Could not connect to 171.67.108.22 ?
slugbug
Hardware configuration: Gigabyte P35-DS3L|Intel Q6600@3.0ghz|Galaxy 8800GT 512mb|2x1gb Buffalo Firestix DDR2 800
171.67.108.22 unable to connect to Work server
Post by slugbug »
http://171.67.108.25:8080 shows OK but my -bigadv client shows:
Couldn't send HTTP request to server
[02:36:54] + Could not connect to Work Server (results)
[02:36:54]     (171.67.108.22:80)
[02:36:54] - Error: Could not transmit unit 09 (completed May 1) to work server.
[02:36:54] + Attempting to send results [May 1 02:36:54 UTC]
[02:36:54] - Couldn't send HTTP request to server
[02:36:54]     (171.67.108.25:8080)
[02:36:54] + Retrying using alternative port
[02:36:54]     (171.67.108.25:80)
[02:36:54]   Could not transmit unit 09 to Collection server; keeping in queue.
[03:04:10
Re: 171.67.108.25 unable to connect to Work server
Actually, server 171.67.108.25 is a Collection Server (see the next few lines) and we need to focus our attention on the actual Work Server, which is 171.67.108.22. It seems to be working normally. Are you able to open http://171.67.108.22 and/or http://171.67.108.22:8080 in your browser?
I'll edit your title to say .22.
bogmali
Re: 171.67.108.22 unable to connect to Work server
Post by bogmali »
Hey Bruce......Everytime I finish a unit and when it pulls the next one I cannot connect and submit results.
Folding@home Client Log:
--- Opening Log file [May 15 06:15:06 UTC]
# Linux SMP Console Edition ###################################################
Folding@Home Client Version 6.29
http://folding.stanford.edu
Launch directory: /usr/local/fah
Executable: ./fah6
Arguments: -bigadv -oneunit -verbosity 7 -smp 8
[06:15:06] - Ask before connecting: No
[06:15:06] - Proxy: localhost:8080
[06:15:06] - User name: ChimPowerUp (Team 50711)
[06:15:06] - User ID: 22B5741C4721E1B3
[06:15:06] - Machine ID: 1
[06:15:06]
[06:15:06] Loaded queue successfully.
[06:15:06] Deleting incompletely fetched item (4) from queue position #8
[06:15:06] - Warning: Could not delete all work unit files (8): Core file absent
[06:15:06] - Preparing to get new work unit...
[06:15:06] Cleaning up work directory
[06:15:06] - Autosending finished units... [May 15 06:15:06 UTC]
[06:15:06] Trying to send all finished work units
[06:15:06] Project: 2682 (Run 1, Clone 23, Gen 14)
[06:15:06] + Attempting to send results [May 15 06:15:06 UTC]
[06:15:06] + Attempting to get work packet
[06:15:06] Passkey found
[06:15:06] (Read 67846144 bytes from disk)
[06:15:06] Connecting to http://171.67.108.22:8080/
[06:15:06] - Couldn't send HTTP request to server
[06:15:06] + Could not connect to Work Server (results)
[06:15:06] (171.67.108.22:8080)
[06:15:06] + Retrying using alternative port
[06:15:06] Connecting to http://171.67.108.22:80/
[06:15:06] - Will indicate memory of 4661 MB
[06:15:06] - Connecting to assignment server
[06:15:06] Connecting to http://assign.stanford.edu:8080/
[06:15:06] (171.67.108.22:80)
[06:15:06] - Error: Could not transmit unit 07 (completed May 14) to work server.
[06:15:06] Connecting to http://171.67.108.25:8080/
[06:15:07] - Couldn't send HTTP request to server
[06:15:07] + Could not connect to Work Server (results)
[06:15:07] (171.67.108.25:8080)
[06:15:07] + Retrying using alternative port
[06:15:07] Connecting to http://171.67.108.25:80/
[06:15:07] (171.67.108.25:80)
[06:15:07] Could not transmit unit 07 to Collection server; keeping in queue.
[06:15:07] + Sent 0 of 1 completed units to the server
[06:15:07] - Autosend completed
[06:15:07] - Successful: assigned to (171.67.108.22).
[06:15:07] + News From Folding@Home: Welcome to Folding@Home
[06:15:07] Loaded queue successfully.
[06:15:07] Connecting to http://171.67.108.22:8080/
[06:16:21] + Could not get Work unit data from Work Server
[06:16:21] - Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
[06:16:41] + Attempting to get work packet
[06:16:41] Passkey found
[06:16:41] - Will indicate memory of 4661 MB
[06:16:41] - Connecting to assignment server
[06:16:41] Connecting to http://assign.stanford.edu:8080/
[06:16:42] - Successful: assigned to (171.67.108.22).
[06:16:42] + News From Folding@Home: Welcome to Folding@Home
[06:16:43] Loaded queue successfully.
[06:16:43] Connecting to http://171.67.108.22:8080/
[06:18:50] - Downloaded at ~348 kB/s
[06:18:50] - Averaged speed for that direction ~746 kB/s
[06:18:50] + Received work.
[06:18:50] - Attempt #2 to get work failed, and no other work to do.
[06:19:04] + Attempting to get work packet
[06:19:04] Passkey found
[06:19:04] - Will indicate memory of 4661 MB
[06:19:04] - Connecting to assignment server
[06:19:04] Connecting to http://assign.stanford.edu:8080/
[06:19:05] - Successful: assigned to (171.67.108.22).
[06:19:05] + News From Folding@Home: Welcome to Folding@Home
[06:19:05] Loaded queue successfully.
[06:19:05] Connecting to http://171.67.108.22:8080/
[06:21:12] - Downloaded at ~352 kB/s
[06:21:12] - Averaged speed for that direction ~667 kB/s
[06:21:12] + Received work.
[06:21:12] - Attempt #3 to get work failed, and no other work to do.
[06:21:36] + Attempting to get work packet
[06:21:36] Passkey found
[06:21:36] - Will indicate memory of 4661 MB
[06:21:36] - Connecting to assignment server
[06:21:36] Connecting to http://assign.stanford.edu:8080/
[06:21:38] - Successful: assigned to (171.67.108.22).
[06:21:38] + News From Folding@Home: Welcome to Folding@Home
[06:21:38] Loaded queue successfully.
[06:21:38] Connecting to http://171.67.108.22:8080/
[06:23:24] - Downloaded at ~448 kB/s
[06:23:24] - Averaged speed for that direction ~623 kB/s
[06:23:24] + Received work.
[06:23:24] - Attempt #4 to get work failed, and no other work to do.
[06:24:06] + Attempting to get work packet
[06:24:06] Passkey found
[06:24:06] - Will indicate memory of 4661 MB
[06:24:06] - Connecting to assignment server
[06:24:06] Connecting to http://assign.stanford.edu:8080/
[06:24:10] - Successful: assigned to (171.67.108.22).
[06:24:10] + News From Folding@Home: Welcome to Folding@Home
[06:24:10] Loaded queue successfully.
[06:24:10] Connecting to http://171.67.108.22:8080/
[06:25:58] - Downloaded at ~477 kB/s
[06:25:58] - Averaged speed for that direction ~594 kB/s
[06:25:58] + Received work.
[06:25:58] - Attempt #5 to get work failed, and no other work to do.
[06:27:23] + Attempting to get work packet
[06:27:23] Passkey found
[06:27:23] - Will indicate memory of 4661 MB
[06:27:23] - Connecting to assignment server
[06:27:23] Connecting to http://assign.stanford.edu:8080/
[06:27:26] - Successful: assigned to (171.67.108.22).
[06:27:26] + News From Folding@Home: Welcome to Folding@Home
[06:27:26] Loaded queue successfully.
[06:27:26] Connecting to http://171.67.108.22:8080/
[06:29:05] - Downloaded at ~527 kB/s
[06:29:05] - Averaged speed for that direction ~581 kB/s
[06:29:05] + Received work.
[06:29:05] - Attempt #6 to get work failed, and no other work to do.
[06:31:52] + Attempting to get work packet
[06:31:52] Passkey found
[06:31:52] - Will indicate memory of 4661 MB
[06:31:52] - Connecting to assignment server
[06:31:52] Connecting to http://assign.stanford.edu:8080/
[06:31:55] - Successful: assigned to (171.67.108.22).
[06:31:55] + News From Folding@Home: Welcome to Folding@Home
[06:31:55] Loaded queue successfully.
[06:31:55] Connecting to http://171.67.108.22:8080/
[06:33:35] - Downloaded at ~502 kB/s
[06:33:35] - Averaged speed for that direction ~565 kB/s
[06:33:35] + Received work.
[06:33:35] - Attempt #7 to get work failed, and no other work to do.
[06:38:57] + Attempting to get work packet
[06:38:57] Passkey found
[06:38:57] - Will indicate memory of 4661 MB
[06:38:57] - Connecting to assignment server
[06:38:57] Connecting to http://assign.stanford.edu:8080/
[06:38:57] - Successful: assigned to (171.67.108.22).
[06:38:57] + News From Folding@Home: Welcome to Folding@Home
[06:38:57] Loaded queue successfully.
[06:38:57] Connecting to http://171.67.108.22:8080/
[06:40:26] - Downloaded at ~630 kB/s
[06:40:26] - Averaged speed for that direction ~578 kB/s
[06:40:26] + Received work.
[06:40:26] - Attempt #8 to get work failed, and no other work to do.
[06:51:07] + Attempting to get work packet
[06:51:07] Passkey found
[06:51:07] - Will indicate memory of 4661 MB
[06:51:07] - Connecting to assignment server
[06:51:07] Connecting to http://assign.stanford.edu:8080/
[06:51:07] - Successful: assigned to (171.67.108.22).
[06:51:07] + News From Folding@Home: Welcome to Folding@Home
[06:51:07] Loaded queue successfully.
[06:51:07] Connecting to http://171.67.108.22:8080/
[06:52:24] - Downloaded at ~740 kB/s
[06:52:24] - Averaged speed for that direction ~610 kB/s
[06:52:24] + Received work.
[06:52:24] - Attempt #9 to get work failed, and no other work to do.
