171.67.108.32
171.67.108.32
Have been having trouble with this server on and off for days.
I can get the OK response if I enter the address via IE8 or ping it directly from my router diagnostics page, but at the moment I'm unable to upload finished WUs to it.
I know the particular computer and router are OK as I'm able to upload uniprocessor WUs processed on it without problem.
I'm using a GTS 450 card on this machine and it is processing WUs without producing errors.
I have another computer fitted with a pair of GTX 460s which are uploading without problem.
I assume the problem is at the Stanford end?
Re: 171.67.108.32
I don't see a problem with that server in Server Status. Did you check to make sure no security apps are blocking the WU? Such as a firewall?
Please be sure to work through the troubleshooting tips in the stickied topic here.
Re: 171.67.108.32
I have tried disabling the firewall in Windows and my router firewall, the WU will still not upload.
I have talked to my ISP and they have confirmed they are not blocking 171.67.108.32
I enclose my latest log, would be grateful if someone could shine some light on the problem.
Launch directory: C:\Documents and Settings\Keith\Application Data\Folding@home-gpu
Arguments: -send all -advmethods
[13:22:49] - Ask before connecting: No
[13:22:49] - User name: deleted
[13:22:49] - User ID: deleted
[13:22:49] - Machine ID: 3
[13:22:49]
[13:22:49] Gpu type=3 species=30.
[13:22:49] Loaded queue successfully.
[13:22:49] Initialization complete
[13:22:49] Attempting to return result(s) to server...
[13:22:49] Project: 10952 (Run 2, Clone 21, Gen 16)
[13:22:49] - Read packet limit of 540015616... Set to 524286976.
[13:22:49] + Attempting to send results [October 17 13:22:49 UTC]
[13:24:47] - Couldn't send HTTP request to server
[13:24:47] + Could not connect to Work Server (results)
[13:24:47] (171.67.108.32:8080)
[13:24:47] + Retrying using alternative port
[13:26:44] - Couldn't send HTTP request to server
[13:26:44] + Could not connect to Work Server (results)
[13:26:44] (171.67.108.32:80)
[13:26:44] - Error: Could not transmit unit 06 (completed October 16) to work server.
[13:26:44] - Read packet limit of 540015616... Set to 524286976.
[13:26:44] + Attempting to send results [October 17 13:26:44 UTC]
[13:26:44] Gpu type=3 species=30.
[13:28:42] - Couldn't send HTTP request to server
[13:28:42] + Could not connect to Work Server (results)
[13:28:42] (171.67.108.26:8080)
[13:28:42] + Retrying using alternative port
[13:28:43] - Couldn't send HTTP request to server
[13:28:43] (Got status 503)
[13:28:43] + Could not connect to Work Server (results)
[13:28:43] (171.67.108.26:80)
[13:28:43] Could not transmit unit 06 to Collection server; keeping in queue.
[13:28:43] - Failed to send all units to server
Folding@Home Client Shutdown.
Re: 171.67.108.32
probably just means the server is busy.(Got status 503)
From the stickied topic:
If it's an upload problem and the server appears to be in trouble, the client is designed to deal with this issue. After the first couple of upload attempts, it should try both the Work Server for that project and a Collection Server. If both fail, the client will keep the result in the local queue and will re-attempt the upload periodically without need for you to intervene.
Re: 171.67.108.32
I'm having trouble with this server as well, a bit differently. It began tonight [server status showing normal]:
[13:54:44] Completed 99%
[13:55:32] Completed 100%
[13:55:32] Finished fah_main
[13:55:32]
[13:55:32] Successful run
[13:55:32] DynamicWrapper: Finished Work Unit: sleep=10000
[13:55:42] Reserved 1083024 bytes for xtc file; Cosm status=0
[13:55:42] Allocated 1083024 bytes for xtc file
[13:55:42] - Reading up to 1083024 from "work/wudata_04.xtc": Read 1083024
[13:55:42] Read 1083024 bytes from xtc file; available packet space=785347440
[13:55:42] xtc file hash check passed.
[13:55:42] Reserved 32280 32280 785347440 bytes for arc file=<work/wudata_04.trr> Cosm status=0
[13:55:42] Allocated 32280 bytes for arc file
[13:55:42] - Reading up to 32280 from "work/wudata_04.trr": Read 32280
[13:55:42] Read 32280 bytes from arc file; available packet space=785315160
[13:55:42] trr file hash check passed.
[13:55:42] Allocated 544 bytes for edr file
[13:55:42] Read bedfile
[13:55:42] edr file hash check passed.
