Project: 5746 (Run 1, Clone 86, Gen 944)
Hermes
Post by Hermes »
Failed to start 6 times. Example:
[16:53:38] Folding@Home GPU Core - Beta
[16:53:38] Version 1.24 (Mon Feb 9 11:00:12 PST 2009)
[16:53:38]
[16:53:38] Compiler  : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[16:53:38] Build host: amoeba
[16:53:38] Board Type: AMD
[16:53:38] Core      :
[16:53:38] Preparing to commence simulation
[16:53:38] - Looking at optimizations...
[16:53:38] - Created dyn
[16:53:38] - Files status OK
[16:53:38] - Expanded 68582 -> 357580 (decompressed 521.3 percent)
[16:53:38] Called DecompressByteArray: compressed_data_size=68582 data_size=357580, decompressed_data_size=357580 diff=0
[16:53:38] - Digital signature verified
[16:53:38]
[16:53:38] Project: 5746 (Run 1, Clone 86, Gen 944)
[16:53:38]
[16:53:38] Assembly optimizations on if available.
[16:53:38] Entering M.D.
[16:53:44] Tpr hash work/wudata_05.tpr:  309737052 361190200 2249294624 1417398607 3170539707
[16:53:44] Working on Protein
[16:53:44] Client config found, loading data.
[16:53:44] Starting GUI Server
[16:53:50] mdrun_gpu returned
[16:53:50] Nonzero force sum on GPU
[16:53:50]
[16:53:50] Folding@home Core Shutdown: UNSTABLE_MACHINE
[16:53:54] CoreStatus = 7A (122)
[16:53:54] Sending work to server
[16:53:54] Project: 5746 (Run 1, Clone 86, Gen 944)
[16:53:54] - Read packet limit of 540015616... Set to 524286976.
[16:53:54] - Error: Could not get length of results file work/wuresults_05.dat
[16:53:54] - Error: Could not read unit 05 file. Removing from queue.
[16:53:54] EUE limit exceeded. Pausing 24 hours.
Re: Project: 5746 (Run 1, Clone 86, Gen 944)
Many similar reports of immediate EUE ... I marked it as bad.
