143.89.28.70
John_Weatherman
Post by John_Weatherman »
Have tried to upload results of Project: 2969 (Run 15, Clone 56, Gen 22) since July 16 to 143.89.28.70 and get following with send all (can get OK with IE to server)
-- Opening Log file [July 20 07:33:45 UTC]
                          http://folding.stanford.edu
Launch directory: E:\Folding6.23
Executable: E:\Folding6.23\Folding@home-Win32-x86.exe
Arguments: -send all -oneunit
[07:33:45] - Ask before connecting: No
[07:33:45] - User name: John_Weatherman (Team 48913)
[07:33:45] - User ID: 56FD91C778A0AD89
[07:33:45] - Machine ID: 1
[07:33:45]
[07:33:45] Loaded queue successfully.
[07:33:45] Attempting to return result(s) to server...
[07:33:45] Project: 2969 (Run 15, Clone 56, Gen 22)
[07:33:45] + Attempting to send results [July 20 07:33:45 UTC]
[07:33:54] - Couldn't send HTTP request to server
[07:33:54] + Could not connect to Work Server (results)
[07:33:54]     (143.89.28.70:8080)
[07:33:54] + Retrying using alternative port
[07:34:04] - Couldn't send HTTP request to server
[07:34:04] + Could not connect to Work Server (results)
[07:34:04]     (143.89.28.70:80)
[07:34:04] - Error: Could not transmit unit 04 (completed July 16) to work server.
[07:34:04] + Attempting to send results [July 20 07:34:04 UTC]
[07:34:14] - Server does not have record of this unit. Will try again later.
[07:34:14]   Could not transmit unit 04 to Collection server; keeping in queue.
[07:34:14] - Failed to send all units to server
Folding@Home Client Shutdown.
Is this to do with the earlier CS problem (have uploaded a completed protomol WU since this one)?
Re: 143.89.28.70
I'm not sure which CS problem you're referring to.
I can't see any obvious reason you can't upload that WU to that server.
The usual suggestions are to reset your router, reboot your machine, and see if anything changes when you restart the client.
Giving those suggestions isn't something that I like to do because they categorically admit that I have no idea what's wrong. Nevertheless, I had it work recently. (Different server, different project, so unrelated). One of my machines has been processing WUs continuously for quite some time without problems. Then I discovered a WU that repeatedly failed to upload -- even though the machine was processing another WU from the same project/sever and no other machine was having problems. I reset my router and it uploaded. Coincidence? Perhaps, but certainly not something with an obvious explanation.
John_Weatherman
Re: 143.89.28.70
Thanks for the tip :) I'll try that and whatever else I can think of.
John_Weatherman
Re: 143.89.28.70
Well, it's still stuck for some reason. If a Mod can check that someone else has returned this, then I can delete it and put it down to experience. :(
Re: 143.89.28.70
Yep.
Hi xxxx (team xxxx),
Your WU (P2969 R15 C56 G22) was added to the stats database on 2010-07-11 18:07:09 for 80.7 points of credit.
lanbrown
143.89.28.70 & 143.89.28.73
Post by lanbrown »
[10:17:50] Folding@home Core Shutdown: FINISHED_UNIT
[10:17:50] CoreStatus = 64 (100)
[10:17:50] Unit 0 finished with 94 percent of time to deadline remaining.
[10:17:50] Updated performance fraction: 0.933051
[10:17:50] Sending work to server
[10:17:50] + Attempting to send results
[10:17:50] - Reading file work/wuresults_00.dat from core
[10:17:50]   (Read 1122425 bytes from disk)
[10:17:50] Connecting to http://143.89.28.70:8080/
[10:17:51] - Couldn't send HTTP request to server
[10:17:51] + Could not connect to Work Server (results)
[10:17:51]     (143.89.28.70:8080)
[10:17:51] - Error: Could not transmit unit 00 (completed July 24) to work server.
[10:17:51] - 1 failed uploads of this unit.
[10:17:51]   Keeping unit 00 in queue.