[07:13:51] + Attempting to get work packet
[07:13:51] Passkey found
[07:13:51] - Will indicate memory of 4661 MB
[07:13:51] - Connecting to assignment server
[07:13:51] Connecting to http://assign.stanford.edu:8080/
[07:13:51] - Successful: assigned to (171.67.108.22).
[07:13:51] + News From Folding@Home: Welcome to Folding@Home
[07:13:51] Loaded queue successfully.
[07:13:51] Connecting to http://171.67.108.22:8080/
[07:15:11] - Downloaded at ~705 kB/s
[07:15:11] - Averaged speed for that direction ~629 kB/s
[07:15:11] + Received work.
[07:15:11] - Attempt #10 to get work failed, and no other work to do.
[07:58:05] + Attempting to get work packet
[07:58:05] Passkey found
[07:58:05] - Will indicate memory of 4661 MB
[07:58:05] - Connecting to assignment server
[07:58:05] Connecting to http://assign.stanford.edu:8080/
[07:58:05] - Successful: assigned to (171.67.108.22).
[07:58:05] + News From Folding@Home: Welcome to Folding@Home
[07:58:05] Loaded queue successfully.
[07:58:05] Connecting to http://171.67.108.22:8080/
[07:59:14] - Downloaded at ~1054 kB/s
[07:59:14] - Averaged speed for that direction ~714 kB/s
[07:59:14] + Received work.
[07:59:14] - Attempt #11 to get work failed, and no other work to do.
[08:47:26] + Attempting to get work packet
[08:47:26] Passkey found
[08:47:26] - Will indicate memory of 4661 MB
[08:47:26] - Connecting to assignment server
[08:47:26] Connecting to http://assign.stanford.edu:8080/
[08:47:26] - Successful: assigned to (171.67.108.22).
[08:47:26] + News From Folding@Home: Welcome to Folding@Home
[08:47:26] Loaded queue successfully.
[08:47:26] Connecting to http://171.67.108.22:8080/
[08:48:33] - Downloaded at ~984 kB/s
[08:48:33] - Averaged speed for that direction ~768 kB/s
[08:48:33] + Received work.
[08:48:33] - Attempt #12 to get work failed, and no other work to do.
[09:36:44] + Attempting to get work packet
[09:36:44] Passkey found
[09:36:44] - Will indicate memory of 4661 MB
[09:36:44] - Connecting to assignment server
[09:36:44] Connecting to http://assign.stanford.edu:8080/
[09:36:44] - Successful: assigned to (171.67.108.22).
[09:36:44] + News From Folding@Home: Welcome to Folding@Home
[09:36:44] Loaded queue successfully.
[09:36:44] Connecting to http://171.67.108.22:8080/
[09:37:53] - Downloaded at ~1018 kB/s
[09:37:53] - Averaged speed for that direction ~818 kB/s
[09:37:53] + Received work.
[09:37:53] - Attempt #13 to get work failed, and no other work to do.
[10:26:06] + Attempting to get work packet
[10:26:06] Passkey found
[10:26:06] - Will indicate memory of 4661 MB
[10:26:06] - Connecting to assignment server
[10:26:06] Connecting to http://assign.stanford.edu:8080/
[10:26:07] - Successful: assigned to (171.67.108.22).
[10:26:07] + News From Folding@Home: Welcome to Folding@Home
[10:26:07] Loaded queue successfully.
[10:26:07] Connecting to http://171.67.108.22:8080/
[10:27:19] - Downloaded at ~955 kB/s
[10:27:19] - Averaged speed for that direction ~845 kB/s
[10:27:19] + Received work.
[10:27:19] - Attempt #14 to get work failed, and no other work to do.
[11:15:31] + Attempting to get work packet
[11:15:31] Passkey found
[11:15:31] - Will indicate memory of 4661 MB
[11:15:31] - Connecting to assignment server
[11:15:31] Connecting to http://assign.stanford.edu:8080/
[11:15:31] - Successful: assigned to (171.67.108.22).
[11:15:31] + News From Folding@Home: Welcome to Folding@Home
[11:15:31] Loaded queue successfully.
[11:15:31] Connecting to http://171.67.108.22:8080/
[11:16:42] - Downloaded at ~925 kB/s
[11:16:42] - Averaged speed for that direction ~861 kB/s
[11:16:42] + Received work.
[11:16:42] - Attempt #15 to get work failed, and no other work to do.
[12:04:48] + Attempting to get work packet
[12:04:48] Passkey found
[12:04:48] - Will indicate memory of 4661 MB
[12:04:48] - Connecting to assignment server
[12:04:48] Connecting to http://assign.stanford.edu:8080/
[12:04:48] - Successful: assigned to (171.67.108.22).
[12:04:48] + News From Folding@Home: Welcome to Folding@Home
[12:04:48] Loaded queue successfully.
[12:04:48] Connecting to http://171.67.108.22:8080/
[12:05:58] - Downloaded at ~1057 kB/s
[12:05:58] - Averaged speed for that direction ~900 kB/s
[12:05:58] + Received work.
[12:05:58] - Attempt #16 to get work failed, and no other work to do.
[12:15:07] - Autosending finished units... [May 15 12:15:07 UTC]
[12:15:07] Trying to send all finished work units
[12:15:07] Project: 2682 (Run 1, Clone 23, Gen 14)
[12:15:07] + Attempting to send results [May 15 12:15:07 UTC]
[12:15:07] (Read 67846144 bytes from disk)
[12:15:07] Connecting to http://171.67.108.22:8080/
[12:15:07] - Couldn't send HTTP request to server
[12:15:07] + Could not connect to Work Server (results)
[12:15:07] (171.67.108.22:8080)
[12:15:07] + Retrying using alternative port
[12:15:07] Connecting to http://171.67.108.22:80/
[12:15:07] (171.67.108.22:80)
[12:15:07] - Error: Could not transmit unit 07 (completed May 14) to work server.
[12:15:07] Connecting to http://171.67.108.25:8080/
[12:15:07] (171.67.108.25:8080)
[12:15:07] Connecting to http://171.67.108.25:80/
[12:15:07] (171.67.108.25:80)
[12:15:07] Could not transmit unit 07 to Collection server; keeping in queue.
[12:15:07] + Sent 0 of 1 completed units to the server
[12:15:07] - Autosend completed
[12:54:12] + Attempting to get work packet
[12:54:12] Passkey found
[12:54:12] - Will indicate memory of 4661 MB
[12:54:12] - Connecting to assignment server
[12:54:12] Connecting to http://assign.stanford.edu:8080/
[12:54:12] - Successful: assigned to (171.67.108.22).
[12:54:12] + News From Folding@Home: Welcome to Folding@Home
[12:54:12] Loaded queue successfully.
[12:54:12] Connecting to http://171.67.108.22:8080/
[12:55:24] - Downloaded at ~1021 kB/s
[12:55:24] - Averaged speed for that direction ~925 kB/s
[12:55:24] + Received work.
[12:55:24] - Attempt #17 to get work failed, and no other work to do.
[13:43:28] + Attempting to get work packet
[13:43:28] Passkey found
[13:43:28] - Will indicate memory of 4661 MB
[13:43:28] - Connecting to assignment server
[13:43:28] Connecting to http://assign.stanford.edu:8080/
[13:43:28] - Successful: assigned to (171.67.108.22).
[13:43:28] + News From Folding@Home: Welcome to Folding@Home
[13:43:28] Loaded queue successfully.
[13:43:28] Connecting to http://171.67.108.22:8080/
[13:44:39] - Downloaded at ~1057 kB/s
[13:44:39] - Averaged speed for that direction ~951 kB/s
[13:44:39] + Received work.
[13:44:39] - Attempt #18 to get work failed, and no other work to do.
[14:32:42] + Attempting to get work packet
[14:32:42] Passkey found
[14:32:42] - Will indicate memory of 4661 MB
[14:32:42] - Connecting to assignment server
[14:32:42] Connecting to http://assign.stanford.edu:8080/
[14:32:42] - Successful: assigned to (171.67.108.22).
[14:32:42] + News From Folding@Home: Welcome to Folding@Home
[14:32:42] Loaded queue successfully.
[14:32:42] Connecting to http://171.67.108.22:8080/
[14:33:53] - Downloaded at ~1021 kB/s
[14:33:53] - Averaged speed for that direction ~965 kB/s
[14:33:53] + Received work.
[14:33:53] - Attempt #19 to get work failed, and no other work to do.
[15:21:55] + Attempting to get work packet
[15:21:55] Passkey found
[15:21:55] - Will indicate memory of 4661 MB
[15:21:55] - Connecting to assignment server
[15:21:55] Connecting to http://assign.stanford.edu:8080/
[15:21:55] - Successful: assigned to (171.67.108.22).
[15:21:55] + News From Folding@Home: Welcome to Folding@Home
[15:21:55] Loaded queue successfully.
[15:21:55] Connecting to http://171.67.108.22:8080/
[15:23:05] - Downloaded at ~922 kB/s
[15:23:05] - Averaged speed for that direction ~956 kB/s
[15:23:05] + Received work.
[15:23:05] - Attempt #20 to get work failed, and no other work to do.
[16:06:21] ***** Got a SIGTERM signal (15)
Folding@Home Client Shutdown.
:27] - Connecting to assignment server
[15:23:27] - Successful: assigned to (171.67.108.22).
[15:23:27] + News From Folding@Home: Welcome to Folding@Home
[15:23:27] Loaded queue successfully.
[15:24:37] - Attempt #20 to get work failed, and no other work to do.
--- Opening Log file [May 15 16:12:50 UTC]
Executable: ./fah6
[16:12:51] - Ask before connecting: No
[16:12:51] - Proxy: localhost:8080
[16:12:51] - User name: ChimPowerUp (Team 50711)
[16:12:51] - User ID: 22B5741C4721E1B3
[16:12:51] - Machine ID: 1
[16:12:51]
[16:12:51] Loaded queue successfully.
[16:12:51] Deleting incompletely fetched item (4) from queue position #8
[16:12:51] - Warning: Could not delete all work unit files (8): Core file absent
[16:12:51] - Preparing to get new work unit...
