Server 171.65.103.160
Superhero2k
Post by Superhero2k »
Hey folks,
i´m new to folding@home and just completed my first WU. Unfortunately the upload of data seems to be impossible. Systray icon keeps saying "Attempting to send results."
Here is what my logfile says:
--- Opening Log file [May 28 08:28:50 UTC]
# Windows CPU Systray Edition #################################################
                          http://folding.stanford.edu
Launch directory: C:\Dokumente und Einstellungen\usera\Anwendungsdaten\Folding@home-x86
Arguments: -verbosity 9
[08:28:50] - Ask before connecting: No
[08:28:50] - User name: Superhero2k (Team 0)
[08:28:50] - User ID: 2C8F5ED67B466264
[08:28:50] - Machine ID: 1
[08:28:50]
[08:28:50] Loaded queue successfully.
[08:28:51] Initialization complete
[08:28:51]
[08:28:51] + Processing work unit
[08:28:51] - Autosending finished units... [May 28 08:28:51 UTC]
[08:28:51] Trying to send all finished work units
[08:28:51] Project: 2494 (Run 127, Clone 23, Gen 3)
[08:28:51] - Read packet limit of 540015616... Set to 524286976.
[08:28:51] + Attempting to send results [May 28 08:28:51 UTC]
[08:28:51] Core required: FahCore_a0.exe
[08:28:51] Core found.
[08:28:51] - Reading file work/wuresults_01.dat from core
[08:28:51] Working on queue slot 02 [May 28 08:28:51 UTC]
[08:28:51] + Working ...
[08:28:51]   (Read 2660896 bytes from disk)
[08:28:51] Connecting to http://171.65.103.160:80/
[08:28:51] - Calling '.\FahCore_a0.exe -dir work/ -suffix 02 -checkpoint 5 -verbose -lifeline 1668 -version 623'
[08:28:51]
[08:28:51] *------------------------------*
[08:28:51] Folding@Home Gromacs 3.3 Core
[08:28:51] Version 1.93 (July 23, 2008)
[08:28:51]
[08:28:51] Preparing to commence simulation
[08:28:51] - Looking at optimizations...
[08:28:51] - Files status OK
[08:28:51] - Expanded 1129416 -> 5930189 (decompressed 525.0 percent)
[08:28:51]
[08:28:51] Project: 1797 (Run 27, Clone 17, Gen 2)
[08:28:51]
[08:28:51] Assembly optimizations on if available.
[08:28:51] Entering M.D.
[08:28:58] FAH Init
[08:28:58] Checkpoint file:
[08:29:02] (Starting from checkpoint)
[08:29:02] Read checkpoint
[08:29:02] Protein: 41361
[08:29:02] Writing local files
[08:29:04] Completed 71150 out of 500000 steps  (14 percent)
[08:29:04] Extra SSE boost OK.
[08:29:09] - Couldn't send HTTP request to server
[08:29:09] + Could not connect to Work Server (results)
[08:29:09]     (171.65.103.160:80)
[08:29:09] + Retrying using alternative port
[08:29:09] Connecting to http://171.65.103.160:8080/
[08:29:10] - Couldn't send HTTP request to server
[08:29:10] + Could not connect to Work Server (results)
[08:29:10]     (171.65.103.160:8080)
[08:29:10] - Error: Could not transmit unit 01 (completed May 27) to work server.
[08:29:10] - 7 failed uploads of this unit.
[08:29:10] - Read packet limit of 540015616... Set to 524286976.
[08:29:10] + Attempting to send results [May 28 08:29:10 UTC]
[08:29:10] - Reading file work/wuresults_01.dat from core
[08:29:10]   (Read 2660896 bytes from disk)
[08:29:10] Connecting to http://171.67.108.17:80/
[08:29:11] - Couldn't send HTTP request to server
[08:29:11]   (Got status 503)
[08:29:11] + Could not connect to Work Server (results)
[08:29:11]     (171.67.108.17:80)
[08:29:11] + Retrying using alternative port
[08:29:11] Connecting to http://171.67.108.17:8080/
[08:29:12] - Couldn't send HTTP request to server
[08:29:12] + Could not connect to Work Server (results)
[08:29:12]     (171.67.108.17:8080)
[08:29:12]   Could not transmit unit 01 to Collection server; keeping in queue.
[08:29:12] + Sent 0 of 1 completed units to the server
[08:29:12] - Autosend completed
[08:34:04] Timered checkpoint triggered.
Am I doing something wrong?
Thanks in advance for any help!
Re: Servers 171.64.65.111 and 171.67.108.17
Superhero2k wrote:Hey folks,
Welcome to the Foldingcommunity, Superhero2k.
The only thing you did wrong was post in the wrong topic -- but that's easily fixed -- and I've got to give you credit for trying.
The fundamental problem is that the result needs to be returned to server 171.65.103.160 and it's currently rejecting connections, so it's not something you did wrong. (The Do this first topic contains some help in how to diagnose and report this sort of problem.) I'll make sure the owner of that server has noticed the problem.