[10:17:51] Trying to send all finished work units
[10:17:51] + Attempting to send results
[10:17:51] - Reading file work/wuresults_00.dat from core
[10:17:51]   (Read 1122425 bytes from disk)
[10:17:51] Connecting to http://143.89.28.70:8080/
[10:17:51] - 2 failed uploads of this unit.
[10:17:51] Connecting to http://143.89.28.73:8080/
[10:18:03] Posted data.
[10:18:03] Initial: 0000; - Uploaded at ~91 kB/s
[10:18:03] - Averaged speed for that direction ~93 kB/s
[10:18:03] - Server does not have record of this unit. Will try again later.
[10:18:03]   Could not transmit unit 00 to Collection server; keeping in queue.
[10:18:03] + Attempting to send results
[10:18:03] - Reading file work/wuresults_00.dat from core
[10:18:03]   (Read 1122425 bytes from disk)
[10:18:03] Connecting to http://143.89.28.70:8080/
[10:18:03] - Couldn't send HTTP request to server
[10:18:03] + Could not connect to Work Server (results)
[10:18:03]     (143.89.28.70:8080)
[10:18:03] - Error: Could not transmit unit 00 (completed July 24) to work server.
[10:18:03] - 3 failed uploads of this unit.
[10:18:03] Connecting to http://143.89.28.73:8080/
[10:18:14] Posted data.
[10:18:14] Initial: 0000; - Uploaded at ~99 kB/s
[10:18:14] - Averaged speed for that direction ~94 kB/s
[10:18:14] - Server does not have record of this unit. Will try again later.
[10:18:14]   Could not transmit unit 00 to Collection server; keeping in queue.
[10:18:14] + Sent 0 of 2 completed units to the server
[10:18:14] - Preparing to get new work unit...
[10:18:14] + Attempting to get work packet
[10:18:15] - Will indicate memory of 1024 MB.
[10:18:15] - Connecting to assignment server
[10:18:15] Connecting to http://assign.stanford.edu:8080/
[10:18:15] Posted data.
[10:18:15] Initial: AB40; - Successful: assigned to (171.64.65.65).
[10:18:15] + News From Folding@Home: Welcome to Folding@Home
[10:18:15] Loaded queue successfully.
[10:18:15] Connecting to http://171.64.65.65:8080/
[10:18:23] Posted data.
[10:18:23] Initial: 0000; - Receiving payload (expected size: 9250793)
[10:18:37] - Downloaded at ~645 kB/s
[10:18:37] - Averaged speed for that direction ~280 kB/s
[10:18:37] + Received work.
[10:18:38] Trying to send all finished work units
[10:18:38] + Attempting to send results
[10:18:38] - Reading file work/wuresults_00.dat from core
[10:18:38]   (Read 1122425 bytes from disk)
[10:18:38] Connecting to http://143.89.28.70:8080/
[10:18:38] - Couldn't send HTTP request to server
[10:18:38] + Could not connect to Work Server (results)
[10:18:38]     (143.89.28.70:8080)
[10:18:38] - Error: Could not transmit unit 00 (completed July 24) to work server.
[10:18:38] - 4 failed uploads of this unit.
[10:18:38] Connecting to http://143.89.28.73:8080/
[10:18:50] Posted data.
[10:18:50] Initial: 0000; - Uploaded at ~91 kB/s
[10:18:50] - Averaged speed for that direction ~94 kB/s
[10:18:50] - Server does not have record of this unit. Will try again later.
[10:18:50]   Could not transmit unit 00 to Collection server; keeping in queue.
[10:18:50] + Attempting to send results
[10:18:50] - Reading file work/wuresults_00.dat from core
[10:18:50]   (Read 1122425 bytes from disk)
[10:18:50] Connecting to http://143.89.28.70:8080/
[10:18:50] - Couldn't send HTTP request to server
[10:18:50] + Could not connect to Work Server (results)
[10:18:50]     (143.89.28.70:8080)
[10:18:50] - Error: Could not transmit unit 00 (completed July 24) to work server.
