Project: 6702 (Run 4, Clone 58, Gen 71)
chrisretusn
Hardware configuration: AMD Athlon(tm) 64 X2 Dual Core Processor 4000+
AMD Athlon(tm) XP 2600+
Post by chrisretusn »
The log is a bit hard to read due several shutdowns. This WU did complete, but had one error and restarted. Only got 921 points for it. I am guessing because I did not make the preferred deadline? ("finished with 18 percent of time to deadline remaining")
I split the log in to two parts to single out the error (second part)
Reason for reboots was upgrade of system and a working out a couple of problems. Probably should have temporarily disabled fah from restarting while troubleshooting.
The Log:
[03:57:21] + Attempting to get work packet
[03:57:21] Passkey found
[03:57:21] - Will indicate memory of 3832 MB
[03:57:21] - Connecting to assignment server
[03:57:21] Connecting to http://assign.stanford.edu:8080/
[03:57:24] Posted data.
[03:57:24] Initial: 40AB; - Successful: assigned to (171.64.65.56).
[03:57:24] + News From Folding@Home: Welcome to Folding@Home
[03:57:24] Loaded queue successfully.
[03:57:24] Connecting to http://171.64.65.56:8080/
[03:57:26] Posted data.
[03:57:26] Initial: 0000; - Receiving payload (expected size: 764009)
[03:57:40] - Downloaded at ~53 kB/s
[03:57:40] - Averaged speed for that direction ~50 kB/s
[03:57:40] + Received work.
[03:57:40] + Closed connections
[03:57:40]
[03:57:40] + Processing work unit
[03:57:40] Core required: FahCore_a3.exe
[03:57:41] Core found.
[03:57:41] Working on queue slot 01 [November 17 03:57:41 UTC]
[03:57:41] + Working ...
[03:57:41] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 01 -np 2 -checkpoint 15 -verbose -lifeline 1547 -version 629'
[03:57:41]
[03:57:41] *------------------------------*
[03:57:41] Folding@Home Gromacs SMP Core
[03:57:41] Version 2.22 (June 10, 2010)
[03:57:41]
[03:57:41] Preparing to commence simulation
[03:57:41] - Looking at optimizations...
[03:57:41] - Created dyn
[03:57:41] - Files status OK
[03:57:41] - Expanded 763497 -> 1404481 (decompressed 183.9 percent)
[03:57:41] Called DecompressByteArray: compressed_data_size=763497 data_size=1404481, decompressed_data_size=1404481 diff=0
[03:57:41] - Digital signature verified
[03:57:41]
[03:57:41] Project: 6702 (Run 4, Clone 58, Gen 71)
[03:57:41]
[03:57:41] Assembly optimizations on if available.
[03:57:41] Entering M.D.
Starting 2 threads
NNODES=2, MYRANK=0, HOSTNAME=thread #0
NNODES=2, MYRANK=1, HOSTNAME=thread #1
Reading file work/wudata_01.tpr, VERSION 4.0.99_development_20090605 (single precision)
Making 1D domain decomposition 2 x 1 x 1
starting mdrun 'VSD in POPC and water, neutralized'
144000000 steps, 720000.0 ps (continuing from step 142000000, 710000.0 ps).
[03:57:48] Completed 0 out of 2000000 steps  (0%)
[04:09:02] ***** Got a SIGTERM signal (15)
[04:09:02] Killing all core threads
Folding@Home Client Shutdown.
Received the TERM signal, stopping at the next NS step
Received the second INT/TERM signal, stopping at the next step
 Average load imbalance: 7.1 %
 Part of the total run time spent waiting due to load imbalance: 4.3 %
	Parallel run - timing based on wallclock.
               NODE (s)   Real (s)      (%)
       Time:    675.303    675.303    100.0
                       11:15
               (Mnbf/s)   (GFlops)   (ns/day)  (hour/ns)
Performance:     66.232      3.706      3.245      7.395
Thanx for Using GROMACS - Have a Nice Day
Note: Please read the license agreement (fah6 -license). Further
use of this software requires that you have read and accepted this agreement.
2 cores detected
--- Opening Log file [November 17 04:16:47 UTC]
# Linux SMP Console Edition ###################################################
                       Folding@Home Client Version 6.29
                          http://folding.stanford.edu
Launch directory: /home/folding/fah
Executable: ./fah6
Arguments: -verbosity 9 -smp
[04:16:47] - Ask before connecting: No
[04:16:47] - User name: chrisretusn (Team 2291)
[04:16:47] - User ID: X
[04:16:47] - Machine ID: 1
[04:16:47]
[04:16:47] Loaded queue successfully.
[November
[04:16:47] - Autosending finished units... [November 17 04:16:47 UTC]
[04:16:47] + Processing work unit
[04:16:47] Trying to send all finished work units
[04:16:47] Core required: FahCore_a3.exe
[04:16:47] Project: 6702 (Run 13, Clone 33, Gen 43)
[04:16:47] Core found.
[04:16:47] + Attempting to send results [November 17 04:16:47 UTC]
[04:16:47] - Reading file work/wuresults_00.dat from core
[04:16:48] Working on queue slot 01 [November 17 04:16:48 UTC]
[04:16:48] + Working ...
[04:16:48] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 01 -np 2 -checkpoint 15 -verbose -lifeline 1550 -version 629'
[04:16:48]   (Read 43678907 bytes from disk)
[04:16:48] Connecting to http://171.64.65.56:8080/
[04:16:48]
[04:16:48] *------------------------------*
[04:16:48] Folding@Home Gromacs SMP Core
[04:16:48] Version 2.22 (June 10, 2010)
[04:16:48]
[04:16:48] Preparing to commence simulation
[04:16:48] - Looking at optimizations...
[04:16:49] - Files status OK
[04:16:49] - Expanded 763497 -> 1404481 (decompressed 183.9 percent)
[04:16:49] Called DecompressByteArray: compressed_data_size=763497 data_size=1404481, decompressed_data_size=1404481 diff=0
[04:16:49] - Digital signature verified
[04:16:49]
[04:16:49] Project: 6702 (Run 4, Clone 58, Gen 71)
[04:16:49]
[04:16:49] Assembly optimizations on if available.
