As I said, it's two in a row for the standard CPU client - but with different WUs - the other EUE was on Project: 6509 (Run 15, Clone 48, Gen 51).
[04:42:12] - Preparing to get new work unit...
[04:42:12] + Attempting to get work packet
[04:42:12] - Will indicate memory of 2047 MB
[04:42:12] - Connecting to assignment server
[04:42:12] Connecting to http://assign.stanford.edu:8080/
[04:42:13] Posted data.
[04:42:13] Initial: 40AB; - Successful: assigned to (171.64.65.62).
[04:42:13] + News From Folding@Home: Welcome to Folding@Home
[04:42:13] Loaded queue successfully.
[04:42:13] Connecting to http://171.64.65.62:8080/
[04:42:13] Initial: 0000; - Receiving payload (expected size: 420183)
[04:42:14] - Downloaded at ~410 kB/s
[04:42:14] - Averaged speed for that direction ~742 kB/s
[04:42:14] + Received work.
[04:42:14] Trying to send all finished work units
[04:42:14] + No unsent completed units remaining.
[04:42:14] + Closed connections
[04:42:19] + Processing work unit
[04:42:19] Core required: FahCore_78.exe
[04:42:19] Core found.
[04:42:19] Working on queue slot 08 [December 21 04:42:19 UTC]
[04:42:19] + Working ...
[04:42:19] - Calling '.\FahCore_78.exe -dir work/ -suffix 08 -nocpulock -checkpoint 15 -verbose -lifeline 2596 -version 623'
[04:42:19]
[04:42:19] *------------------------------*
[04:42:19] Folding@Home Gromacs Core
[04:42:19] Version 1.90 (March 8, 2006)
[04:42:19]
[04:42:19] Preparing to commence simulation
[04:42:19] - Looking at optimizations...
[04:42:19] - Created dyn
[04:42:19] - Files status OK
[04:42:19] - Expanded 419671 -> 2026461 (decompressed 482.8 percent)
[04:42:19] - Starting from initial work packet
[04:42:19]
[04:42:19] Project: 6512 (Run 10, Clone 160, Gen 58)
[04:42:19]
[04:42:19] Assembly optimizations on if available.
[04:42:19] Entering M.D.
[04:42:26] Protein: TR462_A_11 in water
[04:42:26]
[04:42:26] Writing local files
[04:42:26] Extra SSE boost OK.
[04:42:26] Completed 0 out of 250000 steps  (0%)
[04:52:12] Writing local files
[04:52:12] Completed 2500 out of 250000 steps  (1%)
[05:01:54] Writing local files
[05:01:54] Completed 5000 out of 250000 steps  (2%)
[05:11:33] Writing local files
[12:20:32] Completed 117500 out of 250000 steps  (47%)
[12:30:13] Writing local files
[12:30:13] Completed 120000 out of 250000 steps  (48%)
[12:39:56] Writing local files
[12:39:56] Completed 122500 out of 250000 steps  (49%)
[12:43:49] Gromacs cannot continue further.
[12:43:49] Going to send back what have done.
[12:43:49] logfile size: 52922
[12:43:49] - Writing 53458 bytes of core data to disk...
[12:43:49] Done: 52946 -> 5729 (compressed to 10.8 percent)
[12:43:49]   ... Done.
[12:43:49]
[12:43:49] Folding@home Core Shutdown: EARLY_UNIT_END
[12:43:52] CoreStatus = 72 (114)
[12:43:52] Sending work to server
[12:43:52] Project: 6512 (Run 10, Clone 160, Gen 58)
[12:43:52] - Read packet limit of 540015616... Set to 524286976.
[12:43:52] + Attempting to send results [December 21 12:43:52 UTC]
[12:43:52] - Reading file work/wuresults_08.dat from core
[12:43:52]   (Read 6241 bytes from disk)
[12:43:52] Connecting to http://171.64.65.62:8080/
[12:43:52] Posted data.
[12:43:52] Initial: 0000; Conversation time very short, giving reduced weight in bandwidth avg
[12:43:52] - Uploaded at ~14 kB/s
[12:43:52] - Averaged speed for that direction ~242 kB/s
[12:43:52] + Results successfully sent
[12:43:52] Thank you for your contribution to Folding@Home.
