Problems with P3051 (R6,C26,G75)... 3 times in a row this one errored out approx 5 min after reaching 43% (Client-core communications error: ERROR 0x0). Then it dumped the core & reloaded. Then it errored out @ the same place twice more before grabbing a new WU.
~snip
[18:28:42] Completed 485000 out of 500000 steps (97 percent)
[18:37:04] Writing local files
[18:37:04] Completed 490000 out of 500000 steps (98 percent)
[18:45:25] Writing local files
[18:45:25] Completed 495000 out of 500000 steps (99 percent)
[18:53:46] Writing local files
[18:53:46] Completed 500000 out of 500000 steps (100 percent)
[18:53:46] Writing final coordinates.
[18:53:47] Past main M.D. loop
[18:53:47] Will end MPI now
[18:54:47]
[18:54:47] Finished Work Unit:
[18:54:47] - Reading up to 3722496 from "work/wudata_05.arc": Read 3722496
[18:54:47] - Reading up to 1777060 from "work/wudata_05.xtc": Read 1777060
[18:54:47] goefile size: 0
[18:54:47] logfile size: 1019241
[18:54:47] Leaving Run
[18:54:48] - Writing 6523197 bytes of core data to disk...
[18:54:48] ... Done.
[18:54:48] - Shutting down core
[18:54:48]
[18:54:48] Folding@home Core Shutdown: FINISHED_UNIT
[18:54:52] CoreStatus = 64 (100)
[18:54:52] Unit 5 finished with 86 percent of time to deadline remaining.
[18:54:52] Updated performance fraction: 0.836889
[18:54:52] Sending work to server
[18:54:52] + Attempting to send results
[18:54:52] - Reading file work/wuresults_05.dat from core
[18:54:52] (Read 6523197 bytes from disk)
[18:54:52] Connecting to http://171.64.65.64:8080/
[18:56:52] Posted data.
[18:56:52] Initial: 0000; - Uploaded at ~52 kB/s
[18:56:54] - Averaged speed for that direction ~50 kB/s
[18:56:54] + Results successfully sent
[18:56:54] Thank you for your contribution to Folding@Home.
[18:56:54] + Number of Units Completed: 8
[19:00:58] - Warning: Could not delete all work unit files (5): Core returned invalid code
[19:00:58] Trying to send all finished work units
[19:00:58] + No unsent completed units remaining.
[19:00:58] - Preparing to get new work unit...
[19:00:58] + Attempting to get work packet
[19:00:58] - Will indicate memory of 2010 MB
[19:00:58] - Connecting to assignment server
[19:00:58] Connecting to http://assign.stanford.edu:8080/
[19:00:59] Posted data.
[19:00:59] Initial: 40AB; - Successful: assigned to (171.64.65.63).
[19:00:59] + News From Folding@Home: Welcome to Folding@Home
[19:00:59] Loaded queue successfully.
[19:00:59] Connecting to http://171.64.65.63:8080/
[19:01:00] Posted data.
[19:01:00] Initial: 0000; - Receiving payload (expected size: 283953)
[19:01:01] - Downloaded at ~277 kB/s
[19:01:01] - Averaged speed for that direction ~286 kB/s
[19:01:01] + Received work.
[19:01:01] Trying to send all finished work units
[19:01:01] + No unsent completed units remaining.
[19:01:01] + Closed connections
[19:01:01]
[19:01:01] + Processing work unit
[19:01:01] Core required: FahCore_a1.exe
[19:01:01] Core found.
[19:01:01] Working on Unit 06 [March 9 19:01:01]
[19:01:01] + Working ...
[19:01:01] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a1.exe -dir work/ -suffix 06 -checkpoint 15 -forceasm -verbose -lifeline 538 -version 601'
[19:01:02]
[19:01:02] *------------------------------*
[19:01:02] Folding@Home Gromacs SMP Core
[19:01:02] Version 1.74 (November 27, 2006)
[19:01:02]
[19:01:02] Preparing to commence simulation
[19:01:02] - Ensuring status. Please wait.
[19:01:19] - Assembly optimizations manually forced on.
[19:01:19] - Not checking prior termination.
[19:01:19] - Expanded 283441 -> 1506425 (decompressed 531.4 percent)
[19:01:19] - Starting from initial work packet
[19:01:19]
[19:01:19] Project: 3051 (Run 6, Clone 26, Gen 75)
[19:01:19]
[19:01:19] Assembly optimizations on if available.
[19:01:19] Entering M.D.
[19:01:19] optimizations on if available.
[19:01:25] emsv-03Extra SSE boost OK.
[19:01:25]
[19:01:25] Extra SSE boost OK.
[19:01:25] Writing local files
[19:01:25] Completed 0 out of 10000000 steps (0 percent)
[19:03:36] - Autosending finished units...
[19:03:36] Trying to send all finished work units
[19:03:36] + No unsent completed units remaining.
