Really un-professional
*hondo*
- Hardware configuration: Geoforce 250 GTS Active for F@H
4 Core Intel not used at all for F@H - Location: England UK
After starting a team = 51078 I'm beginning to wonder why I bother, having lost heaven knows how many points through server problems a couple of weeks ago it's getting to be one problem after another.
What happened to not having to baby sit F@H ?
[23:35:09] + Attempting to send results [March 10 23:35:09 UTC]
[23:35:10] - Couldn't send HTTP request to server
[23:35:10] + Could not connect to Work Server (results)
[23:35:10] (171.64.65.71:8080)
[23:35:10] + Retrying using alternative port
[23:35:23] - Couldn't send HTTP request to server
[23:35:23] + Could not connect to Work Server (results)
[23:35:23] (171.64.65.71:80)
[23:35:23] - Error: Could not transmit unit 05 (completed March 10) to work server.
[09:40:29] + Attempting to send results [March 11 09:40:29 UTC]
[09:40:31] - Couldn't send HTTP request to server
[09:40:31] + Could not connect to Work Server (results)
[09:40:31] (171.64.65.71:8080)
[09:40:31] + Retrying using alternative port
[09:40:32] - Couldn't send HTTP request to server
[09:40:32] + Could not connect to Work Server (results)
[09:40:32] (171.64.65.71:80)
[09:40:32] - Error: Could not transmit unit 05 (completed March 10) to work server.
patonb
- Hardware configuration: WooHoo= SR-2 -- L5639 @ ?? -- Evga 560ti FPB -- 12Gig Corsair XMS3 -- Corsair 1050hx -- Blackhawk Ultra
Re: Really un-professional
This seems to possibly be your side issue. The client can't send a http out.
Have you recently updated your firewall, or network settings?
That server is "not accepting" at the moment. And I agree, it's a pain. The servers are unacceptably unreliable and this seems to me to be unnecessary. It is utterly normal in commercial environments to have server uptimes measured in years.
single 1070
*hondo*
Nope, I've even tried unsuccessfully running without the firewall.patonb wrote:This seems to possibly be your side issue. The client can't send a http out.
patonb
thing is, he's not getting the initial request sent out.HaloJones wrote:That server is "not accepting" at the moment. And I agree, it's a pain. The servers are unacceptably unreliable and this seems to me to be unnecessary. It is utterly normal in commercial environments to have server uptimes measured in years.
Hondo...... Is it all the time or every so often?
*hondo*
Hi patonb
I'm not sure I know what you mean sori. it's not now happening with all WUs just the odd one. What freaks me out I'd got stacks queued a couple of weeks ago, I then did think the problem was my end & went for a full re-install & obviously therefore lost the lot.
Thanx for the reply
TBH It's beginning to seem to me like someone just isn't taking ownership for these ongoing problems
Thanx for the reply
Yes it seems to be an ongoing problem. The last four or five months have been truly horrible for smp folding. I can understand if they ran out of units but seeing them fail to transmit is irritating. It wouldn't be so bad if it didn't grind all other Internet activity to a halt.
Grandpa_01
- Hardware configuration: 3 - Supermicro H8QGi-F AMD MC 6174=144 cores 2.5Ghz, 96GB G.Skill DDR3 1333Mhz Ubuntu 10.10
pluto7777 wrote:Yes it seems to be an ongoing problem. The last four or five months have been truly horrible for smp folding. I can understand if they ran out of units but seeing them fail to transmit is irritating. It wouldn't be so bad if it didn't grind all other Internet activity to a halt.
Just curious but what is happening that is grinding your Internet activity to a halt. What kind of connection do you have?
2 - I7 980X 4.4Ghz 2-GTX680
1 - 2700k 4.4Ghz GTX680
Total = 464 cores folding
Road Runner cable. According to speedtest.net upload speed is .30mbps which I'm sure is poor. Since ~Nov 09 I usually have one to three finished work units rechecking the work server at any given time.Grandpa_01 wrote:Just curious but what is happening that is grinding your Internet activity to a halt. What kind of connection do you have?
P5-133XL
Machine #2:
Machine 3:
That behavior has always been a problem with folding. I can remember asking for a BW limiter feature added to the uniprocessor client when there was only just the uniprocessor client. The discussion at the time indicated that slowing things down couldn't be done for fear that the number of open sessions would overwhelm the databases. When folding gets or sends data to and from the servers it uses as much of the BW it can and that has nothing to do with the type of connection or the provider. The normal solution, if it is an actual problem (like for real time gaming) for an individual has been to install with QOS either via router or software.Grandpa_01 wrote:Just curious but what is happening that is grinding your Internet activity to a halt. What kind of connection do you have?
Is this discussion still on topic? I don't understand how several of the recent questions can be classified as "Really un-professional"
How about starting a new topic when you have an issue that you'd like help with?