[04:16:49] Entering M.D.
[04:16:55] Using Gromacs checkpoints
Starting 2 threads
Reading checkpoint file work/wudata_01.cpt generated: Wed Nov 17 12:09:02 2010
144000000 steps, 720000.0 ps (continuing from step 142005072, 710025.4 ps).
[04:16:56] Resuming from checkpoint
[04:16:56] Verified work/wudata_01.log
[04:16:56] Verified work/wudata_01.trr
[04:16:56] Verified work/wudata_01.xtc
[04:16:56] Verified work/wudata_01.edr
[04:16:56] Completed 5072 out of 2000000 steps  (0%)
[04:43:40] ***** Got a SIGTERM signal (15)
[04:43:40] Killing all core threads
 Average load imbalance: 8.0 %
 Part of the total run time spent waiting due to load imbalance: 4.8 %
       Time:   1605.270   1605.270    100.0
                       26:45
Performance:     64.260      3.596      3.149      7.622
2 cores detected
--- Opening Log file [November 17 04:45:19 UTC]
Executable: ./fah6
[04:45:19] - Ask before connecting: No
[04:45:19] - User name: chrisretusn (Team 2291)
[04:45:19] - User ID: X
[04:45:19] - Machine ID: 1
[04:45:19]
[04:45:19] Loaded queue successfully.
[04:45:19]
[04:45:19] - Autosending finished units... [November 17 04:45:19 UTC]
[04:45:19] + Processing work unit
[04:45:19] Trying to send all finished work units
[04:45:19] Core required: FahCore_a3.exe
[04:45:19] Project: 6702 (Run 13, Clone 33, Gen 43)
[04:45:19] Core found.
[04:45:19] + Attempting to send results [November 17 04:45:19 UTC]
[04:45:19] - Reading file work/wuresults_00.dat from core
[04:45:20] Working on queue slot 01 [November 17 04:45:20 UTC]
[04:45:20] + Working ...
[04:45:20] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 01 -np 2 -checkpoint 15 -verbose -lifeline 1560 -version 629'
[04:45:20]   (Read 43678907 bytes from disk)
[04:45:20] Connecting to http://171.64.65.56:8080/
[04:45:20]
[04:45:20] *------------------------------*
[04:45:20] Folding@Home Gromacs SMP Core
[04:45:20] Version 2.22 (June 10, 2010)
[04:45:21]
[04:45:21] Preparing to commence simulation
[04:45:21] - Looking at optimizations...
[04:45:21] - Files status OK
[04:45:21] - Expanded 763497 -> 1404481 (decompressed 183.9 percent)
[04:45:21] Called DecompressByteArray: compressed_data_size=763497 data_size=1404481, decompressed_data_size=1404481 diff=0
[04:45:21] - Digital signature verified
[04:45:21]
[04:45:21] Project: 6702 (Run 4, Clone 58, Gen 71)
[04:45:21]
[04:45:21] Assembly optimizations on if available.
[04:45:21] Entering M.D.
[04:45:27] Using Gromacs checkpoints
Starting 2 threads
Reading checkpoint file work/wudata_01.cpt generated: Wed Nov 17 12:43:40 2010
144000000 steps, 720000.0 ps (continuing from step 142016772, 710083.9 ps).
[04:45:28] Resuming from checkpoint
[04:45:28] Verified work/wudata_01.log
[04:45:28] Verified work/wudata_01.trr
[04:45:28] Verified work/wudata_01.xtc
[04:45:28] Verified work/wudata_01.edr
[04:45:28] Completed 16772 out of 2000000 steps  (0%)
NOTE: Turning on dynamic load balancing
[04:52:19] Completed 20000 out of 2000000 steps  (1%)
[05:22:11] Posted data.
[05:22:12] Initial: 0000; - Uploaded at ~19 kB/s
[05:22:14] - Averaged speed for that direction ~19 kB/s
[05:22:14] + Results successfully sent
[05:22:14] Thank you for your contribution to Folding@Home.
[05:22:14] + Number of Units Completed: 185
[05:23:39] + Sent 1 of 1 completed units to the server
[05:23:39] - Autosend completed
[05:34:33] Completed 40000 out of 2000000 steps  (2%)
[06:19:06] Completed 60000 out of 2000000 steps  (3%)
[07:03:13] Completed 80000 out of 2000000 steps  (4%)
[07:45:20] Completed 100000 out of 2000000 steps  (5%)
[08:27:28] Completed 120000 out of 2000000 steps  (6%)
[09:09:38] Completed 140000 out of 2000000 steps  (7%)
[09:51:41] Completed 160000 out of 2000000 steps  (8%)
[10:33:43] Completed 180000 out of 2000000 steps  (9%)
[11:15:47] Completed 200000 out of 2000000 steps  (10%)
[11:23:39] - Autosending finished units... [November 17 11:23:39 UTC]
[11:23:39] Trying to send all finished work units
[11:23:39] + No unsent completed units remaining.
[11:23:39] - Autosend completed
[11:37:57] ***** Got a SIGTERM signal (15)
[11:37:57] Killing all core threads
 Average load imbalance: 0.3 %
 Part of the total run time spent waiting due to load imbalance: 0.2 %
 Steps where the load balancing was limited by -rdd, -rcon and/or -dds: X 0 %
       Time:  24749.879  24749.879    100.0
                       6h52:29
Performance:     68.901      3.856      3.378      7.105
2 cores detected
--- Opening Log file [November 17 11:39:36 UTC]
Executable: ./fah6
[11:39:36] - Ask before connecting: No
[11:39:36] - User name: chrisretusn (Team 2291)
[11:39:36] - User ID: X
[11:39:36] - Machine ID: 1
[11:39:36]
[11:39:37] Loaded queue successfully.