[19:03:36] - Autosend completed
[19:08:59] Writing local files
[19:08:59] Completed 100000 out of 10000000 steps (1 percent)
[19:16:24] Writing local files
[19:16:24] Completed 200000 out of 10000000 steps (2 percent)
[19:23:45] Writing local files
[19:23:45] Completed 300000 out of 10000000 steps (3 percent)
[19:31:06] Writing local files
[19:31:06] Completed 400000 out of 10000000 steps (4 percent)
[19:38:26] Writing local files
[19:38:26] Completed 500000 out of 10000000 steps (5 percent)
[19:45:57] Writing local files
[19:45:57] Completed 600000 out of 10000000 steps (6 percent)
[19:53:28] Writing local files
[19:53:28] Completed 700000 out of 10000000 steps (7 percent)
[20:00:51] Writing local files
[20:00:51] Completed 800000 out of 10000000 steps (8 percent)
[20:08:22] Writing local files
[20:08:22] Completed 900000 out of 10000000 steps (9 percent)
[20:15:50] Writing local files
[20:15:50] Completed 1000000 out of 10000000 steps (10 percent)
[20:23:10] Writing local files
[20:23:10] Completed 1100000 out of 10000000 steps (11 percent)
[20:30:39] Writing local files
[20:30:39] Completed 1200000 out of 10000000 steps (12 percent)
[20:38:17] Writing local files
[20:38:17] Completed 1300000 out of 10000000 steps (13 percent)
[20:45:52] Writing local files
[20:45:52] Completed 1400000 out of 10000000 steps (14 percent)
[20:53:28] Writing local files
[20:53:28] Completed 1500000 out of 10000000 steps (15 percent)
[21:00:51] Writing local files
[21:00:51] Completed 1600000 out of 10000000 steps (16 percent)
[21:08:11] Writing local files
[21:08:11] Completed 1700000 out of 10000000 steps (17 percent)
[21:15:32] Writing local files
[21:15:32] Completed 1800000 out of 10000000 steps (18 percent)
[21:22:52] Writing local files
[21:22:52] Completed 1900000 out of 10000000 steps (19 percent)
[21:30:13] Writing local files
[21:30:13] Completed 2000000 out of 10000000 steps (20 percent)
[21:37:36] Writing local files
[21:37:36] Completed 2100000 out of 10000000 steps (21 percent)
[21:45:08] Writing local files
[21:45:08] Completed 2200000 out of 10000000 steps (22 percent)
[21:52:35] Writing local files
[21:52:35] Completed 2300000 out of 10000000 steps (23 percent)
[21:59:53] Writing local files
[21:59:53] Completed 2400000 out of 10000000 steps (24 percent)
[22:07:12] Writing local files
[22:07:12] Completed 2500000 out of 10000000 steps (25 percent)
[22:14:30] Writing local files
[22:14:30] Completed 2600000 out of 10000000 steps (26 percent)
[22:21:59] Writing local files
[22:21:59] Completed 2700000 out of 10000000 steps (27 percent)
[22:29:27] Writing local files
[22:29:27] Completed 2800000 out of 10000000 steps (28 percent)
[22:36:45] Writing local files
[22:36:45] Completed 2900000 out of 10000000 steps (29 percent)
[22:44:10] Writing local files
[22:44:10] Completed 3000000 out of 10000000 steps (30 percent)
[22:51:41] Writing local files
[22:51:41] Completed 3100000 out of 10000000 steps (31 percent)
[22:58:58] Writing local files
[22:58:58] Completed 3200000 out of 10000000 steps (32 percent)
[23:06:16] Writing local files
[23:06:16] Completed 3300000 out of 10000000 steps (33 percent)
[23:13:35] Writing local files
[23:13:35] Completed 3400000 out of 10000000 steps (34 percent)
[23:20:56] Writing local files
[23:20:56] Completed 3500000 out of 10000000 steps (35 percent)
[23:28:18] Writing local files
[23:28:18] Completed 3600000 out of 10000000 steps (36 percent)
[23:35:47] Writing local files
[23:35:47] Completed 3700000 out of 10000000 steps (37 percent)
[23:43:02] Writing local files
[23:43:02] Completed 3800000 out of 10000000 steps (38 percent)
[23:50:18] Writing local files
[23:50:18] Completed 3900000 out of 10000000 steps (39 percent)
[23:57:39] Writing local files
[23:57:39] Completed 4000000 out of 10000000 steps (40 percent)
[00:05:11] Writing local files
[00:05:11] Completed 4100000 out of 10000000 steps (41 percent)
[00:12:40] Writing local files
[00:12:40] Completed 4200000 out of 10000000 steps (42 percent)
[00:19:58] Writing local files
[00:19:58] Completed 4300000 out of 10000000 steps (43 percent)
[00:25:01] Warning: long 1-4 interactions
[00:25:05] CoreStatus = 0 (0)
[00:25:05] Client-core communications error: ERROR 0x0
[00:25:05] Deleting current work unit & continuing...
[00:29:26] - Warning: Could not delete all work unit files (6): Core returned invalid code
[00:29:26] Trying to send all finished work units
[00:29:26] + No unsent completed units remaining.
[00:29:26] - Preparing to get new work unit...
[00:29:26] + Attempting to get work packet
[00:29:26] - Will indicate memory of 2010 MB
[00:29:26] - Connecting to assignment server
[00:29:26] Connecting to http://assign.stanford.edu:8080/
[00:29:26] Posted data.
[00:29:26] Initial: 40AB; - Successful: assigned to (171.64.65.63).
[00:29:26] + News From Folding@Home: Welcome to Folding@Home
[00:29:26] Loaded queue successfully.
[00:29:26] Connecting to http://171.64.65.63:8080/
[00:29:27] Posted data.
[00:29:27] Initial: 0000; - Receiving payload (expected size: 283953)
[00:29:28] - Downloaded at ~277 kB/s
[00:29:28] - Averaged speed for that direction ~284 kB/s
[00:29:28] + Received work.
[00:29:28] + Closed connections
[00:29:33]
[00:29:33] + Processing work unit
[00:29:33] Core required: FahCore_a1.exe
[00:29:33] Core found.
[00:29:33] Working on Unit 07 [March 10 00:29:33]
[00:29:33] + Working ...
[00:29:33] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a1.exe -dir work/ -suffix 07 -checkpoint 15 -forceasm -verbose -lifeline 538 -version 601'
[00:29:33]
[00:29:33] *------------------------------*
[00:29:33] Folding@Home Gromacs SMP Core
[00:29:33] Version 1.74 (November 27, 2006)
[00:29:33]
[00:29:33] Preparing to commence simulation
[00:29:33] - Ensuring status. Please wait.
[00:29:51] - Assembly optimizations manually forced on.
[00:29:51] - Not checking prior termination.
