oneunit parameter not working in 6.30 ?!
kissson
Post by kissson »
\FAH6.30-win32-SMP>Folding@home-Win32-x86.exe -smp 4 -advmethods -oneunit
when I hit enter, it quits unexpectedly
Re: oneunit parameter not working in 6.30 ?!
It's always better to show us the FAHlog ...
But after the WU completed and the results uploaded, the client will wait for user input (which will exit it). This is how -oneunit should work.
kissson
Post by kissson »
[13:46:54] - Ask before connecting: No
[13:46:54] - User name: kissson (Team 0)
[13:46:54] - User ID: 5C74A705B6A2D0B
[13:46:54] - Machine ID: 1
[13:46:54]
[13:46:54] -configonly flag given, so exiting.
C:\Documents and Settings\xxx\Desktop\app\fah\FAH6.30-win32-SMP>Foldin
g@home-Win32-x86.exe -smp 4 -advmethods -oneunit <---------- I hit enter, but it quits, I know what is oneunit, I use it in old version and behaves correctly
lanbrown
Post by lanbrown »
Remove the -oneunit command, let it get a WU, use crtl-c and then add the -oneunit flag. Does it then start?
kissson
Post by kissson »
no
but it should start in the old version
kissson
Post by kissson »
I think the -smp 4 flag breaks the -oneunit
I tried different combination of -smp 4 -advmethods -oneunit , likes -advmethods -oneunit -smp 4 , -oneunit -smp 4 -advmethods , -smp 4 -oneunit -advmethods
but only -advmethods -oneunit , -oneunit -advmethods , -oneunit works @@
without -smp 4 , I have only 2 cores working
lanbrown
Post by lanbrown »
If you just do -smp all the cores should be active. I have never had a client that wouldn't use all the cores when -smp was used.
kissson
Post by kissson »
ok , fixed . I will use -smp rather than -smp 4
only 2 cores? Out of how many total? On what kind of CPU?
kissson
Post by kissson »
in old version -smp 4 works
but now I use -smp instead , then stdout will show "4 cores detected", without -smp, I will not get "4 cores detected", and only 2 cores out of 4 remain working
I am with a athlon II x4 630
lanbrown
Post by lanbrown »
kissson wrote:In old version -smp 4 works
You could go back to it if the new version is causing you issues.
kissson wrote:but now I use -smp instead , then stdout will show "4 cores detected"
That is what is should say. The default is to use all detected cores. if you don't want all cores used, that is where -smp n comes in.
kissson wrote:without -smp, I will not get "4 cores detected", and only 2 cores out of 4 remain working
Without -smp or -smp n then it will act as the uniprocessor client. You must use -smp or -smp n to work on SMP WU's.
kissson
Post by kissson »
still, -smp n like -smp 3 won't work with -oneunit
I need to set the processor affinity
anyway , solved
patonb
Post by patonb »
Um, i used -smp 2 and -oneunit a bunch of times.
Though, i set -smp in the parameters and -oneunit in my shortcut.
Add the flags to the Additional Parameters field, or add them in to a shortcut.
Or when typing this command in on the command line as you did, you will need to enclose the whole thing in quotes. Command lines don't work so well with extra spaces...
C:\Doc & Sets\xxx\Desktop\app\fah\FAH6.30-win32-SMP>"Folding@home-Win32-x86.exe -smp 4 -advmethods -oneunit"