[11:39:37]
[11:39:37] - Autosending finished units... [11:39:37]
[11:39:37] + Processing work unit
[11:39:37] Trying to send all finished work units
[11:39:37] Core required: FahCore_a3.exe
[11:39:37] + No unsent completed units remaining.
[11:39:37] - Autosend completed
[11:39:37] Core found.
[11:39:37] Working on queue slot 01 [November 17 11:39:37 UTC]
[11:39:37] + Working ...
[11:39:37] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 01 -np 2 -checkpoint 15 -verbose -lifeline 1615 -version 629'
[11:39:37]
[11:39:37] *------------------------------*
[11:39:37] Folding@Home Gromacs SMP Core
[11:39:37] Version 2.22 (June 10, 2010)
[11:39:38]
[11:39:38] Preparing to commence simulation
[11:39:38] - Looking at optimizations...
[11:39:38] - Files status OK
[11:39:38] - Expanded 763497 -> 1404481 (decompressed 183.9 percent)
[11:39:38] Called DecompressByteArray: compressed_data_size=763497 data_size=1404481, decompressed_data_size=1404481 diff=0
[11:39:38] - Digital signature verified
[11:39:38]
[11:39:38] Project: 6702 (Run 4, Clone 58, Gen 71)
[11:39:38]
[11:39:38] Assembly optimizations on if available.
[11:39:38] Entering M.D.
[11:39:44] Using Gromacs checkpoints
Starting 2 threads
Reading checkpoint file work/wudata_01.cpt generated: Wed Nov 17 19:37:57 2010
144000000 steps, 720000.0 ps (continuing from step 142210301, 711051.5 ps).
[11:39:45] Resuming from checkpoint
[11:39:45] Verified work/wudata_01.log
[11:39:45] Verified work/wudata_01.trr
[11:39:45] Verified work/wudata_01.xtc
[11:39:45] Verified work/wudata_01.edr
[11:39:45] Completed 210301 out of 2000000 steps  (10%)
[12:00:32] Completed 220000 out of 2000000 steps  (11%)
[12:50:02] Completed 240000 out of 2000000 steps  (12%)
[13:15:40] ***** Got a SIGTERM signal (15)
[13:15:40] Killing all core threads
 Average load imbalance: 1.7 %
 Part of the total run time spent waiting due to load imbalance: 1.0 %
       Time:   5756.211   5756.211    100.0
                       1h35:56
Performance:     62.651      3.507      3.074      7.807
2 cores detected
--- Opening Log file [November 17 13:17:19 UTC]
Executable: ./fah6
[13:17:19] - Ask before connecting: No
[13:17:19] - User name: chrisretusn (Team 2291)
[13:17:19] - User ID: X
[13:17:19] - Machine ID: 1
[13:17:19]
[13:17:19] Loaded queue successfully.
[13:17:19]
[13:17:19] - Autosending finished units... [13:17:19]
[13:17:19] + Processing work unit
[13:17:19] Trying to send all finished work units
[13:17:19] Core required: FahCore_a3.exe
[13:17:19] + No unsent completed units remaining.
[13:17:19] - Autosend completed
[13:17:19] Core found.
[13:17:19] Working on queue slot 01 [November 17 13:17:19 UTC]
[13:17:19] + Working ...
[13:17:19] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 01 -np 2 -checkpoint 15 -verbose -lifeline 1650 -version 629'
[13:17:20]
[13:17:20] *------------------------------*
[13:17:20] Folding@Home Gromacs SMP Core
[13:17:20] Version 2.22 (June 10, 2010)
[13:17:20]
[13:17:20] Preparing to commence simulation
[13:17:20] - Looking at optimizations...
[13:17:20] - Files status OK
[13:17:20] - Expanded 763497 -> 1404481 (decompressed 183.9 percent)
[13:17:20] Called DecompressByteArray: compressed_data_size=763497 data_size=1404481, decompressed_data_size=1404481 diff=0
[13:17:20] - Digital signature verified
[13:17:20]
[13:17:20] Project: 6702 (Run 4, Clone 58, Gen 71)
[13:17:20]
[13:17:20] Assembly optimizations on if available.
[13:17:20] Entering M.D.
[13:17:26] Using Gromacs checkpoints
Starting 2 threads
Reading checkpoint file work/wudata_01.cpt generated: Wed Nov 17 21:15:40 2010
144000000 steps, 720000.0 ps (continuing from step 142251264, 711256.3 ps).
[13:17:27] Resuming from checkpoint
[13:17:27] Verified work/wudata_01.log
[13:17:27] Verified work/wudata_01.trr
[13:17:27] Verified work/wudata_01.xtc
[13:17:27] Verified work/wudata_01.edr
[13:17:28] Completed 251264 out of 2000000 steps  (12%)
[13:41:16] Completed 260000 out of 2000000 steps  (13%)
[14:25:53] Completed 280000 out of 2000000 steps  (14%)
[15:09:52] Completed 300000 out of 2000000 steps  (15%)
[15:53:49] Completed 320000 out of 2000000 steps  (16%)
[16:37:59] Completed 340000 out of 2000000 steps  (17%)
[17:21:47] Completed 360000 out of 2000000 steps  (18%)
[18:05:09] Completed 380000 out of 2000000 steps  (19%)
[18:48:24] Completed 400000 out of 2000000 steps  (20%)
[19:17:19] - Autosending finished units... [November 17 19:17:19 UTC]
[19:17:19] Trying to send all finished work units
[19:17:19] + No unsent completed units remaining.