[00:29:51] - Expanded 283441 -> 1506425 (decompressed 531.4 percent)
[00:29:51] - Starting from initial work packet
[00:29:51]
[00:29:51] Project: 3051 (Run 6, Clone 26, Gen 75)
[00:29:51]
[00:29:51] Assembly optimizations on if available.
[00:29:51] Entering M.D.
[00:29:51] optimizations on if available.
[00:29:57] emsv-03Extra SSE boost OK.
[00:29:57]
[00:29:57] Extra SSE boost OK.
[00:29:57] Writing local files
[00:29:57] Completed 0 out of 10000000 steps (0 percent)
[00:37:20] Writing local files
[00:37:20] Completed 100000 out of 10000000 steps (1 percent)
[00:44:43] Writing local files
[00:44:43] Completed 200000 out of 10000000 steps (2 percent)
[00:52:09] Writing local files
[00:52:09] Completed 300000 out of 10000000 steps (3 percent)
[00:59:38] Writing local files
[00:59:38] Completed 400000 out of 10000000 steps (4 percent)
[01:03:35] - Autosending finished units...
[01:03:35] Trying to send all finished work units
[01:03:35] + No unsent completed units remaining.
[01:03:35] - Autosend completed
[01:07:00] Writing local files
[01:07:00] Completed 500000 out of 10000000 steps (5 percent)
[01:14:21] Writing local files
[01:14:21] Completed 600000 out of 10000000 steps (6 percent)
[01:21:39] Writing local files
[01:21:39] Completed 700000 out of 10000000 steps (7 percent)
[01:29:00] Writing local files
[01:29:00] Completed 800000 out of 10000000 steps (8 percent)
[01:36:20] Writing local files
[01:36:20] Completed 900000 out of 10000000 steps (9 percent)
[01:43:42] Writing local files
[01:43:42] Completed 1000000 out of 10000000 steps (10 percent)
[01:51:06] Writing local files
[01:51:06] Completed 1100000 out of 10000000 steps (11 percent)
[01:58:40] Writing local files
[01:58:40] Completed 1200000 out of 10000000 steps (12 percent)
[02:06:15] Writing local files
[02:06:15] Completed 1300000 out of 10000000 steps (13 percent)
[02:13:50] Writing local files
[02:13:50] Completed 1400000 out of 10000000 steps (14 percent)
[02:21:16] Writing local files
[02:21:16] Completed 1500000 out of 10000000 steps (15 percent)
[02:28:44] Writing local files
[02:28:44] Completed 1600000 out of 10000000 steps (16 percent)
[02:36:19] Writing local files
[02:36:19] Completed 1700000 out of 10000000 steps (17 percent)
[02:43:51] Writing local files
[02:43:51] Completed 1800000 out of 10000000 steps (18 percent)
[02:51:11] Writing local files
[02:51:11] Completed 1900000 out of 10000000 steps (19 percent)
[02:58:36] Writing local files
[02:58:36] Completed 2000000 out of 10000000 steps (20 percent)
[03:06:06] Writing local files
[03:06:06] Completed 2100000 out of 10000000 steps (21 percent)
[03:13:43] Writing local files
[03:13:43] Completed 2200000 out of 10000000 steps (22 percent)
[03:21:02] Writing local files
[03:21:02] Completed 2300000 out of 10000000 steps (23 percent)
[03:28:23] Writing local files
[03:28:23] Completed 2400000 out of 10000000 steps (24 percent)
[03:35:55] Writing local files
[03:35:55] Completed 2500000 out of 10000000 steps (25 percent)
[03:43:18] Writing local files
[03:43:18] Completed 2600000 out of 10000000 steps (26 percent)
[03:50:37] Writing local files
[03:50:37] Completed 2700000 out of 10000000 steps (27 percent)
[03:57:57] Writing local files
[03:57:57] Completed 2800000 out of 10000000 steps (28 percent)
[04:05:15] Writing local files
[04:05:15] Completed 2900000 out of 10000000 steps (29 percent)
[04:12:35] Writing local files
[04:12:35] Completed 3000000 out of 10000000 steps (30 percent)
[04:19:56] Writing local files
[04:19:56] Completed 3100000 out of 10000000 steps (31 percent)
[04:27:13] Writing local files
[04:27:13] Completed 3200000 out of 10000000 steps (32 percent)
[04:34:32] Writing local files
[04:34:32] Completed 3300000 out of 10000000 steps (33 percent)
[04:42:05] Writing local files
[04:42:05] Completed 3400000 out of 10000000 steps (34 percent)
[04:49:26] Writing local files
[04:49:26] Completed 3500000 out of 10000000 steps (35 percent)
[04:56:44] Writing local files
[04:56:44] Completed 3600000 out of 10000000 steps (36 percent)
[05:04:13] Writing local files
[05:04:13] Completed 3700000 out of 10000000 steps (37 percent)
[05:11:44] Writing local files
[05:11:44] Completed 3800000 out of 10000000 steps (38 percent)
[05:19:06] Writing local files
[05:19:06] Completed 3900000 out of 10000000 steps (39 percent)
[05:26:39] Writing local files
[05:26:39] Completed 4000000 out of 10000000 steps (40 percent)
[05:34:01] Writing local files
[05:34:01] Completed 4100000 out of 10000000 steps (41 percent)
[05:41:20] Writing local files
[05:41:20] Completed 4200000 out of 10000000 steps (42 percent)
[05:48:46] Writing local files
[05:48:46] Completed 4300000 out of 10000000 steps (43 percent)
[05:53:46] Warning: long 1-4 interactions
[05:53:50] CoreStatus = 0 (0)
[05:53:50] Client-core communications error: ERROR 0x0
[05:53:50] Deleting current work unit & continuing...
[05:58:11] - Warning: Could not delete all work unit files (7): Core returned invalid code
[05:58:11] Trying to send all finished work units
[05:58:11] + No unsent completed units remaining.
[05:58:11] - Preparing to get new work unit...