[16:12:51] Cleaning up work directory
[16:12:51] - Autosending finished units... [May 15 16:12:51 UTC]
[16:12:51] Trying to send all finished work units
[16:12:51] Project: 2682 (Run 1, Clone 23, Gen 14)
[16:12:51] + Attempting to send results [May 15 16:12:51 UTC]
[16:12:51] + Attempting to get work packet
[16:12:51] Passkey found
[16:12:51] (Read 67846144 bytes from disk)
[16:12:51] Connecting to http://171.67.108.22:8080/
[16:12:51] - Couldn't send HTTP request to server
[16:12:51] + Could not connect to Work Server (results)
[16:12:51] (171.67.108.22:8080)
[16:12:51] + Retrying using alternative port
[16:12:51] Connecting to http://171.67.108.22:80/
[16:12:51] - Will indicate memory of 4661 MB
[16:12:51] - Connecting to assignment server
[16:12:51] Connecting to http://assign.stanford.edu:8080/
[16:12:51] (171.67.108.22:80)
[16:12:51] - Error: Could not transmit unit 07 (completed May 14) to work server.
[16:12:51] Connecting to http://171.67.108.25:8080/
[16:12:51] (171.67.108.25:8080)
[16:12:51] Connecting to http://171.67.108.25:80/
[16:12:51] (171.67.108.25:80)
[16:12:51] Could not transmit unit 07 to Collection server; keeping in queue.
[16:12:51] + Sent 0 of 1 completed units to the server
[16:12:51] - Autosend completed
[16:12:51] - Successful: assigned to (171.67.108.22).
[16:12:51] + News From Folding@Home: Welcome to Folding@Home
[16:13:50] + Could not get Work unit data from Work Server
[16:13:50] - Attempt #1 to get work failed, and no other work to do.
[16:13:58] + Attempting to get work packet
[16:13:58] Passkey found
[16:13:58] - Will indicate memory of 4661 MB
[16:13:58] - Connecting to assignment server
[16:13:58] Connecting to http://assign.stanford.edu:8080/
[16:13:59] - Successful: assigned to (171.67.108.22).
[16:13:59] + News From Folding@Home: Welcome to Folding@Home
[16:13:59] Loaded queue successfully.
[16:13:59] Connecting to http://171.67.108.22:8080/
And here's from my other rig:
--- Opening Log file [May 7 23:36:52 UTC]
Executable: ./fah6
Arguments: -advmethods -smp 7
[23:36:52] - Ask before connecting: No
[23:36:52] - Proxy: localhost:8080
[23:36:52] - User name: ChimPowerUp (Team 50711)
[23:36:52] - User ID: 1346965C3C67B056
[23:36:52] - Machine ID: 1
[23:36:52]
[23:36:52] Loaded queue successfully.
[23:36:52] - Preparing to get new work unit...
[23:36:52] Cleaning up work directory
[23:36:52] + Attempting to get work packet
[23:36:52] Passkey found
[23:36:52] - Connecting to assignment server
[23:36:54] - Successful: assigned to (171.64.65.54).
[23:36:54] + News From Folding@Home: Welcome to Folding@Home
[23:36:54] Loaded queue successfully.
[23:36:58] - Attempt #1 to get work failed, and no other work to do.
[23:37:16] + Attempting to get work packet
[23:37:16] Passkey found
[23:37:16] - Connecting to assignment server
[23:37:17] - Successful: assigned to (171.64.65.54).
[23:37:17] + News From Folding@Home: Welcome to Folding@Home
[23:37:17] Loaded queue successfully.
[23:37:25] - Attempt #2 to get work failed, and no other work to do.
[23:37:45] + Attempting to get work packet
[23:37:45] Passkey found
[23:37:45] - Connecting to assignment server
[23:37:46] - Successful: assigned to (171.64.65.54).
[23:37:46] + News From Folding@Home: Welcome to Folding@Home
[23:37:46] Loaded queue successfully.
[23:37:50] - Attempt #3 to get work failed, and no other work to do.
[23:38:20] + Attempting to get work packet
[23:38:20] Passkey found
[23:38:20] - Connecting to assignment server
[23:38:21] - Successful: assigned to (171.64.65.54).
[23:38:21] + News From Folding@Home: Welcome to Folding@Home
[23:38:22] Loaded queue successfully.
[23:38:26] - Attempt #4 to get work failed, and no other work to do.
[23:39:18] + Attempting to get work packet
[23:39:18] Passkey found
[23:39:18] - Connecting to assignment server
[23:39:19] - Successful: assigned to (171.64.65.54).
[23:39:19] + News From Folding@Home: Welcome to Folding@Home
[23:39:19] Loaded queue successfully.
[23:39:23] - Attempt #5 to get work failed, and no other work to do.
[23:40:57] + Attempting to get work packet
[23:40:57] Passkey found
[23:40:57] - Connecting to assignment server
[23:40:59] - Successful: assigned to (171.64.65.54).
[23:40:59] + News From Folding@Home: Welcome to Folding@Home
[23:40:59] Loaded queue successfully.
[23:41:03] - Attempt #6 to get work failed, and no other work to do.
[23:43:48] + Attempting to get work packet
[23:43:48] Passkey found
[23:43:48] - Connecting to assignment server
[23:43:48] - Successful: assigned to (171.64.65.54).
[23:43:48] + News From Folding@Home: Welcome to Folding@Home
[23:43:48] Loaded queue successfully.
[23:43:49] - Attempt #7 to get work failed, and no other work to do.
[23:49:10] + Attempting to get work packet
[23:49:10] Passkey found
[23:49:10] - Connecting to assignment server
[23:49:10] - Successful: assigned to (171.64.65.54).
[23:49:10] + News From Folding@Home: Welcome to Folding@Home
[23:49:10] Loaded queue successfully.
[23:49:12] - Attempt #8 to get work failed, and no other work to do.
--- Opening Log file [May 7 23:53:41 UTC]
Executable: ./fah6
Arguments: -oneunit -verbosity 7 -smp 8
[23:53:42] - Ask before connecting: No
[23:53:42] - Proxy: localhost:8080
[23:53:42] - User name: ChimPowerUp (Team 50711)
[23:53:42] - User ID: 1346965C3C67B056
[23:53:42] - Machine ID: 1
[23:53:42]
[23:53:42] Loaded queue successfully.
[23:53:42] - Preparing to get new work unit...
[23:53:42] - Autosending finished units... [23:53:42]
[23:53:42] Trying to send all finished work units
[23:53:42] Cleaning up work directory
[23:53:42] + No unsent completed units remaining.
[23:53:42] - Autosend completed
[23:53:42] + Attempting to get work packet
[23:53:42] Passkey found
[23:53:42] - Will indicate memory of 4661 MB
[23:53:42] - Connecting to assignment server
[23:53:42] Connecting to http://assign.stanford.edu:8080/
[23:53:42] - Successful: assigned to (171.64.65.54).
[23:53:42] + News From Folding@Home: Welcome to Folding@Home
[23:53:42] Connecting to http://171.64.65.54:8080/
[23:53:44] - Downloaded at ~1727 kB/s
[23:53:44] - Averaged speed for that direction ~2898 kB/s
[23:53:44] + Received work.
[23:53:44] - Attempt #1 to get work failed, and no other work to do.
[23:53:53] + Attempting to get work packet
[23:53:53] Passkey found
[23:53:53] - Will indicate memory of 4661 MB
[23:53:53] - Connecting to assignment server
[23:53:53] Connecting to http://assign.stanford.edu:8080/
[23:53:53] - Successful: assigned to (171.64.65.54).
[23:53:53] + News From Folding@Home: Welcome to Folding@Home
[23:53:53] Loaded queue successfully.
[23:53:53] Connecting to http://171.64.65.54:8080/
[23:53:55] - Downloaded at ~1727 kB/s
[23:53:55] - Averaged speed for that direction ~2663 kB/s
[23:53:55] + Received work.
[23:53:55] - Attempt #2 to get work failed, and no other work to do.
[23:54:14] + Attempting to get work packet
[23:54:14] Passkey found
[23:54:14] - Will indicate memory of 4661 MB
[23:54:14] - Connecting to assignment server
[23:54:14] Connecting to http://assign.stanford.edu:8080/
[23:54:15] - Successful: assigned to (171.64.65.54).
[23:54:15] + News From Folding@Home: Welcome to Folding@Home
[23:54:15] Loaded queue successfully.
[23:54:15] Connecting to http://171.64.65.54:8080/
[23:54:16] - Error: Bad packet type from server, expected work assignment
[23:54:16] - Attempt #3 to get work failed, and no other work to do.
[23:54:44] + Attempting to get work packet
[23:54:44] Passkey found
[23:54:44] - Will indicate memory of 4661 MB
[23:54:44] - Connecting to assignment server
[23:54:44] Connecting to http://assign.stanford.edu:8080/
[23:54:46] - Successful: assigned to (171.64.65.54).
[23:54:46] + News From Folding@Home: Welcome to Folding@Home
[23:54:46] Loaded queue successfully.
[23:54:46] Connecting to http://171.64.65.54:8080/
[23:54:50] - Downloaded at ~862 kB/s
[23:54:50] - Averaged speed for that direction ~2303 kB/s
[23:54:50] + Received work.
[23:54:50] - Attempt #4 to get work failed, and no other work to do.
[23:55:30] ***** Got a SIGTERM signal (15)
--- Opening Log file [May 7 23:57:10 UTC]
Executable: ./fah6
[23:57:10] - Ask before connecting: No
[23:57:10] - Proxy: localhost:8080
[23:57:10] - User name: ChimPowerUp (Team 50711)
[23:57:10] - User ID: 1346965C3C67B056
[23:57:10] - Machine ID: 1
[23:57:10]
[23:57:10] Loaded queue successfully.
[23:57:10] - Preparing to get new work unit...
[23:57:10] Cleaning up work directory
[23:57:10] - Autosending finished units... [May 7 23:57:10 UTC]
[23:57:10] Trying to send all finished work units
[23:57:10] + No unsent completed units remaining.
[23:57:10] - Autosend completed
[23:57:10] + Attempting to get work packet
[23:57:10] Passkey found
[23:57:10] - Will indicate memory of 4661 MB
[23:57:10] - Connecting to assignment server
[23:57:10] Connecting to http://assign.stanford.edu:8080/
[23:57:10] - Successful: assigned to (171.64.65.54).