[19:17:19] - Autosend completed
[19:32:04] Completed 420000 out of 2000000 steps  (21%)
[20:15:43] Completed 440000 out of 2000000 steps  (22%)
[20:59:09] Completed 460000 out of 2000000 steps  (23%)
[21:42:11] Completed 480000 out of 2000000 steps  (24%)
[22:24:39] Completed 500000 out of 2000000 steps  (25%)
[23:10:17] Completed 520000 out of 2000000 steps  (26%)
[00:00:45] Completed 540000 out of 2000000 steps  (27%)
[00:39:42] ***** Got a SIGTERM signal (15)
[00:39:42] Killing all core threads
 Average load imbalance: 5.2 %
 Part of the total run time spent waiting due to load imbalance: 3.2 %
       Time:  40935.728  40935.728    100.0
                       11h22:15
Performance:     65.906      3.688      3.232      7.426
2 cores detected
--- Opening Log file [November 18 00:41:41 UTC]
Executable: ./fah6
[00:41:41] - Ask before connecting: No
[00:41:41] - User name: chrisretusn (Team 2291)
[00:41:41] - User ID: X
[00:41:41] - Machine ID: 1
[00:41:41]
[00:41:41] Loaded queue successfully.
[00:41:41]
[00:41:41] + Processing work unit
[00:41:41] Core required: FahCore_a3.exe
[00:41:41] - Autosending finished units... [November 18 00:41:41 UTC]
[00:41:41] Trying to send all finished work units
[00:41:41] + No unsent completed units remaining.
[00:41:41] - Autosend completed
[00:41:41] Core found.
[00:41:41] Working on queue slot 01 [November 18 00:41:41 UTC]
[00:41:41] + Working ...
[00:41:41] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 01 -np 2 -checkpoint 15 -verbose -lifeline 1624 -version 629'
[00:41:41]
[00:41:41] *------------------------------*
[00:41:41] Folding@Home Gromacs SMP Core
[00:41:41] Version 2.22 (June 10, 2010)
[00:41:42]
[00:41:42] Preparing to commence simulation
[00:41:42] - Looking at optimizations...
[00:41:42] - Files status OK
[00:41:42] - Expanded 763497 -> 1404481 (decompressed 183.9 percent)
[00:41:42] Called DecompressByteArray: compressed_data_size=763497 data_size=1404481, decompressed_data_size=1404481 diff=0
[00:41:42] - Digital signature verified
[00:41:42]
[00:41:42] Project: 6702 (Run 4, Clone 58, Gen 71)
[00:41:42]
[00:41:42] Assembly optimizations on if available.
[00:41:42] Entering M.D.
[00:41:48] Using Gromacs checkpoints
Starting 2 threads
Reading checkpoint file work/wudata_01.cpt generated: Thu Nov 18 08:39:42 2010
144000000 steps, 720000.0 ps (continuing from step 142557520, 712787.6 ps).
[00:41:49] Resuming from checkpoint
[00:41:49] Verified work/wudata_01.log
[00:41:49] Verified work/wudata_01.trr
[00:41:50] Verified work/wudata_01.xtc
[00:41:50] Verified work/wudata_01.edr
[00:41:50] Completed 557520 out of 2000000 steps  (27%)
[00:47:12] Completed 560000 out of 2000000 steps  (28%)
[01:33:47] Completed 580000 out of 2000000 steps  (29%)
[02:22:15] Completed 600000 out of 2000000 steps  (30%)
[03:09:53] Completed 620000 out of 2000000 steps  (31%)
[03:56:59] Completed 640000 out of 2000000 steps  (32%)
[04:44:43] Completed 660000 out of 2000000 steps  (33%)
[05:31:52] Completed 680000 out of 2000000 steps  (34%)
[06:20:08] Completed 700000 out of 2000000 steps  (35%)
[06:41:41] - Autosending finished units... [November 18 06:41:41 UTC]
[06:41:41] Trying to send all finished work units
[06:41:41] + No unsent completed units remaining.
[06:41:41] - Autosend completed
[07:07:54] Completed 720000 out of 2000000 steps  (36%)
[07:52:08] Completed 740000 out of 2000000 steps  (37%)
[08:37:33] Completed 760000 out of 2000000 steps  (38%)
[09:21:57] Completed 780000 out of 2000000 steps  (39%)
[10:05:42] Completed 800000 out of 2000000 steps  (40%)
[10:49:17] Completed 820000 out of 2000000 steps  (41%)
[11:33:53] Completed 840000 out of 2000000 steps  (42%)
[12:20:04] Completed 860000 out of 2000000 steps  (43%)
[12:41:41] - Autosending finished units... [November 18 12:41:41 UTC]
[12:41:41] Trying to send all finished work units
[12:41:41] + No unsent completed units remaining.
[12:41:41] - Autosend completed
[13:10:07] Completed 880000 out of 2000000 steps  (44%)
[14:01:49] Completed 900000 out of 2000000 steps  (45%)
[14:54:04] Completed 920000 out of 2000000 steps  (46%)
[15:40:42] Completed 940000 out of 2000000 steps  (47%)
[16:27:24] Completed 960000 out of 2000000 steps  (48%)
[17:13:44] Completed 980000 out of 2000000 steps  (49%)
[17:59:54] Completed 1000000 out of 2000000 steps  (50%)
[18:41:41] - Autosending finished units... [November 18 18:41:41 UTC]
[18:41:41] Trying to send all finished work units
[18:41:41] + No unsent completed units remaining.
[18:41:41] - Autosend completed
[18:46:24] Completed 1020000 out of 2000000 steps  (51%)
[19:33:17] Completed 1040000 out of 2000000 steps  (52%)
[20:20:18] Completed 1060000 out of 2000000 steps  (53%)
[21:06:55] Completed 1080000 out of 2000000 steps  (54%)
[21:53:48] Completed 1100000 out of 2000000 steps  (55%)
[22:41:21] ***** Got a SIGTERM signal (15)
[22:41:21] Killing all core threads
2 cores detected
--- Opening Log file [November 18 22:43:06 UTC]
Executable: ./fah6
[22:43:06] - Ask before connecting: No
[22:43:06] - User name: chrisretusn (Team 2291)
[22:43:06] - User ID: X
[22:43:06] - Machine ID: 1
[22:43:06]
[22:43:06] Loaded queue successfully.