[13:55:42] Allocated 121827 bytes for logfile
[13:55:42] Read logfile
[13:55:42] GuardedRun: success in DynamicWrapper
[13:55:42] GuardedRun: done
[13:55:42] Run: GuardedRun completed.
[13:55:45] + Opened results file
[13:55:45] - Writing 1238187 bytes of core data to disk...
[13:55:45] Done: 1237675 -> 1072185 (compressed to 86.6 percent)
[13:55:45] ... Done.
[13:55:46] DeleteFrameFiles: successfully deleted file=work/wudata_04.ckp
[13:55:46] Shutting down core
[13:55:46]
[13:55:46] Folding@home Core Shutdown: FINISHED_UNIT
[13:55:49] CoreStatus = 64 (100)
[13:55:49] Unit 4 finished with 99 percent of time to deadline remaining.
[13:55:49] Updated performance fraction: 0.996528
[13:55:49] Sending work to server
[13:55:49] Project: 11258 (Run 1, Clone 18, Gen 17)
[13:55:49] - Read packet limit of 540015616... Set to 524286976.
[13:55:49] + Attempting to send results [October 18 13:55:49 UTC]
[13:55:49] - Reading file work/wuresults_04.dat from core
[13:55:49] (Read 1072697 bytes from disk)
[13:55:49] Gpu type=3 species=30.
[13:55:49] Connecting to http://171.67.108.32:8080/
[13:56:06] Posted data.
[13:56:06] Initial: 0000; - Uploaded at ~61 kB/s
[13:56:06] - Averaged speed for that direction ~75 kB/s
[13:56:06] - Server does not have record of this unit. Will try again later.
[13:56:06] - Error: Could not transmit unit 04 (completed October 18) to work server.
[13:56:06] - 1 failed uploads of this unit.
[13:56:06] Keeping unit 04 in queue.
[13:56:06] Trying to send all finished work units
[13:56:06] Project: 11258 (Run 1, Clone 18, Gen 17)
[13:56:06] - Read packet limit of 540015616... Set to 524286976.
[13:56:06] + Attempting to send results [October 18 13:56:06 UTC]
[13:56:06] - Reading file work/wuresults_04.dat from core
[13:56:06] (Read 1072697 bytes from disk)
[13:56:06] Gpu type=3 species=30.
[13:56:06] Connecting to http://171.67.108.32:8080/
[13:56:19] Posted data.
[13:56:19] Initial: 0000; - Uploaded at ~80 kB/s
[13:56:19] - Averaged speed for that direction ~76 kB/s
[13:56:19] - Server does not have record of this unit. Will try again later.
[13:56:19] - Error: Could not transmit unit 04 (completed October 18) to work server.
[13:56:19] - 2 failed uploads of this unit.
[13:56:19] - Read packet limit of 540015616... Set to 524286976.
[13:56:19] + Attempting to send results [October 18 13:56:19 UTC]
[13:56:19] - Reading file work/wuresults_04.dat from core
[13:56:19] (Read 1072697 bytes from disk)
[13:56:19] Gpu type=3 species=30.
[13:56:19] Connecting to http://171.67.108.26:8080/
[13:56:31] Posted data.
[13:56:31] Initial: 0000; - Uploaded at ~87 kB/s
[13:56:31] - Averaged speed for that direction ~78 kB/s
[b][13:56:31] - Server does not have record of this unit. Will try again later.[/b]
[13:56:31] Could not transmit unit 04 to Collection server; keeping in queue.
[13:56:31] + Sent 0 of 1 completed units to the server
[13:56:31] - Preparing to get new work unit...
[13:56:31] Cleaning up work directory
[13:56:31] + Attempting to get work packet
[13:56:31] Passkey found
[13:56:31] - Will indicate memory of 2047 MB
[13:56:31] Gpu type=3 species=30.
[13:56:31] - Detect CPU. Vendor: GenuineIntel, Family: 6, Model: 15, Stepping: 11
[13:56:31] - Connecting to assignment server
[13:56:31] Connecting to http://assign-GPU.stanford.edu:8080/
[13:56:36] Posted data.
[13:56:36] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[13:56:36] + Couldn't get work instructions.
[13:56:36] - Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
[13:56:55] + Attempting to get work packet
[13:56:55] Passkey found
[13:56:55] - Will indicate memory of 2047 MB
[13:56:55] Gpu type=3 species=30.
[13:56:55] - Connecting to assignment server
[13:56:55] Connecting to http://assign-GPU.stanford.edu:8080/
[13:56:56] Posted data.
[13:56:56] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[13:56:56] + Couldn't get work instructions.
[13:56:56] - Attempt #2 to get work failed, and no other work to do.
[13:57:19] + Attempting to get work packet
[13:57:19] Passkey found
[13:57:19] - Will indicate memory of 2047 MB
[13:57:19] Gpu type=3 species=30.