[05:58:11] + Attempting to get work packet
[05:58:11] - Will indicate memory of 2010 MB
[05:58:11] - Connecting to assignment server
[05:58:11] Connecting to http://assign.stanford.edu:8080/
[05:58:11] Posted data.
[05:58:11] Initial: 40AB; - Successful: assigned to (171.64.65.63).
[05:58:11] + News From Folding@Home: Welcome to Folding@Home
[05:58:11] Loaded queue successfully.
[05:58:11] Connecting to http://171.64.65.63:8080/
[05:58:12] Posted data.
[05:58:12] Initial: 0000; - Receiving payload (expected size: 283953)
[05:58:13] - Downloaded at ~277 kB/s
[05:58:13] - Averaged speed for that direction ~283 kB/s
[05:58:13] + Received work.
[05:58:13] + Closed connections
[05:58:18]
[05:58:18] + Processing work unit
[05:58:18] Core required: FahCore_a1.exe
[05:58:18] Core found.
[05:58:18] Working on Unit 08 [March 10 05:58:18]
[05:58:18] + Working ...
[05:58:18] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a1.exe -dir work/ -suffix 08 -checkpoint 15 -forceasm -verbose -lifeline 538 -version 601'
[05:58:18]
[05:58:18] *------------------------------*
[05:58:18] Folding@Home Gromacs SMP Core
[05:58:18] Version 1.74 (November 27, 2006)
[05:58:18]
[05:58:18] Preparing to commence simulation
[05:58:18] - Ensuring status. Please wait.
[05:58:36] - Assembly optimizations manually forced on.
[05:58:36] - Not checking prior termination.
[05:58:36] - Expanded 283441 -> 1506425 (decompressed 531.4 percent)
[05:58:36] - Starting from initial work packet
[05:58:36]
[05:58:36] Project: 3051 (Run 6, Clone 26, Gen 75)
[05:58:36]
[05:58:36] Assembly optimizations on if available.
[05:58:36] Entering M.D.
[05:58:42] Protein: 9675 p3029_SProtein: 9675 p3029_SMP-emsv-03Extra SSE boost OK.
[05:58:42]
[05:58:42] Extra SSE boost OK.
[05:58:42] Writing local files
[05:58:42] Completed 0 out of 10000000 steps (0 percent)
[06:06:17] Writing local files
[06:06:17] Completed 100000 out of 10000000 steps (1 percent)
[06:13:54] Writing local files
[06:13:54] Completed 200000 out of 10000000 steps (2 percent)
[06:21:30] Writing local files
[06:21:30] Completed 300000 out of 10000000 steps (3 percent)
[06:29:03] Writing local files
[06:29:03] Completed 400000 out of 10000000 steps (4 percent)
[06:36:31] Writing local files
[06:36:32] Completed 500000 out of 10000000 steps (5 percent)
[06:44:09] Writing local files
[06:44:09] Completed 600000 out of 10000000 steps (6 percent)
[06:51:41] Writing local files
[06:51:41] Completed 700000 out of 10000000 steps (7 percent)
[06:59:14] Writing local files
[06:59:14] Completed 800000 out of 10000000 steps (8 percent)
[07:03:34] - Autosending finished units...
[07:03:34] Trying to send all finished work units
[07:03:34] + No unsent completed units remaining.
[07:03:34] - Autosend completed
[07:06:49] Writing local files
[07:06:49] Completed 900000 out of 10000000 steps (9 percent)
[07:14:19] Writing local files
[07:14:19] Completed 1000000 out of 10000000 steps (10 percent)
[07:21:39] Writing local files
[07:21:39] Completed 1100000 out of 10000000 steps (11 percent)
[07:28:59] Writing local files
[07:28:59] Completed 1200000 out of 10000000 steps (12 percent)
[07:36:21] Writing local files
[07:36:21] Completed 1300000 out of 10000000 steps (13 percent)
[07:43:43] Writing local files
[07:43:43] Completed 1400000 out of 10000000 steps (14 percent)
[07:51:04] Writing local files
[07:51:04] Completed 1500000 out of 10000000 steps (15 percent)
[07:58:28] Writing local files
[07:58:28] Completed 1600000 out of 10000000 steps (16 percent)
[08:06:04] Writing local files
[08:06:04] Completed 1700000 out of 10000000 steps (17 percent)
[08:13:38] Writing local files
[08:13:38] Completed 1800000 out of 10000000 steps (18 percent)
[08:21:12] Writing local files
[08:21:12] Completed 1900000 out of 10000000 steps (19 percent)
[08:28:46] Writing local files
[08:28:46] Completed 2000000 out of 10000000 steps (20 percent)
[08:36:24] Writing local files
[08:36:24] Completed 2100000 out of 10000000 steps (21 percent)
[08:44:02] Writing local files
[08:44:02] Completed 2200000 out of 10000000 steps (22 percent)
[08:51:39] Writing local files
[08:51:39] Completed 2300000 out of 10000000 steps (23 percent)
[08:59:11] Writing local files
[08:59:11] Completed 2400000 out of 10000000 steps (24 percent)
[09:06:29] Writing local files
[09:06:29] Completed 2500000 out of 10000000 steps (25 percent)
[09:13:49] Writing local files
[09:13:49] Completed 2600000 out of 10000000 steps (26 percent)
[09:21:08] Writing local files
[09:21:08] Completed 2700000 out of 10000000 steps (27 percent)
[09:28:40] Writing local files
[09:28:40] Completed 2800000 out of 10000000 steps (28 percent)
[09:35:59] Writing local files
[09:35:59] Completed 2900000 out of 10000000 steps (29 percent)
[09:43:18] Writing local files
[09:43:18] Completed 3000000 out of 10000000 steps (30 percent)
[09:50:39] Writing local files
[09:50:39] Completed 3100000 out of 10000000 steps (31 percent)
[09:57:56] Writing local files
[09:57:56] Completed 3200000 out of 10000000 steps (32 percent)
[10:05:14] Writing local files
[10:05:14] Completed 3300000 out of 10000000 steps (33 percent)
[10:12:32] Writing local files
[10:12:32] Completed 3400000 out of 10000000 steps (34 percent)
[10:20:06] Writing local files
[10:20:06] Completed 3500000 out of 10000000 steps (35 percent)
[10:27:38] Writing local files
[10:27:38] Completed 3600000 out of 10000000 steps (36 percent)
[10:35:10] Writing local files
[10:35:10] Completed 3700000 out of 10000000 steps (37 percent)
[10:42:42] Writing local files
[10:42:42] Completed 3800000 out of 10000000 steps (38 percent)
[10:50:01] Writing local files
[10:50:01] Completed 3900000 out of 10000000 steps (39 percent)
[10:57:29] Writing local files
[10:57:29] Completed 4000000 out of 10000000 steps (40 percent)
[11:04:51] Writing local files
[11:04:51] Completed 4100000 out of 10000000 steps (41 percent)
[11:12:25] Writing local files
[11:12:25] Completed 4200000 out of 10000000 steps (42 percent)
[11:19:55] Writing local files
[11:19:55] Completed 4300000 out of 10000000 steps (43 percent)
[11:25:04] Warning: long 1-4 interactions
[11:25:09] CoreStatus = 0 (0)
[11:25:09] Client-core communications error: ERROR 0x0
[11:25:09] - Attempting to download new core...
