Project: 2686 (Run 9, Clone 2, Gen 21) missing stats?
I don't see these stats (including bigadv bonus) for this. I had plenty of WU's posted before starting the below. Work started on Sep-16, and finished Sep-18, with successful submission of results sep-18 concluded at 19:06:51. Log excerpt posted below.
Note I started the run with 12 threads, and resumed this with 24 threads -- hence TPF goes from ~20 minutes to ~12 minutes. A couple of other bigadv work items have posted successfully since.
[15:57:23] - Ask before connecting: No
[15:57:23] - User name: sfield (Team 111065)
[15:57:23] - Machine ID: 1
[20:19:26] - Connecting to assignment server
[20:19:27] - Successful: assigned to (171.67.108.22).
[20:19:27] + News From Folding@Home: Welcome to Folding@Home
[20:19:27] Loaded queue successfully.
[20:19:40] + Closed connections
[20:19:40]
[20:19:40] + Processing work unit
[20:19:40] Core required: FahCore_a3.exe
[20:19:40] Core found.
[20:19:40] Working on queue slot 01 [September 16 20:19:40 UTC]
[20:19:40] + Working ...
[20:19:41] *------------------------------*
[20:19:41] Folding@Home Gromacs SMP Core
[20:19:41] Version 2.22 (Mar 12, 2010)
[20:19:41]
[20:19:41] Preparing to commence simulation
[20:19:41] - Looking at optimizations...
[20:19:41] - Created dyn
[20:19:41] - Files status OK
[20:19:45] - Expanded 25475500 -> 31941441 (decompressed 125.3 percent)
[20:19:45] Called DecompressByteArray: compressed_data_size=25475500 data_size=31941441, decompressed_data_size=31941441 diff=0
[20:19:45] - Digital signature verified
[20:19:45]
[20:19:45] Project: 2686 (Run 9, Clone 2, Gen 21)
[20:19:45]
[20:19:46] Assembly optimizations on if available.
[20:19:46] Entering M.D.
[20:19:54] Completed 0 out of 250000 steps (0%)
[20:41:00] Completed 2500 out of 250000 steps (1%)
[21:02:04] Completed 5000 out of 250000 steps (2%)
[21:23:09] Completed 7500 out of 250000 steps (3%)
<clipped>
17:56:58] Completed 237500 out of 250000 steps (95%)
[18:10:03] Completed 240000 out of 250000 steps (96%)
[18:22:42] Completed 242500 out of 250000 steps (97%)
[18:37:56] Completed 245000 out of 250000 steps (98%)
[18:50:16] Completed 247500 out of 250000 steps (99%)
[19:02:46] Completed 250000 out of 250000 steps (100%)
[19:02:55] DynamicWrapper: Finished Work Unit: sleep=10000
[19:03:05]
[19:03:05] Finished Work Unit:
[19:03:05] - Reading up to 52713120 from "work/wudata_01.trr": Read 52713120
[19:03:06] trr file hash check passed.
[19:03:06] - Reading up to 47102480 from "work/wudata_01.xtc": Read 47102480
[19:03:06] xtc file hash check passed.
[19:03:06] edr file hash check passed.
[19:03:06] logfile size: 213578
[19:03:06] Leaving Run
[19:03:08] - Writing 100200154 bytes of core data to disk...
[19:03:10] ... Done.
[19:04:16] - Shutting down core
[19:04:16]
[19:04:16] Folding@home Core Shutdown: FINISHED_UNIT
[19:04:26] CoreStatus = 64 (100)
[19:04:26] Sending work to server
[19:04:26] Project: 2686 (Run 9, Clone 2, Gen 21)
[19:04:26] + Attempting to send results [September 18 19:04:26 UTC]
[19:06:51] + Results successfully sent
[19:06:51] Thank you for your contribution to Folding@Home.
[20:19:40]
[20:19:41]
[20:19:45]
[20:19:45]
<clipped>
[19:03:05]
[19:04:16]
Re: Project: 2686 (Run 9, Clone 2, Gen 21) missing stats?
I do see a large credit to a nameless folder, Team 0, but nothing with your folding name and team number. Check the part of the log you snipped out. Is it possible the client was shut down in the middle and somehow lost the configuration for your account? If not, I'm at a loss for an explanation.
Hmm, that's odd -- the username line is ommitted before the final run initiates. I didnt' change the config here -- just restarted with -smp 24 added after CTRL-C the prior session.
However, the User ID is the same as specified when the run starts, and all the runs since have the username line present.
[09:31:41] - Ask before connecting: No
[09:31:41] - User ID: 78A00 .... <is it safe adn useful to post the rest of the User ID?
