12:45:58] - Created dyn
[12:45:58] - Files status OK
[12:45:58] - Expanded 46552 -> 252912 (decompressed 543.2 percent)
[12:45:58] Called DecompressByteArray: compressed_data_size=46552 data_size=252912, decompressed_data_size=252912 diff=0
[12:45:58] - Digital signature verified
[12:45:58]
[12:45:58] Project: 5766 (Run 2, Clone 288, Gen 23)
[12:45:58]
[12:45:58] Assembly optimizations on if available.
[12:45:58] Entering M.D.
[12:46:04] Tpr hash work/wudata_03.tpr:  21851554 3185670580 3954251265 3285105199 2068183461
[12:46:04]
[12:46:04] Calling fah_main args: 14 usage=100
[12:46:04]
[12:46:04] Working on Protein
[12:46:05] Client config found, loading data.
[12:46:05] Starting GUI Server
[12:46:39] Completed 1%
[12:47:14] Completed 2%
[12:47:48] Completed 3%
[12:48:24] Completed 4%
[12:48:59] Completed 5%
[12:49:35] Completed 6%
[12:50:10] Completed 7%
[12:50:44] Completed 8%
[12:51:20] Completed 9%
[12:51:54] Completed 10%
[12:52:29] Completed 11%
[12:53:03] Completed 12%
[12:53:38] Completed 13%
[12:54:12] Completed 14%
[12:54:47] Completed 15%
[12:55:21] Completed 16%
[12:55:56] Completed 17%
[12:56:31] Completed 18%
[12:57:06] Completed 19%
[12:57:42] Completed 20%
[12:58:17] Completed 21%
[12:58:53] Completed 22%
[12:59:28] Completed 23%
[13:00:04] Completed 24%
[13:00:39] Completed 25%
[13:01:14] Completed 26%
[13:01:49] Completed 27%
[13:02:24] Completed 28%
[13:03:01] Completed 29%
[13:03:36] Completed 30%
[13:04:12] Completed 31%
[13:04:47] Completed 32%
[13:05:22] Completed 33%
[13:05:57] Completed 34%
[13:06:31] Completed 35%
[13:07:06] Completed 36%
[13:07:41] Completed 37%
[13:08:15] Completed 38%
[13:08:50] Completed 39%
[13:09:25] Completed 40%
[13:09:59] Completed 41%
[13:10:34] Completed 42%
[13:11:09] Completed 43%
[13:11:43] Completed 44%
[13:12:18] Completed 45%
[13:12:53] Completed 46%
PC1//C2Q-Q9450,GA-X48-DS5-,2xGTX285,2x160GB Western Sata2,2x1GB Geil800,Tagan 800W;XP Pro SP3-32Bit
PC2//C2Q-Q2600k.GB-P67UD4-Freezer 7Pro,GTX285Leadtek,260 GB WeSata2,4x2GB GeilPC3,OCZ600W;Win7-64Bit;Siemens 22"stern
Re: Projekt:5768(13,130,213)
Bobby-Uschi wrote:Bad WU?
Very likely : there's only one result in the DB and it's an immediate EUE ...
Teddy
Post by Teddy »
Immediate EUE here too for that one
[03:55:16] Posted data.
[03:55:16] Initial: 0000; - Receiving payload (expected size: 47277)
[03:55:17] - Downloaded at ~46 kB/s
[03:55:17] - Averaged speed for that direction ~44 kB/s
[03:55:17] + Received work.
[03:55:17] + Closed connections
[03:55:17]
[03:55:17] + Processing work unit
[03:55:17] Core required: FahCore_11.exe
[03:55:17] Core found.
[03:55:17] Working on queue slot 06 [December 26 03:55:17 UTC]
[03:55:17] + Working ...
[03:55:17] - Calling '.\FahCore_11.exe -dir work/ -suffix 06 -nice 19 -priority 96 -checkpoint 3 -verbose -lifeline 3316 -version 641'
[03:55:18]
[03:55:18] *------------------------------*
[03:55:18] Folding@Home GPU Core
[03:55:18] Version 1.31 (Tue Sep 15 10:57:42 PDT 2009)
[03:55:18]
[03:55:18] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[03:55:18] Build host: amoeba
[03:55:18] Board Type: Nvidia
[03:55:18] Core :
[03:55:18] Preparing to commence simulation
[03:55:18] - Looking at optimizations...
[03:55:18] DeleteFrameFiles: successfully deleted file=work/wudata_06.ckp
[03:55:18] - Created dyn
[03:55:18] - Files status OK
[03:55:18] - Expanded 46765 -> 252912 (decompressed 540.8 percent)
[03:55:18] Called DecompressByteArray: compressed_data_size=46765 data_size=252912, decompressed_data_size=252912 diff=0
[03:55:18] - Digital signature verified
[03:55:18]
[03:55:18] Project: 5768 (Run 13, Clone 130, Gen 213)
[03:55:18]
[03:55:18] Assembly optimizations on if available.
[03:55:18] Entering M.D.
[03:55:24] Tpr hash work/wudata_06.tpr: 1264142866 3381986924 2430460001 1890696594 841210888
[03:55:24]
[03:55:24] Calling fah_main args: 14 usage=100
[03:55:24]
[03:55:24] Working on Protein
[03:55:25] Client config found, loading data.
[03:55:25] mdrun_gpu returned
[03:55:25] NANs detected on GPU
[03:55:25]
[03:55:25] Folding@home Core Shutdown: UNSTABLE_MACHINE
[03:55:28] CoreStatus = 7A (122)
[03:55:28] Sending work to server
rinse & repeat..
Teddy
Right, two reports on the forum and two immediate EUE in the DB too : I'm marking this WU as a bad one.
ChasR
Post by ChasR »
It taken out one of my cards twice in two days. Instant EUE, definitely a bad WU.