[22:43:06]
[22:43:06] - Autosending finished units... [22:43:06]
[22:43:06] + Processing work unit
[22:43:06] Trying to send all finished work units
[22:43:06] Core required: FahCore_a3.exe
[22:43:06] + No unsent completed units remaining.
[22:43:06] - Autosend completed
[22:43:06] Core found.
[22:43:06] Working on queue slot 01 [November 18 22:43:06 UTC]
[22:43:06] + Working ...
[22:43:06] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 01 -np 2 -checkpoint 15 -verbose -lifeline 1639 -version 629'
[22:43:07]
[22:43:07] *------------------------------*
[22:43:07] Folding@Home Gromacs SMP Core
[22:43:07] Version 2.22 (June 10, 2010)
[22:43:07]
[22:43:07] Preparing to commence simulation
[22:43:07] - Looking at optimizations...
[22:43:07] - Files status OK
[22:43:07] - Expanded 763497 -> 1404481 (decompressed 183.9 percent)
[22:43:07] Called DecompressByteArray: compressed_data_size=763497 data_size=1404481, decompressed_data_size=1404481 diff=0
[22:43:07] - Digital signature verified
[22:43:07]
[22:43:07] Project: 6702 (Run 4, Clone 58, Gen 71)
[22:43:07]
[22:43:07] Assembly optimizations on if available.
[22:43:07] Entering M.D.
[22:43:13] Using Gromacs checkpoints
Starting 2 threads
Reading checkpoint file work/wudata_01.cpt generated: Fri Nov 19 06:41:21 2010
144000000 steps, 720000.0 ps (continuing from step 143117708, 715588.5 ps).
Program mdrun, VERSION 4.0.99-dev-20100610-b6a86-dirty
Source code file: /data0/FAHdev/a3_development/gromacs/src/kernel/md.c, line: 1417
Fatal error:
Checkpoint error on step 0
For more information and tips for troubleshooting, please check the GROMACS
website at http://www.gromacs.org/Documentation/Errors
: No such process
[22:43:14] fcSaveRestoreState: I/O failed dir=0, var=0000000042F33950, varsize=20
[22:43:14] fcCheckPointResume: failure in call to fcSaveRestoreState() to restore cpt hash.
[22:43:14] Resuming from checkpoint
[22:43:14] detected an invalid checkpoint.  Restarting...fcSaveRestoreState: I/O failed dir=0, var=0000000040F0FA30, varsize=20
[22:44:07]
[22:44:07] Folding@home Core Shutdown: UNKNOWN_ERROR
[22:44:07] CoreStatus = 62 (98)
[22:44:07] + Restarting core (settings changed)
[22:44:07]
[22:44:07] + Processing work unit
[22:44:07] Core required: FahCore_a3.exe
[22:44:07] Core found.
[22:44:07] Working on queue slot 01 [November 18 22:44:07 UTC]
[22:44:07] + Working ...
[22:44:07] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 01 -np 2 -checkpoint 15 -notermcheck -verbose -lifeline 1639 -version 629'
[22:44:07]
[22:44:07] *------------------------------*
[22:44:07] Folding@Home Gromacs SMP Core
[22:44:07] Version 2.22 (June 10, 2010)
[22:44:07]
[22:44:07] Preparing to commence simulation
[22:44:07] - Looking at optimizations...
[22:44:07] - Not checking prior termination.
[22:44:08] - Expanded 763497 -> 1404481 (decompressed 183.9 percent)
[22:44:08] Called DecompressByteArray: compressed_data_size=763497 data_size=1404481, decompressed_data_size=1404481 diff=0
[22:44:08] - Digital signature verified
[22:44:08]
[22:44:08] Project: 6702 (Run 4, Clone 58, Gen 71)
[22:44:08]
[22:44:08] Assembly optimizations on if available.
[22:44:08] Entering M.D.
Starting 2 threads
[22:44:14] Completed 0 out of 2000000 steps  (0%)
[23:06:23] ***** Got a SIGTERM signal (15)
[23:06:23] Killing all core threads
 Average load imbalance: 6.8 %
 Part of the total run time spent waiting due to load imbalance: 4.1 %
       Time:   1329.853   1329.853    100.0
                       22:09
Performance:     65.338      3.656      3.202      7.495
2 cores detected
--- Opening Log file [November 18 23:08:07 UTC]
Executable: ./fah6
[23:08:07] - Ask before connecting: No
[23:08:07] - User name: chrisretusn (Team 2291)
[23:08:07] - User ID: X
[23:08:07] - Machine ID: 1
[23:08:07]
[23:08:07] Loaded queue successfully.
[23:08:07]
[23:08:07] - Autosending finished units... [23:08:07]
[23:08:07] + Processing work unit
[23:08:07] Trying to send all finished work units
[23:08:07] Core required: FahCore_a3.exe
[23:08:07] + No unsent completed units remaining.
[23:08:07] - Autosend completed
[23:08:07] Core found.
[23:08:07] Working on queue slot 01 [November 18 23:08:07 UTC]
[23:08:07] + Working ...
[23:08:07] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 01 -np 2 -checkpoint 15 -verbose -lifeline 1623 -version 629'
[23:08:08]
[23:08:08] *------------------------------*
[23:08:08] Folding@Home Gromacs SMP Core
[23:08:08] Version 2.22 (June 10, 2010)
[23:08:08]
[23:08:08] Preparing to commence simulation
[23:08:08] - Looking at optimizations...
[23:08:08] - Files status OK
[23:08:08] - Expanded 763497 -> 1404481 (decompressed 183.9 percent)
[23:08:08] Called DecompressByteArray: compressed_data_size=763497 data_size=1404481, decompressed_data_size=1404481 diff=0
[23:08:08] - Digital signature verified
[23:08:08]
[23:08:08] Project: 6702 (Run 4, Clone 58, Gen 71)
[23:08:08]
[23:08:08] Assembly optimizations on if available.
[23:08:08] Entering M.D.
[23:08:14] Using Gromacs checkpoints
Starting 2 threads
Reading checkpoint file work/wudata_01.cpt generated: Fri Nov 19 07:06:23 2010
144000000 steps, 720000.0 ps (continuing from step 142009856, 710049.3 ps).