[11:25:09] + Downloading new core: FahCore_a1.exe
[11:25:09] Downloading core (/~pande/Linux/x86//Core_a1.fah from www.stanford.edu)
[11:25:09] Initial: AFDE; + 10240 bytes downloaded
[11:25:09] Initial: B54E; + 20480 bytes downloaded
[11:25:09] Initial: D6C2; + 30720 bytes downloaded
[11:25:09] Initial: 9F08; + 40960 bytes downloaded
[11:25:09] Initial: C6C3; + 51200 bytes downloaded
[11:25:09] Initial: EBA8; + 61440 bytes downloaded
[11:25:09] Initial: 3141; + 71680 bytes downloaded
[11:25:10] Initial: D218; + 81920 bytes downloaded
[11:25:10] Initial: F7AC; + 92160 bytes downloaded
[11:25:10] Initial: 820B; + 102400 bytes downloaded
[11:25:10] Initial: 1B1E; + 112640 bytes downloaded
[11:25:10] Initial: C249; + 122880 bytes downloaded
[11:25:10] Initial: 5EBD; + 133120 bytes downloaded
[11:25:10] Initial: CD6C; + 143360 bytes downloaded
[11:25:10] Initial: 221C; + 153600 bytes downloaded
[11:25:10] Initial: DB18; + 163840 bytes downloaded
[11:25:10] Initial: 237E; + 174080 bytes downloaded
[11:25:10] Initial: AEEC; + 184320 bytes downloaded
[11:25:10] Initial: 4C66; + 194560 bytes downloaded
[11:25:10] Initial: AE1E; + 204800 bytes downloaded
[11:25:10] Initial: A37E; + 215040 bytes downloaded
[11:25:10] Initial: 8193; + 225280 bytes downloaded
[11:25:10] Initial: 9F05; + 235520 bytes downloaded
[11:25:10] Initial: AAA5; + 245760 bytes downloaded
[11:25:10] Initial: 6400; + 256000 bytes downloaded
[11:25:10] Initial: 6E3D; + 266240 bytes downloaded
[11:25:10] Initial: EA6B; + 276480 bytes downloaded
[11:25:10] Initial: 820A; + 286720 bytes downloaded
[11:25:10] Initial: DE6D; + 296960 bytes downloaded
[11:25:10] Initial: B97B; + 307200 bytes downloaded
[11:25:10] Initial: 9D5D; + 317440 bytes downloaded
[11:25:10] Initial: 91D7; + 327680 bytes downloaded
[11:25:10] Initial: BB3B; + 337920 bytes downloaded
[11:25:10] Initial: 611B; + 348160 bytes downloaded
[11:25:10] Initial: B290; + 358400 bytes downloaded
[11:25:10] Initial: B0AA; + 368640 bytes downloaded
[11:25:10] Initial: 6A85; + 378880 bytes downloaded
[11:25:10] Initial: BF10; + 389120 bytes downloaded
[11:25:11] Initial: A818; + 399360 bytes downloaded
[11:25:11] Initial: 90E1; + 409600 bytes downloaded
[11:25:11] Initial: 2869; + 419840 bytes downloaded
[11:25:11] Initial: CAFE; + 430080 bytes downloaded
[11:25:11] Initial: 414B; + 440320 bytes downloaded
[11:25:11] Initial: 9B7A; + 450560 bytes downloaded
[11:25:11] Initial: 33AA; + 460800 bytes downloaded
[11:25:11] Initial: B1D5; + 471040 bytes downloaded
[11:25:11] Initial: 0206; + 481280 bytes downloaded
[11:25:11] Initial: 11F4; + 491520 bytes downloaded
[11:25:11] Initial: 31B5; + 501760 bytes downloaded
[11:25:11] Initial: 46B2; + 512000 bytes downloaded
[11:25:11] Initial: 3113; + 522240 bytes downloaded
[11:25:11] Initial: 525A; + 532480 bytes downloaded
[11:25:11] Initial: 66F9; + 542720 bytes downloaded
[11:25:11] Initial: 9672; + 552960 bytes downloaded
[11:25:11] Initial: 9058; + 563200 bytes downloaded
[11:25:11] Initial: 49ED; + 573440 bytes downloaded
[11:25:11] Initial: 515D; + 583680 bytes downloaded
[11:25:11] Initial: CAC0; + 593920 bytes downloaded
[11:25:11] Initial: 0B15; + 604160 bytes downloaded
[11:25:11] Initial: 5A89; + 614400 bytes downloaded
[11:25:11] Initial: 0F31; + 624640 bytes downloaded
[11:25:11] Initial: 2BC3; + 634880 bytes downloaded
[11:25:11] Initial: 3C06; + 645120 bytes downloaded
[11:25:11] Initial: 89C7; + 655360 bytes downloaded
[11:25:11] Initial: 6C54; + 665600 bytes downloaded
[11:25:11] Initial: 8D4D; + 675840 bytes downloaded
[11:25:11] Initial: EA59; + 686080 bytes downloaded
[11:25:11] Initial: C563; + 696320 bytes downloaded
[11:25:11] Initial: 8D45; + 706560 bytes downloaded
[11:25:12] Initial: 9BD0; + 716800 bytes downloaded
[11:25:12] Initial: 130C; + 727040 bytes downloaded
[11:25:12] Initial: CDA1; + 737280 bytes downloaded
[11:25:12] Initial: 7681; + 747520 bytes downloaded