[09:31:41] - Machine ID: 1
[09:31:41]
[09:31:41]
sortofageek wrote:I do see a large credit to a nameless folder, Team 0, but nothing with your folding name and team number. Check the part of the log you snipped out. Is it possible the client was shut down in the middle and somehow lost the configuration for your account? If not, I'm at a loss for an explanation.
Please post all of the log concerning any startups, stops, send, etc. which concern this particular work unit. If we can see the whole thing, perhaps someone can help us understand what happened.
Enclose the log in Code tags to keep the post from being annoyingly long, please.
Below is the full log from this work unit -- this includes the initial session restarting with another work unit (6041), the 2686 unit, and then the start of another work unit (6067). Interestingly, the "User name" line re-appears in the restart of the 6067 unit, but is clearly missing in the final leg of the 2686 unit where it's submitted.
Note the work unit would have been posted from the same IP address as (some of) the other units from me.
I was playing around with the -smp XX count as I was experimenting with GPU folding in parallel. By default, folding on one of two 5970 GPUs itself chews up 50% of one thread/core (I haven't tweaked the env settings yet).
--- Opening Log file [September 16 15:57:23 UTC]
Folding@Home Client Version 6.30
http://folding.stanford.edu
Launch directory: C:\software\smp2
Executable: Folding@home-Win32-x86.exe
Arguments: -smp 12 -bigadv
[15:57:23] - User ID: 78A00BA30E3CA18B
[15:57:23]
[15:57:23] Loaded queue successfully.
[15:57:23]
[15:57:23] + Processing work unit
[15:57:23] Core required: FahCore_a3.exe
[15:57:23] Core found.
[15:57:23] Working on queue slot 00 [September 16 15:57:23 UTC]
[15:57:23] + Working ...
[15:57:23]
[15:57:23] *------------------------------*
[15:57:23] Folding@Home Gromacs SMP Core
[15:57:23] Version 2.22 (Mar 12, 2010)
[15:57:23]
[15:57:23] Preparing to commence simulation
[15:57:23] - Ensuring status. Please wait.
[15:57:33] - Looking at optimizations...
[15:57:33] - Working with standard loops on this execution.
[15:57:33] - Previous termination of core was improper.
[15:57:33] - Going to use standard loops.
[15:57:33] - Files status OK
[15:57:34] - Expanded 7884685 -> 10126021 (decompressed 128.4 percent)
[15:57:34] Called DecompressByteArray: compressed_data_size=7884685 data_size=10126021, decompressed_data_size=10126021 diff=0
[15:57:34] - Digital signature verified
[15:57:34]
[15:57:34] Project: 6041 (Run 0, Clone 183, Gen 49)
[15:57:34]
[15:57:34] Entering M.D.
[15:57:40] Using Gromacs checkpoints
[15:57:42] Resuming from checkpoint
[15:57:42] Verified work/wudata_00.log
[15:57:42] Verified work/wudata_00.trr
[15:57:42] Verified work/wudata_00.xtc
[15:57:42] Verified work/wudata_00.edr
[15:57:43] Completed 139453 out of 250000 steps (55%)
[15:59:05] Completed 140000 out of 250000 steps (56%)
[16:04:56] Completed 142500 out of 250000 steps (57%)
[16:10:46] Completed 145000 out of 250000 steps (58%)
[16:16:37] Completed 147500 out of 250000 steps (59%)
[16:22:30] Completed 150000 out of 250000 steps (60%)
[16:28:21] Completed 152500 out of 250000 steps (61%)
[16:34:12] Completed 155000 out of 250000 steps (62%)
[16:40:03] Completed 157500 out of 250000 steps (63%)
[16:45:54] Completed 160000 out of 250000 steps (64%)
[16:51:45] Completed 162500 out of 250000 steps (65%)
[16:57:35] Completed 165000 out of 250000 steps (66%)
[17:03:26] Completed 167500 out of 250000 steps (67%)
[17:09:16] Completed 170000 out of 250000 steps (68%)
[17:15:07] Completed 172500 out of 250000 steps (69%)
[17:20:58] Completed 175000 out of 250000 steps (70%)
[17:26:48] Completed 177500 out of 250000 steps (71%)
[17:32:39] Completed 180000 out of 250000 steps (72%)
[17:38:30] Completed 182500 out of 250000 steps (73%)
[17:44:20] Completed 185000 out of 250000 steps (74%)
[17:50:11] Completed 187500 out of 250000 steps (75%)
[17:56:02] Completed 190000 out of 250000 steps (76%)