[13:57:19] - Connecting to assignment server
[13:57:19] Connecting to http://assign-GPU.stanford.edu:8080/
[13:57:20] Posted data.
[13:57:20] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[13:57:20] + Couldn't get work instructions.
[13:57:20] - Attempt #3 to get work failed, and no other work to do.
[13:57:54] + Attempting to get work packet
[13:57:54] Passkey found
[13:57:54] - Will indicate memory of 2047 MB
[13:57:54] Gpu type=3 species=30.
[13:57:54] - Connecting to assignment server
[13:57:54] Connecting to http://assign-GPU.stanford.edu:8080/
[13:57:55] Posted data.
[13:57:55] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[13:57:55] + Couldn't get work instructions.
[13:57:55] - Attempt #4 to get work failed, and no other work to do.
[13:58:45] + Attempting to get work packet
[13:58:45] Passkey found
[13:58:45] - Will indicate memory of 2047 MB
[13:58:45] Gpu type=3 species=30.
[13:58:45] - Connecting to assignment server
[13:58:45] Connecting to http://assign-GPU.stanford.edu:8080/
[13:58:46] Posted data.
[13:58:46] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[13:58:46] + Couldn't get work instructions.
[13:58:46] - Attempt #5 to get work failed, and no other work to do.
[14:00:15] + Attempting to get work packet
[14:00:15] Passkey found
[14:00:15] - Will indicate memory of 2047 MB
[14:00:15] Gpu type=3 species=30.
[14:00:15] - Connecting to assignment server
[14:00:15] Connecting to http://assign-GPU.stanford.edu:8080/
[14:00:16] Posted data.
[14:00:16] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[14:00:16] + Couldn't get work instructions.
[14:00:16] - Attempt #6 to get work failed, and no other work to do.
[14:03:02] + Attempting to get work packet
[14:03:02] Passkey found
[14:03:02] - Will indicate memory of 2047 MB
[14:03:02] Gpu type=3 species=30.
[14:03:02] - Connecting to assignment server
[14:03:02] Connecting to http://assign-GPU.stanford.edu:8080/
[14:03:03] Posted data.
[14:03:03] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[14:03:03] + Couldn't get work instructions.
[14:03:03] - Attempt #7 to get work failed, and no other work to do.
[14:08:38] + Attempting to get work packet
[14:08:38] Passkey found
[14:08:38] - Will indicate memory of 2047 MB
[14:08:38] Gpu type=3 species=30.
[14:08:38] - Connecting to assignment server
[14:08:38] Connecting to http://assign-GPU.stanford.edu:8080/
[14:08:39] Posted data.
[14:08:39] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[14:08:39] + Couldn't get work instructions.
[14:08:39] - Attempt #8 to get work failed, and no other work to do.
[14:19:23] + Attempting to get work packet
[14:19:23] Passkey found
[14:19:23] - Will indicate memory of 2047 MB
[14:19:23] Gpu type=3 species=30.
[14:19:23] - Connecting to assignment server
[14:19:23] Connecting to http://assign-GPU.stanford.edu:8080/
[14:19:24] Posted data.
[14:19:24] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[14:19:24] + Couldn't get work instructions.
[14:19:24] - Attempt #9 to get work failed, and no other work to do.
Re: 171.67.108.32
Similar problem just started happening here within the last hour.
Server Status shows no WUs Available for this server.
14:39:30] + Attempting to get work packet
[14:39:30] Passkey found
[14:39:30] - Will indicate memory of 12279 MB
[14:39:30] Gpu type=3 species=30.
[14:39:30] - Connecting to assignment server
[14:39:30] Connecting to http://assign-GPU.stanford.edu:8080/
[14:39:31] Posted data.
[14:39:31] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[14:39:31] + Couldn't get work instructions.
[14:39:31] - Attempt #9 to get work failed, and no other work to do.
Problem with Assignment Server?????
Is there currently a problem with the assignment server? I have heard from several folders that they are unable to get any GPU3 wu at the moment. The following three lines are from the log file posted by one of my fellow team members.
Original posts can be found at http://www.evga.com/forums/fb.ashx?m=635439.
Thank you for any useful information you can provide.
- Hardware configuration: Parts:
Intel Core i7 8700 cpu (X2)
Veddha 8 gpu miner case (X2)
Thermaltake hsf (X2)
Ubit riser card (X16) - Location: ames, iowa
Re: Problem with Assignment Server?????
i am also having this problem today. running a couple of gtx 480's here. nothing for a couple of hours now.