[11:25:12] Initial: 1110; + 757760 bytes downloaded
[11:25:12] Initial: EE35; + 768000 bytes downloaded
[11:25:12] Initial: E5E1; + 778240 bytes downloaded
[11:25:12] Initial: 4B97; + 788480 bytes downloaded
[11:25:12] Initial: 4D75; + 798720 bytes downloaded
[11:25:12] Initial: E268; + 808960 bytes downloaded
[11:25:12] Initial: FAC6; + 819200 bytes downloaded
[11:25:12] Initial: A625; + 829440 bytes downloaded
[11:25:12] Initial: A12A; + 839680 bytes downloaded
[11:25:12] Initial: 83A3; + 849920 bytes downloaded
[11:25:12] Initial: 3BEA; + 860160 bytes downloaded
[11:25:12] Initial: 5298; + 870400 bytes downloaded
[11:25:12] Initial: 4811; + 880640 bytes downloaded
[11:25:12] Initial: EB07; + 890880 bytes downloaded
[11:25:12] Initial: 83FC; + 901120 bytes downloaded
[11:25:12] Initial: FA4E; + 911360 bytes downloaded
[11:25:12] Initial: 2945; + 921600 bytes downloaded
[11:25:12] Initial: 6BC9; + 931840 bytes downloaded
[11:25:12] Initial: E495; + 942080 bytes downloaded
[11:25:12] Initial: 1050; + 952320 bytes downloaded
[11:25:12] Initial: 2070; + 962560 bytes downloaded
[11:25:12] Initial: 1083; + 972800 bytes downloaded
[11:25:12] Initial: 96E5; + 983040 bytes downloaded
[11:25:12] Initial: 3EEE; + 993280 bytes downloaded
[11:25:12] Initial: 84AC; + 1003520 bytes downloaded
[11:25:12] Initial: 3B6B; + 1013760 bytes downloaded
[11:25:12] Initial: 3030; + 1024000 bytes downloaded
[11:25:13] Initial: 4B95; + 1034240 bytes downloaded
[11:25:13] Initial: D9BC; + 1044480 bytes downloaded
[11:25:13] Initial: C5B8; + 1054720 bytes downloaded
[11:25:13] Initial: A5EF; + 1064960 bytes downloaded
[11:25:13] Initial: 28DC; + 1075200 bytes downloaded
[11:25:13] Initial: 0943; + 1085440 bytes downloaded
[11:25:13] Initial: 338A; + 1095680 bytes downloaded
[11:25:13] Initial: ADFC; + 1105920 bytes downloaded
[11:25:13] Initial: ED39; + 1116160 bytes downloaded
[11:25:13] Initial: D284; + 1126400 bytes downloaded
[11:25:13] Initial: 0057; + 1136640 bytes downloaded
[11:25:13] Initial: 3E65; + 1146880 bytes downloaded
[11:25:13] Initial: FCB5; + 1157120 bytes downloaded
[11:25:13] Initial: A7D8; + 1167360 bytes downloaded
[11:25:13] Initial: A564; + 1177600 bytes downloaded
[11:25:13] Initial: 7654; + 1187840 bytes downloaded
[11:25:13] Initial: 0848; + 1198080 bytes downloaded
[11:25:13] Initial: 471E; + 1208320 bytes downloaded
[11:25:13] Initial: A7F3; + 1218560 bytes downloaded
[11:25:13] Initial: FA59; + 1228800 bytes downloaded
[11:25:13] Initial: FBF2; + 1239040 bytes downloaded
[11:25:13] Initial: F54E; + 1249280 bytes downloaded
[11:25:13] Initial: 3023; + 1259520 bytes downloaded
[11:25:13] Initial: AB37; + 1269760 bytes downloaded
[11:25:13] Initial: 0896; + 1280000 bytes downloaded
[11:25:13] Initial: 756D; + 1290240 bytes downloaded
[11:25:13] Initial: C1E7; + 1300480 bytes downloaded
[11:25:13] Initial: 9AAC; + 1310720 bytes downloaded
[11:25:14] Initial: E5AF; + 1320960 bytes downloaded
[11:25:14] Initial: BBE3; + 1331200 bytes downloaded
[11:25:14] Initial: 3596; + 1341440 bytes downloaded
[11:25:14] Initial: 924C; + 1351680 bytes downloaded
[11:25:14] Initial: 30B7; + 1361920 bytes downloaded
[11:25:14] Initial: AEB7; + 1372160 bytes downloaded
[11:25:14] Initial: 7D25; + 1382400 bytes downloaded
[11:25:14] Initial: 0FEB; + 1392640 bytes downloaded
[11:25:14] Initial: 3131; + 1402880 bytes downloaded
[11:25:14] Initial: 755F; + 1413120 bytes downloaded
[11:25:14] Initial: 4800; + 1423360 bytes downloaded
[11:25:14] Initial: 1282; + 1433600 bytes downloaded
[11:25:14] Initial: B2A3; + 1443840 bytes downloaded
[11:25:14] Initial: 21E9; + 1454080 bytes downloaded
[11:25:14] Initial: 789E; + 1464320 bytes downloaded
[11:25:14] Initial: 8542; + 1474560 bytes downloaded
[11:25:14] Initial: 3A56; + 1484800 bytes downloaded
[11:25:14] Initial: D4FE; + 1490945 bytes downloaded
[11:25:14] Verifying core Core_a1.fah...