[23:57:10] + News From Folding@Home: Welcome to Folding@Home
[23:57:10] Connecting to http://171.64.65.54:8080/
[23:57:12] - Downloaded at ~1724 kB/s
[23:57:12] - Averaged speed for that direction ~2897 kB/s
[23:57:12] + Received work.
[23:57:12] - Attempt #1 to get work failed, and no other work to do.
[23:57:18] + Attempting to get work packet
[23:57:18] Passkey found
[23:57:18] - Will indicate memory of 4661 MB
[23:57:18] - Connecting to assignment server
[23:57:18] Connecting to http://assign.stanford.edu:8080/
[23:57:18] - Successful: assigned to (171.64.65.54).
[23:57:18] + News From Folding@Home: Welcome to Folding@Home
[23:57:18] Loaded queue successfully.
[23:57:18] Connecting to http://171.64.65.54:8080/
[23:57:20] - Downloaded at ~1725 kB/s
[23:57:20] - Averaged speed for that direction ~2663 kB/s
[23:57:20] + Received work.
[23:57:20] - Attempt #2 to get work failed, and no other work to do.
[23:57:31] + Attempting to get work packet
[23:57:31] Passkey found
[23:57:31] - Will indicate memory of 4661 MB
[23:57:31] - Connecting to assignment server
[23:57:31] Connecting to http://assign.stanford.edu:8080/
[23:57:31] - Successful: assigned to (171.64.65.54).
[23:57:31] + News From Folding@Home: Welcome to Folding@Home
[23:57:31] Loaded queue successfully.
[23:57:31] Connecting to http://171.64.65.54:8080/
[23:57:34] - Downloaded at ~862 kB/s
[23:57:34] - Averaged speed for that direction ~2302 kB/s
[23:57:34] + Received work.
[23:57:34] - Attempt #3 to get work failed, and no other work to do.
[23:58:00] + Attempting to get work packet
[23:58:00] Passkey found
[23:58:00] - Will indicate memory of 4661 MB
[23:58:00] - Connecting to assignment server
[23:58:00] Connecting to http://assign.stanford.edu:8080/
[23:58:00] - Successful: assigned to (171.64.65.54).
[23:58:00] + News From Folding@Home: Welcome to Folding@Home
[23:58:00] Loaded queue successfully.
[23:58:00] Connecting to http://171.64.65.54:8080/
[23:58:04] - Downloaded at ~862 kB/s
[23:58:04] - Averaged speed for that direction ~2014 kB/s
[23:58:04] + Received work.
[23:58:04] - Attempt #4 to get work failed, and no other work to do.
[23:58:56] + Attempting to get work packet
[23:58:56] Passkey found
[23:58:56] - Will indicate memory of 4661 MB
[23:58:56] - Connecting to assignment server
[23:58:56] Connecting to http://assign.stanford.edu:8080/
[23:58:57] - Successful: assigned to (171.64.65.54).
[23:58:57] + News From Folding@Home: Welcome to Folding@Home
[23:58:57] Loaded queue successfully.
[23:58:57] Connecting to http://171.64.65.54:8080/
[23:59:02] - Downloaded at ~575 kB/s
[23:59:02] - Averaged speed for that direction ~1726 kB/s
[23:59:02] + Received work.
[23:59:02] - Attempt #5 to get work failed, and no other work to do.
[00:00:33] + Attempting to get work packet
[00:00:33] Passkey found
[00:00:33] - Will indicate memory of 4661 MB
[00:00:33] - Connecting to assignment server
[00:00:33] Connecting to http://assign.stanford.edu:8080/
[00:00:34] - Successful: assigned to (171.64.65.54).
[00:00:34] + News From Folding@Home: Welcome to Folding@Home
[00:00:34] Loaded queue successfully.
[00:00:34] Connecting to http://171.64.65.54:8080/
[00:00:35] - Downloaded at ~1725 kB/s
[00:00:35] - Averaged speed for that direction ~1726 kB/s
[00:00:35] + Received work.
[00:00:35] - Attempt #6 to get work failed, and no other work to do.
[00:03:23] + Attempting to get work packet
[00:03:23] Passkey found
[00:03:23] - Will indicate memory of 4661 MB
[00:03:23] - Connecting to assignment server
[00:03:23] Connecting to http://assign.stanford.edu:8080/
[00:03:24] - Successful: assigned to (171.64.65.54).
[00:03:24] + News From Folding@Home: Welcome to Folding@Home
[00:03:24] Loaded queue successfully.
[00:03:24] Connecting to http://171.64.65.54:8080/
[00:03:25] - Downloaded at ~1725 kB/s
[00:03:25] - Averaged speed for that direction ~1726 kB/s
[00:03:25] + Received work.
[00:03:25] - Attempt #7 to get work failed, and no other work to do.
[00:08:52] + Attempting to get work packet
[00:08:52] Passkey found
[00:08:52] - Will indicate memory of 4661 MB
[00:08:52] - Connecting to assignment server
[00:08:52] Connecting to http://assign.stanford.edu:8080/
[00:08:52] - Successful: assigned to (171.64.65.54).
[00:08:52] + News From Folding@Home: Welcome to Folding@Home
[00:08:53] Loaded queue successfully.
[00:08:53] Connecting to http://171.64.65.54:8080/
[00:08:54] - Downloaded at ~1725 kB/s
[00:08:54] - Averaged speed for that direction ~1725 kB/s
[00:08:54] + Received work.
[00:08:54] - Attempt #8 to get work failed, and no other work to do.
[00:19:38] + Attempting to get work packet
[00:19:38] Passkey found
[00:19:38] - Will indicate memory of 4661 MB
[00:19:38] - Connecting to assignment server
[00:19:38] Connecting to http://assign.stanford.edu:8080/
[00:19:38] - Successful: assigned to (171.64.65.54).
[00:19:38] + News From Folding@Home: Welcome to Folding@Home
[00:19:38] Loaded queue successfully.
[00:19:38] Connecting to http://171.64.65.54:8080/
[00:19:40] - Downloaded at ~1725 kB/s
[00:19:40] - Averaged speed for that direction ~1725 kB/s
[00:19:40] + Received work.
[00:19:40] - Attempt #9 to get work failed, and no other work to do.
--- Opening Log file [May 15 18:49:25 UTC]
Executable: ./fah6
[18:49:25] - Ask before connecting: No
[18:49:25] - Proxy: localhost:8080
[18:49:25] - User name: ChimPowerUp (Team 50711)
[18:49:25] - User ID: 1346965C3C67B056
[18:49:25] - Machine ID: 1
[18:49:25]
[18:49:25] Loaded queue successfully.
[18:49:25] - Preparing to get new work unit...
[18:49:25] - Autosending finished units... [18:49:25]
[18:49:25] Trying to send all finished work units
[18:49:25] + No unsent completed units remaining.
[18:49:25] - Autosend completed
[18:49:25] Cleaning up work directory
[18:49:25] + Attempting to get work packet
[18:49:25] Passkey found
[18:49:25] - Will indicate memory of 4661 MB
[18:49:25] - Connecting to assignment server
[18:49:25] Connecting to http://assign.stanford.edu:8080/
[18:49:25] - Successful: assigned to (171.67.108.22).
[18:49:25] + News From Folding@Home: Welcome to Folding@Home
[18:49:25] Connecting to http://171.67.108.22:8080/
[18:50:12] - Downloaded at ~4921 kB/s
[18:50:12] - Averaged speed for that direction ~3536 kB/s
[18:50:12] + Received work.
[18:50:12] - Attempt #1 to get work failed, and no other work to do.
[18:50:28] + Attempting to get work packet
[18:50:28] Passkey found
[18:50:28] - Will indicate memory of 4661 MB
[18:50:28] - Connecting to assignment server
[18:50:28] Connecting to http://assign.stanford.edu:8080/
[18:50:28] - Successful: assigned to (171.67.108.22).
[18:50:28] + News From Folding@Home: Welcome to Folding@Home
[18:50:28] Loaded queue successfully.
[18:50:28] Connecting to http://171.67.108.22:8080/
--- Opening Log file [May 15 18:50:50 UTC]
Executable: ./fah6
Arguments: -bigadv -smp 7
[18:50:50] - Ask before connecting: No
[18:50:50] - Proxy: localhost:8080
[18:50:50] - User name: ChimPowerUp (Team 50711)
[18:50:50] - User ID: 1346965C3C67B056
[18:50:50] - Machine ID: 1
[18:50:50]
A potential conflict was detected:
Process 972 is currently running and may also be a client with Mach. ID 1.
The program will now exit. Upon restart, this check will not be done --
You may wish to check that no client is currently running in
/usr/local/fah before restarting.
Please press any key to exit.
--- Opening Log file [May 15 18:51:01 UTC]
Executable: ./fah6
[18:51:01] - Ask before connecting: No
[18:51:01] - Proxy: localhost:8080
[18:51:01] - User name: ChimPowerUp (Team 50711)
[18:51:01] - User ID: 1346965C3C67B056
[18:51:01] - Machine ID: 1
[18:51:01]
[18:51:01] Loaded queue successfully.
[18:51:01] - Preparing to get new work unit...
[18:51:01] Cleaning up work directory
[18:51:01] + Attempting to get work packet
[18:51:01] Passkey found
[18:51:01] - Connecting to assignment server
[18:51:01] - Successful: assigned to (171.67.108.22).
[18:51:01] + News From Folding@Home: Welcome to Folding@Home
[18:51:11] - Downloaded at ~4218 kB/s
[18:51:11] - Averaged speed for that direction ~3673 kB/s
[18:51:11] + Received work.
[18:51:11] - Attempt #2 to get work failed, and no other work to do.
[18:51:29] + Attempting to get work packet
[18:51:29] Passkey found
[18:51:29] - Will indicate memory of 4661 MB
[18:51:29] - Connecting to assignment server
[18:51:29] Connecting to http://assign.stanford.edu:8080/
[18:51:29] - Successful: assigned to (171.67.108.22).
[18:51:29] + News From Folding@Home: Welcome to Folding@Home
[18:51:29] Loaded queue successfully.
[18:51:29] Connecting to http://171.67.108.22:8080/
[18:51:30] - Error: Bad packet type from server, expected work assignment
[18:51:30] - Attempt #3 to get work failed, and no other work to do.