[10:18:50] - 5 failed uploads of this unit.
[10:18:50] Connecting to http://143.89.28.73:8080/
[10:19:01] Posted data.
[10:19:01] Initial: 0000; - Uploaded at ~99 kB/s
[10:19:01] - Averaged speed for that direction ~95 kB/s
[10:19:01] - Server does not have record of this unit. Will try again later.
[10:19:01]   Could not transmit unit 00 to Collection server; keeping in queue.
[10:19:01] + Sent 0 of 2 completed units to the server
[10:19:01] + Closed connections
[10:19:01]
Now the WU server is back on-line, but doesn't have a record of the Wu, as does the collection server.
[05:05:19] - Autosending finished units...
[05:05:19] Trying to send all finished work units
[05:05:19] + Attempting to send results
[05:05:19] - Reading file work/wuresults_00.dat from core
[05:05:19]   (Read 1122425 bytes from disk)
[05:05:19] Connecting to http://143.89.28.70:8080/
[05:05:30] Posted data.
[05:05:30] Initial: 0000; - Uploaded at ~99 kB/s
[05:05:30] - Averaged speed for that direction ~95 kB/s
[05:05:30] - Server does not have record of this unit. Will try again later.
[05:05:30] - Error: Could not transmit unit 00 (completed July 24) to work server.
[05:05:30] - 12 failed uploads of this unit.
[05:05:30] + Attempting to send results
[05:05:30] - Reading file work/wuresults_00.dat from core
[05:05:30]   (Read 1122425 bytes from disk)
[05:05:30] Connecting to http://143.89.28.73:8080/
[05:05:42] Posted data.
[05:05:42] Initial: 0000; - Uploaded at ~91 kB/s
[05:05:42] - Averaged speed for that direction ~94 kB/s
[05:05:42] - Server does not have record of this unit. Will try again later.
[05:05:42]   Could not transmit unit 00 to Collection server; keeping in queue.
[05:05:42] + Attempting to send results
[05:05:42] - Reading file work/wuresults_00.dat from core
[05:05:42]   (Read 1122425 bytes from disk)
[05:05:42] Connecting to http://143.89.28.70:8080/
[05:05:54] Posted data.
[05:05:54] Initial: 0000; - Uploaded at ~91 kB/s
[05:05:54] - Averaged speed for that direction ~93 kB/s
[05:05:54] - Server does not have record of this unit. Will try again later.
[05:05:54] - Error: Could not transmit unit 00 (completed July 24) to work server.
[05:05:54] - 13 failed uploads of this unit.
[05:05:54] + Attempting to send results
[05:05:54] - Reading file work/wuresults_00.dat from core
[05:05:54]   (Read 1122425 bytes from disk)
[05:05:54] Connecting to http://143.89.28.73:8080/
[05:06:05] Posted data.
[05:06:05] Initial: 0000; - Uploaded at ~99 kB/s
[05:06:05] - Averaged speed for that direction ~95 kB/s
[05:06:05] - Server does not have record of this unit. Will try again later.
[05:06:05]   Could not transmit unit 00 to Collection server; keeping in queue.
[05:06:05] + Sent 0 of 2 completed units to the server
[05:06:05] - Autosend completed
John_Weatherman
Re: 143.89.28.70
bruce wrote:Yep.
That's why it will not send in the WU - somebody already has! :?
codysluder
Re: 143.89.28.70
Post by codysluder »
John_Weatherman wrote:
bruce wrote:Yep.
No. That doesn't explain why you didn't get credit.
When someone fails to return it by the preferred deadline, it is reissued. Then it's not a matter of who finishes first. Both of them can get credit.
The server was definitely messed up and apparently your WU was lost somewhere in that process, but the science moves on, now that somebody has finished it.
lanbrown
Re: 143.89.28.70 & 143.89.28.73
Post by lanbrown »
[10:19:01]
Any status update on this or should I just do a destination NAT and when the assignment server directs me to that server, I WILL choose a server that I WILL USE. I'm sure kasson will absolutely love that.
codysluder
lanbrown wrote:Any status update on this or should I just do a destination NAT and when the assignment server directs me to that server, I WILL choose a server that I WILL USE. I'm sure kasson will absolutely love that.