[11:25:14] Signature is VALID
[11:25:14]
[11:25:14] Trying to unzip core FahCore_a1.exe
[11:25:14] Decompressed FahCore_a1.exe (3625104 bytes) successfully
[11:25:14] + Core successfully engaged
[11:25:14] Deleting current work unit & continuing...
[11:29:35] - Warning: Could not delete all work unit files (8): Core returned invalid code
[11:29:35] Trying to send all finished work units
[11:29:35] + No unsent completed units remaining.
[11:29:35] - Preparing to get new work unit...
[11:29:35] + Attempting to get work packet
[11:29:35] - Will indicate memory of 2010 MB
[11:29:35] - Connecting to assignment server
[11:29:35] Connecting to http://assign.stanford.edu:8080/
[11:29:36] Posted data.
[11:29:36] Initial: 40AB; - Successful: assigned to (171.64.65.63).
[11:29:36] + News From Folding@Home: Welcome to Folding@Home
[11:29:36] Loaded queue successfully.
[11:29:36] Connecting to http://171.64.65.63:8080/
[11:29:37] Posted data.
[11:29:37] Initial: 0000; - Receiving payload (expected size: 283953)
[11:29:38] - Downloaded at ~277 kB/s
[11:29:38] - Averaged speed for that direction ~281 kB/s
[11:29:38] + Received work.
[11:29:38] + Closed connections
[11:29:43]
[11:29:43] + Processing work unit
[11:29:43] Core required: FahCore_a1.exe
[11:29:43] Core found.
[11:29:43] Working on Unit 09 [March 10 11:29:43]
[11:29:43] + Working ...
[11:29:43] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a1.exe -dir work/ -suffix 09 -checkpoint 15 -forceasm -verbose -lifeline 538 -version 601'
[11:29:43]
[11:29:43] *------------------------------*
[11:29:43] Folding@Home Gromacs SMP Core
[11:29:43] Version 1.74 (November 27, 2006)
[11:29:43]
[11:29:43] Preparing to commence simulation
[11:29:43] - Ensuring status. Please wait.
[11:30:00] - Assembly optimizations manually forced on.
[11:30:00] - Not checking prior termination.
[11:30:00] - Expanded 283441 -> 1506425 (decompressed 531.4 percent)
[11:30:00] - Starting from initial work packet
[11:30:00]
[11:30:00] Project: 3051 (Run 6, Clone 26, Gen 75)
[11:30:00]
[11:30:00] Assembly optimizations on if available.
[11:30:00] Entering M.D.
[11:30:06] Protein: 9675 p3029_SProtein: 9675 p3029_SMP-emsv-03Extra SSE boost OK.
[11:30:06]
[11:30:06] Extra SSE boost OK.
[11:30:06] Writing local files
[11:30:06] Completed 0 out of 10000000 steps (0 percent)
[11:37:41] Writing local files
[11:37:41] Completed 100000 out of 10000000 steps (1 percent)
[11:45:18] Writing local files
[11:45:18] Completed 200000 out of 10000000 steps (2 percent)
[11:52:53] Writing local files
[11:52:53] Completed 300000 out of 10000000 steps (3 percent)
[12:00:25] Writing local files
[12:00:25] Completed 400000 out of 10000000 steps (4 percent)
[12:08:00] Writing local files
[12:08:00] Completed 500000 out of 10000000 steps (5 percent)
[12:15:33] Writing local files
[12:15:33] Completed 600000 out of 10000000 steps (6 percent)
[12:22:51] Writing local files
[12:22:52] Completed 700000 out of 10000000 steps (7 percent)
[12:30:12] Writing local files
[12:30:12] Completed 800000 out of 10000000 steps (8 percent)
[12:37:33] Writing local files
[12:37:33] Completed 900000 out of 10000000 steps (9 percent)
[12:44:55] Writing local files
[12:44:55] Completed 1000000 out of 10000000 steps (10 percent)
[12:52:15] Writing local files
[12:52:15] Completed 1100000 out of 10000000 steps (11 percent)
[12:59:42] Writing local files
[12:59:42] Completed 1200000 out of 10000000 steps (12 percent)
[13:03:33] - Autosending finished units...
[13:03:33] Trying to send all finished work units
[13:03:33] + No unsent completed units remaining.