[23:08:15] Resuming from checkpoint
[23:08:15] Verified work/wudata_01.log
[23:08:15] Verified work/wudata_01.trr
[23:08:15] Verified work/wudata_01.xtc
[23:08:15] Verified work/wudata_01.edr
[23:08:16] Completed 9856 out of 2000000 steps  (0%)
[23:32:34] Completed 20000 out of 2000000 steps  (1%)
[23:48:10] ***** Got a SIGTERM signal (15)
[23:48:10] Killing all core threads
 Average load imbalance: 1.8 %
 Part of the total run time spent waiting due to load imbalance: 1.1 %
       Time:   2395.545   2395.545    100.0
                       39:55
Performance:     61.553      3.445      3.016      7.957
2 cores detected
--- Opening Log file [November 18 23:49:51 UTC]
Executable: ./fah6
[23:49:51] - Ask before connecting: No
[23:49:51] - User name: chrisretusn (Team 2291)
[23:49:51] - User ID: X
[23:49:51] - Machine ID: 1
[23:49:51]
[23:49:51] Loaded queue successfully.
[23:49:51]
[23:49:51] - Autosending finished units... [23:49:51]
[23:49:51] + Processing work unit
[23:49:51] Trying to send all finished work units
[23:49:51] Core required: FahCore_a3.exe
[23:49:51] + No unsent completed units remaining.
[23:49:51] - Autosend completed
[23:49:51] Core found.
[23:49:51] Working on queue slot 01 [November 18 23:49:51 UTC]
[23:49:51] + Working ...
[23:49:51] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 01 -np 2 -checkpoint 15 -verbose -lifeline 1624 -version 629'
[23:49:51]
[23:49:51] *------------------------------*
[23:49:51] Folding@Home Gromacs SMP Core
[23:49:51] Version 2.22 (June 10, 2010)
[23:49:51]
[23:49:51] Preparing to commence simulation
[23:49:51] - Looking at optimizations...
[23:49:51] - Files status OK
[23:49:52] - Expanded 763497 -> 1404481 (decompressed 183.9 percent)
[23:49:52] Called DecompressByteArray: compressed_data_size=763497 data_size=1404481, decompressed_data_size=1404481 diff=0
[23:49:52] - Digital signature verified
[23:49:52]
[23:49:52] Project: 6702 (Run 4, Clone 58, Gen 71)
[23:49:52]
[23:49:52] Assembly optimizations on if available.
[23:49:52] Entering M.D.
[23:49:58] Using Gromacs checkpoints
Starting 2 threads
Reading checkpoint file work/wudata_01.cpt generated: Fri Nov 19 07:48:10 2010
144000000 steps, 720000.0 ps (continuing from step 142026581, 710132.9 ps).
[23:49:59] Resuming from checkpoint
[23:49:59] Verified work/wudata_01.log
[23:49:59] Verified work/wudata_01.trr
[23:49:59] Verified work/wudata_01.xtc
[23:49:59] Verified work/wudata_01.edr
[23:49:59] Completed 26581 out of 2000000 steps  (1%)
[00:15:07] ***** Got a SIGTERM signal (15)
[00:15:07] Killing all core threads
 Average load imbalance: 4.8 %
 Part of the total run time spent waiting due to load imbalance: 3.0 %
       Time:   1508.896   1508.896    100.0
                       25:08
Performance:     66.148      3.702      3.243      7.400
2 cores detected
--- Opening Log file [November 19 00:16:49 UTC]
Executable: ./fah6
[00:16:49] - Ask before connecting: No
[00:16:49] - User name: chrisretusn (Team 2291)
[00:16:49] - User ID: X
[00:16:49] - Machine ID: 1
[00:16:49]
[00:16:49] Loaded queue successfully.
[00:16:49]
[00:16:49] - Autosending finished units... [00:16:49]
[00:16:49] + Processing work unit
[00:16:49] Trying to send all finished work units
[00:16:49] Core required: FahCore_a3.exe
[00:16:49] + No unsent completed units remaining.
[00:16:49] - Autosend completed
[00:16:49] Core found.
[00:16:50] Working on queue slot 01 [November 19 00:16:50 UTC]
[00:16:50] + Working ...
[00:16:50] - Calling './FahCore_a3.exe -dir work/ -nice 19 -suffix 01 -np 2 -checkpoint 15 -verbose -lifeline 1644 -version 629'
[00:16:50]
[00:16:50] *------------------------------*
[00:16:50] Folding@Home Gromacs SMP Core
[00:16:50] Version 2.22 (June 10, 2010)
[00:16:50]
[00:16:50] Preparing to commence simulation
[00:16:50] - Looking at optimizations...
[00:16:50] - Files status OK
[00:16:50] - Expanded 763497 -> 1404481 (decompressed 183.9 percent)
[00:16:50] Called DecompressByteArray: compressed_data_size=763497 data_size=1404481, decompressed_data_size=1404481 diff=0
[00:16:50] - Digital signature verified
[00:16:50]
[00:16:50] Project: 6702 (Run 4, Clone 58, Gen 71)
[00:16:50]
[00:16:50] Assembly optimizations on if available.
[00:16:50] Entering M.D.
[00:16:56] Using Gromacs checkpoints
Starting 2 threads
Reading checkpoint file work/wudata_01.cpt generated: Fri Nov 19 08:15:07 2010
144000000 steps, 720000.0 ps (continuing from step 142037908, 710189.5 ps).