The server has been fixed. That's the only status update that you'll ever get.
Threaten all you want. Do you really think that Stanford is going to negotiate with terrorists?
Aardvark
Re: 143.89.28.70
Post by Aardvark »
Is the Subject Server functioning? The server_status page seems to indicate things are normal but I get a "Couldn't send HTTP request to server".
[20:38:35] - Error: Attempt #10  to get work failed, and no other work to do.
             Waiting before retry.
[21:21:24] + Attempting to get work packet
[21:21:24] - Will indicate memory of 4294965248 MB.
[21:21:24] - Connecting to assignment server
[21:21:24] Connecting to http://assign.stanford.edu:8080/
[21:21:25] Posted data.
[21:21:25] Initial: 8F59; - Successful: assigned to (143.89.28.70).
[21:21:25] + News From Folding@Home: Welcome to Folding@Home
[21:21:25] Loaded queue successfully.
[21:21:25] Connecting to http://143.89.28.70:8080/
[21:21:26] - Couldn't send HTTP request to server
[21:21:26] + Could not connect to Work Server
[21:21:26] - Error: Attempt #11  to get work failed, and no other work to do.
What is past is prologue!
lanbrown
Post by lanbrown »
Shows what you know; less than an hour later another contributor posts that they ALSO are having issues with that server. Obviously you are 100% wrong, provided nothing and thus shouldn't comment. The server has NOT been fixed.
How am I a terrorist? Because I get to say what projects I VOLUNTEER FOR? It is quite simple, if there is an issue that isn't being addressed for a particular project, why contribute to that project at all?
It is people like YOU that drive people away from here. Don't even bother responding, you are in the bit bucket!!!!!
Aardvark
Re: 143.89.28.70
Post by Aardvark »
The AS Burped and decided to change my assignment to 171.64.65.58 and I got a new WU out of it. You can disregard my entry above.
John_Weatherman
Re: 143.89.28.70
codysluder wrote:No. That doesn't explain why you didn't get credit.
I'm not worried about the points, the reason I posted was that the WU was returned on the 11th by someone, and I downloaded it on the 13th - from my queue info -
Project: 2969 (Run 15, Clone 56, Gen 22), Core: 78
Work server: 143.89.28.70:8080
Collection server: 143.89.28.73
Download date: July 13 11:12:53
Finished date: July 16 12:09:39
Mactin
Re: 143.89.28.70
Post by Mactin »
I have just noticed that I have two WUs with the "Server does not have record of this unit" problem for the past three days.
p2973-r2-c55-g10 :
[18:14:36] - Preparing to get new work unit...
[18:14:36] + Attempting to get work packet
[18:14:36] - Connecting to assignment server
[18:14:37] - Successful: assigned to (143.89.28.70).
[18:14:37] + News From Folding@Home: Welcome to Folding@Home
[18:14:37] Loaded queue successfully.
[18:14:42] + Closed connections
[18:14:42]
[18:14:42] + Processing work unit
[18:14:42] Core required: FahCore_78.exe
[18:14:42] Core found.
[18:14:42] Working on queue slot 04 [July 23 18:14:42 UTC]
[18:14:42] + Working ...
[18:14:42]
[18:14:42] *------------------------------*
[18:14:42] Folding@Home Gromacs Core
[18:14:42] Version 1.90 (March 8, 2006)
[18:14:42]
[18:14:42] Preparing to commence simulation
[18:14:42] - Looking at optimizations...
[18:14:42] - Created dyn
[18:14:42] - Files status OK
[18:14:43] - Expanded 269654 -> 1308560 (decompressed 485.2 percent)
[18:14:43] - Starting from initial work packet
[18:14:43]
[18:14:43] Project: 2973 (Run 2, Clone 55, Gen 10)
[18:14:43]
[18:14:43] Assembly optimizations on if available.
