20:32:56] Successful run
[20:32:56] DynamicWrapper: Finished Work Unit: sleep=10000
[20:33:06] Reserved 109012 bytes for xtc file; Cosm status=0
[20:33:06] Allocated 109012 bytes for xtc file
[20:33:06] - Reading up to 109012 from "work/wudata_08.xtc": Read 109012
[20:33:06] Read 109012 bytes from xtc file; available packet space=786321452
[20:33:06] xtc file hash check passed.
[20:33:06] Reserved 21912 21912 786321452 bytes for arc file=<work/wudata_08.trr> Cosm status=0
[20:33:06] Allocated 21912 bytes for arc file
[20:33:06] - Reading up to 21912 from "work/wudata_08.trr": Read 21912
[20:33:06] Read 21912 bytes from arc file; available packet space=786299540
[20:33:06] trr file hash check passed.
[20:33:06] Allocated 560 bytes for edr file
[20:33:06] Read bedfile
[20:33:06] edr file hash check passed.
[20:33:06] Logfile not read.
[20:33:06] GuardedRun: success in DynamicWrapper
[20:33:06] GuardedRun: done
[20:33:06] Run: GuardedRun completed.
[20:33:09] + Opened results file
[20:33:09] - Writing 131996 bytes of core data to disk...
[20:33:09] Done: 131484 -> 130469 (compressed to 99.2 percent)
[20:33:09] ... Done.
[20:33:09] DeleteFrameFiles: successfully deleted file=work/wudata_08.ckp
[20:33:09] Shutting down core
[20:33:09]
[20:33:09] Folding@home Core Shutdown: FINISHED_UNIT
[20:33:12] CoreStatus = 64 (100)
[20:33:12] Sending work to server
[20:33:12] Project: 10503 (Run 358, Clone 0, Gen 83)
[20:33:12] - Read packet limit of 540015616... Set to 524286976.
[20:33:12] + Attempting to send results [May 17 20:33:12 UTC]
[21:06:21] + Could not connect to Work Server (results)
[21:06:21] (171.67.108.21:8080)
[21:06:21] + Retrying using alternative port
[21:06:22] - Couldn't send HTTP request to server
[21:06:22] + Could not connect to Work Server (results)
[21:06:22] (171.67.108.21:80)
[21:06:22] - Error: Could not transmit unit 08 (completed May 17) to work server.
[21:06:22] Keeping unit 08 in queue.
[21:06:22] Project: 10503 (Run 358, Clone 0, Gen 83)
[21:06:22] - Read packet limit of 540015616... Set to 524286976.
[21:06:22] + Attempting to send results [May 17 21:06:22 UTC]
[21:06:23] - Couldn't send HTTP request to server
[21:06:23] + Could not connect to Work Server (results)
[21:06:23] (171.67.108.21:8080)
[21:06:23] + Retrying using alternative port
[21:06:24] - Couldn't send HTTP request to server
[21:06:24] + Could not connect to Work Server (results)
[21:06:24] (171.67.108.21:80)
[21:06:24] - Error: Could not transmit unit 08 (completed May 17) to work server.
[21:06:24] - Read packet limit of 540015616... Set to 524286976.
[21:06:24] + Attempting to send results [May 17 21:06:24 UTC]
[21:06:27] - Server does not have record of this unit. Will try again later.
[21:06:27] Could not transmit unit 08 to Collection server; keeping in queue.
[21:06:27] - Preparing to get new work unit...
[21:06:27] + Attempting to get work packet
After half an hour hang, server doesn't have record of this unit