[00:16:57] Resuming from checkpoint
[00:16:57] Verified work/wudata_01.log
[00:16:57] Verified work/wudata_01.trr
[00:16:57] Verified work/wudata_01.xtc
[00:16:57] Verified work/wudata_01.edr
[00:16:58] Completed 37908 out of 2000000 steps  (1%)
[00:21:30] Completed 40000 out of 2000000 steps  (2%)
[01:08:01] Completed 60000 out of 2000000 steps  (3%)
[02:06:48] Completed 80000 out of 2000000 steps  (4%)
[02:52:17] Completed 100000 out of 2000000 steps  (5%)
[03:35:30] Completed 120000 out of 2000000 steps  (6%)
[04:19:17] Completed 140000 out of 2000000 steps  (7%)
[05:03:23] Completed 160000 out of 2000000 steps  (8%)
[05:47:53] Completed 180000 out of 2000000 steps  (9%)
[06:16:49] - Autosending finished units... [November 19 06:16:49 UTC]
[06:16:49] Trying to send all finished work units
[06:16:49] + No unsent completed units remaining.
[06:16:49] - Autosend completed
[06:32:10] Completed 200000 out of 2000000 steps  (10%)
[07:16:31] Completed 220000 out of 2000000 steps  (11%)
[08:01:30] Completed 240000 out of 2000000 steps  (12%)
[08:46:47] Completed 260000 out of 2000000 steps  (13%)
[09:34:13] Completed 280000 out of 2000000 steps  (14%)
[10:27:51] Completed 300000 out of 2000000 steps  (15%)
[11:21:48] Completed 320000 out of 2000000 steps  (16%)
[12:15:18] Completed 340000 out of 2000000 steps  (17%)
[12:16:49] - Autosending finished units... [November 19 12:16:49 UTC]
[12:16:49] Trying to send all finished work units
[12:16:49] + No unsent completed units remaining.
[12:16:49] - Autosend completed
[12:57:37] Completed 360000 out of 2000000 steps  (18%)
[13:39:44] Completed 380000 out of 2000000 steps  (19%)
[14:21:52] Completed 400000 out of 2000000 steps  (20%)
[15:03:55] Completed 420000 out of 2000000 steps  (21%)
[15:45:52] Completed 440000 out of 2000000 steps  (22%)
[16:27:52] Completed 460000 out of 2000000 steps  (23%)
[17:09:54] Completed 480000 out of 2000000 steps  (24%)
[17:51:54] Completed 500000 out of 2000000 steps  (25%)
[18:16:49] - Autosending finished units... [November 19 18:16:49 UTC]
[18:16:49] Trying to send all finished work units
[18:16:49] + No unsent completed units remaining.
[18:16:49] - Autosend completed
[18:33:58] Completed 520000 out of 2000000 steps  (26%)
[19:16:01] Completed 540000 out of 2000000 steps  (27%)
[19:58:04] Completed 560000 out of 2000000 steps  (28%)
[20:40:09] Completed 580000 out of 2000000 steps  (29%)
[21:22:16] Completed 600000 out of 2000000 steps  (30%)
[22:04:20] Completed 620000 out of 2000000 steps  (31%)
[22:46:22] Completed 640000 out of 2000000 steps  (32%)
[23:28:26] Completed 660000 out of 2000000 steps  (33%)
[00:10:28] Completed 680000 out of 2000000 steps  (34%)
[00:16:49] - Autosending finished units... [November 20 00:16:49 UTC]
[00:52:29] Completed 700000 out of 2000000 steps  (35%)
[01:34:35] Completed 720000 out of 2000000 steps  (36%)
[02:16:42] Completed 740000 out of 2000000 steps  (37%)
[03:06:36] Completed 760000 out of 2000000 steps  (38%)
[03:55:04] Completed 780000 out of 2000000 steps  (39%)
[04:39:40] Completed 800000 out of 2000000 steps  (40%)
[05:24:11] Completed 820000 out of 2000000 steps  (41%)
[06:08:50] Completed 840000 out of 2000000 steps  (42%)
[06:16:49] - Autosending finished units... [November 20 06:16:49 UTC]
[06:53:26] Completed 860000 out of 2000000 steps  (43%)
[07:38:13] Completed 880000 out of 2000000 steps  (44%)
[08:22:56] Completed 900000 out of 2000000 steps  (45%)
[09:07:40] Completed 920000 out of 2000000 steps  (46%)
[09:52:24] Completed 940000 out of 2000000 steps  (47%)
[10:38:11] Completed 960000 out of 2000000 steps  (48%)
[11:24:44] Completed 980000 out of 2000000 steps  (49%)
[12:11:10] Completed 1000000 out of 2000000 steps  (50%)
[12:16:49] - Autosending finished units... [November 20 12:16:49 UTC]
[13:04:11] Completed 1020000 out of 2000000 steps  (51%)
[13:48:04] Completed 1040000 out of 2000000 steps  (52%)
[14:32:49] Completed 1060000 out of 2000000 steps  (53%)
[15:15:04] Completed 1080000 out of 2000000 steps  (54%)
[15:57:15] Completed 1100000 out of 2000000 steps  (55%)
[16:39:26] Completed 1120000 out of 2000000 steps  (56%)
[17:21:38] Completed 1140000 out of 2000000 steps  (57%)
[18:03:53] Completed 1160000 out of 2000000 steps  (58%)
[18:16:49] - Autosending finished units... [November 20 18:16:49 UTC]
[18:46:07] Completed 1180000 out of 2000000 steps  (59%)
[19:28:23] Completed 1200000 out of 2000000 steps  (60%)
[20:10:36] Completed 1220000 out of 2000000 steps  (61%)
[20:52:52] Completed 1240000 out of 2000000 steps  (62%)
[21:35:04] Completed 1260000 out of 2000000 steps  (63%)
[22:19:38] Completed 1280000 out of 2000000 steps  (64%)
[23:06:50] Completed 1300000 out of 2000000 steps  (65%)
[23:49:01] Completed 1320000 out of 2000000 steps  (66%)
[00:16:49] - Autosending finished units... [November 21 00:16:49 UTC]
[00:31:10] Completed 1340000 out of 2000000 steps  (67%)
[01:13:18] Completed 1360000 out of 2000000 steps  (68%)
[01:55:28] Completed 1380000 out of 2000000 steps  (69%)
[02:37:36] Completed 1400000 out of 2000000 steps  (70%)
[03:51:27] Completed 1420000 out of 2000000 steps  (71%)