[18:14:43] Entering M.D.
[18:14:49] Protein: Protein
[18:14:49]
[18:14:49] Writing local files
[18:14:49] Extra SSE boost OK.
[18:14:49] Completed 0 out of 2500000 steps  (0%)
[18:25:42] Writing local files
[18:25:42] Completed 25000 out of 2500000 steps  (1%)
[18:36:31] Writing local files
[18:36:31] Completed 50000 out of 2500000 steps  (2%)
[18:47:20] Writing local files
[18:47:20] Completed 75000 out of 2500000 steps  (3%)
[12:19:07] Writing local files
[12:19:07] Completed 2450000 out of 2500000 steps  (98%)
[12:30:01] Writing local files
[12:30:01] Completed 2475000 out of 2500000 steps  (99%)
[12:40:50] Writing local files
[12:40:50] Completed 2500000 out of 2500000 steps  (100%)
[12:40:50] Writing final coordinates.
[12:40:50] Past main M.D. loop
[12:41:50]
[12:41:50] Finished Work Unit:
[12:41:50] - Reading up to 215904 from "work/wudata_04.arc": Read 215904
[12:41:50] - Reading up to 916592 from "work/wudata_04.xtc": Read 916592
[12:41:50] goefile size: 0
[12:41:50] Leaving Run
[12:41:55] - Writing 1199852 bytes of core data to disk...
[12:41:55] Done: 1199340 -> 1122387 (compressed to 93.5 percent)
[12:41:55]   ... Done.
[12:41:55] - Shutting down core
[12:41:55]
[12:41:55] Folding@home Core Shutdown: FINISHED_UNIT
[12:42:00] CoreStatus = 64 (100)
[12:42:00] Sending work to server
[12:42:00] Project: 2973 (Run 2, Clone 55, Gen 10)
[12:42:00] + Attempting to send results [July 24 12:42:00 UTC]
[12:42:02] - Couldn't send HTTP request to server
[12:42:02] + Could not connect to Work Server (results)
[12:42:02]     (143.89.28.70:8080)
[12:42:02] + Retrying using alternative port
[12:42:03] - Couldn't send HTTP request to server
[12:42:03] + Could not connect to Work Server (results)
[12:42:03]     (143.89.28.70:80)
[12:42:03] - Error: Could not transmit unit 04 (completed July 24) to work server.
[12:42:03]   Keeping unit 04 in queue.
[12:42:03] Project: 2973 (Run 2, Clone 55, Gen 10)
[12:42:03] + Attempting to send results [July 24 12:42:03 UTC]
[12:42:05] - Couldn't send HTTP request to server
[12:42:05] + Could not connect to Work Server (results)
[12:42:05]     (143.89.28.70:8080)
[12:42:05] + Retrying using alternative port
[12:42:08] - Couldn't send HTTP request to server
[12:42:08] + Could not connect to Work Server (results)
[12:42:08]     (143.89.28.70:80)
[12:42:08] - Error: Could not transmit unit 04 (completed July 24) to work server.
[12:42:08] + Attempting to send results [July 24 12:42:08 UTC]
[12:42:16] - Server does not have record of this unit. Will try again later.
[12:42:16]   Could not transmit unit 04 to Collection server; keeping in queue.
[12:42:16] - Preparing to get new work unit...
[12:42:16] + Attempting to get work packet
[12:42:16] - Connecting to assignment server
[12:42:16] - Successful: assigned to (134.139.127.32).
[12:42:16] + News From Folding@Home: Welcome to Folding@Home
[12:42:17] Loaded queue successfully.
[12:42:24] Project: 2973 (Run 2, Clone 55, Gen 10)
[12:42:24] + Attempting to send results [July 24 12:42:24 UTC]
[12:42:26] - Couldn't send HTTP request to server
[12:42:26] + Could not connect to Work Server (results)
[12:42:26]     (143.89.28.70:8080)
[12:42:26] + Retrying using alternative port
[12:42:28] - Couldn't send HTTP request to server
[12:42:28] + Could not connect to Work Server (results)
[12:42:28]     (143.89.28.70:80)
[12:42:28] - Error: Could not transmit unit 04 (completed July 24) to work server.
