WU Frame Amount Different From Amount of Frames Observed
Locked
geokilla
Hardware configuration: Intel Core i5-10600KF @ 4.9Ghz @ 1.25V
MSI Z490 Gaming Edge Wi-Fi BIOS v17
XPG D50 32GB DDR4-3200 16-19-9-36 2T (Samsung M-Die)
XPG S11 Pro 1TB and Western Digital WD140EDFZ 14TB
EVGA RTX 3060 XC
Corsair RM650x
Phantek P360A with Noctua Exhaust Fans
Post by geokilla »
According to HFM, the WU has only 100 frames. Why is it that the number of frames observed is usually higher or lower than the amount of frames for a WU? Take the following for example.
 Project ID: 6020
 Core: GRO-A3
 Credit: 467
 Frames: 100
 Path: C:\Folding@Home\CPU\
 Number of Frames Observed: 46
 Min. Time / Frame : 00:09:47 - 2,888.8 PPD
 Avg. Time / Frame : 00:11:23 - 2,301.7 PPD
 Path: \\VALERIE-PC\Folding\
 Number of Frames Observed: 190
 Min. Time / Frame : 00:18:17 - 1,130.8 PPD
 Avg. Time / Frame : 00:21:25 - 891.9 PPD
ASUS TUF RTX 3070 OC
Corsair RM650x
Wrish
Re: WU Frame Amount Different From Amount of Frames Observed
Post by Wrish »
HFM will benchmark whatever it can sample, up to the 300 most recent frames for a client/project combination. If you started HFM when a log file was showing a work unit resuming at 54% and eventually finishing, HFM will see just 46 frames worth of times.
Please use the tool official thread for this kind of questions : viewtopic.php?f=14&t=9903
Locked