[18:01:53] Completed 192500 out of 250000 steps (77%)
[18:07:44] Completed 195000 out of 250000 steps (78%)
[18:13:36] Completed 197500 out of 250000 steps (79%)
[18:19:27] Completed 200000 out of 250000 steps (80%)
[18:25:18] Completed 202500 out of 250000 steps (81%)
[18:31:11] Completed 205000 out of 250000 steps (82%)
[18:37:02] Completed 207500 out of 250000 steps (83%)
[18:42:54] Completed 210000 out of 250000 steps (84%)
[18:48:45] Completed 212500 out of 250000 steps (85%)
[18:54:36] Completed 215000 out of 250000 steps (86%)
[19:00:28] Completed 217500 out of 250000 steps (87%)
[19:06:19] Completed 220000 out of 250000 steps (88%)
[19:12:11] Completed 222500 out of 250000 steps (89%)
[19:18:02] Completed 225000 out of 250000 steps (90%)
[19:23:52] Completed 227500 out of 250000 steps (91%)
[19:29:43] Completed 230000 out of 250000 steps (92%)
[19:35:33] Completed 232500 out of 250000 steps (93%)
[19:41:23] Completed 235000 out of 250000 steps (94%)
[19:47:13] Completed 237500 out of 250000 steps (95%)
[19:53:02] Completed 240000 out of 250000 steps (96%)
[19:58:53] Completed 242500 out of 250000 steps (97%)
[20:04:42] Completed 245000 out of 250000 steps (98%)
[20:10:32] Completed 247500 out of 250000 steps (99%)
[20:16:22] Completed 250000 out of 250000 steps (100%)
[20:16:25] DynamicWrapper: Finished Work Unit: sleep=10000
[20:16:35]
[20:16:35] Finished Work Unit:
[20:16:35] - Reading up to 31748256 from "work/wudata_00.trr": Read 31748256
[20:16:35] trr file hash check passed.
[20:16:35] - Reading up to 30739616 from "work/wudata_00.xtc": Read 30739616
[20:16:36] xtc file hash check passed.
[20:16:36] edr file hash check passed.
[20:16:36] logfile size: 189002
[20:16:36] Leaving Run
[20:16:37] - Writing 62694758 bytes of core data to disk...
[20:16:38] ... Done.
[20:17:05] - Shutting down core
[20:17:05]
[20:17:05] Folding@home Core Shutdown: FINISHED_UNIT
[20:17:09] CoreStatus = 64 (100)
[20:17:09] Sending work to server
[20:17:09] Project: 6041 (Run 0, Clone 183, Gen 49)
[20:17:09] + Attempting to send results [September 16 20:17:09 UTC]
[20:18:32] + Results successfully sent
[20:18:32] Thank you for your contribution to Folding@Home.
[20:18:32] + Number of Units Completed: 3
[20:18:52] - Preparing to get new work unit...
[20:18:52] Cleaning up work directory
[20:18:52] + Attempting to get work packet
[20:18:52] Passkey found
[20:18:52] - Connecting to assignment server
[20:18:53] - Successful: assigned to (171.64.65.54).
[20:18:53] + News From Folding@Home: Welcome to Folding@Home
[20:18:53] Loaded queue successfully.
[20:18:53] + Could not connect to Work Server
[20:18:53] - Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
[20:19:03] + Attempting to get work packet
[20:19:03] Passkey found
[20:19:03] - Connecting to assignment server
[20:19:03] - Successful: assigned to (171.64.65.54).
[20:19:03] + News From Folding@Home: Welcome to Folding@Home
[20:19:03] Loaded queue successfully.
[20:19:04] + Could not connect to Work Server
[20:19:04] - Attempt #2 to get work failed, and no other work to do.
[20:19:26] + Attempting to get work packet
[20:19:26] Passkey found
[20:19:40]
[20:19:41]
[20:19:41]
[20:19:45]
[20:19:45]
[21:44:12] Completed 10000 out of 250000 steps (4%)
[22:05:17] Completed 12500 out of 250000 steps (5%)
[22:26:22] Completed 15000 out of 250000 steps (6%)
[22:47:26] Completed 17500 out of 250000 steps (7%)
[23:08:31] Completed 20000 out of 250000 steps (8%)
[23:29:35] Completed 22500 out of 250000 steps (9%)
[23:50:39] Completed 25000 out of 250000 steps (10%)
[00:11:43] Completed 27500 out of 250000 steps (11%)
[00:32:47] Completed 30000 out of 250000 steps (12%)
[00:53:52] Completed 32500 out of 250000 steps (13%)
[01:14:57] Completed 35000 out of 250000 steps (14%)
[01:36:04] Completed 37500 out of 250000 steps (15%)
[01:57:08] Completed 40000 out of 250000 steps (16%)
[03:33:11] Completed 42500 out of 250000 steps (17%)
Folding@Home Client Shutdown at user request.
Folding@Home Client Shutdown.