[18:51:46] - Attempt #1 to get work failed, and no other work to do.
[18:51:52] + Attempting to get work packet
[18:51:52] Passkey found
[18:51:52] - Connecting to assignment server
[18:51:53] - Successful: assigned to (171.67.108.22).
[18:51:53] + News From Folding@Home: Welcome to Folding@Home
[18:51:53] Loaded queue successfully.
[18:51:54] - Attempt #2 to get work failed, and no other work to do.
[18:52:01] + Attempting to get work packet
[18:52:01] Passkey found
[18:52:01] - Will indicate memory of 4661 MB
[18:52:01] - Connecting to assignment server
[18:52:01] Connecting to http://assign.stanford.edu:8080/
[18:52:01] - Successful: assigned to (171.67.108.22).
[18:52:01] + News From Folding@Home: Welcome to Folding@Home
[18:52:01] Loaded queue successfully.
[18:52:01] Connecting to http://171.67.108.22:8080/
[18:52:02] - Error: Bad packet type from server, expected work assignment
[18:52:02] - Attempt #4 to get work failed, and no other work to do.
[18:52:51] + Attempting to get work packet
[18:52:51] Passkey found
[18:52:51] - Will indicate memory of 4661 MB
[18:52:51] - Connecting to assignment server
[18:52:51] Connecting to http://assign.stanford.edu:8080/
[18:52:51] - Successful: assigned to (171.67.108.22).
[18:52:51] + News From Folding@Home: Welcome to Folding@Home
[18:52:51] Loaded queue successfully.
[18:52:51] Connecting to http://171.67.108.22:8080/
[18:52:52] - Error: Bad packet type from server, expected work assignment
[18:52:52] - Attempt #5 to get work failed, and no other work to do.
[18:53:58] ***** Got a SIGTERM signal (15)
--- Opening Log file [May 15 18:55:49 UTC]
Executable: ./fah6
[18:55:49] - Ask before connecting: No
[18:55:49] - Proxy: localhost:8080
[18:55:49] - User name: ChimPowerUp (Team 50711)
[18:55:49] - User ID: 1346965C3C67B056
[18:55:49] - Machine ID: 1
[18:55:49]
[18:55:49] Loaded queue successfully.
[18:55:49] - Preparing to get new work unit...
[18:55:49] Cleaning up work directory
[18:55:49] - Autosending finished units... [May 15 18:55:49 UTC]
[18:55:49] Trying to send all finished work units
[18:55:49] + No unsent completed units remaining.
[18:55:49] - Autosend completed
[18:55:49] + Attempting to get work packet
[18:55:49] Passkey found
[18:55:49] - Will indicate memory of 4661 MB
[18:55:49] - Connecting to assignment server
[18:55:49] Connecting to http://assign.stanford.edu:8080/
[18:55:49] - Successful: assigned to (171.67.108.22).
[18:55:49] + News From Folding@Home: Welcome to Folding@Home
[18:55:49] Connecting to http://171.67.108.22:8080/
[18:55:50] - Error: Bad packet type from server, expected work assignment
[18:55:50] - Attempt #1 to get work failed, and no other work to do.
[18:56:09] + Attempting to get work packet
[18:56:09] Passkey found
[18:56:09] - Will indicate memory of 4661 MB
[18:56:09] - Connecting to assignment server
[18:56:09] Connecting to http://assign.stanford.edu:8080/
[18:56:09] - Successful: assigned to (171.67.108.22).
[18:56:09] + News From Folding@Home: Welcome to Folding@Home
[18:56:09] Loaded queue successfully.
[18:56:09] Connecting to http://171.67.108.22:8080/
[18:56:10] - Error: Bad packet type from server, expected work assignment
[18:56:10] - Attempt #2 to get work failed, and no other work to do.
[18:56:33] + Attempting to get work packet
[18:56:33] Passkey found
[18:56:33] - Will indicate memory of 4661 MB
[18:56:33] - Connecting to assignment server
[18:56:33] Connecting to http://assign.stanford.edu:8080/
[18:56:33] - Successful: assigned to (171.67.108.22).
[18:56:33] + News From Folding@Home: Welcome to Folding@Home
[18:56:33] Loaded queue successfully.
[18:56:33] Connecting to http://171.67.108.22:8080/
[18:56:34] - Error: Bad packet type from server, expected work assignment
[18:56:34] - Attempt #3 to get work failed, and no other work to do.
[18:56:56] + Attempting to get work packet
[18:56:56] Passkey found
[18:56:56] - Will indicate memory of 4661 MB
[18:56:56] - Connecting to assignment server
[18:56:56] Connecting to http://assign.stanford.edu:8080/
[18:56:56] - Successful: assigned to (171.67.108.22).
[18:56:56] + News From Folding@Home: Welcome to Folding@Home
[18:56:57] Loaded queue successfully.
[18:56:57] Connecting to http://171.67.108.22:8080/
[18:56:57] - Error: Bad packet type from server, expected work assignment
[18:56:57] - Attempt #4 to get work failed, and no other work to do.
[18:57:47] + Attempting to get work packet
[18:57:47] Passkey found
[18:57:47] - Will indicate memory of 4661 MB
[18:57:47] - Connecting to assignment server
[18:57:47] Connecting to http://assign.stanford.edu:8080/
[18:57:47] - Successful: assigned to (171.67.108.22).
[18:57:47] + News From Folding@Home: Welcome to Folding@Home
[18:57:47] Loaded queue successfully.
[18:57:47] Connecting to http://171.67.108.22:8080/
[18:57:48] - Error: Bad packet type from server, expected work assignment
[18:57:48] - Attempt #5 to get work failed, and no other work to do.
[18:59:09] + Attempting to get work packet
[18:59:09] Passkey found
[18:59:09] - Will indicate memory of 4661 MB
[18:59:09] - Connecting to assignment server
[18:59:09] Connecting to http://assign.stanford.edu:8080/
[18:59:09] - Successful: assigned to (171.67.108.22).
[18:59:09] + News From Folding@Home: Welcome to Folding@Home
[18:59:09] Loaded queue successfully.
[18:59:09] Connecting to http://171.67.108.22:8080/
[18:59:10] - Error: Bad packet type from server, expected work assignment
[18:59:10] - Attempt #6 to get work failed, and no other work to do.
[19:01:50] + Attempting to get work packet
[19:01:50] Passkey found
[19:01:50] - Will indicate memory of 4661 MB
[19:01:50] - Connecting to assignment server
[19:01:50] Connecting to http://assign.stanford.edu:8080/
[19:01:50] - Successful: assigned to (171.67.108.22).
[19:01:50] + News From Folding@Home: Welcome to Folding@Home
[19:01:50] Loaded queue successfully.
[19:01:50] Connecting to http://171.67.108.22:8080/
[19:01:51] - Error: Bad packet type from server, expected work assignment
[19:01:51] - Attempt #7 to get work failed, and no other work to do.
--- Opening Log file [May 15 19:04:00 UTC]
Executable: ./fah6
[19:04:00] - Ask before connecting: No
[19:04:01] - Proxy: localhost:8080
[19:04:01] - User name: ChimPowerUp (Team 50711)
[19:04:01] - User ID: 1346965C3C67B056
[19:04:01] - Machine ID: 1
[19:04:01]
Process 943 is currently running and may also be a client with Mach. ID 1.
--- Opening Log file [May 15 19:04:34 UTC]
Executable: ./fah6
[19:04:34] - Ask before connecting: No
[19:04:34] - Proxy: localhost:8080
[19:04:34] - User name: ChimPowerUp (Team 50711)
[19:04:34] - User ID: 1346965C3C67B056
[19:04:34] - Machine ID: 1
[19:04:34]
[19:04:34] Loaded queue successfully.
[19:04:34] - Preparing to get new work unit...
[19:04:34] Cleaning up work directory
[19:04:34] + Attempting to get work packet
[19:04:34] Passkey found
[19:04:34] - Connecting to assignment server
[19:04:34] - Successful: assigned to (171.67.108.22).
[19:04:34] + News From Folding@Home: Welcome to Folding@Home
[19:04:35] - Attempt #1 to get work failed, and no other work to do.
[19:04:52] + Attempting to get work packet
[19:04:52] Passkey found
[19:04:52] - Connecting to assignment server
[19:04:52] - Successful: assigned to (171.67.108.22).
[19:04:52] + News From Folding@Home: Welcome to Folding@Home
[19:04:52] Loaded queue successfully.
[19:04:53] - Attempt #2 to get work failed, and no other work to do.
[19:05:10] + Attempting to get work packet
[19:05:10] Passkey found
[19:05:10] - Connecting to assignment server
[19:05:10] - Successful: assigned to (171.67.108.22).
[19:05:10] + News From Folding@Home: Welcome to Folding@Home
[19:05:10] Loaded queue successfully.
[19:05:11] - Attempt #3 to get work failed, and no other work to do.
[19:05:38] + Attempting to get work packet
[19:05:38] Passkey found
[19:05:38] - Connecting to assignment server
[19:05:38] - Successful: assigned to (171.67.108.22).
[19:05:38] + News From Folding@Home: Welcome to Folding@Home
[19:05:38] Loaded queue successfully.
[19:05:39] - Attempt #4 to get work failed, and no other work to do.
[19:06:27] + Attempting to get work packet
[19:06:27] Passkey found
[19:06:27] - Connecting to assignment server
[19:06:27] - Successful: assigned to (171.67.108.22).
[19:06:27] + News From Folding@Home: Welcome to Folding@Home
[19:06:27] Loaded queue successfully.
[19:06:28] - Attempt #5 to get work failed, and no other work to do.
[19:07:15] + Attempting to get work packet
[19:07:15] Passkey found
[19:07:15] - Will indicate memory of 4661 MB
[19:07:15] - Connecting to assignment server
[19:07:15] Connecting to http://assign.stanford.edu:8080/
[19:07:15] - Successful: assigned to (171.67.108.22).
[19:07:15] + News From Folding@Home: Welcome to Folding@Home
[19:07:15] Loaded queue successfully.
[19:07:15] Connecting to http://171.67.108.22:8080/
[19:07:16] - Error: Bad packet type from server, expected work assignment
[19:07:16] - Attempt #8 to get work failed, and no other work to do.