[12:42:28] + Attempting to send results [July 24 12:42:28 UTC]
[12:42:34] - Server does not have record of this unit. Will try again later.
[12:42:34]   Could not transmit unit 04 to Collection server; keeping in queue.
[12:42:34] + Closed connections
p2969-r10-c64-g8
[16:58:59] - Preparing to get new work unit...
[16:58:59] + Attempting to get work packet
[16:58:59] - Connecting to assignment server
[16:59:00] - Successful: assigned to (143.89.28.70).
[16:59:00] + News From Folding@Home: Welcome to Folding@Home
[16:59:00] Loaded queue successfully.
[16:59:03] + Closed connections
[16:59:03]
[16:59:03] + Processing work unit
[16:59:03] Core required: FahCore_78.exe
[16:59:03] Core found.
[16:59:03] Working on queue slot 09 [July 22 16:59:03 UTC]
[16:59:03] + Working ...
[16:59:03]
[16:59:03] *------------------------------*
[16:59:03] Folding@Home Gromacs Core
[16:59:03] Version 1.90 (March 8, 2006)
[16:59:03]
[16:59:03] Preparing to commence simulation
[16:59:03] - Looking at optimizations...
[16:59:03] - Created dyn
[16:59:03] - Files status OK
[16:59:04] - Expanded 270561 -> 1308560 (decompressed 483.6 percent)
[16:59:04] - Starting from initial work packet
[16:59:04]
[16:59:04] Project: 2969 (Run 10, Clone 64, Gen 8)
[16:59:04]
[16:59:04] Assembly optimizations on if available.
[16:59:04] Entering M.D.
[16:59:10] Protein: Protein
[16:59:10]
[16:59:10] Writing local files
[16:59:10] Extra SSE boost OK.
[16:59:10] Completed 0 out of 2500000 steps  (0%)
[17:10:00] Writing local files
[17:10:00] Completed 25000 out of 2500000 steps  (1%)
[17:20:52] Writing local files
[17:20:52] Completed 50000 out of 2500000 steps  (2%)
[17:31:53] Writing local files
[17:31:53] Completed 75000 out of 2500000 steps  (3%)
[20:59:00] Writing local files
[20:59:00] Completed 2475000 out of 2500000 steps  (99%)
[21:21:15] Writing local files
[21:21:15] Completed 2500000 out of 2500000 steps  (100%)
[21:21:15] Writing final coordinates.
[21:21:16] Past main M.D. loop
[21:22:16]
[21:22:16] Finished Work Unit:
[21:22:16] - Reading up to 215904 from "work/wudata_09.arc": Read 215904
[21:22:16] - Reading up to 919984 from "work/wudata_09.xtc": Read 919984
[21:22:16] goefile size: 0
[21:22:16] Leaving Run
[21:22:17] - Writing 1203900 bytes of core data to disk...
[21:22:18] Done: 1203388 -> 1124865 (compressed to 93.4 percent)
[21:22:18]   ... Done.
[21:22:18] - Shutting down core
[21:22:18]
[21:22:18] Folding@home Core Shutdown: FINISHED_UNIT
[21:22:21] CoreStatus = 64 (100)
[21:22:21] Sending work to server
[21:22:21] Project: 2969 (Run 10, Clone 64, Gen 8)
[21:22:21] + Attempting to send results [July 24 21:22:21 UTC]
[21:22:31] - Server does not have record of this unit. Will try again later.
[21:22:31] - Error: Could not transmit unit 09 (completed July 24) to work server.
[21:22:31]   Keeping unit 09 in queue.
[21:22:31] Project: 2969 (Run 10, Clone 64, Gen 8)
Every 6 hours, the clients try to send the results back, unsuccesfully.
I dont care about the 162 points. Well ..., not really, but not much.
I mostly care about fixing the problem for those who realy do.