--- Opening Log file [September 17 06:26:25 UTC]
Executable: C:\software\FAH6.30-win32-SMP\Folding@home-Win32-x86.exe
[06:26:25] - Ask before connecting: No
[06:26:25] - User name: sfield (Team 111065)
[06:26:25] - User ID: 78A00BA30E3CA18B
[06:26:25] - Machine ID: 1
[06:26:25]
[06:26:25] Loaded queue successfully.
[06:26:25]
[06:26:25] + Processing work unit
[06:26:25] Core required: FahCore_a3.exe
[06:26:25] Core found.
[06:26:25] Working on queue slot 01 [September 17 06:26:25 UTC]
[06:26:25] + Working ...
[06:26:25]
[06:26:25] *------------------------------*
[06:26:25] Folding@Home Gromacs SMP Core
[06:26:25] Version 2.22 (Mar 12, 2010)
[06:26:25]
[06:26:25] Preparing to commence simulation
[06:26:25] - Ensuring status. Please wait.
--- Opening Log file [September 17 06:26:45 UTC]
Arguments: -smp 24 -bigadv
[06:26:45] - Ask before connecting: No
[06:26:45] - User name: sfield (Team 111065)
[06:26:45] - User ID: 78A00BA30E3CA18B
[06:26:45] - Machine ID: 1
[06:26:45]
[06:26:46] Loaded queue successfully.
[06:26:46]
[06:26:46] + Processing work unit
[06:26:46] Core required: FahCore_a3.exe
[06:26:46] Core found.
[06:26:46] Working on queue slot 01 [September 17 06:26:46 UTC]
[06:26:46] + Working ...
[06:26:46]
[06:26:46] *------------------------------*
[06:26:46] Folding@Home Gromacs SMP Core
[06:26:46] Version 2.22 (Mar 12, 2010)
[06:26:46]
[06:26:46] Preparing to commence simulation
[06:26:46] - Looking at optimizations...
[06:26:46] - Files status OK
[06:26:51] - Expanded 25475500 -> 31941441 (decompressed 125.3 percent)
[06:26:51] Called DecompressByteArray: compressed_data_size=25475500 data_size=31941441, decompressed_data_size=31941441 diff=0
[06:26:51] - Digital signature verified
[06:26:51]
[06:26:51] Project: 2686 (Run 9, Clone 2, Gen 21)
[06:26:51]
[06:26:51] Assembly optimizations on if available.
[06:26:51] Entering M.D.
[06:26:57] Using Gromacs checkpoints
[06:27:04] Resuming from checkpoint
[06:27:06] Verified work/wudata_01.log
[06:27:06] Verified work/wudata_01.trr
[06:27:06] Verified work/wudata_01.xtc
[06:27:06] Verified work/wudata_01.edr
[06:27:07] Completed 42390 out of 250000 steps (16%)
[06:27:48] Completed 42500 out of 250000 steps (17%)
[06:41:18] Completed 45000 out of 250000 steps (18%)
[06:58:26] Completed 47500 out of 250000 steps (19%)
[07:24:38] Completed 50000 out of 250000 steps (20%)
--- Opening Log file [September 17 07:37:03 UTC]
[07:37:03] - Ask before connecting: No
[07:37:03] - User name: sfield (Team 111065)
[07:37:03] - User ID: 78A00BA30E3CA18B
[07:37:03] - Machine ID: 1
[07:37:03]
[07:37:03] Loaded queue successfully.
[07:37:03]
[07:37:03] + Processing work unit
[07:37:03] Core required: FahCore_a3.exe
[07:37:03] Core found.
[07:37:03] Working on queue slot 01 [September 17 07:37:03 UTC]
[07:37:03] + Working ...
[07:37:03]
[07:37:03] *------------------------------*
[07:37:03] Folding@Home Gromacs SMP Core
[07:37:03] Version 2.22 (Mar 12, 2010)
[07:37:03]
[07:37:03] Preparing to commence simulation
[07:37:03] - Ensuring status. Please wait.
[07:37:13] - Looking at optimizations...
[07:37:13] - Working with standard loops on this execution.
[07:37:13] - Previous termination of core was improper.
[07:37:13] - Files status OK
[07:37:19] - Expanded 25475500 -> 31941441 (decompressed 125.3 percent)
[07:37:19] Called DecompressByteArray: compressed_data_size=25475500 data_size=31941441, decompressed_data_size=31941441 diff=0
[07:37:19] - Digital signature verified
[07:37:19]
[07:37:19] Project: 2686 (Run 9, Clone 2, Gen 21)
[07:37:19]
[07:37:19] Entering M.D.