[19:09:04] ***** Got a SIGTERM signal (15)
--- Opening Log file [May 15 19:12:03 UTC]
Executable: ./fah6
[19:12:03] - Ask before connecting: No
[19:12:03] - Proxy: localhost:8080
[19:12:03] - User name: ChimPowerUp (Team 50711)
[19:12:03] - User ID: 1346965C3C67B056
[19:12:03] - Machine ID: 1
[19:12:03]
[19:12:03] Loaded queue successfully.
[19:12:03] - Preparing to get new work unit...
[19:12:03] Cleaning up work directory
[19:12:03] + Attempting to get work packet
[19:12:03] Passkey found
[19:12:03] - Will indicate memory of 4661 MB
[19:12:03] - Connecting to assignment server
[19:12:03] Connecting to http://assign.stanford.edu:8080/
[19:12:03] - Autosending finished units... [May 15 19:12:03 UTC]
[19:12:03] Trying to send all finished work units
[19:12:03] + No unsent completed units remaining.
[19:12:03] - Autosend completed
[19:12:03] - Successful: assigned to (171.67.108.22).
[19:12:03] + News From Folding@Home: Welcome to Folding@Home
[19:12:03] Connecting to http://171.67.108.22:8080/
[19:12:04] - Error: Bad packet type from server, expected work assignment
[19:12:04] - Attempt #1 to get work failed, and no other work to do.
[19:12:12] + Attempting to get work packet
[19:12:12] Passkey found
[19:12:12] - Will indicate memory of 4661 MB
[19:12:12] - Connecting to assignment server
[19:12:12] Connecting to http://assign.stanford.edu:8080/
[19:12:12] - Successful: assigned to (171.67.108.22).
[19:12:12] + News From Folding@Home: Welcome to Folding@Home
[19:12:12] Loaded queue successfully.
[19:12:12] Connecting to http://171.67.108.22:8080/
[19:12:13] - Error: Bad packet type from server, expected work assignment
[19:12:13] - Attempt #2 to get work failed, and no other work to do.
[19:12:31] + Attempting to get work packet
[19:12:31] Passkey found
[19:12:31] - Will indicate memory of 4661 MB
[19:12:31] - Connecting to assignment server
[19:12:31] Connecting to http://assign.stanford.edu:8080/
[19:12:31] - Successful: assigned to (171.67.108.22).
[19:12:31] + News From Folding@Home: Welcome to Folding@Home
[19:12:31] Loaded queue successfully.
[19:12:31] Connecting to http://171.67.108.22:8080/
[19:12:32] - Error: Bad packet type from server, expected work assignment
[19:12:32] - Attempt #3 to get work failed, and no other work to do.
[19:12:57] + Attempting to get work packet
[19:12:57] Passkey found
[19:12:57] - Will indicate memory of 4661 MB
[19:12:57] - Connecting to assignment server
[19:12:57] Connecting to http://assign.stanford.edu:8080/
[19:12:58] - Successful: assigned to (171.67.108.22).
[19:12:58] + News From Folding@Home: Welcome to Folding@Home
[19:12:58] Loaded queue successfully.
[19:12:58] Connecting to http://171.67.108.22:8080/
[19:12:58] - Error: Bad packet type from server, expected work assignment
[19:12:58] - Attempt #4 to get work failed, and no other work to do.
--- Opening Log file [May 15 19:13:00 UTC]
Executable: ./fah6
[19:13:00] - Ask before connecting: No
[19:13:00] - Proxy: localhost:8080
[19:13:00] - User name: ChimPowerUp (Team 50711)
[19:13:00] - User ID: 1346965C3C67B056
[19:13:00] - Machine ID: 1
[19:13:00]
Process 964 is currently running and may also be a client with Mach. ID 1.
--- Opening Log file [May 15 19:13:15 UTC]
Executable: ./fah6
[19:13:15] - Ask before connecting: No
[19:13:15] - Proxy: localhost:8080
[19:13:15] - User name: ChimPowerUp (Team 50711)
[19:13:15] - User ID: 1346965C3C67B056
[19:13:15] - Machine ID: 1
[19:13:15]
[19:13:16] Loaded queue successfully.
[19:13:16] - Preparing to get new work unit...
[19:13:16] Cleaning up work directory
[19:13:16] + Attempting to get work packet
[19:13:16] Passkey found
[19:13:16] - Connecting to assignment server
[19:13:16] - Successful: assigned to (171.67.108.22).
[19:13:16] + News From Folding@Home: Welcome to Folding@Home
[19:13:17] - Attempt #1 to get work failed, and no other work to do.
[19:13:23] + Attempting to get work packet
[19:13:23] Passkey found
[19:13:23] - Connecting to assignment server
[19:13:23] - Successful: assigned to (171.67.108.22).
[19:13:23] + News From Folding@Home: Welcome to Folding@Home
[19:13:23] Loaded queue successfully.
[19:13:24] - Attempt #2 to get work failed, and no other work to do.
[19:13:35] + Attempting to get work packet
[19:13:35] Passkey found
[19:13:35] - Connecting to assignment server
[19:13:36] - Successful: assigned to (171.67.108.22).
[19:13:36] + News From Folding@Home: Welcome to Folding@Home
[19:13:36] Loaded queue successfully.
[19:13:37] - Attempt #3 to get work failed, and no other work to do.
klasseng
Hardware configuration: System 1: Mac Studio, M1 Max,
System 2: Mac Mini, M2
Post by klasseng »
I'm getting:
[13:09:41] Connecting to http://171.67.108.22:8080/
[13:09:41] Posted data.
[13:09:41] Initial: 0000; - Error: Bad packet type from server, expected work assignment
[13:09:42] - Attempt #4 to get work failed, and no other work to do.
peace,
Grant
bollix47
Post by bollix47 »
Receiving the same message here so I switched from -bigadv to -advmethods until the problem is sorted. Only getting around half the PPD but better than nothing. :wink:
@ bollix47 and klasseng:
What OS and what client experienced this problem?
klasseng
Post by klasseng »
Mac OSX 10.6
FAH 6.29
peace,
Grant
bollix47
Post by bollix47 »
Linux - Ubuntu 8.04
Client - 6.29
Setup has been running -bigadv since they became available on this i7 920 with 6 gig of ram.
Launch directory: /home/bollix/fah/smp
Executable: ./fah6
Arguments: -bigadv -smp 7 -verbosity 9
[00:42:11] - Ask before connecting: No
[00:42:11] - User name: bollix47 (Team 39340)
[00:42:11] - User ID: XXXXXXXXXXXXXXXX
[00:42:11] - Machine ID: 1
[00:42:11]
[00:42:11] Work directory not found. Creating...
[00:42:11] Could not open work queue, generating new queue...
[00:42:11] - Autosending finished units... [May 17 00:42:11 UTC]
[00:42:11] Trying to send all finished work units
[00:42:11] + No unsent completed units remaining.
[00:42:11] - Autosend completed
[00:42:11] - Preparing to get new work unit...
[00:42:11] Cleaning up work directory
[00:42:11] + Attempting to get work packet
[00:42:11] Passkey found
[00:42:11] - Will indicate memory of 5966 MB
[00:42:11] - Connecting to assignment server
[00:42:11] Connecting to http://assign.stanford.edu:8080/
[00:42:12] Posted data.
[00:42:12] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[00:42:12] + News From Folding@Home: Welcome to Folding@Home
[00:42:12] Loaded queue successfully.
[00:42:12] Connecting to http://171.67.108.22:8080/
[00:42:12] Initial: 0000; - Error: Bad packet type from server, expected work assignment
[00:42:12] - Attempt #1  to get work failed, and no other work to do.
[00:42:21] + Attempting to get work packet
[00:42:21] Passkey found
[00:42:21] - Will indicate memory of 5966 MB
[00:42:21] - Connecting to assignment server
[00:42:21] Connecting to http://assign.stanford.edu:8080/
[00:42:21] Posted data.
[00:42:21] Initial: 43AB; - Successful: assigned to (171.67.108.22).
[00:42:21] + News From Folding@Home: Welcome to Folding@Home
[00:42:21] Loaded queue successfully.
[00:42:21] Connecting to http://171.67.108.22:8080/
[00:42:22] Posted data.
[00:42:22] Initial: 0000; - Error: Bad packet type from server, expected work assignment
[00:42:22] - Attempt #2  to get work failed, and no other work to do.
kasson
Pande Group Member
Post by kasson »
There's something slightly funny going on with this work server. Most assigns look ok, but some consistently have problems.
We'll look into it.
caintry_boy
Post by caintry_boy »
Has it taken this long to look at the server???
Launch directory: /home/caintry_boy/fah1
Executable: ./fah6
Arguments: -smp 8 -bigadv
[13:22:00] - Ask before connecting: No
[13:22:00] - User name: caintry_boy (Team 32035)
[13:22:00] - User ID: 39DDA196B77E1CD
[13:22:00] - Machine ID: 1
[13:22:00]
[13:22:00] Could not open work queue, generating new queue...
[13:22:00] - Preparing to get new work unit...
[13:22:00] Cleaning up work directory
[13:22:00] + Attempting to get work packet
[13:22:00] Passkey found
[13:22:00] - Connecting to assignment server
[13:22:00] - Successful: assigned to (171.67.108.22).
[13:22:00] + News From Folding@Home: Welcome to Folding@Home
[13:22:00] Loaded queue successfully.
[13:24:35] + Closed connections
[13:24:35]
[13:24:35] + Processing work unit
[13:24:35] Core required: FahCore_a3.exe
[13:24:35] Core not found.
[13:24:35] - Core is not present or corrupted.
[13:24:35] - Attempting to download new core...