[13:03:33] - Autosend completed
[13:07:08] Writing local files
[13:07:08] Completed 1300000 out of 10000000 steps (13 percent)
[13:14:30] Writing local files
[13:14:30] Completed 1400000 out of 10000000 steps (14 percent)
[13:22:02] Writing local files
[13:22:02] Completed 1500000 out of 10000000 steps (15 percent)
[13:29:39] Writing local files
[13:29:39] Completed 1600000 out of 10000000 steps (16 percent)
[13:37:14] Writing local files
[13:37:14] Completed 1700000 out of 10000000 steps (17 percent)
[13:44:35] Writing local files
[13:44:35] Completed 1800000 out of 10000000 steps (18 percent)
[13:52:09] Writing local files
[13:52:09] Completed 1900000 out of 10000000 steps (19 percent)
[13:59:37] Writing local files
[13:59:37] Completed 2000000 out of 10000000 steps (20 percent)
[14:07:14] Writing local files
[14:07:14] Completed 2100000 out of 10000000 steps (21 percent)
[14:14:53] Writing local files
[14:14:53] Completed 2200000 out of 10000000 steps (22 percent)
[14:22:15] Writing local files
[14:22:15] Completed 2300000 out of 10000000 steps (23 percent)
[14:29:38] Writing local files
[14:29:38] Completed 2400000 out of 10000000 steps (24 percent)
[14:36:59] Writing local files
[14:36:59] Completed 2500000 out of 10000000 steps (25 percent)
[14:44:19] Writing local files
[14:44:19] Completed 2600000 out of 10000000 steps (26 percent)
[14:51:45] Writing local files
[14:51:45] Completed 2700000 out of 10000000 steps (27 percent)
[14:59:19] Writing local files
[14:59:19] Completed 2800000 out of 10000000 steps (28 percent)
[15:06:46] Writing local files
[15:06:46] Completed 2900000 out of 10000000 steps (29 percent)
[15:14:07] Writing local files
[15:14:07] Completed 3000000 out of 10000000 steps (30 percent)
[15:21:36] Writing local files
[15:21:36] Completed 3100000 out of 10000000 steps (31 percent)
[15:29:07] Writing local files
[15:29:07] Completed 3200000 out of 10000000 steps (32 percent)
[15:36:27] Writing local files
[15:36:27] Completed 3300000 out of 10000000 steps (33 percent)
[15:43:46] Writing local files
[15:43:46] Completed 3400000 out of 10000000 steps (34 percent)
[15:51:08] Writing local files
[15:51:08] Completed 3500000 out of 10000000 steps (35 percent)
[15:58:26] Writing local files
[15:58:26] Completed 3600000 out of 10000000 steps (36 percent)
[16:05:44] Writing local files
[16:05:44] Completed 3700000 out of 10000000 steps (37 percent)
[16:13:01] Writing local files
[16:13:01] Completed 3800000 out of 10000000 steps (38 percent)
[16:20:24] Writing local files
[16:20:24] Completed 3900000 out of 10000000 steps (39 percent)
[16:27:47] Writing local files
[16:27:47] Completed 4000000 out of 10000000 steps (40 percent)
[16:35:12] Writing local files
[16:35:12] Completed 4100000 out of 10000000 steps (41 percent)
[16:42:30] Writing local files
[16:42:30] Completed 4200000 out of 10000000 steps (42 percent)
[16:49:48] Writing local files
[16:49:48] Completed 4300000 out of 10000000 steps (43 percent)
[16:54:48] Warning: long 1-4 interactions
[16:54:52] CoreStatus = 0 (0)
[16:54:52] Client-core communications error: ERROR 0x0
[16:54:52] Deleting current work unit & continuing...
[16:59:13] - Warning: Could not delete all work unit files (9): Core returned invalid code
[16:59:13] Trying to send all finished work units
[16:59:13] + No unsent completed units remaining.
[16:59:13] - Preparing to get new work unit...
[16:59:13] + Attempting to get work packet
[16:59:13] - Will indicate memory of 2010 MB
[16:59:13] - Connecting to assignment server
[16:59:13] Connecting to http://assign.stanford.edu:8080/
[16:59:14] Posted data.
[16:59:14] Initial: 40AB; - Successful: assigned to (171.64.65.63).
[16:59:14] + News From Folding@Home: Welcome to Folding@Home
[16:59:14] Loaded queue successfully.
[16:59:14] Connecting to http://171.64.65.63:8080/
[16:59:15] Posted data.
[16:59:15] Initial: 0000; - Receiving payload (expected size: 283953)
[16:59:16] - Downloaded at ~277 kB/s
[16:59:16] - Averaged speed for that direction ~281 kB/s
[16:59:16] + Received work.
[16:59:16] + Closed connections
[16:59:21]
[16:59:21] + Processing work unit
[16:59:21] Core required: FahCore_a1.exe
[16:59:21] Core found.
[16:59:21] Working on Unit 00 [March 10 16:59:21]
[16:59:21] + Working ...
[16:59:21] - Calling './mpiexec -np 4 -host 127.0.0.1 ./FahCore_a1.exe -dir work/ -suffix 00 -checkpoint 15 -forceasm -verbose -lifeline 538 -version 601'
[16:59:21]
[16:59:21] *------------------------------*
[16:59:21] Folding@Home Gromacs SMP Core
[16:59:21] Version 1.74 (November 27, 2006)
[16:59:21]
[16:59:21] Preparing to commence simulation
[16:59:21] - Ensuring status. Please wait.
[16:59:38] - Assembly optimizations manually forced on.
[16:59:38] - Not checking prior termination.
[16:59:38] - Expanded 283441 -> 1506425 (decompressed 531.4 percent)
[16:59:38] - Starting from initial work packet
[16:59:38]
[16:59:38] Project: 3051 (Run 6, Clone 26, Gen 75)
[16:59:38]
[16:59:38] Assembly optimizations on if available.
[16:59:38] Entering M.D.
[16:59:44] Protein: 9675 p3029_SProtein: 9675 p3029_SMP-emsv-03Extra SSE boost OK.
[16:59:44]
[16:59:44] Extra SSE boost OK.
[16:59:44] Writing local files
[16:59:44] Completed 0 out of 10000000 steps (0 percent)
[17:07:05] Writing local files
[17:07:05] Completed 100000 out of 10000000 steps (1 percent)
[17:14:26] Writing local files
[17:14:26] Completed 200000 out of 10000000 steps (2 percent)
[17:22:00] Writing local files
[17:22:00] Completed 300000 out of 10000000 steps (3 percent)
[17:29:34] Writing local files
[17:29:34] Completed 400000 out of 10000000 steps (4 percent)
[17:37:09] Writing local files
[17:37:09] Completed 500000 out of 10000000 steps (5 percent)
[17:44:45] Writing local files
[17:44:45] Completed 600000 out of 10000000 steps (6 percent)
~snip
I don't really care about lost points, just want to report what I think may be a bad WU.
Cheers