[07:37:25] Using Gromacs checkpoints
[07:37:33] Resuming from checkpoint
[07:37:33] Verified work/wudata_01.log
[07:37:33] Verified work/wudata_01.trr
[07:37:34] Verified work/wudata_01.xtc
[07:37:34] Verified work/wudata_01.edr
[07:37:34] Completed 50265 out of 250000 steps (20%)
[07:56:06] Completed 52500 out of 250000 steps (21%)
[08:16:46] Completed 55000 out of 250000 steps (22%)
[08:37:26] Completed 57500 out of 250000 steps (23%)
[08:58:08] Completed 60000 out of 250000 steps (24%)
[09:18:48] Completed 62500 out of 250000 steps (25%)
[09:39:28] Completed 65000 out of 250000 steps (26%)
[10:00:06] Completed 67500 out of 250000 steps (27%)
[10:20:43] Completed 70000 out of 250000 steps (28%)
[10:41:22] Completed 72500 out of 250000 steps (29%)
[11:02:00] Completed 75000 out of 250000 steps (30%)
[11:22:39] Completed 77500 out of 250000 steps (31%)
[11:43:17] Completed 80000 out of 250000 steps (32%)
[12:03:54] Completed 82500 out of 250000 steps (33%)
[12:24:32] Completed 85000 out of 250000 steps (34%)
[12:45:10] Completed 87500 out of 250000 steps (35%)
[13:05:47] Completed 90000 out of 250000 steps (36%)
[13:26:26] Completed 92500 out of 250000 steps (37%)
[13:47:03] Completed 95000 out of 250000 steps (38%)
[14:07:42] Completed 97500 out of 250000 steps (39%)
[14:28:20] Completed 100000 out of 250000 steps (40%)
[14:48:58] Completed 102500 out of 250000 steps (41%)
[15:09:40] Completed 105000 out of 250000 steps (42%)
[15:30:33] Completed 107500 out of 250000 steps (43%)
--- Opening Log file [September 18 02:04:25 UTC]
[02:04:25] - Ask before connecting: No
[02:04:25] - User ID: 78A00BA30E3CA18B
[02:04:25] - Machine ID: 1
[02:04:25]
[02:04:25] Loaded queue successfully.
[02:04:25]
[02:04:25] + Processing work unit
[02:04:25] Core required: FahCore_a3.exe
[02:04:25] Core found.
[02:04:25] Working on queue slot 01 [September 18 02:04:25 UTC]
[02:04:25] + Working ...
[02:04:25]
[02:04:25] *------------------------------*
[02:04:25] Folding@Home Gromacs SMP Core
[02:04:25] Version 2.22 (Mar 12, 2010)
[02:04:25]
[02:04:25] Preparing to commence simulation
[02:04:25] - Ensuring status. Please wait.
[02:04:35] - Looking at optimizations...
[02:04:35] - Working with standard loops on this execution.
[02:04:35] - Previous termination of core was improper.
[02:04:35] - Going to use standard loops.
[02:04:35] - Files status OK
[02:04:39] - Expanded 25475500 -> 31941441 (decompressed 125.3 percent)
[02:04:39] Called DecompressByteArray: compressed_data_size=25475500 data_size=31941441, decompressed_data_size=31941441 diff=0
[02:04:39] - Digital signature verified
[02:04:39]
[02:04:39] Project: 2686 (Run 9, Clone 2, Gen 21)
[02:04:39]
[02:04:40] Entering M.D.
[02:04:46] Using Gromacs checkpoints
[02:04:55] Resuming from checkpoint
[02:04:56] Verified work/wudata_01.log
[02:04:56] Verified work/wudata_01.trr
[02:04:56] Verified work/wudata_01.xtc
[02:04:56] Verified work/wudata_01.edr
[02:04:56] Completed 108335 out of 250000 steps (43%)
[02:13:37] Completed 110000 out of 250000 steps (44%)
[02:25:42] Completed 112500 out of 250000 steps (45%)
[02:37:47] Completed 115000 out of 250000 steps (46%)
[02:50:09] Completed 117500 out of 250000 steps (47%)
--- Opening Log file [September 18 03:09:16 UTC]
[03:09:16] - Ask before connecting: No
[03:09:16] - User ID: 78A00BA30E3CA18B
[03:09:16] - Machine ID: 1
[03:09:16]
[03:09:16] Loaded queue successfully.
[03:09:16]
[03:09:16] + Processing work unit
[03:09:16] Core required: FahCore_a3.exe
[03:09:16] Core found.
[03:09:16] Working on queue slot 01 [September 18 03:09:16 UTC]
[03:09:16] + Working ...
[03:09:16]
[03:09:16] *------------------------------*
[03:09:16] Folding@Home Gromacs SMP Core
[03:09:16] Version 2.22 (Mar 12, 2010)
[03:09:16]
[03:09:16] Preparing to commence simulation
[03:09:16] - Ensuring status. Please wait.
[03:09:26] - Looking at optimizations...
[03:09:26] - Working with standard loops on this execution.