[13:24:35] + Downloading new core: FahCore_a3.exe
[13:24:36] + 10240 bytes downloaded
[13:24:36] + 20480 bytes downloaded
[13:24:36] + 30720 bytes downloaded
[13:24:37] + 40960 bytes downloaded
[13:24:37] + 51200 bytes downloaded
[13:24:37] + 61440 bytes downloaded
[13:24:37] + 71680 bytes downloaded
[13:24:37] + 81920 bytes downloaded
[13:24:37] + 92160 bytes downloaded
[13:24:37] + 102400 bytes downloaded
[13:24:37] + 112640 bytes downloaded
[13:24:37] + 122880 bytes downloaded
[13:24:37] + 133120 bytes downloaded
[13:24:37] + 143360 bytes downloaded
[13:24:37] + 153600 bytes downloaded
[13:24:37] + 163840 bytes downloaded
[13:24:38] + 174080 bytes downloaded
[13:24:38] + 184320 bytes downloaded
[13:24:38] + 194560 bytes downloaded
[13:24:38] + 204800 bytes downloaded
[13:24:38] + 215040 bytes downloaded
[13:24:38] + 225280 bytes downloaded
[13:24:38] + 235520 bytes downloaded
[13:24:38] + 245760 bytes downloaded
[13:24:38] + 256000 bytes downloaded
[13:24:38] + 266240 bytes downloaded
[13:24:38] + 276480 bytes downloaded
[13:24:38] + 286720 bytes downloaded
[13:24:38] + 296960 bytes downloaded
[13:24:38] + 307200 bytes downloaded
[13:24:38] + 317440 bytes downloaded
[13:24:38] + 327680 bytes downloaded
[13:24:38] + 337920 bytes downloaded
[13:24:38] + 348160 bytes downloaded
[13:24:38] + 358400 bytes downloaded
[13:24:38] + 368640 bytes downloaded
[13:24:38] + 378880 bytes downloaded
[13:24:39] + 389120 bytes downloaded
[13:24:39] + 399360 bytes downloaded
[13:24:39] + 409600 bytes downloaded
[13:24:39] + 419840 bytes downloaded
[13:24:39] + 430080 bytes downloaded
[13:24:39] + 440320 bytes downloaded
[13:24:39] + 450560 bytes downloaded
[13:24:39] + 460800 bytes downloaded
[13:24:39] + 471040 bytes downloaded
[13:24:39] + 481280 bytes downloaded
[13:24:39] + 491520 bytes downloaded
[13:24:39] + 501760 bytes downloaded
[13:24:39] + 512000 bytes downloaded
[13:24:39] + 522240 bytes downloaded
[13:24:39] + 532480 bytes downloaded
[13:24:40] + 542720 bytes downloaded
[13:24:40] + 552960 bytes downloaded
[13:24:40] + 563200 bytes downloaded
[13:24:40] + 573440 bytes downloaded
[13:24:40] + 583680 bytes downloaded
[13:24:40] + 593920 bytes downloaded
[13:24:40] + 604160 bytes downloaded
[13:24:40] + 614400 bytes downloaded
[13:24:40] + 624640 bytes downloaded
[13:24:40] + 634880 bytes downloaded
[13:24:40] + 645120 bytes downloaded
[13:24:40] + 655360 bytes downloaded
[13:24:40] + 665600 bytes downloaded
[13:24:41] + 675840 bytes downloaded
[13:24:41] + 686080 bytes downloaded
[13:24:41] + 696320 bytes downloaded
[13:24:41] + 706560 bytes downloaded
[13:24:41] + 716800 bytes downloaded
[13:24:41] + 727040 bytes downloaded
[13:24:41] + 737280 bytes downloaded
[13:24:41] + 747520 bytes downloaded
[13:24:41] + 757760 bytes downloaded
[13:24:41] + 768000 bytes downloaded
[13:24:41] + 778240 bytes downloaded
[13:24:41] + 788480 bytes downloaded
[13:24:41] + 798720 bytes downloaded
[13:24:41] + 808960 bytes downloaded
[13:24:42] + 819200 bytes downloaded
[13:24:42] + 829440 bytes downloaded
[13:24:42] + 839680 bytes downloaded
[13:24:42] + 849920 bytes downloaded
[13:24:42] + 860160 bytes downloaded
[13:24:42] + 870400 bytes downloaded
[13:24:42] + 880640 bytes downloaded
[13:24:42] + 890880 bytes downloaded
[13:24:42] + 901120 bytes downloaded
[13:24:42] + 911360 bytes downloaded
[13:24:42] + 921600 bytes downloaded
[13:24:42] + 931840 bytes downloaded
[13:24:42] + 942080 bytes downloaded
[13:24:42] + 952320 bytes downloaded
[13:24:42] + 962560 bytes downloaded
[13:24:43] + 972800 bytes downloaded
[13:24:43] + 983040 bytes downloaded
[13:24:43] + 993280 bytes downloaded
[13:24:43] + 1003520 bytes downloaded
[13:24:43] + 1013760 bytes downloaded
[13:24:43] + 1024000 bytes downloaded
[13:24:43] + 1034240 bytes downloaded
[13:24:43] + 1044480 bytes downloaded
[13:24:43] + 1054720 bytes downloaded
[13:24:43] + 1064960 bytes downloaded
[13:24:43] + 1075200 bytes downloaded
[13:24:43] + 1085440 bytes downloaded
[13:24:43] + 1095680 bytes downloaded
[13:24:43] + 1105920 bytes downloaded
[13:24:44] + 1116160 bytes downloaded
[13:24:44] + 1126400 bytes downloaded
[13:24:44] + 1136640 bytes downloaded
[13:24:44] + 1146880 bytes downloaded
[13:24:44] + 1157120 bytes downloaded
[13:24:44] + 1167360 bytes downloaded
[13:24:44] + 1177600 bytes downloaded
[13:24:44] + 1187840 bytes downloaded
[13:24:44] + 1198080 bytes downloaded
[13:24:44] + 1208320 bytes downloaded
[13:24:44] + 1218560 bytes downloaded
[13:24:44] + 1228800 bytes downloaded
[13:24:44] + 1239040 bytes downloaded
[13:24:45] + 1249280 bytes downloaded
[13:24:45] + 1259520 bytes downloaded
[13:24:45] + 1269760 bytes downloaded
[13:24:45] + 1280000 bytes downloaded
[13:24:45] + 1290240 bytes downloaded
[13:24:45] + 1300480 bytes downloaded
[13:24:45] + 1310720 bytes downloaded
[13:24:45] + 1320960 bytes downloaded
[13:24:45] + 1331200 bytes downloaded
[13:24:45] + 1341440 bytes downloaded
[13:24:45] + 1351680 bytes downloaded
[13:24:45] + 1361920 bytes downloaded
[13:24:45] + 1372160 bytes downloaded
[13:24:45] + 1382400 bytes downloaded
[13:24:46] + 1392640 bytes downloaded
[13:24:46] + 1402880 bytes downloaded
[13:24:46] + 1413120 bytes downloaded
[13:24:46] + 1423360 bytes downloaded
[13:24:46] + 1433600 bytes downloaded
[13:24:46] + 1443840 bytes downloaded
[13:24:46] + 1454080 bytes downloaded
[13:24:46] + 1464320 bytes downloaded
[13:24:46] + 1474560 bytes downloaded
[13:24:46] + 1484800 bytes downloaded
[13:24:46] + 1495040 bytes downloaded
[13:24:46] + 1505280 bytes downloaded
[13:24:46] + 1515520 bytes downloaded
[13:24:46] + 1525760 bytes downloaded
[13:24:47] + 1536000 bytes downloaded
[13:24:47] + 1546240 bytes downloaded
[13:24:47] + 1556480 bytes downloaded
[13:24:47] + 1566720 bytes downloaded
[13:24:47] + 1576960 bytes downloaded
[13:24:47] + 1587200 bytes downloaded
[13:24:47] + 1597440 bytes downloaded
[13:24:47] + 1607680 bytes downloaded
[13:24:47] + 1617920 bytes downloaded
[13:24:47] + 1628160 bytes downloaded
[13:24:47] + 1638400 bytes downloaded
[13:24:47] + 1648640 bytes downloaded
[13:24:47] + 1658880 bytes downloaded
[13:24:48] + 1669120 bytes downloaded
[13:24:48] + 1679360 bytes downloaded
[13:24:48] + 1689600 bytes downloaded
[13:24:48] + 1699840 bytes downloaded
[13:24:48] + 1710080 bytes downloaded
[13:24:48] + 1720320 bytes downloaded
[13:24:48] + 1730560 bytes downloaded
[13:24:48] + 1740800 bytes downloaded
[13:24:48] + 1751040 bytes downloaded
[13:24:48] + 1761280 bytes downloaded
[13:24:48] + 1771520 bytes downloaded
[13:24:48] + 1781760 bytes downloaded
[13:24:48] + 1792000 bytes downloaded
[13:24:48] + 1802240 bytes downloaded
[13:24:48] + 1812480 bytes downloaded
[13:24:49] + 1822720 bytes downloaded
[13:24:49] + 1832960 bytes downloaded
[13:24:49] + 1843200 bytes downloaded
[13:24:49] + 1843342 bytes downloaded
[13:24:49] Verifying core Core_a3.fah...
[13:24:49] Signature is VALID
[13:24:49]
[13:24:49] Trying to unzip core FahCore_a3.exe
[13:24:49] Decompressed FahCore_a3.exe (4375728 bytes) successfully
[13:24:49] + Core successfully engaged
[13:25:06]
[13:25:06] + Processing work unit
[13:25:06] Core required: FahCore_a3.exe
[13:25:06] Core found.
[13:25:06] Working on queue slot 01 [May 29 13:25:06 UTC]
[13:25:06] + Working ...
[13:25:06]
[13:25:06] *------------------------------*
[13:25:06] Folding@Home Gromacs SMP Core
[13:25:06] Version 2.21 (May 10, 2010)
[13:25:06]
[13:25:06] Preparing to commence simulation
[13:25:06] - Looking at optimizations...
[13:25:06] - Created dyn
[13:25:06] - Files status OK
[13:25:08] - Expanded 20075563 -> 30791309 (decompressed 153.3 percent)
[13:25:08] Called DecompressByteArray: compressed_data_size=20075563 data_size=30791309, decompressed_data_size=30791309 diff=0
[13:25:08] - Digital signature verified
[13:25:08]
[13:25:08] Project: 2684 (Run 7, Clone 4, Gen 0)
[13:25:08]
[13:25:08] Assembly optimizations on if available.
[13:25:08] Entering M.D.
