2 wu EUE after start [P4608 / 4610]
vmzy
Post by vmzy »
received 2 WU EUE after start.
[13:24:51] - Preparing to get new work unit...
[13:24:51] + Attempting to get work packet
[13:24:51] - Connecting to assignment server
[13:24:53] - Successful: assigned to (169.230.26.30).
[13:24:53] + News From Folding@Home: Welcome to Folding@Home
[13:24:53] Loaded queue successfully.
[13:25:04] + Closed connections
[13:25:04]
[13:25:04] + Processing work unit
[13:25:04] Core required: FahCore_82.exe
[13:25:04] Core found.
[13:25:04] Working on queue slot 07 [June 15 13:25:04 UTC]
[13:25:04] + Working ...
[13:25:05]
[13:25:05] *------------------------------*
[13:25:05] Folding@Home PMD Core
[13:25:05] Version 1.03 (September 7, 2005)
[13:25:05]
[13:25:05] Preparing to commence simulation
[13:25:05] - Assembly optimizations manually forced on.
[13:25:05] - Not checking prior termination.
[13:25:05] - Expanded 23238 -> 146268 (decompressed 629.4 percent)
[13:25:05]
[13:25:05] Project: 4608 (Run 1, Clone 173, Gen 70)
[13:25:05]
[13:25:05] Assembly optimizations on if available.
[13:25:05] Entering M.D.
[13:25:11] Going to send back what have done.
[13:25:11] logfile size: 5649
[13:25:11] - Writing 6169 bytes of core data to disk...
[13:25:11]   ... Done.
[13:25:11]
[13:25:11] Folding@home Core Shutdown: EARLY_UNIT_END
[13:25:15] CoreStatus = 72 (114)
[13:25:15] Sending work to server
[13:25:15] Project: 4608 (Run 1, Clone 173, Gen 70)
[13:25:15] + Attempting to send results [June 15 13:25:15 UTC]
[13:25:19] + Results successfully sent
[13:25:19] Thank you for your contribution to Folding@Home.
[13:25:23] - Preparing to get new work unit...
[13:25:23] + Attempting to get work packet
[13:25:23] - Connecting to assignment server
[13:25:27] - Successful: assigned to (169.230.26.30).
[13:25:27] + News From Folding@Home: Welcome to Folding@Home
[13:25:27] Loaded queue successfully.
[13:25:30] + Closed connections
[13:25:35]
[13:25:35] + Processing work unit
[13:25:35] Core required: FahCore_82.exe
[13:25:35] Core found.
[13:25:35] Working on queue slot 08 [June 15 13:25:35 UTC]
[13:25:35] + Working ...
[13:25:35]
[13:25:35] *------------------------------*
[13:25:35] Folding@Home PMD Core
[13:25:35] Version 1.03 (September 7, 2005)
[13:25:35]
[13:25:35] Preparing to commence simulation
[13:25:35] - Assembly optimizations manually forced on.
[13:25:35] - Not checking prior termination.
[13:25:35] - Expanded 9099 -> 60509 (decompressed 665.0 percent)
[13:25:35]
[13:25:35] Project: 4610 (Run 46, Clone 131, Gen 84)
[13:25:35]
[13:25:35] Assembly optimizations on if available.
[13:25:35] Entering M.D.
[13:25:41] Going to send back what have done.
[13:25:41] logfile size: 5649
[13:25:41] - Writing 6169 bytes of core data to disk...
[13:25:41]   ... Done.
[13:25:41]
[13:25:41] Folding@home Core Shutdown: EARLY_UNIT_END
[13:25:45] CoreStatus = 72 (114)
[13:25:45] Sending work to server
[13:25:45] Project: 4610 (Run 46, Clone 131, Gen 84)
[13:25:45] + Attempting to send results [June 15 13:25:45 UTC]
[13:25:46] + Results successfully sent
[13:25:46] Thank you for your contribution to Folding@Home.
Re: 2 wu EUE after start
I reported both WUs.