[03:09:26] - Previous termination of core was improper.
[03:09:26] - Going to use standard loops.
[03:09:26] - Files status OK
[03:09:32] - Expanded 25475500 -> 31941441 (decompressed 125.3 percent)
[03:09:32] Called DecompressByteArray: compressed_data_size=25475500 data_size=31941441, decompressed_data_size=31941441 diff=0
[03:09:32] - Digital signature verified
[03:09:32]
[03:09:32] Project: 2686 (Run 9, Clone 2, Gen 21)
[03:09:32]
[03:09:32] Entering M.D.
[03:09:38] Using Gromacs checkpoints
[03:09:46] Resuming from checkpoint
[03:09:48] Verified work/wudata_01.log
[03:09:48] Verified work/wudata_01.trr
[03:09:48] Verified work/wudata_01.xtc
[03:09:48] Verified work/wudata_01.edr
[03:09:48] Completed 117455 out of 250000 steps (46%)
[03:10:04] Completed 117500 out of 250000 steps (47%)
[03:23:51] Completed 120000 out of 250000 steps (48%)
[03:37:34] Completed 122500 out of 250000 steps (49%)
--- Opening Log file [September 18 04:47:28 UTC]
[04:47:28] - Ask before connecting: No
[04:47:28] - User ID: 78A00BA30E3CA18B
[04:47:28] - Machine ID: 1
[04:47:28]
[04:47:28] Loaded queue successfully.
[04:47:28]
[04:47:28] + Processing work unit
[04:47:28] Core required: FahCore_a3.exe
[04:47:28] Core found.
[04:47:28] Working on queue slot 01 [September 18 04:47:28 UTC]
[04:47:28] + Working ...
[04:47:28]
[04:47:28] *------------------------------*
[04:47:28] Folding@Home Gromacs SMP Core
[04:47:28] Version 2.22 (Mar 12, 2010)
[04:47:28]
[04:47:28] Preparing to commence simulation
[04:47:28] - Ensuring status. Please wait.
[04:47:38] - Looking at optimizations...
[04:47:38] - Working with standard loops on this execution.
[04:47:38] - Previous termination of core was improper.
[04:47:38] - Going to use standard loops.
[04:47:38] - Files status OK
[04:47:42] - Expanded 25475500 -> 31941441 (decompressed 125.3 percent)
[04:47:42] Called DecompressByteArray: compressed_data_size=25475500 data_size=31941441, decompressed_data_size=31941441 diff=0
[04:47:42] - Digital signature verified
[04:47:42]
[04:47:42] Project: 2686 (Run 9, Clone 2, Gen 21)
[04:47:42]
[04:47:43] Entering M.D.
[04:47:49] Using Gromacs checkpoints
[04:47:58] Resuming from checkpoint
[04:47:58] Verified work/wudata_01.log
[04:47:58] Verified work/wudata_01.trr
[04:47:59] Verified work/wudata_01.xtc
[04:47:59] Verified work/wudata_01.edr
[04:47:59] Completed 122905 out of 250000 steps (49%)
[04:59:21] Completed 125000 out of 250000 steps (50%)
[05:13:25] Completed 127500 out of 250000 steps (51%)
[05:26:53] Completed 130000 out of 250000 steps (52%)
[05:40:20] Completed 132500 out of 250000 steps (53%)
[05:55:02] Completed 135000 out of 250000 steps (54%)
[06:08:46] Completed 137500 out of 250000 steps (55%)
[06:22:23] Completed 140000 out of 250000 steps (56%)
[06:36:07] Completed 142500 out of 250000 steps (57%)
--- Opening Log file [September 18 09:31:41 UTC]
[09:31:41] - User ID: 78A00BA30E3CA18B
[09:31:41]
[09:31:41] Loaded queue successfully.
[09:31:41]
[09:31:41] + Processing work unit
[09:31:41] Core required: FahCore_a3.exe
[09:31:41] Core found.
[09:31:41] Working on queue slot 01 [September 18 09:31:41 UTC]
[09:31:41] + Working ...
[09:31:41]
[09:31:41] *------------------------------*
[09:31:41] Folding@Home Gromacs SMP Core
[09:31:41] Version 2.22 (Mar 12, 2010)
[09:31:41]
[09:31:41] Preparing to commence simulation
[09:31:41] - Ensuring status. Please wait.
[09:31:51] - Looking at optimizations...
[09:31:51] - Working with standard loops on this execution.
[09:31:51] - Previous termination of core was improper.
[09:31:51] - Going to use standard loops.