[13:25:21] Completed 0 out of 250000 steps  (0%)
[14:12:48] Completed 2500 out of 250000 steps  (1%)
[15:00:25] Completed 5000 out of 250000 steps  (2%)
[15:47:53] Completed 7500 out of 250000 steps  (3%)
[16:35:23] Completed 10000 out of 250000 steps  (4%)
[17:22:50] Completed 12500 out of 250000 steps  (5%)
[18:10:07] Completed 15000 out of 250000 steps  (6%)
[18:57:24] Completed 17500 out of 250000 steps  (7%)
[19:44:46] Completed 20000 out of 250000 steps  (8%)
[20:32:02] Completed 22500 out of 250000 steps  (9%)
[21:19:20] Completed 25000 out of 250000 steps  (10%)
[22:06:53] Completed 27500 out of 250000 steps  (11%)
[22:54:18] Completed 30000 out of 250000 steps  (12%)
[23:41:42] Completed 32500 out of 250000 steps  (13%)
[00:29:30] Completed 35000 out of 250000 steps  (14%)
[01:17:04] Completed 37500 out of 250000 steps  (15%)
[02:04:48] Completed 40000 out of 250000 steps  (16%)
[02:52:10] Completed 42500 out of 250000 steps  (17%)
[03:39:47] Completed 45000 out of 250000 steps  (18%)
[04:27:17] Completed 47500 out of 250000 steps  (19%)
[05:14:36] Completed 50000 out of 250000 steps  (20%)
[06:02:01] Completed 52500 out of 250000 steps  (21%)
[06:49:29] Completed 55000 out of 250000 steps  (22%)
[07:36:57] Completed 57500 out of 250000 steps  (23%)
[08:24:17] Completed 60000 out of 250000 steps  (24%)
[09:11:47] Completed 62500 out of 250000 steps  (25%)
[09:59:16] Completed 65000 out of 250000 steps  (26%)
[10:46:35] Completed 67500 out of 250000 steps  (27%)
[11:34:00] Completed 70000 out of 250000 steps  (28%)
[12:21:27] Completed 72500 out of 250000 steps  (29%)
[13:09:10] Completed 75000 out of 250000 steps  (30%)
[13:56:52] Completed 77500 out of 250000 steps  (31%)
[14:44:16] Completed 80000 out of 250000 steps  (32%)
[15:31:37] Completed 82500 out of 250000 steps  (33%)
[16:18:56] Completed 85000 out of 250000 steps  (34%)
[17:06:08] Completed 87500 out of 250000 steps  (35%)
[17:53:21] Completed 90000 out of 250000 steps  (36%)
[18:40:38] Completed 92500 out of 250000 steps  (37%)
[19:28:17] Completed 95000 out of 250000 steps  (38%)
[20:15:37] Completed 97500 out of 250000 steps  (39%)
[21:03:11] Completed 100000 out of 250000 steps  (40%)
[21:50:33] Completed 102500 out of 250000 steps  (41%)
[22:18:11] mdrun returned 255
[22:18:11] Going to send back what have done -- stepsTotalG=250000
[22:18:11] Work fraction=0.0000 steps=250000.
[22:18:15] logfile size=85859 infoLength=85859 edr=25 trr=1
[22:18:15] logfile size: 85859 info=85859 bed=25 hdr=1
[22:18:15] - Writing 86397 bytes of core data to disk...
[22:18:16]   ... Done.
[22:33:49]
[22:33:49] Folding@home Core Shutdown: UNSTABLE_MACHINE
[22:33:49] CoreStatus = 7A (122)
[22:33:49] Sending work to server
[22:33:49] Project: 2684 (Run 7, Clone 4, Gen 0)
[22:33:49] + Attempting to send results [May 30 22:33:49 UTC]
[22:33:52] + Results successfully sent
[22:33:52] Thank you for your contribution to Folding@Home.
[22:33:52] - Preparing to get new work unit...
[22:33:52] Cleaning up work directory
[22:33:52] + Attempting to get work packet
[22:33:52] Passkey found
[22:33:52] - Connecting to assignment server
[22:33:53] - Successful: assigned to (171.67.108.22).
[22:33:53] + News From Folding@Home: Welcome to Folding@Home
[22:33:53] Loaded queue successfully.
[22:33:54] - Attempt #1  to get work failed, and no other work to do.
[22:34:00] + Attempting to get work packet
[22:34:00] Passkey found
[22:34:00] - Connecting to assignment server
[22:34:01] - Successful: assigned to (171.67.108.22).
[22:34:01] + News From Folding@Home: Welcome to Folding@Home
[22:34:01] Loaded queue successfully.
[22:34:02] - Attempt #2  to get work failed, and no other work to do.
Waiting before retry.
[22:34:25] + Attempting to get work packet
[22:34:25] Passkey found
[22:34:25] - Connecting to assignment server
[22:34:25] - Successful: assigned to (171.67.108.22).
[22:34:25] + News From Folding@Home: Welcome to Folding@Home
[22:34:25] Loaded queue successfully.
[22:34:27] - Attempt #3  to get work failed, and no other work to do.
[22:34:58] + Attempting to get work packet
[22:34:58] Passkey found
[22:34:58] - Connecting to assignment server
[22:34:58] - Successful: assigned to (171.67.108.22).
[22:34:58] + News From Folding@Home: Welcome to Folding@Home
[22:34:59] Loaded queue successfully.
[22:35:00] - Attempt #4  to get work failed, and no other work to do.
[22:35:45] + Attempting to get work packet
[22:35:45] Passkey found
[22:35:45] - Connecting to assignment server
[22:35:45] - Successful: assigned to (171.67.108.22).
[22:35:45] + News From Folding@Home: Welcome to Folding@Home
[22:35:46] Loaded queue successfully.
[22:35:47] - Attempt #5  to get work failed, and no other work to do.
[22:37:19] + Attempting to get work packet
[22:37:19] Passkey found
[22:37:19] - Connecting to assignment server
[22:37:20] - Successful: assigned to (171.67.108.22).
[22:37:20] + News From Folding@Home: Welcome to Folding@Home
[22:37:20] Loaded queue successfully.
[22:37:21] - Attempt #6  to get work failed, and no other work to do.
[22:40:12] + Attempting to get work packet
[22:40:12] Passkey found
[22:40:12] - Connecting to assignment server
[22:40:12] - Successful: assigned to (171.67.108.22).
[22:40:12] + News From Folding@Home: Welcome to Folding@Home
[22:40:13] Loaded queue successfully.
[22:40:14] - Attempt #7  to get work failed, and no other work to do.
[22:45:45] + Attempting to get work packet
[22:45:45] Passkey found
[22:45:45] - Connecting to assignment server
[22:45:45] - Successful: assigned to (171.67.108.22).
[22:45:45] + News From Folding@Home: Welcome to Folding@Home
[22:45:45] Loaded queue successfully.
[22:45:47] - Attempt #8  to get work failed, and no other work to do.
[22:56:39] + Attempting to get work packet
[22:56:39] Passkey found
[22:56:39] - Connecting to assignment server
[22:56:40] - Successful: assigned to (171.67.108.22).
[22:56:40] + News From Folding@Home: Welcome to Folding@Home
[22:56:40] Loaded queue successfully.
[22:56:41] - Attempt #9  to get work failed, and no other work to do.
[23:18:04] + Attempting to get work packet
[23:18:04] Passkey found
[23:18:04] - Connecting to assignment server
[23:18:05] - Successful: assigned to (171.67.108.22).
[23:18:05] + News From Folding@Home: Welcome to Folding@Home
[23:18:05] Loaded queue successfully.
[23:18:07] - Attempt #10  to get work failed, and no other work to do.
[00:00:54] + Attempting to get work packet
[00:00:54] Passkey found
[00:00:54] - Connecting to assignment server
[00:00:55] - Successful: assigned to (171.67.108.22).
[00:00:55] + News From Folding@Home: Welcome to Folding@Home
[00:00:55] Loaded queue successfully.
[00:00:56] - Attempt #11  to get work failed, and no other work to do.
[00:49:00] + Attempting to get work packet
[00:49:00] Passkey found
[00:49:00] - Connecting to assignment server
[00:49:00] - Successful: assigned to (171.67.108.22).
[00:49:00] + News From Folding@Home: Welcome to Folding@Home
[00:49:00] Loaded queue successfully.
[00:49:02] - Attempt #12  to get work failed, and no other work to do.
--- Opening Log file [May 31 01:39:15 UTC]
This is from the recent log, I spent 2 days trying to get a WU from this rascal before I restarted and got another WU. Then it was an _a3 core that failed and now this.
sgb101
Could not connect to 171.67.108.22 ?
Post by sgb101 »
i compleated the above WU at around 5.30 this morning but as of now (10.05) is still trying to sent the results back.
im now getting the msg
could not connect to server
(171.67.108.22.8080)
retrying using alternative port.
i would put a log in but my folding pc is not with me i monitor it via teamviewer from work, and am not sure how to find the logs. i use a FAH image, running in vmware, within win7.
heres abit more info
Parallel run – timing based on wall clock
(Mnbf/s) (GFlops) (ns/day) (hours/ns)
Performance 420.909 22.957 0.401 59.828
i5 750@3.47-4Gb ddr3-HD5850-Win 7 64bit
i7 920@3.87-6Gb ddr3-9800GT- Win7 64bit
Re: Project2683 Run0 Clone3 Gen85
It's not an issue with a specific WU ... it's an issue with a specific server ...
Let's move this thread to the right place.
As far as I can tell, this server is working :
171.67.108.22 classic vsp16v kasson full Accepting
sgb101
Re: Could not connect to 171.67.108.22 ?
Post by sgb101 »
just checked back in with and it has now uploaded the completed WU. But any ideas why it took so long, 6 hours in total!
ts good to see you mods are on the ball, otherwise this place would be a mess :roll:
Do you have a slow upload speed ?
I think someont reported that the server might take quite a while to acknoledge a successful return too, and we don't know why :(
Most of the time a WU is uploaded promptly when it finishes processing. If there happens to be a disruption in communications (server is down or too busy, your ISP is down, your laptop isn't connected at the moment, etc.) the client is designed to hold the results in a local queue and retry uploading later. The client will retry the upload every 6 hours or less, depending on what it's doing.
In other words, it's perfectly normal.
Posting the log showing what happened when the WU finished as well as 6 hours later might give some clue as to what happened but that's not particularly important since it already uploaded successfully.