Related Thread -> viewtopic.php?f=59&t=16352
I did read that one already and figured this was a different issue. That one was started 2 days ago, and he resolved the issue by reinstalling the client. The current issue is affecting many more people.PantherX wrote:Related Thread -> viewtopic.php?f=59&t=16352
- Hardware configuration: Home Network:
ADSL 12Mbps - 807 / 14.439
USRobotics 8port 10/100/1000
All computers connected with TP CAT5
HC1:
E8400@4GHz(8*500)
4GB PC2-8000
9800GX2@stock
removed - (8800GTS-512MB@724/1810/972)
Mist 600W rev2
WinXP Pro 32bit SP3
FW180.43
1xGPU2 v6.20 R1 Core 1.18/1.19
1xSMP v6.23 Beta R1
HC2:
AM2+ x4 Phenom 9950@3GHz
2GB Crucial Ballistix PC2-5300
3x8800GS-384MB
Corsair TX 750W
WinXP Pro 32bit SP3
FW178.24
3xGPU2 v6.20 R1 Core 1.18
1xSMP v6.23 Beta R1
HC3: (not folding atm and outdated)
X2 6000+@Stock
HD3850OC-512MB@783MHz
2GB PC6400
PSU 420W
WinXP Pro 32bit SP3
CCC8.6
1*GPU2 v6.12 Beta8 Core 1.04
1*CPU 5.04
Office Network:
SDSL 20Mbps
100/1000
OC1:
E6750@stock
8800GT-256MB@702/1755/900
4GB PC6400
Tagan 480W
Vista Ultimate 32bit SP1
FW 178.24
1xGPU2 v6.20 R1 Core 1.15
1xSMP v6.23 Beta R1
OC2:
E8400@stock
2x8800GT-512MB@stock
8GB PC3-8500
Corsair HX520
Vista Business 64bit
FW178.24
2xGPU2 v6.20 R1 Core 1.15
1xSMP v6.23 Beta R1 - Location: Norway
Now i got WUs on all my non-fermi and fermi cards
Had to restart the fermi clients and som more on the non-fermi.
Looks like everybody is getting GPU3 wu again, but one report of CPU not getting a wu.
Is there a rolling server or network upgrade going on right now?
Re: 171.67.108.32
Wouldn't that be the same issue as this one: viewtopic.php?f=59&t=16352 It must be time for the OpenMM guys to collect their results and issue more work. More people are buying fast fermi hardware. (I'm ordering one today.)
- Hardware configuration: 2 x GTX 460 (825/1600/1650)
AMD Athlon II X2 250 3.0Ghz
Kingston 2Gb DDR2 1066 Mhz
MSI K9A2 Platinum
Western Digital 500Gb Sata II
LiteOn DVD
Coolermaster 900W UCP
Antec 902
Windows XP SP3 - Location: Malvern, UK
It was a problem with the servers. I had the same issue on 3 GPUs in 2 separate systems, was still getting the error message at 15:58:04 but then one GPU got a response at 16:09 UTC and the other 2 a bit later when they next tried.rjbelans wrote:Looks like everybody is getting GPU3 wu again, but one report of CPU not getting a wu.
See also: http://foldingforum.org/viewtopic.php?f=59&t=16352 and http://foldingforum.org/viewtopic.php?f=19&t=16367
which are reporting the same issue.
MSI K9A2 Platinum
LiteOn DVD
Antec 902
There was a problem with the server.
It has now been fixed, because after 11 unsuccessful attempts, the server finally accepted the results;
[13:53:20] - Server does not have record of this unit. Will try again later.
[13:53:20] - Error: Could not transmit unit 06 (completed October 18) to work server.
[13:53:20] Keeping unit 06 in queue.
[13:53:20] Project: 10928 (Run 1, Clone 22, Gen 8)
[15:21:15] - Attempt #11 to get work failed, and no other work to do.
[16:09:29] + Attempting to get work packet
[16:09:29] Passkey found
[16:09:29] Gpu type=3 species=30.
[16:09:29] - Connecting to assignment server
[16:09:30] - Successful: assigned to (171.67.108.32).
[16:09:30] + News From Folding@Home: Welcome to Folding@Home
[16:09:30] Loaded queue successfully.
[16:09:30] Gpu type=3 species=30.
[16:09:31] Project: 10928 (Run 1, Clone 22, Gen 8)
[16:09:31] - Read packet limit of 540015616... Set to 524286976.
[16:09:31] + Attempting to send results [October 18 16:09:31 UTC]
[16:09:31] Gpu type=3 species=30.
[16:09:54] + Results successfully sent
[16:09:54] Thank you for your contribution to Folding@Home.
[16:09:54] + Number of Units Completed: 1360
[16:09:54] + Closed connections