[09:31:51] - Files status OK
[09:32:00] - Expanded 25475500 -> 31941441 (decompressed 125.3 percent)
[09:32:01] Called DecompressByteArray: compressed_data_size=25475500 data_size=31941441, decompressed_data_size=31941441 diff=0
[09:32:01] - Digital signature verified
[09:32:01]
[09:32:01] Project: 2686 (Run 9, Clone 2, Gen 21)
[09:32:01]
[09:32:01] Entering M.D.
[09:32:07] Using Gromacs checkpoints
[09:32:16] Resuming from checkpoint
[09:32:17] Verified work/wudata_01.log
[09:32:17] Verified work/wudata_01.trr
[09:32:17] Verified work/wudata_01.xtc
[09:32:17] Verified work/wudata_01.edr
[09:32:18] Completed 141935 out of 250000 steps (56%)
[09:35:54] Completed 142500 out of 250000 steps (57%)
[09:51:06] Completed 145000 out of 250000 steps (58%)
[10:05:13] Completed 147500 out of 250000 steps (59%)
[10:19:13] Completed 150000 out of 250000 steps (60%)
[10:33:19] Completed 152500 out of 250000 steps (61%)
[10:47:03] Completed 155000 out of 250000 steps (62%)
[11:01:02] Completed 157500 out of 250000 steps (63%)
[11:14:52] Completed 160000 out of 250000 steps (64%)
[11:28:45] Completed 162500 out of 250000 steps (65%)
[11:42:46] Completed 165000 out of 250000 steps (66%)
[11:56:35] Completed 167500 out of 250000 steps (67%)
[12:10:40] Completed 170000 out of 250000 steps (68%)
[12:24:55] Completed 172500 out of 250000 steps (69%)
[12:38:50] Completed 175000 out of 250000 steps (70%)
[12:52:32] Completed 177500 out of 250000 steps (71%)
[13:06:31] Completed 180000 out of 250000 steps (72%)
[13:20:24] Completed 182500 out of 250000 steps (73%)
[13:34:19] Completed 185000 out of 250000 steps (74%)
[13:48:09] Completed 187500 out of 250000 steps (75%)
[14:01:32] Completed 190000 out of 250000 steps (76%)
[14:13:28] Completed 192500 out of 250000 steps (77%)
[14:25:24] Completed 195000 out of 250000 steps (78%)
[14:37:16] Completed 197500 out of 250000 steps (79%)
[14:49:15] Completed 200000 out of 250000 steps (80%)
[15:01:10] Completed 202500 out of 250000 steps (81%)
[15:13:07] Completed 205000 out of 250000 steps (82%)
[15:25:06] Completed 207500 out of 250000 steps (83%)
[15:37:04] Completed 210000 out of 250000 steps (84%)
[15:49:02] Completed 212500 out of 250000 steps (85%)
[16:01:00] Completed 215000 out of 250000 steps (86%)
[16:12:58] Completed 217500 out of 250000 steps (87%)
[16:24:55] Completed 220000 out of 250000 steps (88%)
[16:36:53] Completed 222500 out of 250000 steps (89%)
[16:49:03] Completed 225000 out of 250000 steps (90%)
[17:02:06] Completed 227500 out of 250000 steps (91%)
[17:14:11] Completed 230000 out of 250000 steps (92%)
[17:26:45] Completed 232500 out of 250000 steps (93%)
[17:44:37] Completed 235000 out of 250000 steps (94%)
[17:56:58] Completed 237500 out of 250000 steps (95%)
[19:03:05]
[19:04:16]
[19:06:51] + Starting local stats count at 1
[19:07:23] - Preparing to get new work unit...
[19:07:23] Cleaning up work directory
[19:07:23] + Attempting to get work packet
[19:07:23] - Connecting to assignment server
[19:07:24] - Successful: assigned to (171.64.65.54).
[19:07:24] + News From Folding@Home: Welcome to Folding@Home
[19:07:24] Loaded queue successfully.
[19:07:25] + Closed connections
[19:07:25]
[19:07:25] + Processing work unit
[19:07:25] Core required: FahCore_a3.exe
[19:07:25] Core found.
[19:07:25] Working on queue slot 02 [September 18 19:07:25 UTC]
[19:07:25] + Working ...
[19:07:25]
[19:07:25] *------------------------------*
[19:07:25] Folding@Home Gromacs SMP Core
[19:07:25] Version 2.22 (Mar 12, 2010)
[19:07:25]
[19:07:25] Preparing to commence simulation
[19:07:25] - Looking at optimizations...
[19:07:25] - Created dyn
[19:07:25] - Files status OK
[19:07:26] - Expanded 1765266 -> 2251033 (decompressed 127.5 percent)
[19:07:26] Called DecompressByteArray: compressed_data_size=1765266 data_size=2251033, decompressed_data_size=2251033 diff=0
[19:07:26] - Digital signature verified
[19:07:26]
[19:07:26] Project: 6067 (Run 1, Clone 90, Gen 13)
[19:07:26]
[19:07:26] Assembly optimizations on if available.