[04:35:17] Completed 1440000 out of 2000000 steps  (72%)
[05:18:09] Completed 1460000 out of 2000000 steps  (73%)
[06:00:54] Completed 1480000 out of 2000000 steps  (74%)
[06:16:49] - Autosending finished units... [November 21 06:16:49 UTC]
[06:43:44] Completed 1500000 out of 2000000 steps  (75%)
[07:46:29] Completed 1520000 out of 2000000 steps  (76%)
[08:55:35] Completed 1540000 out of 2000000 steps  (77%)
[09:59:45] Completed 1560000 out of 2000000 steps  (78%)
[10:48:51] Completed 1580000 out of 2000000 steps  (79%)
[11:38:33] Completed 1600000 out of 2000000 steps  (80%)
[12:16:49] - Autosending finished units... [November 21 12:16:49 UTC]
[12:23:50] Completed 1620000 out of 2000000 steps  (81%)
[13:11:43] Completed 1640000 out of 2000000 steps  (82%)
[13:58:58] Completed 1660000 out of 2000000 steps  (83%)
[14:40:59] Completed 1680000 out of 2000000 steps  (84%)
[15:23:00] Completed 1700000 out of 2000000 steps  (85%)
[16:05:03] Completed 1720000 out of 2000000 steps  (86%)
[16:47:06] Completed 1740000 out of 2000000 steps  (87%)
[17:29:11] Completed 1760000 out of 2000000 steps  (88%)
[18:11:16] Completed 1780000 out of 2000000 steps  (89%)
[18:16:49] - Autosending finished units... [November 21 18:16:49 UTC]
[18:53:23] Completed 1800000 out of 2000000 steps  (90%)
[19:35:28] Completed 1820000 out of 2000000 steps  (91%)
[20:17:30] Completed 1840000 out of 2000000 steps  (92%)
[20:59:34] Completed 1860000 out of 2000000 steps  (93%)
[21:41:39] Completed 1880000 out of 2000000 steps  (94%)
[22:23:46] Completed 1900000 out of 2000000 steps  (95%)
[23:05:51] Completed 1920000 out of 2000000 steps  (96%)
[23:47:57] Completed 1940000 out of 2000000 steps  (97%)
[00:16:49] - Autosending finished units... [November 22 00:16:49 UTC]
[00:30:02] Completed 1960000 out of 2000000 steps  (98%)
[01:12:03] Completed 1980000 out of 2000000 steps  (99%)
[01:54:03] Completed 2000000 out of 2000000 steps  (100%)
Writing final coordinates.
 Average load imbalance: 0.9 %
 Part of the total run time spent waiting due to load imbalance: 0.5 %
       Time: 265026.656 265026.656    100.0
                       3d01h37:06
Performance:     65.218      3.650      3.198      7.504
[01:54:04] DynamicWrapper: Finished Work Unit: sleep=10000
[01:54:14]
[01:54:14] Finished Work Unit:
[01:54:14] - Reading up to 687408 from "work/wudata_01.trr": Read 687408
[01:54:14] trr file hash check passed.
[01:54:14] - Reading up to 42706704 from "work/wudata_01.xtc": Read 42706704
[01:54:14] xtc file hash check passed.
[01:54:14] edr file hash check passed.
[01:54:14] logfile size: 293920
[01:54:14] Leaving Run
[01:54:17] - Writing 43690368 bytes of core data to disk...
[01:54:18]   ... Done.
[01:55:51] - Shutting down core
[01:55:51]
[01:55:51] Folding@home Core Shutdown: FINISHED_UNIT
[01:55:53] CoreStatus = 64 (100)
[01:55:53] Unit 1 finished with 18 percent of time to deadline remaining.
[01:55:53] Updated performance fraction: 0.430365
[01:55:53] Sending work to server
[01:55:53] Project: 6702 (Run 4, Clone 58, Gen 71)
[01:55:53] + Attempting to send results [November 22 01:55:53 UTC]
[01:55:53] - Reading file work/wuresults_01.dat from core
[01:55:53]   (Read 43690368 bytes from disk)
[01:55:53] Connecting to http://171.64.65.56:8080/
[02:31:56] Posted data.
[02:31:57] Initial: 0000; - Uploaded at ~19 kB/s
[02:31:57] - Averaged speed for that direction ~19 kB/s
[02:31:57] + Results successfully sent
[02:31:57] Thank you for your contribution to Folding@Home.
[02:31:57] + Number of Units Completed: 186
Folding on Slackware Linux.
Re: Project: 6702 (Run 4, Clone 58, Gen 71)
Hi chrisretusn (team 2291),
Your WU (P6702 R4 C58 G71) was added to the stats database on 2010-11-21 19:05:39 for 921 points of credit.
Because of this : Days taken to complete WU: 4.96
Someone else completed the WU after you right within the deadline ...
chrisretusn wrote:I am guessing because I did not make the preferred deadline? ("finished with 18 percent of time to deadline remaining")
That report is saying that the computation time was 18% of the FINAL Deadline. It doesn't include the upload time and I'm not sure about the download time, both of which are included in the bonus calculation.
The Preferred Deadline is 4.90 and the Final Deadline is 6.00 so that means you have to do better than 18.33% including an allowance for communication.
chrisretusn
Thanks toTOW and Bruce. I sort of figured it missing the preferred deadline. Nice to know I figured correctly. :)
I know were to find the Preferred and Final Deadline days. Where can I find "Days taken to complete WU: 4.96"? If FahMon, HFM or qd give that information I missed it.
The transactions that show "Days taken to complete WU" are restricted to Moderators only. That elapsed time is measured by the server. HFM and qd measure the time spent computing. You'll have to manually add the time for upload (and maybe for download) if you want an improved estimate of the bonus.
chrisretusn
I decided to calculated this WU. I used the "Posted data" times for start and finish and came up with 4.94 days. That is fairly close I'd say. :D
[03:57:40]