[19:07:26] Entering M.D.
[19:07:32] Completed 0 out of 500000 steps (0%)
[19:08:37] Completed 5000 out of 500000 steps (1%)
--- Opening Log file [September 18 19:14:38 UTC]
Arguments: -smp 24 -bigadv -forceasm
[19:14:38] - Ask before connecting: No
[19:14:38] - User name: sfield (Team 111065)
[19:14:38] - User ID: 78A00BA30E3CA18B
[19:14:38] - Machine ID: 1
[19:14:38]
[19:14:39] Loaded queue successfully.
[19:14:39]
[19:14:39] + Processing work unit
[19:14:39] Core required: FahCore_a3.exe
[19:14:39] Core found.
[19:14:39] Working on queue slot 02 [September 18 19:14:39 UTC]
[19:14:39] + Working ...
[19:14:39]
[19:14:39] *------------------------------*
[19:14:39] Folding@Home Gromacs SMP Core
[19:14:39] Version 2.22 (Mar 12, 2010)
[19:14:39]
[19:14:39] Preparing to commence simulation
[19:14:39] - Ensuring status. Please wait.
[19:14:48] - Assembly optimizations manually forced on.
[19:14:48] - Not checking prior termination.
[19:14:49] - Expanded 1765266 -> 2251033 (decompressed 127.5 percent)
[19:14:49] Called DecompressByteArray: compressed_data_size=1765266 data_size=2251033, decompressed_data_size=2251033 diff=0
[19:14:49] - Digital signature verified
[19:14:49]
[19:14:49] Project: 6067 (Run 1, Clone 90, Gen 13)
[19:14:49]
[19:14:49] Assembly optimizations on if available.
[19:14:49] Entering M.D.
[19:14:55] Completed 0 out of 500000 steps (0%)
--- Opening Log file [September 18 19:18:50 UTC]
Arguments: -smp 22 -bigadv -forceasm -oneunit
[19:18:50] - Ask before connecting: No
[19:18:50] - User name: sfield (Team 111065)
[19:18:50] - User ID: 78A00BA30E3CA18B
[19:18:50] - Machine ID: 1
[19:18:50]
[19:18:50] Loaded queue successfully.
[19:18:50]
[19:18:50] + Processing work unit
[19:18:50] Core required: FahCore_a3.exe
[19:18:50] Core found.
[19:18:50] Working on queue slot 02 [September 18 19:18:50 UTC]
[19:18:50] + Working ...
[19:18:51]
[19:18:51] *------------------------------*
[19:18:51] Folding@Home Gromacs SMP Core
[19:18:51] Version 2.22 (Mar 12, 2010)
[19:18:51]
[19:18:51] Preparing to commence simulation
[19:18:51] - Ensuring status. Please wait.
[19:19:00] - Assembly optimizations manually forced on.
[19:19:00] - Not checking prior termination.
[19:19:01] - Expanded 1765266 -> 2251033 (decompressed 127.5 percent)
[19:19:01] Called DecompressByteArray: compressed_data_size=1765266 data_size=2251033, decompressed_data_size=2251033 diff=0
[19:19:01] - Digital signature verified
[19:19:01]
[19:19:01] Project: 6067 (Run 1, Clone 90, Gen 13)
Thank you. It is pretty obvious you managed to wipe your user name and team number from the configuration. Several startups show that and the WU returned to Stanford before you put the identifying info back. That's why the credit went to anon/team 0.
Thankfully, you seem to have caught it and fixed the issue before the next WU was complete.
I don't know how you did this. The only time I remember ever losing my user name and team number was during early days folding when I decided to edit the client.cfg file in Notepad and save it as a text file. That will do it.
I don't think I was touching client.cfg at all, so it's not clear how that would have been wiped.
Anyway to get this credit/points? It should be pretty obvious it was from me.
sortofageek wrote:Thank you. It is pretty obvious you managed to wipe your user name and team number from the configuration. Several startups show that and the WU returned to Stanford before you put the identifying info back. That's why the credit went to anon/team 0.
Sorry to say but that won't happen PG will not transfer credits even if the mistake is a genuine one. The only time that I know when PG re-credits is when there is a server fault. That too, it takes a couple of days to do so. The bright side is that you only "lost" 1 WU's credit and was able to fix it before the nest WU.sfield wrote:...Anyway to get this credit/points? It should be pretty obvious it was from me.
If you run two instances of the client in in parallel Bruce has said that this could wipe out username/teamnumber information. Maybe that's what what happened here? You changing -smp in the shortcut and starting a new instance while the old one was still active?
Edit: just trying to explain what might have happened, and also to make sure that you know of this issue so that you will watch out for it in the future
